- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
02-HH3C-L2VPN-MIB | 103.49 KB |
HH3C-L2VPN-MIB
About this MIB
Use this MIB to obtain L2VPN configuration information. This MIB also contains notifications about PW state changes.
MIB file name
hh3c-l2vpn.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3L2vpn(162)
Tabular objects
hh3cL2vpnPwcTable
About this table
This table contains PW class information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cL2vpnPwcName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnPwcName (1.3.6.1.4.1.25506.2.162.2.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (0..19) |
PW class name. |
As per the MIB. |
hh3cL2vpnPwcCvType (1.3.6.1.4.1.25506.2.162.2.1.1.2) |
read-create |
INTEGER |
unknown(1), bfd(2), rawBFD(3) |
Encapsulation mode used by BFD packets for PW fault detection. |
Supports only the read operation. |
hh3cL2vpnPwcCcType (1.3.6.1.4.1.25506.2.162.2.1.1.3) |
read-create |
INTEGER |
unknown(1), controlWord(2), routerAlert(3), ttl(4) |
VCCV control channel type. |
hh3cL2vpnPwcControlWord (1.3.6.1.4.1.25506.2.162.2.1.1.4) |
read-create |
TruthValue |
true(1) false(2) |
Whether the control word feature is enabled. |
hh3cL2vpnPwcPwType (1.3.6.1.4.1.25506.2.162.2.1.1.5) |
read-create |
INTEGER |
vlan(4), ethernet(5) |
PW data encapsulation type. |
hh3cL2vpnPwcRowStatus (1.3.6.1.4.1.25506.2.162.2.1.1.6) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
hh3cL2vpnPwcFlowLabel (1.3.6.1.4.1.25506.2.162.2.1.1.7) |
read-create |
INTEGER |
unknown(1), send(2), receive(3), both(4) |
PW flow label. |
hh3cL2vpnXcgTable
About this table
This table contains L2VPN cross-connect group information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is hh3cL2vpnXcgName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgName (1.3.6.1.4.1.25506.2.162.3.1.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..31)) |
Name of the cross-connect group. |
As per the MIB. |
hh3cL2vpnXcgAdminState (1.3.6.1.4.1.25506.2.162.3.1.1.2) |
read-create |
INTEGER |
adminUp(1), adminDown(2) |
Administrative state of the cross-connect group. |
hh3cL2vpnXcgRowStatus (1.3.6.1.4.1.25506.2.162.3.1.1.3) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgConnTable
About this table
This table contains L2VPN cross-connect information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName and hh3cL2vpnXcgConnName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgConnName (1.3.6.1.4.1.25506.2.162.3.2.1.1) |
not-accessible |
OCTET STRING |
OCTET STRING (1..20) |
Name of the cross-connect. |
As per the MIB. |
hh3cL2vpnXcgConnRowStatus (1.3.6.1.4.1.25506.2.162.3.2.1.2) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgAcTable
About this table
This table contains cross-connect group AC information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, hh3cL2vpnXcgAcIfIndex, and hh3cL2vpnXcgAcEvcSrvInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgAcIfIndex (1.3.6.1.4.1.25506.2.162.3.3.1.1) |
not-accessible |
InterfaceIndex |
InterfaceIndex (1..2147483647) |
Interface index of the AC. |
As per the MIB. |
hh3cL2vpnXcgAcEvcSrvInstId (1.3.6.1.4.1.25506.2.162.3.3.1.2) |
not-accessible |
Unsigned32 |
ID of the Ethernet service instance bound to the cross-connect group. |
As per the MIB. The value of this object is fixed at 0 for a Layer 3 interface. |
hh3cL2vpnXcgAcAccessMode (1.3.6.1.4.1.25506.2.162.3.3.1.3) |
read-create |
INTEGER |
vlan(1), ethernet(2) |
Access mode of the AC. |
Supports only the read operation. This object is meaningless when the AC is not a Layer 2 Ethernet interface. |
hh3cL2vpnXcgAcRowStatus (1.3.6.1.4.1.25506.2.162.3.3.1.4) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnXcgPwTable
About this table
This table contains cross-connect group PW information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnXcgName, hh3cL2vpnXcgConnName, and hh3cL2vpnXcgPwIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnXcgPwIndex (1.3.6.1.4.1.25506.2.162.3.4.1.1) |
accessible-for-notify |
Unsigned32 |
Unsigned32 (0..4294967295) |
PW index. |
As per the MIB. |
hh3cL2vpnXcgPwCfgType (1.3.6.1.4.1.25506.2.162.3.4.1.2) |
read-create |
INTEGER |
primary(1), backup(2) |
PW type, primary PW or backup PW. |
hh3cL2vpnXcgPwClassName (1.3.6.1.4.1.25506.2.162.3.4.1.3) |
read-create |
OCTET STRING |
Name of the used PW class. |
hh3cL2vpnXcgPwTunnelPolicy (1.3.6.1.4.1.25506.2.162.3.4.1.4) |
read-create |
OCTET STRING |
Name of the used tunnel policy. |
hh3cL2vpnXcgPwPeerIp (1.3.6.1.4.1.25506.2.162.3.4.1.5) |
IpAddress |
OCTET STRING (SIZE (4)) |
Peer's IP address. |
As per the MIB. |
hh3cL2vpnXcgPwPwID (1.3.6.1.4.1.25506.2.162.3.4.1.6) |
Unsigned32 |
PW ID. |
As per the MIB. |
hh3cL2vpnXcgPwRowStatus (1.3.6.1.4.1.25506.2.162.3.4.1.7) |
read-create |
RowStatus |
Row status. |
hh3cL2vpnLinkTable
About this table
This table contains L2VPN link information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnLinkVsiIndex and hh3cL2vpnLinkLinkID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnLinkVsiIndex |
not-accessible |
Unsigned32 |
VSI index. |
As per the MIB. |
hh3cL2vpnLinkLinkID (1.3.6.1.4.1.25506.2.162.2.2.1.2) |
not-accessible |
Unsigned32 |
Link ID |
As per the MIB. |
hh3cL2vpnLinkType (1.3.6.1.4.1.25506.2.162.2.2.1.3) |
read-only |
INTEGER |
unknown(1), ac(2), tunnel(3) |
VSI link type. |
As per the MIB. |
hh3cL2vpnLinkIfIndex (1.3.6.1.4.1.25506.2.162.2.2.1.4) |
read-only |
InterfaceIndex |
Interface index of the VSI link. |
As per the MIB. |
hh3cL2vpnLinkSrvID (1.3.6.1.4.1.25506.2.162.2.2.1.5) |
read-only |
Unsigned32 |
Unsigned32(0..4294967295) |
Ethernet service instance ID of the VSI link. |
As per the MIB. |
hh3cL2vpnLinkTunnelID (1.3.6.1.4.1.25506.2.162.2.2.1.6) |
read-only |
Unsigned32 |
Tunnel interface number of the VSI link. |
As per the MIB. |
hh3cL2vpnMacLimitPwTable
About this table
This table contains L2VPN MAC limit alarm information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are hh3cL2vpnMacLimitPwVsiIndex and hh3cL2vpnMacLimitPwLinkID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2vpnMacLimitPwVsiIndex (1.3.6.1.4.1.25506.2.162.2.3.1.1) |
Unsigned32 |
VSI index. |
As per the MIB. |
hh3cL2vpnMacLimitPwLinkID (1.3.6.1.4.1.25506.2.162.2.3.1.2) |
Unsigned32 |
Link ID of the PW. |
As per the MIB. |
hh3cL2vpnMacLimitPwVsiName (1.3.6.1.4.1.25506.2.162.2.3.1.3) |
read-create |
DisplayString |
OCTET STRING (0..255) |
VSI name. |
As per the MIB. |
hh3cL2vpnMacLimitPwRowStatus (1.3.6.1.4.1.25506.2.162.2.3.1.4) |
read-create |
RowStatus |
Row status of the MacLimitPw table. |
Notifications
hh3cL2vpnPwSwitchPtoB
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.162.0.1 |
Traffic is switched from the primary PW to the backup PW. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.2(hh3cL2vpnPwSwitchBtoP) |
OFF |
A notification sent when the traffic is switched from the primary PW to the backup PW.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn [ pw-switch ] command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [ pw-switch ] command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.3.4.1.1 (hh3cL2vpnXcgPwIndex) |
PW index associated with the cross-connect. |
Yes |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.5 (hh3cL2vpnXcgPwPeerIp) |
IP address of the PW associated with the cross-connect. |
No |
IpAddress |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.3.4.1.6 (hh3cL2vpnXcgPwPwID) |
ID of the PW associated with the cross-connect. |
No |
Unsigned32 |
As per the MIB. |
Recommended action
No action is required.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.2 |
Traffic is switched from the backup PW to the primary PW. |
Recovery |
Warning |
OFF |
A notification sent when the traffic is switched from the backup PW to the primary PW.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Unsigned32 |
As per the MIB. |
No |
IpAddress |
As per the MIB. |
No |
Unsigned32 |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxPw
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.3 |
The number of MAC addresses learned on a PW exceeded the limit. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.4(hh3cL2vpnMacLimitMaxPw_Clear) |
OFF |
This notification is generated when the number of MAC addresses learned on a PW exceeds the limit.
Status control
CLI: Use the snmp-agent trap enable l2vpn [maclimit-pw] command.
CLI: Use the undo snmp-agent trap enable l2vpn [maclimit-pw] command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.2.3.1.1 (hh3cL2vpnMacLimitPwVsiIndex) |
VSI index. |
Yes |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.12 (hh3cL2vpnMacLimitPwLinkID) |
Yes |
Unsigned32 |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.2.3.1.3 (hh3cL2vpnMacLimitPwVsiName) |
VSI name. |
No |
DisplayString |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.4 |
The number of MAC addresses learned on a PW dropped below the limit. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the number of MAC addresses learned on a PW drops below the limit.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
VSI index. |
Yes |
Unsigned32 |
As per the MIB. |
Yes |
Unsigned32 |
As per the MIB. |
VSI name. |
No |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnMacLimitMaxAc
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.5 |
The number of MAC addresses learned on an AC exceeded the limit. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.6(hh3cL2vpnMacLimitMaxAc_Clear) |
OFF |
This notification is generated when the number of MAC addresses learned on an AC exceeds the limit.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn [maclimit-ac] command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [maclimit-ac] command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.4.1.1.3 (hh3cL2vpnAcIfName) |
Name of the interface (AC). |
No |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.4.1.1.4 (hh3cL2vpnAcVsiName) |
Name of the VSI bound to the AC. |
No |
DisplayString |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.6 |
The number of MAC addresses learned on an AC dropped below the limit. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the number of MAC addresses learned on an AC drops below the limit.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
As per the MIB. |
No |
DisplayString |
As per the MIB. |
Recommended action
hh3cL2vpnPwParaMisMatch
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.7 |
PW parameter settings do not match. |
Error |
Warning |
1.3.6.1.4.1.25506.2.162.0.8 (hh3cL2vpnPwParaMatch) |
OFF |
This notification is generated when the settings of the PW parameters do not match.
Status control
ON
CLI: Use the snmp-agent trap enable l2vpn [pw-parameter] command.
OFF
CLI: Use the undo snmp-agent trap enable l2vpn [pw-parameter] command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.162.5.1.1.6 (hh3cL2vpnPwVsiName) |
Name of the VSI to which the PW is bound. |
No |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.7 (hh3cL2vpnPwXcgName) |
Name of the cross-connect group to which the PW is bound. |
No |
DisplayString |
As per the MIB. |
1.3.6.1.4.1.25506.2.162.5.1.1.8 (hh3cL2vpnPwXcgConnName) |
Name of the cross-connect to which the PW is bound. |
No |
DisplayString |
As per the MIB. |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.162.0.8 |
PW parameter settings are consistent. |
Recovery |
Warning |
N/A |
OFF |
This notification is generated when the PW parameters settings are matching.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
No |
DisplayString |
As per the MIB. |
No |
DisplayString |
As per the MIB. |
No |
DisplayString |
As per the MIB. |
Recommended action
