- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
11-MPLS-FRR-FACILITY-STD-MIB | 91.89 KB |
mplsFrrConfiguredBypassTunnels
mplsFrrFacilityNotificationsEnabled
mplsFrrFacilityNotificationsMaxRate
About this MIB
Use this MIB to manage tunnels on the MPLS interfaces configured for FRR protection.
MIB file name
rfc6445-mpls-frr-facility-std.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).mplsFrrFacilityMIB(204)
Scalar objects
mplsFrrConfiguredInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrConfiguredInterfaces (1.3.6.1.2.1.204.1.1) |
read-only |
Integer32 |
Integer32 (0..2147483647) |
Number of MPLS interfaces configured for FRR protection. |
As per the MIB. |
mplsFrrActiveInterfaces
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrActiveInterfaces (1.3.6.1.2.1.204.1.2) |
read-only |
Gauge32 |
Gauge32 (0..4294967295) |
Number of interfaces currently being protected. An interface is being protected as long as the bypass tunnel on the interface is up. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrConfiguredBypassTunnels (1.3.6.1.2.1.204.1.3) |
read-only |
Gauge32 |
Number of bypass tunnels configured to protect tunnels on this LSR. |
As per the MIB. |
mplsFrrActiveBypassTunnels
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrActiveBypassTunnels (1.3.6.1.2.1.204.1.4) |
read-only |
Gauge32 |
Number of bypass tunnels in up state (ready to protect tunnels). |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityNotificationsEnabled (1.3.6.1.2.1.204.1.5) |
read-write |
Integer32 |
true(1), false(2) |
The capability of sending FRR notifications. |
As per the MIB. |
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityNotificationsMaxRate (1.3.6.1.2.1.204.1.6) |
read-write |
Gauge32 |
Maximum number of FRR notifications sent per second. |
Not supported. This value is already 0. |
Tabular objects
mplsFrrFacilityDBTable
About this table
Use this table to obtain FRR database information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
The mplsFrrFacilityDBProtectingTunnelResvBw object displays only the bandwidth information. It does not display the CT information. The value active(1) for mplsFrrFacilityDBProtectingTunnelStatus indicates that a primary/bypass tunnel FRR switchover has occurred. The value ready(2) for mplsFrrFacilityDBProtectingTunnelStatus indicates a bypass tunnel has been bound to the primary tunnel but no FRR switchover has occurred. |
Columns
The table indexes are mplsFrrFacilityProtectedIfIndex, mplsFrrFacilityProtectingTunnelIndex, mplsFrrFacilityBackupTunnelIndex, mplsFrrFacilityBackupTunnelInstance, and mplsFrrFacilityBackupTunnelIngressLSRId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
mplsFrrFacilityProtectedIfIndex (1.3.6.1.2.1.204.1.7.1.1) |
not-accessible |
InterfaceIndex |
Integer32 (1..2147483647) |
Index of an interface configured for FRR protection. |
As per the MIB. |
mplsFrrFacilityProtectingTunnelIndex (1.3.6.1.2.1.204.1.7.1.2) |
not-accessible |
MplsTunnelIndex |
Unsigned32 (0..65535) |
Index for a bypass tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex. |
As per the MIB. |
mplsFrrFacilityBackupTunnelIndex (1.3.6.1.2.1.204.1.7.1.3) |
not-accessible |
MplsTunnelIndex |
Index of the protected tunnel on the interface specified by mplsFrrFacilityProtectedIfIndex. |
As per the MIB. |
mplsFrrFacilityBackupTunnelInstance (1.3.6.1.2.1.204.1.7.1.4) |
not-accessible |
MplsTunnelInstanceIndex |
Unsigned32 (0..2147483647) |
Index of the protected tunnel instance. |
As per the MIB. |
mplsFrrFacilityBackupTunnelIngressLSRId (1.3.6.1.2.1.204.1.7.1.5) |
not-accessible |
MplsLsrIdentifier |
OCTET STRING (0..255) |
Ingress LSR ID of the protected tunnel. |
As per the MIB. |
mplsFrrFacilityBackupTunnelEgressLSRId (1.3.6.1.2.1.204.1.7.1.6) |
not-accessible |
MplsLsrIdentifier |
Egress LSR ID of the protected tunnel. |
As per the MIB. |
mplsFrrFacilityDBNumProtectingTunnelOnIf (1.3.6.1.2.1.204.1.7.1.7) |
read-only |
Gauge32 |
Number of bypass tunnels on the interface. |
As per the MIB. |
mplsFrrFacilityDBNumProtectedLspOnIf (1.3.6.1.2.1.204.1.7.1.8) |
read-only |
Gauge32 |
Gauge32 (0.. 4294967295) |
Number of LSPs being protected on the interface. |
As per the MIB. |
mplsFrrFacilityDBNumProtectedTunnels (1.3.6.1.2.1.204.1.7.1.9) |
read-only |
Gauge32 |
Number of tunnels being protected on the interface. |
As per the MIB. |
mplsFrrFacilityDBNumProtectingTunnelStatus (1.3.6.1.2.1.204.1.7.1.10) |
read-only |
Integer32 |
active(1), ready(2), partial(3) |
State of the bypass tunnel. |
Supports only active(1) and ready(2) |
mplsFrrFacilityDBNumProtectingTunnelResvBw (1.3.6.1.2.1.204.1.7.1.11) |
read-only |
Unsigned32 |
Unsigned32 (0..4294967295) |
Bandwidth reserved for the bypass tunnel to provide bandwidth protection. |
As per the MIB. |
Notifications
mplsFrrFacilityInitialBackupTunnelInvoked
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.2.1.204.0.1 |
Interface failed and bypass tunnel took over. |
Error |
Major |
1.3.6.1.2.1.204.1.7.1.7 (mplsFrrFacilityDBNumProtectingTunnelOnIf) |
ON |
This notification is generated when a bypass tunnel specified in mplsFrrConstraintsTable takes over the primary tunnel running over an interface also specified in the mplsFrrConstraintsTable.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index |
Type |
Value range |
Number of bypass tunnels on an interface for protection. |
No |
Gauge32 |
Standard MIB values. |
1.3.6.1.2.1.204.1.7.1.8 (mplsFrrFacilityDBNumProtectedLspOnIf) |
Number of CRLSPs protected on the interface. |
No |
Gauge32 |
1.3.6.1.2.1.204.1.7.1.9 (mplsFrrFacilityDBNumProtectedTunnels) |
Number of tunnels protected on the interface. |
No |
Gauge32 |
1.3.6.1.2.1.204.1.7.1.10 (mplsFrrFacilityDBProtectingTunnelStatus) |
State of a bypass tunnel on the interface. |
No |
INTEGER |
active(1) ready(2) |
1.3.6.1.2.1.204.1.7.1.11 (mplsFrrFacilityDBProtectingTunnelResvBw) |
Amount of bandwidth reserved by a bypass tunnel on the interface. |
No |
Unsigned32 |
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
mplsFrrFacilityFinalTunnelRestored
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.2.1.204.0.2 |
Interface recovered and primary tunnel recovered. |
Recovery |
ON |
This notification is generated when the primary tunnel that is being protected by a bypass tunnel as specified in the mplsFrrConstraintsTable restores normal operation.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Number of bypass tunnels for FRR facility backup. |
No |
Unsigned32 |
Number of LSPs protected by FRR facility backup. |
No |
Unsigned32 |
Number of tunnels protected by FRR facility backup. |
No |
Unsigned32 |
State of a bypass tunnel for FRR facility backup. |
No |
Integer32 |
Amount of bandwidth reserved by the bypass tunnel for FRR facility backup. |
No |
Unsigned32 |
Recommended action
