08-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
06-HH3C-DHCP4-CLIENT-MIB
06-HH3C-DHCP4-CLIENT-MIB 66.71 KB
About this MIB
Use this MIB to obtain IP address information and configure alarm settings.
MIB file name
hh3c-dhcp4-client.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cDhcp4Client(242)
Scalar objects
hh3cDhcp4ClientConflictIP (1.3.6.1.4.1.25506.2.242.1.1.1)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
InetAddressIPv4
OCTET STRING (4)
Conflicting IP address assigned to the DHCP client.
As per the MIB.
hh3cDhcp4ClientReacquiredIP (1.3.6.1.4.1.25506.2.242.1.1.2)
Object (OID)
Access
Value range
Implementation
InetAddressIPv4
OCTET STRING (4)
Usable address obtained by the DHCP client after it sent an address request again.
As per the MIB.
hh3cDhcp4ClientUserInfoMacAddr (1.3.6.1.4.1.25506.2.242.1.1.3)
Object (OID)
Access
Value range
Implementation
MacAddress
OCTET STRING (6)
MAC address of the DHCP client.
As per the MIB.
Notifications
hh3cDhcp4ClientIpConflictAlm
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.242.3.0.1
The DHCP client obtains a conflicting IP address.
Error
Warning
1.3.6.1.4.1.25506.2.242.3.1.2 (hh3cDhcp4ClientIpConflictAlmRsm)
OFF
Notification triggers
This notification is generated when the DHCP client obtains an IP address that is in the same network segment as another interface address on the local device.
System impact
The DHCP client fails to obtain an IP address.
Status control
ON
CLI: Use the snmp-agent trap enable dhcp-client local-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp-client local-conflict command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.31.1.1.1.1
 (ifName)
Interface name.
ifindex
DisplayString
Standard MIB values.
1.3.6.1.4.1.25506.2.242.1.1.1 (hh3cDhcp4ClientConflictIP)
N/A
InetAddressIPv4
Recommended action
To resolve this issue:
1.Use the display dhcp client command in any view to identify whether the DHCP client has obtained an IP address:
  - If the DHCP client has obtained an IP address, no action is required.
  - If the DHCP client has not obtained any IP address, use the display ip routing-table command to identify whether the assigned IP address is in the same network segment as the IP address of another interface.
If yes, change the IP address of the interface.
If no, proceed to step 2.
2.If the issue persists, collect alarm information, log messages, and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.242.3.0.2
The DHCP client obtains a usable IP address after obtaining a conflicting IP address.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the DHCP client obtains a usable IP address after obtaining a conflicting IP address.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (ifName)
Interface name.
ifindex
DisplayString
1.3.6.1.4.1.25506.2.242.1.1.2 (hh3cDhcp4ClientReacquiredIP)
Usable IP address obtained by the DHCP client.
N/A
InetAddressIPv4
Recommended action
No action is required.
hh3cDhcp4ClientApplyIpFailAlm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.242.3.0.3
The DHCP client fails to request an IP address.
Error
Warning
1.3.6.1.4.1.25506.2.242.3.1.4 (hh3cDhcp4ClientApplyIpFailAlmRsm)
OFF
This notification is generated when the DHCP client fails to request an IP address.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp-client ip-apply-failed command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp-client ip-apply-failed command.
Object
OID (object name)
Index
Value range
1.3.6.1.2.1.31.1.1.1.1 (ifName)
Interface name.
ifindex
DisplayString
Recommended action
  - If the DHCP client has not obtained any IP address, proceed to step 2.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.242.3.0.4
The DHCP client successfully requests an IP address after an IP address request failure.
Recovery
Warning
N/A (N/A)
OFF
This notification is generated when the DHCP client successfully requests a usable IP address after an IP address request failure.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (ifName)
Interface name.
ifindex
DisplayString
Usable IP address assigned to the DHCP client.
N/A
InetAddressIPv4
Recommended action
hh3cDhcp4ClientApplyIpConflictAlm
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.242.3.0.5
The DHCP client obtains an IP address conflicting with the IP address of another host.
Informational
Warning
N/A (N/A)
OFF
This notification is generated when the DHCP client obtains an IP address that conflicts with the IP address of another host. The DHCP client detects for address conflicts by sending gratuitous ARP packets.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable dhcp-client arp-conflict command.
OFF
CLI: Use the undo snmp-agent trap enable dhcp-client arp-conflict command.
Object
OID (object name)
Index
Value range
Interface name.
ifindex
DisplayString
N/A
InetAddressIPv4
Recommended action
  - If the DHCP client has not obtained any IP address, use the display ip routing-table command to identify whether IP address conflicts occur in the network.
If multiple IP address conflicts exist, make a new network plan as a best practice.
