- 01-System Management
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
05-SSH Local Authentication Configuration Example | 89.69 KB |
H3C Access Controllers |
Comware 7 SSH Local Authentication |
Example: Configuring SSH local authentication
Configuring the VLAN and the VLAN interface
Configure the administrator account
Overview
The following information provides an example for configuring the device as an Stelnet server that provides local authentication for login users.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of AAA and SSH.
As shown in Figure 1, the device is the gateway of the enterprise network. Use SSH to ensure security of the device management.
Configure the device as an Stelnet server and the host as an Stelnet client. The Stelnet server uses password authentication to authenticate the Stelnet client. The username and password of the Stelnet client are saved on the Stelnet server.
After the network administrator logs in to the device from the host through Stelnet, the administrator can configure and manage the device.
Procedures
Enabling the Stelnet service
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Management Protocols.
3. Click the SSH tab.
4. Enable the Stelnet service.
2. From the navigation pane, select Network Configuration > VLAN.
3. Click the Create VLANs
button to create VLAN 2.
4. Click the Edit button for
VLAN 2.
5. Add GigabitEthernet 1/0/2 to the untagged port list.
6. Select Configure VLAN interface, and assign an IP address to VLAN-interface 2.
7. Click Apply.
2. From the navigation pane, select System > Administrators.
4. Configure the administrator account as follows:
a. Set the username and password to client and aabbcc, respectively.
b. Select network-admin from the user roles list.
c. Select SSH for the permitted access types parameter.
Figure 2 Configure the administrator account
5. Click Apply.
This example uses PuTTY0.58 as the SSH client software to verify the configuration.
1. Execute PuTTY on the host.
2. Enter the IP address of the AC in the Host Name (or IP address) field.
3. Click Open.
4. Verify that you can use username client and password aabbcc to log in to the configuration page of the AC.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
