08-Layer 3 - IP Services
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10008-Layer 3 - IP Services
15-HH3C-SESSION-MIB
15-HH3C-SESSION-MIB 91.31 KB
HH3C-SESSION-MIB
About this MIB
Use this MIB to configure session modules and obtain session messages.
MIB file name
hh3c-session.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cSession(149)
Tabular objects
hh3cSessionStatTable
About this table
Use this table to obtain session statistics.
Support for operations
CreateNot supported
Edit/ModifyNot supported
DeleteNot supported
ReadSupported
Columns
The table indexes are hh3cSessionStatChassis, hh3cSessionStatSlot, and hh3cSessionStatCPUID.
Object (OID)
Access
Value range
Implementation
(1.3.6.1.4.1.25506.2.149.1.1.1.1)
not-accessible
Unsigned32
0..65534
IRF member ID.
As per the MIB.
hh3cSessionStatSlot
(1.3.6.1.4.1.25506.2.149.1.1.1.2)
not-accessible
Unsigned32
0..65534
Slot number.
As per the MIB.
(1.3.6.1.4.1.25506.2.149.1.1.1.3)
not-accessible
Unsigned32
0..7
CPU ID.
As per the MIB.
hh3cSessionStatCount
(1.3.6.1.4.1.25506.2.149.1.1.1.4)
read-only
Unsigned32
Standard MIB values.
Total number of sessions.
As per the MIB.
hh3cSessionStatCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.5)
read-only
Unsigned32
Number of sessions created per second.
As per the MIB.
hh3cSessionStatTCPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.6)
read-only
Unsigned32
Number of TCP sessions.
As per the MIB.
hh3cSessionStatUDPCount
(1.3.6.1.4.1.25506.2.149.1.1.1.7)
read-only
Unsigned32
Number of UDP sessions.
As per the MIB.
hh3cSessionStatOtherCount
(1.3.6.1.4.1.25506.2.149.1.1.1.8)
read-only
Unsigned32
Number of sessions other than TCP and UDP sessions.
As per the MIB.
hh3cSessionStatTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.9)
read-only
Unsigned32
Number of TCP sessions created per second.
As per the MIB.
hh3cSessionStatUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.10)
read-only
Unsigned32
Number of UDP sessions created per second.
As per the MIB.
hh3cSessionStatOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.1.1.11)
read-only
Unsigned32
Number of non-TCP and non-UDP sessions created per second.
As per the MIB.
hh3cSessionStatTCPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.12)
read-only
Counter64
Total number of TCP sessions created till now.
As per the MIB.
hh3cSessionStatUDPTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.13)
read-only
Counter64
Total number of UDP sessions created till now.
As per the MIB.
hh3cSessionStatOtherTotal
(1.3.6.1.4.1.25506.2.149.1.1.1.14)
read-only
Counter64
Total number of non-TCP and non-UDP sessions created till now.
As per the MIB.
hh3cSessionEntTable
About this table
Use this table to obtain statistics about sessions by entity.
CreateNot supported
DeleteNot supported
ReadSupported
Columns
The table index is hh3cSessionEntIndex.
Object (OID)
Access
Value range
Implementation
hh3cSessionEntIndex
not-accessible
Unsigned32
1..2147483647
Device entity index.
As per the MIB.
hh3cSessionEntCount
(1.3.6.1.4.1.25506.2.149.1.2.1.2)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.3)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.4)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCount
(1.3.6.1.4.1.25506.2.149.1.2.1.5)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCount
(1.3.6.1.4.1.25506.2.149.1.2.1.6)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.7)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntUDPCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.8)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntOtherCreateRate
(1.3.6.1.4.1.25506.2.149.1.2.1.9)
read-only
Unsigned32
As per the MIB.
hh3cSessionEntTCPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.10)
read-only
Counter64
As per the MIB.
hh3cSessionEntUDPTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.11)
read-only
Counter64
As per the MIB.
hh3cSessionEntOtherTotal
(1.3.6.1.4.1.25506.2.149.1.2.1.12)
read-only
Counter64
As per the MIB.
Notifications
hh3cSessionDrvMaxTrap
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.149.1.3.0.1
Hardware session resource exhaustion.
Error
Major
1.3.6.1.4.1.25506.2.149.1.3.0.2 (hh3cSessionDrvRecoveryTrap)
OFF
Notification triggers
This notification is generated when the number of sessions on the device reaches the upper limit.
System impact
New sessions initiated by the CGN device cannot be forwarded by hardware. Too many new sessions might increase CPU usage.
Status control
ON
CLI: Use the snmp-agent trap enable session resource command.
OFF
CLI: Use the undo snmp-agent trap enable session resource command.
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.149.1.3.1.1
 (hh3cSessionDrvNum)
Maximum number of sessions supported by hardware.
N/A
Unsigned32
1.3.6.1.4.1.25506.2.149.1.3.1.2
 (hh3cSessionChassis)
Chassis number.
N/A
Unsigned32
(0..65534)
1.3.6.1.4.1.25506.2.149.1.3.1.3
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
1.3.6.1.4.1.25506.2.149.1.3.1.4 (hh3cSessionCpu)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
To resolve this issue:
1.Execute the display session table { ipv4 | ipv6 } command to verify whether the number has reached the upper limit.
  - If the upper limit is reached, expand the device capacity to store more sessions and verify whether the alarm is removed. If the alarm is not removed, go to the next step.
  - If the upper limit is not reached, go to the next step.
2.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
Number of sessions drops below the limit.
Recovery
Warning
OFF
This notification is generated if the number of sessions on the device drops below the limit supported by hardware.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
No action is required.
hh3cSessionThdMaxTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.149.1.3.0.3
High hardware session resource usage.
Error
Major
1.3.6.1.4.1.25506.2.149.1.3.0.4 (hh3cSessionThdRecoveryTrap)
OFF
This notification is generated if the hardware session resource usage exceeds the alarm threshold.
System impact
No impact is generated on services upon the triggering of the notification. However, if new sessions continue to be created and the number of sessions reaches the upper limit, the new sessions cannot be forwarded by hardware and too many new sessions might increase CPU usage.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.149.1.3.1.5
 (hh3cSessionUsage)
Hardware session resource usage.
N/A
Unsigned32
(0..100)
1.3.6.1.4.1.25506.2.149.1.3.1.6
 (hh3cSessionThreshold)
Alarm threshold.
N/A
Unsigned32
(60..90)
1.3.6.1.4.1.25506.2.149.1.3.1.2 (hh3cSessionChassis)
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
N/A
Unsigned32
(0..7)
Recommended action
1.Execute the display session table { ipv4 | ipv6 } command to verify whether the resource usage has exceeded the alarm threshold.
  - If the alarm threshold is exceeded, go to step 2.
  - If the alarm threshold is not exceeded, go to step 3.
2.Execute the session alarm usage threshold command to increase the alarm threshold or expand the device capacity to store more sessions. Verify whether the alarm is removed. If the alarm is not removed, proceed to step 3.
3.If the issue persists, collect alarm information and configuration data, and then contact H3C Support for help.
Basic information
OID
Event
Severity
Default status
The hardware session resource usage drops below 87.5% of the alarm threshold.
Recovery
Warning
OFF
This notification is generated if the hardware session resource usage drops below 87.5% of the alarm threshold.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
 (hh3cSessionUsage)
N/A
Unsigned32
(0..100)
Alarm threshold.
N/A
Unsigned32
(60..90)
Chassis number.
N/A
Unsigned32
(0..65534)
 (hh3cSessionSlot)
Slot number.
N/A
Unsigned32
(0..65534)
CPU number.
Yes
Unsigned32
(0..7)
Recommended action
