- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
03-HH3C-L3VPN-MIB | 68.80 KB |
HH3C-L3VPN-MIB
About this MIB
This MIB contains L3VPN information.
MIB file name
hh3c-l3vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cL3vpn (228)
Scalar objects
hh3cL3vpnVrfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL3vpnVrfName (1.3.6.1.4.1.25506.2.228.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..31) |
Name of a VRF. |
As per the MIB. |
hh3cL3vpnIfName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL3vpnIfName (1.3.6.1.4.1.25506.2.228.1.2) |
DisplayString |
OCTET STRING (1..255) |
Name of an interface bound to a VRF. |
As per the MIB. |
Notifications
hh3cL3vpnVrfV6Up
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.228.0.1 |
At least one of the IPv6 interfaces bound to the VRF come up from the down state. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the status of the IPv6 interfaces associated with the VPN instance (VRF) changes from all down to partially up.
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn vrf-ipv6-up command.
Off
CLI: Use the undo snmp-agent trap enable l3vpn vrf-ipv6-up command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.228.1.1 (hh3cL3vpnVrfName) |
Name of a VRF. |
No |
OCTET STRING |
OCTET STRING(0..31) |
1.3.6.1.4.1.25506.2.228.1.2 (hh3cL3vpnIfName) |
Name of an interface bound to the VRF. |
No |
DisplayString |
OCTET STRING(1..255) |
Recommended action
Check the IPv6 interfaces bound to the VRF. If the status of the IPv6 interfaces is not as expected, collect trap and configuration information of the interfaces and then contact the technical support.
hh3cL3vpnVrfV6Down
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.228.0.2 |
The IPv6 interfaces bound to the VRF are all down. |
Informational |
Warning |
N/A |
ON |
This notification is generated when the IPv6 interfaces bound to the VPN instance (VRF) are all down.
Status control
ON
CLI: Use the snmp-agent trap enable l3vpn vrf-ipv6-down command.
Off
CLI: Use the undo snmp-agent trap enable l3vpn vrf-ipv6-down command.
Objects
OID (object name) |
Index |
Type |
Value range |
Name of a VRF. |
No |
OCTET STRING |
No |
DisplayString |
Recommended action
