05-Layer 2 - LAN Switching
HomeSupportRoutersCR16000-F SeriesDiagnose & MaintainAlarms ReferencesH3C CR16000-F Routers Alarm Reference-R838x-6W10005-Layer 2 - LAN Switching
07-IEEE8021-CFM-MIB
07-IEEE8021-CFM-MIB 38.53 KB
IEEE8021-CFM-MIB
About this MIB
Connectivity Fault Management (CFM) is the name of the feature defined in IEEE 802.1ag for end-to-end Operations, Administration and Maintenance (OAM) for Ethernet. In the Comware platform, the feature is called Connectivity Fault Detection (CFD).
CFD is an end-to-end per-VLAN link layer OAM mechanism. CFD is used for link connectivity detection, fault verification, and fault location.
This MIB defines how to implement CFD. Use this MIB to configure CFD on managed devices.
MIB file name
ieee8021-cfm.mib
Notifications
dot1agCfmFaultAlarm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.111.2.802.1.1.8.0.1
A MEP error occurs.
Informational
Warning
N/A (N/A)
ON
Notification triggers
This notification is sent when the MEP continuously fails.
Possible causes might include the following:
The CFD entities at the two ends have inconsistent MDs or MAs.
The CFD entities at the two ends have inconsistent CCM intervals.
The MEP ID in CCMs is not in the MEP ID on the local end.
No CCM is received upon expiration of the specified timer.
System impact
Continuity check cannot be performed. Service traffic switchover or interruption might occur.
Status control
This notification cannot be disabled.
Object
OID (object name)
Index
Value range
1.3.111.2.802.1.1.8.1.5.2.1.1 (dot1agCfmMdIndex)
MD index.
dot1agCfmMdIndex
Integer32
1.. 4294967295
1.3.111.2.802.1.1.8.1.6.1.1.1 (dot1agCfmMaIndex)
MA index.
dot1agCfmMaIndex
Integer32
1.. 4294967295
1.3.111.2.802.1.1.8.1.7.1.1.1 (dot1agCfmMepIdentifier)
MEP ID and ultimate index in the MEP list
dot1agCfmMdIndex
dot1agCfmMaIndex
Integer32
1.. 8191
1.3.111.2.802.1.1.8.1.7.1.1.13 (dot1agCfmMepHighestPrDefect)
Detected faulty MEP.
dot1agCfmMdIndex
dot1agCfmMaIndex
Dot1agCfmHighestDefectPri
none (0), defRemoteCCM (3), defErrorCCM (4), defXconCCM (5)
Recommended action
To resolve this issue:
1.Identify whether the CFD configuration is correct.
2.Identify whether the port and link states are normal.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
