H3C iMC License Matrixes-5W104
HomeSupportNetwork Operations & ManagementIntelligent Management Center 7Install & UpgradeLicensing GuidesH3C iMC License Matrixes-5W104
Title Size Downloads
H3C iMC License Matrixes-5W104-Book.pdf 236.33 KB
Table of Contents
Related Documents
Book
Book 236.33 KB
Some of the features for H3C iMC are license-based. To use these features, you must install licenses for them. This document provides information about the license-based features and licenses available for them. For information about registering, installing, or managing a license, see H3C Intelligent Management Center Licensing Guide.
IMPORTANT
IMPORTANT:
License-based features and attributes of licenses might change with software version over time. This document contains information about only licenses for software versions shipped and some of the information might change over time. To obtain the most up-to-date information about licenses or information about licenses for software versions not listed in this document, contact your H3C sales representative or contact H3C Support.
IMPORTANT
IMPORTANT:
·     iMC licenses support local licensing and remote licensing. Remote licensing is implemented through iLP.
·     As a best practice, use local licensing when you request a license for the PLAT professional edition (replacement for intelligent management platform standard edition).
·     The UBA component calculates the number of used UBA licenses based on the number of user source IP addresses. License overuse might cause a loss of audit data. As a best practice to avoid this risk, plan the use of the UBA component appropriately.
·     The DR1000 component can be deployed separately, and does not need to request licenses for the other components. To license any other application-driven component, you must first request licenses for DR2000. Table 4 shows the licenses for the application-driven components.
·     To license an iMC service component, you must first request licenses for the iMC Intelligent Management Platform. Table 2 shows the licenses for the iMC platform and Table 3 shows the licenses for iMC service components.
·     When the iMC platform and its service components use the hierarchal licensing function, the upper-level NMS must use the H3C iMC Intelligent Management Platform Professional Edition license or the H3C iMC Intelligent Management Platform Professional Edition (Replacement for Intelligent Management Platform Standard Edition) license. If the upper-level NMS has been registered with the standard edition license, perform one of the following tasks:
¡     First uninstall the standard edition license, and then register the H3C iMC Intelligent Management Platform Professional Edition license.
¡     Upgrade the standard edition license to the H3C iMC Intelligent Management Platform Professional Edition (Replacement for Intelligent Management Platform Standard Edition) license.
·     To request the quantity licenses and feature licenses for a component, you must first request the basic licenses for the component.
·     You can mix the H3C iMC Intelligent Management Platform Standard Edition licenses and the H3C iMC Intelligent Management Platform Professional Edition Licenses. For more information about license dependencies, see Table 2. When you mix the licenses, the effective licenses and supported licensed nodes are as follows:
¡     The basic license for PLAT professional edition has higher priority than the basic license for PLAT standard edition. If both the basic license for PLAT professional edition and the basic license for PLAT professional edition (replacement for intelligent management platform standard edition) exist, the former license takes effect. The maximum number of nodes that can be licensed is the sum of the following values: the capacity of the quantity license for the PLAT professional edition + the smaller value from the capacity of the quantity license for the PLAT professional edition (replacement for intelligent management platform standard edition) and the capacity of the quantity license for the PLAT standard edition. If a type of license does not exist, the capacity of the license is 0.
¡     If only the basic license for the PLAT standard edition is installed, the license takes effect. The quantity license for the PLAT professional edition is downgraded as a quantity license for the PLAT standard edition.
¡     For the same type of licenses, the validity period for trial licenses is the shortest validity period among all effective trial licenses.
·     This system supports preinstalled licenses, trial licenses, and formal licenses. For more information, see Table 1.
Table 1 License types
License type
Validity period
License uninstallation and transfer
Remarks
Formal license
Permanent
Licenses by remote licensing can be uninstalled and transferred.
Licenses by local licensing cannot be uninstalled or transferred.
When you purchase a formal license, identify whether the license has a validity period. The start time of formal license validity period (if any) is the date and time when the activation file for the license is generated on the license management platform. If the formal license has a validity period, to ensure service continuity, you must purchase and install a new formal license before the formal license expires.
Trial (temporary) license
30/60/90 days
A trial license cannot be uninstalled or transferred.
A trial license is time limited. The start time of license validity period is the date and time when the activation file for the license is generated on the license management platform. When a trial license expires, the license-based feature becomes unavailable. To continue to use the feature, you must purchase and install a formal license for it.
Preinstalled license
45 days
A preinstalled license cannot be uninstalled or transferred.
A preinstalled license is time limited. When the product software starts to run, the validity period of the preinstalled license-based feature starts to count down. To try a preinstalled license-based feature, please pay attention to the validity period. When the preinstalled license expires, the preinstalled license-based feature becomes unavailable. To formally use the license-based feature, purchase and install a formal license.
The product category for the iMC software products is NMS_IMC&U-CenterLicenseServer. Table 2 shows the licenses for the iMC platform.
Table 2 iMC license matrix (iMC PLAT)
Component
License description
Product code
Product description
Depends on
Versions that support local licensing
Versions that support remote licensing
PLAT
Basic license for PLAT standard edition
SWP-IMC7-IMP
H3C iMC, Intelligent Management Platform Standard Edition
N/A
All versions
All versions
LIS-UCENTER-IOM-HM
H3C iMC, Intelligent Management Platform Standard Edition License
N/A
E0703P07 and later
E0703P07 and later
Quantity license for PLAT standard edition
LIS-IMC7-IMPA-25
H3C iMC, Intelligent Management Platform Standard Edition, 25 Licenses
All versions
All versions
LIS-IMC7-IMPB-50
H3C iMC, Intelligent Management Platform Standard Edition, 50 Licenses
All versions
All versions
LIS-IMC7-IMPC-100
H3C iMC, Intelligent Management Platform Standard Edition,  100 Licenses
All versions
All versions
LIS-IMC7-IMPD-200
H3C iMC, Intelligent Management Platform Standard Edition, 200 Licenses
All versions
All versions
LIS-IMC7-IMPE-500
H3C iMC, Intelligent Management Platform Standard Edition, 500 Licenses
All versions
All versions
LIS-IMC7-IMPF-1K
H3C iMC, Intelligent Management Platform Standard Edition,  1000 Licenses
All versions
All versions
Basic license for PLAT professional edition
SWP-IMC7-IMP-PFS
H3C iMC, Intelligent Management Platform Professional Edition, Software (DVD9)
N/A
All versions
All versions
Quantity license for PLAT professional edition
LIS-IMC7-IMPA-PFS-25
H3C iMC, Intelligent Management Platform Professional Edition, 25 Licenses
This license depends on one of the following licenses or license combination:
·     Basic license for PLAT professional edition
·     Basic license for PLAT professional edition (replacement for intelligent management platform standard edition) + Basic license for PLAT standard edition
All versions
All versions
LIS-IMC7-IMPB-PFS-50
H3C iMC, Intelligent Management Platform Professional Edition, 50 Licenses
All versions
All versions
LIS-IMC7-IMPC-PFS-100
H3C iMC, Intelligent Management Platform Professional Edition, 100 Licenses
All versions
All versions
LIS-IMC7-IMPD-PFS-200
H3C iMC, Intelligent Management Platform Professional Edition, 200 Licenses
All versions
All versions
LIS-IMC7-IMPE-PFS-500
H3C iMC, Intelligent Management Platform Professional Edition, 500 Licenses
All versions
All versions
LIS-IMC7-IMPF-PFS-1K
H3C iMC, Intelligent Management Platform Professional Edition, 1000 Licenses
All versions
All versions
SWP-IMC7-IMP-PFS-T
H3C iMC, Intelligent Management Platform Professional Edition (Replacement for Intelligent Management Platform Standard Edition)
All versions
All versions
Quantity license for PLAT professional edition (replacement for intelligent management platform standard edition)
LIS-IMC7-IMPC-PFS-T-100
H3C iMC, Intelligent Management Platform Professional Edition (Replacement for Intelligent Management Platform Standard Edition), 100 Licenses
·     Basic license for PLAT professional edition (replacement for intelligent management platform standard edition) + Basic license for PLAT standard edition + Quantity license for PLAT standard edition
·     Basic license for PLAT professional edition + Quantity license for PLAT standard edition
All versions
All versions
The product category for the iMC software products is NMS_IMC&U-CenterLicenseServer. Table 3 shows the licenses for iMC service components.
Table 3 iMC license matrix (iMC service components)
Component
License description
Product code
Product description
QoSM
QoSM license
SWP-IMC7-QOSM
H3C iMC, QoS Manager Component
All versions
E0502 and later
MVM
Basic license for MVM
SWP-IMC7-MVM
H3C iMC, MPLS VPN Manager Component (50 Licenses)
All versions
E0501 and later
Quantity license for MVM
LIS-IMC7-MVMA-50
H3C iMC, MPLS VPN Manager Component, 50 Licenses
All versions
E0501 and later
LIS-IMC7-MVMB-100
H3C iMC, MPLS VPN Manager Component, 100 Licenses
All versions
E0501 and later
LIS-IMC7-MVMC-200
H3C iMC, MPLS VPN Manager Component, 200 Licenses
All versions
E0501 and later
LIS-IMC7-MVMD-500
H3C iMC, MPLS VPN Manager Component, 500 Licenses
All versions
E0501 and later
LIS-IMC7-MVME-1K
H3C iMC, MPLS VPN Manager Component, 1000 Licenses
All versions
E0501 and later
LIS-IMC7-MVMF-3K
H3C iMC, MPLS VPN Manager Component, 3000 Licenses
All versions
E0501 and later
LIS-IMC7-MVMG-UR
H3C iMC, MPLS VPN Manager Component, Unlimited Licenses
All versions
E0501 and later
MVM BGP/MPLS VPN manager license
LIS-IMC7-MVM-B
H3C iMC, MPLS VPN Manager Component, BGP/MPLS VPN Manager License
All versions
E0501 and later
MVM VPLS/MPLS VPN manager license
LIS-IMC7-MVM-V
H3C iMC, MPLS VPN Manager Component, VPLS/MPLS VPN Manager License
All versions
E0501 and later
MVM route detection and prediction license
LIS-IMC7-MVM-RDP
H3C iMC, MPLS VPN Manager Component, Route Detection and Prediction License
All versions
Not supported
MVM MPLS TE manager license
LIS-IMC7-MVM-TE
H3C iMC, MPLS VPN Manager Component, MPLS TE Manager License
All versions
Not supported
MVM Cisco device BGP/MPLS VPN manager license
LIS-IMC7-MVM-C
H3C iMC, MPLS VPN Manager Component, Cisco Device BGP/MPLS VPN Manager License
All versions
E0501 and later
U-Center
U-Center license
SWP-UCENTER-IOP
H3C UCenter, Intelligent Operations Platform Software
E0510P08 and later
E0510P08 and later
Basic license for IOM application management
SWP-IMC7-APM
H3C UCenter, IOM, Application Management Component
E0510P08 and later
E0510P08 and later
Quantity license for IOM application management
LIS-UCENTER-IOM-AA-25
H3C UCenter, IOM, Application, 25 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-AB-50
H3C UCenter, IOM, Application, 50 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-AC-100
H3C UCenter, IOM, Application, 100 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-AD-200
H3C UCenter, IOM, Application, 200 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-AE-500
H3C UCenter, IOM, Application, 500 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-AF-1K
H3C UCenter, IOM, Application, 1000 Licenses
E0510P08 and later
E0510P08 and later
IOM host license
LIS-UCENTER-IOM-VA-10
H3C UCenter, IOM, Host, 10 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-VB-100
H3C UCenter, IOM, Host, 100 Licenses
E0510P08 and later
E0510P08 and later
IOM physical server license
LIS-UCENTER-IOM-FA-10
H3C UCenter, IOM, Physical Server, 10 Licenses
E0510P08 and later
E0510P08 and later
LIS-UCENTER-IOM-FB-100
H3C UCenter, IOM, Physical Server, 100 Licenses
E0510P08 and later
E0510P08 and later
EAD
Basic license for EAD
SWP-IMC7-EAD
H3C iMC, End-user Admission Defense Component
E0611P05 and later
E0611P05 and later
Quantity license for EAD
LIS-IMC7-EADF-50
H3C iMC, End-user Admission Defense Component, 50 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EADA-200
H3C iMC, End-user Admission Defense Component, 200 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EADB-500
H3C iMC, End-user Admission Defense Component, 500 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EADD-2K
H3C iMC, End-user Admission Defense Component, 2000 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EADE-5K
H3C iMC, End-user Admission Defense Component, 5000 Licenses
E0611P05 and later
E0611P05 and later
EIA
Basic license for EIA
SWP-IMC7-EIA
H3C iMC, End-user Intelligent Access Component
E0611P05 and later
E0611P05 and later
Quantity license for EIA
LIS-IMC7-EIAA-50
H3C iMC, End-user Intelligent Access Component, 50 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAB-200
H3C iMC, End-user Intelligent Access Component, 200 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAC-500
H3C iMC, End-user Intelligent Access Component, 500 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAD-2K
H3C iMC, End-user Intelligent Access Component, 2000 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAE-5K
H3C iMC, End-user Intelligent Access Component, 5000 Licenses
E0611P05 and later
E0611P05 and later
Basic license for EIA intelligent portal component (Telecom operators version)
SWP-IMC7-EIA-TOV
H3C iMC, EIA, Intelligent Portal Component (Telecom Operators Version)
D0507 and later
Not supported
Quantity license for EIA intelligent portal component (Telecom operators version)
LIS-IMC7-EIAA-TOV-200
H3C iMC, EIA, Intelligent Portal Component (Telecom Operators Version), 200 Licenses
D0507 and later
Not supported
Feature license for EIA end-user intelligent profiling
LIS-IMC7-EIAA-50-EIP
H3C iMC, End-user Intelligent Access Component, End-user Intelligent Profiling, 50 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAB-200-EIP
H3C iMC, End-user Intelligent Access Component, End-user Intelligent Profiling, 200 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAC-500-EIP
H3C iMC, End-user Intelligent Access Component, End-user Intelligent Profiling, 500 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAD-2K-EIP
H3C iMC, End-user Intelligent Access Component, End-user Intelligent Profiling, 2000 Licenses
E0611P05 and later
E0611P05 and later
LIS-IMC7-EIAE-5K-EIP
H3C iMC, End-user Intelligent Access Component, End-user Intelligent Profiling, 5000 Licenses
E0611P05 and later
E0611P05 and later
IPM
Basic license for IPM
SWP-IMC7-IPM
H3C iMC, Intelligent Portal Manager Component
E0609 and later
E0609 and later
Quantity license for IPM
LIS-IMC7-IPMA-50
H3C iMC, Intelligent Portal Manager Component, 50 Licenses
E0609 and later
E0609 and later
LIS-IMC7-IPMB-200
H3C iMC, Intelligent Portal Manager Component, 200 Licenses
E0609 and later
E0609 and later
LIS-IMC7-IPMC-500
H3C iMC, Intelligent Portal Manager Component, 500 Licenses
E0609 and later
E0609 and later
LIS-IMC7-IPMD-2K
H3C iMC, Intelligent Portal Manager Component, 2000 Licenses
E0609 and later
E0609 and later
LIS-IMC7-IPME-5K
H3C iMC, Intelligent Portal Manager Component, 5000 Licenses
E0609 and later
E0609 and later
WSM
Basic license for WSM wireless services
SWP-IMC7-WSM
H3C iMC, Wireless Service Manager Component
E0505 and later
E0608 and later
Quantity license for WSM APs
LIS-IMC7-WSMA-50
H3C iMC, Wireless Service Manager Component, 50 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMB-100
H3C iMC, Wireless Service Manager Component, 100 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMC-200
H3C iMC, Wireless Service Manager Component, 200 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMD-500
H3C iMC, Wireless Service Manager Component, 500 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSME-1K
H3C iMC, Wireless Service Manager Component, 1000 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMF-2K
H3C iMC, Wireless Service Manager Component, 2000 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMG-5K
H3C iMC, Wireless Service Manager Component, 5000 Licenses
E0505 and later
E0608 and later
Quantity license for WSM AP location
LIS-IMC7-WSMA-50AP-L
H3C iMC, Wireless Service Manager Component, Location Service, 50 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSMB-100AP-L
H3C iMC, Wireless Service Manager Component, Location Service, 100 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSMC-200AP-L
H3C iMC, Wireless Service Manager Component, Location Service, 200 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSMD-500AP-L
H3C iMC, Wireless Service Manager Component, Location Service, 500 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSME-1KAP-L
H3C iMC, Wireless Service Manager Component, Location Service, 1000 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSMF-2KAP-L
H3C iMC, Wireless Service Manager Component, Location Service, 2000 Licenses (AP)
E0505 and later
E0608 and later
LIS-IMC7-WSMG-5KAP-L
H3C iMC, Wireless Service Manager Component, Location Service, 5000 Licenses (AP)
E0505 and later
E0608 and later
WSM WLAN health assessment license
LIS-IMC7-WSM-H
H3C iMC, Wireless Service Manager Component, WLAN Health Assessment License
E0505 and later
Not supported
Quantity license for WSM WIPS sensors
LIS-IMC7-WSMA-50-W
H3C iMC, Wireless Service Manager Component, Intrusion Prevention System, 50 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMB-100-W
H3C iMC, Wireless Service Manager Component, Intrusion Prevention System, 100 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMC-500-W
H3C iMC, Wireless Service Manager Component, Intrusion Prevention System, 500 Licenses
E0505 and later
E0608 and later
Quantity license for WSM wireless terminators
LIS-IMC7-WSMA-50-WT
H3C iMC, Wireless Service Manager Component, Wireless Terminator Unit, 50 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMB-100-WT
H3C iMC, Wireless Service Manager Component, Wireless Terminator Unit, 100 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMC-500-WT
H3C iMC, Wireless Service Manager Component, Wireless Terminator Unit, 500 Licenses
E0505 and later
E0608 and later
LIS-IMC7-WSMD-1K-WT
H3C iMC, Wireless Service Manager Component, Wireless Terminator Unit, 1000 Licenses
E0505 and later
E0608 and later
Supervisor license for WSM wireless services
SWP-IMC7-WSM-S
H3C iMC, Wireless Service Manager Supervisor Component
E0601 and later
Not supported
Quantity license for WSM bluetooth location
LIS-IMC7-WSMA-50IOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 50 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSMB-100IOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 100 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSMC-200IOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 200 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSMD-500IOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 500 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSME-1KIOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 1000 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSMF-2KIOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 2000 Licenses (IOT)
E0505 and later
Not supported
LIS-IMC7-WSMG-5KIOT-L
H3C iMC, Wireless Service Manager Component, Location Service, 5000 Licenses (IOT)
E0505 and later
Not supported
Basic license for WSM IOT
LIS-IMC7-WSM-IOT
H3C iMC, Wireless Service Manager Component, IOT License
E0505 and later
Not supported
Quantity license for WSM IOT
LIS-IMC7-WSMA-50-IOT
H3C iMC, Wireless Service Manager Component, IOT, 50 Licenses
E0505 and later
Not supported
LIS-IMC7-WSMB-100-IOT
H3C iMC, Wireless Service Manager Component, IOT, 100 Licenses
E0505 and later
Not supported
LIS-IMC7-WSMC-200-IOT
H3C iMC, Wireless Service Manager Component, IOT, 200 Licenses
E0505 and later
Not supported
LIS-IMC7-WSMD-500-IOT
H3C iMC, Wireless Service Manager Component, IOT, 500 Licenses
E0505 and later
Not supported
LIS-IMC7-WSME-1K-IOT
H3C iMC, Wireless Service Manager Component, IOT, 1000 Licenses
E0505 and later
Not supported
LIS-IMC7-WSMF-2K-IOT
H3C iMC, Wireless Service Manager Component, IOT, 2000 Licenses
E0505 and later
Not supported
LIS-IMC7-WSMG-5K-IOT
H3C iMC, Wireless Service Manager Component, IOT, 5000 Licenses
E0505 and later
Not supported
The product category for the application-driven software products is NMS_ADNet Director. Table 4 shows the licenses for components.
Table 4 iMC license matrix (application-driven components)
Component
License description
Product code
Product description
DR1000
Basic license for DR1000
SWP-DR1000-ADDC
H3C ADDC Fabric Director Software
E0505 and later
E0506 and later
Quantity license for DR1000
LIS-DR1000-ADDCA-25
H3C ADDC Fabric Director Software, 25 Licenses
E0505 and later
E0506 and later
LIS-DR1000-ADDCB-50
H3C ADDC Fabric Director Software, 50 Licenses
E0505 and later
E0506 and later
LIS-DR1000-ADDCC-100
H3C ADDC Fabric Director Software, 100 Licenses
E0505 and later
E0506 and later
LIS-DR1000-ADDCD-200
H3C ADDC Fabric Director Software, 200 Licenses
E0505 and later
E0506 and later
LIS-DR1000-ADDCE-500
H3C ADDC Fabric Director Software, 500 Licenses
E0505 and later
E0506 and later
LIS-DR1000-ADDCF-1K
H3C ADDC Fabric Director Software, 1000 Licenses
E0505 and later
E0506 and later
DR2000
Basic license for DR2000
SWP-DR2000-ADCAM
H3C ADCampus Director Software
E0508 and later
E0508 and later
Basic license for DR2000 miniature edition
SWP-DR2000-ADCAM-M
H3C ADCampus Director Software, Miniature Edition
E0508 and later
Not supported
Basic license for DR2000 small edition
SWP-DR2000-ADCAM-S
H3C ADCampus Director Software, Small Edition
E0508 and later
Not supported
Basic license for DR2000 SMB edition
SWP-DR2000-ADCAM-SMB
H3C ADCampus Director Software, SMB Edition
E0508 and later
Not supported
Quantity license for DR2000
LIS-DR2000-ADCAMA-25
H3C ADCampus Director, 25 Licenses
E0508 and later
E0508 and later
LIS-DR2000-ADCAMB-50
H3C ADCampus Director, 50 Licenses
E0508 and later
E0508 and later
LIS-DR2000-ADCAMC-100
H3C ADCampus Director, 100 Licenses
E0508 and later
E0508 and later
LIS-DR2000-ADCAMD-200
H3C ADCampus Director, 200 Licenses
E0508 and later
E0508 and later
LIS-DR2000-ADCAME-500
H3C ADCampus Director, 500 Licenses
E0508 and later
E0508 and later
LIS-DR2000-ADCAMF-1K
H3C ADCampus Director, 1000 Licenses
E0508 and later
E0508 and later
ADEAD
Basic license for ADEAD
SWP-SDNAPP-ADEAD
H3C SDNAPP, Endpoint Admission Defense Software
E0601 and later
E0601 and later
Quantity license for ADEAD
LIS-SDNAPP-ADEADA-50
H3C SDNAPP, Endpoint Admission Defense, 50 Licenses
E0601 and later
E0601 and later
LIS-SDNAPP-ADEADB-200
H3C SDNAPP, Endpoint Admission Defense, 200 Licenses
E0601 and later
E0601 and later
LIS-SDNAPP-ADEADC-500
H3C SDNAPP, Endpoint Admission Defense, 500 Licenses
E0601 and later
E0601 and later
LIS-SDNAPP-ADEADD-2K
H3C SDNAPP, Endpoint Admission Defense, 2000 Licenses
E0601 and later
E0601 and later
LIS-SDNAPP-ADEADE-5K
H3C SDNAPP, Endpoint Admission Defense, 5000 Licenses
E0601 and later
E0601 and later
ADEIA
Basic license for ADEIA
SWP-SDNAPP-ADEIA
H3C SDNAPP, End-user Intelligent Access Software
E0515 and later
E0515 and later
Quantity license for ADEIA
LIS-SDNAPP-ADEIAA-50
H3C SDNAPP, End-user Intelligent Access, 50 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAB-200
H3C SDNAPP, End-user Intelligent Access, 200 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAC-500
H3C SDNAPP, End-user Intelligent Access, 500 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAD-2K
H3C SDNAPP, End-user Intelligent Access, 2000 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAE-5K
H3C SDNAPP, End-user Intelligent Access, 5000 Licenses
E0515 and later
E0515 and later
License for ADEIA EIP
LIS-SDNAPP-ADEIAA-50-EIP
H3C SDNAPP, End-user Intelligent Access, End-user Intelligent Profiling, 50 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAB-200-EIP
H3C SDNAPP, End-user Intelligent Access, End-user Intelligent Profiling, 200 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAC-500-EIP
H3C SDNAPP, End-user Intelligent Access, End-user Intelligent Profiling, 500 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAD-2K-EIP
H3C SDNAPP, End-user Intelligent Access, End-user Intelligent Profiling, 2000 Licenses
E0515 and later
E0515 and later
LIS-SDNAPP-ADEIAE-5K-EIP
H3C SDNAPP, End-user Intelligent Access, End-user Intelligent Profiling, 5000 Licenses
E0515 and later
E0515 and later
ADWSM
Quantity license for ADWSM APs
LIS-SDNAPP-ADWSMA-50
H3C SDNAPP, Wireless Service Manager, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100
H3C SDNAPP, Wireless Service Manager, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMC-200
H3C SDNAPP, Wireless Service Manager, 200 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500
H3C SDNAPP, Wireless Service Manager, 500 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSME-1K
H3C SDNAPP, Wireless Service Manager, 1000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMF-2K
H3C SDNAPP, Wireless Service Manager, 2000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMG-5K
H3C SDNAPP, Wireless Service Manager, 5000 Licenses
E0508 and later
E0508 and later
Quantity license for ADWSM AP location
LIS-SDNAPP-ADWSMA-50AP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100AP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMC-200AP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 200 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500AP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 500 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSME-1KAP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 1000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMF-2KAP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 2000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMG-5KAP-L
H3C SDNAPP, Wireless Service Manager, AP Location Service, 5000 Licenses
E0508 and later
E0508 and later
Quantity license for ADWSM WIPS sensors
LIS-SDNAPP-ADWSMA-50-W
H3C SDNAPP, Wireless Service Manager, Intrusion Prevention System, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100-W
H3C SDNAPP, Wireless Service Manager, Intrusion Prevention System, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500-W
H3C SDNAPP, Wireless Service Manager, Intrusion Prevention System, 500 Licenses
E0508 and later
E0508 and later
Quantity license for ADWSM wireless terminators
LIS-SDNAPP-ADWSMA-50-WT
H3C SDNAPP, Wireless Service Manager, Wireless Terminator Unit, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100-WT
H3C SDNAPP, Wireless Service Manager, Wireless Terminator Unit, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500-WT
H3C SDNAPP, Wireless Service Manager, Wireless Terminator Unit, 500 Licenses
E0508 and later
E0508 and later
Quantity license for ADWSM bluetooth location service
LIS-SDNAPP-ADWSMA-50IOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100IOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMC-200IOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 200 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500IOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 500 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSME-1KIOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 1000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMF-2KIOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 2000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMG-5KIOT-L
H3C SDNAPP, Wireless Service Manager, IoT Location Service, 5000 Licenses
E0508 and later
E0508 and later
Basic license for ADWSM IOT
LIS-SDNAPP-ADWSM-IOT
H3C SDNAPP, Wireless Service Manager, IoT License
E0508 and later
E0508 and later
Quantity license for ADWSM IOT
LIS-SDNAPP-ADWSMA-50-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 50 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMB-100-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 100 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMC-200-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 200 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMD-500-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 500 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSME-1K-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 1000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMF-2K-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 2000 Licenses
E0508 and later
E0508 and later
LIS-SDNAPP-ADWSMG-5K-IOT
H3C SDNAPP, Wireless Service Manager, IoT, 5000 Licenses
E0508 and later
E0508 and later
Feature license for ADWSM WLAN health assessment
LIS-SDNAPP-ADWSM-H
H3C SDNAPP, Wireless Service Manager, WLAN Health Assessment License
E0508 and later
E0508 and later
Copyright © 2024 New H3C Technologies Co., Ltd.
The information in this document is subject to change without notice
