- 01-System Management
- 01-Telnet Access Control Configuration Example
- 02-IPv6 Telnet Access Control Configuration Example
- 03-Web Access Control Configuration Example
- 04-User Role Assignment for Local Web Authentication Users Configuration Example
- 05-SSH Local Authentication Configuration Example
- 06-SSH User Remote Password Authentication Configuration Example
- 07-IPv6 SSH User Remote Password Authentication Configuration Example
- 08-Password Control Configuration Example
04-User Role Assignment for Local Web Authentication Users Configuration Example | 308.71 KB |
H3C Access Controllers |
Comware 7 User Role Assignment for Local Web Authentication Users |
Example: Assigning a user role to a local Web authentication user
Enabling the HTTP and HTTPS services
Configuring administrator account user1
Overview
The following information provides an example for assigning a user role to a local Web authentication user.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of RBAC.
As shown in Figure 1, the AC performs local authentication for the Web user at 192.168.100.22.
Create user account user1 for the Web user and assign user role role1 to the user account.
Configure the user role to offer the following permissions to the user:
· Access interfaces GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2. Access to any other interfaces is denied.
· Access VLANs 10 to 20. Access to any other VLANs is denied.
Make sure the AC and the Web user can reach each other.
To ensure the security of a new account, the device prompts for setting a new password when you use the account to log in to the device for the first time.
Procedures
1. Click the System View tab at the bottom of the page.
2. From the navigation pane, select Network Configuration > Management Protocols.
3. On the HTTP/HTTPS tab, enable the HTTP and HTTPS services.
Figure 2 Enabling the HTTP and HTTPS services
Configuring user role role1
2. From the navigation pane, select System > Administrators.
3. Click User roles in the top right corner of the page.
4. Click the Create roles button to create a user role:
a. Set the role name to role1.
b. Select Interface list from the Interface access permission field and select GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 from the interface list as permitted interfaces.
c. Select VLAN list from the VLAN access permission field and configure VLANs 10 to 20 as permitted VLANs.
d. Click Apply.
Figure 3 Creating user role role1
5. In the user role list, click the link for the user role in the Rules column to configure user role rules.
Figure 4 Opening the page for configuring user role rules
6. Click the Create rules button to create a user role rule:
a. Set a rule ID.
b. Select the read, write, and execute permissions.
c. Click Apply.
Figure 5 Creating a user role rule
3. Click the Create administrators
button to create an administrator:
a. Set the username to user1 and the password to aabbccddee.
b. Select role1 from the User roles list.
c. Select HTTP and HTTPS from the Permitted access types field.
d. Click Apply.
Figure 6 Creating administrator account user1
1. Use account user1 to log in to the device.
2. Click the System View tab at the bottom of the page.
3. Verify VLAN access permissions:
a. From the navigation pane, select Network Configuration > VLAN.
b. On the VLAN tab, verify that you can create and configure only VLANs 10 to 20. Permission to any other VLANs is denied.
Figure 7 Verifying VLAN access permissions
4. Verify interface access permissions:
a. From the navigation pane, select Network Configuration > Network Interfaces.
b. On the Interfaces tab, verify that the interface list displays only GE 1/0/1 and GE 1/0/2.
Figure 8 Verifying interface access permissions
Related documentation
H3C Access Controllers Web-Based Configuration Guide
