- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
19-PW-MPLS-STD-MIB | 42.48 KB |
PW-MPLS-STD-MIB
About this MIB
Use this MIB to configure PWs.
MIB file name
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).pwMplsStdMIB(181)
Tabular objects
pwMplsTable
About this table
Use this table to configure and obtain settings of the MPLS public tunnel that carries a PW.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table index is pwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwMplsMplsType (1.3.6.1.2.1.181.1.1.1.1) |
read-write |
BITS |
mplsTe(0), mplsNonTe(1), pwOnly(2) |
Type of the public tunnel. |
Supports only the read operation. |
pwMplsLocalLdpID (1.3.6.1.2.1.181.1.1.1.5) |
read-write |
MplsLdpIdentifier |
OCTET STRING (6) |
Local LDP ID. |
pwMplsStorageType (1.3.6.1.2.1.181.1.1.1.8) |
read-write |
StorageType |
other(1), volatile(2), nonVolatile(3), permanent(4), readOnly(5) |
Storage type for this role. |
Supports only the read operation. This value is always nonVolatile(3). |
pwMplsOutboundTable
About this table
Use this table to configure and obtain detailed information about the MPLS public tunnel that carries the PW traffic toward the public network.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
pwMplsOutboundLsrXcIndex (1.3.6.1.2.1.181.1.2.1.1) |
read-write |
MplsIndexType |
OCTET STRING (1..24) |
XC index of the public tunnel. |
pwMplsOutboundTunnelIndex (1.3.6.1.2.1.181.1.2.1.2) |
read-write |
MplsIndexIndex |
ID of the public tunnel. |
pwMplsOutboundTunnelInstance (1.3.6.1.2.1.181.1.2.1.3) |
read-only |
MplsTunnelInstanceIndex |
Unsigned32 (0 | 1..65535 | 65536..2147483647) |
CRLSP ID of the public tunnel. |
As per the MIB. |
pwMplsOutboundTunnelLclLSR (1.3.6.1.2.1.181.1.2.1.4) |
read-write |
MplsLsrIdentifier |
OCTET STRING (4) |
Ingress LSR ID of the public tunnel. |
pwMplsOutboundTunnelPeerLSR (1.3.6.1.2.1.181.1.2.1.5) |
read-write |
MplsLsrIdentifier |
OCTET STRING (4) |
Egress LSR ID of the public tunnel. |
pwMplsOutboundIfIndex (1.3.6.1.2.1.181.1.2.1.6) |
read-write |
InterfaceIndexOrZero |
Integer32 (0..2147483647) |
Index of the outgoing interface of the public tunnel. |
pwMplsOutboundTunnelTypeInUse (1.3.6.1.2.1.181.1.2.1.7) |
read-only |
INTEGER |
notYetKnown(1), mplsTe(2), mplsNonTe(3), pwOnly(4) |
Type of the public tunnel that is carrying the PW traffic. |
As per the MIB. |
