H3C Servers hREST User Guide-6W101
HomeSupportConfigure & DeployUser ManualsH3C Servers hREST User Guide-6W101
Title Size Downloads
H3C Servers hREST User Guide-6W101-book.pdf 1015.23 KB
Table of Contents
Related Documents
book
book 1015.23 KB
H3C Servers
hREST User Guide
New H3C Technologies Co., Ltd.
http://www.h3c.com
Copyright © 2023, New H3C Technologies Co., Ltd. and its licensors
All rights reserved
Trademarks
Notice
The information in this document is subject to change without notice. All contents in this document, including statements, information, and recommendations, are believed to be accurate, but they are presented without warranty of any kind, express or implied. H3C shall not be liable for technical or editorial errors or omissions contained herein.
Introduction· 1
Command format 1
Applicable products· 2
Software compatibility· 3
HDM compatibility· 3
OS compatibility· 3
Use the hREST command tool 3
Manage the server with the hREST command tool 5
Obtain command help information· 5
Obtain CPU information· 7
Obtain memory information· 9
Obtain physical drive information· 10
Disable or enable a physical drive· 12
Obtain logical drive information· 12
Create a logical drive· 14
Delete a logical drive· 16
Configure a logical drive· 16
Obtain storage controller information· 17
Obtain storage information· 18
Obtain event log messages· 20
Delete event log messages· 22
Obtain network port information· 22
Configure IPv4 address settings for a network port 25
Configure IPv6 address settings for a network port 25
Obtain network port VLAN information· 26
Configure VLAN settings for a network port 27
Obtain the network port mode· 27
Set the network port mode· 28
Obtain network adapter information· 28
Obtain IP-based login rule information· 30
Configure an IP-based login rule· 31
Obtain NVMe SSD information· 32
Obtain power capping information· 32
Configure power capping· 33
Obtain power supply information· 34
Set the active/standby state of a power supply· 35
Power on or power off the server 35
Obtain device information· 36
Set the asset tag· 38
Set a host name· 38
Obtain user role information· 39
Assign role group privileges· 40
Obtain boot settings· 40
Configure system boot settings· 41
Obtain health status· 42
Obtain HDM operation logs· 43
Obtain system time· 44
Set the time zone· 44
Obtain temperature information· 45
Obtain user information· 46
Add a user 48
Edit a user 49
Delete a user 50
Obtain BIOS settings· 51
Configure BIOS settings· 51
Obtain pending BIOS settings· 52
Restore the BIOS settings· 52
Restore the BMC settings· 53
Obtain fan information· 53
Set the fan speed· 55
Disable inband management of HDM users· 56
Export configuration· 56
Import configuration· 57
Obtain firmware information· 57
Obtain NTP information· 58
Configure NTP settings· 59
Obtain SNMP information· 60
Configure SNMP settings· 62
Obtain service information· 63
Configure service settings· 64
Download SDS logs· 65
Obtain virtual media information· 66
Mount or unmount virtual media· 67
Upgrade the firmware· 68
Obtain PCIe device list 69
Take a screenshot of KVM·· 70
Configure advanced LDAP settings· 71
Obtain LDAP information· 72
Add or edit an LDAP user 73
Delete an LDAP user 75
Configure AD settings· 75
Obtain AD information· 76
Add or edit an AD user 77
Delete an AD user 79
Obtain GPU information· 79
Obtain VNC session information· 80
Obtain the firewall status· 81
Set the firewall status· 81
Obtain components using a serial port 82
Configure the components to use a serial port 83
Locate a physical drive· 83
Obtain storage media alarm thresholds· 84
Set a storage media alarm threshold· 85
Obtain event subscription information· 85
Upload an SSH secret key· 86
Delete an SSH secret key· 87
Obtain two-factor authentication settings· 87
Configure two-factor authentication settings· 88
Obtain LLDP information· 88
Configure LLDP settings· 89
Obtain DNS information· 90
Configure the DNS service· 91
Obtain system performance information· 92
Configure system performance alarm thresholds· 93
Obtain video recording configuration· 93
Configure video recording· 94
Configure the power mode· 95
Scan the servers for memory module failures· 96
Disable the HDM shared network port 97
Obtain NCSI status for the shared network port 98
Configure NCSI status for the shared network port 98
Set the VNC password· 99
Obtain SMTP information· 99
Configure SMTP settings· 100
Export operation log· 102
Introduction
hREST, developed by using Python, is a server management command tool based on HTTPs, Redfish, RESTful, and IPMI. It allows users to use commands to obtain server information and configure servers.
Command format
An hREST command format varies by management mode:
·     In out-of-band management mode, an hREST command uses the hREST -H host -p port–q ipmi_port -U username -P password <command> format, where:
¡     -H host—Specifies the HDM IP address of the managed device.
¡     -p port—Specifies the HTTPS port number. By default, the port number is 443. This option is optional.
¡     –q ipmi_port—Specifies the IPMI port number. By default, the port number is 623. This option is optional.
¡     -U username -P password—Specifies the HDM username and password of the managed device. Unless otherwise specified, use an administrator account as a best practice to avoid operation failures caused by insufficient privileges.
¡     <command>—Specifies which action to take on which instance.
·     The hREST command arguments are case-sensitive.
·     Avoid using special character combinations that are related to the operating system. To use such special characters, use quotation marks (") or single quotation marks (') to quote them as a best practice.
·     In in-band management mode, an hREST command use the hREST -p port <command> format, where:
·     Only some features support in-band management. For more information, see the specific command. Before using the in-band management mode, install the hdmdrv driver and use in-band management command ipmitool raw 0x36 0x09 0xa2 0x63 0x00 0x1a 0x11 0x00 to enable the USB channel.
·     To install the hdmdrv driver, execute the insmod hdmdrv.ko command.
·     As a best practice, use ipmitool raw 0x36 0x09 0xa2 0x63 0x00 0x1a 0x11 0x01 to disable the USB channel after completing tasks in in-band management mode. If you do not do so, hdmdrv-related devices will be displayed in the system.
The in-band management mode cannot be used concurrently.
If you have used KVM to access the system and KVM is idle for a long time or is manually closed, the USB channel might be disconnected. In this case, re-enable the USB channel.
As a best practice, use the root user to install the in-band driver and use the in-band management mode to avoid operation failure due to lack of permissions.
Applicable products
This document is applicable to the following products:
·     AE100
·     H3C UniServer B5700 G6
·     H3C UniServer R4700 G6
·     H3C UniServer R4700LE G6
·     H3C UniServer R4900 G6
·     H3C UniServer R4900 G6 Ultra
·     H3C UniServer R4900LE G6
·     H3C UniServer R4950 G6
·     H3C UniServer R5300 G6
·     H3C UniServer R5350 G6
·     H3C UniServer R5500 G6
·     H3C UniServer R6700 G6
·     H3C UniServer R6900 G6
·     H3C UniServer B5700 G5
·     H3C UniServer R4300 G5
·     H3C UniServer R4330 G5
·     H3C UniServer R4330 G5 H3
·     H3C UniServer R4700 G5
·     H3C UniServer R4700LC G5
·     H3C UniServer R4900 G5
·     H3C UniServer R4900LC G5
·     H3C UniServer R4930 G5
·     H3C UniServer R4930 G5 H3
·     H3C UniServer R4930LC G5 H3
·     H3C UniServer R4950 G5
·     H3C UniServer R5300 G5
·     H3C UniServer R5500 G5
·     H3C UniServer R5500LC G5
·     H3C UniServer R6900 G5
·     H3C UniServer B5700 G3
·     H3C UniServer B5800 G3
·     H3C UniServer B7800 G3
·     H3C UniServer E3200 G3
·     H3C UniServer R2700 G3
·     H3C UniServer R2900 G3
·     H3C UniServer R4100 G3
·     H3C UniServer R4300 G3
·     H3C UniServer R4500 G3
·     H3C UniServer R4700 G3
·     H3C UniServer R4900 G3
·     H3C UniServer R4950 G3
·     H3C UniServer R5300 G3
·     H3C UniServer R6700 G3
·     H3C UniServer R6900 G3
·     H3C UniServer R8900 G3
·     H3C UniStor X10000 G3
HDM compatibility
Item
Compatible versions
HDM
Recommended: HDM-1.30.15 or later
Some commands might require specific HDM versions. For more information, see the specific command. hREST only supports universal HDM versions. For custom requirements, see the exclusively released versions.
OS compatibility
Item
Compatible versions
Windows OSs (64-bit)
Windows Server 2012 R2
Windows 7
Windows 10
Linux OSs (64-bit)
CentOS 6.2
CentOS 7.3
Redhat
Redhat 9.0
hREST might not be available in other OSs or OS versions. In-band management is supported only in Linux OSs in the current software version.
The hREST command tool does not require installation.
To use the hREST command tool:
1.     Copy the tool project file to the operating system. The file name is hREST_Linux_Vx.xx.tar.gz for Linux OSs and hREST_Windows_Vx.xx.zip for Windows OSs.
The project file contains the basic Python running package, Redfish source codes, and external packages on which the tool depends.
2.     Decompress the file and access the hREST_Linux_Vx.xx or hREST_Windows_Vx.xx directory.
3.     Access the bin folder.
4.     Enter the corresponding command and then press Enter to execute the command.
¡     For Linux, enter ./hREST -H host -p port -U username -P password <command>.
¡     For Windows, enter hREST -H host -p port -U username -P password <command>.
For driver installation in in-band management mode, perform the following steps:
1.     Copy the compatible in-band driver package (hdmdrv.ko) to the system;
2.     Use insmod hdmdrv.ko to install the driver.
3.     After installation, verify that the driver is installed successfully with lsmod | grep hdmdrv;
4.     To uninstall the driver, use rmmod hdmdrv.ko.
Perform this task to obtain command help information.
hREST –h
hREST --help
# Obtain command help information.
-> hREST –h
usage: hREST [-h] [-V] [-H HOST] [-p PORT] [-q IPMI_PORT] [-U USERNAME]
             [-P PASSWORD]
             sub command ...
optional arguments:
  -h, --help        show this help message and exit
  -V, --version     show program's version number and exit
  -H HOST           domain name, IPv4 address,or [IPv6 address]
  -p PORT           port
  -q IPMI_PORT      ipmi_port
  -U USERNAME       local or LDAP username
  -P PASSWORD       password
sub commands:
  sub command       sub-command help
    addaduser       add ad user.
    addldapuser     add ldap user.
    addldisk        create logical disk.
    adduser         add user.
    delelog         delete event log.
    closeinner      close inner user setting.
    getsdslog       get sds log.
    deladuser       delete ad user.
    delldapuser     delete ldap user.
    delldisk        delete logical disk.
    deluser         delete user by username.
    downloadconfig  download configuration.
    fwupdate        fwupdate command.
    getbios         get BIOS information.
    getbiossetting  set pending bios setting.
    getcpu          get CPUs information.
    getgpu          get GPUs information.
    getelog         get event log.
    getfan          get fan information.
    getfirewall     get firewall status.
    setfirewall     set firewall status.
    getfwv          get firmware version.
    gethdmlog       get hdm log.
    getsyshealth    get system health state.
    getip           get ip information.
    getvlan         get vlan information.
    getvncsession   get vnc session info.
    getldisk        get logical drive information.
    getloginruleip  get ip login rule.
    getmemory       get memory information.
    getnetmode      get net mode.
    getnic          get nic information.
    getntp          get ntp information.
    getnvmessd      get nvme ssd information.
    getpcie         get pcie information.
    getpdisk        get physical disk information.
    getpowerlimit   get power limit.
    getproductinfo  get product information.
    getpsu          get power information.
    getraid         get raid information.
    getrole         get role information.
    setrole         set role rivileges.
    getscreencapture
                    get virtual media information.
    getsensor       get sensors information.
    geteventsub     get event subscription information.
    getservice      get service information.
    getsnmp         get snmp information.
    getsmtp         get smtp information.
    setsmtp         set smtp information.
    getstorage      get storage information.
    getsysboot      get system boot information.
    setsysboot      set system boot.
    gettemp         get temperature information.
    getthreshold    get predictive failure threshold.
    setthreshold    set predictive failure threshold.
    gettime         get system time.
    getuser         get user information.
    getvmm          get virtual media information.
    mountvmm        mount or unmount virtual media.
    setbiosdefault  set bios default.
    setbmcdefault   set bmc default.
    syspowerctrl    system power control options.
    setad           set ad(Active Directory).
    setbios         set bios parameter.
    setfan          set fan speed.
    setshareport    set the BMC shareport.
    setipv4         set IPv4 information of the BMC network port.
    setipv6         set IPv6 information of the BMC network port.
    locatedisk      locate the physical disk by LED lights.
    setvlan         set VLAN information.
    setldap         set ldap.
    setloginruleip  add ip login rule.
    setnetmode      set net mode.
    getncsi         get ncsi status.
    setncsi         set ncsi status.
    setntp          set ntp information.
    setpdisk        set physical disk information.
    setpowerlimit   set power limit.
    setpmb          set power main/backup.
    setassettag     set product information.
    sethostname     set hostname information.
    getserialport   get serial port information.
    setserialport   set serial port.
    setservice      set service configuration.
    setsnmp         set snmp information.
    settimezone     time zone. for example, UTC+9 and UTC-3.
    setuser         set user.
    uploadconfig    download configuration.
    importsshkey    import SSH key.
    delsshkey       delete SSH key.
    getldap         get ldap configuration information.
    getad           get ad configuration information.
    get2factorauth  get two-factor authentication configuration information.
    set2factorauth  configure two-factor authentication attributes.
    getdns          get dns configuration information.
    setdns          DNS configuration.
    getlldp         get lldp information.
    setlldp         set LLDP service properties.
    getsysperf      get system performance information.
    setsysperf      set the host monitoring alarm threshold.
    getvideocfg     get video recording function configuration.
    setvideocfg     set video recording function.
    setldisk        set logical disk properties.
    setpsu          power configuration.
    memoryinspect   memory inspect.
    setvnc          set vnc.
    exportlog       export operator log.
    gethardware     get hardware information.
    sendipmirawcmd  send ipmi raw command.
Perform this task to obtain CPU information.
hREST -H host -p port -U username -P password getcpu -CI cpu_id
Table 1 Parameter description
Parameter
Value
cpu_id
CPU ID.
Optional.
If you do not specify this argument, the command displays information about all CPUs.
# Obtain information about CPU 2.
-> hREST –H 192.168.10.6 –U ****** -P ****** getcpu –CI 2
FrequencyMHz                            : 3200
L1CacheKiB                              : 768
L2CacheKiB                              : 12288
L3CacheKiB                              : 12288
Temperature                             : 62
ProcessorType                           : CPU
ProcessorArchitecture                   : x86
InstructionSet                          : x86-64
Manufacturer                            : Intel(R) Corporation
Model                                   : Intel(R) Xeon(R) Gold 6146 CPU @ 3.20GHz
MaxSpeedMHz                             : 255
TotalCores                              : 12
TotalThreads                            : 24
Socket                                  : 2
[Status]
Health                                  : OK
State                                   : Enabled
[ProcessorId]
IdentificationRegisters                 : BF-EB-FB-FF-00-05-06-54
Id
CPU ID.
Name
CPU name.
FrequencyMHz
CPU frequency.
L1CacheKiB
CPU L1 cache size.
L2CacheKiB
CPU L2 cache size.
L3CacheKiB
CPU L3 cache size.
ProcessorType
CPU type.
CPU architecture.
InstructionSet
CPU instruction set.
Manufacturer
CPU manufacturer.
Model
CPU model.
MaxSpeedMHz
CPU maximum speed.
TotalCores
CPU cores.
TotalThreads
CPU total threads.
Socket
CPU socket ID.
CPU enabling status.
Health
CPU health status.
CPU ProcessID.
Perform this task to obtain memory information.
hREST -H host -p port -U username -P password getmemory -MI memory_id
Table 3 Parameter description
Parameter
Value
memory_id
Memory module name.
Optional.
If you do not specify this argument, the command displays information about all memory modules.
The command is available in in-band management mode.
# Obtain information about memory module CPU1channel 3 in slot D0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getmemory –MI CPU1CH3D0
CommonName                              : CPU1CH3D0
CapacityMiB                             : 32768
Manufacturer                            : Micron
Model                                   : 18ASF4G72PDZ-2G9E1
SerialNumber                            : S802C0F20212847D95C
OperatingSpeedMhz                       : 2933
MemoryDeviceType                        : DDR4
DataWidthBits                           : 64
RankCount                               : 2
PartNumber                              : 18ASF4G72PDZ-2G9E1
[MemoryLocation]
Position                                : CPU1
Channel                                 : 3
Slot                                    : D0
[Status]
State                                   : Enabled
Health                                  : OK
CommonName
CPU ID and memory module slot.
CapacityMiB
Memory module capacity.
Manufacturer
Memory module manufacturer.
Model
Memory module model.
SerialNumber
Memory module serial number.
OperatingSpeedMhz
Memory module operating speed.
MemoryDeviceType
Memory module device type.
DataWidthBits
Memory data width.
RankCount
Memory module ranks.
PartNumber
Memory module part number.
MemoryLocation
Memory module location.
Position
ID of the CPU that manages the memory module.
Channel
Memory module channel.
Slot
Memory module slot number.
Memory module enabling status.
Health
Memory module health status.
Perform this task to obtain physical drive information.
hREST -H host -p port -U username -P password getpdisk -PI physical_id
Table 5 Parameter description
Parameter
Value
physical_id
Physical drive ID (physical drive number in the BIOS).
Optional.
If you do not specify this argument, the command displays information about all physical drives.
# Obtain information about physical drive 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getpdisk –PI 0
Panel                                   : Front
Slot_phys_no                            : 11
Slot                                    : Front 11
Connection id                           : 0
Drive number in BIOS                    : 3
Drive number in OS                      : 3
Status                                  : Ready
Model                                   : ATA INTEL SSDSC2BB12
Firmware version                        : 0140
Serial number                           : PHWA606300D5120CGN
Property                                : 6 Gbps SATA SSD
Capacity                                : 0.11TiB
ControllerID                            : 0
[Status]
Health                                  : OK
State                                   : Enabled
Table 6 Command output
Panel
Panel location.
Slot_phys_no
Physical drive slot number.
Slot
Physical drive slot location and slot number.
Connection id
Physical drive connection ID, used for logical drive creation.
Physical drive number in the BIOS.
Drive number in OS
Physical drive number in the OS.
Status
Physical drive status.
Model
Physical drive model.
Firmware version
Physical drive firmware version.
Serial number
Physical drive serial number.
Property
Physical drive properties.
Capacity
Physical drive storage capacity.
PredictedMediaLifeLeftPercent
Remaining life of the physical drive in percentage. This field displays None when the feature is not supported.
ControllerID
ID of the storage controller to which the physical drive is connected.
Physical drive enabling status.
Health
Physical drive health status.
Perform this task to disable or enable a physical drive.
hREST -H host -p port -U username -P password setpdisk -CI controller_id –PI physical_id -S status -B BIOSId -I SlotId LI logical_id
Table 7 Parameter description
Parameter
Value
controller_id
Storage controller ID.
Optional.
physical_id
Physical drive ID (connection ID of the drive).
Optional.
logical_id
Logical drive ID.
Optional.
This ID can be obtained from the logical drive set.
status
Optional. Supported options:
·     Enable.
·     Disable.
·     JBOD.
BIOSId
Physical drive ID in the BIOS.
Optional.
If you do not specify this argument, the BIOS ID is displayed as 0 in logs for the physical drive.
SlotId
Slot ID.
Optional.
You can use this command to configure a correctly connected physical drive that is not used by any logical drives.
# Disable logical drive 22 of controller 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** setpdisk -CI 0 -PI 22 -S Disable
Success: set physical drive successfully
Perform this task to obtain information about a logical drive.
hREST -H host -p port -U username -P password getldisk -CI controller_id –LI logical_id
Table 8 Parameter description
Parameter
Value
controller_id
Optional.
If you do not specify this argument, the command displays information on all controllers.
logical_id
Logical drive ID.
Optional.
If you do not specify this argument, the command displays information about all logical drives. Make sure the specified drive ID exists.
# Obtain information about logical drive 3 managed by controller 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getldisk –CI 0 –LI 3
RaidControllerID                        : 0
Logical Drive Id                        : 3
LogicDiskName                           :
CapacityGiB                             : 400
RaidLevel                               : RAID 0
OptimumIOSizeBytes                      : 65536
DriveCache                              : Unchanged
CurrentReadPolicy                       : No Read Ahead
CurrentWritePolicy                      : Write Through
CurrentIOPolicy                         : Direct
CurrentCachePolicy                      : Direct
BootEnable                              : True
Drives                                  : 1, 2
Health                                  : OK
Table 9 Command output
RaidControllerID
Logical Drive Id
Logical drive ID.
LogicDiskName
Logical drive name.
CapacityGiB
Logical drive capacity.
RaidLevel
Logical drive RAID level.
OptimumIOSizeBytes
Logical drive stripe size. Supported options:
·     16384—16 KB.
·     32768—32 KB.
·     65536—64 KB.
·     131072—128 KB.
·     262144—256 KB.
·     524288—512 KB.
·     1048576—1 MB.
DriveCache
Logical drive cache policy.
CurrentReadPolicy
Logical drive read policy.
CurrentWritePolicy
Logical drive write policy.
CurrentIOPolicy
Logical drive I/O policy.
CurrentCachePolicy
BootEnable
Whether the drive is a boot drive.
Drives
IDs of member physical drives.
The physical drive IDs in the OS are displayed.
Health
Logical drive health status.
Perform this task to create a logical drive.
hREST -H host -p port -U username -P password addldisk -CI controlerid -N volumename –OV optsizebytes –M initmode –VL volumeraidlevel –CNI drivesid –SN spannumber –RP readpolicy –WP writepolicy –IP iopolicy –DCP cachepolicy –AP accesspolicy –V capacity –SU sizeunit –AM acceleration_method
User role
admin
Table 10 Parameter description
Parameter
Value
controllerid
Required.
volumename
Logical drive name.
Optional.
optsizebytes
Stripe size.
·     64.
·     128.
·     256.
·     512.
·     1024.
initmode
Initialization type.
·     No.
·     Fast.
·     Full.
volumeraidlevel
RAID level.
·     RAID0.
·     RAID1.
·     RAID5.
·     RAID6.
·     RAID00.
·     RAID10.
·     RAID50.
·     RAID60.
drivesid
Member physical drives.
Required.
Specify the physical drive connection ID and span ID in the [connectionID:spanID] format.
To specify multiple member drives, use an underscore (_) to separate the drive information, for example, [26:0_23:0].
spannumber
Span quantity.
Optional.
readpolicy
Read policy.
·     NoReadAhead.
·     ReadAhead.
writepolicy
Write policy.
·     WriteThrough.
·     WriteBack.
·     AlwaysWriteBack.
iopolicy
I/O policy.
·     Direct.
·     CachedWrite.
cachepolicy
Cache policy.
·     Unchanged.
·     Enabled.
·     Disabled.
accesspolicy
Access policy.
·     ReadWrite.
·     ReadOnly.
·     Blocked.
capacity
Optional.
sizeunit
Capacity unit.
·     MB.
·     GB.
·     TB.
acceleration_method
Acceleration method.
Available only for PMC controllers. Supported options:
·     1—None.
·     2—Controller Cache.
·     3—IO Bypass (available only on SSDs).
This command is available only for storage controllers supported by HDM out-of-band management.
# Create a logical drive. The logical drive properties are as follows:
·     Controller ID 0.
·     Logical drive name dragon.
·     Stripe size 64.
·     Initialization type No.
·     RAID level 1.
·     Two member physical drives with connection IDs 26 and 23 in span 0.
·     Two member drives per span.
·     Write policy WriteThrough, I/O policy Cached, cache policy Enabled, and access policy ReadOnly.
·     Capacity 600 GB.
·     Acceleration method None.
-> hREST –H 192.168.10.6 –U ****** -P ****** addldisk -CI 0 -N dragon -OV 64 -M No  -VL RAID1 -CNI [26:0_23:0] -SN 1 -RP NoReadAhead -WP WriteThrough -IP Cached -DCP Enabled -AP ReadOnly -V 600 -SU GB -AM 1
Success: add logical drive successfully
Perform this task to delete a logical drive.
hREST -H host -p port -U username -P password delldisk -CI controlerid -LI logicalid
Table 11 Parameter description
Parameter
Value
controllerid
Required.
logicalid
Logical drive ID.
Required.
# Delete logical drive 3 managed by storage controller 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** delldisk -CI 0 -LI 3
Success: delete logical driver successfully
Perform this task to configure a logical drive.
hREST -H host -p port -U username -P password setldisk -CI raidID –LI logicalID –WP writePolicy –RP readPolicy -AP AccessPolicy -CP DriveCache
Table 12 Parameter description
Parameter
Value
raidID
RAID controller ID.
Optional.
logicalID
Logical drive ID.
Optional.
writePolicy
Write policy.
·     WriteBack.
·     WriteThrough.
·     AlwaysWriteBack.
readPolicy
Read policy.
·     NoReadAhead.
·     ReadAhead.
AccessPolicy
Access policy.
·     Read/Write.
·     ReadOnly.
·     Blocked.
This field is not available for PMC storage controllers.
DriveCache
Drive cache policy.
·     Optional.
·     Enable.
·     Disable.
This command is supported by HDM-2.33 and later versions.
You cannot use this command to configure logical drives managed by PMC storage controllers.
G3 and G5 servers added support for configuring access policies and cache policies in HDM-6.05. The read policy and write policy of G6 servers are the default read policy and the default write policy.
# Configure write policy WriteThrough and read policy NoReadAhead for logical drive 0 managed by storage controller 0.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setldisk -CI 0 -LO 0 -WP WriteThrough -RP NoReadAhead
Success: set logical disk properties successfully
Perform this task to obtain information about a storage controller.
hREST -H host -p port -U username -P password getraid
# Obtain information about storage controller 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getraid
CommonName                              : RAIDStorage0
SerialNumber                            : SP73513465
State                                   : Enabled
Health                                  : OK
Controller
    Manufacturer                        : LSI
    Model                               : HBA-LSI-9440-8i
    SupportedDeviceProtocols            : ['SAS']
    SASAddress                          : null
    FirmwareVersion                     : 5.010.01-0671
    PackageVersion                      : None
    JBODState                           : Disabled
    MemorySizeMiB                       : null
    SupportedRAIDLevels                 : RAID0, RAID1, RAID5, RAID10, RAID50
    [CapacitanceStatus]
        State                           : Absent
        Health                          : None
Table 13 Command output
CommonName
Storage controller name.
SerialNumber
Storage controller serial number.
Storage controller enabling status.
Health
Storage controller health status.
Id
Manufacturer
Manufacturer.
Model
Storage controller model.
Protocols supported by the storage controller.
SASAddress
Storage controller address.
FirmwareVersion
Storage controller firmware version.
PackageVersion
Package version of LSI storage controllers.
JBODState
JBOD state.
MemorySizeMiB
Memory size.
SupportedRAIDLevels
Supported RAID levels.
CapacitanceStatus.State
Enabling status of the supercapacitor.
CapacitanceStatus.Health
Health status of the supercapacitor.
Perform this task to obtain storage information.
hREST -H host -p port -U username -P password getstorage -CI controlerid
Table 14 Parameter description
Parameter
Value
controllerid
Optional.
If you do not specify this argument, the command displays information for all storage controllers.
# Obtain storage information for storage controller 0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getstorage –CI 0
Ctrl_id                                 : 0
Raid card model                         : HBA-LSI-9440-8i
Firmware version                        : 5.010.01-0671
Serial number                           : SP73513465
DDR size                                :
Flash                                   :
Supercapacitor                          :
Charging status                         :
Support RAID Level                      : 0/1/5/10/50
Volumes
    Status                              : Optimal
    Level                               : RAID 0
    Capacity                            : 400GiB
    Element                             : 2
    Drives                              : 1,2
    Status                              : Optimal
    Level                               : RAID 0
    Capacity                            : 223.060GiB
    Element                             : 1
    Drives                              : 0
    Status                              : Optimal
    Level                               : RAID 0
    Capacity                            : 500GiB
    Element                             : 1
    Drives                              : 4
    Status                              : Optimal
    Level                               : RAID 1
    Capacity                            : 600GiB
    Element                             : 2
    Drives                              : 5,7
Drives                                  : 0, 1, 2, 3, 4, 5, 6, 7
Table 15 Command output
Ctrl_id
Raid card model
Firmware version
Serial number
DDR size
Storage controller DDR size.
Flash
Flash card state.
Supercapacitor
Supercapacitor state.
Charging status
Supercapacitor charging status.
Support RAID Level
Id
Logical drive ID.
Status
Logical drive status.
Level
RAID level.
Capacity
Element
Member physical drivers of the logical drive.
Volumes.Drives
Drives
IDs of all physical drives managed by the storage controller.
Perform this task to obtain event log messages.
hREST -H host -p port -U username -P password getelog -C count -T time -F file_path
Table 16 Parameter description
Parameter
Value
count
Number of event log messages to obtain.
Optional.
If you do not specify this argument, the command displays all event log messages. The maximum number depends on the window limit.
time
Time range of log messages to obtain.
Optional.
The time format is YYYY-MM-DDTHH:MM:SS+HH:MM. for example, 2019-03-13T03:24:45+08:00.
file_path
Path of a log file.
Optional.
# Obtain one event log message.
-> hREST –H 192.168.10.6 –U ****** -P ****** getelog –C 1
Record type                             : system_event_record
Time                                    : 2020-07-04 02:37:27
System software type                    : system_management_software
Generator type                          : ipmb_slave_address
Channel number                          : 0
Ipmb lun                                : 0
Event format ipmi version               : 4
Sensor type                             : Microcontroller / Coprocessor
Type number                             : 22
Sensor number                           : 255
Sensor name                             : Microcontroller
Event direction                         : asserted
Event reading class                     : discrete
Sensor reading value                    : 0
Triggered value                         : 0
Sensor reading value type               : unspecified
Triggered type                          : unspecified
Event description                       : BMC reset
Level                                   : 1
Table 17 Command output
Id
Log message ID.
The ID used by the HDM backstage is displayed, instead of the ID on the Web interface.
Record type
Event type. Supported options:
·     system_event_record.
·     oem_record.
Time
Message generation time.
Event source. Supported options:
·     bios.
·     smi_handler.
·     system_management_software.
·     system_software_oem.
·     remote_console_software.
·     oem.
·     terminal_mode_remote_console_software.
Generator type
Generator type. Supported options:
·     system_software_id.
·     ipmb_slave_address.
Channel number
Channel number.
Ipmb lun
LUN number.
IPMI protocol version.
Sensor type
Sensor type.
Type number
Log type number.
Sensor number
Sensor number.
Sensor name
Sensor name.
Event direction
Alert status. Supported options:
·     assertedThe event alarm is to be solved.
·     deassertedThe event alarm has been cleared.
Event reading class
Event reading class. Supported options:
·     threshold.
·     discrete.
·     oem.
Sensor reading.
Triggered value
Sensor reading threshold.
Sensor reading type. Supported options:
·     trigger_based.
·     oem_based.
·     sensor_specific.
·     unspecified.
Triggered type
Sensor type.
Event description
Event description.
Level
Event level. Supported options:
·     0Reserved for future use.
·     1Normal.
·     2Minor.
·     3Major.
·     4Critical.
Perform this task to delete event log messages.
hREST -H host -p port -U username -P password delelog
# Delete event log messages.
-> hREST –H 192.168.10.6 –U ****** -P ****** delelog
Success: clear system event log successfully
Perform this task to obtain network port information.
hREST -H host -p port -U username -P password getip –NI ethernetid
User role
admin
Table 18 Parameter description
Parameter
Value
ethernetid
Network port name.
Optional.
If you do not specify this argument, the command displays information about the network port specified by the host address.
Make sure the specified port name is valid, for example, eth0, eth1, or eth1.401.
The command cannot obtain temporary IP settings configured through a serial port. If such IP settings are configured, the command returns Failure: Failed to get ip information.
# Obtain network port information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getip –NI eth0
Description                             : Ethernet Interface eth0
AutoNeg                                 : True
FQDN                                    : HDM210200A00QH17C000002.
FullDuplex                              : True
HostName                                : HDM210200A00QH17C000002
MACAddress                              : 30:7B:AC:DE:64:B2
IPv6DefaultGateway                      : ::
InterfaceEnabled                        : True
MTUSize                                 : 1500
MaxIPv6StaticAddresses                  : 16
NameServers                             : ::
PermanentMACAddress                     : 30:7B:AC:DE:64:B2
SpeedMbps                               : 1000
[Status]
Health                                  : OK
Status                                  : Enabled
IPv4Status                              : True
IPv6Status                              : True
VLANEnable                              : False
[IPv4Addresses]
SubnetMask                              : 255.255.0.0
AddressOrigin                           : DHCP
Address                                 : 192.168.0.13
[IPv6Addresses]
Address                                 : fe80::327b:acff:fede:64b2
AddressOrigin                           : LinkLocal
PrefixLength                            : 64
Table 19 Command output
Id
Network port ID.
Name
Network port name.
Network port description.
FQDN
Fully qualified domain name (FQDN).
FullDuplex
Full duplex enabling status.
HostName
Host name.
MACAddress
MAC address.
IPv6DefaultGateway
IPv6 default gateway.
InterfaceEnabled
Network port enabling status.
MTUSize
MTU size.
Maximum length of IPv6 static addresses.
NameServers
Primary and secondary DNS server addresses. The primary server address comes first.
This field is available only when the network port is configured to obtain IP addresses through DHCP.
PermanentMACAddress
Permanent MAC address.
SpeedMbps
Transmission speed in Mbps.
Health
Health status.
Status
Enabling status.
IPv4Status
IPv4 enabling status.
IPv6Status
IPv6 enabling status.
VLANEnable
VLAN enabling status.
IPv4Addresses.SubnetMask
IPv4 subnet mask.
IPv4Addresses.AddressOrigin
IPv4 protocol type.
IPv4 address.
IPv6Addresses.Address
IPv6 address.
IPv6Addresses.AddressOrigin
IPv6 protocol type.
IPv6Addresses.PrefixLength
IPv6 prefix length.
Perform this task to configure IPv4 address settings for a network port.
hREST -H host -p port -U username -P password setipv4 –N ethernetid –S ipv4enable –IP address –T dhcpenable –G gateway –M subnetmask
Table 20 Parameter description
Parameter
Value
ethernetid
Network port name.
Required.
ipv4enable
Enable or disable IPv4.
·     Enabled.
·     Disabled.
address
IP address.
Optional.
dhcpenable
Address obtaining method.
·     DHCP.
·     Static.
gateway
Gateway address.
Optional.
subnetmask
Subnet mask.
Optional.
This operation enables the shared network port if the port is disabled.
For the network to operate correctly, make sure IPv6 settings are enabled when you disable IPv4 address settings for the network port.
# Configure IPv4 address settings for network port eth0.
-> hREST –H 192.168.10.6 –U ****** -P ****** setipv4 -N eth0 -IP 172.16.10.162 -T Static -G 0.0.0.0 -M 255.255.255.0
Success: set network successfully
hREST -H host -p port -U username -P password setipv6 –N ethernetid –S ipv6enable –IP address –T dhcpenable –G gateway –L prefixlength
Table 21 Parameter description
Parameter
Value
ethernetid
Network port name.
Required.
Make sure the specified port name is valid.
ipv6enable
Enable or disable IPv6.
·     Enabled.
·     Disabled.
address
IP address.
Optional.
dhcpenable
·     DHCP.
·     Static.
gateway
Gateway address.
Optional.
prefixlength
Prefix length.
Optional.
For the network to operate correctly, make sure IPv4 settings are enabled when you disable IPv6 address settings for the network port.
# Configure IPv6 address settings for network port eth0.
-> hREST –H 192.168.10.6 –U ****** -P ****** setipv6 -N eth0 -IP 2022::10 –T Static –G 2022::1 –L 64
Perform this task to obtain VLAN information on a network port.
hREST -H host -p port -U username -P password getvlan -NI ethernetid
Table 22 Parameter description
Parameter
Value
ethernetid
Network port name.
Required.
# Obtain VLAN information on network port eth0.
-> hREST –H 192.168.10.6 –U ****** -P ****** getvlan –N eth0
VLANEnable                    : False
VLANId                        : 0
VLANPriority                  : 0
Table 23 Command output
VLANEnable
VLAN enabling status. Supported options:
·     TrueEnabled.
·     FalseDisabled.
VLANId
VLAN ID.
VLANPriority
VLAN priority. Value 0 indicates that no priority is specified.
Perform this task to configure VLAN settings for a network port.
hREST -H host -p port -U username -P password setvlan –N ethernetid -S vlanenable -I vlanid –P priority
Table 24 Parameter description
Parameter
Value
ethernetid
Network port name.
Required.
vlanenable
Enable or disable VLAN.
·     Enabled.
·     Disabled.
vlanid
VLAN ID.
Optional.
Integer in the range of 2 to 4094.
priority
VLAN priority.
Optional.
Integer in the range of 0 to 7.
A larger value represents a higher priority.
# Configure VLAN settings for network port eth0.
-> hREST –H 192.168.10.6 –U ****** -P ****** setvlan -N eth0 -S Enabled -I 5 -P 0
Perform this task to obtain the network port mode.
hREST -H host -p port -U username -P password getnetmode
# Obtain the network port mode.
-> hREST –H 192.168.10.6 –U ****** -P ****** getnetmode
PortModes                               : Normal mode
Table 25 Command output
PortModes
Network port mode. Supported options:
·     Normal mode.
·     Bonding mode.
·     Active/standby mode.
Perform this task to set the network port mode.
hREST -H host -p port -U username -P password setnetmode –M status
Table 26 Parameter description
Parameter
Value
status
Network port mode.
Required. Supported options:
·     NormalNormal mode.
·     BondBonding mode.
·     Adaptive—Active/standby mode.
# Set the network port mode to bonding.
-> hREST –H 192.168.10.6 –U ****** -P ****** setnetmode –M Bond
Success: set network port mode succeed
Perform this task to obtain network adapter information.
hREST -H host -p port -U username -P password getnic
hREST getnic
# Obtain network adapter information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getnic
CommonName                              : mLOM
CardManufacturer                        : H3C
SlotNumber                              : 9
CardModel                               : 2*10GE
SerialNumber                            : 02A3GLH175000029
State                                   : Enabled
Health                                  : OK
Controller
    Model                               : NIC-10GE-2P-560T-L2
    FirmwareVersion                     : 1.2585.0
    PortCount                           : 2
    Port
        MACAddress                      : ['30:7B:AC:C1:24:54']
        LinkStatus                      : Up
        MediaType                       : ElectricalPort
        MACAddress                      : ['30:7B:AC:C1:24:55']
        LinkStatus                      : Down
Table 27 Command output
CommonName
Resource name of the network adapter.
Location
Mark of the network adapter.
CardManufacturer
Manufacturer of the network adapter.
SlotNumber
Slot number of the network adapter.
Model
Interface type of the network adapter.
SerialNumber
Serial number of the network adapter.
Controller.Id
Resource ID of the network adapter.
Controller.Manufacturer
Chip manufacturer of the network adapter.
Controller.Model
Model of the network adapter.
Controller.FirmwareVersion
Firmware version of the network adapter.
Controller.PortCount
Number of related network ports for the network adapter.
Controller.Port.Id
Related network port ID for the network adapter.
Controller.Port.MACAddress
Related network port MAC address for the network adapter.
Controller.Port.LinkStatus
Related network port status for the network adapter.
Controller.Port.MediaType
Related network port type for the network adapter.
Perform this task to obtain IP-based login rule information.
hREST -H host -p port -U username -P password getloginruleip
# Obtain IP-based login rule information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getloginruleip
MemberId                                : 1
IpFrom                                  : 192.168.253.1
IpTo                                    : 192.168.253.2
MacAddress                              : aa:bb:cc:dd:ee:ff
Rule                                    : Blacklist
TimeRange                               : Enabled
TimeFrom                                : 2023-11-17T00:00:00+08:00
TimeTo                                  : 2023-11-18T00:00:00+08:00
Protocol                                : ['TCP', 'UDP']
PortFrom                                : 10096
PortTo                                  : 10100
Table 28 Command output
MemberId
Rule ID.
IpFrom
Login rule start IP address.
IpTo
Login rule end IP address.
MacAddress
MAC address entries.
Rule
Rule type. Supported options:
·     Whitelist.
·     Blacklist.
TimeRange
Time range enabling status. Supported options:
·     Enabled.
·     Disabled.
TimeFrom
Login rule start time.
TimeTo
Login rule end time.
Protocol
Supported protocols.
PortFrom
Start port number of the login rule.
PortTo
End port number of the login rule.
Perform this task to add or delete an IP-based login rule.
hREST -H host -p port -U username -P password addloginruleip –O operator –E rule –M macaddress –P starttime –Q endtime -IS ipstart –IE ipend -PS port_start -PE port_end -I member_id -T protocol type
Table 29 Parameter description
Parameter
Value
operator
Operation type.
·     Add—Add a rule.
·     Del—Delete a rule.
rule
Rule type.
·     Allow—Whitelist rule that allows login.
·     Block—Blacklist rule that blocks login.
macaddress
MAC address.
Optional.
You must specify either the rule or ipstart argument.
starttime
Rule start time.
Optional.
Format: yyyy-mm-ddThh:mm
For example, 2020-06-03T13:10
endtime
Rule end time.
Optional.
For example, 2020-06-06T13:15
ipstart
Rule start IP address.
Optional.
ipend
Rule end IP address.
Optional.
port_start
Rule start port number.
Optional.
The port range is 1 to 65535.
port_end
Optional.
member_id
Member ID.
N/A
protocol type
Protocol type.
Supported options:
·     UDP.
·     TCP.
·     TCP+UDP.
# Create a blacklist rule to block access from IP range 172.16.10.11-172.16.10.13 and set the time range to 2020-05-20T12:22-2020-06-03T13:10.
-> hREST –H 192.168.10.6 –U ****** -P ****** setloginruleip -O Add -E Block -IS 172.16.10.11 -IE 172.16.10.13 -M aa:aa:aa:aa:aa:aa -P 2020-05-20T12:22 -Q 2020-06-03T13:10
Success: set ip login rule succeed
# Delete a blacklist rule.
-> hREST –H 192.168.10.6 –U ****** -P ****** setloginruleip -O Del -E Block -IS 172.16.10.11 -IE 172.16.10.13 -M aa:aa:aa:aa:aa:aa -P 2020-05-20T12:22 -Q 2020-06-03T13:10
Perform this task to obtain NVMe SSD information.
hREST -H host -p port -U username -P password getnvmessd
# Obtain NVMe SSD information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getnvmessd
SlotID                        : N1 Slot 164
VendorName                    : INTEL
ProductName                   : P3520
PDStatus                      : Normal
PercentLife                   : 0
SerialNumber                  : CVPF733500CL450RGN
ModelNumber                   : SSDPE2MX450G7
Capacity                      : 450.0GB
FirmwareVersion               : MDV10271
PortType                      : PCIe
Table 30 Command output
SlotID
PCIe slot.
VendorName
SSD manufacturer.
ProductName
SSD product name.
PDStatus
NVMe SSD status.
PercentLife
Percentage of NVMe SSD life used.
SerialNumber
SSD serial number.
ModelNumber
SSD model number.
Capacity
SSD capacity.
FirmwareVersion
SSD firmware version.
PortType
SSD port type.
Perform this task to obtain power capping information.
hREST -H host -p port -U username -P password getpowerlimit
This command is unavailable for blade servers.
# Obtain power capping information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getpowerlimit
PowerLimitEnable                        : False
LimitInWatts                            : 500
LimitException                          : HardPowerOff
Table 31 Command output
PowerLimitEnable
Power capping enabling status. Supported options:
·     TrueEnabled.
·     FalseDisabled.
LimitInWatts
Power cap value.
LimitException
Action to take upon a power capping failure. Supported options:
·     HardPowerOff.
·     NoAction.
Perform this task to configure power capping.
hREST -H host -p port -U username -P password setpowerlimit -S status -V limitvalue –E exception
Table 32 Parameter description
Parameter
Value
status
Enable or disable power capping.
·     Enable.
·     Disable.
limitvalue
Power cap value.
Optional.
The value range is 150 to 10000.
exception
·     Shutdown.
·     NoAction.
Blade servers do not support power capping.
# Enable power capping, set the power cap value to 600, and configure the system not to perform any action upon a power capping failure.
-> hREST –H 192.168.10.6 –U ****** -P ****** setpowerlimit -S Enable -V 600 -E NoAction
Success: set power limit succeed
Perform this task to obtain power supply information.
hREST -H host -p port -U username -P password getpsu
hREST getpsu
# Obtain power supply information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getpsu
Model                                   : PSR550-12A
SerialNumber                            : N/A
PowerSupplyType                         : No-input
PowerCapacityWatts                      : 550
PowerOutputWatts                        : 108
LineInputVoltageType                    : ACMidLine
LineInputCurrent                        : 0.667
FirmwareVersion                         : 1M.0009.0021.001
PowerID                                 : 1
SlotNumber                              : 0
ActiveStandby                           : Active
[Status]
Health                                  : Critical
State                                   : Enabled
Table 33 Command output
Name
Power supply name.
Model
Power supply model.
SerialNumber
Power supply serial number.
PowerSupplyType
Power supply type.
PowerCapacityWatts
Total power.
PowerOutputWatts
Output power of the power supply.
Input voltage type.
LineInputCurrent
Input current of the power supply.
FirmwareVersion
Power supply firmware version.
PowerID
Power supply ID.
SlotNumber
Power supply slot number.
ActiveStandby
Power supply active/standby state.
Power supply enabling status.
Health
Power supply health status.
Perform this task to set the active/standby state of a power supply.
hREST -H host -p port -U username -P password setpmb -I powerid -S status
Table 34 Parameter description
Parameter
Value
powerid
Power supply ID.
Required.
status
Power supply state.
·     Active.
·     Standby.
# Specify power supply 2 as a standby power supply.
-> hREST –H 192.168.10.6 –U ****** -P ****** setpmb –I 2 –S Standby
 Success: set power redundancy succeed
Perform this task to power on or power off the server.
hREST -H host -p port -U username -P password syspowerctrl -T type
Table 35 Parameter description
Parameter
Value
type
Power action.
·     On.
·     GracefulShutdown.
·     ForceOff.
·     ForceReset.
·     ForcePowerCycle.
# Power off the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** syspowerctrl -T ForceOff
Success: set power state succeed
Perform this task to obtain device information.
hREST -H host -p port -U username -P password getproductinfo
# Obtain device information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getproductinfo
AssetTag                                : N/A2
Manufacturer                            : Unis Huashan Technologies Co., Ltd.
Model                                   : UniServer R4900 G3
HostName                                : HDM123456
IndicatorLED                            : Off
SerialNumber                            : 12345678901234567890
PartNumber                              : 0200A00Q
ChassisPartNumber                       : 0235AQ7
PowerState                              : On
SystemType                              : Physical
BiosVersion                             : 2.00.41 V100R001B02D041
[Status]
Health                                  : OK
HealthRollup                            : None
State                                   : Enabled
[Healthstate]
OverallHealth                           : OK
board                                   : OK
current                                 : OK
disk                                    : OK
fans                                    : OK
memory                                  : OK
pcie                                    : OK
power                                   : OK
processor                               : OK
storage                                 : OK
raid                                    : OK
temperature                             : OK
volatge                                 : OK
Table 36 Command output
Id
Device ID.
Name
Device name.
AssetTag
Device asset tag.
Manufacturer
Device manufacturer.
Model
Device model.
HostName
Host name.
IndicatorLED
LED status:
·     On.
·     Off.
·     Blink.
SerialNumber
Serial number of the device.
PartNumber
Part number of the device.
ChassisPartNumber
Chassis part number.
PowerState
Current power state.
SystemType
System type.
BiosVersion
BIOS version.
Status
Device status:
·     Health—System resource health status.
·     HealthRollup.
·     State—System resource enabling status.
OverallHealth
Overall health status.
board
System board health status.
current
Electrical current health status.
disk
Drive health status.
fans
Fan health status.
memory
Memory health status.
pcie
PCIe module health status.
power
processor
Processor health status.
storage
Storage health status.
raid
temperature
Temperature sensor health status.
volatge
Voltage sensor health status.
Set the asset tag
Perform this task to set the device asset tag.
hREST -H host -p port -U username -P password setassettag -T assettag
Table 37 Parameter description
Parameter
Value
assettag
Device asset tag.
Required.
# Set the asset tag.
-> hREST –H 192.168.10.6 –U ****** -P ****** setassettag –T test_123
Success: set asset tag succeed
Set a host name
Perform this task to set a host name.
hREST -H Host -p Port -U UserName -P PassWord sethostname -M NameMathod -N NewName
User role
Admin
Table 38 Parameter description
Parameter
Value
NameMathod
Method for obtaining the name.
·     Manual.
·     Auto.
NewName
Host name.
Optional.
The name is a string of 1 to 63 characters.
If the manual method is specified, you must specify a new name. If the auto method is specified, you cannot specify a host name.
The host name is a string of 1 to 63 characters. The string cannot end or start with a hyphen (-).
# Set the host name manually to HDM210235A2CSH17C000001.
-> ./hREST –H 192.168.10.6 –U ****** -P ****** sethosname -M Manual -N HDM210235A2CSH17C000001
Success: host name configuration is successful
Perform this task to obtain user role information.
hREST -H host -p port -U username -P password getrole –R role
Table 39 Parameter description
Parameter
Value
role
User role.
Optional.
If you do not specify this argument, the command displays information about all user roles.
# Obtain information about the administrator user role.
-> hREST –H 192.168.10.6 –U ****** -P ****** getrole –R Administrator
Role                                    : Administrator
IsPredefined                            : True
AssignedPrivileges                      : Login, ConfigureManager, ConfigureUsers, ConfigureSelf, ConfigureComponents
OemPrivileges                           : OemKvm, OemVemdia, OemWeb, OemIPMI
Table 40 Command output
Role
User role that represents a set of privileges.
IsPredefined
Whether the role is predefined.
AssignedPrivileges
Role privileges. Supported options:
·     ConfigureManager.
·     ConfigureUsers.
·     ConfigureComponents.
·     Login.
·     ConfigureSelf.
OemPrivileges
Csutom privileges. Supported options:
·     OemWebWeb access.
·     OemIPMIIPMI access.
·     OemKvmRemote control.
·     OemVmmRemote media.
·     OemSecurityMgmtSecurity management.
·     OemPowerControlPower control.
·     OemDiagnosisMaintenance and diagnosis.
·     OemSystemAuditSystem audit.
Perform this task to assign privileges to a role group.
hREST -H host -p port -U username -P password setrole –R Role –P Privileges
Table 41 Parameter description
Parameter
Value
Role
Role group ID.
Required.
Privileges
Privileges of a role group.
·     Kvm.
·     Vmm.
·     SecurityMgmt.
·     PowerControl.
·     Diagnosis.
·     ConfigureSelf.
·     OemSystemAudit.
You can specify multiple privileges as needed. If you do not specify this argument, the role group does not have any privileges.
# Assign privileges Kvm and Vmm to role group CustomRole1.
-> hREST –H 192.168.10.6 –U ****** -P ****** setrole -R CustomRole1 -P Kvm,Vmm
Success: set user role information successfully
Change history
Version
Change description
HDM-2.08 and hREST V1.08
Moved privilege assignment from the Security module to the Users Accounts module.
Perform this task to obtain boot settings.
hREST -H host -p port -U username -P password getsysboot
This command obtains boot settings for the next startup.
# Obtain boot settings.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsysboot
BootSourceOverrideTarget                : Pxe
BootSourceOverrideEnabled               : Continuous
BootSourceOverrideMode                  : Legacy
Table 42 Command output
Current boot device to be used at next boot. Supported options:
·     None.
·     Hdd.
·     Pxe.
·     BiosSetup.
·     Cd.
Current enabling status of the boot settings. Supported options:
·     Once—Effective only for the next startup.
·     Continuous—Always effective.
Current boot mode. Supported options:
·     None.
·     Legacy—Legacy mode.
·     UEFI—UEFI mode.
Perform this task to configure system boot settings.
hREST -H Host -p Port -U UserName -P PassWord setsysboot -D BootDevice –E Effective -M BootMode
User role
admin
Table 43 Parameter description
Parameter
Value
BootDevice
Boot device.
·     CD.
·     HDD.
·     PXE.
·     BIOSSETUP.
·     none.
Effective
Effective period for the boot settings.
·     OnceEffective only at the next startup.
·     ContinuousEffectively permanently.
BootMode
Boot mode.
·     Legacy.
·     UEFI.
HDM B01 supports only the once effective period.
# Set the boot device to PXE, the boot mode to UEFI, and the effective period to Continuous.
-> ./hREST –H 192.168.10.6 –U ****** -P ****** setsysboot -D PXE -E Continuous -M UEFI
Success: set system startup item successfully
Perform this task to obtain the health status from the server.
hREST -H host -p port -U username -P password getsyshealth
# Obtain the health status of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsyshealth
System health                           : OK
Temperature                             : OK
Voltage                                 : OK
Current                                 : OK
Memory                                  : OK
Fans                                    : OK
Processor                               : OK
Disk                                    : OK
Power                                   : OK
Table 44 Command output
System health
Overall health status. Supported options:
·     OK.
·     Caution.
·     Warning.
·     Critical.
Supported health status levels vary by HDM version.
Temperature
Temperature health status.
Voltage
Voltage health status.
Current
Electric current health status.
Memory
Fans
Fan health status.
Processor
Disk
Disk health status.
Power
Perform this task to obtain HDM operation logs.
hREST -H host -p port -U username -P password gethdmlog -C count
Table 45 Parameter description
Value
count
Number of HDM operation logs.
Optional.
If you do not specify this argument, the command displays all HDM operation logs.
# Obtain HDM operation logs.
-> hREST –H 192.168.10.6 –U ****** -P ****** gethdmlog -C 2
UserName                                : N/A
Interface                               : KCS
LogIpAdd                                : HOST
LogType                                 : 3
LogContent                              : Failed to set virtual keyboard mouse status.
Timestamp                               : 2020-07-03 23:41:07.178
HostName                                : HDM210200A00QH175000046
LogLevel                                : WARN
UserName                                : admin
Interface                               : LAN
LogIpAdd                                : 192.168.0.177
LogType                                 : 1
LogContent                              : HTTPS login from IP:192.168.0.177 user:admin
Timestamp                               : 2020-07-03 23:42:05.133
LogLevel                                : INFO
Table 46 Command output
ID
HDM log ID.
Username
Username of the administrator.
Interface type.
LogIpAdd
IP address.
LogType
Log type. Supported options:
·     1Audit log.
·     2Firmware update log.
·     3Operation log.
·     4Event log.
·     5Hardware update log.
LogContent
Log content.
Timestamp
Timestamp of the log.
HostName
Host name.
LogLevel
Severity level of the log. Supported options:
·     INFOInformation.
·     WARNWarning.
Obtain system time
Perform this task to obtain the system time from the server.
hREST -H host -p port -U username -P password gettime
For HDM of some HDM-1.10.xx versions, the tool returns time in GMT format, and the time on the Web service displays in UTC format. The time displayed depends on the API, and the tool does not add the time display compatibility.
# Obtain the system time from the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** gettime
Time                       : 2023-11-15 13:28:25
Timezone                   : UTC+08:00
Table 47 Command output
Time
Current system time of the server.
Timezone
Current time zone of the server.
Set the time zone
Perform this task to set the time zone of the server.
hREST -H host -p port -U username -P password settimezone –Z timezone
Table 48 Parameter description
Parameter
Value
timezone
Time zone.
Required.
# Set the time zone of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** settimezone -Z UTC-9
Success: set system timezone successfully: UTC-9
Perform this task to obtain temperature information of the server.
hREST -H host -p port -U username -P password gettemp
# Obtain the temperature information of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** gettemp
Name                          : N1 FrontBP R
SensorNumber                  : 185
ReadingCelsius                : 27
PhysicalContext               : Room
LowerThresholdCritical        : 0
UpperThresholdCritical        : 100
LowerThresholdFatal           : 0
UpperThresholdFatal           : 0
LowerThresholdNonCritical     : 0
UpperThresholdNonCritical     : 95
[Status]
Health                        : OK
State                         : Enabled
Name                          : N2 FrontBP L
SensorNumber                  : 186
ReadingCelsius                : 0
[Status]
Health                        : Critical
State                         : Disabled
Name                          : N2 FrontBP R
SensorNumber                  : 187
ReadingCelsius                : 29
[Status]
Health                        : OK
State                         : Enabled
Table 49 Command output
Name
Name of a temperature sensor.
SensorNumber
Number of the temperature sensor, which uniquely identifies a temperature sensor.
ReadingCelsius
Current reading of the temperature sensor.
PhysicalContext
Physical environment.
Lower major threshold of the temperature sensor.
Upper major threshold of the temperature sensor.
LowerThresholdFatal
Lower critical threshold of the temperature sensor.
UpperThresholdFatal
Upper critical threshold of the temperature sensor.
Lower minor threshold of the temperature sensor.
Upper minor threshold of the temperature sensor.
Status
Status of the temperature sensor. Supported options:
·     Health—Health state.
·     State—Enabling state. Supported options include Enabled and Disabled.
Perform this task to obtain information about a user.
hREST -H host -p port -U username -P password getuser –N name
Table 50 Parameter description
Parameter
Value
name
Username.
Optional.
If you do not specify this argument, the command displays information about all users.
# Obtain information about user test.
-> hREST –H 192.168.10.6 –U ****** -P ****** getuser –N test
UserName                                : test
RoleId                                  : Operator
Enabled                                 : True
Privilege                               : ['IPMI', 'WEB']
IPMIEnable                              : True
KvmEnable                               : True
SnmpV3AccessPermission                  : read_only
SnmpV3AuthProtocol                      : sha
SnmpV3Enable                            : True
SnmpV3PrivProtocol                      : des
VmediaEnable                            : True
WebEnable                               : True
Table 51 Command output
Id
User ID.
UserName
Username.
RoleId
User role.
Enabled
Enabling status of access privileges. Supported options:
·     True—Enabled.
·     FalseDisabled.
Privilege
Privileges of the user.
IPMIEnable
Enabling status of IPMI access privilege.
KvmEnable
Enabling status of KVM access privilege.
VmediaEnable
Enabling status of virtual media access privilege.
WebEnable
Enabling status of Web interface access privilege.
SnmpV3Enable
Enabling status of SNMPv3 access privilege.
SNMPv3 access privilege. Supported options:
·     read_only.
·     read_write.
SnmpV3AuthProtocol
SNMPv3 authentication algorithm. Supported options:
·     sha.
·     md5.
SnmpV3PrivProtocol
SNMPv3 encryption algorithm. Supported options:
·     des.
·     aes.
Add a user
Perform this task to add a user.
hREST -H host -p port -U username -P password adduser -N name –P userpwd –R role -EN enabled –KVM kvmenable –VME vmeenable -IPMI Enable -WEB Enable -V3 SnmpV3Enable -V3APE SnmpV3AccessPermission -V3APR SnmpV3AuthProtocol -V3PP SnmpV3PrivProtocol -I user_id - V3PWD SnmpV3Password
Table 52 Parameter description
Parameter
Value
name
Username of a user.
Required.
userpwd
Password of the user.
Required.
role
Role of the user.
Required.
enabled
Enable or disable the access privileges.
·     Enable.
·     Disable.
kvmenable
Enable or disable the KVM access privilege.
·     Enable.
·     Disable.
vmeenable
Enable or disable the VMedia access privilege.
·     Enable.
·     Disable.
IPMIEnable
Enable or disable the IPMI access privilege.
Optional.
Boolean.
WebEnable
Enable or disable the Web extended privilege.
Optional.
Boolean.
SnmpV3Enable
Enable or disable SNMPv3.
Optional.
Boolean.
String. Supported options:
·     read_only.
·     read_write.
SnmpV3AuthProtocol
·     sha.
·     md5.
SnmpV3PrivProtocol
·     des.
·     aes.
user_id
User ID.
Optional.
String.
SnmpV3Password
SNMPv3 independent password.
Optional.
String.
The maximum length of the independent password is 40 characters.
In a version earlier than HDM-2.0.04, role groups CustomRole1 to CustomRole5 are not configurable. From HDM-2.0.04 to HDM-2.0.06, role groups Custom 1 to Custom 5, instead of CustomRole1 to CustomRole5, take effect.
# Add a user named test.
-> hREST –H 192.168.10.6 –U ****** -P ****** adduser -N test -P test@test123 -R Operator -EN Enable -KVM Enable -VME Enable -IPMI Enable -WEB Enable -V3 Enable -V3APE read_only -V3APR sha -V3PP des
Success: add user successfully
Change history
Version
Change description
hREST V1.08
Added supported options CustomRole1, CustomRole2, CustomRole3, CustomRole4, and CustomRole5 for role groups.
Edit a user
Perform this task to edit a user, including changing the password or role of the user.
hREST -H host -p port -U username -P password setuser –N name –P newpwd –R newrole -EN enabled –KVM kvmenable –VME vmeenable -IPMI Enable -WEB Enable -V3 SnmpV3Enable -V3APE SnmpV3AccessPermission -V3APR SnmpV3AuthProtocol -V3PP SnmpV3PrivProtocol -U newname - V3PWD SnmpV3Password
Table 53 Parameter description
Parameter
Value
name
Username of a user to be edited.
Required.
newpwd
New password of the user.
Optional.
newrole
New role of the user.
Optional.
enabled
·     Enable.
·     Disable.
kvmenable
·     Enable.
·     Disable.
vmeenable
·     Enable.
·     Disable.
IPMIEnable
Optional.
Boolean.
WebEnable
Optional.
Boolean.
SnmpV3Enable
Optional.
Boolean.
·     read_only.
·     read_write.
SnmpV3AuthProtocol
·     sha.
·     md5.
SnmpV3PrivProtocol
·     des.
·     aes.
newname
Username.
Optional.
SnmpV3Password
Optional.
# Edit user test.
-> hREST –H 192.168.10.6 –U ****** -P ****** setuser -N test -P test@test123 -R Operator -EN Enable -KVM Enable -VME Enable -IPMI Enable -WEB Enable -V3 Enable -V3APE read_only -V3APR sha -V3PP aes
Success: set user successfully
Delete a user
Perform this task to delete a user.
hREST -H host -p port -U username -P password deluser –N name
Table 54 Parameter description
Parameter
Value
name
Name of the user to be deleted.
Required.
# Delete user named user.
-> hREST –H 192.168.10.6 –U ****** -P ****** deluser –N user
Success: delete user successfully
Perform this task to obtain BIOS settings of the server.
hREST -H host -p port -U username -P password getbios –A value
Table 55 Parameter description
Parameter
Value
value
BIOS option.
This argument is required when HDM or the BIOS firmware version is B01.
This argument is optional when HDM or the BIOS firmware version is B02 or later.
If BIOS version BIOS-1.00.XX or HDM version HDM-1.10.XX is used, hREST uses the HDM IPMI interface to obtain BIOS settings, and only the setting of a single BIOS option can be obtained at a time.
# Obtain the settings of the BIOS CPUC6Report option.
-> hREST –H 192.168.10.6 –U ****** -P ****** getbios -A CPUC6Report
CPUC6Report                               : Auto
Perform this task to configure BIOS settings.
hREST uses the HDM IPMI or Redfish interface to configure BIOS settings. The interface to use depends on the HDM version:
·     If the HDM version is HDM-1.10.XX, the HDM IPMI interface is used.
·     If the HDM version is HDM-1.11.00 or later, the HDM Redfish interface is used.
For more information about the configurable options, refer to the configuration options that can be obtained by using the getbios command.
hREST -H host -p port -U username -P password setbios –A attribute –V value
Table 56 Parameter description
Parameter
Value
attribute
BIOS option.
Required.
value
Value of the BIOS option.
Required.
For this configuration to take effect, reboot the BIOS.
# Disable the BIOS CPUC6Report option.
-> hREST –H 192.168.10.6 –U ****** -P ****** setbios -A CPUC6Report -V Disable
Success: BIOS setup is successfully
# Specify BootOption#1 as Network.
-> hREST –H 192.168.10.6 –U ****** -P ****** setbios -a BootOption#1 -v Network
Obtain pending BIOS settings
Perform this task to obtain configured BIOS settings that have not taken effect.
hREST -H host -p port -U username -P password getbiossetting
This command is not supported if the BIOS version is BIOS-1.00.XX or the HDM version is HDM-1.10.XX.
# Obtain configured BIOS settings that have not taken effect.
-> hREST –H 192.168.10.6 –U ****** -P ****** getbiossetting
CPUC6Report                               : Auto
Restore the BIOS settings
Perform this task to restore the BIOS settings.
hREST -H host -p port -U username -P password setbiosdefault –T Type
Table 57 Parameter description
Parameter
Value
Restoring type of BIOS settings.
·     defaultRestores the BIOS to the default settings.
·     factoryRestores the BIOS to the factory defaults.
HDM B01 does not support this command. Support for this command is added in HDM B03-1.30.15SP12 and synchronized with HDM B05-2.19.
If the factory defaults cannot be restored, the command restores the default settings.
# Restore the BIOS to the factory defaults.
-> hREST –H 192.168.10.6 –U ****** -P ****** setbiosdefault –T factory
Success: restore BIOS factory settings successfully
Restore the BMC settings
Perform this task to restore the BMC settings.
hREST -H host -p port -U username -P password setbmcdefault –T Type
Table 58 Parameter description
Parameter
Value
Restoring type of BMC settings.
·     defaultRestore BMC to the default settings.
·     factoryRestore BMC to the factory defaults.
# Restore BMC to the factory defaults.
-> hREST H 192.168.10.6 –U ****** -P ****** setbmcdefault –T factory
Success: restore BMC factory settings successfully
Obtain fan information
Perform this task to obtain fan information of the server.
hREST -H host -p port -U username -P password getfan
hREST getfan
# Obtain information about fans of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getfan
FanCount                                : 6
FanSpeedAdjustmentMode                  : Automatic
FanName                                 : N/A
Slot                                    : 1
Model                                   : 3203A01V
RatedSpeedRPM                           : 19
SpeedRPM                                : 3500
LowerThresholdRPM                       : N/A
[Status]
State                                   : Enabled
Health                                  : N/A
FanName                                 : N/A
Model                                   : 3203A01V
RatedSpeedRPM                           : 42
SpeedRPM                                : 7200
[Status]
State                                   : Enabled
Health                                  : N/A
FanName                                 : N/A
Model                                   : 3203A01V
RatedSpeedRPM                           : 19
SpeedRPM                                : 3300
[Status]
State                                   : Enabled
Health                                  : N/A
FanName                                 : N/A
Model                                   : 3203A01V
RatedSpeedRPM                           : 25
SpeedRPM                                : 4300
[Status]
State                                   : Enabled
Health                                  : N/A
FanName                                 : N/A
Model                                   : 3203A01V
RatedSpeedRPM                           : 42
SpeedRPM                                : 7300
[Status]
State                                   : Enabled
Health                                  : N/A
FanName                                 : N/A
Model                                   : 3203A01V
RatedSpeedRPM                           : 42
SpeedRPM                                : 7300
[Status]
State                                   : Enabled
Health                                  : N/A
Table 59 Command output
FanCount
Maximum number of fan sensors.
Fan speed mode.
Id
Fan ID.
FanName
Fan name.
Slot
Slot number.
Location
Fan position.
Model
Fan model.
RatedSpeedRPM
Fan rotation ratio.
SpeedRPM
Fan speed.
LowerThresholdRPM
Lower fan speed alarm threshold.
Enabling status of the fan.
Health
Health status of the fan.
Set the fan speed
Perform this task to set the fan speed.
hREST -H host -p port -U username -P password setfan –M mode –S fanspeed
Table 60 Parameter description
Parameter
Value
mode
Fan speed mode.
·     Optimal.
·     Increased.
·     Maximum.
·     Custom.
fanspeed
Fan speed level.
Required.
Value range: 1 to 20.
This field is available only when the FanSpeedAdjustmentMode field is set to Custom.
# Set the fan speed.
-> hREST –H 192.168.10.6 –U ****** -P ****** setfan -M Custom -S 10
Success: fan speed control successfully
Disable inband management of HDM users
Perform this task to disable inband management of HDM users.
hREST -H host -p port -U username -P password closeinner –S status
Table 61 Parameter description
Parameter
Value
status
Enable or disable the disabling inband management feature.
Supported options:
·     Enable.
·     Disable.
# Disable inband management of HDM users.
-> hREST –H 192.168.10.6 –U ****** -P ****** closeinner –S Enable
Success: set close inner set user status successfully
Export configuration
Perform this task to export configuration.
hREST -H host -p port -U username -P password downloadconf -T type –F filepath
Table 62 Parameter description
Parameter
Value
type
Type of the configuration to be exported.
·     RAID.
·     BMC.
·     BIOS.
filepath
Name of the configuration file and the path for saving the file.
Required.
If you do not specify this argument, the command saves the configuration to the config file folder under the hRest directory.
# Export BIOS configuration.
-> hREST –H 192.168.10.6 –U ****** -P ****** downloadconfig -T BIOS -F ../update/bios.json
Success: export BIOS configuration is successful
Import configuration
Perform this task to import configuration.
hREST -H host -p port -U username -P password uploadconf -T type –F filepath
Table 63 Parameter description
Parameter
Value
type
Type of the configuration to be imported.
·     RAID.
·     BMC.
·     BIOS.
filepath
Path of the configuration file.
Required.
# Import BIOS configuration.
-> hREST –H 192.168.10.6 –U ****** -P ****** uploadconfig -T BIOS -F ../update/bios.json
Success: import BIOS configuration successfully
Obtain firmware information
Perform this task to obtain firmware information.
hREST -H host -p port -U username -P password getfwv
# Obtain information about the firmware of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getfwv
Version                                 : 1.30.15 HDM V100R001B03D015
Version                                 : V007
Version                                 : 2.00.37P06 V100R001B02D037SP06
Version                                 : 4.1.4.339
Version                                 : 1.1767.0
Table 64 Command output
Name
Firmware name.
Version
Firmware version.
Obtain NTP information
Perform this task to obtain NTP information from the server.
hREST -H host -p port -U username -P password getntp
# Obtain NTP information from the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getntp
ServiceEnabled                          : False
RefreshInterval                         : 3600
TimeZone                                : UTC-9
PreferredNtpServer                      : 1.cn.pool.ntp.org
AlternateNtpServer                      : 2.cn.pool.ntp.org
TertiaryNtpServer                       :
NtpAddressOrigin                        : Static
Table 65 Command output
ServiceEnabled
Enabling status of the NTP service.
RefreshInterval
Refresh interval.
TimeZone
Time zone.
PreferredNtpServer
Primary NTP server.
AlternateNtpServer
Secondary NTP server.
TertiaryNtpServer
Tertiary NTP server.
NtpAddressOrigin
NTP mode. The current software version supports only the static mode.
Configure NTP settings
Perform this task to configure NTP settings.
hREST -H host -p port -U username -P password setntp -S status -PRE prentpserver -ALT altntpserver -TN TertiaryNtpServer
hREST -H host -p port -U username -P password setntp -Z timezone
hREST -H host -p port -U username -P password setntp -F timeinterval
Table 66 Parameter description
Parameter
Value
status
Enable or disable the NTP service.
·     Enable.
·     Disable.
prentpserver
Primary NTP server.
Optional.
altntpserver
Optional.
TertiaryNtpServer
Optional.
timezone
Time zone.
Optional.
timeinterval
Time synchronization interval, in ms.
Value range: 600 to 2592000. The value must be a multiple of 100.
Before you perform this task, make sure the NTP service is disabled.
If the value you set for a parameter is the same as the original value, the system returns configuration failure.
For HDM-2.xx, to avoid NTP server configuration errors, make sure you configure both the primary NTP server and the secondary NTP server. This issue has been resolved in HDM-3.10 and later versions.
# Enable the NTP service.
-> hREST –H 192.168.10.6 –U ****** -P ****** setntp -S Enable -PRE 192.168.170.66 -ALT 192.168.170.67 -TN 192.168.170.68
Success: set ntp server information successful
# Set the NTP time zone.
-> hREST –H 192.168.10.6 –U ****** -P ****** setntp –Z UTC+9
# Set the NTP time synchronization interval.
-> hREST –H 192.168.10.6 –U ****** -P ****** setntp –F 800
Success: set ntp time synchronization interval successful
Obtain SNMP information
Perform this task to obtain SNMP information from the server.
hREST -H host -p port -U username -P password getsnmp
# Obtain SNMP information from the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsnmp
Description                             : SnmpService Gettings
LongPasswordEnabled                     : False
ReadOnlyCommunity                       : rocommstr
ReadWriteCommunity                      :
SnmpTrapNotification
    AlarmSeverity                       : Minor+Major+Critical
    CommunityName                       : public
    ServiceEnabled                      : True
    TrapMode                            : NodeMode
    TrapServer
        Enabled                         : True
        MemberId                        : 1
        TrapServerAddress               :
        TrapServerPort                  : 162
        Enabled                         : True
        MemberId                        : 2
        TrapServerAddress               :
        Enabled                         : True
        MemberId                        : 3
        TrapServerAddress               :
        Enabled                         : True
        MemberId                        : 4
        TrapServerAddress               :
    TrapServerIdentity                  : HDM210200A00QH17C000002
    TrapV3User                          :
    TrapVersion                         : v1
SnmpV1Enabled                           : False
SnmpV2CEnabled                          : True
SnmpV3Enabled                           : True
Table 67 Command output
Description of the SNMP service resource.
Id
ID of the SNMP service.
LongPasswordEnabled
Enabling status of the long community string feature.
Name
Name of the SNMP service.
ReadOnlyCommunity
Read-only community name.
ReadWriteCommunity
Read/write community name.
AlarmSeverity
Alarm severity level. Supported options:
·     Critical.
·     Minor+Major+Critical.
·     All.
The supported options vary by HDM version.
CommunityName
Trap community name.
ServiceEnabled
Enabling status of the SNMP trap service.
TrapMode
Trap mode. Supported options:
·     NodeMode.
·     EventMode.
TrapServer
SNMP trap server settings.
Enabled
Enabling status of the SNMP trap servers.
MemberId
Trap server ID.
TrapServerAddress
Trap server address.
TrapServerPort
Trap server port.
TrapServerIdentity
Trap server identifier.
TrapV3User
SNMPv3 user.
TrapVersion
SNMP trap version.
SnmpV1Enabled
Enabling status of SNMPv1.
SnmpV2CEnabled
Enabling status of SNMPv2.
SnmpV3AuthProtocol
·     sha.
·     md5.
SnmpV3Enabled
Enabling status of SNMPv3.
SnmpV3PrivProtocol
·     des.
·     aes.
Configure SNMP settings
Perform this task to configure SNMP settings.
hREST -H host -p port -U username -P password setsnmp -V1E SnmpV1Enabled -V2CE SnmpV2CEnabled -LPE LongPasswordEnabled -ROC ReadOnlyCommunity -RWC ReadWriteCommunity -CN CommunityName -SE ServiceEnabled -TV TrapVersion -T3U TrapV3User -AS AlarmSeverity -TM TrapMode -TS TrapServer -V3E SnmpV3Enabled
Table 68 Parameter description
Parameter
Value
SnmpV1Enabled
Enable or disable SNMPv1.
·     Enable.
·     Disable.
SnmpV2CEnabled
Enable or disable SNMPv2.
·     Enable.
·     Disable.
SnmpV3Enabled
·     Enable.
·     Disable.
LongPasswordEnabled
Enable or disable the long community password feature.
·     Enable.
·     Disable.
ReadOnlyCommunity
Optional.
ReadWriteCommunity
Optional.
CommunityName
Optional.
To delete the community name, leave this field empty.
ServiceEnabled
Enable or disable the SNMP trap service.
·     Enable.
·     Disable.
TrapVersion
SNMP trap version.
·     v1.
·     v2c.
·     v3.
TrapV3User
SNMPv3 user.
Optional.
AlarmSeverity
Severity level.
Optional.
The supported options vary by HDM version, including:
·     In a version earlier than HDM-1.12.05:
¡     Critical.
¡     WarningAndCritical.
¡     All.
·     In HDM-1.30.11P01:
¡     Critical.
¡     Minor+Major+Critical.
¡     All.
·     In HDM-2.10.00:
¡     Major+Critical. This value is changed from Critical.
TrapMode
Trap mode.
·     NodeMode.
·     EventMode.
TrapServer
Trap server properties.
Optional.
You can specify four trap servers. Each server is in the format of MemberID-Enabled-TrapServerPort-STrapSrverAddress.
TrapServer.MemberId
Trap server ID.
Optional.
TrapServer.Enabled
Enable or disable the SNMP trap server.
Optional.
TrapServer.TrapServerPort
Trap server port number.
Optional.
TrapServer.TrapServerAddress
Optional. Both IP addresses and domain names are supported.
# Configure SNMP settings.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setsnmp -V1E Disable -V2CE Enable -LPE Disable -ROC rocommstr_r -RWC rocommstr_w -CN public -SE Enable -TV v1 -T3U admin -AS Critical -TM NodeMode -TS [1-1-163-192.168.10.121_2-1-163-192.168.10.122]
Success: set snmp successfully
Obtain service information
Perform this task to obtain information about services of the server.
hREST -H host -p port -U username -P password getservice –T servicttype
Table 69 Parameter description
Parameter
Value
servicetype
Service type.
·     Web.
·     KVM.
·     CD-Media.
·     FD-Media.
·     HD-Media.
·     SSH.
·     Telnet.
·     IPMI.
·     SNMP.
·     VNC.
·     Remote_XDP.
If you do not specify this argument, the command displays information about all services.
# Obtain information about the Web service.
-> hREST –H 192.168.10.6 –U ****** -P ****** getservice –T Web
Status                                  : Enable
Insecure service port                   : 80
Secure service port                     : 443
Idle timeout                            : 1800
Maximum sessions                        : 20
Table 70 Command output
Name
Service name.
Status
Enabling status of the service. Supported options:
·     Enable.
·     Disable.
Insecure service port number of the service.
Secure service port
Secure port number of the service.
Idle timeout
Idle timeout time.
Maximum sessions
Maximum number of sessions for the service.
Configure service settings
Perform this task to configure settings for a service.
hREST -H host -p port -U username -P password setservice -T type -S status –M timeout –SP secure_port –NSP non_secure_port
Table 71 Parameter description
Parameter
Value
type
Type of the service to be configured.
·     Web.
·     KVM.
·     CD-Media.
·     FD-Media.
·     HD-Media.
·     SSH.
·     Telnet.
·     IPMI.
·     SNMP.
·     VNC.
·     Remote_XDP.
status
Enable or disable the service.
·     Enabled.
·     Disabled.
timeout
Timeout time, in minutes.
This parameter is unavailable for the following services:
·     CD-Media.
·     FD-Media.
·     HD-Media.
·     Remote_XDP.
·     SNMP.
·     IPMI.
secure_port
Optional.
non_secure_port
Insecure port number of the service.
Optional.
# Configure settings for the VNC service.
-> hREST –H 192.168.10.6 –U ****** -P ****** setservice -T VNC -S Enabled -NSP 4901
Success: set BMC network protocol services successfully
Download SDS logs
Perform this task to download SDS logs from the server.
hREST -H host -p port -U username -P password getsdslog –F filepath -P startdate –Q enddate
Table 72 Parameter description
Parameter
Value
filepath
Path of the file to save SDS logs.
Required.
By default, the file name is in the SN_Date.sds format. For example, HDM12345678912345678907_20191223_20191230.sds.
To avoid character decoding error, do not include Chinese characters in the file path.
startdate
Start date for exporting, in YY-MM-DD.
Optional.
enddate
End date for exporting, in YY-MM-DD.
Optional.
If you do not specify the start date or end date, the system downloads all SDS logs.
This command is not available in in-band management mode.
# Download SDS logs from 2019-01-21 to 2019-01-28 to directory :\sdslog.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsdslog –F F:\sdslog -P 2019-01-21 -Q 2019-01-28
Success: one-click collection of log requests succeeded
Obtain virtual media information
Perform this task to obtain virtual media information.
hREST -H host -p port -U username -P password getvmm –T mediatype
Table 73 Parameter description
Parameter
Value
mediatype
Type of a virtual media.
Required Supported options:
·     HD.
·     CD.
# Obtain information about virtual media CD.
-> hREST –H 192.168.10.6 –U ****** -P ****** getvmm –T CD
[Connected]
    MediaIndex                : 0
    ImageName                 : bnx2x-1.714.18-dd-xs6.5-3.10.0+2-x86_64.iso
    MediaTypes                : CD/DVD
    MediaIndex                : 1
    ImageName                 : netxtreme2-7.14.46-dd-sles11sp3-3.0.76_0.11-x86_64.iso
    MediaTypes                : CD/DVD
[NotConnected]
    ImageName                 : netxtreme2-7.14.46-dd-sles12sp2-4.4.21_69-x86_64.iso
    MediaTypes                : CD/DVD
    ImageName                 : ONEStor-Ubuntu_14.04.3.18.iso
    MediaTypes                : CD/DVD
    ImageName                 : REPO-1.11.02.iso
    MediaTypes                : CD/DVD
# Obtain information about virtual media HD.
-> hREST –H 192.168.10.6 –U ****** -P ****** getvmm –T HD
[Connected]
    MediaIndex                : 0
    ImageName                 : BOOT95.IMG
    MediaTypes                : Hard disk
[NotConnected]
    ImageName                 : BOOT98.IMG
    ImageName                 : BOOTDOS.IMG
Table 74 Command output
MediaIndex
ID of a mounted virtual media.
ID
ID of an unmounted virtual media.
ImageName
Name of the virtual media.
MediaTypes
Type of the virtual media.
Mount or unmount virtual media
Perform this task to mount or unmount virtual media.
Synta
hREST-H Host -p Port -U UserName -P PassWord mountvmm -O Type -I Image –T MediaType
User role
admin
Table 75 Parameter description
Parameter
Value
Action to take on the virtual media.
·     Mount.
·     Unmount.
Virtual media image.
This parameter is required for a mounting operation.
MediaType
Type of virtual media.
Supported options:
·     HD.
·     CD.
# Mount the virtual media and specify the media type as CD.
-> ./hREST –H 192.168.10.6 –U ****** -P ****** mountvmm -O Mount -I nfs://192.168.190.51/Share/image.so
Success: successfully mount virtual media
Upgrade the firmware
Perform this task to upgrade the firmware (such as BIOS, BMC, and CPLD) of the server.
hREST -H host -p port -U username -P password fwupdate –E Mode –O Override -T Type -U Firmware –F IsForce
Table 76 Parameter description
Parameter
Value
Mode
Upgrade mode.
·     ManualYou need to manually start the server after upgrade.
·     AutoThe server automatically starts up after upgrade.
Override
Select whether to override the current settings.
Optional. Supported options:
·     0Not override the current settings.
·     1Override the current settings.
Type of the firmware to be upgraded.
Required.
Firmware
Name and path of the firmware file.
Required.
IsForce
Select whether the update is forced or not.
Available only for REPO update.
Supported options:
·     0Perform an update only when the file version is higher than the current version. This is the default value.
·     1Update to the file version in despite of the current version.
Overriding the settings indicates restoring HDM to the factory defaults for HDM firmware upgrade, and indicates overriding the current BIOS settings for BIOS firmware upgrade.
The in-band management mode supports only the update of the BIOS and BMC.
# Upgrade the BMC.
-> hREST –H 192.168.10.6 –U ****** -P ****** fwupdate -E Auto -T BMC -U ../config/HDM-1.30.18_signed.bin
2020-07-03 17:21:54 Get product serial number : 210200A00QH17C000002
2020-07-03 17:21:54 Check environment is ok
2020-07-03 17:21:54 Set fw type success
2020-07-03 17:21:55 Upload file start
2020-07-03 17:22:02 Upload file inprogress...
2020-07-03 17:22:41 Upload file successfully
2020-07-03 17:22:45 File verify successfully
2020-07-03 17:22:45 Apply(Flash) start
2020-07-03 17:23:56 Apply(Flash) ingrogress, process: 100% done
2020-07-03 17:24:01 Apply(Flash) successfully
2020-07-03 17:24:01 Auto model BMC restart, please waiting...
2020-07-03 17:29:13 BMC reboot complete
2020-07-03 17:29:13 Version verify ok
HDM upgrade successfully, Version: image change from 1.30.15 to 1.30.18
Obtain PCIe device list
Perform this task to obtain the list of PCIe devices.
hREST -H host -p port -U username -P password getpcie
# Obtain the list of PCIe devices.
-> hREST –H 192.168.10.6 –U ****** -P ****** getpcie
ProductName                             : HBA-LSI-9440-8i
VendorID                                : 0x1000
VendorName                              : None
ProductID                               : 0x0017
NegotiatedSpeed                         : 8.0GT/s
NegotiatedProtocol                      : Gen 3
NegotiatedLinkWidth                     : x8
MaxSpeed                                : None
MaxProtocol                             : Gen 3
PartNumber                              : N/A
MaxLinkWidth                            : x8
[Status]
Status                                  : Enabled
Health                                  : OK
Table 77 Command output
Location
Location of a PCIe module.
ProductName
Product name.
VendorID
Manufacturer ID.
VendorName
Manufacturer name.
SerialNumber
Serial number of the PCIe device.
ProductID
Product ID of the PCIe device.
NegotiatedSpeed
Negotiated speed.
NegotiatedProtocol
Protocol used for negotiation.
NegotiatedLinkWidth
Negotiated bandwidth.
MaxSpeed
Maximum speed.
MaxProtocol
Highest version of the protocol.
PartNumber
Part number of the PCIe device.
Status
Enabling status of the PCIe device.
Health
Health status of the PCIe device.
Take a screenshot of KVM
Perform this task to take a screenshot of KVM.
hREST -H host -p port -U username -P password getscreencapture -F path
G6 models do not support this command.
Table 78 Parameter description
Parameter
Value
path
Path for saving the screenshot.
Required.
# Take a screenshot of KVM.
-> hREST -H 192.168.10.11 -U admin -P Password@_ getscreencapture -F ../update
Success: get screen capture successfully
The following is an example of KVM screenshot.
Change history
Version
Change description
HDM-1.30.12
Added this command.
Configure advanced LDAP settings
Perform this task to configure advanced LDAP settings.
hREST -H host -p port -U username -P password setldap -BD bind_dn -CNT common_name_type -E enable -ET encryption_type -PW ldap_password –P port -SB search_base -SA server_address -ULA user_login_attribute
Table 79 Parameter description
Parameter
Value
bind_dn
Administrator bind DN.
Optional.
The maximum length is 255 bytes.
common_name_type
Address type of the LDAP server.
·     ipIP address.
·     fqdnFQDN address.
enable
Enable or disable LDAP authentication.
·     0Disable.
·     1Enable.
encryption_type
Encryption type.
·     0No encryption.
·     1SSL.
ldap_password
LDAP password.
Optional.
port
LDAP port number.
Optional.
search_base
LDAP search DN.
Optional.
server_address
LDAP server address.
Optional.
IPv4 address, IPv6 address, or domain name are supported.
User identification method.
·     uidUID.
·     cnCN.
# Configure advanced LDAP settings.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setldap -E 1 -PW 123456 -BD cn=admin,dc=example,dc=com -ULA uid -ET 1 -P 100 -CNT ip -SB dc=example,dc=com -SA 192.168.1.2
Success: set ldap successfully
Obtain LDAP information
Perform this task to obtain LDAP information.
hREST -H host -p port -U username -P password getldap
# Obtain LDAP information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getldap
CertificateVerificationState            : Enable
EncryptionType                          : SSL
CommonNameType                          : IP
ServerAddress                           : 192.168.1.2
PortNumber                              : 100
BindDN                                  : cn=admin,dc=example,dc=com
Password                                :
SearchBase                              : dc=example,dc=com
UserIdentification                      : uid
[LdapGroups]
    MemberId                            : 1
    GroupName                           : test
    GroupDomain                         : dc=example,dc=com
    GroupRole                           : Administrator
    MemberId                            : 2
    GroupName                           : test1
    GroupRole                           : User
    MemberId                            : 3
    GroupName                           : test2
    GroupRole                           : Operator
Table 80 Command output
Enabling status of LDAP authentication. Supported options:
·     Enable.
·     Disable.
EncryptionType
Encryption type. Supported options:
·     No encryption.
·     SSL.
CommonNameType
Common name type. Supported options:
·     IP.
·     FQDN.
ServerAddress
Server address.
PortNumber
Port number.
BindDN
Bind DN.
Password
Password. The password value is not displayed.
SearchBase
User search base.
UserIdentification
User ID.
MemberId
Role group ID.
GroupName
Role group name.
GroupDomain
Role group search base.
GroupRole
Role group privilege.
Add or edit an LDAP user
Perform this task to add or edit an LDAP user.
hREST -H host -p port -U username -P password addldapuser -RI role_id -RGN role_group_name -RGD role_group_domain -RGP role_group_privilege -RGKP role_group_kvm_privilege -RGVP role_group_vmedia_privilege -RGNP role_group_network_privilege -RGUP role_group_user_privilege -RGBP role_group_basic_privilege -RGPP role_group_power_privilege -RGFP role_group_firmware_privilege -RGHP role_group_health_privilege -RGRP role_group_remotectrl_privilege
Table 81 Parameter description
Parameter
Value
role_id
Role group ID.
·     1.
·     2.
·     3.
·     4.
·     5.
role_group_name
Name of a role group.
Required.
role_group_domain
Search base of the role group.
Required.
Level of privileges assigned to the role group.
Required.
KVM privilege.
·     1Enabled.
·     0Disabled.
Image mounting privilege.
·     1Enabled.
·     0Disabled.
Network configuration privilege.
·     1Enabled.
·     0Disabled.
User configuration privilege.
·     1Enabled.
·     0Disabled.
Basic setting configuration privilege.
·     1Enabled.
·     0Disabled.
Power management privilege.
·     1Enabled.
·     0Disabled.
Firmware update privilege.
·     1Enabled.
·     0Disabled.
Health diagnosis privilege.
·     1Enabled.
·     0Disabled.
Remote control privilege.
·     1Enabled.
·     0Disabled.
# Add an LDAP user.
-> hREST -H 192.168.10.11 -U admin -P Password@_ addldapuser -RI 1 -RGN test -RGD dc=example,dc=com -RGP 3 Operator -RGKP 1 -RGVP 1 -RGNP 1 -RGUP 1 -RGBP 1 -RGPP 1 -RGFP 1 -RGHP 1 -RGRP 1
Success: add ldap user successfully
Change history
Version
Change description
hREST V1.08
Delete an LDAP user
Perform this task to delete an LDAP user.
hREST -H host -p port -U username -P password delldapuser -RI role_id
Table 82 Parameter description
Parameter
Value
role_id
Role group ID.
·     1.
·     2.
·     3.
·     4.
·     5.
If the LDAP user to be deleted does not exist, the system still prompts operation success.
# Delete an LDAP user.
-> hREST -H 192.168.10.11 -U admin -P Password@_ delldapuser -RI 1
Success: delete ldap user successfully
Configure AD settings
Perform this task to configure AD settings.
hREST -H host -p port -U username -P password setad -E ad_enable -UDN ad_user_domain_name -SU ad_secret_username -SP ad_secret_password -DC1 ad_domain_controller1 -DC2 ad_domain_controller2 -DC3 ad_domain_controller3
Table 83 Parameter description
Parameter
Value
ad_enable
Enable or disable AD authentication.
·     Disable.
·     Enable.
ad_user_domain_name
Name of an AD user domain.
Optional.
ad_secret_username
Username of a secrete AD user.
Optional.
ad_secret_password
Password of the secrete AD user.
Optional. Ths password must contain a minimum of six characters.
Address of AD server 1.
Optional.
Address of AD server 2.
Optional.
Address of AD server 3.
Optional.
# Configure AD settings.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setad -E 1 -UDN sit.com -SU group1 -SP 123456 -DC1 192.168.1.78 -DC2 192.168.1.79 -DC3 192.168.1.80
uccess: set ad successfully
Obtain AD information
Perform this task to obtain AD information.
hREST -H host -p port -U username -P password getad
This command is supported in HDM-1.30.12 and later versions.
# Obtain AD information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getad
SecretUsername                          : group
SecretPassword                          :
UserDomainName                          : sit.com
DomainControllerAddress1                : 192.168.1.78
DomainControllerAddress2                : 192.168.1.79
DomainControllerAddress3                : 192.168.1.80
[ADUsers]
    MemberId                            : 1
    GroupName                           : test
    GroupDomain                         : sit.com
    MemberId                            : 2
    GroupName                           : test1
    GroupRole                           : CustomRole1
Table 84 Command output
Enabling status of AD authentication. Supported options:
·     Enable.
·     Disable.
SecretUsername
Secret username.
SecretPassword
Secret password. The password value is not displayed.
UserDomainName
User domain name.
Domain controller server address 1.
Domain controller server address 2.
Domain controller server address 3.
MemberId
Role group ID.
GroupName
Role group name.
GroupDomain
Role group search based.
GroupRole
Add or edit an AD user
Perform this task to add or edit an AD user.
hREST -H host -p port -U username -P password addaduser -RI role_id -RGN role_group_name -RGD role_group_domain -RGP role_group_privilege -RGOP role_group_withoem_privilege -RGKP role_group_kvm_privilege -RGVP role_group_vmedia_privilege -RGNP role_group_network_privilege -RGUP role_group_user_privilege -RGBP role_group_basic_privilege -RGPP role_group_power_privilege -RGFP role_group_firmware_privilege -RGHP role_group_health_privilege -RGRP role_group_remotectrl_privilege
Table 85 Parameter description
Parameter
Value
role_id
Role group ID.
·     1.
·     2.
·     3.
·     4.
·     5.
role_group_name
Required.
role_group_domain
Domain name of the role group.
Required.
Required.
·     0Disable.
·     1Enable.
·     0Disable.
·     1Enable.
·     0Disable.
·     1Enable.
User management privilege.
·     0Disable.
·     1Enable.
·     0Disable.
·     1Enable.
·     0Disable.
·     1Enable.
Hardware upgrade privilege.
·     0Disable.
·     1Enable.
Health diagnostic privilege.
·     0Disable.
·     1Enable.
Remote access privilege.
·     0Disable.
·     1Enable.
# Add an AD user.
-> hREST -H 192.168.10.11 -U admin -P Password@_ addaduser -RI 1 -RGN test -RGD sit.com -RGP administrator -RGKP 1 -RGVP 1 -RGNP 1 -RGUP 1 -RGBP 1 -RGPP 1 -RGFP 1 -RGHP 1 -RGRP 1
Success: add ad user successfully
Change history
Version
Change description
hREST V1.08
Delete an AD user
Perform this task to delete an AD user.
hREST -H host -p port -U username -P password deladuser -RI role_id
Table 86 Parameter description
Parameter
Value
role_id
ID of a role group.
·     1.
·     2.
·     3.
·     4.
·     5.
# Delete an AD user.
-> hREST -H 192.168.10.11 -U admin -P Password@_ deladuser -RI 1
Success: delete ad user successfully
Obtain GPU information
Perform this task to obtain GPU information.
hREST -H host -p port -U username -P password getgpu
# Obtain GPU information of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getgpu
SlotNum                                 : 2
Manufacturer                            : NVIDIA
Model                                   : Tesla K80
SerialNumber                            : 0324816063163
PartNumber                              : 102D-885-A1
FirmwareVersion                         : 80.21.1F.00.01
PowerConsumedWatts                      : 0
TemperatureCelsius                      : 67
DriverVersion                           : null
ECCEnable                               : null
GCUVoltage                              : null
HBMVoltage                              : null
[Status]
Health                                  : OK
State                                   : Enable
Table 87 Command output
ID
GPU ID.
Name
GPU name.
SlotNum
GPU slot number.
Manufacturer
Vendor name.
Model
GPU model.
SerialNumber
GPU serial number.
PartNumber
GPU part number.
FirmwareVersion
GPU firmware version.
PowerConsumedWatts
Power of the GPU. If the power is 0, install the GPU driver in the OS.
TemperatureCelsius
Temperature in °C.
DriverVersion
Driver version.
ECCEnable
ECC status.
GCUVoltage
GCU voltage.
HBMVoltage
HBM voltage.
Health
GPU health status.
GPU presence status.
Obtain VNC session information
Perform this task to obtain VNC session information.
hREST -H host -p port -U username -P password getvncsession
# Obtain VNC session information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getvncsession
SessionID                               : 28
SessionType                             : VNC
ClientIP                                : 192.168.184.44
UserID                                  : N/A
UserName                                : N/A
UserPrivilege                           : Administrator
Table 88 Command output
Id
ID.
SessionID
Session ID.
SessionType
Session type.
ClientIP
IP address
UserID
User ID.
UserName
Username.
UserPrivilege
User privilege.
Obtain the firewall status
Perform this task to obtain the firewall status of the server.
hREST -H host -p port -U username -P password getfirewall
# Obtain the firewall status of the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getfirewall
Status                                  : Stop
Table 89 Command output
Status
Firewall status. Supported options:
·     StopThe firewall is disabled.
·     WhiteListThe firewall operates in whitelist mode.
·     BlackListThe firewall operates in blacklist mode.
Set the firewall status
Perform this task to set the firewall status of the server.
hREST -H host -p port -U username -P password setfirewall –S status
Table 90 Parameter description
Parameter
Value
status
Firewall status.
# Set the firewall status of the server to Whitelist.
-> hREST –H 192.168.10.6 –U ****** -P ****** setfirewall -S WhiteList
Success: set the firewall status successfully
Obtain components using a serial port
Perform this task to obtain the components that use a serial port.
hREST -H host -p port -U username -P password getserialport
# Obtain the components that use a serial port.
-> hREST –H 192.168.10.6 –U ****** -P ****** getserialport
PanelComSources                         : Host
SOLSource                               : Host
Table 91 Command output
PanelComSources
Components that are using the serial port on the front panel. Supported options:
·     BMC.
·     Host.
·     PCIeNIC.
·     MEZZNIC.
·     MEZZRAID.
SOLSource
Components that are using the serial port on the panel. Supported options:
·     BMC.
·     Host.
·     PCIeNIC.
·     MEZZNIC.
·     MEZZRAID.
Configure the components to use a serial port
Perform this task to configure the components of the server to use a serial port.
hREST -H host -p port -U username -P password setserialport –D type –S source
Table 92 Parameter description
Parameter
Value
type
Serial port type.
·     panel.
·     sol.
source
Components that use a serial port.
·     host.
·     bmc.
·     mezzraid.
·     mezznic.
·     PCIeNIC.
# Configure BMC to use the serial port on the front server panel.
-> hREST –H 192.168.10.6 –U ****** -P ****** setserialport -D panel -S bmc
Success: the serial port is set successfully
Locate a physical drive
Perform this task to set the UID LED status to locate a physical drive.
hREST -H host -p port -U username -P password locatedisk -I diskId –L diskType –S status
User role
admin
Table 93 Parameter description
Parameter
Value
diskId
Physical drive ID.
Required.
diskType
Physical drive type.
Optional.
status
UID LED status.
·     on.
·     off.
In a version earlier than HDM-2.12, a physical drive ID is the ID of the corresponding sensor, and the diskType field is reserved and does not take effect.
In HDM-2.12 or later, a physical drive ID is the physical drive slot number. You can obtain the physical drive ID from the Slot_phys_no field in the output of the getpdsik command. The options for the DiskType field include 0 (default) and 1. 0 represents an HDD or SSD drive, and 1 represents an NVMe drive.
# Turn on the UID LED for the physical drive with sensor ID 160.
-> hREST –H 192.168.10.6 –U ****** -P ****** locatedisk -I 160 -S on
Success: set the physical disk led light successfully
Obtain storage media alarm thresholds
Perform this task to obtain the alarm thresholds for storage media in the server.
hREST -H host -p port -U username -P password getthreshold
# Obtain the alarm thresholds for storage media in the server.
-> hREST –H 192.168.10.6 –U ****** -P ****** getthreshold
ReservedBlock                           : 10
ReservedBlockStatus                     : Disabled
RemainLifePercents                      : 90
RemainLifePercentsStatus                : Disabled
PrefailCount                            : 0
PrefailCountStatus                      : Enabled
MediaError                              : 60000
MediaErrorStatus                        : Disabled
Table 94 Command output
ReservedBlock
Number of reserved blocks that can trigger an alarm.
ReservedBlockStatus
Status of reserved blocks.
RemainLifePercents
Remaining drive life in percentage.
Status of remaining drive life in percentage.
PrefailCount
Number of predictive failures that can trigger an alarm. This field is available only for HDDs and SSDs.
PrefailCountStatus
Status of predictive failures.
MediaError
Number of media errors that can trigger an alarm. This field is available only for HDDs and SSDs.
MediaErrorStatus
Status of media errors.
Change history
Version
Change description
HDM-1.30.09
Added the interface.
Set a storage media alarm threshold
Perform this task to set an alarm threshold for storage media in the server.
hREST -H host -p port -U username -P password setthreshold –F type –T threshold –S status
Table 95 Parameter description
Parameter
Value
type
Alarm type.
Required. Supported options:
·     reservedblock.
·     remainlife.
·     prefailcount.
·     mediaerror.
threshold
Value range of an alarm threshold.
·     reservedblock0 to100.
·     remainlife0 to 100.
·     prefailcount0 to 255.
·     mediaerror0 to 65535.
status
Enablement status of storage media alarming.
·     Enable. This option is the default.
·     Disable.
# Set the alarm threshold of remaining drive life to 90, and enable remaining life alarming.
-> hREST –H 192.168.10.6 –U ****** -P ****** setthreshold -F remainlife -T 90 -S Enable
Success: successfully set the remainlife threshold
Change history
Version
Change description
HDM-1.30.09
Obtain event subscription information
Perform this task to obtain event subscription information from the server.
hREST -H host -p port -U username -P password geteventsubs
# Obtain event subscription information.
-> hREST –H 192.168.10.6 –U ****** -P ****** geteventsub
Destination                             : https://172.16.11.96
EventTypes                              : ResourceUpdated, StatusChange, ResourceRemoved, ResourceAdded, Alert
HttpHeaders                             : null
Protocol                                : Redfish
Context                                 : event subscription context string
MessageIds                              : []
OriginResources                         : []
Table 96 Command output
Id
Event service resource ID.
Destination
URI of the event recipient.
EventTypes
Event type. Supported options:
·     ResourceRemoved.
·     ResourceAdded.
·     StatusChange.
·     ResourceUpdated.
·     Alert.
HttpHeaders
HTTP header of event subscription and is fixed at null for event subscription query.
Protocol
Event subscription protocol. Supported options include Redfish.
Context
Event subscription context information in strings.
MessageIds
Event subscription message ID matching list.
OriginResources
Event subscription event source matching list.
Upload an SSH secret key
Perform this task to upload an SSH secret key.
hREST -H host -p port -U username -P password importsshkey –N name –F sshfFile -O Status
Table 97 Parameter description
Parameter
Value
name
Name of the user for editing.
Optional.
If you do not specify this argument, the command configures the current user.
sshfFile
SSH secret key file.
Optional.
Status
Whether to only bind users without uploading files.
·     Enable.
·     Disable.
# Upload an SSH secret key for user test.
-> hREST –H 192.168.10.6 –U ****** -P ****** importsshkey -N test -F ../config/key.pub
Success: import SSH key successfully
Delete an SSH secret key
Perform this task to delete an SSH secret key.
hREST -H host -p port -U username -P password delsshkey –N name -F SSH_key_name
Table 98 Parameter description
Parameter
Value
name
Name of the user for deletion.
Optional.
If you do not specify this argument, the command deletes the SSH password for the current user.
SSH_key_name
Name of the SSH secret key file.
Optional.
# Delete the SSH secret key for user test.
Success: successfully delete the ssh public key
Obtain two-factor authentication settings
Perform this task to obtain two-factor authentication settings.
hREST -H host -p port -U username -P password get2factorauth
# Obtain two-factor authentication settings.
-> hREST –H 192.168.10.6 –U ****** -P ****** get2factorauth
TwoFactorAuthenticationState            : False
OTPServerAddress                        : sit.com
OTPServerPort                           : 1812
OTPServerSharedKey                      : 123
Table 99 Command output
Enabling status of two-factor authentication. Supported options:
·     True—Enabled.
·     False—Disabled.
OTPServerAddress
OTP server address.
OTPServerPort
OTP service port number.
OTPServerSharedKey
Shared key.
Configure two-factor authentication settings
Perform this task to configure two-factor authentication settings.
hREST -H host -p port -U username -P password set2factorauth –E authEnable –D serverAddr –P portNum –K shareKey
Table 100 Parameter description
Parameter
Value
authEnable
Enable or disable two-factor authentication.
·     Enable.
·     Disable.
serverAddr
OTP server address.
Optional.
portNum
Service port number.
Optional.
shareKey
Shared key.
Optional.
The shared key is a string of 1 to 64 characters.
# Configure two-factor authentication settings.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ set2factorauth -E Disable -P 999 -D sit.com –K 1234
Success: two-factor authentication configuration is successful
Obtain LLDP information
Perform this task to obtain LLDP information.
hREST -H host -p port -U username -P password getlldp
This command is supported in HDM-1.30.10 and later versions.
# Obtain LLDP information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getlldp
LldpEnabled                             : Disable
WorkMode                                : Tx
[LLDP]
    ChassisMac                          : 58:6a:b1:0b:31:af
    ChassisName                         : 21
    EthIndex                            : eth0
    PortDesc                            : GigabitEthernet1/0/4 Interface
    PortIfName                          : GigabitEthernet1/0/4
    VlanId                              : 1
    ChassisName                         : 21
    EthIndex                            : eth1
    PortDesc                            : GigabitEthernet1/0/25 Interface
    PortIfName                          : GigabitEthernet1/0/25
    VlanId                              : 1
Table 101 Command output
Name
Service name.
Enabling status of LLDP frame sending. Supported options:
·     Enable.
·     Disable.
WorkMode
LLDP operation mode. Supported options:
·     Tx—Frame sending mode.
ChassisMac
MAC address of the connected switch.
ChassisName
System name of the connected switch.
EthIndex
Network port.
PortDesc
Information about the connected switch port.
PortIfName
Number of the connected switch port.
VlanId
VLAN ID
Configure LLDP settings
Perform this task to configure LLDP settings.
hREST -H host -p port -U username -P password setlldp –S serviceEnable
Table 102 Parameter description
Parameter
Value
serviceEnable
Enable or disable LLDP service.
·     Enable.
·     Disable.
This command is not available in HDM-3.30, HDM-3.31, or HDM-3.32.
# Enable LLDP frame sending.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setlldp –S Enable
Success: successfully set LLDP service attributes
Obtain DNS information
Perform this task to obtain DNS information.
hREST -H host -p port -U username -P password getdns -N network_port_id -IP internet_protocol
Table 103 Parameter description
Parameter
Value
network_port_id
Network port ID.
Optional.
internet_protocol
Network protocol.
Supported options:
·     IPv4.
·     IPv6.
# Obtain DNS information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getdns
Status                                  : Enable
ServerSetup                             : Manual
SuperiorDomain                          :
PreferredServer                         : 192.168.0.66
AlternateServer                         : 192.168.0.67
TertiaryServer                          : 192.168.0.68
Table 104 Command output
Status
Enabling status of the DNS service. Supported options:
·     Enable.
·     Disable.
ServerSetup
Method for configuring the DNS server. Supported options:
·     Manual.
·     IPv4Auto.
·     IPv6Auto.
SuperiorDomain
Parent domain of the current domain.
PreferredServer
DNS server 1.
AlternateServer
DNS server 2.
TertiaryServer
DNS server 3.
Configure the DNS service
Perform this task to configure the DNS service.
hREST -H host -p port -U username -P password setdns E serviceEnable –M configMethod –D dynamicSelects -P RegPort –DS domainSuffix -PS preferredServer –AS alternateServer –TS tertiaryServer -N network_port_id -IP internet_protocol
Table 105 Parameter description
Parameter
Value
serviceEnable
Enable or disable the DNS service.
·     Enable.
·     Disable.
configMethod
·     Manual.
·     IPv4Auto.
·     IPv6Auto.
dynamicSelects
Dynamic registration option.
·     HostName.
·     Auto.
RegPort
Port to obtain DNS registration information.
·     Shared.
·     Dedicated.
By default, the system uses the shared network port.
domainSuffix
Domain suffix.
Optional.
This argument is in the domain name format.
preferredServer
Address of DNS server 1.
Optional.
IPv4 and IPv6 addresses are supported.
alternateServer
Address of DNS server 2.
Optional.
tertiaryServer
Address of DNS server 3.
Optional. IPv4 and IPv6 addresses are supported.
network_port_id
Network port ID.
Optional.
internet_protocol
Internet protocol.
·     IPv4.
·     IPv6.
# Enable DNS service, set the configuration method to manual, and specify domain suffix sit.com, DNS sever 1 IP address 192.168.0.66, DNS server 2 IP address 192.168.0.67, and DNS server 3 IP address 192.168.0.68.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setdns -E Disable -M Manual -DS sit.com -PS 192.168.0.66 -AS 192.168.0.67 -TS 192.168.0.68
Success: DNS configuration is successful
Obtain system performance information
Perform this task to obtain system performance information.
hREST -H host -p port -U username -P password getsysperf
# Obtain system performance information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsysperf
CPUUsagePercent                         : 0
CPUThresholdPercent                     : 40
CPUUsageAlert                           : OK
MemoryUsagePercent                      : 3
MemoryThresholdPercent                  : 50
MemoryUsageAlert                        : OK
[IOUsage]
    UsedSize                            : 29.16GB
    TotalSize                           : 1.82TB
    IOUsagePercent                      : 2
    IOUsageAlert                        : Alert
IOThresholdPercent                      : 1
Table 106 Command output
CPUUsagePercent
CPU usage.
CPUThresholdPercent
CPU usage alarm threshold.
CPUUsageAlert
CPU usage alarm status. Supported options:
·     OK.
·     Alert.
MemoryUsagePercent
Memory usage.
Memory usage alarm threshold.
MemoryUsageAlert
Memory usage alarm status. Supported options:
·     OK.
·     Alert.
IOUsage
IO usage.
Name
Drive name.
UsedSize
Used drive capacity.
TotalSize
Total drive capacity.
IOUsagePercent
Drive usage.
IOUsageAlert
Drive usage alarm status.
IOThresholdPercent
IO usage alarm threshold.
Configure system performance alarm thresholds
Perform this task to configure system performance alarm thresholds.
hREST -H host -p port -U username -P password setsysperf -C CPU –M MEM -I IO
Table 107 Parameter description
Parameter
Value
CPU
Optional.
MEM
Optional.
IO
Optional.
# Configure usage alarm thresholds for the CPU, memory, and drive as 70, 80, 90, respectively.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setsysperf  -C 70 -M 80 -I 90
Success: successfully set the host monitoring alarm threshold
Obtain video recording configuration
Perform this task to obtain video recording configuration.
hREST -H host -p port -U username -P password getvideocfg
# Obtain video recording configuration.
-> hREST –H 192.168.10.6 –U ****** -P ****** getvideocfg
RecordService                           : Enable
RecordTime                              : 20
[RecordEvent]
Crash                                   : Enable
Restart                                 : Enable
Shutdown                                : Disable
Table 108 Command output
RecordService
Enabling status of video recording. Supported options:
·     Enable.
·     Disable.
RecordTime
Recording duration in seconds.
Crash
Enabling status of pre-crash video recording.
Restart
Enabling status of pre-restart video recording.
Shutdown
Enabling status of pre-shutdown video recording.
Configure video recording
Perform this task to configure video recording.
hREST -H host -p port -U username -P password setvideocfg -E recordEnable –T recordTime –C crashEnable –R restartEnable –S shutdownEnable
Table 109 Parameter description
Parameter
Value
recordEnable
Enable or disable video recording.
·     Enable.
·     Disable.
recordTime
Video recording duration.
Optional.
The length is in the range of 15 to 255 seconds.
crashEnable
Pre-crash recording.
·     Enable.
·     Disable.
restartEnable
Pre-restart recording.
·     Enable.
·     Disable.
shutdownEnable
Pre-shutdown recording.
·     Enable.
·     Disable.
# Enable video recording for crash and restart events and set the recording duration to 15s.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setvideocfg -E Enable -T 15 -C Enable -R Enable -S Disable
Success: the video recording function is set successfully
Configure the power mode
Perform this task to configure the power mode.
hREST -H host -p port -U username -P password setpsu -M powerMode –I powerID –P  perfMode
Table 110 Parameter description
Parameter
Value
powerMode
Power mode.
·     LoadBalancing.
·     ActiveStandby.
powerID
ID of the active power supply in active/standby mode.
This argument is required in active/standby mode.
perfMode
Power efficiency mode.
·     PerformancePerformance first.
·     Balanced.
·     PowerPower saving.
In active/standby mode, make sure a minimum of one standby power is reserved. If only one power supply is present, you cannot set the power mode.
Exampels
# Set the power mode to active/standby, specify power supply 1 as the active power supply, and set the power efficiency mode to performance.
-> hREST -H 192.168.10.32 -p 443 -U admin -P Password@_ setpsu -M ActiveStandby -I 1 -P Power
Success: power setting is successful
Scan the servers for memory module failures
Perform this task to scan the servers for memory module failures.
hREST -H host -p port -U username -P password memoryinspect –M Mode –C ThreadCount –P LogPath -L ALARMLIMIT
Table 111 Parameter description
Parameter
Value
Mode
Scanning mode.
·     SingleScans a single server.
·     MultipleScans servers in batch.
By default, the system uses the single mode for memory module failure prediction.
ThreadCount
Number of threads.
Optional.
By default, the number of threads is 100.
LogPath
Result file path.
Optional.
By default, the result file path is project_directory/logs/result.log.
ALARMLIMIT
Alarm limit.
Optional.
In HDM-3.37 and later versions, the user-defined alarm threshold is no longer effective. For details, see the usage guidelines below.
This command is not supported in in-band mode. Memory CE Limit alarm is by default in a masked state and must be manually enabled before you use the function.
HDM-3.37 introduced a PFA alarm strategy where a single CE limit alarm does not trigger an event log. If 32 CE alarms accumulate within a specific period, a PFA alarm will be triggered. The user-defined alarm threshold is no longer effective, and is always set to 1.
This command is supported in HDM-1.30.18P56 and later versions and BIOS-2.00.39 and later versions.
To perform bulk scanning, make sure the …/config/server_info.txt file exists and the server information format is correct. The system records the scanning process in the …/logs/execute.log file. When the file size reaches 10 M, the system backs up the file as execute.log.1.
For batch scanning, the –H, -U, -P, and –p keywords do not take effect. The keywords are kept for consistency with other commands. You can specify any valid values for these keywords.
To ensure the accuracy of the scanning result, make sure the servers use consistent time zones.
This command is not available in HDM-1.10.xx. (The corresponding version does not record log messages of hardware replacement.)
Each row in the server_info.txt file represents a server, including server host address, username, password, and port number (optional), which are separated by spaces, for example, 192.168.0.14  admin ****** 443. Make sure the server_info.txt file does not have extra blank lines at the end.
-> server_info.txt
192.168.0.18 admin ******
192.168.0.19 root ******
192.168.0.20 admin ****** 443
192.168.0.21 admin ******
The above is a sample. Remove these rows before you use the server_info.txt file.
# Scan memory module failures on a single server.
-> hREST –H 192.168.0.14 –U ****** -P ****** memoryinspect
IP             Serial Number            Slot           Description
192.168.0.14   210235A2CSH17C000001     CPU1_DIMM_A5   occur 32 ce limit(s) in the past day
# Scan memory module failures on multiple servers in bulk, set the thread count to 50, and record the result in directory D:/result/inspect_res.log.
-> hREST –H 192.168.0.14 –U ****** -P ****** memoryinspect –M Multiple –C 50 –P D:/result/inspect_res.log
192.168.0.33      None                     None           Cannot access HDM
192.168.0.32      None                     None           Ping https failed
192.168.170.53    210235A2CSH17D000001     None           No memory failure detected
192.168.0.197     210235A2CSH17C000001     CPU1_DIMM_A1   occur 33 ce limit(s) in the past day
Disable the HDM shared network port
Perform this task to disable the HDM shared network port.
hREST -H host -p port -U username -P password setshareport –N ethernetid –S disable
Table 112 Parameter description
Parameter
Value
ethernetid
Network port name.
Optional.
disable
Disable the shared port.
·     Disabled.
This command is supported in HDM-2.97 and later versions.
Example
# Disable shared network port eth0.
-> hREST –H 192.168.10.6 –U ****** -P ****** setshareport -N eth0 –S Disabled
Success: set shareport successfully
Obtain NCSI status for the shared network port
Perform this task to obtain NCSI status for the shared network port.
hREST -H host -p port -U username -P password getncsi
Exampels
# Obtain NCSI status for the shared network port.
-> hREST –H 192.168.10.6 –U ****** -P ****** getncsi
NCSIStatus                              : Enable
Table 113 Command output
NCSIStatus
NCSI enabling status for the network port. Supported options:
·     Enable.
·     Disable.
Configure NCSI status for the shared network port
Perform this task to configure NCSI status for the shared network port.
hREST -H Host -p Port -U UserName -P PassWord  setncsi -S NcsiStatus
User role
admin
Table 114 Parameter description
Parameter
Value
NcsiStatus
Enable or disable NCSI for the shared network port.
·     Enable.
·     Disable.
You cannot use the IP address of the shared network port to disable NCSI for the port.
# Disable NCSI for the shared network port.
-> ./hREST –H 192.168.10.6 –U ****** -P ****** setncsi -S Disable
Success: set the shared port NCSI successfully
Set the VNC password
Perform this task to configure the VNC password.
hREST -H Host -p Port -U UserName -P PassWord  setvnc -P VNCpwd
User role
admin
Table 115 Parameter description
Parameter
Value
VNCpwd
VNC password.
Required.
The password complexity and length are restricted by the back end, and this tool does not perform password check. As a best practice, do not use special characters that the operating system can automatically escape, to avoid setting a password that deviates from the actual valid password.
This command is not available in HDM B01.
# Set the VNC timeout timer to 20 minutes and the password to root.
-> ./hREST –H 192.168.10.6 –U ****** -P ****** setvnc -P root
"Success: VNC password is set successfully"
Obtain SMTP information
Perform this task to obtain SMTP information.
hREST -H host -p port -U username -P password getsmtp
# Obtain SMTP information.
-> hREST –H 192.168.10.6 –U ****** -P ****** getsmtp
ServerAddress                           : 2022::20
ServerPort                              : 10086
AnonymousLoginEnabled                   : False
SenderAddress                           : [email protected]
SenderUserName                          : test
SenderPassword                          : null
AlarmSeverity                           : All
TLSEnabled                              : False
RecipientAddresses
    MemberId                            : 1
    EmailAddress                        :
    Enabled                             : True
Table 116 Command output
Id
SMTP resource ID
Name
Resource name.
ServiceEnabled
Whether the service is enabled.
ServerAddress
Server address.
ServerPort
Server port.
Whether anonymous login is enabled.
SenderAddress
Sender email address.
SenderUserName
Sender username.
SenderPassword
Sender password.
AlarmSeverity
Alarm severities. Supported options:
·     Critical
·     All
TLSEnabled
Whether TLS is enabled for trap notification.
RecipientAddresses.MemberId
ID of the recipient email address.
RecipientAddresses. EmailAddress
Recipient email address.
RecipientAddresses. Enabled
Whether the email address of the recipient is enabled.
Configure SMTP settings
Perform this task to configure SMTP settings.
hREST -H host -p port -U username -P password setsmtp -S SmtpEnabled - A SeverAddress -P ServerPort -AN AnonymousEnabled -SN SenderName -SP SenderPwd -SA SenderAddr -AS AlarmSeverity -TLS TlsEnabled -RA RecipAddr
Table 117 Parameter description
Parameter
Value
SmtpEnabled
Enabling status of the SMTP service.
Optional.
Supported options:
·     Enable.
·     Disable.
SeverAddress
Server address.
Optional.
ServerPort
Service port.
Optional.
The port range is 1 to 65535.
AnonymousEnabled
Enabling status of anonymous login.
Optional.
Supported options:
·     Enable.
·     Disable.
SenderName
Sender username.
Optional.
SenderPwd
Sender password.
Optional.
SenderAddr
Optional.
AlarmSeverity
Alarm severity.
Optional.
Supported options:
·     Critical.
·     All.
TlsEnabled
Enabling status of TLS.
·     Enable.
·     Disable.
RecipAddr
Email address that receives alarm emails.
Optional.
For example:
[1:1:admin:administrator+2:0:test:abc]
Where two recipients are configured, each contains four options separated by colons (:). Take 2:0:test:abc as an example:
·     2A ID, in the range of 1 to 15.
·     1 indicates enabled and 0 indicates disabled.
·     testHDM username.
·     abcEmail subject.
# Configure the SMTP service.
-> hREST.bat -H 192.168.0.49 -U admin –P Password@_ setsmtp -S Enable -A 192.168.0.16 -P10999 -AN Enable -AS All -TLS Enable -RA [1:1:admin:administrator+2:1:test:abc]
Success: set smtp successfully
Export operation log
Perform this task to export the operation log of the tool.
hREST -H host -p port -U username -P password exportlog –F filepath
This command is available in in-band management mode.
In out-of-band management mode, the tool will check the connectivity of the host address. As a best practice, do not use this command in out-of-band management mode. The log file is in ZIP format. As a best practice, name the log file name suffixed with .zip.
Table 118 Parameter description
Parameter
Value
filepath
Path and name of the file for saving configuration files.
Required.
If this argument is empty, the operation log will be saved to the config folder in the tool directory.
# Export the operation log of the tool.
-> hREST –H 192.168.10.6 –U ****** -P ****** exportlog -F ../abc.zip
Success: export tool operation logs successful
