05-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10005-Layer 2 - LAN Switching
10-LLDP-V2-MIB
10-LLDP-V2-MIB 61.38 KB
LLDP-V2-MIB
About this MIB
This MIB is compliant with IEEE 802.1AB-2009. It defines MIB objects for the following LLDP information:
LLDP configuration.
LLDP statistics.
LLDP local system information.
LLDP neighbor system information.
802.1 extension.
DCBX extension.
802.3 extension.
MIB file name
lldp-v2.mib
Notifications
lldpV2RemTablesChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.111.2.802.1.1.13.0.0.1
LLDP polling is triggered.
Informational
Warning
N/A (N/A)
OFF
Notification triggers
This notification is generated when the value of the lldpV2StatsRemTableLastChangeTime object changes. The network management system can use this notification to trigger LLDP polling to facilitate maintaining remote system entries.
You can set the notification transmission interval by configuring the lldpV2NotificationInterval object.
System impact
No negative impact on the system.
Status control
ON
CLI: Use the lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to true(1).
OFF
CLI: Use the undo lldp notification remote-change enable command.
MIB: Set the lldpV2PortConfigNotificationEnable object to false(2).
Object
OID (object name)
Index
Value range
lldpV2StatsRemTablesInserts
 (1.3.111.2.802.1.1.13.1.2.2)
Neighbor creation.
N/A
ZeroBasedCounter32
Standard MIB values.
lldpV2StatsRemTablesDeletes
 (1.3.111.2.802.1.1.13.1.2.3)
Neighbor deletion.
N/A
ZeroBasedCounter32
lldpV2StatsRemTablesDrops
 (1.3.111.2.802.1.1.13.1.2.4)
Neighbor discard.
N/A
ZeroBasedCounter32
lldpV2StatsRemTablesAgeouts (1.3.111.2.802.1.1.13.1.2.5)
Neighbor ageout.
N/A
ZeroBasedCounter32
Recommended action
1.Verify that the topology changes are as expected.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
