- 10-MPLS
- 01-HH3C-EVC-MIB
- 02-HH3C-L2VPN-MIB
- 03-HH3C-L3VPN-MIB
- 04-HH3C-MPLSCRLSP-MIB
- 05-HH3C-MPLSEXT-MIB
- 06-HH3C-MPLSRSVP-MIB
- 07-HH3C-MPLSSLSP-MIB
- 08-HH3C-MPLSTE-MIB
- 09-HH3C-MPLS-VPN-BGP-MIB
- 10-HH3C-VSI-MIB
- 11-MPLS-FRR-FACILITY-STD-MIB
- 12-MPLS-FRR-GENERAL-STD-MIB
- 13-MPLS-FTN-STD-MIB
- 14-MPLS-L3VPN-STD-MIB
- 15-MPLS-LDP-STD-MIB
- 16-MPLS-LSR-STD-MIB
- 17-MPLS-TE-STD-MIB
- 18-PW-ENET-STD-MIB
- 19-PW-MPLS-STD-MIB
- 20-PW-STD-MIB
- 21-TE-MIB
04-HH3C-MPLSCRLSP-MIB | 49.19 KB |
HH3C-MPLSSCRLSP-MIB
About this MIB
Use this MIB to notify traps about static CRLSPs.
MIB file name
hh3c-mplsscrlsp.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(4).mib-2(1).transmission(25506).mplsStdMIB(2).mplsTeCrlspStdMIB(231)
Tabular objects
hh3cMplsScrlspBaseInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsScrlspBaseInfo (1.3.6.1.4.1.25506.2.231.1.1.1) |
accessible-for-notify |
OCTET STRING |
OCTET STRING (1..127) |
Static CRLSP basic information |
As per the MIB. |
hh3cMplsScrlspExtInfo
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cMplsScrlspExtInfo (1.3.6.1.4.1.25506.2.231.1.1.2) |
OCTET STRING |
Static CRLSP extended information |
As per the MIB. |
Notifications
hh3cMplsScrlspDown
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.231.0.1 |
Static CRLSP down |
Error |
Major |
1.3.6.1.4.1.25506.2.231.0.2 (hh3cMplsScrlspUp) |
ON |
This notification is generated when a static CRLSP goes down. The MPLS TE tunnel that uses the static CRLSP will fail to forward traffic.
Status control
ON
CLI: Use the snmp-agent trap enable lsm command.
OFF
CLI: Use the undo snmp-agent trap enable lsm command.
Objects
OID (object name) |
Index |
Type |
Value range |
(1.3.6.1.4.1.25506.2.231.1.1.1) hh3cMplsScrlspBaseInfo |
Yes |
OCTET STRING |
As per the MIB. |
(1.3.6.1.4.1.25506.2.231.1.1.2) hh3cMplsScrlspExtInfo |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
No action is required.
hh3cMplsScrlspUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.231.0.2 |
Static CRLSP up |
Recovery |
N/A |
N/A |
ON |
This notification is generated when a static CRLSP comes up.
Status control
ON
CLI: Use the snmp-agent trap enable te command.
OFF
CLI: Use the undo snmp-agent trap enable te command.
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
OCTET STRING |
As per the MIB. |
Yes |
OCTET STRING |
As per the MIB. |
Recommended action
