01-System Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10001-System Management
03-Web Access Control Configuration Example
03-Web Access Control Configuration Example 129.14 KB
Web Access Control
Overview
The following information provides an example for configuring Web access control.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of Web access control.
Example: Configuring Web access control
As shown in Figure 1, configure the AC to permit only HTTP and HTTPS packets sourced from 192.168.100.22.
Figure 1 Network diagram
Make sure the network connections are available.
Procedures
Configuring an ACL
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select System > Resource.
3.     On the IPv4 ACL tab, click the Add button  to create an IPv4 ACL:
¡     Select Basic.
¡     Enter ACL number 2000.
¡     Click Apply.
Figure 2 Configuring an ACL
4.     Configure an ACL rule:
¡     Select the Source IP address/wildcard mask match criterion, and enter 192.168.100.22 as the IP address and 0.0.0.0 as the wildcard mask.
¡     Clear the Continue to add next rule option.
¡     Click Apply.
Figure 3 Configuring an ACL rule
Applying the ACL to Web services
2.     From the navigation pane, select Network Settings > Management Protocols.
3.     Apply the ACL to HTTP and HTTPS services:
¡     Click the light bulb icon next to Access ACL  in the HTTP area.
¡     Select ACL 2000.
¡     Click Apply.
Figure 4 Applying the ACL to the HTTP service
¡     Click the light bulb icon next to Access ACL  in the HTTPS area.
¡     Select ACL 2000.
¡     Click Apply.
Figure 5 Applying the ACL to the HTTPS service
1.     On Host A, launch the Web browser and enter http://192.168.100.1 in the address bar. You can log in to the Web interface after entering the correct username and password. (Details not shown.)
2.     On Host B, launch the Web browser and enter http://192.168.100.1 in the address bar.  You cannot log in to the Web interface after entering the correct username and password. (Details not shown.)
Related documentation
H3C Access Controllers Web-Based Configuration Guide
