02-Configuration Examples
HomeSupportRoutersCR16000-M SeriesConfigure & DeployConfiguration ExamplesH3C CR16000-M Routers Configuration Examples All-In-One-R8630Pxx-6W10002-Configuration Examples
Table of Contents
Related Documents
29-H3C_Samplers_and_IPv4_NetStream_Configuration_Examples
Introduction
This document provides configuration examples of collaborating samplers with IPv4 NetStream.
This document assumes that you have basic knowledge of samplers and IPv4 NetStream.
General restrictions and guidelines
·     Support for this feature varies by card. For more information, see the configuration guide for your product.
·     NetStream flow mirroring supports mirroring traffic only to the current interface module.
Example: Configuring Samplers and IPv4 NetStream
As shown in Figure 1, configure a sampler and IPv4 NetStream as follows:
·     Configure IPv4 NetStream on the router to collect statistics on incoming traffic.
·     Configure the router to send IPv4 NetStream data to port 5000 on the NetStream server.
·     Configure fixed sampling in the inbound direction to select the first packet out of 1001 packets on Ten-GigabitEthernet 3/0/1.
Figure 1 Network diagram
Procedures
1.     Configure a sampler:
# Create sampler samperin in fixed sampling mode, and set the rate to 1001. The first packet out of 1001 packets is selected.
[Device] sampler samplerin mode fixed packet-interval 1001
2.     Configure NetStream:
# Assign an IP address to Ten-GigabitEthernet 3/0/1.
[Device] interface ten-gigabitethernet 3/0/1
[Device-Ten-GigabitEthernet3/0/1] ip address 192.168.0.1 24
[Device-Ten-GigabitEthernet3/0/1] quit
# Assign an IP address to interface Ten-GigabitEthernet 3/0/2.
[Device] interface ten-gigabitethernet 3/0/2
[Device-Ten-GigabitEthernet3/0/2] ip address 10.0.0.1 24
[Device-Ten-GigabitEthernet3/0/2] quit
# Assign an IP address to interface Ten-GigabitEthernet 3/0/3.
[Device] interface ten-gigabitethernet 3/0/3
[Device-Ten-GigabitEthernet3/0/3] ip address 192.168.1.1 24
[Device-Ten-GigabitEthernet3/0/3] quit
# Enable NetStream globally.
[Device] ip netstream
# Configure QoS policy ns_ipv4_in with a flow mirroring action that uses sampler samperin.
[Device] acl advanced 3000
[Device-acl-ipv4-adv-3000] rule 0 permit ip
[Device] traffic classifier ns_ipv4
[Device-classifier-ns_ipv4] if-match acl 3000
[Device-classifier-ns_ipv4] quit
[Device] traffic behavior ns_ipv4_in
[Device-behavior-ns_ipv4] mirror-to local sampler samplerin
[Device-behavior-ns_ipv4] quit
[Device] qos policy ns_ipv4_in
[Device-qospolicy-ns_ipv4] classifier ns_ipv4 behavior ns_ipv4_in
[Device-qospolicy-ns_ipv4] quit
# Apply QoS policy ns_ipv4_in to the inbound direction of Ten-GigabitEthernet 3/0/1.
[Device-Ten-GigabitEthernet3/0/1] qos apply policy ns_ipv4_in inbound
# Specify 192.168.1.2 as the IP address of the destination host and UDP port 5000 as the export destination port number.
[Device] ip netstream export host 192.168.1.2 5000
1.     Display configuration information for sampler samperin.
[Device] display sampler
Sampler name: samplerin
  Mode: fixed;  Packet-interval: 1001;  IsNpower : N
2.     Display the statistics about NetStream data:
# Display NetStream entry information.
[Device] display ip netstream cache verbose
IP NetStream cache information:
  Active flow timeout               : 30 min
  Inactive flow timeout             : 30 sec
  Max number of entries             : 460800
  IP active flow entries            : 1
  MPLS active flow entries          : 0
  L2 active flow entries            : 0
  IPL2 active flow entries          : 0
  IP flow entries counted           : 22
  MPLS flow entries counted         : 0
  L2 flow entries counted           : 0
  IPL2 flow entries counted         : 0
  Last statistics resetting time    : Never
IP packet size distribution (300 packets in total):
 1-32   64   96  128  160  192  224  256  288  320  352  384  416  448  480
 .000 .000 1.00 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000 .000
  512  544  576 1024 1536 2048 2560 3072 3584 4096 4608 >4608
 Protocol          Total  Packets    Flows  Packets Active(sec) Idle(sec)
                   Flows  /sec       /sec   /flow   /flow       /flow
 ICMP                 22        0        0       13           1        30
Type DstIP(Port)            SrcIP(Port)            Pro ToS If(Direct)   Pkts
     DstMAC(VLAN)           SrcMAC(VLAN)
     TopLblType(IP/MASK)    Lbl-Exp-S-List
IP   10.0.0.2(2048)         192.168.0.2(0)         1   0   XGE3/0/1(I)  5
     TCPFlag:       0
     DstMask:      32       SrcMask:      32       NextHop:          10.0.0.2
     DstAS:         0       SrcAS:         0       BGPNextHop:        0.0.0.0
     InVRF:         0
     SamplerMode:   1       SamplerInt: 1001
     Active:        0       Bytes/Pkt:    84
# Display information about the NetStream data export.
[Device] display ip netstream export
IP export information:
  Flow source interface                           : Not specified
  Flow destination VPN instance                   : Not specified
  Flow destination IP address (UDP)               : 192.168.1.2 (5000)
  Version 5 exported flow number                  : 0
  Version 5 exported UDP datagram number (failed) : 0 (0)
  Version 9 exported flow number                  : 1
  Version 9 exported UDP datagram number (failed) : 0 (0)
  Version 10 exported flow number                 : 0
  Version 10 exported UDP datagram number (failed): 0 (0)
IPL2 export information:
  Version 9 exported flow number                  : 0
Configuration files
ip netstream
traffic classifier ns_ipv4 operator and
 if-match acl 3000
interface Ten-GigabitEthernet3/0/1
 port link-mode route
 ip address 192.168.0.1 255.255.255.0
interface Ten-GigabitEthernet3/0/2
 ip address 10.0.0.1 255.255.255.0
interface Ten-GigabitEthernet3/0/3
acl advanced 3000
 rule 0 permit ip
Related documentation
·     H3C CR16000-M Routers Network Management and Monitoring Configuration Guide
·     H3C CR16000-M Routers Network Management and Monitoring Command Reference
