03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9900)-6W10003-Security Command Reference
17-Application account auditing commands
17-Application account auditing commands 34.97 KB
This feature parses personal information from user packets and must be used for legitimate purposes.
app-account extract enable
Use app-account extract enable to enable application account auditing.
Use undo app-account extract enable to disable application account auditing.
Application account auditing is disabled.
context-admin
This command can audit the application name and user account in the application layer of packets. Then, the audited information is sent as system logs to the information center for processing.
# Enable application account auditing.
[Sysname] app-account extract enable
