05-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10005-Layer 2 - LAN Switching
08-LLDP-EXT-MED-MIB
08-LLDP-EXT-MED-MIB 37.98 KB
LLDP-EXT-MED-MIB
About this MIB
Use this MIB to obtain TIA-TR41.4 Media Endpoint Discovery (MED) information.
MIB file name
lldp-ext-med.mib
Notifications
lldpXMedTopologyChangeDetected
Basic information
OID
Event
Severity
Recovery notification
Default status
1.0.8802.1.1.2.1.5.4795.0.1
MED neighbor topology changes.
Informational
Warning
OFF
Notification triggers
This notification is generated when the device detects MED neighbor topology changes, such as attaching a peer device to the local device, disconnecting a peer device, or moving a peer device from one port to another port.
System impact
No negative impact on services.
Status control
ON
CLI: Use the lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to true (1).
OFF
CLI: Use the undo lldp notification med-topology-change enable command.
MIB: Set the lldpXMedPortConfigNotifEnable object to false (2).
Object
OID (object name)
Index
Value range
1.0.8802.1.1.2.1.4.1.1.4 (lldpRemChassisIdSubtype)
Neighbor chassis ID type.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpChassisIdSubtype
Standard MIB values.
1.0.8802.1.1.2.1.4.1.1.5 (lldpRemChassisId)
Neighbor chassis ID.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpChassisId
1.0.8802.1.1.2.1.5.4795.1.3.1.1.3 (lldpXMedRemDeviceClass)
Neighbor MED device class.
lldpRemTimeMark
lldpRemLocalPortNum
lldpRemIndex
LldpXMedDeviceClass
Recommended action
Verify that the topology changes are as expected.
If the issue persists, collect alarm information and configuration data, and then contact H3C Support.
