- 07-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-IP addressing commands
- 03-DHCP commands
- 04-DNS commands
- 05-NAT commands
- 06-NAT66 commands
- 07-IP forwarding basics commands
- 08-Fast forwarding commands
- 09-Multi-CPU packet distribution commands
- 10-Adjacency table commands
- 11-IRDP commands
- 12-IP performance optimization commands
- 13-UDP helper commands
- 14-IPv6 basics commands
- 15-DHCPv6 commands
- 16-IPv6 fast forwarding commands
- 17-AFT commands
- 18-Tunneling commands
- 19-GRE commands
- 20-ADVPN commands
- 21-WAAS commands
- 22-Web caching commands
- 23-STUN commands
10-Adjacency table commands | 72.72 KB |
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
IPv4 adjacency table commands
display adjacent-table
Use display adjacent-table to display IPv4 adjacency entries.
In standalone mode:
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
In IRF mode:
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | chassis chassis-number slot slot-number } [ count | verbose ]
View
all: Displays all IPv4 adjacency entries.
physical-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified routing interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4 adjacency entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4 adjacency entries for all cards. (In IRF mode.)
count: Displays the number of IPv4 adjacency entries.
verbose: Displays detailed information about IPv4 adjacency entries.
# Display detailed information about all IPv4 adjacency entries.
<Sysname> display adjacent-table all verbose
IP address : 0.0.0.0
Routing interface : Tunnel1
Physical interface : Tunnel1
Logical interface : N/A
Service type : Tunnel
Action type : Forwarding
Link media type : P2P
Slot : 0
Cpu : 0
VPN index : 0
Virtual circuit information : N/A
Link head information(IP) : 4500000000000000ff2f000002020201020202020000
0800
Link head information(MPLS) : 4500000000000000ff2f000002020201020202020000
0800
# Display IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1
IP address Routing interface Physical interface Type
0.0.0.0 Tun1 Tun1 Tunnel
# Display the number of IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1 count
Total entries on slot 1: 1
IP address |
IP address of the next hop. · For a P2P link, the IP address of the next hop is not needed. This field displays 0.0.0.0. · For an NBMA link, the value 0.0.0.0 indicates the default adjacency entry. Packets are forwarded through the default virtual circuit. |
Routing interface |
Output interface of the matching route entry. |
Physical interface |
Physical interface of which the outgoing packets are sent out. |
Logical interface |
Logical interface for sending the packets. If the entry has no logical interface, this field displays N/A. |
Service type/Type |
Link layer protocol type. |
Action type |
Packet processing type, Forwarding or Drop. |
Link media type |
Link media type: · P2P—Point-to-point link. · NBMA—Non-broadcast multi-access link. |
Cpu |
This field is not supported in the current software version. Number of the CPU. |
VPN index |
Index of the VPN. |
Virtual circuit information |
Information about the virtual circuit, such as PVC or DLCI. If the entry has no virtual circuit, this field displays N/A. |
Link head information(IP) |
Link layer header for IPv4. |
Link head information(MPLS) |
Link layer header for MPLS. |
IPv6 adjacency table commands
display ipv6 adjacent-table
Use display ipv6 adjacent-table to display IPv6 adjacency entries.
In standalone mode:
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
In IRF mode:
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | chassis chassis-number slot slot-number } [ count | verbose ]
all: Displays all IPv6 adjacency entries.
physical-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified routing interface.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 adjacency entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 adjacency entries for all cards. (In IRF mode.)
count: Displays the number of IPv6 adjacency entries.
verbose: Displays detailed information about IPv6 adjacency entries.
# Display detailed information about all IPv6 adjacency entries.
<Sysname> display ipv6 adjacent-table all verbose
IPv6 address : N/A
Slot : 1
Cpu : 0
VPN index : 0
Link head information(IPv6) : 4500000000000000ff2f000002020201020202020000
86dd
86dd
# Display IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1
IPv6 address Routing interface Physical interface Type
N/A Tun1 Tun1 Tunnel
# Display the number of IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1 count
IPv6 address |
IPv6 address of the next hop. · For a P2P link, the IPv6 address of the next hop is not needed. This field has the value 0::0, and displays N/A. · For an NBMA link, the value 0.0.0.0 indicates a default adjacency table. Packets are forwarded through the default virtual circuit. |
Routing interface |
Logical interface |
Logical interface that sends the packets. If the entry has no logical interface, this field displays N/A. |
Service type/Type |
Action type |
Link media type |
Cpu |
VPN index |
Index of the VPN. |
Link head information(IPv6) |
Link layer header for IPv6. |
