- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
07-HH3C-MPLSSLSP-MIB | 47.07 KB |
HH3C-MPLSSLSP-MIB
About this MIB
Use this MIB to notify static LSP traps.
MIB file name
hh3c-mplsslsp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsSlsp(230)
Tabular objects
hh3cMplsSlspBaseInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsSlspBaseInfo (1.3.6.1.4.1.25506.2.230.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (0..127) |
Static LSP basic information |
As per the MIB. |
hh3cMplsSlspExtInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsSlspExtInfo (1.3.6.1.4.1.25506.2.230.1.1.2) |
OCTET STRING |
Static LSP extended information |
As per the MIB. |
Notifications
hh3cMplsSlspDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.230.0.1 |
Static LSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.230.0.2(hh3cMplsSlspUp) |
ON |
This notification is generated when a static LSP goes down. Traffic forwarding over the static LSP will fail.
Status control
ON
CLI: Use the snmp-agent trap enable lsm command.
OFF
CLI: Use the undo snmp-agent trap enable lsm command.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.230.1.1.1 (hh3cMplsSlspBaseInfo) |
Yes |
OCTET STRING |
As per the MIB. |
1.3.6.1.4.1.25506.2.230.1.1.2 (hh3cMplsSlspExtInfo) |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsSlspUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.226.0.2 |
Static LSP up |
Recovery |
ON |
This notification is generated when a static LSP comes up.
Status control
ON
OFF
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
