- 08-Layer 3 - IP Services
- 01-HH3C-ARP-RATELIMIT-MIB
- 02-HH3C-ARP-SUPPRESSION-MIB
- 03-HH3C-ARP-TRAP-MIB
- 04-HH3C-BPA-MIB
- 05-HH3C-DHCP-SNOOP2-MIB
- 06-HH3C-DHCP4-CLIENT-MIB
- 07-HH3C-DHCP4-MIB
- 08-HH3C-DHCP6-MIB
- 09-HH3C-FIB-MIB
- 10-HH3C-IP-ADDRESS-MIB
- 11-HH3C-IPFW-MIB
- 12-HH3C-IPV6-ADDRESS-MIB
- 13-HH3C-NAT-MIB
- 14-HH3C-ND-TRAP-MIB
- 15-HH3C-SESSION-MIB
- 16-HH3C-TCP-MIB
- 17-HH3C-TUNNEL-TRAP-MIB
- 18-HH3C-DNS-MIB
- 19-IP-MIB
- 20-IPV6-ICMP-MIB
- 21-IPV6-MIB
- 22-IPV6-TCP-MIB
- 23-IPV6-UDP-MIB
- 24-TCP-MIB
- 25-UDP-MIB
| 12-HH3C-IPV6-ADDRESS-MIB | 72.86 KB |
About this MIB
Use this MIB to obtain and configure IPv6 addresses.
MIB file name
hh3c-ipv6-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpv6AddrMIB(71)
Tabular objects
hh3cIpv6AddrSetTable
About this table
This table configures an IPv6 addresses.
Support for operations
Create:Supported
Edit/Modify:Not supported
Delete:Supported
Read:Supported
Columns
The table indexes are hh3cIpv6AddrSetIfIndex, hh3cIpv6AddrSetAddrType, and hh3cIpv6AddrSetAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpv6AddrSetIfIndex (1.3.6.1.4.1.25506.2.71.1.1.1.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483) |
Interface index. |
As per the MIB. |
hh3cIpv6AddrSetAddrType (1.3.6.1.4.1.25506.2.71.1.1.1.1.2) |
not-accessible |
InetAddressType |
ipv6(2) |
IP address version. |
As per the MIB. |
hh3cIpv6AddrSetAddr (1.3.6.1.4.1.25506.2.71.1.1.1.1.3) |
not-accessible |
InetAddress |
OCTET STRING (0..255) |
IP address. |
As per the MIB. |
hh3cIpv6AddrSetPfxLength (1.3.6.1.4.1.25506.2.71.1.1.1.1.4) |
read-create |
Integer32 |
Integer32 (1..128) |
IPv6 address subnet prefix length. |
As per the MIB. |
hh3cIpv6AddrSetSourceType (1.3.6.1.4.1.25506.2.71.1.1.1.1.5) |
read-create |
INTEGER |
assignedIp(1) assignedEUI64Ip(2) assignedLinklocalIp(3) |
Source type of the IPv6 address. |
As per the MIB. |
hh3cIpv6AddrSetRowStatus (1.3.6.1.4.1.25506.2.71.1.1.1.1.6) |
read-create |
RowStatus |
active(1) createAndGo(4) destroy(6) |
Create a new row or delete an existing row. |
As per the MIB. |
hh3cIpv6AddrReadTable
About this table
This table displays IPv6 addresses.
Create:Not supported
Delete:Not supported
Read:Supported
Columns
The table indexes are hh3cIpv6AddrReadIfIndex, hh3cIpv6AddrReadAddrType, and hh3cIpv6AddrReadAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cIpv6AddrReadIfIndex (1.3.6.1.4.1.25506.2.71.1.1.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
Interface index. |
As per the MIB. |
hh3cIpv6AddrReadAddrType (1.3.6.1.4.1.25506.2.71.1.1.2.1.2) |
not-accessible |
InetAddressType |
ipv6(2) |
As per the MIB. |
hh3cIpv6AddrReadAddr (1.3.6.1.4.1.25506.2.71.1.1.2.1.3) |
not-accessible |
InetAddress |
IPv6 address. |
As per the MIB. |
hh3cIpv6AddrReadPfxLength (1.3.6.1.4.1.25506.2.71.1.1.2.1.4) |
read-only |
Integer32 |
IPv6 address prefix length. |
As per the MIB. |
hh3cIpv6AddrReadSourceType (1.3.6.1.4.1.25506.2.71.1.1.2.1.5) |
read-only |
INTEGER |
assignedIp(1) assignedEUI64Ip(2), assignedAutoIp(3) autoIp(4) dhcpv6(5) negotiate(6) cluster(7) |
As per the MIB. |
hh3cIpv6AddrReadCatalog (1.3.6.1.4.1.25506.2.71.1.1.2.1.6) |
read-only |
INTEGER |
nodelocal(1) linklocal(2) sitelocal(3) orglocal(4) global(5) |
Type of the IPv6 address. |
As per the MIB. |
Notifications
hh3cIpv6AddrSetProEnableFailed
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.71.1.2.0.1 |
IPv6 enabling failed. |
Informational |
Major |
N/A (N/A) |
ON |
Notification triggers
This notification is generated when IPv6 fails to be enabled on an interface due to insufficient system resources.
System impact
IPv6 services are unavailable on the interface.
Status control
ON
CLI: snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
OFF
CLI: undo snmp-agent trap enable ipv6 address [ protocol-enable-failure ]
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.71.1.2.1.1 (hh3cIpv6AddrSetProEnableIfName) |
Interface name. |
N/A |
OCTET STRING |
1.3.6.1.4.1.25506.2.71.1.2.1.2 (hh3cIpv6AddrSetProEnableChassis) |
Chassis number. |
N/A |
Unsigned32 |
Unsigned32(0..65535) |
1.3.6.1.4.1.25506.2.71.1.2.1.3 (hh3cIpv6AddrSetProEnableSlot) |
Slot number. |
N/A |
Unsigned32 |
Recommended action
To resolve the issue:
1.Use the display ipv6 interface command to view IPv6 information on all interfaces.
2.Based on network planning and service deployment, examine whether IPv6 is not required on some interfaces enabled with IPv6.
- If such interfaces do not exist, proceed to step 3.
- If such interfaces exist, use the undo ipv6 address command to delete all IPv6 addresses of the interfaces. Then, try to configure an IPv6 address for the target interface for which the notification is generated.
3.Collect alarm information and configuration data, and then contact H3C Support for help.
