07-Layer 3—IP Services Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10107-Layer 3—IP Services Command Reference
04-DNS commands
04-DNS commands 315.23 KB
DNS commands
description
Use description to configure a description for a DNS server group.
No description is configured for a DNS server group.
DNS server group view
text: Specifies a description, a case-insensitive string of 1 to 255 characters.
# Configure the description as office for DNS server group 1.
[Sysname] dns server-group 1
[Sysname-dns-server-group-1] description office
dns server-group
display dns domain
Use display dns domain to display the domain name suffixes.
display dns domain [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays the domain name suffixes dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained domain name suffixes.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name suffixes for the public network.
# Display the statically configured and dynamically obtained domain name suffixes for the public network.
<Sysname> display dns domain
Type:
  D: Dynamic    S: Static
No.    Type   Domain suffix
1      S      com
2      D      net
No.
Sequence number.
Domain name suffix type:
·     S—A statically configured domain name suffix.
·     D—A domain name suffix dynamically obtained through DHCP or other protocols. ‌
Domain suffix
Domain name suffixes.
dns domain
display dns host
Use display dns host to display information about domain name-to-IP address mappings.
display dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
ip: Specifies type A queries. A type A query resolves a domain name to the mapped IPv4 address.
ipv6: Specifies type AAAA queries. A type AAAA query resolves a domain name to the mapped IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays domain name-to-IP address mappings for the public network.
If you do not specify the ip or ipv6 keyword, this command displays domain name-to-IP address mappings of all query types.
# Display domain name-to-IP address mappings of all query types.
<Sysname> display dns host
Type:
Total number: 3
No.  Host name           Interface    Type  TTL      QType  IP addresses
1    sample.com                       D     3132     A      192.168.10.1
                                                            192.168.10.2
                                                            192.168.10.3
2    zig.sample.com                   S     -        A      192.168.1.1
3    sample.net                       S     -        AAAA   FE80::4904:4448
No.
Sequence number.
Host name
Domain name.
Name of the output interface. If you do not specify an output interface by using the direct interface command, this field displays a hyphen (-).For more information about the direct interface command, see RIR commands in Layer 3—IP Services Command Reference.
Domain name-to-IP address mapping type:
·     S—A static mapping configured by the ip host or ipv6 host command.
·     D—A mapping dynamically obtained through dynamic domain name resolution. ‌
TTL
Time in seconds that a mapping can be stored in the cache.
For a static mapping, a hyphen (-) is displayed.
Query type
Query type: A and AAAA.
IP addresses
Replied IP address:
·     For a type A query, the replied IP address is an IPv4 address.
·     For a type AAAA query, the replied IP address is an IPv6 address.
ip host
ipv6 host
reset dns host
display dns server
Use display dns server to display IPv4 DNS server information.
display dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv4 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays statically configured and dynamically obtained IPv4 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv4 DNS server information for the public network.
# Display IPv4 DNS server information for the public network.
<Sysname> display dns server
Type:
No. Type  IP address
1   S     202.114.0.124
2   S     169.254.65.125
No.
Sequence number.
DNS server type:
·     S—A manually configured DNS server.
·     D—DNS server information dynamically obtained through DHCP or other protocols. ‌
IP address
IPv4 address of the DNS server.
dns server
display dns server health status
Use display dns server health status to display health status of DNS servers.
# Display health status of DNS servers.
<Sysname> display dns server health status
No. DNS server           OutInterface     VPN name                        Status
1   1.1.1.1              -                vpn1                            Up
2   2::1                 -                                                Up
3   FE80::1              -                vpn1                            Up
No.
Sequence number.
DNS server
Address of the DNS server.
OutInterface
Output interface of the DNS server.
This field is displayed only when the DNS server address is a local IPv6 link address.
VPN name
VPN instance name. If this field is empty, the domain name rule is on the public network.
Status
Result of the health check:
·     Up—The DNS server is available.
·     Down—The DNS server is unavailable.
health-check enable
display ipv6 dns server
Use display ipv6 dns server to display IPv6 DNS server information.
display ipv6 dns server [ dynamic ] [ vpn-instance vpn-instance-name ]
dynamic: Displays IPv6 DNS server information dynamically obtained through DHCP or other protocols. If you do not specify this keyword, the command displays the statically configured and dynamically obtained IPv6 DNS server information.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 DNS server information for the public network.
# Display IPv6 DNS server information for the public network.
<Sysname> display ipv6 dns server
Type:
No. Type  IPv6 address                             Outgoing Interface
1   S     2::2
Table 5 Command output
No.
Sequence number.
DNS server type:
IPv6 address
IPv6 address of the DNS server.
Outgoing Interface
Output interface.
ipv6 dns server
dns cache ttl
Use dns cache ttl to set the TTL value for DNS entries.
Use undo dns cache ttl to cancel the TTL configuration for DNS entries.
dns cache ttl { maximum max-value | minimum min-value } *
undo dns cache ttl [ maximum | minimum ]
The TTL value for DNS entries is the TTL value in the DNS reply.
maximum max-value: Specifies the maximum TTL value for DNS entries, in the range of 60 to 3600 seconds.
minimum min-value: Specifies the minimum TTL value for DNS entries, in the range of 60 to 3600 seconds. The value for the min-value argument must be smaller than that for the max-value argument.
The device periodically sends a DNS request to the DNS server according to the TTL for DNS entries, which consumes CPU resources. If the TTL value is too small, the device sends DNS requests frequently to the DNS server, which consumes more CPU resources. If the TTL value is too large, DNS mappings cannot be updated in time. To avoid such issues, you can use this command to set the TTL value for DNS entries.
By default, the DNS client obtains the TTL for the following DNS entries from the DNS reply:
·     DNS entries generated from transparent DNS proxy.
·     DNS entries generated from DNS snooping.
·     Dynamic domain name resolution cache generated from the DNS server/DNS server group.
After you set the TTL value for DNS entries, the device specifies the TTL for DNS entries as follows:
·     If the TTL value in the DNS reply is smaller than the minimum TTL value, the device uses the minimum TTL value as the TTL for DNS entries. If the TTL value is greater than or equal to the minimum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
·     If the TTL value in the DNS reply is greater than the maximum TTL value, the device uses the maximum TTL value as the TTL for DNS entries. If the TTL value is smaller than or equal to the maximum TTL value, the device uses the TTL value in the DNS reply as the TTL for DNS entries.
After you execute this command, the configuration only takes effect on the subsequent DNS entries generated from transparent DNS proxy, DNS snooping, and DNS server/DNS server group.
After you execute the undo dns cache ttl command, the current TTL for the existing DNS entries still works.
If you do not specify any keywords when you execute the undo dns cache ttl command, this command cancels all TTL configuration for DNS entries.
If you execute the dns cache ttl minimum, dns cache ttl maximum, or dns cache ttl minimum maximum command multiple times, the most recent configuration takes effect.
# Set the maximum TTL value for DNS entries to 3600 seconds and the minimum TTL value for DNS entries to 180 seconds.
[Sysname] dns cache ttl maximum 3600 minimum 180
dns server
dns server-group
dns snooping enable
dns transparent-proxy enable
dns domain
Use dns domain to configure a domain name suffix.
Use undo dns domain to delete the specified domain name suffix.
dns domain domain-name [ vpn-instance vpn-instance-name ]
undo dns domain domain-name [ vpn-instance vpn-instance-name ]
No domain name suffix is configured. Only the provided domain name is resolved.
domain-name: Specifies a domain name suffix. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, example.com. The domain name suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To configure a domain name suffix for the public network, do not specify this option.
For domain name resolution, the resolver automatically uses the suffix list to supply the missing part of an incomplete name entered by a user.
A domain name suffix applies to both IPv4 DNS and IPv6 DNS.
The system allows a maximum of 16 domain name suffixes for the public network or each VPN instance. You can specify domain name suffixes for both public network and VPN instances.
# Configure domain name suffix com for the public network.
[Sysname] dns domain com
display dns domain
dns domain-name-group
Use dns domain-name-group to create a domain name group and enter its view, or enter an existing domain name group view.
Use undo dns domain-name-group to delete a domain name group.
dns domain-name-group group-name
undo dns domain-name-group group-name
The system has default domain name group any.
group-name: Specifies the name of a domain name group, a case-insensitive string of 1 to 31 characters.
Application scenarios
When the device uses domain name rules to match DNS queries, you can associate a domain name rule with a domain name group to simplify configuration. When multiple domain names are to be matched, you do not need to configure domain name rules multiple times.
Operating mechanism
After adding domain names or subdomain names to a domain name group, you can associate it with a domain name rule to enable the device to distribute DNS queries based on the matching results. To add domain names or subdomain names to a domain name group, use the domain-name or subdomain-name command, respectively.
The relationship between a domain name rule and its associated domain name groups include the following types:
·     Include the domain name group—The device matches the domain name in a query against the domain names in the domain name groups. The match succeeds if the domain name in the query matches any domain name in a group.
If the domain name rule includes default domain name group any, any domain name can match the rule.
·     Exclude the domain name group—The device matches the domain name in a query against the domain names in the domain name groups. The match succeeds only when the domain name in the query does not match any domain name in the domain name groups.
If the domain name rule includes default domain name group any, no domain names can match the rule.
The default domain name group cannot be manually created or deleted.
You can execute this command multiple times to create multiple domain name groups. The maximum number of domain name groups that can be created varies by device.
Do not delete domain name groups referenced by domain name rules.
# Create a domain name group named 1 and enter its view.
[Sysname] dns domain-name-group 1
[Sysname-domain-name-group-1]
dns domain-rule
domain-name
subdomain-name
dns domain-rule
Use dns domain-rule to configure a domain name rule.
Use undo dns domain-rule to delete a domain name rule.
dns domain-rule rule-id { domain-name domain-name | [ exclude ] domain-name-group group-name | subdomain-name subdomain-name } [ vpn-instance vpn-instance-name ] server-group group-id
undo dns domain-rule rule-id [ domain-name domain-name | [ exclude ] domain-name-group group-name | subdomain-name subdomain-name ]
No domain name rule is configured.
rule-id: Specifies the ID of a domain name rule. The value range is 1 to 16.
domain-name domain-name: Specifies a domain name. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, www.example.com. The domain name can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
exclude: Matches a DNS query when the domain name in the query is not in the domain name group. If you do not specify this keyword, the domain name rule matches a DNS query when the domain name in the query is in the domain name group.
domain-name-group domain-group-name: Specifies a domain name group associated with the domain name rule. domain-group-name specifies the name of the domain name group. The name is a case-insensitive string of 1 to 31 characters. Make sure the specified domain name group already exists.
subdomain-name subdomain-name: Specifies a subdomain name. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), dots (.), and asterisk (*). The domain name suffix can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the DNS client that sends DNS queries belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the DNS client belongs to the public network, do not specify this option.
server-group group-id: Specifies the ID of a DNS server group, in the range of 1 to 16. The DNS server group must already exist.
In some scenarios, to have the device (the DNS client or DNS proxy) to send a DNS query to the designated DNS server based on the domain name in the received DNS query, create a DNS server group and domain name rule on the device.
Operating mechanism
Upon receiving a DNS query from a user on the public network or in a VPN instance, a DNS client identifies whether corresponding local domain name cache exists. If no local domain name cache exists, it looks up the domain name rules on the public network or in the VPN instance for a match.
·     If a match is found, the DNS client forwards the query to the DNS servers in the DNS server group bound to the rule.
·     If no match is found, the DNS client does not forward the query to any DNS servers in the DNS server group bound to the rule.
A domain name rule can be matched by using one of the following methods:
·     Exact match—The match succeeds only when the domain name in the query is exactly the same as a domain name in the rule.
·     Fuzzy match—The match succeeds if the domain name in the query contains a subdomain name. When you specify a subdomain name in a rule, do not include an asterisk (*).
A domain name rule is uniquely identified by its ID and VPN instance. When you configure a domain name rule, follow these guidelines:
·     A domain name rule can be bound to only one DNS server group.
·     A domain name rule can be bound to a maximum of eight domain name groups. Do not configure both the including the domain name group and excluding the domain name group matching methods for the same rule.
·     For one domain name rule, you can repeat this command to bind a maximum of eight domain names and subdomain names to the same DNS server group.
·     After you associate a domain name rule with a domain name group, do not configure the domain name or subdomain name matching method for the rule. After you configure the domain name or subdomain name matching method for a domain name rule, do not associate the rule with a domain name group.
·     To delete a domain name or subdomain name, execute the undo dns domain-rule command and specify the domain-name domain-name or subdomain-name subdomain-name option. To disassociate a domain name group from a domain name rule, execute the undo dns domain-rule command and specify the exclude domain-name-group domain-group-name or domain-name-group domain-group-name option. To delete a rule, do not specify any domain name.
·     A user query can match only domain name rules that are in the same VPN instance or on the public network as the user.
·     A domain name rule and its bound DNS server group can be in different VPN instances, or one can be in a VPN instance and the other on the public network.
# Create domain name rule 1 and bind subdomain name example.com and domain name www.ddeeff.com to DNS server group 1.
[Sysname] dns domain-rule 1 subdomain-name example.com server-group 1
[Sysname] dns domain-rule 1 domain-name www.ddeeff.com server-group 1
# Create domain name rule 1, associate domain name group group1 with the rule, and bind DNS server group 1 to the rule.
[Sysname] dns domain-name-group group1
[Sysname-dns-domain-name-group-group1] domain-name www.example.com
[Sysname-dns-domain-name-group-group1] subdomain-name example.com
[Sysname-dns-domain-name-group-group1] quit
[Sysname] dns domain-rule 1 domain-name-group group1 server-group 1
dns server-group
dns dscp
Use dns dscp to set the DSCP value for DNS packets sent by a DNS client or DNS proxy.
Use undo dns dscp to restore the default.
dns dscp dscp-value
undo dns dscp
The DSCP value is 0 in DNS packets sent by a DNS client or DNS proxy.
dscp-value: Specifies the DSCP value in the range of 0 to 63.
The DSCP value of a packet specifies the priority level of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
# Set the DSCP value to 30 for outgoing DNS packets.
[Sysname] dns dscp 30
dns fast-reply enable
Use dns fast-reply enable to enable DNS fast-reply.
Use undo dns fast-reply enable to disable DNS fast-reply.
DNS fast-reply is disabled.
As DNS fast-reply can process a large number of DNS requests per second, use this feature in scenarios that require high DNS packet processing performance.
With this feature enabled, the device monitors the received DNS requests (only UDP packets are supported in the current software version). Then, it resolves the domain names in the requests, and searches for a match in the local static domain name resolution table.
·     If a match is found, the device sends a DNS reply to the DNS client.
·     If no match is found, the device forwards the query to the DNS server.
This command enables both IPv4 DNS fast-reply and IPv6 DNS fast-reply.
The dns fast-reply enable and dns transparent-proxy enable commands are mutually exclusive. After one command is executed, the other command cannot be executed.
# Enable DNS fast-reply.
[Sysname] dns fast-reply enable
dns filter
Use dns filter to enable DNS filtering and add a host name to the denylist or allowlist.
Use undo dns filter to disable DNS filtering and delete a host name from the denylist or allowlist.
dns filter { allowlist | denylist } hostname
undo dns filter { allowlist | denylist } hostname
DNS filtering is disabled.
allowlist: Adds a host name to the allowlist.
denylist: Adds a host name to the denylist.
hostname: Specifies a host name, a case-insensitive string of 1 to 253 characters. The string can contain letters, digits, hyphens (-), underscores (_), and dots (.). This argument supports fuzzy match by adding a wildcard (*) to the host name. For example, to match a host name including abc, specify the hostname argument as *abc*, *abc, or abc*. To exactly match a host name, do not add the wildcard (*).
The DNS proxy uses DNS filtering to filter DNS requests as follows:
·     If the allowlist has a matching host name or the denylist does not have any matching host name with the domain name in the received DNS request, the DNS proxy forwards the request. Upon receiving a DNS reply, the DNS proxy records the DNS mapping and forwards the reply to the DNS client.
·     If the denylist has a matching host name or the allowlist does not have any matching host name with the domain name in the received DNS request, the DNS proxy discards the DNS request.
To implement a strict access control, use an allowlist to filter DNS requests. To implement a loose access control, use a denylist to filter DNS requests.
To add multiple host names to the allowlist or denylist, repeat this command. However, a host name cannot be added to both the denylist and allowlist.
# Enable DNS filtering and add the host names containing .abc to the allowlist.
[Sysname] dns filter allowlist *.abc
dns proxy enable
Use dns proxy enable to enable DNS proxy.
Use undo dns proxy enable to disable DNS proxy.
dns proxy enable
DNS proxy is disabled.
This configuration applies to both IPv4 DNS and IPv6 DNS.
# Enable DNS proxy.
[Sysname] dns proxy enable
dns redirect enable
Use dns redirect enable to enable DNS redirection.
Use undo dns redirect enable to disable DNS redirection.
dns redirect enable
DNS redirection is disabled.
With DNS redirection enabled, the device monitors the received DNS requests (only UDP packets are supported in the current software version) and resolves the source IP addresses, source port numbers, and domain names. Then, the device searches for a matching domain name rule and redirects the request to the DNS server in the rule.
The device enabled with DNS redirection works as follows:
1.     The device searches for a matching domain name rule.
¡     If a match is found, it replaces the destination IP address in the request with the IP address of the first reachable DNS server in the server group bound to the rule. Then, the device forwards the request to the DNS server.
¡     If no match is found, the device does not redirect the DNS request.
2.     The device records the replacement, including the source IP address, source port number, and requested server address in the DNS request, and the replaced server address
3.     Upon receiving the DNS reply, the device replaces the source IP address in the reply with the original server address in the request.
This configuration applies to both IPv4 DNS redirection and IPv6 DNS redirection.
The dns redirect enable and dns transparent-proxy enable commands are mutually exclusive. After one command is executed, the other command cannot be executed.
# Enable DNS redirection.
[Sysname] dns redirect enable
dns server
Use dns server to specify the IPv4 address of a DNS server.
Use undo dns server to remove the IPv4 address of a DNS server.
dns server ip-address [ vpn-instance vpn-instance-name ] [ priority priority-value ]
undo dns server [ ip-address ] [ vpn-instance vpn-instance-name ]
No DNS server IPv4 address is specified.
Interface view
ip-address: Specifies the IPv4 address of a DNS server. When you execute the undo form of the command in interface view, you must specify this argument.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv4 address for the public network, do not use this option.
priority priority-value: Specifies the DNS server priority. The value range for the priority-value argument is 1 to 255 and the default is 100. A smaller value indicates a higher priority.
Operating mechanism
The device sends a DNS query request to the DNS servers in descending order of their priorities. If they have the same priority, the device sends the DNS query request to the DNS servers in ascending order of their IPv4 addresses. You can edit the priority of DNS servers to change the DNS query request sending order.
The system allows a maximum of six DNS server IPv4 addresses for the public network or each VPN instance. You can specify DNS server IPv4 addresses for both public network and VPN instances.
If you do not specify an IPv4 address, the undo dns server command removes all DNS server IPv4 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv4 address 172.16.1.1.
[Sysname] dns server 172.16.1.1
# Specify DNS server IPv4 address 172.16.1.1 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] dns server 172.16.1.1
display dns server
dns server (DNS server group view)
Use dns server to add an IPv4 DNS server to the DNS server group.
Use undo dns server to remove IPv4 DNS servers from the DNS server group.
dns server ip-address [ priority priority-value ]
No DNS servers exist in a DNS server group.
Operating mechanism
The device sends a DNS query to DNS servers of the DNS server group in descending order of their priorities. If they have the same priority, the device sends the DNS query to the DNS servers in the same order as the order displayed in the display this command output for the group. You can edit the priority of DNS servers to change the DNS query sending order.
A DNS server group supports a maximum of six IPv4 DNS server addresses.
If you do not specify the ip-address argument, the undo dns server command deletes all IPv4 addresses in the DNS server group.
# Add DNS server 172.16.1.1 to DNS server group 1.
[Sysname-dns-server-group-1] dns server 172.16.1.1
dns server-group
Use dns server-group to create a DNS server group and enter its view, or enter the view of an existing DNS server group.
Use undo dns server-group to delete the specified DNS server group.
dns server-group group-id [ vpn-instance vpn-instance-name ]
undo dns server-group group-id
No DNS server group exists.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the DNS server group belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the DNS server group is on the public network.
To allow the device to send queries to specific DNS servers, add the DNS servers to a DNS server group and bind the group to domain names in a domain name rule. When the device receives a user query and fails to find a local matching DNS entry, the device determines whether a matching domain name rule exists in the same VPN instance or on the public network as the user. If a matching rule exists, the device forwards the query to DNS servers in the DNS server group bound to the rule. If no matching rule exists, the device does not forward the query to DNS servers in DNS server groups.
# Create DNS server group 1.
description
dns domain-rule
dns snooping enable
Use dns snooping enable to enable DNS snooping.
Use undo dns snooping enable to disable DNS snooping.
dns snooping enable
DNS snooping is disabled.
DNS snooping is applicable to scenarios that use domain name-based policies (such as security policies and bandwidth policies). In such a scenario, the device requires the resolved IP addresses for traffic filtering. Enabled with DNS snooping, the device monitors received DNS requests and replies, and works as follows:
·     If the domain name in a DNS request matches a policy, the device records the DNS mapping after receiving the DNS reply, and reports the mapping to the policy for traffic filtering.
·     If the domain name does not match a policy, the device does not record the DNS mapping.
DNS snooping is only applicable to Layer 3 services. Layer 2 forwarding services belonging to the same VLAN on the device do not support this feature.
DNS snooping works only between the DNS client and DNS server, or the DNS client and DNS proxy.
The DNS snooping and transparent DNS proxy features cannot be both configured.
The DNS snooping feature cannot be used across VPNs. Make sure the input and output interfaces of DNS packets on the device belong to the same VPN.
# Enable DNS snooping.
[Sysname] dns snooping enable
dns snooping log enable
Use dns snooping log enable to enable DNS snooping logging.
Use undo dns snooping log enable to disable DNS snooping logging.
DNS snooping logging is disabled.
The DNS proxy searches the static domain name resolution table and dynamic domain name resolution cache after receiving a request.
·     If the requested information is found, the DNS proxy returns a DNS reply to the client.
·     If the requested information is not found, the DNS proxy sends the request to the designated DNS server.
Too many requests received at the same time will increase network load and affect the performance of the DNS proxy and DNS server.
To avoid this issue, you can configure DNS snooping on the device between the DNS client and DNS proxy, or the DNS client and DNS server. Also, you can configure the device to generate and send DNS snooping logs to the fast log module. The administrator can locate and troubleshoot issues based on the logs. For information about the fast log output function, see Network Management and Monitoring Configuration Guide.
# Enable DNS snooping logging.
[Sysname] dns snooping log enable
dns snooping rate-limit
Use dns snooping rate-limit to configure a rate limit for incoming DNS packets on interfaces.
Use undo dns snooping rate-limit to disable DNS snooping packet rate limit.
dns snooping rate-limit rate
The rate of incoming DNS packets is not limited.
rate: Specifies the maximum rate in pps. The value range for the rate argument is 64 to 512. Usage guidelines
An interface will discard DNS packets exceeding the specified rate limit.
This command takes effect only when the DNS snooping logging feature or transparent DNS proxy feature is enabled.
# Set the DNS packet rate limit to 64 pps.
[Sysname] dns snooping rate-limit 64
dns source-interface
Use dns source-interface to specify the source interface for DNS packets.
Use undo dns source-interface to restore the default.
dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
undo dns source-interface interface-type interface-number [ vpn-instance vpn-instance-name ]
No source interface is specified for DNS packets. The device uses the primary IP address of the output interface of the matching route as the source IP address for a DNS request.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a source interface for the public network, do not use this option.
This configuration applies to both IPv4 and IPv6.
In IPv4 DNS, the device uses the primary IPv4 address of the specified source interface as the source IP address of a DNS query. In IPv6 DNS, the device selects an IPv6 address of the specified source interface as the source IP address of a DNS query. The method of selecting the IPv6 address is defined in RFC 3484.
The system allows only one source interface for the public network or each VPN instance. If you execute this command multiple times, the most recent configuration takes effect. You can specify source interfaces for both public network and VPN instances.
This command takes effect whether the source interface belongs to the VPN instance or not. As a best practice, specify an interface that belongs to the VPN instance as the source interface.
# Specify GigabitEthernet 1/0/1 as the source interface for DNS packets on the public network.
[Sysname] dns source-interface gigabitethernet 1/0/1
dns spoofing
Use dns spoofing to enable DNS spoofing and specify the IPv4 address for spoofing DNS requests.
Use undo dns spoofing to disable DNS spoofing.
dns spoofing ip-address [ vpn-instance vpn-instance-name ]
undo dns spoofing ip-address [ vpn-instance vpn-instance-name ]
DNS spoofing is disabled.
ip-address: Specifies the IPv4 address used to spoof DNS requests.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To enable DNS spoofing for the public network, do not specify this option.
Use the dns spoofing command together with the dns proxy enable command.
DNS spoofing functions when the DNS proxy does not know the DNS server address or cannot reach the DNS server. It enables the DNS proxy to spoof DNS queries of type A by responding with the specified IPv4 address.
The system allows only one replied IPv4 address for the public network or each VPN instance. If you execute this command multiple times, the most recent configuration takes effect. You can configure DNS spoofing for both public network and VPN instances.
# Enable DNS spoofing for the public network and specify IPv4 address 1.1.1.1 for spoofing DNS requests.
[Sysname] dns spoofing 1.1.1.1
dns proxy enable
Use dns transparent-proxy enable to enable transparent DNS proxy.
Use undo dns transparent-proxy enable to disable transparent DNS proxy.
Transparent DNS proxy is disabled.
Transparent DNS proxy modifies the source address in DNS requests so that the DNS client seems to receive a DNS reply directly from the DNS server. This feature is applicable to domain name-based policies, such as security policies and bandwidth policies.
The DNS client does not configure the DNS server address as the transparent DNS proxy address, which simplifies the DNS client configuration. As a best practice, enable transparent DNS proxy in some load balancing scenarios.
The device enabled with transparent DNS proxy monitors received DNS requests and replies and records DNS mappings as follows:
1.     The device monitors all received DNS packets. Upon receiving a DNS request, the device specifies a local IP address that can reach the DNS server as the source IP address for the request.
2.     Upon receiving the DNS reply, the device records the DNS mapping and forwards the reply to the DNS client.
3.     The device searches the local entries after receiving another request. If a match is found, the device returns a DNS reply to the client. If no match is found, the device forwards the query to the DNS server for domain name resolution.
Do not configure the transparent DNS proxy feature together with the following features:
·     DNS fast-reply.
·     DNS snooping.
·     DNS redirection.
The transparent DNS proxy feature cannot be used across VPNs. Make sure the input and output interfaces of DNS packets on the device belong to the same VPN.
# Enable transparent DNS proxy.
[Sysname] dns transparent-proxy enable
dns proxy enable
dns redirect enable
dns snooping enable
dns trust-interface
Use dns trust-interface to specify a DNS trusted interface.
Use undo dns trust-interface to remove a DNS trusted interface.
dns trust-interface interface-type interface-number
undo dns trust-interface [ interface-type interface-number ]
No DNS trusted interface is specified.
By default, an interface obtains DNS suffix and DNS server information from DHCP. A network attacker might act as the DHCP server to assign a wrong DNS suffix and DNS server address to the device. As a result, the device fails to obtain the resolved IP address or might get the wrong IP address. With the DNS trusted interface specified, the device only uses the DNS suffix and DNS server information obtained through the trusted interface to avoid attacks.
You can configure a maximum of 128 DNS trusted interfaces on the device.
If you do not specify an interface, the undo dns trust-interface command removes all DNS trusted interfaces and restores the default.
# Specify GigabitEthernet 1/0/1 as a DNS trusted interface.
[Sysname] dns trust-interface gigabitethernet 1/0/1
domain-name
Use domain-name to add a domain name to a domain name group.
Use undo domain-name to delete a domain name from a domain name group.
undo domain-name domain-name
A domain name group does not have domain names.
Domain name group view
When the device matches the domain name in a query against the domain names in a domain name group, the match succeeds only when the domain name in the query is exactly the same as a domain name in the domain name group.
You can execute this command multiple times to add multiple domain names to a domain name group. The maximum number of domain names and subdomain names that can be added to a domain name group varies by device.
# Add domain name www.example.com to domain name group 1.
[Sysname-domain-name-group-1] domain-name www.example.com
subdomain-name
health-check enable
Use health-check enable to enable DNS server health check.
Use undo health-check enable to disable DNS server health check.
health-check enable
DNS server health check is disabled.
When the device enabled with DNS redirection receives a DNS request that matches a domain name rule, the device forwards the request to a DNS server. The DNS server is selected as follows:
·     If the DNS servers are configured with priorities, the device selects DNS servers in descending order of their priorities.
·     If the DNS servers are not configured with priorities or they have the same priority, the device selects DNS servers according to the server order displayed in the display this command.
After the device forwards the request to a DNS server, if it does not receive a DNS reply from the DNS server within two seconds, it reselects a DNS server. To prevent the device from selecting an unavailable DNS server, execute the health-check enable command to detect the availability of DNS servers. After you execute the command on the device, it works as follows:
1.     The device periodically sends a DNS request to each DNS server in the DNS server group.
2.     If the device receives a DNS reply from a DNS server, it regards the DNS server available.
3.     If the device does not receive any DNS reply from a DNS server after it sends a DNS request to the DNS server for three consecutive times, it regards the DNS server unavailable.
4.     Upon receiving a DNS request that matches a domain name rule, the device ignores the unavailable DNS servers automatically and selects a DNS server according to the lexicographical order.
# Enable health check for DNS servers in DNS server group 1.
[Sysname-server-group-1] health-check enable
ip host
Use ip host to create a host name-to-IPv4 address mapping.
Use undo ip host to remove a host name-to-IPv4 address mapping.
ip host host-name ip-address [ vpn-instance vpn-instance-name ]
undo ip host host-name ip-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv4 address mappings exist.
host-name: Specifies a host name, a case-insensitive string of 1 to 253 characters that can contain letters, digits, hyphens (-), underscores (_), and dots (.). A host name must meet the following requirements:
·     The host name string is separated by dots (.). Each separated part can contain up to 63 characters.
·     The host name cannot start or end with a dot (.).
·     The host name cannot contain two consecutive dots (..).
ip-address: Specifies the IPv4 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IP address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv4 address mappings for the public network or each VPN instance. You can configure host name-to-IPv4 address mappings for both public network and VPN instances.
For the public network or a VPN instance, each host name maps to only one IPv4 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping command parameter ip, -a, -c, -f, -h, -i, -m, -n, -p, -q, -r, -s, -t, -tos, -v, or -vpn-instance as the host name. For more information about the ping command parameters, see Network Management and Monitoring Command Reference.
# Map IPv4 address 10.110.0.1 to host name aaa for the public network.
[Sysname] ip host aaa 10.110.0.1
display dns host
ipv6 dns dscp
Use ipv6 dns dscp to set the DSCP value for IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
Use undo ipv6 dns dscp to restore the default.
ipv6 dns dscp dscp-value
undo ipv6 dns dscp
The DSCP value is 0 in IPv6 DNS packets sent by an IPv6 DNS client or IPv6 DNS proxy.
# Set the DSCP value to 30 for outgoing IPv6 DNS packets.
[Sysname] ipv6 dns dscp 30
ipv6 dns server
Use ipv6 dns server to specify the IPv6 address of a DNS server.
Use undo ipv6 dns server to remove the IPv6 address of a DNS server.
ipv6 dns server ipv6-address [ interface-type interface-number ] [ vpn-instance vpn-instance-name ] [ priority priority-value ]
undo ipv6 dns server [ ipv6-address [ interface-type interface-number ] ] [ vpn-instance vpn-instance-name ]
No DNS server IPv6 address is specified.
ipv6-address: Specifies the IPv6 address of a DNS server.
interface-type interface-number: Specifies the output interface by its type and number. If you do not specify an interface, the device forwards DNS packets out of the output interface of the matching route. Specify this argument if the IPv6 address of the DNS server is a link-local address. Do not specify this argument if the IPv6 address of the DNS server is a global unicast address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To specify a DNS server IPv6 address for the public network, do not use this option.
Operating mechanism
The device sends a DNS query request to the DNS servers in descending order of their priorities. If they have the same priority, the device sends the DNS query request to the DNS servers in ascending order of their IPv6 addresses. You can edit the priority of DNS servers to change the DNS query request sending order.
The system allows a maximum of six DNS server IPv6 addresses for the public network or each VPN instance. You can specify DNS server IPv6 addresses for both public network and VPN instances.
If you do not specify an IPv6 address, the undo ipv6 dns server command removes all DNS server IPv6 addresses for the public network or the specified VPN instance.
# Specify DNS server IPv6 address 2002::1 for the public network.
[Sysname] ipv6 dns server 2002::1
ipv6 dns server (DNS server group view)
Use ipv6 dns server to add an IPv6 DNS server to the DNS server group.
Use undo ipv6 dns server to remove IPv6 DNS servers from the DNS server group.
ipv6 dns server ipv6-address [ interface-type interface-number ] [ priority priority-value ]
ipv6-address : Specifies the IPv6 address of a DNS server.
Operating mechanism
The device sends a DNS query to DNS servers of the DNS server group in descending order of their priorities. If they have the same priority, the device sends the DNS query to the DNS servers in an order that is the same as the one displayed in the display this command output for the group. You can edit the priority of DNS servers to change the DNS query sending order.
A DNS server group supports a maximum of six IPv6 DNS server addresses.
If you do not specify the ipv6-address argument, the undo ipv6 dns server command deletes all IPv6 addresses in the DNS server group.
# Add DNS server 2000::1 to DNS server group 1.
[Sysname-server-group-1] ipv6 dns server 2000::1
ipv6 dns spoofing
Use ipv6 dns spoofing to enable DNS spoofing and specify the IPv6 address to spoof DNS requests.
Use undo ipv6 dns spoofing to disable DNS spoofing.
ipv6 dns spoofing ipv6-address [ vpn-instance vpn-instance-name ]
undo ipv6 dns spoofing ipv6-address [ vpn-instance vpn-instance-name ]
ipv6-address: Specifies the IPv6 address used to spoof DNS requests.
Use the ipv6 dns spoofing command together with the dns proxy enable command.
DNS spoofing functions when the DNS proxy does not know the DNS server address or cannot reach the DNS server. It enables the DNS proxy to spoof DNS queries of type AAAA by responding with the specified IPv6 address.
The system allows only one replied IPv6 address for the public network or each VPN instance. If you execute this command multiple times, the most recent configuration takes effect. You can configure DNS spoofing for both public network and VPN instances.
# Enable DNS spoofing for the public network and specify IPv6 address 2001::1 for spoofing DNS requests.
[Sysname] ipv6 dns spoofing 2001::1
dns proxy enable
ipv6 host
Use ipv6 host to create a host name-to-IPv6 address mapping.
Use undo ipv6 host to remove a host name-to-IPv6 address mapping.
ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
undo ipv6 host host-name ipv6-address [ vpn-instance vpn-instance-name ]
No host name-to-IPv6 address mappings exist.
ipv6-address: Specifies the IPv6 address of the host.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To create a host name-to-IPv6 address mapping for the public network, do not specify this option.
The system allows a maximum of 1024 host name-to-IPv6 address mappings for the public network or each VPN instance. You can configure host name-to-IPv6 address mappings for both public network and VPN instances.
For the public network or a VPN instance, each host name maps to only one IPv6 address. If you execute this command multiple times, the most recent configuration takes effect.
Do not use the ping ipv6 command parameter -a, -c, -i, -m, -q, -s, -t, -tc, -v, or -vpn-instance as the host name. For more information about the ping ipv6 command parameters, see Network Management and Monitoring Command Reference.
# Map IPv6 address 2001::1 to host name aaa for the public network.
[Sysname] ipv6 host aaa 2001::1
ip host
reset dns host
Use reset dns host to clear dynamic DNS entries.
reset dns host [ ip | ipv6 ] [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears dynamic DNS entries for the public network.
If you do not specify the ip or ipv6 keyword, the reset dns host command clears dynamic DNS entries of all query types.
Use this command to clear the following dynamic DNS entries:
·     Dynamic DNS entries on the DNS client.
·     Dynamic DNS entries on the device enabled with transparent DNS proxy.
# Clear dynamic DNS entries of all query types for the public network.
<Sysname> reset dns host
display dns host
subdomain-name
Use subdomain-name to add a subdomain name to a domain name group.
Use undo subdomain-name to delete a subdomain name from a domain name group.
undo subdomain-name subdomain-name
A domain name group does not have subdomain names.
subdomain-name: Specifies a subdomain name. It is a dot-separated, case-insensitive string that can include letters, digits, hyphens (-), underscores (_), and dots (.), for example, .example.com. It cannot contain asterisks (*). The subdomain name can include a maximum of 253 characters, and each separated string includes no more than 63 characters.
When the device matches the domain name in a query against the subdomain names in a domain name group, the match succeeds if the domain name in the query contains a subdomain name in the group. For example, example.net has two subdomain names a.example.net and b.example.net.
·     If you specify subdomain-name as .example.net, only a.example.net and b.example.net can match the specified subdomain name.
·     If you specify subdomain-name as example.net, example.net, a.example.net, and b.example.net can all match the specified subdomain name.
You can execute this command multiple times to add multiple subdomain names to a domain name group. The maximum number of domain names and subdomain names that can be added to a domain name group varies by device.
# Add subdomain name com to domain name group 1.
[Sysname-domain-name-group-1] subdomain-name com
domain-name
DDNS commands
ddns apply policy
Use ddns apply policy to apply a DDNS policy to an interface and enable DDNS update. DDNS updates the mapping between the FQDN and the primary IP address of the interface.
Use undo ddns apply policy to remove the application of a DDNS policy from an interface and to stop DDNS update.
ddns apply policy policy-name [ fqdn domain-name ]
undo ddns apply policy policy-name
No DDNS policy and FQDN are specified on the interface, and DDNS update is disabled.
Interface view
policy-name: Specifies a DDNS policy by its name, a case-insensitive string of 1 to 32 characters.
fqdn domain-name: Specifies the FQDN to replace <h> in the URL for DDNS update. The domain-name argument specifies a case-insensitive string of 1 to 253 characters. It can include letters, digits, hyphens (-), underscores (_), and dots (.).
You can apply a maximum of four DDNS policies to an interface.
If you execute this command multiple times with the same DDNS policy name but different FQDNs, both of the following occur:
·     The most recent configuration takes effect.
·     The device initiates a DDNS update request immediately.
# Apply DDNS policy steven_policy to GigabitEthernet 1/0/1 to update the domain name-to-IP address mapping for FQDN www.example.com and enable DDNS update.
[Sysname-GigabitEthernet1/0/1] ddns apply policy steven_policy fqdn www.example.com
ddns policy
display ddns policy
ddns dscp
Use ddns dscp to set the DSCP value for outgoing DDNS packets.
Use undo ddns dscp to restore the default.
ddns dscp dscp-value
undo ddns dscp
The DSCP value for outgoing DDNS packets is 0.
# Set the DSCP value to 30 for outgoing DDNS packets.
[Sysname] ddns dscp 30
ddns policy
Use ddns policy to create a DDNS policy and enter its view, or enter the view of an existing DDNS policy.
Use undo ddns policy to delete a DDNS policy.
ddns policy policy-name
undo ddns policy policy-name
No DDNS policies exist.
policy-name: Specifies the DDNS policy name, a case-insensitive string of 1 to 32 characters.
You can create a maximum of 16 DDNS policies on the device.
# Create a DDNS policy named steven_policy and enter its view.
[Sysname] ddns policy steven_policy
ddns apply policy
display ddns policy
display ddns policy
Use display ddns policy to display information about DDNS policies.
display ddns policy [ policy-name ]
policy-name: Specifies a DDNS policy by its name, a case-insensitive string of 1 to 32 characters. If you do not specify a DDNS policy, this command displays information about all DDNS policies.
# Display information about DDNS policy steven_policy.
<Sysname> display ddns policy steven_policy
DDNS policy: steven_policy
  URL              : http://members.3322.org/dyndns/update?
                     system=dyndns&hostname=<h>&myip=<a>
  Username         : steven
  Password         : ******
  Method           : GET
  SSL client policy:
  Interval         : 1 days 0 hours 1 minutes
# Display information about all DDNS policies.
  URL              : http://members.3322.org/dyndns/update?system=
  Username         : steven
  Password         : ******
  Method           : GET
  SSL client policy:
  Interval         : 0 days 0 hours 30 minutes
DDNS policy: tom-policy
  Username         :
  Password         :
  Method           : GET
  SSL client policy:
  Interval         : 0 days 0 hours 15 minutes
DDNS policy: u-policy
  URL              : oray://phddns60.oray.net
  Username         : username
  Password         :
  Method           : -
  SSL client policy:
Table 6 Command output
DDNS policy
DDNS policy name.
URL
URL address for a DDNS update request. This field is empty if no URL address is configured.
Username
Username for logging in to the DDNS server. This field is empty if no username is configured.
Password
Password for logging in to the DDNS server. This field is empty if no password is configured and displays ****** if a password is configured.
Method
Parameter transmission method used to send HTTP/HTTPS-based DDNS update requests.
Method types include GET and POST.
SSL client policy
Name of the associated SSL client policy. This field is empty if no SSL client policy is associated.
Interval
Interval for sending DDNS update requests.
ddns policy
interval
Use interval to set the interval for sending DDNS update requests.
Use undo interval to restore the default.
interval days [ hours [ minutes ] ]
undo interval
The DDNS update request interval is 1 hour.
DDNS policy view
days: Days in the range of 0 to 365.
hours: Hours in the range of 0 to 23.
minutes: Minutes in the range of 0 to 59.
The interface always sends a DDNS update request in one of the following conditions:
·     The primary IP address of the interface changes.
·     The link state of the interface changes from down to up.
If you set the interval to 0, the device does not periodically initiate DDNS update requests.
If you execute this command multiple times, the most recent configuration takes effect. If you change the interval for an applied DDNS policy, the device immediately initiates a DDNS update request and sets the interval as the update interval.
# Set the interval to 1 day and 1 minute for sending DDNS update requests for DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] interval 1 0 1
ddns policy
display ddns policy
method
Use method to specify the parameter transmission method for sending DDNS update requests to HTTP/HTTPS-based DDNS servers.
Use undo method to restore the default.
method { http-get | http-post }
undo method
The method http-get applies.
DDNS policy view
http-get: Uses the get operation.
http-post: Uses the post operation.
This command applies to DDNS updates in HTTP/HTTPS. If the DDNS server uses HTTP or HTTPS service, choose a parameter transmission method compatible with the DDNS server. For example, a DHS server supports the http-post method.
If the DDNS policy has been applied to an interface, a DDNS update is sent immediately after the parameter transmission is changed.
# Specify the parameter transmission method as http-post for DDNS update requests for DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] method http-post
ddns policy
display ddns policy
password
Use password to specify the password for logging in to the DDNS server.
Use undo password to restore the default.
undo password
No password is specified for logging in to the DDNS server.
DDNS policy view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
# In DDNS policy steven_policy, specify nevets as the password for logging in to the DDNS server.
[Sysname-ddns-policy-steven_policy] password simple nevets
ddns policy
display ddns policy
url
username
ssl-client-policy
Use ssl-client-policy to associate an SSL client policy with a DDNS policy.
Use undo ssl-client-policy to restore the default.
ssl-client-policy policy-name
No SSL client policy is associated with a DDNS policy.
DDNS policy view
policy-name: Specifies a SSL client policy by its name, a case-insensitive string of 1 to 31 characters.
The SSL client policy is effective only for HTTPS-based DDNS update requests.
If you execute this command multiple times with different SSL client policies, the most recent configuration takes effect.
# Associate SSL client policy ssl_policy with DDNS policy steven_policy.
[Sysname-ddns-policy-steven_policy] ssl-client-policy ssl_policy
ddns policy
display ddns policy
ssl-client-policy (Security Command Reference)
url
Use url to specify the URL address for DDNS update requests.
Use undo url to restore the default.
url request-url
undo url
No URL address is specified for DDNS update requests.
DDNS policy view
request-url: Specifies the URL address, a case-sensitive string of 1 to 240 characters.
The URL addresses configured for update requests vary by DDNS server. Common DDNS server URL address formats are shown in Table 7.
Table 7 Common URL addresses for DDNS update request
DDNS server
URL addresses for DDNS update requests
www.3322.org
http://members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
DYNDNS
http://members.dyndns.org/nic/update?system=dyndns&hostname=<h>&myip=<a>
DYNS
http://www.dyns.cx/postscript.php?host=<h>&ip=<a>
ZONEEDIT
http://dynamic.zoneedit.com/auth/dynamic.html?host=<h>&dnsto=<a>
TZO
http://cgi.tzo.com/webclient/signedon.html?TZOName=<h>IPAddress=<a>
EASYDNS
http://members.easydns.com/dyn/ez-ipupdate.php?action=edit&myip=<a>&host_id=<h>
HEIPV6TB
http://dyn.dns.he.net/nic/update?hostname=<h>&myip=<a>
CHANGE-IP
http://nic.changeip.com/nic/update?hostname=<h>&offline=1
NO-IP
http://dynupdate.no-ip.com/nic/update?hostname=<h>&myip=<a>
Do not specify the myip parameter if traffic from the DDNS client to the DDNS server goes through a NAT device.
DHS
http://members.dhs.org/nic/hosts?domain=dyn.dhs.org&hostname=<h>&hostscmd=edit&hostscmdstage=2&type=1&ip=<a>
HP
https://server-name/nic/update?group=group-name&myip=<a>
ODS
ods://update.ods.org
GNUDIP
gnudip://server-name
PeanutHull
·     oray://phddns60.oray.net
·     oray://phservice2.oray.net
·     http://ddns.oray.com/ph/update?hostname=<h>&myip=<a>
The URL address cannot contain the username or password. To configure the username and password, use the username command and the password command.
HP and GNUDIP are common DDNS update protocols. The server-name parameter is the domain name or IP address of the service provider's server using one of the update protocols.
The URL address for an update request can start with:
·     http://—The HTTP-based DDNS server.
·     https://—The HTTPS-based DDNS server.
·     ods://—The TCP-based ODS server.
·     gnudip://—The TCP-based GNUDIP server.
·     oray://—The TCP-based DDNS server.
The domain names of DDNS servers are members.3322.org and phddns60.oray.net. The domain names of PeanutHull DDNS servers can be phddns60.oray.net and phservice2.oray.net. The domain name phservice2.oray.net maps to the public IP address of the old version PeanutHull DDNS server, which is not maintained any more. You need to try several times upon failures to connect to the server. As a best practice, register a new account and a domain name on the PeanutHull DDNS of a new version. Determine the domain name in the URL according to the actual situation.
The port number in the URL address is optional. If you do not specify a port number, the default port number is used. HTTP uses port 80, HTTPS uses port 443, and the PeanutHull server uses port 6060.
The system automatically performs the following tasks:
·     Fills <h> with the FQDN that is specified when the DDNS policy is applied to an interface.
·     Fills <a> with the primary IP address of the interface to which the DDNS policy is applied.
You can also manually specify an FQDN and an IP address in <h> and <a>, respectively. In this case, the FQDN that is specified when the DDNS policy is applied to an interface will not take effect. As a best practice, do not manually change the <h> and <a> because your configuration might be incorrect.
You cannot specify an FQDN and IP address in the URL address for contacting the PeanutHull server. Alternatively, you can specify an FQDN when applying the DDNS policy to an interface. The system automatically uses the primary IP address of the interface to which the DDNS policy is applied as the IP address for DDNS update.
To avoid misinterpretation, do not include colons (:), at signs (@), and question marks (?) in your login username or password, even if you can do so.
# Specify the URL address for DDNS update requests for DDNS policy steven_policy. The device contacts www.3322.org for DDNS update.
[Sysname-ddns-policy-steven_policy] url http:// members.3322.org/dyndns/update?system=dyndns&hostname=<h>&myip=<a>
ddns policy
display ddns policy
password
username
username
Use username to specify the username for logging in to the DDNS server.
Use undo username to restore the default.
username username
undo username
No username is specified for logging in to the DDNS server.
DDNS policy view
username: Specifies the username, a case-sensitive string of 1 to 32 characters.
# In DDNS policy steven_policy, specify steven as the username for logging in to the DDNS server.
[Sysname-ddns-policy-steven_policy] username steven
ddns policy
display ddns policy
password
url
