- 03-Security Command Reference
- 01-ARP attack protection commands
- 02-ASPF commands
- 03-IP-MAC binding commands
- 04-Keychain commands
- 05-ND attack defense commands
- 06-Password control commands
- 07-uRPF commands
- 08-Location identification commands
- 09-Security zone commands
- 10-User identification commands
- 11-MAC learning through a Layer 3 device commands
- 12-Security policy commands
- 13-Microsegmentation commands
- 14-IP-SGT mapping commands
- 15-SMS commands
- 16-Trusted access control commands
- 17-Application account auditing commands
- 18-Terminal identification commands
- 19-IPoE commands
- 20-SSL commands
- 21-Flow manager commands
- 22-Object group commands
- 23-IP source guard commands
- 24-Server connection detection commands
- 25-Session management commands
- 26-DDoS protection commands
- 27-PKI commands
- 28-Crypto engine commands
- 29-AAA commands
- 30-Portal commands
- 31-IPsec commands
- 32-Public key management commands
- 33-Attack detection and prevention commands
- 34-Connection limit commands
- 35-SSH commands
- 36-SDP zero trust commands
- 37-APR commands
- 38-Overbilling prevention commands
| 22-Object group commands | 226.96 KB |
display object-group notify-list
exclude (IPv4 address object group view)
exclude (IPv6 address object group view)
network (IPv4 address object group view)
network (IPv6 address object group view)
network exclude (IPv4 address object group view)
network exclude (IPv6 address object group view)
service (service object group view)
Non-default vSystems do not support some of the object group commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
description
Use description to configure a description for an object group.
No description is configured for an object group.
Object group view
context-admin
vsys-admin
text: Specifies a description, a case-sensitive string of 1 to 127 characters.
# Configure the description as This is an IPv4 object-group for an IPv4 address object group.
[Sysname] object-group ip address ipgroup
[Sysname-obj-grp-ip-ipgroup] description This is an IPv4 object-group
Use display object-group to display information about object groups.
display object-group [ { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } [ default ] [ name object-group-name ] | name object-group-name ]
context-admin
context-operator
vsys-admin
vsys-operator
ip address: Specifies the IPv4 address object groups.
ipv6 address: Specifies the IPv6 address object groups.
ip address-yundi: Specifies the IPv4 address object groups for a Yundi network.
ipv6 address-yundi: Specifies the IPv6 address object groups for a Yundi network.
mac-address: Specifies the MAC address object groups.
port: Specifies the port object groups.
service: Specifies the service object groups.
service-yundi: Specifies the service object groups for a Yundi network.
default: Specifies the default object groups.
name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters.
# Display information about all object groups.
<Sysname> display object-group
IP address object group obj1: 0 object(in use)
IP address object group obj2: 6 objects(out of use)
0 network host address 1.1.1.1
object 0 description this is a description for object 0
10 network host name host
object 10 description this is a description for object 10
20 network subnet 1.1.1.1 255.255.255.0
30 network range 1.1.1.1 1.1.1.2
40 network group-object obj1
50 network user-group group1
60 network host name dns1 vpn-instance vpn1
70 network exclude range 2.2.2.2 3.3.3.3
IPv6 address object-group obj3: 0 object(in use)
IPv6 address object-group obj4: 5 objects(out of use)
0 network host address 1::1:1
20 network subnet 1::1:0 112
30 network range 1::1:1 1::1:2
40 network group-object obj3
50 network host name dns2 vpn-instance vpn2
60 network exclude range 2::2:2 3::3:3
Service object-group obj5: 0 object(in use)
Service object-group obj6: 6 objects(out of use)
0 service 200
10 service tcp source lt 50 destination range 30 40
20 service udp source range 30 40 destination gt 30
30 service icmp 20 20
40 service icmpv6 20 20
50 service group-object obj5
MAC object-group obj7: 0 object(in use)
MAC object-group obj8: 2 objects(out of use)
0 MAC address 0010-dc28-11ac
10 MAC group-object obj7
# Display information about object group obj2.
<Sysname> display object-group name obj2
IP address object-group obj2: 5 objects(out of use)
50 network host name a1 vpn-instance v1
60 network exclude range 2.2.2.2 3.3.3.3
# Display information about all IPv4 address object groups.
<Sysname> display object-group ip address
IP address object-group obj1: 0 object(in use)
50 network exclude range 2.2.2.2 3.3.3.3
# Display information about IPv6 address object group obj4.
<Sysname> display object-group ipv6 address name obj4
50 network host name host vpn-instance vpn1
in use |
The object group is used by an ACL or object group. |
out of use |
The object group is not used. |
display object-group host
Use display object-group host to display IPv4 or IPv6 addresses for host names.
In standalone mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display object-group { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
object-group-name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays information about the specified host name.
name host-name: Specifies a host by its name, a case-insensitive string of 1 to 253 characters. If you do not specify this option, the command displays information about all the included and excluded host names in the specified object group.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 or IPv6 addresses for host names for the public network and all VPN instances.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
Non-default vSystems do not support this command.
# Display IPv4 addresses for host name a.example.com in object group group1.
<Sysname> display object-group ip host object-group-name group1 name a.example.com
Object group : group1
Object ID : 0
Host name : a.example.com
VPN instance : -
Updated at : 2019-05-20 11:04:24
IP addresses :
169.0.0.10
169.0.0.11
# Display IPv6 addresses for all host names in object group group1.
<Sysname> display object-group ipv6 host object-group-name group1
Object ID : 0
VPN instance : -
IP addresses :
169:0::0:10
169:0::0:11
Object ID : 10
Host name : b.example.com
VPN instance : -
IP addresses :
169:0::0:11
169:0::0:12
Descrption |
VPN instance |
VPN to which the host belongs. |
object-group
display object-group kernel
Use display object-group kernel to display information about the IP address corresponding to the kernel host name.
In standalone mode:
display object-group kernel { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display object-group kernel { ip | ipv6 } host { object-group-name object-group-name | name host-name [ vpn-instance vpn-instance-name ] } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
ip: Specifies the IPv4 address object group.
ipv6: Specifies the IPv6 address object group.
object-group-name object-group-name: Specifies an object group by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this option, the command displays the IP address corresponding to the specified or excluded host name in any object group.
name host-name: Specifies the host name, a case-insensitive string of 1 to 60 characters. If you do not specify this option, the command displays the IP addresses corresponding to all host names and excluded host names in the specified object group.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN to which the host belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the host resides on the public network, do not specify this option.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays packet statistics for all cards. (In IRF mode.)
# Display information about the IP address corresponding to the kernel host name.
<Sysname> display object-group kernel ip host object-group-name group1 name a.example.com
Object ID : 0
VPN instance : -
IP addresses :
169.0.0.10
169.0.0.11
Object group |
Object group name. |
Object ID |
Object ID. |
Host name |
Host name. |
VPN instance |
Updated at |
Most recent time at which the IP address corresponding to the host name was updated. |
IP addresses |
IP address corresponding to the host name. |
object-group
Use display object-group notify-list to display information about the object group module waiting for responses from external modules.
In standalone mode:
display object-group notify-list [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display object-group notify-list [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
context-admin
context-operator
# Display information about the object group module waiting for responses from external modules.
<Sysname> display object-group notify-list
Node 1, vsys ID: 1, socket ID: 50, wait: False;
Node 2, vsys ID: 1, socket ID: 50, wait: False;
Vsys ID |
ID of the vSystem. |
Wait |
Whether the object group module is waiting for responses: · True—Yes. · False—No. |
Use exclude to exclude an IPv4 address, range, or subnet from an address object group.
Use undo exclude to restore the default.
exclude { host ip-address | range ip-address1 ip-address2 | subnet ip-address { mask-length | mask } }
undo exclude { host ip-address | range ip-address1 ip-address2 | subnet ip-address {mask-length | mask } }
No IPv4 address, range, or subnet is excluded from an address object group.
context-admin
vsys-admin
host ip-address: Specifies a host IPv4 address to be excluded.
range ip-address1 ip-address2: Specifies an IPv4 address range to be excluded. The ip-address1 argument specifies the start address and the ip-address2 argument represents the end address.
subnet ip-address { mask-length | mask }: Specifies the IPv4 address and mask of a subnet to be excluded. You can specify the mask length or specify the mask in dotted decimal notation. The mask length is in the range of 0 to 32.
You can execute this command multiple times to exclude several IPv4 addresses, ranges, or subnets from an IPv4 address object group. Make sure the excluded addresses, ranges, or subnets do not overlap with each other.
# Exclude IPv4 address 192.166.0.10 from address object group ipgroup.
[Sysname-obj-grp-ip-ipgroup] exclude host 192.166.0.10
# Exclude IPv4 subnet 192.166.1.0/24 from address object group ipgroup.
[Sysname-obj-grp-ip-ipgroup] exclude subnet 192.166.1.0 24
# Exclude IPv4 address range 192.166.0.10 to 192.166.0.60 from address object group ipgroup.
[Sysname-obj-grp-ip-ipgroup] exclude range 192.166.0.10 192.166.0.60
Use exclude to exclude an IPv6 address, range, or subnet from an address object group.
exclude { host ipv6-address | range ipv6-address1 ipv6-address2 | subnet ipv6-address prefix-length }
undo exclude { host ipv6-address | range ipv6-address1 ipv6-address2 | subnet ipv6-address prefix-length }
No IPv6 address, range, or subnet is excluded from an address object group.
context-admin
vsys-admin
host ip-address: Specifies a host IPv6 address to be excluded.
subnet ipv6-address prefix-length: Specifies an IPv6 subnet to be excluded. The prefix length is in the range of 0 to 128.
range ip-address1 ip-address2: Specifies the IPv6 address range to be excluded. The ip-address1 argument specifies the start address and the ip-address2 argument represents the end address.
You can execute this command multiple times to exclude several IPv6 addresses, ranges, or subnets from an IPv6 address object group. Make sure the excluded addresses, ranges, or subnets do not overlap with each other.
The configuration fails if either of the following conditions exists:
· The specified address is the same as an existing excluded address or is contained in an existing excluded subnet or range.
· The specified range contains an existing excluded address or overlaps with an existing excluded range or subnet.
· The specified subnet contains an existing excluded address or overlaps with an existing excluded range or subnet.
# Exclude the IPv6 address 1:1:1::10 from ipv6group address object group.
[Sysname] object-group ipv6 address ipv6group
[Sysname-obj-grp-ipv6-ipv6group] exclude 1:1:1::10
# Exclude IPv6 address subnet 1:1:1::2:0/112 from address object group ipv6group.
[Sysname-obj-grp-ipv6-ipv6group] exclude subnet 1:1:1::2:0 112
# Exclude IPv6 address range 1:1:1::10 to 1:1:1::60 from address object group ipv6group.
[Sysname-obj-grp-ipv6-ipv6group] exclude range 1:1:1::10 1:1:1::60
mac
Use mac to configure a MAC address object.
Use undo mac to delete a MAC address object.
[ object-id ] mac { mac-address | group-object object-group-name }
undo mac { mac-address | group-object object-group-name }
undo object-id
No MAC address objects exist.
MAC address object group view
context-admin
vsys-admin
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not specify an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
mac-address: Specifies a MAC address in format H-H-H.
group-object object-group-name: Specifies a MAC address object group by its name, a case-insensitive string of 1 to 63 characters.
You can execute this command multiple times to create multiple MAC address objects for a MAC address object group.
This command creates a MAC address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When you use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be a MAC address object group.
· If the specified object group does not exist, the system creates a MAC address object group with the name you specified and uses the object group for the object.
· Two object groups cannot use each other at the same time.
· The system supports a maximum of five object group hierarchy layers. For example, if groups 1, 2, 3, and 4 use groups 2, 3, 4, and 5, respectively, group 5 cannot use another group and group 1 cannot be used by another group.
# Configure a MAC address object with MAC address 0010-dc28-a4e9.
[Sysname] object-group mac-address groupmac
[Sysname-obj-grp-mac-groupmac] mac 0010-dc28-a4e9
object-group
Use network to configure an IPv4 address object.
Use undo network to delete an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
No IPv4 address objects exist.
context-admin
vsys-admin
host: Configures an IPv4 address object with the host address or name.
address ip-address: Specifies an IPv4 host address.
name host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters. This parameter supports fuzzy matching. You can add an asterisk (*) to the front, end, or both of a string to indicate all host names that include the string. If no asterisks are attached, the system performs exact matching with the specified host name.
subnet ip-address { mask-length | mask | wildcard wildcard }: Configures an IPv4 address object with the subnet address followed by a mask length in the range of 0 to 32 or a mask in dotted decimal notation. The wildcard wildcard option specifies a wildcard mask in dotted decimal notation. A wildcard mask of zeros represents a host address.
range ip-address1 ip-address2: Configures an IPv4 address object with the address range.
group-object object-group-name: Specifies an IPv4 address object group by its name, a case-insensitive string of 1 to 63 characters.
user user-name: Specifies a user by its name, a case-sensitive string of 1 to 55 characters.
The following compatibility matrix shows the support of hardware platforms for this keyword:
Series |
Models |
Parameter compatibility |
M9000 series |
M9006, M9010, M9014, M9016-V |
Yes |
M9000-S series |
M9008-S, M9008-S-V |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
M9000-AI-E4, M9000-AI-E8, M9000-AI-E16 |
Yes |
M9000-X series |
M9000-X06, M9000-X06-B, M9000-X06-B-G, M9000-X06-G, M9000-X10 |
No |
M9000-AI-X series |
M9000-AI-X06, M9000-AI-X10 |
No |
M9000-CN series |
M9000-CN04 |
Yes |
user-group user-group-name: Specifies a user group by its name, a case-insensitive string of 1 to 32 characters.
Series |
Models |
M9000 series |
Yes |
M9000-S series |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
Yes |
M9000-X series |
No |
M9000-AI-X series |
No |
M9000-CN series |
M9000-CN04 |
Yes |
domain domain-name: Specifies the name of a domain to which the user or the user group belongs, a case-insensitive string of 1 to 255 characters. The string cannot contain question marks (?). If you do not specify this option, the command considers that the user or the user group does not belong to any domains.
Series |
Models |
M9000 series |
Yes |
M9000-S series |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
Yes |
M9000-X series |
No |
M9000-AI-X series |
No |
M9000-CN series |
M9000-CN04 |
Yes |
This command fails if you use it to configure or change an IPv4 address object to be identical with an existing object.
This command creates an IPv4 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet with the mask length of 32 or the mask of 255.255.255.255, the system configures the object with a host address.
When you use the range ip-address1 ip-address2 option, if ip-address1 is higher than ip-address2, the system adjusts the range to [ ip-address2, ip-address1 ].
· The object group to be used must be an IPv4 address object group.
· If the specified object group does not exist, the system creates an IPv4 address object group with the name you specified and uses the object group for the object.
# Configure an IPv4 address object with the host address of 192.168.0.1.
[Sysname-obj-grp-ip-ipgroup] network host address 192.168.0.1
# Configure an IPv4 address object with exact-matching host name pc3.
[Sysname-obj-grp-ip-ipgroup] network host name pc3
# Configure an IPv4 address object with fuzzy-matching host name abc.
[Sysname] object-group ip address ipgroup1
[Sysname-obj-grp-ip-ipgroup1] network host name *abc*
# Configure an IPv4 address object with the IPv4 address of 192.167.0.0 and mask length of 24.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.167.0.0 24
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.166.0.0 255.255.0.0
# Configure an IPv4 address object with the address range of 192.165.0.100 to 192.165.0.200.
[Sysname-obj-grp-ip-ipgroup] network range 192.165.0.100 192.165.0.200
# Configure an IPv4 address object using object group ipgroup2.
[Sysname-obj-grp-ip-ipgroup] network group-object ipgroup2
# Configure an IPv4 address object with the IPv4 address of 192.168.0.1 and wildcard mask of 0.0.255.0.
[Sysname-obj-grp-ip-ipgroup] network subnet 192.168.0.1 wildcard 0.0.255.0
# Configure an IPv4 address object using user user1 in domain domain1.
[Sysname-obj-grp-ip-ipgroup] network user user1 domain domain1
# Configure an IPv4 address object using user group usergroup1 in domain domain1.
[Sysname-obj-grp-ip-ipgroup] network user-group usergroup1 domain domain1
Use network to configure an IPv6 address object.
Use undo network to delete an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
undo object-id
No IPv6 address objects exist.
context-admin
vsys-admin
object-id: Specifies an object ID in the range of 0 to 4294967294. If you do not configure an object ID, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the system automatically assigns 30.
host: Configures an IPv6 address object with the host address or name.
address ipv6-address: Specifies an IPv6 host address.
subnet ipv6-address prefix-length: Configures an IPv6 address object with the subnet address followed by the prefix length in the range of 0 to 128.
range ipv6-address1 ipv6-address2: Configures an IPv6 address object.
group-object object-group-name: Specifies an IPv6 address object group by its name, a case-insensitive string of 1 to 63 characters.
Series |
Models |
M9000 series |
Yes |
M9000-S series |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
Yes |
M9000-X series |
No |
M9000-AI-X series |
No |
M9000-CN series |
M9000-CN04 |
Yes |
Series |
Models |
M9000 series |
Yes |
M9000-S series |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
Yes |
M9000-X series |
No |
M9000-AI-X series |
No |
M9000-CN series |
M9000-CN04 |
Yes |
Series |
Models |
M9000 series |
Yes |
M9000-S series |
Yes |
M9000-AK series |
M9000-AK001 |
Yes |
M9000-AI-E series |
Yes |
M9000-X series |
No |
M9000-AI-X series |
No |
M9000-CN series |
M9000-CN04 |
Yes |
This command fails if you use it to configure or change an IPv6 address object to be identical with an existing object.
This command creates an IPv6 address object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
If you configure a subnet address with the prefix length of 128, the system configures the object with a host address.
When you use the range ipv6-address1 ipv6-address2 option, if ip-address1 is higher than ip-address2, the system adjusts the range to [ ip-address2, ip-address1 ].
· The object group to be used must be an IPv6 address object group.
· If the specified object group does not exist, the system creates an IPv6 address object group with the name you specified and uses the object group for the object.
# Configure an IPv6 address object with the host address of 1::1.
[Sysname-obj-grp-ipv6-ipv6group] network host address 1::1
# Configure an IPv6 address object with exact-matching host name pc3.
[Sysname-obj-grp-ipv6-ipv6group] network host name pc3
# Configure an IPv6 address object with fuzzy-matching host name abc.
[Sysname] object-group ipv6 address ipv6group1
[Sysname-obj-grp-ipv6-ipv6group1] network host name *abc*
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24.
[Sysname-obj-grp-ipv6-ipv6group] network subnet 1:1:1::1 24
# Configure an IPv6 address object with the address range of 1:1:1::1 to 1:1:1::100
[Sysname-obj-grp-ipv6-ipv6group] network range 1:1:1::1 1:1:1::100
# Configure an IPv6 address object using object group ipv6group2.
[Sysname-obj-grp-ipv6-ipv6group] network group-object ipv6group2
# Configure an IPv6 address object using user user1 in domain domain1.
[Sysname-obj-grp-ipv6-ipv6group] network user user1 domain domain1
# Configure an IPv6 address object using user group usergroup1 in domain domain1.
[Sysname-obj-grp-ipv6-ipv6group] network user-group usergroup1 domain domain1
Use network exclude to exclude an IPv4 address or a subnet from an address object.
Use undo network exclude to restore the default.
object-id network exclude ip-address
undo object-id network exclude ip-address
No IPv4 address or subnet in an address object is excluded.
context-admin
vsys-admin
object-id: Specifies an address object by its ID in the range of 1 to 4294967294. The specified address object must have been created.
ip-address: Specifies the IPv4 address to be excluded.
You can execute this command multiple times to exclude multiple IPv4 addresses from an address object. Make sure the excluded items do not overlap with each other.
# Configure an IPv4 address object with the IPv4 address of 192.166.0.0 and mask of 255.255.0.0. Exclude IPv4 address 192.166.0.10 and subnet 192.166.1.0/24 from the address object.
[Sysname-obj-grp-ip-ipgroup] 10 network exclude 192.166.0.10
Use network exclude to exclude an IPv6 address or a subnet from an address object.
object-id network exclude ipv6-address
undo object-id network exclude ipv6-address
No IPv6 address or subnet in an address object is excluded.
context-admin
vsys-admin
ip-address: Specifies the IPv6 address to be excluded.
You can execute this command multiple times to exclude multiple IPv6 addresses from an address object. Make sure the excluded items do not overlap with each other.
# Configure an IPv6 address object with the IPv6 address of 1:1:1::1 and prefix length of 24. Exclude IPv6 address 1:1:1::10 and subnet 1:1:1::2:0 with a prefix length of 112 from the address object.
[Sysname-obj-grp-ipv6-ipv6group] 10 network exclude 1:1:1::10
object description
Use object description to configure a description for an object.
Use undo object description to restore the default.
object object-id description text
undo object object-id description
No description is configured for an object.
Object group view
context-admin
vsys-admin
object-id: Specifies an object ID in the range of 0 to 4294967294. The object must already exist.
# Configure the description as This is an IPv4 object 0 for an IPv4 address object.
[Sysname-obj-grp-ip-ipgroup] 0 network host address 1.2.3.4
[Sysname-obj-grp-ip-ipgroup] object 0 description This is a description for object 0
object-group
object-group
Use object-group to create an object group and enter its view, or enter the view of an existing object group.
Use undo object-group to delete an object group.
object-group { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } object-group-name
undo object-group { { ip | ipv6 } { address | address-yundi } | mac-address | port | service | service-yundi } object-group-name
Default object groups exist.
context-admin
vsys-admin
ip address: Creates an IPv4 address object group.
ipv6 address: Creates an IPv6 address object group.
ip address-yundi: Creates an IPv4 address object group for a Yundi network.
ipv6 address-yundi: Creates an IPv6 address object group for a Yundi network.
mac-address: Creates a MAC object group.
port: Creates a port object group.
service: Creates a service object group.
service-yundi: Creates a service object group for a Yundi network.
object-group-name: Specifies an object group name, a case-insensitive string of 1 to 63 characters. The object group name must be globally unique.
The object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system creates a new object group and enters the object group view.
· If the specified group exists but the group type is different from that in the command, the command fails.
The undo object-group command execution results vary with the specified object group.
· If the specified group does not exist, the system executes the command without any system prompt.
· If the specified group exists and the group type is the same as that in the command, the system deletes the group.
· If the specified object group is being used by an ACL or object group, the command fails.
Default object groups cannot be deleted.
Address object groups and service object groups for a Yundi network can only use other existing object groups. You cannot create objects for Yundi address or service object groups.
# Create an IPv4 address object group named ipgroup.
# Create an IPv6 address object group named ipv6group.
# Create a MAC object group named groupmac.
# Create a service object group named servicegroup.
[Sysname] object-group service servicegroup
# Create an IPv4 address object group named ipyundi for a Yundi network.
[Sysname] object-group ip address-yundi ipyundi
# Create an IPv6 address object group named ipv6yundi for a Yundi network.
[Sysname] object-group ipv6 address-yundi ipv6yundi
# Create a service object group named serviceyundi for a Yundi network.
[Sysname] object-group service-yundi serviceyundi
object-group dns-aging
Use object-group dns-aging to enable aging of DNS-resolved IP addresses from host names.
Use undo object-group dns-aging to disable aging of DNS-resolved IP addresses from host names.
object-group dns-aging [ time aging-time ]
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware |
Command compatibility |
CSAP-NTA-100, CSAP-NTA-200, CSAP-NTA-AK375 |
No |
CSAP-NTA-300, CSAP-NTA-400, CSAP-NTA-500, CSAP-NTA-600 |
Yes |
CSAP-NTA-V200, CSAP-NTA-V1000 |
No |
Aging of DNS-resolved IP addresses from host names is disabled.
context-admin
time aging-time: Specifies the aging time in the range of 1 to 70000000 minutes. The default value is 120.
In load balancing scenarios where one host name maps to several IP addresses, DNS-resolved IP address for a host name changes between these mapping addresses. Upon every change, the object group module notifies relevant policies (such as security policy) of the change, which causes policies to submit changes frequently and consumes memory. To resolve this issue, you can enable aging of DNS-resolved IP addresses from host names.
With this feature enabled, the system maintains an IP address group for each host name. If a resolved IP address is not in the group, the system adds the address to the group and notifies relevant policies of the change. If a resolved IP address is in the group, the system does not notify relevant policies.
As a best practice, set the aging time to be longer than the TTL of resolution records on the DNS server.
# Enable aging of DNS-resolved IP addresses from host names and set the aging time to 5 minutes.
[Sysname] object-group dns-aging
[Sysname] object-group dns-aging time 5
object-group rename
Use object-group rename to rename an object group.
object-group rename old-object-group-name new-object-group-name
context-admin
vsys-admin
old-object-group-name: Specifies the name of the object group to be renamed, a case-insensitive string of 1 to 63 characters.
new-object-group-name: Specifies a new name for the object group, a case-insensitive string of 1 to 63 characters. The object group name must be globally unique.
You can only rename non-default object groups.
# Rename object group ipgroup1 to ipgroup2.
[Sysname] object-group rename ipgroup1 ipgroup2
object-group
port (port object group view)
Use port to configure a port object.
Use undo port to delete a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo port { { eq | lt | gt } port | range port1 port2 | group-object object-group-name }
undo object-id
No port objects exist.
Port object group view
context-admin
vsys-admin
eq: Configures a port object with a port number equal to the specified port.
lt: Configures a port object with a port number smaller than the specified port.
gt: Configures a port object with a port number greater than the specified port.
port: Specifies a port number in the range of 0 to 65535.
range port1 port2: Configures a port object with a port range. The value range for the port1 and port2 arguments is 0 to 65535.
group-object object-group-name: Specifies a port object group by its name, a case-insensitive string of 1 to 63 characters.
This command fails if you use it to configure or change a port object to be identical with an existing object.
This command creates a port object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
When you use the lt port option, follow these guidelines:
· The value of port cannot be 0.
· If the value of port is 1, the system configures the object with a port number of 0.
· If the value of port is in the range of 2 to 65535, the system configures the object with a port number range of [0, port–1].
When you use the gt port option, follow these guidelines:
· The value of port cannot be 65535.
· If the value of port is 65534, the system configures the object with a port number of 65535.
· If the value of port is in the range of 0 to 65533, the system configures the object with a port number range of [port+1, 65535].
When you use the range port1 port2 option, follow these guidelines:
· If port1 is equal to port2, the system configures the object with the port number port1.
· If port1 is smaller than port2, the system configures the object with the port number range.
· If port1 is greater than port2, the system changes the range to [port2, port1] and configures the object with the changed port number range.
· If port1 is 0, the range is displayed as lt port2+1.
· If port2 is 65535, the range is displayed as gt port1–1.
· The object group to be used must be a port object group.
· If the specified object group does not exist, the system creates a port object group with the name you specified and uses the object group for the object.
# Configure a port object with a port number of 100.
[Sysname] object-group port portgroup
[Sysname-obj-grp-port-portgroup] port eq 100
# Configure a port object with a port number smaller than 20.
[Sysname-obj-grp-port-portgroup] port lt 20
# Configure a port object with a port number greater than 60000.
[Sysname-obj-grp-port-portgroup] port gt 60000
# Configure a port object with a port number in the range of 1000 to 2000.
[Sysname-obj-grp-port-portgroup] port range 1000 2000
# Configure a port object using object group portgroup2.
[Sysname-obj-grp-port-portgroup] port group-object portgroup2
security-zone
Use security-zone to specify a security zone for an IP address object group.
Use undo security-zone to restore the default.
security-zone security-zone-name
undo security-zone
No security zone is specified for an IP address object group.
context-admin
vsys-admin
security-zone-name: Specifies the security zone name, a case-insensitive string of 1 to 31 characters. The string cannot contain hyphens (-) and cannot be any.
This feature enables fast selection of IP address object groups when you specify IP address filtering criteria for a security policy from the Web interface. If a security policy uses an IP address object group specified with a security zone, you can specify only IP address object groups from the same or no security zone for the policy.
You can specify only one security zone for an IP address object group. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the security zone for IPv4 address object group 1 as Local.
[Sysname] object-group ip address 1
[Sysname-obj-grp-ip-1] security-zone Local
object-group
Use service to configure a service object.
Use undo service to delete a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
undo object-id
No service objects exist.
Service object group view
context-admin
vsys-admin
object-id: Configures an object ID in the range of 0 to 4294967294. If you do not configure an ID for the object, the system automatically assigns the object a multiple of 10 next to the greatest ID being used. For example, if the greatest ID is 22, the automatically assigned ID is 30.
protocol: Configures the protocol number in the range of 0 to 255, or the protocol name such as TCP, UDP, SCTP, ICMP, and ICMPv6.
source: Configures a service object with a source port when the protocol is TCP, UDP, or SCTP.
destination: Configures a service object with a destination port when the protocol is TCP, UDP, or SCTP.
eq: Configures a port equal to the specified port.
lt: Configures a port smaller than the specified port.
gt: Configures a port greater than the specified port.
range port1 port2: Configures a service object with a port range. The value range for the port1 and port2 arguments is 0 to 65535.
icmp-type: Configures the ICMP message type in the range of 0 to 255.
icmp-code: Configures the ICMP message code in the range of 0 to 255.
icmpv6-type: Configures the ICMPv6 message type in the range of 0 to 255.
icmpv6-code: Configures the ICMPv6 message code in the range of 0 to 255.
group-object object-group-name: Specifies a service object group by its name, a case-insensitive string of 1 to 31 characters.
This command fails if you use it to configure or change a service object to be identical with an existing object.
This command creates a service object if the specified object ID does not exist. Otherwise, the command overwrites the configuration of the specified object.
· If the value of port is in the range of 1 to 65535, the system configures the object with a port number range of [0, port–1].
· If the value of port is in the range of 0 to 65534, the system configures the object with a port number range of [port+1, 65535].
When you use the range port1 port2 option, if port1 is greater than port2, the system changes the range to [port2, port1].
When use the group-object object-group-name option, follow these guidelines:
· The object group to be used must be a service object group.
· If the specified object group does not exist, the system creates a service object group with the name you specified and uses the object group for the object.
# Configure a service object with a protocol number of 100.
[Sysname-obj-grp-service-servicegroup] service 100
# Configure a service object with the source and destination port numbers for the TCP service.
[Sysname-obj-grp-service-servicegroup] service tcp source eq 100 destination range 10 100
# Configure a service object with the message type and code for the ICMP service.
[Sysname-obj-grp-service-servicegroup] service icmp 100 150
# Configure a service object using object group servicegroup2.
[Sysname-obj-grp-service-servicegroup] service group-object servicegroup2
yundi alias
Use yundi alias to specify an alias and tenant ID for an object group in a Yundi network.
Use undo yundi alias to restore the default.
yundi alias alias tenant tenant-id
undo yundi alias alias tenant tenant-id
The alias and tenant ID are not specified.
Object group view
context-admin
vsys-admin
alias: Specifies the object group alias, a case-insensitive string of 1 to 63 characters.
tenant tenant-id: Specifies the object group tenant ID, a case insensitive string of 1 to 63 characters.
In a Yundi network, the tenant specifies an alias and tenant ID on the controller at object group creation, and then the controller deploys the alias and tenant ID to devices. As a best practice, do not perform this task manually on devices.
# Specify alias alias1 and tenant ID tenant1 for IPv4 address object group ipgroup.
[Sysname-obj-grp-ip-ipgroup] yundi alias alias1 tenant tenant1
