- H3C SR8800-X Router Series Installation Guide-5W106
- 01-Chapter 1 Preparing for Installation
- 02-Chapter 2 Installing the Router
- 03-Chapter 3 Installing FRUs
- 04-Chapter 4 Connecting Your Router to the Network
- 05-Chapter 5 Troubleshooting
- 06-Chapter 6 Replacement Procedures
- 07-Appendix A Engineering Labels
- 08-Appendix B Cable Management
- 09-Appendix C Repackaging the Router
00-Preface | 109.35 KB |
Preface
The H3C SR8800-X Router Series Installation Guide describes how to install the H3C SR8800-X routers.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the SR8800-X router series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
