- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Web caching commands
- 23-STUN commands
13-UDP helper commands | 78.10 KB |
UDP helper commands
display udp-helper interface
Use display udp-helper interface to display information about broadcast to unicast conversion by UDP helper on an interface.
display udp-helper interface interface-type interface-number
This command displays information about destination servers and total number of unicast packets converted from UDP broadcast packets by UDP helper.
# Display information about broadcast to unicast conversion by UDP helper on GigabitEthernet 1/0/1.
<Sysname> display udp-helper interface gigabitethernet 1/0/1
Interface Server VPN instance Server address Packets sent
GigabitEthernet1/0/1 N/A 192.1.1.2 0
Interface name. |
Server VPN instance |
VPN instance to which the destination server belongs. |
Server address |
Destination server to which UDP packets are forwarded. |
Packets sent |
Number of unicast packets that are converted from broadcast packets by UDP helper. |
reset udp-helper statistics
udp-helper server
Use reset udp-helper statistics to clear statistics about broadcast to unicast conversion by UDP helper.
# Clear the statistics about broadcast to unicast conversion by UDP helper.
<Sysname> reset udp-helper statistics
udp-helper broadcast-map
Use udp-helper broadcast-map to specify a multicast address for UDP helper to convert broadcast to multicast.
Use undo udp-helper broadcast-map to restore the default.
udp-helper broadcast-map multicast-address [ acl acl-number ]
undo udp-helper broadcast-map multicast-address
No multicast address is specified for UDP helper to convert broadcast to multicast.
Interface view
multicast-address: Specifies the destination multicast address to which the destination broadcast address is converted.
acl acl-number: Specifies an ACL by its number. The ACL filters incoming broadcast packets for UDP helper. Packets permitted by the ACL can be converted. If no ACL is specified, all incoming broadcast packets are checked for UDP helper. If you specify an ACL, the display acl command does not display the ACL match count to avoid device performance degradation.
· For a basic ACL, the value range is 2000 to 2999.
· For an advanced ACL, the value range is 3000 to 3999.
Use this command on the interface that receives broadcast packets.
You can configure a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets.
# Configure UDP helper to convert received broadcast packets on GigabitEthernet 1/0/1 to multicast packets destined for 225.0.0.1.
[Sysname-GigabitEthernet1/0/1] udp-helper broadcast-map 225.0.0.1
udp-helper enable
Use udp-helper enable to enable UDP helper.
Use undo udp-helper enable to disable UDP helper.
udp-helper enable
UDP helper is disabled.
For UDP helper to take effect on an interface, make sure the following conditions are met:
· UDP helper is enabled.
· A UDP port number is specified by using the udp-helper port command.
· Packet conversion for UDP helper is configured on the interface.
# Enable UDP helper.
[Sysname] udp-helper enable
udp-helper port
udp-helper server
udp-helper multicast-map
Use udp-helper multicast-map to map a multicast address to a directed broadcast or a unicast address for UDP helper.
Use undo udp-helper multicast-map to restore the default.
udp-helper multicast-map multicast-address ip-address [ global | vpn-instance vpn-instance-name ] [ acl acl-number ]
undo udp-helper multicast-map multicast-address ip-address [ global | vpn-instance vpn-instance-name ]
No address mapping is specified for UDP helper to convert multicast to broadcast or unicast.
Interface view
multicast-address: Specifies the destination address of the multicast packets.
ip-address: Specifies a unicast address or a directed broadcast address to which a destination multicast address is converted.
global: Forwards converted packets on the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the destination unicast or broadcast address belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters.
acl acl-number: Specifies an ACL by its number. The ACL filters incoming multicast packets. Packets permitted by the ACL can be converted. If no ACL is specified, all incoming multicast packets are checked for UDP helper. If you specify an ACL, the display acl command does not display the ACL match count to avoid device performance degradation.
Use this command on the interface that receives multicast packets.
If the global keyword and a VPN instance are not specified, UDP helper forwards converted packets in the VPN bound to the interface that receives multicast packets. If the interface is not bound to any VPNs, UDP helper forwards the converted packets on the public network.
You can map one multicast address to a maximum of 16 broadcast and unicast addresses. The packets destined for the multicast address are forwarded to all mapping addresses.
# Configure UDP helper to convert the multicast packets destined for 225.0.0.1 to broadcast packets destined for 192.168.1.255.
[Sysname-GigabitEthernet1/0/1] udp-helper multicast-map 225.0.0.1 192.168.1.255
# Configure UDP helper to convert the multicast packets destined for 225.0.0.1 to unicast packets destined for 192.168.1.3 in VPN instance a.
[Sysname-GigabitEthernet1/0/1] udp-helper multicast-map 225.0.0.1 192.168.1.3 vpn-instance a
udp-helper port
Use udp-helper port to specify a UDP port number for UDP helper.
Use undo udp-helper port to remove UDP port numbers.
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
No UDP port numbers are specified for UDP helper.
port-number: Specifies a UDP port number in the range of 1 to 65535 (except 67 and 68).
dns: Specifies the UDP port 53 used by DNS packets.
netbios-ds: Specifies the UDP port 138 used by NetBIOS distribution service packets.
netbios-ns: Specifies the UDP port 137 used by NetBIOS name service packets.
tacacs: Specifies the UDP port 49 used by TACACS packets.
tftp: Specifies the UDP port 69 used by TFTP packets.
time: Specifies the UDP port 37 used by time protocol packets.
Upon receiving a UDP broadcast or multicast packet, UDP helper uses the specified UDP ports to match the UDP destination port number of the packet.
To specify a UDP port, you can specify the port number or the protocol keyword. For example, udp-helper port 53 and udp-helper port dns specify the same UDP port.
You can specify a maximum of 256 UDP ports on a device.
# Specify the UDP port 100 for UDP helper.
[Sysname] udp-helper port 100
udp-helper server
Use udp-helper server to specify a destination server for UDP helper to convert broadcast to unicast.
Use undo udp-helper server to remove a destination server.
udp-helper server ip-address [ global | vpn-instance vpn-instance-name ]
undo udp-helper server [ ip-address [ global | vpn-instance vpn-instance-name ] ]
No destination server is specified for UDP helper to convert broadcast to unicast.
Interface view
ip-address: Specifies the IP address of a destination server, in dotted decimal notation.
global: Forwards converted unicast packets to the server on the public network.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance to which the server belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters.
Specify destination servers on an interface that receives UDP broadcast packets. If the packets' destination UDP port numbers match the UDP helper ports, UDP helper forwards the broadcasts to the specified servers.
You can specify a maximum of 20 unicast and multicast addresses for UDP helper to convert broadcast packets on an interface.
If you do not specify the ip-address argument, the undo udp-helper server command removes all destination servers on the interface.
A destination server with the global keyword and the same destination server with the vpn-instance vpn-instance-name option do not overwrite each other. If you specify only the IP address, UDP helper forwards converted unicast packets in the VPN to which the receiving interface belongs. If the interface is not bound to any VPN instance, UDP helper forwards the unicast packets on the public network.
# Specify the destination server 192.1.1.2 for UDP helper to convert broadcast to unicast on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] udp-helper server 192.1.1.2
# Specify the destination server 192.1.1.2 in VPN instance a for UDP helper to convert broadcast to unicast on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] udp-helper server 192.1.1.2 vpn-instance a
