05-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10005-Layer 2 - LAN Switching
05-HH3C-MAC-INFORMATION-MIB
05-HH3C-MAC-INFORMATION-MIB 72.32 KB
About this MIB
Use this MIB to configure MAC Information.
MIB file name
hh3c-mac-information.mib
Notifications
hh3cMACInformationChangedTrapExt
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.1
MAC changes.
Informational
Warning
ON
Notification triggers
This notification is generated when MAC addresses change.
System impact
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.1 (hh3cMACInfoTrapVerExt)
SNMP version.
N/A
Unsigned32
Standard MIB values.
1.3.6.1.4.1.25506.2.87.1.4.2.2 (hh3cMACInfoTrapIndexExt)
Notification index.
N/A
Unsigned32
Unsigned32 (1..2147483647)
1.3.6.1.4.1.25506.2.87.1.4.2.3 (hh3cMACInfoTrapCountExt)
Notification count.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.4 (hh3cMACInfoTrapMsgExt)
Notification contents.
N/A
OCTET STRING
OCTET STRING (1..254)
Recommended action
No action is required.
hh3cMACInformationMovedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.2
A MAC address moves.
Error
Minor
1.3.6.1.4.1.25506.2.87.1.4.0.3 (hh3cMACInformationMovedRsmTrap)
OFF
This notification is generated when a MAC address moves.
System impact
The MAC address move might cause transient interruption of traffic.
Status control
ON
CLI: Use the snmp-agent trap enable mac-address [ mac-move ] command.
OFF
CLI: Use the undo snmp-agent trap enable mac-address [ mac-move ] command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.5.0 (hh3cMACInfoTrapMsgMovedAddress)
MAC address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.6.0 (hh3cMACInfoTrapMsgMovedVlan)
VLAN ID.
N/A
Unsigned32
Unsigned32 (1..4094)
1.3.6.1.4.1.25506.2.87.1.4.2.7.0 (hh3cMACInfoTrapMsgMovedFromIf)
Source port for the MAC address move.
N/A
Unsigned32
Unsigned32(1..2147483647)
1.3.6.1.4.1.25506.2.87.1.4.2.8.0 (hh3cMACInfoTrapMsgMovedToIf)
Destination port for the MAC address move.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.9.0 (hh3cMACInfoTrapMsgMovedCount)
MAC address move count.
N/A
Counter32
1.3.6.1.4.1.25506.2.87.1.4.2.13.0 (hh3cMACInfoTrapMsgChassis)
Chassis ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.14.0 (hh3cMACInfoTrapMsgSlot)
Slot ID.
N/A
Unsigned32
Recommended action
To resolve this issue:
1.Execute the display mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on interfaces.
  - If physical Layer 2 loops exist, remove these loops. If MAC address moves occur frequently after you remove the loops, perform step 2.
  - If no Layer 2 loop exists, perform step 2.
2.Collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
MAC address moves stop.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when MAC address moves stop in a VLAN within a specific time period.
System impact
No impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.6 (hh3cMACInfoTrapMsgMovedVlan)
VLAN ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.13 (hh3cMACInfoTrapMsgChassis)
Chassis ID.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.87.1.4.2.14 (hh3cMACInfoTrapMsgSlot)
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACInfoVsiMovedTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.4
A MAC address moves on a VSI.
Error
Minor
1.3.6.1.4.1.25506.2.87.1.4.0.5 (hh3cMACInfoVsiMovedRsmTrap)
ON
This notification is generated when a MAC address moves on a VSI.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.5 (hh3cMACInfoTrapMsgMovedAddress)
MAC address.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.10 (hh3cMACInfoTrapMsgMovedVsi)
VSI name.
N/A
OCTET STRING
OCTET STRING (1..31)
1.3.6.1.4.1.25506.2.87.1.4.2.11 (hh3cMACInfoTrapMsgMovedFmIfName)
Source interface name for the MAC address move or interface + service instance or link identifier
N/A
OCTET STRING
OCTET STRING (0..255)
1.3.6.1.4.1.25506.2.87.1.4.2.12 (hh3cMACInfoTrapMsgMovedToIfName)
Destination interface name for the MAC address move or interface + service instance or link identifier
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.9 (hh3cMACInfoTrapMsgMovedCount)
N/A
Counter32
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
1.Execute the display l2vpn mac-address mac-move command to view the MAC address move records, and check whether physical Layer 2 loops exist on the VSI.
Basic information
OID
Event
Severity
Default status
MAC address moves stop on a VSI.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when MAC address moves stop on a VSI within a specific time period.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
VSI name.
N/A
OCTET STRING
Chassis ID.
N/A
Unsigned32
Slot ID.
N/A
Unsigned32
Recommended action
hh3cMACInfoMovedIfBlockTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.87.1.4.0.6
MAC address move suppression is triggered on an interface due to frequent MAC address moves.
Error
Critical
1.3.6.1.4.1.25506.2.87.1.4.0.7 (hh3cMACInfoMovedIfResumeTrap)
ON
This notification is generated when MAC address move suppression is triggered on an interface due to frequent MAC address moves, and this interface will be shut down for a suppression interval.
System impact
MAC address move suppression might cause service interruption on the shutdown interface.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.87.1.4.2.15 (hh3cMACInfoTrapMsgBlockIfName)
Interface name.
N/A
OCTET STRING
1.3.6.1.4.1.25506.2.87.1.4.2.16 (hh3cMACInfoTrapMsgBlockTime)
Suppression interval (seconds).
N/A
Unsigned32
Unsigned32(30..86400)
MAC address.
N/A
OCTET STRING
VLAN ID.
N/A
Unsigned32
Recommended action
1.Check whether physical Layer 2 loops exist in the VLAN.
Basic information
OID
Event
Severity
Default status
An interface recovers from MAC address move suppression.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when an interface goes up after a suppression interval elapses.
System impact
Services interrupted due to MAC address move suppression are restored.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Interface name.
N/A
OCTET STRING
N/A
Unsigned32
VLAN ID.
N/A
Unsigned32
Recommended action
