- 03-Security Command Reference
- 01-ARP attack protection commands
- 02-ASPF commands
- 03-IP-MAC binding commands
- 04-Keychain commands
- 05-ND attack defense commands
- 06-Password control commands
- 07-uRPF commands
- 08-Location identification commands
- 09-Security zone commands
- 10-User identification commands
- 11-MAC learning through a Layer 3 device commands
- 12-Security policy commands
- 13-Microsegmentation commands
- 14-IP-SGT mapping commands
- 15-SMS commands
- 16-Trusted access control commands
- 17-Application account auditing commands
- 18-Terminal identification commands
- 19-IPoE commands
- 20-SSL commands
- 21-Flow manager commands
- 22-Object group commands
- 23-IP source guard commands
- 24-Server connection detection commands
- 25-Session management commands
- 26-DDoS protection commands
- 27-PKI commands
- 28-Crypto engine commands
- 29-AAA commands
- 30-Portal commands
- 31-IPsec commands
- 32-Public key management commands
- 33-Attack detection and prevention commands
- 34-Connection limit commands
- 35-SSH commands
- 36-SDP zero trust commands
- 37-APR commands
- 38-Overbilling prevention commands
| 36-SDP zero trust commands | 135.37 KB |
display trusted-access controller sdp assigned-resource
display trusted-access controller sdp default-policy
display trusted-access controller sdp ip-tunnel route
display trusted-access controller sdp mode transparent
display trusted-access controller sdp session
display trusted-access controller sdp tcp-proxy-connection
vSystem supports all SDP zero trust features. For more information about vSystem, see Virtual Technologies Configuration Guide.
Use display trusted-access controller sdp assigned-resource to display the resources assigned by the SDP controller to users.
display trusted-access controller sdp assigned-resource { api | app } [ context context-name ]
context-admin
context-operator
vsys-admin
vsys-operator
api: Displays API resources.
app: Displays app resources.
context context-name: Specifies an SDP context by its name. An SDP context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SDP context, this command displays resource information in all SDP contexts.
# Display app resources assigned by the SDP controller to users.
<Sysname> display trusted-access controller sdp assigned-resource app
Total Apps : 2
Context : default
Apps : 2
App ID : 1
App Name : udp
AccessType : ip-tunnel
Address : Protocol : ALL
IPv4Address : 15.0.0.2
Port : 1-65535
App ID : 13
App Name : udpv6
IPv6Address : 88::93
Port : 9090
Address : Protocol : ICMP
IPv4Address : 4.1.1.1-4.1.1.10
IPv6Address : 66::77-66::88
Total Apps |
Total number of apps assigned to the SDP gateway by the SDP controller. |
Context |
SDP context to which the SDP user belongs. The SDP context name must be default. |
Apps |
Total number of apps under the SDP context. |
App ID |
ID of the app that the SDP controller assigns to users. |
App Name |
Name of the app that the SDP controller assigns to users. |
AccessType |
Access mode supported by the app: · ip-tunnel—IP access mode. · web-access—Web access mode. · tcp-access—TCP access mode. |
HostName |
Host name of the app. |
Gateway Port |
SDP gateway port number for the app server. This field is available only for an app of the TCP proxy type. |
Identity Location |
Location of the user token in the request message sent by the TCP app client to the SDP gateway, in the range of 1 to 65535. The field value indicates the start bit of user information. This field is available only for an app of the TCP proxy type. |
Address |
Address of the app. This field might display multiple times. |
Protocol |
Protocol pf the app, including: · TCP. · UDP. · HTTP. · HTTPS. · ALL—Supports both TCP, UDP, and ICMP. · ICMP. |
IPv4Address |
IPv4 address of the app. |
IPv4Address |
IPv6 address of the app. |
Port |
Port number of the app. This field is not available for ICMP. |
# Display API resources assigned by the SDP controller to users.
<Sysname> display trusted-access controller sdp assigned-resource api
Total APIs : 2
Context : default
APIs : 2
API ID : 4
API Name : ui1
URL : /ui1
App ID : 7
API ID : 5
API Name : ui2
URL : /ui2
App ID : 7
Total APIs |
Total number of APIs assigned to the SDP gateway by the SDP controller. |
Context |
APIs |
API ID |
ID of the API that the SDP controller assigns to users. |
API Name |
Name of the API that the SDP controller assigns to users. |
URL |
URL suffix. |
App ID |
ID of the app to which the API belongs. |
Use display trusted-access controller sdp default-policy to display the default policies assigned to the gateway by the SDP controller.
context-admin
context-operator
vsys-admin
vsys-operator
# Display the default policies assigned to the gateway by the SDP controller.
<Sysname> display trusted-access controller sdp default-policy
App default policy: Deny
API default policy: Permit
App default policy |
App default policy assigned to the gateway by the SDP controller, including: · Permit. · Deny. |
API default policy |
API default policy assigned to the gateway by the SDP controller, including: · Permit. · Deny. |
Use display trusted-access controller sdp ip-tunnel route to display internal tunnel routes issued by the SDP controller to the gateway.
context-admin
context-operator
vsys-admin
vsys-operator
# Display internal tunnel routes issued by the SDP controller to the gateway.
<Sysname> display trusted-access controller sdp ip-tunnel route
State: Enabled
IPv4 route:
IPv4 address Mask length
12.1.0.0 16
13.1.1.0 24
IPv6 route:
IPv6 address Prefix length
2002::0 16
State |
Enabling status of a route issued by the SDP controller to the gateway: · Enabled. · Disabled. |
IPv4 route |
IPv4 route issued by the SDP controller to the gateway. |
IPv4 address |
Address of the IPv4 route. |
Mask length |
Mask length of the IPv4 route address. |
IPv6 route |
IPv6 route issued by the SDP controller to the gateway. |
IPv6 address |
Address of the IPv6 route. |
Prefix length |
Prefix length of the IPv6 route address. |
Use display trusted-access controller sdp mode transparent to transparent mode information deployed by the SDP controller.
context-admin
context-operator
vsys-admin
vsys-operator
# Display transparent mode information deployed by the SDP controller.
<Sysname> display trusted-access controller sdp mode transparent
Transparent mode : Enabled
Heartbeat port : 2002
Heartbeat interval : 10 min
Table 5 Command output
Mode |
Enabling status of transparent mode deployed by the SDP controller: · Disabled. · Enabled. The transparent mode applies to only zero trust scenarios in the internal network. |
Heartbeat port |
Port number of heartbeat packets. This field is available only in transparent mode. |
Heartbeat interval |
Sending interval of heartbeat packets in minutes. This field is available only in transparent mode. |
Use display trusted-access controller sdp session to display SDP session information.
display trusted-access controller sdp session [ context context-name ] [ user user-name ] [ transparent ]
context-admin
context-operator
vsys-admin
vsys-operator
context context-name: Specifies an SDP context by its name. An SDP context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SDP context, this command displays detailed SDP session information in all SDP contexts.
user user-name: Specifies an SDP user by the username, a case-insensitive string of 1 to 63 characters. If you do not specify a user, this command displays detailed SDP session information for all users.
transparent: Displays transparent mode information of SDP sessions. If you do not specify this keyword, this command displays detailed SDP session information of all users or a user in all SDP contexts or an SDP context.
# Display detailed SDP session information for all users.
<Sysname> display trusted-access controller sdp session
Total users : 3
User : user1
Context : default
Created at : 13:49:27 UTC Wed 04/14/2021
Latest : 17:50:58 UTC Wed 04/14/2021
Allocated IPv4 address : 2.2.2.1
Allocated IPv6 address : 3001::C351
Session ID : 1
Send rate : 0.00 B/s
Receive rate : 0.00 B/s
Sent bytes : 0.00 B
Received bytes : 0.00 B
Mode : Tunnel
Apps : app1/permit;
User : user2
Context : default
Created at : 13:50:20 UTC Wed 04/14/2021
Latest : 17:55:58 UTC Wed 04/14/2021
Allocated IPv6 address : 3001::C34C
Session ID : 9
Sent bytes : 0.00 B
Mode : Transparent (client)
Apps : app1/permit;
User : user3
Context : default
Created at : 13:52:20 UTC Wed 04/14/2021
Latest : 17:59:58 UTC Wed 04/14/2021
Allocated IPv4 address : 2.2.2.2
Allocated IPv6 address : 3001::C34D
Session ID : 10
Sent bytes : 0.00 B
Mode : Transparent (no client)
Apps : app1/permit;
# Display SDP session information for SDP user user1.
<Sysname> display trusted-access controller sdp session user user1
User : user1
Context : default
Session ID : 1
Sent bytes : 0.00 B
Mode : Tunnel
Apps : app1/permit;
# Display transparent mode information of an SDP session for SDP user user1.
<Sysname> display trusted-access controller sdp session transparent
User : user1
Context : default
Session ID : 1
Source IPv4 address : 192.0.2.1,192.67.1.1
Source IPv6 address : 12::12
Table 6 Command output
Total users |
Total number of SDP users. |
User |
SDP username. |
Context |
Created at |
Time at which the SDP session was created. |
Latest |
Most recent time when the SDP user accessed resources through the SDP session. |
Allocated IPv4 address |
IPv4 address allocated to the iNode client of the SDP user. This field is available only for iNode users. |
Allocated IPv6 address |
IPv6 address allocated to the iNode client of the SDP user. This field is available only for iNode users. |
Session ID |
ID of the SDP session. |
Send rate |
Sending rate of the SDP session in one of the following units: · B/s—Bytes per second. · KB/s—Kilobytes per second. · MB/s—Megabytes per second. · GB/s—Gigabytes per second. · TB/s—Terabytes per second. · PB/s—Petabytes per second. This field is not available in transparent mode. |
Receive rate |
Receiving rate of the SDP session in one of the following units: · B/s—Bytes per second. · KB/s—Kilobytes per second. · MB/s—Megabytes per second. · GB/s—Gigabytes per second. · TB/s—Terabytes per second. · PB/s—Petabytes per second. This field is not available in transparent mode. |
Sent bytes |
Traffic sent by the SDP session in one of the following units: · B—Bytes. · KB—Kilobytes. · MB—Megabytes. · GB—Gigabytes. · TB—Terabytes. · PB—Petabytes. This field is not available in transparent mode. |
Received bytes |
Traffic received by the SDP session in one of the following units: · B—Bytes. · KB—Kilobytes. · MB—Megabytes. · GB—Gigabytes. · TB—Terabytes. · PB—Petabytes. This field is not available in transparent mode. |
Mode |
SDP user access mode: · Transparent (client)—Transparent mode with clients, also transparent direct access. This mode applies to only zero trust scenarios in the internal network. · Tunnel—IP tunnel mode. · Web proxy. · Transparent (no client)—Transparent mode without clients, also transparent direct access. This mode applies to only zero trust scenarios in the internal network. |
Apps |
Apps to which the SDP controller allows or denies user access. |
APIs |
APIs to which the SDP controller allows or denies user access. |
Source IPv4 address |
Source IPv4 address of an SDP user in transparent mode. |
Source IPv6 address |
Source IPv6 address of an SDP user in transparent mode. |
Use display trusted-access controller sdp tcp-proxy-connection to display information about TCP proxy for access to apps.
In standalone mode:
display trusted-access controller sdp tcp-proxy-connection [ context context-name ] [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display trusted-access controller sdp tcp-proxy-connection [ context context-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
vsys-admin
vsys-operator
context context-name: Specifies an SDP context by its name. An SDP context name is a case-insensitive string of 1 to 31 characters, and can contain only letters, digits, and underscores (_). If you do not specify an SDP context, this command displays TCP proxy information for all SDP contexts.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays TCP proxy information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays TCP proxy information for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
# (In standalone mode.) Display TCP proxy information for all SDP contexts.
<Sysname> display trusted-access controller sdp tcp-proxy-connection
Slot : 1
Total count : 2
Context : default
User : user1
Client address : 192.0.2.1
Client port : 1025
Server address : 192.168.0.39
Server port : 80
TCP connection status : Connected
User : user2
Client address : 192.0.2.4
Client port : 56190
Server address : 192.168.0.50
Server port : 23
TCP connection status : Connecting
Table 7 Command output
Total count |
Total number of SDP users for the SDP context. |
Context |
SDP context name. |
User |
Login name of the SDP user. |
Client address |
IP address of the SDP client. |
Client port |
Port number of the SDP client. |
Server address |
IP address of the app server. |
Server port |
Port number of the app server. |
TCP connection status |
TCP connection status, Connected or Connecting. |
sdp access-method
Use sdp access-method to specify the resource access mode through the SDP gateway.
Use undo sdp access-method to restore the default.
sdp access-method { ip-tunnel | mix | web-access }
The resource access mode through the SDP gateway is mix.
SDP trusted access controller view
context-admin
vsys-admin
ip-tunnel: Specifies IP access mode. In this mode, a user can use only the iNode client to log in to the SDP controller for authentication. After authentication, the user can access internal resources only through the iNode client.
mix: Specifies mix access mode. In this mode, a user must use the iNode client to log in to the SDP controller for authentication. After authentication, the user can access internal resources through a browser or the iNode client.
web-access: Specifies Web access mode. In this mode, a user can log in to the SDP controller only through browsers for authentication. After authentication, the user can access internal resources only through a browser.
This command takes effect only when SDP is enabled for trusted access control.
If you change the access mode, a user that has logged in must log in to the SDP controller again for authentication. The user can continue to access internal resources only after passing the authentication.
# Specify the Web access mode for users to access the SDP gateway.
[Sysname] trusted-access controller sdp
[Sysname-tac-sdp] sdp access-method web-access
sdp enable
sdp api-access default
Use sdp api-access default to configure the default API access control rule.
Use undo sdp api-access default to restore the default.
sdp api-access default { deny | permit }
Users are permitted to access internal APIs through the SDP gateway.
context-admin
vsys-admin
deny: Denies user access to internal APIs through the SDP gateway.
permit: Allows user access to internal APIs through the SDP gateway.
If an API is not in the API list assigned by the SDP controller, the device will deny or allow user access to the API according to the default API access control rule.
If a large number of internal APIs are available, you can manage permissions to access specific APIs. For example, deny or allow user access to an important API. For other APIs, you can use this command to configure the default API access control rule as a whole.
# Deny user access to internal APIs through the SDP gateway.
[Sysname-tac-sdp] sdp api-access default deny
sdp enable
sdp enable
Use sdp enable to enable SDP for trusted access control.
Use undo sdp enable to disable SDP for trusted access control.
sdp enable
undo sdp enable
SDP is disabled for trusted access control.
context-admin
vsys-admin
SDP zero trust allows the device to act as an SDP gateway to cooperate with an SDP controller to authenticate and authorize users that access a specific app or API. This can centrally control user identities and access permissions to avoid illegal user access.
The SDP gateway uses the cloud connection feature to notify the SDP controller of the keepalive status. To ensure the operation of SDP trusted access control, use cloud-management keepalive to set the keepalive interval to 10 to 29 seconds for the device to send keepalive packets to the cloud server. Because the keepalive interval set on the SDP controller is 30 seconds. For more information about cloud connections, see Network Management and Monitoring Configuration Guide.
In a zero trust scenario, the SDP gateway acts as the SSL VPN gateway to connect remote users to the enterprise internal network.
# Enable SDP for trusted access control.
[Sysname-tac-sdp] sdp enable
spa enable
Use spa enable to enable SPA authentication.
Use undo spa enable to disable SPA authentication.
spa enable
undo spa enable
SPA authentication is disabled.
context-admin
vsys-admin
This command is supported only in IP access mode and mix access mode, and takes effect only when SDP is enabled for trusted access control.
In IP or mix access mode, the iNode client must send an SPA message to the SDP gateway. Then, the SDP gateway identifies whether the client is legal according to the SPA message. If the client is legal, the SDP gateway will receive the subsequent requests from the client. If not, the SDP gateway will reject the client requests.
Re-enabling this feature affects online users. When users access resources, do not re-enable this feature as a best practice. You can use the display trusted-access controller sdp session command to obtain information about online users.
# Enable SPA authentication.
[Sysname-tac-sdp] spa enable
sdp enable
sdp access-method
Use trusted-access controller sdp to enter SDP trusted access controller view.
Use undo trusted-access controller sdp to exit SDP trusted access controller view.
The SDP trusted access controller view does not exist.
context-admin
vsys-admin
# Enter SDP trusted access controller view.
[Sysname-tac-sdp]
