01-System Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Web-Based Configuration Examples-6W10001-System Management
07-IPv6 SSH User Remote Password Authentication Configuration Example
Comware 7 IPv6 SSH User Remote Password Authentication
Overview
The following information provides an example for configuring RADIUS-based remote password authentication for an IPv6 SSH user who wants to log in to the AC to manage it.
The following information applies to Comware 7-based access controllers. Procedures and information in the examples might be slightly different depending on the software or hardware version of the H3C access controllers.
The following information is provided based on the assumption that you have basic knowledge of AAA and SSH.
Example: Configuring remote password authentication for an IPv6 SSH user
As shown in Figure 1, the AC acts as an Stelnet server. It uses a RADIUS server to perform authentication, authorization, and accounting for the SSH user. The authentication method is password.
An IMC server is used as the RADIUS server. Configure an SSH user account (hello@bbb) and the user password on the RADIUS server.
The shared key for secure RADIUS communication is expert. The AC includes the domain name in the username sent to the RADIUS server, so the server can provide services for users according to their domain names.
The SSH user uses an Stelnet client to log in to the AC by providing the username and password configured on the RADIUS server.
Figure 1 Network diagram
Procedures
Configuring the RADIUS server
In this example, the RADIUS server runs on IMC PLAT 7.0 (E0102) and IMC UAM 7.0 (E0201).
Adding the AC to the IMC Platform as an access device
1.     Log in to IMC.
2.     Click the User tab.
3.     From the navigation tree, select User Access Policy> Access Device Management > Access Device.
4.     Click Add.
5.     Configure an access device as follows:
a.     Set the ports for authentication and accounting to 1812 and 1813, respectively.
b.     Select the service type Device Management Service.
c.     Select the access device type H3C(General).
d.     Set the shared key to expert for secure RADIUS communication.
e.     Select the AC from the device list or manually add the AC. (The IPv6 address of the AC is 3000::200).
The IPv6 address of the AC added to the IMC platform must be the same as the source IPv6 address of outgoing RADIUS packets configured on the AC. This example uses the default source IPv6 address of RADIUS packets, which is the IPv6 address of the output interface of the RADIUS packets.
f.     Use the default settings for other parameters.
6.     Click OK.
Figure 2 Adding the AC as an access device
Adding a user account for device management
1.     Click the User tab.
2.     From the navigation tree, select Access User > Device User.
3.     Click Add.
4.     Configure a device management account as follows:
a.     Enter account name hello@bbb and the password.
b.     Select the service type SSH.
c.     Use the default settings for other parameters.
5.     Click OK.
Figure 3 Adding a device management account
Configuring the AC
Enabling the Stelnet service
1.     Click the System View tab at the bottom of the page.
2.     From the navigation pane, select Network Configuration > Management Protocols.
3.     Click the SSH tab.
4.     Enable the Stelnet service.
Figure 4 Enabling the Stelnet service
2.     From the navigation pane, select Network Security > Authentication.
3.     Click the RADIUS tab.
4.     Click the Add button .
5.     Configure a RADIUS scheme:
a.     Enter RADIUS scheme name ssh.
b.     Specify the primary authentication server as 3000::100 and the share key as expert. Use the default settings of other parameters.
c.     Specify the primary accounting server as 3000::100 and the share key as expert. Use the default settings of other parameters.
Figure 5 Configuring the RADIUS server
6.     Click Apply.
Configuring an ISP domain
3.     On the ISP Domains tab, click the Add button .
4.     Configure an ISP domain:
a.     Enter domain name bbb.
b.     Select Login for Service type.
c.     Select RADIUS and specify RADIUS scheme ssh for Authentication, Authorization, and Accounting.
Figure 6 Configuring an ISP domain
5.     Click Apply.
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses PuTTY0.58 to verify the configuration.
1.     Execute PuTTY.
2.     Enter 3000::100 in the Host Name (or IP address) field.
3.     Click Open.
4.     Verify that you can use username hello@bbb and the password to log in to the configuration page of the AC.
Related documentation
H3C Access Controllers Web-Based Configuration Guide
