- 01-System Management
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
08-Password Control Configuration Example | 153.88 KB |
H3C Access Controllers |
Comware 7 Password Control |
Overview
The following information provides an example for configuring password control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of password control.
Example: Configuring password control
As shown in Figure 1, configure a password control policy on the AC. The user passwords must meet the following requirements:
· A password must contain a minimum of 10 characters.
· A password must contain a minimum of three character types and a minimum of two characters for each type.
If a user password does not meet these requirements, the user is prompted to change the password.
Make sure the AC and the client can reach each other.
Procedures
1. Configure IP settings, VLAN, AP access, and radio status on the AC. (Details not shown.)
2. Click the System View tab at the bottom of the page.
3. From the navigation pane, select System > Administrators.
4. Click the Password
control button at
the upper right of the page.
Figure 2 Entering the password control page
5. Click Enable Password Control.
Figure 3 Enabling password control
6. Configure password control settings.
a. Set the minimum password length to 10 characters.
b. Set the number of character types to three.
c. Set the number of characters for each type to two.
d. Set the password aging time to 90 days.
Figure 4 Configuring password control settings
Verify that you are prompted to change the password after entering the username and the initial password on the login page for the first time.
Figure 5 Changing the password
Related documentation
H3C Access Controllers Web-Based Configuration Guide
