07-Layer 3—IP Services Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10107-Layer 3—IP Services Command Reference
06-NAT66 commands
06-NAT66 commands 117.77 KB
NAT66 commands
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
display nat66 all
Use display nat66 all to display all NAT66 configurations.
display nat66 all
# Display all NAT66 configurations.
<Sysname> display nat66 all
NAT66 source information:
  Totally 2 source rules.
  Interface(outbound): GigabitEthernet1/0/1
    Original prefix/prefix-length: 11::/64
    Original VPN-instance: vpn1
    Translated prefix/prefix-length: 22::/64 PAT
    Translated VPN-instance: vpn1
  Interface(outbound): GigabitEthernet1/0/2
    Type: Easy-IP
    ACL: 2100
    Config status: Active
NAT66 destination information:
  Totally 1 destination rules.
  Interface(inbound): GigabitEthernet1/0/2
    Original prefix/prefix-length: FD01:203:405::/48 Protocol TCP 6000
    Translated prefix/prefix-length: 1::/48 4000
Configuration information about NAT66 source address translation.
Configuration information about NAT66 destination address translation.
Totally n source rules
Total number of source address translation rules.
Totally n destination rules
Total number of destination address translation rules.
Interface(outbound)
Interface configured with NAT66 source address translation rules.
Interface(inbound)
Interface configured with NAT66 destination address translation rules.
NAT66 source address translation type. This field is displayed only after you configure NAT66 source address translation with Easy IP.
ACL
Number or name of the ACL specified for the NAT66 source address translation with Easy IP configuration. If no ACL is specified, this field displays hyphens (---).
Config status
Status of the NAT66 source address translation with Easy IP configuration:
·     Active—The configuration is taking effect.
·     Inactive—The configuration is not taking effect.
Reasons for inactive status
Reasons why the NAT66 source address translation with Easy IP configuration does not take effect. This field is available when the Config status field displays Inactive.
Original prefix/prefix-length: xxx Protocol yyy zzz
Prefix and prefix length before NAT66 translation:
·     xxx—Prefix and prefix length before NAT66 translation.
·     Protocol—Transport layer protocol. Options for yyy include IPv6-ICMP, UDP, and TCP. If you have not specified a transport layer protocol, this field is not displayed.
·     zzz—External port number used by an internal server to provide services. If you have not specified an external port number, no port number is displayed.
Original VPN instance
VPN instance to which the prefix before NAT66 translation belong. If the prefix before NAT66 translation belongs to the public network, this field is not displayed.
Translated  prefix/prefix-length: xxx yyy PAT
Prefix and prefix length after NAT66 translation:
·     xxx—Prefix and prefix length after NAT66 translation.
·     yyy—Port number of an internal server in the internal network. If you have not specified the port number, no port number is displayed.
·     PAT—Uses PAT for address translation. If you have not specified PAT, it is not displayed.
Translated VPN instance
VPN instance to which the prefix after NAT66 translation belong. If the prefix after NAT66 translation belongs to the public network, this field is not displayed.
nat66 prefix destination
nat66 prefix source
display nat66 session
Use display nat66 session to display NAT66 sessions.
In standalone mode:
display nat66 session [ slot slot-number ] [ verbose ]
In IRF mode:
display nat66 session [ chassis chassis-number slot slot-number ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT66 sessions for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NAT66 sessions for all cards. (In IRF mode.)
verbose: Displays detailed information about NAT66 sessions. If you do not specify this keyword, the command displays brief information about NAT66 sessions.
If you do not specify any parameters, this command displays brief information about all NAT66 sessions.
# (In standalone mode.) Display brief information about NAT66 sessions for the specified slot.
<Sysname> display nat66 session slot 1
Slot 1:
Initiator:
  Source      IP/port: FD01:203:405::1/4048
  Destination IP/port: 2001:DB8:1::100/21
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/2
Total sessions found: 1
# (In standalone mode.) Display detailed information about NAT66 sessions for the specified slot.
<Sysname> display nat session slot 1 verbose
Slot 1:
Initiator:
  Protocol: TCP(6)
  Source security zone: Trust
Responder:
  Source      IP/port: 2001:DB8:1::100/21
  Destination IP/port: 1:0:0:309::1/4048
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/1
State: TCP_ESTABLISHED
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2018-12-10 09:19:28  TTL: 3585s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Initiator
Session information about the initiator.
Responder
Session information about the responder.
Source IP/port
Source IPv6 address and port number.
Destination IP/port
Destination IPv6 address and port number.
·     VPN instance—MPLS L3VPN instance to which the session belongs.
·     VLAN ID—ID of the VLAN to which the session belongs for Layer 2 forwarding.
·     Inline ID—ID of the INLINE to which the session belongs for Layer 2 forwarding.
If no settings are specified, this field displays slash-separated hyphens (-/-/-).
Protocol
Transport layer protocol type: DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, or UDP-Lite.
The number after the protocol is the protocol number.
Inbound interface
Input interface.
Security zone to which the input interface belongs. If the input interface does not belong to any security zone, this field displays a hyphen (-).
NAT66 session state.
Application
Application layer protocol type, such as FTP and DNS.
This field displays OTHER for the protocol types identified by non-well-known ports.
Rule ID
ID of the security policy rule.
Rule name
Name of the security policy rule.
Start time
Time when the session starts.
TTL
Remaining lifetime of the NAT66 session, in seconds.
Number of packets and packet bytes from the initiator to the responder.
Number of packets and packet bytes from the responder to the initiator.
Total number of sessions.
reset nat66 session
display nat66 statistics
Use display nat66 statistics to display NAT66 statistics.
In standalone mode:
display nat66 statistics [ summary ] [ slot slot-number  ]
In IRF mode:
display nat66 statistics [ summary ] [ chassis chassis-number slot slot-number ]
summary: Displays NAT66 statistics summary. If you do not specify this keyword, the command displays detailed NAT66 statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NAT66 statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NAT66 statistics for all cards. (In IRF mode.)
# (In standalone mode.) Display detailed NAT66 statistics.
<Sysname> display nat66 statistics
Slot 1:
  Total session entries: 100
  Total outbound NO-PAT entries: 100
Number of NAT66 session entries.
Number of outbound NAT66 NO-PAT session entries.
# (In standalone mode.) Display NAT66 statistics summary.
<Sysname> display nat66 statistics summary
Slot Sessions
1    100
Sessions
Use nat66 prefix destination to configure an IPv6 prefix mapping for IPv6 destination address translation.
Use undo nat66 prefix destination to remove an IPv6 prefix mapping for IPv6 destination address translation.
nat66 prefix destination [ protocol pro-type ] original-ipv6-prefix prefix-length [ global-port ] [ vpn-instance original-vpn-instance-name ] translated-ipv6-prefix prefix-length [ local-port ] [ vpn-instance translated-vpn-instance-name ]
undo nat66 prefix destination [ protocol pro-type ] original-ipv6-prefix prefix-length [ global-port ] [ vpn-instance original-vpn-instance-name ] translated-ipv6-prefix prefix-length [ local-port ] [ vpn-instance translated-vpn-instance-name ]
No IPv6 prefix mappings are configured for IPv6 destination address translation.
Interface view
protocol pro-type: Specifies a protocol type. If you do not specify a protocol type, the command applies to packets of all protocols. The protocol type format can be one of the following:
·     A number in the range of 1 to 255. The values 50 (ESP) and 51 (AH) are not supported.
·     A protocol name of ipv6-icmp, tcp, or udp.
original-ipv6-prefix: Specifies the original IPv6 prefix. For IPv6 destination address translation, specify the external prefix.
global-port: Specifies a public port number for the internal server, in the range of 1 to 65535. If you do not specify this argument, the translation will be performed no matter what the destination port number is. You can specify this argument only when the protocol type is TCP or UDP.
vpn-instance original-vpn-instance-name: Specifies the MPLS L3VPN instance to which the original IPv6 prefix belongs. The original-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the original IPv6 prefix belongs to the public network, do not specify this option.
translated-ipv6-prefix: Specifies the translated IPv6 prefix. For IPv6 destination address translation, specify the internal prefix.
prefix-length: Specifies a prefix length, in the range of 1 to 128.
local-port: Specifies a private port number for the internal server, in the range of 1 to 65535. If you do not specify this argument, the value for this argument is the same as the value of the global-port argument. If you do not specify the global-port and local-port arguments, the port number is not translated. You can specify this argument only when the protocol type is TCP or UDP.
vpn-instance translated-vpn-instance-name: Specifies the MPLS L3VPN instance to which the translated IPv6 prefix belongs. The translated-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If the translated IPv6 prefix belongs to the public network, do not specify this option.
To allow external users to access internal servers (such as Web or FTP server), configure IPv6 destination prefix mappings on the interface connected to the external network.
When you configure IPv6 destination prefix mappings, follow these restrictions and guidelines:
·     The prefix length before and after NAT66 must be the same.
·     On one interface on the public network or in the same VPN instance, the mapping between an external prefix and an internal prefix must be unique.
·     On different interfaces on the public network or in the same VPN instance, one external prefix cannot be mapped to different internal prefixes.
·     The translated IPv6 prefix cannot be the same as the prefix of the public IPv6 address of the NAT66 device or the prefix of the IPv6 address of an external host.
·     The command does not support modifying an existing IPv6 prefix mapping. To modify it, first execute the undo nat66 prefix destination command to remove the mapping, and then configure the new one.
This feature cannot perform translation on AH or ESP packets.
# On GigabitEthernet 1/0/1, configure an IPv6 destination prefix mapping to translate IPv6 prefix 2001::/64 to IPv6 prefix 2101::/64.
[Sysname-GigabitEthernet1/0/1] nat66 prefix destination 2001:: 64 2101:: 64
# On GigabitEthernet 1/0/1, configure an IPv6 destination prefix mapping to translate IPv6 prefix 2001::/64 and port 64 to IPv6 prefix 2101::/64 and port 200 for packets destined for the internal FTP server.
[Sysname-GigabitEthernet1/0/1] nat66 prefix destination 2001:: 64 protocol tcp 100 2101:: 64 200
display nat66 all
nat66 prefix source
Use nat66 prefix source to configure an IPv6 prefix mapping for IPv6 source address translation.
Use undo nat66 prefix source to remove an IPv6 prefix mapping for IPv6 source address translation.
nat66 prefix source original-ipv6-prefix prefix-length [ vpn-instance original-vpn-instance-name ] translated-ipv6-prefix prefix-length [ vpn-instance translated-vpn-instance-name ] [ pat ]
undo nat66 prefix source original-ipv6-prefix prefix-length [ vpn-instance original-vpn-instance-name ] translated-ipv6-prefix prefix-length [ vpn-instance translated-vpn-instance-name ] [ pat ]
No IPv6 prefix mappings are configured for IPv6 source address translation.
Interface view
original-ipv6-prefix: Specifies the original IPv6 prefix. For IPv6 source address translation, specify the internal prefix.
translated-ipv6-prefix: Specifies the translated IPv6 prefix. For IPv6 source address translation, specify the external prefix.
pat: Uses the PAT mode for address translation. In this mode, port information is translated. If you do not specify this keyword, the device does not translate port information.
NAT66 source address translation is applicable to the following scenarios:
·     Single internal and external network—The NAT66 device is connected to an internal network and an external network. Hosts in the internal network uses locally routed IPv6 prefixes. When an internal host sends packets to access the external network, the NAT66 device translates the source IPv6 address prefix in the packets to a global unicast address prefix.
·     Redundancy and load sharing—Multiple NAT66 devices are deployed between two IPv6 networks and they use ECMPs for load sharing. To allow any NAT66 device to process IPv6 traffic among different sites, configure the same source prefix mappings on these NAT66 devices.
·     Multihoming—In a multihomed network, NAT66 devices are connected to an internal network and multiple external networks. One internal prefix is mapped to different external prefixes on the NAT66 devices, so that one internal address can be translated to multiple external addresses.
When you configure source prefix mappings, follow these restrictions and guidelines:
·     Source prefix mappings are typically configured on the interface connected to the external network.
·     The prefix length before and after NAT66 in a mapping must be the same if this mapping does not support port translation.
·     On one interface on the public network or in the same VPN instance, the mapping between an internal prefix and an external prefix must be unique.
·     On different interfaces on the public network or in the same VPN instance, different internal prefixes cannot be mapped to the same external prefix.
·     The translated IPv6 prefix cannot be the same as the prefix of the public IPv6 address of the NAT66 device or the prefix of the destination public IPv6 address.
·     The command does not support modifying an existing prefix mapping. To modify it, first execute the undo nat66 prefix source command to remove the mapping, and then configure the new one.
# On GigabitEthernet 1/0/1, configure an IPv6 source prefix mapping to translate IPv6 prefix FD9C:58ED:7D73:2::/64 to 2101::/64.
[Sysname-GigabitEthernet1/0/1] nat66 prefix source fd9C:58ed:7d73:2:: 64 2101:: 64
# On GigabitEthernet 1/0/1, configure an IPv6 source prefix mapping in PAT mode to translate IPv6 prefix FD9C:58ED:7D73:2::/64 to 2101::/64.
[Sysname-GigabitEthernet1/0/1] nat66 prefix source fd9C:58ed:7d73:2:: 64 2101:: 64 pat
display nat66 all
nat66 source easy-ip
Use nat66 source easy-ip to configure NAT66 source address translation with Easy IP.
Use undo nat66 source easy-ip to remove the NAT66 source address translation with Easy IP configuration.
nat66 source [ acl { ipv6-acl-number | name ipv6-acl-name } ] easy-ip
undo nat66 source [ acl { ipv6-acl-number | name ipv6-acl-name } ] easy-ip
NAT66 source address translation with Easy IP is not configured
Interface view
ipv6-acl-number: Specifies an ACL number in the range of 2000 to 3999.
name ipv6-acl-name: Specifies an ACL name, a case-insensitive string of 1 to 63 characters that must start with a letter. To avoid confusion, you cannot set the ACL name to all.
Application scenarios
NAT66 with Easy IP allows the device to use the IPv6 address of the output interface as the IPv6 address after address translation. It also translates the source port numbers of packets from the private network.
NAT66 with Easy IP can operate correctly even if the IP address of the interface is dynamically assigned. For example, the device accesses the network through dial-up and dynamically obtains its public IPv6 address. To use only the dynamically obtained public IPv6 address for address translation, configure NAT66 with Easy IP. Even if the public IPv6 address of the output interface changes, the device can still perform effective address translation based on the latest public IPv6 address.
Execute this command on the interface connected to the external network on the NAT66 device, and follow these restrictions and guidelines:
·     If the interface has multiple IPv6 addresses, NAT66 with Easy IP works as follows:
a.     Automatically compares the next-hop IPv6 address of packets with all the IPv6 addresses of the interface.
b.     Selects the IPv6 address that has the longest matching prefix with the next-hop IPv6 address.
c.     Uses the IPv6 address as the source IPv6 address after translation.
·     If the interface does not have any IPv6 address, the device discards that packets passing through the interface.
·     If the ACL rule specified for the NAT66 with Easy IP configuration does not take effect, the NAT66 with Easy IP configuration does not take effect either.
# Create IPv6 basic ACL 2100 to permit packets only from subnet 2000::/64 to pass through.
[Sysname] acl ipv6 basic 2100
[Sysname-acl-ipv6-basic-2100] rule permit source 2000::/64
[Sysname-acl-ipv6-basic-2100] quit
# Set the IPv6 global unicast address of GigabitEthernet 1/0/1 to 3000::1 with prefix length 64.
[Sysname-GigabitEthernet1/0/1] ipv6 address 3000::1 64
# Configure NAT66 source address translation with Easy IP on GigabitEthernet 1/0/1 so that the device uses the IPv6 address of the interface to perform address translation only on packets that match IPv6 ACL 2001.
[Sysname-GigabitEthernet1/0/1] nat66 source acl 2100 easy-ip
display nat66 all
reset nat66 session
Use reset nat66 session to delete NAT66 sessions.
In standalone mode:
reset nat66 session [ slot slot-number ]
In IRF mode:
reset nat66 session [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command deletes NAT66 sessions for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command deletes NAT66 sessions for all cards. (In IRF mode.)
# (In standalone mode.) Delete NAT66 sessions for the specified slot.
<Sysname> reset nat66 session slot 1
