- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
01-HH3C-EVC-MIB | 51.81 KB |
HH3C-EVC-MIB
About this MIB
Use this MIB to configure EVC related settings.
MIB file name
hh3c-evc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEvc(106)
Tabular objects
hh3cEvcScalarGroup
About this table
Use this table to obtain global EVC information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
This table does not contain indexes.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvcSrvInstEncapCapabilities (1.3.6.1.4.1.25506.2.106.1.1.1) |
read-only |
BITS |
encapDefault(0), encapUntagged(1), encapTagged(2), encapSvlanId(3), encapSvlanIdList(4), encapSvlanIdOnlyTagged(5), encapSvlanIdCvlanId(6), encapSvlanIdCvlanIdList(7), encapCvlanId(8), encapCvlanIdList(9) |
Capabilities of the EVC service instance. |
As per the MIB. |
hh3cEvcPortMaxSrvInstNum (1.3.6.1.4.1.25506.2.106.1.1.2) |
read-only |
Integer32 |
Integer32 (1..2147483647) |
Maximum number of EVC service instances supported on a port. |
As per the MIB. |
hh3cEvcSrvInstTable
About this table
Use this table to create and delete EVC service instances.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
The table indexes are ifIndex and hh3cEvcSrvInstId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvcSrvInstId (1.3.6.1.4.1.25506.2.106.1.2.1.1) |
not-accessible |
Integer32 |
Service instance ID. |
As per the MIB. |
hh3cEvcSrvInstEncap (1.3.6.1.4.1.25506.2.106.1.2.1.2) |
read-create |
INTEGER |
none(0), default(1), untagged(2), tagged(3), svlanIdList(4), svlanIdListOnlyTagged(5), svlanIdCvlanId(6), svlanIdCvlanIdList(7), svlanIdCvlanIdAll(8), cvlanIdList(9) |
Encapsulation type of the service instance. |
As per the MIB. |
hh3cEvcSrvInstSvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.3) |
read-create |
OCTET STRING |
OCTET STRING (0..256) |
Low bit of the SVLAN list. |
As per the MIB. |
hh3cEvcSrvInstSvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.4) |
read-create |
OCTET STRING |
High bit of the SVLAN list. |
As per the MIB. |
hh3cEvcSrvInstRowStatus (1.3.6.1.4.1.25506.2.106.1.2.1.5) |
read-create |
RowStatus |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
Row status. |
Supports active(1), createAndGo(4), and destroy(6). |
hh3cEvcSrvInstEnableInStat (1.3.6.1.4.1.25506.2.106.1.2.1.6) |
read-create |
TruthValue |
true(1), false(2) |
Inbound statistics function. |
Supports only the read operation. The set operation will be ignored. |
hh3cEvcSrvInstEnableOutStat (1.3.6.1.4.1.25506.2.106.1.2.1.7) |
read-create |
TruthValue |
true(1), false(2) |
Outbound statistics function. |
hh3cEvcSrvInstCvlanIdListLow (1.3.6.1.4.1.25506.2.106.1.2.1.8) |
read-create |
OCTET STRING |
Low bit of the CVLAN list. |
As per the MIB. |
hh3cEvcSrvInstCvlanIdListHigh (1.3.6.1.4.1.25506.2.106.1.2.1.9) |
read-create |
OCTET STRING |
High bit of the CVLAN list. |
As per the MIB. |
hh3cEvcSrvInstCarTable
About this table
Use this table to configure CAR for EVC service instances.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvcSrvInstInCarIndex (1.3.6.1.4.1.25506.2.106.1.3.1.1) |
read-write |
Integer32 |
Global CAR index in the inbound direction. |
Supports only the read operation. |
hh3cEvcSrvInstOutCarIndex (1.3.6.1.4.1.25506.2.106.1.3.1.2) |
read-write |
Integer32 |
Global CAR index in the outbound direction. |
hh3cEvcSrvInstStatInfoTable
About this table
Use this table to obtain forwarding statistics about an EVC service instance.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cEvcSrvInstInPackets (1.3.6.1.4.1.25506.2.106.1.4.1.1) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Number of packets received on this service instance. |
As per the MIB. |
hh3cEvcSrvInstInBytes (1.3.6.1.4.1.25506.2.106.1.4.1.2) |
read-only |
Counter64 |
Number of bytes received on this service instance. |
As per the MIB. |
hh3cEvcSrvInstOutPackets (1.3.6.1.4.1.25506.2.106.1.4.1.3) |
read-only |
Counter64 |
Number of packets transmitted on this service instance. |
As per the MIB. |
hh3cEvcSrvInstOutBytes (1.3.6.1.4.1.25506.2.106.1.4.1.4) |
read-only |
Counter64 |
Number of bytes transmitted on this service instance. |
As per the MIB. |
