- 03-Security Command Reference
- 01-ARP attack protection commands
- 02-ASPF commands
- 03-IP-MAC binding commands
- 04-Keychain commands
- 05-ND attack defense commands
- 06-Password control commands
- 07-uRPF commands
- 08-Location identification commands
- 09-Security zone commands
- 10-User identification commands
- 11-MAC learning through a Layer 3 device commands
- 12-Security policy commands
- 13-Microsegmentation commands
- 14-IP-SGT mapping commands
- 15-SMS commands
- 16-Trusted access control commands
- 17-Application account auditing commands
- 18-Terminal identification commands
- 19-IPoE commands
- 20-SSL commands
- 21-Flow manager commands
- 22-Object group commands
- 23-IP source guard commands
- 24-Server connection detection commands
- 25-Session management commands
- 26-DDoS protection commands
- 27-PKI commands
- 28-Crypto engine commands
- 29-AAA commands
- 30-Portal commands
- 31-IPsec commands
- 32-Public key management commands
- 33-Attack detection and prevention commands
- 34-Connection limit commands
- 35-SSH commands
- 36-SDP zero trust commands
- 37-APR commands
- 38-Overbilling prevention commands
| 21-Flow manager commands | 34.85 KB |
flow-manager mac-forwarding enable
Use flow-manager mac-forwarding enable to enable the flow manager for Layer 2 forwarding.
Use undo flow-manager mac-forwarding enable to disable the flow manager for Layer 2 forwarding.
The flow manager is disabled for Layer 2 forwarding.
context-admin
An interface card cannot obtain packet information of the packets with two VLAN tags (such as QinQ packets), and therefore cannot send the packets to the correct security engine.
This feature can query OpenFlow entries for such packets and transparently transmit them to the correct security engine.
# Enable the flow manager for Layer 2 forwarding.
[Sysname] flow-manager mac-forwarding enable
