- 08-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-BPA-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DHCP4-CLIENT-MIB
- 07-HH3C-DHCP4-MIB
- 08-HH3C-DHCP6-MIB
- 09-HH3C-FIB-MIB
- 10-HH3C-IP-ADDRESS-MIB
- 11-HH3C-IPFW-MIB
- 12-HH3C-IPV6-ADDRESS-MIB
- 13-HH3C-NAT-MIB
- 14-HH3C-ND-TRAP-MIB
- 15-HH3C-SESSION-MIB
- 16-HH3C-TCP-MIB
- 17-HH3C-TUNNEL-TRAP-MIB
- 18-HH3C-DNS-MIB
- 19-IP-MIB
- 20-IPV6-ICMP-MIB
- 21-IPV6-MIB
- 22-IPV6-TCP-MIB
- 23-IPV6-UDP-MIB
- 24-TCP-MIB
- 25-UDP-MIB
| 19-IP-MIB | 176.67 KB |
IP-MIB
About this MIB
Use this MIB to obtain device IP and ICMP basic information and packet statistics.
MIB file name
rfc4293-ip.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ipMIB(48)
Tabular objects
ipAddrTable
About this table
This table contains IPv4 address information.
Support for operations
Create:Not supported
Edit/Modify:Not supported
Delete:Not supported
Read:Supported
Columns
The table index is ipAdEntAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipAdEntAddr (1.3.6.1.2.1.4.20.1.1) |
read-only |
IpAddress |
Standard MIB values. |
IP address. |
As per the MIB. |
ipAdEntIfIndex (1.3.6.1.2.1.4.20.1.2) |
read-only |
INTEGER |
INTEGER (1..2147483647) |
Index of the interface corresponding to the entry. |
As per the MIB. |
ipAdEntNetMask (1.3.6.1.2.1.4.20.1.3) |
read-only |
IpAddress |
Subnet mask of the IP address. |
As per the MIB. |
ipAdEntBcastAddr (1.3.6.1.2.1.4.20.1.4) |
read-only |
INTEGER |
INTEGER (0..1) |
Value of the least-significant bit in the IP broadcast address used for sending packets on the (logical) interface associated with the IP address of this entry. For example, when the Internet standard all-ones broadcast address is used, the value is 1. |
As per the MIB. |
ipAdEntReasmMaxSize (1.3.6.1.2.1.4.20.1.5) |
read-only |
INTEGER |
INTEGER (0..65535) |
Maximum size of an IP packet which the entry can reassemble from fragments. |
As per the MIB. |
ipNetToMediaTable
About this table
This table contains IPv4 address-to-physical address mappings.
Read:Supported
Columns
The table indexes are ipNetToMediaIfIndex and ipNetToMediaNetAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipNetToMediaIfIndex (1.3.6.1.2.1.4.22.1.1) |
read-write |
INTEGER |
Supports only the read operation. |
ipNetToMediaPhysAddress (1.3.6.1.2.1.4.22.1.2) |
read-write |
PhysAddress |
SIZE(0..65535) |
Physical address of the media. |
ipNetToMediaNetAddress (1.3.6.1.2.1.4.22.1.3) |
read-write |
IpAddress |
IP address corresponding to the media’s physical address. |
ipNetToMediaType (1.3.6.1.2.1.4.22.1.4) |
read-write |
INTEGER |
other(1), invalid(2), dynamic(3), static(4) |
Mapping type. Setting this object to the value invalid(2) invalidates the corresponding entry in the ipNetTomediaTable. You can use this object to disassociate the interface from the mapping. |
ipv6InterfaceTable
About this table
This table contains detailed IPv6 information about each interface.
Read:Supported
Columns
The table index is ipv6InterfaceIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6InterfaceIfIndex (1.3.6.1.2.1.4.30.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipv6InterfaceReasmMaxSize (1.3.6.1.2.1.4.30.1.2) |
read-only |
Unsigned32 |
Unsigned32 (1500..65535) |
Maximum size of an IPv6 packet that the entry can reassemble from fragments received on the interface. |
As per the MIB. |
ipv6InterfaceIdentifier (1.3.6.1.2.1.4.30.1.3) |
read-only |
Ipv6AddressIfIdentifierTC |
Interface identifier. An IPv6 interface address is an interface identifier attached with an address prefix. By default, the Interface Identifier is auto-configured according to the rules of the interface link type. The length of an interface identifier might be zero for specific interfaces, such as a loopback interface. |
As per the MIB. |
ipv6InterfaceEnableStatus (1.3.6.1.2.1.4.30.1.5) |
read-write |
INTEGER |
up(1), down(2) |
IPv6 enablement status on the interface. |
ipv6InterfaceReachableTime (1.3.6.1.2.1.4.30.1.6) |
read-only |
Unsigned32 |
Time used to reach a neighbor based on the received reachability confirmation. |
As per the MIB. |
ipv6InterfaceRetransmitTime (1.3.6.1.2.1.4.30.1.7) |
read-only |
Unsigned32 |
Interval at which Neighbor Solicitation messages are retransmitted during address resolving or neighbor reachability probing. |
As per the MIB. |
ipv6InterfaceForwarding (1.3.6.1.2.1.4.30.1.8) |
read-write |
INTEGER |
forwarding(1), notForwarding(2) |
Whether the object is an IPv6 router that can forward data packets destined to any other devices. |
ipSystemStatsTable
About this table
This table contains IP traffic statistics in the current system.
Read:Supported
Columns
The table index is ipSystemStatsIPVersion.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipSystemStatsIPVersion (1.3.6.1.2.1.4.31.1.1.1) |
not-accessible |
InetVersion |
IP version of the current entry. |
Supports only ipv4(1) and ipv6(2). |
ipSystemStatsInReceives (1.3.6.1.2.1.4.31.1.1.3) |
read-only |
Counter32 |
Number of received IP packets in the system, including error packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsHCInReceives (1.3.6.1.2.1.4.31.1.1.4) |
read-only |
Counter64 |
Number of received IP packets in the system, including error packets. This object counts the same packets as ipSystemStatsInReceives, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInOctets (1.3.6.1.2.1.4.31.1.1.5) |
read-only |
Counter32 |
Total octets of received IP packets in the system, including error packets.
As per the MIB. |
ipSystemStatsHCInOctets (1.3.6.1.2.1.4.31.1.1.6) |
read-only |
Counter64 |
Total octets of received IP packets in the system, including error packets. This object counts the same octets as ipSystemStatsInOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInHdrErrors (1.3.6.1.2.1.4.31.1.1.7) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of IP header errors, including version number mismatch, other format errors, hop count exceeded, and IP option processing errors.
As per the MIB. |
ipSystemStatsInNoRoutes (1.3.6.1.2.1.4.31.1.1.8) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of no route to the destination can be found. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInAddrErrors (1.3.6.1.2.1.4.31.1.1.9) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of an invalid destination address in the IP header, for example, address 0.0.0.0.
For a non-IP gateway entity, it drops packets destined to any other devices because such entities cannot forward traffic. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInUnknownProtos (1.3.6.1.2.1.4.31.1.1.10) |
read-only |
Counter32 |
Number of received locally-addressed packets that were dropped because of an unknown or unsupported protocol. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInTruncatedPkts (1.3.6.1.2.1.4.31.1.1.11) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of an invalid data length. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsInForwDatagrams (1.3.6.1.2.1.4.31.1.1.12) |
read-only |
Counter32 |
Number of forwarded packets. Forwarded packets are those that are not locally-addressed and require the system to find a route to forward them. For non-router devices, this counter counts only source-routed packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsHCInForwDatagrams (1.3.6.1.2.1.4.31.1.1.13) |
read-only |
Counter64 |
Number of forwarded packets. Forwarded packets are those that are not locally-addressed and require the system to find a route to forward them. This object counts the same packets as ipSystemStatsInForwDatagrams, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsReasmReqds (1.3.6.1.2.1.4.31.1.1.14) |
read-only |
Counter32 |
Number of received fragments that need to be reassembled. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsReasmOKs (1.3.6.1.2.1.4.31.1.1.15) |
read-only |
Counter32 |
Number of packets successfully reassembled. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsReasmFails (1.3.6.1.2.1.4.31.1.1.16) |
read-only |
Counter32 |
Number of packet reassembly failures detected by the IP reassembly algorithm because of reasons such as timeout or errors. The system does not calculate the number of dropped fragments because some algorithms do not record fragment quantity information. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInDiscards (1.3.6.1.2.1.4.31.1.1.17) |
read-only |
Counter32 |
Number of received packets that should be processed, but were dropped because of reasons such as insufficient buffer space. This value does not include packet fragments dropped because of reassembly timeout. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInDelivers (1.3.6.1.2.1.4.31.1.1.18) |
read-only |
Counter32 |
Number of received packets successfully delivered to IP user-protocols. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsHCInDelivers (1.3.6.1.2.1.4.31.1.1.19) |
read-only |
Counter64 |
Number of received packets successfully delivered to IP user-protocols. This object counts the same packets as ipSystemStatsInDelivers, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsOutRequests (1.3.6.1.2.1.4.31.1.1.20) |
read-only |
Counter32 |
Number of packets that local IP user-protocols (including ICMP) supplied to IP in requests for transmission. This counter does not include any packets counted in ipSystemStatsOutForwDatagrams. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsHCOutRequests (1.3.6.1.2.1.4.31.1.1.21) |
read-only |
Counter64 |
Number of packets that local IP user-protocols (including ICMP) supplied to IP in requests for transmission. This object counts the same packets as ipSystemStatsOutRequests, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsOutNoRoutes (1.3.6.1.2.1.4.31.1.1.22) |
read-only |
Counter32 |
Number of IP packets dropped because no route to the destination can be found. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutForwDatagrams (1.3.6.1.2.1.4.31.1.1.23) |
read-only |
Counter32 |
Number of packets forwarded successfully. For non-router devices, this counter counts only source-routed packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsHCOutForwDatagrams (1.3.6.1.2.1.4.31.1.1.24) |
read-only |
Counter64 |
Number of packets forwarded successfully. This object counts the same packets as ipSystemStatsOutForwDatagrams, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutDiscards (1.3.6.1.2.1.4.31.1.1.25) |
read-only |
Counter32 |
Number of outgoing packets that should be processed, but were dropped because of reasons such as insufficient buffer space. This value might be included in the counting of ipSystemStatsOutForwDatagrams. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutFragReqds (1.3.6.1.2.1.4.31.1.1.26) |
read-only |
Counter32 |
Number of IP packets that require fragmentation for forwarding. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutFragOKs (1.3.6.1.2.1.4.31.1.1.27) |
read-only |
Counter32 |
Number of IP packets that were fragmented successfully. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutFragFails (1.3.6.1.2.1.4.31.1.1.28) |
read-only |
Counter32 |
Number of IP packets that need fragmentation but were dropped because of fragmentation failures, including IPv4 packets with the DF flag set and IPv6 packets whose length exceeds the MTU size.
As per the MIB. |
ipSystemStatsOutFragCreates (1.3.6.1.2.1.4.31.1.1.29) |
read-only |
Counter32 |
Number of packets created because of IP packet fragmentation. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutTransmits (1.3.6.1.2.1.4.31.1.1.30) |
read-only |
Counter32 |
Number of IP packets supplied to the lower layers for transmission, including both locally generated packets and forwarded packets.
As per the MIB. |
ipSystemStatsHCOutTransmits (1.3.6.1.2.1.4.31.1.1.31) |
read-only |
Counter64 |
Number of IP packets supplied to the lower layers for transmission, including both locally generated packets and forwarded packets. This object counts the same packets as ipSystemStatsOutTransmits, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsOutOctets (1.3.6.1.2.1.4.31.1.1.32) |
read-only |
Counter32 |
Total octets of IP packets supplied to the lower layers for transmission, including packets counted in ipSystemStatsOutTransmits.
As per the MIB. |
ipSystemStatsHCOutOctets (1.3.6.1.2.1.4.31.1.1.33) |
read-only |
Counter64 |
Total octets of IP packets supplied to the lower layers for transmission. This object counts the same octets as ipSystemStatsOutOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
As per the MIB. |
ipSystemStatsInMcastPkts (1.3.6.1.2.1.4.31.1.1.34) |
read-only |
Counter32 |
Number of received IP multicast packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsHCInMcastPkts (1.3.6.1.2.1.4.31.1.1.35) |
read-only |
Counter64 |
Number of received IP multicast packets. This object counts the same packets as ipSystemStatsInMcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsInMcastOctets (1.3.6.1.2.1.4.31.1.1.36) |
read-only |
Counter32 |
Total octets of received IP multicast packets, including packets counted in ipSystemStatsInMcastPkts.
Not supported |
ipSystemStatsHCInMcastOctets (1.3.6.1.2.1.4.31.1.1.37) |
read-only |
Counter64 |
Total octets of received IP multicast packets. This object counts the same octets as ipSystemStatsInMcastOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsOutMcastPkts (1.3.6.1.2.1.4.31.1.1.38) |
read-only |
Counter32 |
Number of sent IP multicast packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsHCOutMcastPkts (1.3.6.1.2.1.4.31.1.1.39) |
read-only |
Counter64 |
Number of sent IP multicast packets. This object counts the same packets as ipSystemStatsOutMcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsOutMcastOctets (1.3.6.1.2.1.4.31.1.1.40) |
read-only |
Counter32 |
Total octets of sent IP multicast packets, including packets counted in ipSystemStatsOutMcastPkts.
Not supported |
ipSystemStatsHCOutMcastOctets (1.3.6.1.2.1.4.31.1.1.41) |
read-only |
Counter64 |
Total octets of sent IP multicast packets. This object counts the same octets as ipSystemStatsOutMcastOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsInBcastPkts (1.3.6.1.2.1.4.31.1.1.42) |
read-only |
Counter32 |
Number of received IP broadcast packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsHCInBcastPkts (1.3.6.1.2.1.4.31.1.1.43) |
read-only |
Counter64 |
Number of received IP broadcast packets. This object counts the same packets as ipSystemStatsInBcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsOutBcastPkts (1.3.6.1.2.1.4.31.1.1.44) |
read-only |
Counter32 |
Number of sent IP broadcast packets. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsHCOutBcastPkts (1.3.6.1.2.1.4.31.1.1.45) |
read-only |
Counter64 |
Number of sent IP broadcast packets. This object counts the same packets as ipSystemStatsOutBcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipSystemStatsDiscontinuityTime object. |
Not supported |
ipSystemStatsDiscontinuityTime (1.3.6.1.2.1.4.31.1.1.46) |
read-only |
TimeStamp |
The most recent time at which any count in the table was interrupted (sysUpTime). If no count interrupt has occurred since the last system restart, the value of this object is 0. |
Not supported |
ipSystemStatsRefreshRate (1.3.6.1.2.1.4.31.1.1.47) |
read-only |
Unsigned32 |
Minimum reasonable polling interval for this table. This object provides an indication of the minimum amount of time required to update the counters in this table. |
Not supported |
ipIfStatsTable
About this table
This table contains IP traffic statistics about each interface.
Read:Supported
Columns
The table indexes are ipIfStatsIPVersion and ipIfStatsIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipIfStatsIPVersion (1.3.6.1.2.1.4.31.3.1.1) |
not-accessible |
InetVersion |
ipIfStatsIfIndex (1.3.6.1.2.1.4.31.3.1.2) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipIfStatsInReceives (1.3.6.1.2.1.4.31.3.1.3) |
read-only |
Counter32 |
Number of received IP packets, including error packets. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsHCInReceives (1.3.6.1.2.1.4.31.3.1.4) |
read-only |
Counter64 |
Number of received IP packets, including error packets. This object counts the same packets as ipIfStatsInReceives, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsInOctets (1.3.6.1.2.1.4.31.3.1.5) |
read-only |
Counter32 |
Total octets of received IP packets, including error packets.
As per the MIB. |
ipIfStatsHCInOctets (1.3.6.1.2.1.4.31.3.1.6) |
read-only |
Counter64 |
Total octets of received IP packets, including error packets. This objects counts the same octets as ipIfStatsInOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsInHdrErrors (1.3.6.1.2.1.4.31.3.1.7) |
read-only |
Counter32 |
As per the MIB. Supports only ipv6(2). |
ipIfStatsInNoRoutes (1.3.6.1.2.1.4.31.3.1.8) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of no route to the destination can be found. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInAddrErrors (1.3.6.1.2.1.4.31.3.1.9) |
read-only |
Counter32 |
For a non-IP gateway entity, it drops packets destined to any other devices because such entities cannot forward traffic. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInUnknownProtos (1.3.6.1.2.1.4.31.3.1.10) |
read-only |
Counter32 |
Number of received packets destined to the local IP address but dropped because of unsupported protocol or unknown reasons. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInTruncatedPkts (1.3.6.1.2.1.4.31.3.1.11) |
read-only |
Counter32 |
Number of received IP packets that were dropped because of an invalid data length. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInForwDatagrams (1.3.6.1.2.1.4.31.3.1.12) |
read-only |
Counter32 |
Number of forwarded packets. Forwarded packets are those that are not locally-addressed and require the system to find a route to forward them. For non-router devices, this counter counts only source-routed packets. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsHCInForwDatagrams (1.3.6.1.2.1.4.31.3.1.13) |
read-only |
Counter64 |
Number of forwarded packets. Forwarded packets are those that are not locally-addressed and require the system to find a route to forward them. This object counts the same packets as ipIfStatsInForwDatagrams, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsReasmReqds (1.3.6.1.2.1.4.31.3.1.14) |
read-only |
Counter32 |
Number of received fragments that need to be reassembled. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsReasmOKs (1.3.6.1.2.1.4.31.3.1.15) |
read-only |
Counter32 |
Number of packets successfully reassembled. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsReasmFails (1.3.6.1.2.1.4.31.3.1.16) |
read-only |
Counter32 |
Number of packet reassembly failures detected by the IP reassembly algorithm because of reasons such as timeout and errors. The system does not calculate the number of dropped fragments because some algorithms do not record fragment quantity information. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInDiscards (1.3.6.1.2.1.4.31.3.1.17) |
read-only |
Counter32 |
Number of received packets that should be processed, but were dropped because of reasons such as insufficient buffer space. This value does not include packet fragments dropped because of reassembly timeout. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsInDelivers (1.3.6.1.2.1.4.31.3.1.18) |
read-only |
Counter32 |
Number of received packets successfully delivered to IP user-protocols. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsHCInDelivers (1.3.6.1.2.1.4.31.3.1.19) |
read-only |
Counter64 |
Number of received packets successfully delivered to IP user-protocols. This object counts the same packets as ipIfStatsInDelivers, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsOutRequests (1.3.6.1.2.1.4.31.3.1.20) |
read-only |
Counter32 |
Number of packets that local IP user-protocols (including ICMP) supplied to IP in requests for transmission. This counter does not include any packets counted in ipIfStatsOutForwDatagrams. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsHCOutRequests (1.3.6.1.2.1.4.31.3.1.21) |
read-only |
Counter64 |
Number of packets that local IP user-protocols (including ICMP) supplied to IP in requests for transmission. This object counts the same packets as ipIfStatsOutRequests, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsOutForwDatagrams (1.3.6.1.2.1.4.31.3.1.23) |
read-only |
Counter32 |
Number of packets forwarded successfully. For non-router devices, this counter counts only source-routed packets. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsHCOutForwDatagrams (1.3.6.1.2.1.4.31.3.1.24) |
read-only |
Counter64 |
Number of packets forwarded successfully. This object counts the same packets as ipIfStatsOutForwDatagrams, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsOutDiscards (1.3.6.1.2.1.4.31.3.1.25) |
read-only |
Counter32 |
Number of outgoing packets that should be processed, but were dropped because of reasons such as insufficient buffer space. This value might be included in the counting of ipIfStatsOutForwDatagrams. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsOutFragReqds (1.3.6.1.2.1.4.31.3.1.26) |
read-only |
Counter32 |
Number of IP packets that require fragmentation for forwarding. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsOutFragOKs (1.3.6.1.2.1.4.31.3.1.27) |
read-only |
Counter32 |
Number of IP packets that were fragmented successfully. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsOutFragFails (1.3.6.1.2.1.4.31.3.1.28) |
read-only |
Counter32 |
ipIfStatsOutFragCreates (1.3.6.1.2.1.4.31.3.1.29) |
read-only |
Counter32 |
Number of packets created because of IP packet fragmentation. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsOutTransmits (1.3.6.1.2.1.4.31.3.1.30) |
read-only |
Counter32 |
As per the MIB. |
ipIfStatsHCOutTransmits (1.3.6.1.2.1.4.31.3.1.31) |
read-only |
Counter64 |
Number of IP packets supplied to the lower layers for transmission, including both locally generated packets and forwarded packets. This object counts the same packets as ipIfStatsOutTransmits, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsOutOctets (1.3.6.1.2.1.4.31.3.1.32) |
read-only |
Counter32 |
Total octets of IP packets supplied to the lower layers for transmission, including packets counted in ipIfStatsOutTransmits.
As per the MIB. |
ipIfStatsHCOutOctets (1.3.6.1.2.1.4.31.3.1.33) |
read-only |
Counter64 |
Total octets of IP packets supplied to the lower layers for transmission, including packets counted in ipIfStatsOutTransmits. This object counts the same octets as ipIfStatsOutOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
As per the MIB. |
ipIfStatsInMcastPkts (1.3.6.1.2.1.4.31.3.1.34) |
read-only |
Counter32 |
Number of received IP multicast packets. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsHCInMcastPkts (1.3.6.1.2.1.4.31.3.1.35) |
read-only |
Counter64 |
Number of received IP multicast packets. This object counts the same packets as ipIfStatsInMcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsInMcastOctets (1.3.6.1.2.1.4.31.3.1.36) |
read-only |
Counter32 |
Total octets of received IP multicast packets, including packets counted in ipIfStatsInMcastPkts.
Not supported |
ipIfStatsHCInMcastOctets (1.3.6.1.2.1.4.31.3.1.37) |
read-only |
Counter64 |
Total octets of received IP multicast packets, including packets counted in ipIfStatsInMcastPkts. This object counts the same octets as ipIfStatsInMcastOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsOutMcastPkts (1.3.6.1.2.1.4.31.3.1.38) |
read-only |
Counter32 |
Number of sent IP multicast packets. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
ipIfStatsHCOutMcastPkts (1.3.6.1.2.1.4.31.3.1.39) |
read-only |
Counter64 |
Number of sent IP multicast packets. This object counts the same packets as ipIfStatsOutMcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsOutMcastOctets (1.3.6.1.2.1.4.31.3.1.40) |
read-only |
Counter32 |
Total octets of sent IP multicast packets, including packets counted in ipIfStatsOutMcastPkts.
Not supported |
ipIfStatsHCOutMcastOctets (1.3.6.1.2.1.4.31.3.1.41) |
read-only |
Counter64 |
Total octets of received IP multicast packets. This object counts the same octets as ipIfStatsOutMcastOctets, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsInBcastPkts (1.3.6.1.2.1.4.31.3.1.42) |
read-only |
Counter32 |
Not supported |
ipIfStatsHCInBcastPkts (1.3.6.1.2.1.4.31.3.1.43) |
read-only |
Counter64 |
Number of received IP multicast packets. This object counts the same packets as ipIfStatsInBcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsOutBcastPkts (1.3.6.1.2.1.4.31.3.1.44) |
read-only |
Counter32 |
Not supported |
ipIfStatsHCOutBcastPkts (1.3.6.1.2.1.4.31.3.1.45) |
read-only |
Counter64 |
Number of sent IP multicast packets. This object counts the same packets as ipIfStatsOutBcastPkts, but allows for larger values. The statistics collection starts at system startup or at the time indicated by the ipIfStatsDiscontinuityTime object. |
Not supported |
ipIfStatsDiscontinuityTime (1.3.6.1.2.1.4.31.3.1.46) |
read-only |
TimeStamp |
Not supported |
ipIfStatsRefreshRate (1.3.6.1.2.1.4.31.3.1.47) |
read-only |
Unsigned32 |
Not supported |
ipAddressPrefixTable
About this table
This table contains information about IP address prefixes.
Read:Supported
Columns
The table indexes are ipAddressPrefixIfIndex, ipAddressPrefixType, ipAddressPrefixPrefix, and ipAddressPrefixLength.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipAddressPrefixIfIndex (1.3.6.1.2.1.4.32.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipAddressPrefixType (1.3.6.1.2.1.4.32.1.2) |
not-accessible |
InetAddressType |
Address type of ipAddressPrefix. |
Supports only ipv6(2) and ipv6z(4). |
ipAddressPrefixPrefix (1.3.6.1.2.1.4.32.1.3) |
not-accessible |
InetAddress |
Address prefix. The address type is specified in ipAddressPrefixType. The address length is the standard length for objects of that type (4 or 16 bytes). If the prefix length exceeds 114 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3. |
As per the MIB. |
ipAddressPrefixLength (1.3.6.1.2.1.4.32.1.4) |
not-accessible |
InetAddressPrefixLength |
Prefix length. The value 0 refers to address ::/0. |
As per the MIB. |
ipAddressPrefixOrigin (1.3.6.1.2.1.4.32.1.5) |
read-only |
IpAddressPrefixOriginTC |
Other(1) Manual(2) Wellknown(3) Dhcp(4) Routeready(5) |
Prefix origin. |
As per the MIB. |
ipAddressPrefixOnLinkFlag (1.3.6.1.2.1.4.32.1.6) |
read-only |
TruthValue |
true(1), false(2) |
Whether this prefix can be used for on-link determination. The value true(1) indicates yes and the value false(2) indicates no. For IPv4 prefixes, the default value is true(1). |
As per the MIB. |
ipAddressPrefixAutonomousFlag (1.3.6.1.2.1.4.32.1.7) |
read-only |
TruthValue |
true(1), false(2) |
Whether this prefix can be used for autonomous address configuration. The value true(1) indicates yes and the value false(2) indicates no. For IPv4 prefixes, the default value is false(2). |
As per the MIB. |
ipAddressPrefixAdvPreferredLifetime (1.3.6.1.2.1.4.32.1.8) |
read-only |
Unsigned32 |
Remaining lifetime of the prefix in seconds. A value of 4,294,967,295 represents infinity. After the lifetime expires, the prefix will be deprecated. Addresses generated by using a deprecated prefix cannot be used as the source addresses in new communications, but packets received on such an interface are processed as expected. For IPv4 prefixes, the default lifetime is 4,294,967,295 (infinity). |
As per the MIB. |
ipAddressPrefixAdvValidLifetime (1.3.6.1.2.1.4.32.1.9) |
read-only |
Unsigned32 |
Remaining validity period of the prefix in seconds. A value of 4,294,967,295 represents infinity. Addresses generated by using an invalid prefix cannot be used as source or destination addresses of packets. For IPv4 prefixes, the default validity period is 4,294,967,295 (infinity). |
As per the MIB. |
ipAddressTable
About this table
This table contains IP address information.
Read:Supported
Columns
The table indexes are ipAddressAddrType and ipAddressAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipAddressAddrType (1.3.6.1.2.1.4.34.1.1) |
not-accessible |
InetAddressType |
Address type of ipAddressAddr. |
ipAddressAddr (1.3.6.1.2.1.4.34.1.2) |
not-accessible |
InetAddress |
IP address. The address type is specified in ipAddressAddrType. If the address length exceeds 116 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3. |
As per the MIB. |
ipAddressIfIndex (1.3.6.1.2.1.4.34.1.3) |
read-create |
InterfaceIndex |
Index of the interface corresponding to the address. |
ipAddressType (1.3.6.1.2.1.4.34.1.4) |
read-create |
INTEGER |
unicast(1), anycast(2), broadcast(3) |
Address type. For IPv6 addresses, broadcast(3) is not a valid value. |
ipAddressPrefix (1.3.6.1.2.1.4.34.1.5) |
read-only |
RowPointer |
A pointer to the row in the prefix table to which this address belongs. If the row does not exist, this object is { 0 0 }. |
As per the MIB. |
ipAddressOrigin (1.3.6.1.2.1.4.34.1.6) |
read-only |
IpAddressOriginTC |
IP address origin. |
As per the MIB. |
ipAddressStatus (1.3.6.1.2.1.4.34.1.7) |
read-create |
IpAddressStatusTC |
Address status, indicating whether the address can be used for communication. In the absence of other information, an IPv4 address is always preferred(1). |
ipAddressCreated (1.3.6.1.2.1.4.34.1.8) |
read-only |
TimeStamp |
Time at which the entry was created (sysUpTime). If the entry was created before the most recent system startup, this value is 0. |
As per the MIB. |
ipAddressLastChanged (1.3.6.1.2.1.4.34.1.9) |
read-only |
TimeStamp |
Time at which the entry was last updated (sysUpTime). If the last update occurred before the most recent system startup, this value is 0. |
As per the MIB. |
ipAddressRowStatus (1.3.6.1.2.1.4.34.1.10) |
read-create |
RowStatus |
Status of the entry. |
Supports only the read operation. Supports only active(1). |
ipAddressStorageType (1.3.6.1.2.1.4.34.1.11) |
read-only |
StorageType |
Storage type of the entry. |
The value is fixed to volatile(2). |
ipNetToPhysicalTable
About this table
This table contains IP address-to-physical address mappings.
Read:Supported
Columns
The table indexes are ipNetToPhysicalIfIndex, ipNetToPhysicalNetAddressType, and ipNetToPhysicalNetAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipNetToPhysicalIfIndex (1.3.6.1.2.1.4.35.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipNetToPhysicalNetAddressType (1.3.6.1.2.1.4.35.1.2) |
not-accessible |
InetAddressType |
Address type of ipNetToPhysicalNetAddress. |
ipNetToPhysicalNetAddress (1.3.6.1.2.1.4.35.1.3) |
not-accessible |
InetAddress |
IP address. The address type is specified in ipNetToPhysicalAddressType. |
As per the MIB. |
ipNetToPhysicalPhysAddress (1.3.6.1.2.1.4.35.1.4) |
read-create |
PhysAddress |
SIZE(0..65535) |
Physical address. |
ipNetToPhysicalLastUpdated (1.3.6.1.2.1.4.35.1.5) |
read-only |
TimeStamp |
As per the MIB. |
ipNetToPhysicalType (1.3.6.1.2.1.4.35.1.6) |
read-create |
INTEGER |
other(1), invalid(2), dynamic(3), static(4), local(5) |
Address mapping type. |
ipNetToPhysicalState (1.3.6.1.2.1.4.35.1.7) |
read-only |
INTEGER |
reachable(1), stale(2), delay(3), probe(4), invalid(5), unknown(6), incomplete(7) |
Neighbor unreachability detection state. If neighbor unreachability detection is not performed, the value is unknown(6). |
As per the MIB. |
ipNetToPhysicalRowStatus (1.3.6.1.2.1.4.35.1.8) |
read-create |
RowStatus |
ipDefaultRouterTable
About this table
This table contains information about the default routers.
Read:Supported
Columns
The table indexes are ipDefaultRouterAddressType, ipDefaultRouterAddress, and ipDefaultRouterIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipDefaultRouterAddressType (1.3.6.1.2.1.4.37.1.1) |
not-accessible |
InetAddressType |
Address type of the entry. |
ipDefaultRouterAddress (1.3.6.1.2.1.4.37.1.2) |
not-accessible |
InetAddress |
IP address. The address type is specified in ipDefaultRouterAddressType. If the address length exceeds 115 octets, then OIDs of the instances will have more than 128 sub-identifiers and cannot be accessed by using SNMPv1, SNMPv2c, or SNMPv3. |
As per the MIB. |
ipDefaultRouterIfIndex (1.3.6.1.2.1.4.37.1.3) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipDefaultRouterLifetime (1.3.6.1.2.1.4.37.1.4) |
read-only |
Unsigned32 |
Unsigned32 (0..65535) |
Remaining time that the router can be used as a default router, in seconds. A value of 0 indicates that the router is no longer used as a default router. |
As per the MIB. |
ipDefaultRouterPreference (1.3.6.1.2.1.4.37.1.5) |
read-only |
INTEGER |
reserved (-2), low (-1), medium (0), high (1) |
Priority of the default router. The priority value is a 2-bit signed integer that allows for simple arithmetic comparisons. |
As per the MIB. |
ipv6RouterAdvertTable
About this table
This table contains information used to construct router advertisements.
Read:Supported
Columns
The table index is ipv6RouterAdvertIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipv6RouterAdvertIfIndex (1.3.6.1.2.1.4.39.1.1) |
not-accessible |
InterfaceIndex |
As per the MIB. |
ipv6RouterAdvertSendAdverts (1.3.6.1.2.1.4.39.1.2) |
read-create |
TruthValue |
A flag indicating whether the router sends periodic router advertisements and responds to router solicitations. |
ipv6RouterAdvertMaxInterval (1.3.6.1.2.1.4.39.1.3) |
read-create |
Unsigned32 |
Unsigned32 (4..1800) |
Maximum interval at which unsolicited router advertisements are sent, in seconds. |
ipv6RouterAdvertMinInterval (1.3.6.1.2.1.4.39.1.4) |
read-create |
Unsigned32 |
Unsigned32 (3..1350) |
Minimum interval at which unsolicited router advertisements are sent, in seconds. |
ipv6RouterAdvertManagedFlag (1.3.6.1.2.1.4.39.1.5) |
read-create |
TruthValue |
Value to be placed into the 'managed address configuration' flag field in router advertisements to send. |
ipv6RouterAdvertOtherConfigFlag (1.3.6.1.2.1.4.39.1.6) |
read-create |
TruthValue |
Value to be placed into the 'other stateful configuration' flag field in router advertisements to send. |
ipv6RouterAdvertLinkMTU (1.3.6.1.2.1.4.39.1.7) |
read-create |
Unsigned32 |
Value to be placed in MTU options to send. A value of zero indicates that no MTU options are sent. |
ipv6RouterAdvertReachableTime (1.3.6.1.2.1.4.39.1.8) |
read-create |
Unsigned32 |
Unsigned32 (0..3600000) |
Value to be placed in the reachable time field in router advertisement messages to send. A value of zero indicates that no reachable time is specified. |
ipv6RouterAdvertRetransmitTime (1.3.6.1.2.1.4.39.1.9) |
read-create |
Unsigned32 |
Value to be placed in the retransmit time field in router advertisements to send. A value of zero indicates that no retransmit time is specified. |
ipv6RouterAdvertCurHopLimit (1.3.6.1.2.1.4.39.1.10) |
read-create |
Unsigned32 |
Unsigned32 (0..255) |
Value to be placed in the current hop limit field in router advertisements to send. A value of zero indicates that the hops are not limited. |
ipv6RouterAdvertDefaultLifetime (1.3.6.1.2.1.4.39.1.11) |
read-create |
Unsigned32 |
Unsigned32 (0|4..9000) |
Value to be placed in the router lifetime field of router advertisements to send. A value of zero indicates that the router is no longer used as a default router. The default value is the ipv6RouterAdvertMaxInterval value multiplied by three. |
ipv6RouterAdvertRowStatus (1.3.6.1.2.1.4.39.1.12) |
read-create |
RowStatus |
icmpStatsTable
About this table
This table contains system-level ICMP statistics.
Read:Supported
Columns
The table index is icmpStatsIPVersion.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
icmpStatsIPVersion (1.3.6.1.2.1.5.29.1.1) |
not-accessible |
InetVersion |
IP version of the statistics. |
icmpStatsInMsgs (1.3.6.1.2.1.5.29.1.2) |
read-only |
Counter32 |
Number of received ICMP messages, including messages counted by icmpStatsInErrors. |
As per the MIB. |
icmpStatsInErrors (1.3.6.1.2.1.5.29.1.3) |
read-only |
Counter32 |
Number of received ICMP error messages. Possible errors include ICMP checksum error and length error. |
As per the MIB. |
icmpStatsOutMsgs (1.3.6.1.2.1.5.29.1.4) |
read-only |
Counter32 |
Number of sent ICMP messages, including messages counted by icmpStatsOutErrors. |
As per the MIB. |
icmpStatsOutErrors (1.3.6.1.2.1.5.29.1.5) |
read-only |
Counter32 |
Number of ICMP messages failed to be sent because of reasons such as insufficient buffer space. Errors occurred outside the ICMP layer are not included. In some implementations, there may be no types of error which contribute to this counter's value. |
The value is fixed to 0. |
icmpMsgStatsTable
About this table
This table contains statistics about each IP version and each ICMP message type.
Read:Supported
Columns
The table indexes are icmpMsgStatsIPVersion and icmpMsgStatsType.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
icmpMsgStatsIPVersion (1.3.6.1.2.1.5.30.1.1) |
not-accessible |
InetVersion |
icmpMsgStatsType (1.3.6.1.2.1.5.30.1.2) |
not-accessible |
Integer32 |
Integer32 (0..255) |
ICMP message type. |
As per the MIB. |
icmpMsgStatsInPkts (1.3.6.1.2.1.5.30.1.3) |
read-only |
Counter32 |
Number of received ICMP messages of the type. |
As per the MIB. |
icmpMsgStatsOutPkts (1.3.6.1.2.1.5.30.1.4) |
read-only |
Counter32 |
Number of sent ICMP messages of the type. |
As per the MIB. |
