10-Security
HomeSupportReference GuidesMIB CompanionH3C S6826 & S9826 MIB Companion-Release 6715-6W10010-Security
08-SAVI-MIB
08-SAVI-MIB 92.57 KB
SAVI-MIB
About this MIB
Use this MIB to manage SAVI configuration.
MIB file name
savi.mib
Root object
iso(1).org(3).dod(devil).internet(1).mgmt(2).mib-2(1).ip(4).saviMIB(40)
Tabular objects
saviObjectsSystemTable
About this table
Use this table to configure global SAVI parameters.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are saviObjectsSystemIPVersion and saviObjectsSystemTable.
Object (OID)
Access
Value range
Implementation
saviObjectsSystemIPVersion (1.3.6.1.2.1.4.40.1.1.1.1)
not-accessible
INTEGER
unknown(0)
ipv4(1)
ipv6(2)
IP version.
As per the MIB.
saviObjectsSystemMode (1.3.6.1.2.1.4.40.1.1.1.2)
read-write
INTEGER
savi-disable(1)
savi-default(2)
savi-dhcp-only(3)
savi-slaac-only(4)
savi-dhcp-slaac-mix(5)
savi-send(6)
IP address assignment methods.
As per the MIB.
saviObjectsSystemMaxDhcpResponseTime (1.3.6.1.2.1.4.40.1.1.1.3)
read-write
INTEGER
INTEGER (0..2147483647)
Maximum interval between two DHCP responses.
As per the MIB.
saviObjectsSystemDataSnoopingInterval (1.3.6.1.2.1.4.40.1.1.1.4)
read-write
INTEGER
Data snooping interval.
As per the MIB.
saviObjectsSystemMaxLeaseQueryDelay (1.3.6.1.2.1.4.40.1.1.1.5)
read-write
INTEGER
Maximum lease query delay.
As per the MIB.
saviObjectsSystemOffLinkDelay (1.3.6.1.2.1.4.40.1.1.1.6)
read-write
INTEGER
Off-link entry deletion delay.
As per the MIB.
saviObjectsSystemDetectionTimeout (1.3.6.1.2.1.4.40.1.1.1.7)
read-write
INTEGER
Detection timeout.
As per the MIB.
saviObjectsSystemTentLT (1.3.6.1.2.1.4.40.1.1.1.8)
read-write
INTEGER
ND snooping tentative entry lifetime.
As per the MIB.
saviObjectsSystemDefaultLT (1.3.6.1.2.1.4.40.1.1.1.9)
read-write
INTEGER
ND snooping valid entry lifetime.
As per the MIB.
saviObjectsSystemTWAIT (1.3.6.1.2.1.4.40.1.1.1.10)
read-write
INTEGER
ND snooping DAD NS transmission interval.
As per the MIB.
saviObjectsSystemNotifySpoofing
(1.3.6.1.2.1.4.40.1.1.1.11)
read-write
INTEGER
enable(1)
disable(2)
Status of packet spoofing logging.
As per the MIB.
saviObjectsSystemNotifyFilter
(1.3.6.1.2.1.4.40.1.1.1.12)
read-write
INTEGER
enable(1)
disable(2)
Status of filtering entry logging.
As per the MIB.
saviObjectsSystemNotifySpoofingInterval
(1.3.6.1.2.1.4.40.1.1.1.13)
read-write
Unsigned32
Unsigned32 (0|5..3600)
Log output interval for packet spoofing logging, in seconds.
As per the MIB.
saviObjectsSystemNotifySpoofingNumber
(1.3.6.1.2.1.4.40.1.1.1.14)
read-write
Unsigned32
Unsigned32 (1..128)
Maximum number of log messages that can be output per interval.
As per the MIB.
saviObjectsSystemBindingCount
(1.3.6.1.2.1.4.40.1.1.1.15)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Number of binding entries.
As per the MIB.
saviObjectsSystemFilteringCount
(1.3.6.1.2.1.4.40.1.1.1.16)
read-only
Unsigned32
Unsigned32
(0..4294967295)
Number of filtering entries.
As per the MIB.
saviObjectsPortTable
About this table
Use this table to configure SAVI parameters on interfaces.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are saviObjectsPortIPVersion and saviObjectsPortIfIndex.
Object (OID)
Access
Value range
Implementation
saviObjectsPortIPVersion (1.3.6.1.2.1.4.40.1.2.1.1)
not-accessible
INTEGER
unknown(0)
ipv4(1)
ipv6(2)
IP version
As per the MIB.
saviObjectsPortIfIndex (1.3.6.1.2.1.4.40.1.2.1.2)
not-accessible
Integer32
Integer32 (1..2147483647)
Interface index.
As per the MIB.
saviObjectsPortValidatingAttr (1.3.6.1.2.1.4.40.1.2.1.3)
read-write
INTEGER
enable(1)
disable(2)
Status of SAVI on the interface.
As per the MIB.
saviObjectsPortDhcpTrustAttr (1.3.6.1.2.1.4.40.1.2.1.4)
read-write
INTEGER
enable(1)
disable(2)
Whether the interface trusts DHCP packets.
As per the MIB.
saviObjectsPortTrustAttr (1.3.6.1.2.1.4.40.1.2.1.5)
read-write
INTEGER
enable(1)
disable(2)
Whether the interface trusts any packets.
As per the MIB.
saviObjectsPortDhcpSnoopingAttr (1.3.6.1.2.1.4.40.1.2.1.6)
read-write
INTEGER
enable(1)
disable(2)
Whether the interface creates bindings based on DHCPv6 snooping.
As per the MIB.
saviObjectsPortDataSnoopingAttr (1.3.6.1.2.1.4.40.1.2.1.7)
read-write
INTEGER
enable(1)
disable(2)
Whether the interface creates bindings based on data snooping.
As per the MIB.
saviObjectsPortFilteringNum (1.3.6.1.2.1.4.40.1.2.1.8)
read-write
Unsigned32
Unsigned32 (0..4294967295)
Maximum filtering entry number of the interface.
As per the MIB.
saviObjectsBindingTable
About this table
Use this table to configure binding entries.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are saviObjectsBindingIpAddressType, saviObjectsBindingType, saviObjectsBindingIfIndex, and saviObjectsBindingIpAddress.
Object (OID)
Access
Value range
Implementation
saviObjectsBindingIpAddressType (1.3.6.1.2.1.4.40.1.3.1.1)
not-accessible
INTEGER
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
IP version.
As per the MIB.
saviObjectsBindingType (1.3.6.1.2.1.4.40.1.3.1.2)
not-accessible
INTEGER
manual(1)
slaac(2)
dhcp(3)
send(4)
Binding type.
As per the MIB.
saviObjectsBindingIfIndex (1.3.6.1.2.1.4.40.1.3.1.3)
not-accessible
Integer32
Interface index.
As per the MIB.
saviObjectsBindingIpAddress (1.3.6.1.2.1.4.40.1.3.1.4)
not-accessible
OCTET STRING
OCTET STRING (0..255)
IP address.
As per the MIB.
saviObjectsBindingMacAddr (1.3.6.1.2.1.4.40.1.3.1.5)
read-create
OCTET STRING
OCTET STRING (6)
MAC address.
As per the MIB.
saviObjectsBindingState (1.3.6.1.2.1.4.40.1.3.1.6)
read-create
INTEGER
nO-BIND(1)
iNIT-BIND(2)
bOUND(3)
dETECTION(4)
rECOVERY(5)
vERIFY(6)
tENTATIVE(7)
vALID(8)
tESTING-TP-LT(9)
tESTING-VP(10)
tESTING-VPP(11)
tENTATIVE-NUD(12)
tENTATIVE-DAD(13)
Binding status.
As per the MIB.
saviObjectsBindingLifetime (1.3.6.1.2.1.4.40.1.3.1.7)
read-create
INTEGER
Remaining lifetime of the entry.
As per the MIB.
saviObjectsBindingCreationtime (1.3.6.1.2.1.4.40.1.3.1.8)
read-create
OCTET STRING
OCTET STRING (8  11)
Time when the entry was created.
As per the MIB.
saviObjectsBindingTID (1.3.6.1.2.1.4.40.1.3.1.9)
read-create
INTEGER
Standard MIB values.
Transaction ID.
As per the MIB.
saviObjectsBindingRowStatus (1.3.6.1.2.1.4.40.1.3.1.10)
read-create
INTEGER
active(1)
notInService(2)
notReady(3)
createAndGo(4)
createAndWait(5)
destroy(6)
Status of this row.
As per the MIB.
saviObjectsFilteringTable
About this table
Use this table to configure filtering entries.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are saviObjectsFilteringIpAddressType, saviObjectsFilteringIfIndex, and saviObjectsFilteringIpAddress.
Object (OID)
Access
Value range
Implementation
saviObjectsFilteringIpAddressType (1.3.6.1.2.1.4.40.1.4.1.1)
not-accessible
INTEGER
unknown(0)
ipv4(1)
ipv6(2)
ipv4z(3)
ipv6z(4)
dns(16)
IP address type of the filtering source IP address.
As per the MIB.
saviObjectsFilteringIfIndex (1.3.6.1.2.1.4.40.1.4.1.2)
not-accessible
Integer32
Interface index.
As per the MIB.
saviObjectsFilteringIpAddress (1.3.6.1.2.1.4.40.1.4.1.3)
not-accessible
OCTET STRING
Filtering source IP address.
As per the MIB.
saviObjectsFilteringMacAddr (1.3.6.1.2.1.4.40.1.4.1.4)
read-only
OCTET STRING
OCTET STRING (6)
As per the MIB.
saviObjectsCountTable
About this table
Use this table to obtain SAVI packet filtering statistics.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are saviObjectsCountIPVersion and saviObjectsCountIfIndex.
Object (OID)
Access
Value range
Implementation
saviObjectsCountIPVersion (1.3.6.1.2.1.4.40.1.5.1.1)
not-accessible
INTEGER
unknown(0)
ipv4(1)
ipv6(2)
IP version.
Only supports ipv6(2).
saviObjectsCountIfIndex (1.3.6.1.2.1.4.40.1.5.1.2)
not-accessible
Integer32
Interface index.
As per the MIB.
saviObjectsCountFilterPkts (1.3.6.1.2.1.4.40.1.5.1.3)
read-only
Counter64
Counter64
(1.. 18446744073709551616)
Number of spoofed packets filtered by SAVI.
As per the MIB.
saviObjectsCountFilterOctets
(1.3.6.1.2.1.4.40.1.5.1.4)
read-only
Counter64
Counter64
Byte count for spoofed packets filtered by SAVI.
As per the MIB.
