- 03-Security Command Reference
- 01-ARP attack protection commands
- 02-ASPF commands
- 03-IP-MAC binding commands
- 04-Keychain commands
- 05-ND attack defense commands
- 06-Password control commands
- 07-uRPF commands
- 08-Location identification commands
- 09-Security zone commands
- 10-User identification commands
- 11-MAC learning through a Layer 3 device commands
- 12-Security policy commands
- 13-Microsegmentation commands
- 14-IP-SGT mapping commands
- 15-SMS commands
- 16-Trusted access control commands
- 17-Application account auditing commands
- 18-Terminal identification commands
- 19-IPoE commands
- 20-SSL commands
- 21-Flow manager commands
- 22-Object group commands
- 23-IP source guard commands
- 24-Server connection detection commands
- 25-Session management commands
- 26-DDoS protection commands
- 27-PKI commands
- 28-Crypto engine commands
- 29-AAA commands
- 30-Portal commands
- 31-IPsec commands
- 32-Public key management commands
- 33-Attack detection and prevention commands
- 34-Connection limit commands
- 35-SSH commands
- 36-SDP zero trust commands
- 37-APR commands
- 38-Overbilling prevention commands
| 28-Crypto engine commands | 63.89 KB |
display crypto-engine
Use display crypto-engine to display crypto engine information.
context-admin
context-operator
If the device does not have hardware crypto engines, this command displays information only about software crypto engines.
# Display crypto engine information.
<Sysname> display crypto-engine
Crypto engine name: Software crypto engine
Crypto engine state: Enabled
Crypto engine type: Software
Slot ID: 0
CPU ID: 0
Crypto engine ID: 0
Crypto device name: Software
Crypto device serial number:
Symmetric algorithms: des-cbc des-ecb 3des-cbc aes-cbc aes-ecb aes-ctr camellia_cbc md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc aes-xcbc-hmac sm3 sm3-hmac sm4-cbc
Asymmetric algorithms:
Random number generation function: Supported
Slot ID: 2
CPU ID: 0
Crypto engine ID: 0
Slot ID: 4
CPU ID: 0
Crypto engine ID: 0
Slot ID: 4
CPU ID: 1
Crypto engine ID: 0
Crypto engine name: Cavium crypto driver
Crypto engine type: Hardware
Slot ID: 4
CPU ID: 1
Crypto engine ID: 1
Crypto device name: Cavium crypto
Symmetric algorithms: des-cbc des-ecb 3des-cbc 3des-ecb aes-cbc aes-ecb aes-ctr md5 sha1 sha2-256 sha2-384 sha2-512 md5-hmac sha1-hmac sha2-256-hmac sha2-384-hmac sha2-512-hmac aes-xcbc-hmac sm4-cbc
Asymmetric algorithms: dh-group1 dh-group2 dh-group5 dh-group14
Slot ID: 5
CPU ID: 0
Crypto engine ID: 0
Slot ID: 6
CPU ID: 0
Crypto engine ID: 0
Crypto engine state |
Hardware crypto engine state: · Enabled. · Disabled. This field always displays Enabled for software crypto engines. |
Crypto engine type |
Crypto engine type: · Hardware. · Software. |
Crypto device name |
Name of the crypto device. This field displays Software for software crypto engines. |
Crypto device serial number |
Serial number of the crypto device. This field is always empty for software crypto engines. |
Symmetric algorithms |
Supported symmetric algorithms. |
Asymmetric algorithms |
Supported asymmetric algorithms. |
Random number generation function |
Whether random number generation function is supported: · Supported. · Not supported. |
display crypto-engine statistics
Use display crypto-engine statistics to display crypto engine statistics.
In standalone mode:
display crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
engine-id engine-id: Specifies a crypto engine by its ID.The value range for the engine-id argument is 0 to 4294967295.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
If hardware crypto engines are not enabled or the device does not have hardware crypto engines, this command displays statistics only for software crypto engines.
(In standalone mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command displays crypto engine statistics for all cards.
# (In standalone mode.) Display all crypto engine statistics.
<Sysname> display crypto-engine statistics
Slot ID: 1
CPU ID: 0
Crypto engine ID: 0
Submitted sessions: 0
Failed sessions: 0
Symmetric operations: 0
Symmetric errors: 0
Asymmetric operations: 0
Asymmetric errors: 0
Get-random operations: 0
Get-random errors: 0
# (In standalone mode.) Display statistics for crypto engine 1 on the specified slot.
<Sysname> display crypto-engine statistics engine-id 1 slot 1
Failed sessions: 0
Symmetric errors: 0
Submitted sessions |
Number of established sessions. |
Failed sessions |
Number of failed sessions. |
Symmetric operations |
Number of operations using symmetric algorithms. |
Symmetric errors |
Number of failed operations using symmetric algorithms. |
Asymmetric operations |
Number of operations using asymmetric algorithms. |
Asymmetric errors |
Number of failed operations using asymmetric algorithms. |
Get-random operations |
Number of operations for obtaining random numbers. |
Get-random errors |
Number of failed operations for obtaining random numbers. |
reset crypto-engine statistics
Use reset crypto-engine statistics to clear crypto engine statistics.
In standalone mode:
reset crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
(In standalone mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
(In IRF mode.) If you do not specify any parameters, this command clears crypto engine statistics for all cards.
# Clear statistics for all crypto engines.
<Sysname> reset crypto-engine statistics
# Clear statistics for crypto engine 1 on the specified slot.
<Sysname> reset crypto-engine statistics engine-id 1 slot 1
