- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
30-RBRIDGE-MIB | 142.69 KB |
RBRIDGE-MIB
About this MIB
Use this MIB to manage TRILL-capable RBridges.
MIB file name
rfc6850-rbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).rbridgeMIB(214)
Scalar objects
rbridgeBaseTrillVersion
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseTrillVersion (1.3.6.1.2.1.214.1.1.1) |
read-only |
Unsigned32 |
Standard MIB values. |
Maximum TRILL version number that this RBridge supports. |
As per the MIB. |
rbridgeBaseNumPorts
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseNumPorts (1.3.6.1.2.1.214.1.1.2) |
read-only |
Unsigned32 |
Number of ports controlled by an RBridge. |
As per the MIB. |
rbridgeBaseForwardDelay
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseForwardDelay (1.3.6.1.2.1.214.1.1.3) |
read-write |
Unsigned32 |
Unsigned32 (4..30) |
Address entry aging time after an appointed forwarder changes. |
Not supported |
rbridgeBaseUniMultipathEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseUniMultipathEnable (1.3.6.1.2.1.214.1.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Enabling state of unicast TRILL multipathing. true(1) means enabled. |
As per the MIB. |
rbridgeBaseMultiMultipathEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseMultiMultipathEnable (1.3.6.1.2.1.214.1.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Enabling state of multidestination TRILL multipathing. true(1) means enabled. |
The object can only be read. |
rbridgeBaseAcceptEncapNonadj
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseAcceptEncapNonadj (1.3.6.1.2.1.214.1.1.6) |
read-write |
TruthValue |
true(1), false(2) |
Accept TRILL-encapsulated frames from a neighbor with which this RBridge does not have an IS-IS adjacency when the value of this object is true (1). |
The object can only be read. The value is fixed at False(2). |
rbridgeBaseNicknameNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseNicknameNumber (1.3.6.1.2.1.214.1.1.7) |
read-write |
Unsigned32 |
Unsigned32 (1..256) |
Number of nicknames this RBridge should acquire. |
The object can only be read. The value is fixed at 1. |
rbridgeDtreePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeDtreePriority (1.3.6.1.2.1.214.1.7.1) |
Read-write |
Unsigned32 |
Unsigned32 (1..65535) |
Distribution tree root priority for this RBridge. |
As per the MIB. |
rbridgeDtreeActiveTrees
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeDtreeActiveTrees (1.3.6.1.2.1.214.1.7.2) |
read-only |
Unsigned32 |
Total number of trees being computed by all RBridges in the network. |
As per the MIB. |
rbridgeDtreeMaxTrees
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeDtreeMaxTrees (1.3.6.1.2.1.214.1.7.3) |
read-only |
Unsigned32 |
Maximum number of trees this RBridge can compute. |
The value is fixed at 15. |
rbridgeDtreeDesiredUseTrees
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeDtreeDesiredUseTrees (1.3.6.1.2.1.214.1.7.4) |
read-only |
Unsigned32 |
Maximum number of trees this RBridge would like to use for transmission of ingress multi-destination frames. |
As per the MIB. |
rbridgeTrillMinMtuDesired
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeTrillMinMtuDesired (1.3.6.1.2.1.214.1.8.1) |
read-write |
Unsigned32 |
Desired minimum acceptable inter-RBridge link MTU for the network. |
The value range is 512 to 16384. |
rbridgeTrillSz
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeTrillSz(1.3.6.1.2.1.214.1.8.2) |
read-only |
Unsigned32 |
Minimum acceptable inter-RBridge link size for the network for the proper operation of TRILL IS-IS. |
As per the MIB. |
rbridgeTrillMaxMtuProbes
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeTrillMaxMtuProbes(1.3.6.1.2.1.214.1.8.3) |
read-write |
Unsigned32 |
Unsigned32 (1..255) |
Number of failed MTU-probes before the RBridge concludes that a particular MTU is not supported by a neighbor. |
Not supported |
Tabular objects
rbridgeBaseNicknameTable
About this table
Use this table to obtain information about nicknames configured by an operator or learned dynamically by this RBridge.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is rbridgeBaseNicknameName.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBaseNicknameName (1.3.6.1.2.1.214.1.1.8.1.1) |
not-accessible |
RbridgeNickname |
16-bit abbreviation for an RBridge's 48-bit IS-IS system ID. |
As per the MIB. |
rbridgeBaseNicknamePriority (1.3.6.1.2.1.214.1.1.8.1.2) |
read-create |
Unsigned32 |
Unsigned32 (0..255) |
RBridge's priority to hold this nickname. |
In an automatically generated entry, this object cannot be modified. |
rbridgeBaseNicknameDtrPriority (1.3.6.1.2.1.214.1.1.8.1.3) |
read-create |
Unsigned32 |
Distribution tree root priority for this nickname. |
rbridgeBaseNicknameType (1.3.6.1.2.1.214.1.1.8.1.4) |
read-only |
INTEGER |
static(1), dynamic(2) |
Nickname type. The default is static(1). |
As per the MIB. |
rbridgeBaseNicknameRowStatus (1.3.6.1.2.1.214.1.1.8.1.5) |
read-create |
RowStatus |
State of the current entry. |
Available values are active(1), createAndGo(4), and destroy(6). An RBridge can have only one such an entry. When a new entry is added, the old entry is overwritten. When an entry is deleted, a new entry is automatically generated. In an automatically generated entry, this object cannot be deleted. |
rbridgeBasePortTable
About this table
Use this to obtain basic information about ports associated with an RBridge.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is rbridgeBasePort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeBasePort (1.3.6.1.2.1.214.1.1.9.1.1) |
not-accessible |
Unsigned32 |
Port number of the port for which this entry contains RBridge management information. |
As per the MIB. |
rbridgeBasePortIfIndex (1.3.6.1.2.1.214.1.1.9.1.2) |
read-only |
InterfaceIndex |
Index of the interface corresponding to this port in the IF-MIB. |
As per the MIB. |
rbridgeBasePortDisable (1.3.6.1.2.1.214.1.1.9.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Bit for disabling a port. When this bit is set (true), all frames received or to be transmitted are discarded, except local frames. The default is false (2). |
Not supported. The value is fixed at false(2). |
rbridgeBasePortTrunkPort (1.3.6.1.2.1.214.1.1.9.1.4) |
read-write |
TruthValue |
true(1), false(2) |
Bit for disabling the endpoint service. When this bit is set (true), all native frames received on the port and all native frames that would have been sent on the port are discarded. The default is false (2). |
The rbridgeBasePortTrunkPort and rbridgeBasePortAccessPort objects cannot be both set to false(2). |
rbridgeBasePortAccessPort (1.3.6.1.2.1.214.1.1.9.1.5) |
read-write |
TruthValue |
true(1), false(2) |
Bit for disabling TRILL traffic. If this bit is set to true(1), the port does not send any TRILL frames except TRILL-Hello frames. The default is false (2). |
The default is true (1). The rbridgeBasePortTrunkPort and rbridgeBasePortAccessPort objects cannot be both set to false(2). |
rbridgeBasePortP2pHellos (1.3.6.1.2.1.214.1.1.9.1.6) |
read-write |
TruthValue |
true(1), false(2) |
Point-to-point (P2P) Hellos bit. If this bit is set to true(1), the port sends IS-IS Hello frames rather than TRILL HELLO frames (default). The default is false (2). |
rbridgeBasePortState (1.3.6.1.2.1.214.1.1.9.1.7) |
read-only |
INTEGER |
uninhibited(1), portInhibited(2), vlanInhibited(3), disabled(4), broken(5) |
Current state of a port. |
As per the MIB. |
rbridgeBasePortInhibitionTime (1.3.6.1.2.1.214.1.1.9.1.8) |
read-write |
Unsigned32 |
Time in seconds that this RBridge will inhibit forwarding on this port after it observes a spanning tree root bridge change on a link or receives conflicting VLAN forwarder information. The default is 30. |
The value range is 0 to 30. |
rbridgeBasePortDisableLearning (1.3.6.1.2.1.214.1.1.9.1.9) |
read-write |
TruthValue |
true(1), false(2) |
Set this object to true(1) to disable learning of MAC addresses seen on this port. |
rbridgeBasePortDesiredDesigVlan (1.3.6.1.2.1.214.1.1.9.1.10) |
read-write |
VlanId |
VLAN that a Designated RBridge (DRB) will specify in its TRILL-Hellos as the VLAN to be used by all RBridges on the link for TRILL frames. |
The default is that of rbridgeBasePortDesigVlan. |
rbridgeBasePortDesigVlan (1.3.6.1.2.1.214.1.1.9.1.11) |
read-only |
VlanId |
VLAN being used on this link for TRILL frames. |
The object does not return any value when the port state is down or no VLAN is enabled. |
rbridgeBasePortStpRoot (1.3.6.1.2.1.214.1.1.9.1.12) |
read-only |
BridgeId |
Bridge identifier of the root of the spanning tree learned from a Bridge PDU (BPDU) received on this port. |
As per the MIB. |
rbridgeBasePortStpRootChanges (1.3.6.1.2.1.214.1.1.9.1.13) |
read-only |
Counter32 |
Number of times a change in the root bridge is seen from spanning tree BPDUs received on this port, indicating a change in bridged LAN topology. |
As per the MIB. |
rbridgeBasePortStpWiringCloset (1.3.6.1.2.1.214.1.1.9.1.14) |
read-write |
BridgeId |
Bridge ID to be used as the spanning tree root in BPDUs. |
Not supported. The value is fixed at 0. |
rbridgeUniFdbTable
About this table
Use this table to obtain the information about unicast entries for which the device has forwarding and/or filtering information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are rbridgeFdbId and rbridgeUniFdbAddr.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeFdbId (1.3.6.1.2.1.214.1.2.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32 (0..4294967295) |
ID of this filtering database. |
As per the MIB. |
rbridgeUniFdbAddr (1.3.6.1.2.1.214.1.2.4.1.2) |
not-accessible |
MacAddress |
MAC address for which the device has forwarding information. |
As per the MIB. |
rbridgeUniFdbPort (1.3.6.1.2.1.214.1.2.4.1.3) |
read-only |
Unsigned32 |
Unsigned32 (0..65535) |
Port number corresponding the address of rbridgeUniFdbAddr. The value 0 indicates no port number is learned. |
rbridgeUniFdbNickname (1.3.6.1.2.1.214.1.2.4.1.4) |
read-only |
RbridgeNickname |
RBridge nickname that is placed in the egress nickname field of a TRILL frame sent to the current address. |
As per the MIB. |
rbridgeUniFdbConfidence (1.3.6.1.2.1.214.1.2.4.1.5) |
read-only |
Unsigned32 |
Confidence level associated with this entry. |
rbridgeUniFdbStatus (1.3.6.1.2.1.214.1.2.4.1.6) |
read-only |
INTEGER |
other(1), invalid(2), learned(3), self(4), mgmt(5), esadi(6) |
As per the MIB. |
rbridgeUniFibTable
About this table
Use this table to obtain the known nicknames of an RBridge.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are rbridgeUniFibNickname, rbridgeUniFibPort, and rbridgeUniFibNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeUniFibNickname (1.3.6.1.2.1.214.1.2.5.1.1) |
not-accessible |
RbridgeNickname |
RBridge nickname for which this RBridge has forwarding information. |
As per the MIB. |
rbridgeUniFibPort (1.3.6.1.2.1.214.1.2.5.1.2) |
not-accessible |
Unsigned32 |
RBridge port number of the corresponding RBridge. |
As per the MIB. |
rbridgeUniFibNextHop (1.3.6.1.2.1.214.1.2.5.1.3) |
not-accessible |
RbridgeNickname |
Nickname of the next-hop RBridge for the path towards the RBridge whose nickname is specified in this entry. |
As per the MIB. |
rbridgeUniFibHopCount (1.3.6.1.2.1.214.1.2.5.1.4) |
read-only |
Unsigned32 |
Hop count from this ingress RBridge to the egress RBridge. |
As per the MIB. |
rbridgeMultiFibTable
About this table
Use this table to obtain information about egress nicknames used for multi-destination frame forwarding by this RBridge.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is rbridgeMultiFibNickname.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeMultiFibNickname (1.3.6.1.2.1.214.1.2.6.1.1) |
not-accessible |
RbridgeNickname |
Nickname of the multicast distribution tree. |
As per the MIB. |
rbridgeMultiFibPorts (1.3.6.1.2.1.214.1.2.6.1.2) |
read-only |
PortList |
List of ports to which a frame destined to this multicast distribution tree is flooded. |
As per the MIB. |
rbridgeVlanTable
About this table
Use this to obtain VLAN information of RBridges.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is rbridgeVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeVlanIndex (1.3.6.1.2.1.214.1.3.1.1.1) |
not-accessiable |
Unsigned32 |
Unsigned32 (1..4094|4096..4294967295) |
ID of a VLAN. |
As per the MIB. |
rbridgeVlanForwarderLosts (1.3.6.1.2.1.214.1.3.1.1.2) |
read-only |
Counter32 |
Number of times this RBridge has lost appointed forwarder status for this VLAN on any of its ports. |
rbridgeVlanDisableLearning (1.3.6.1.2.1.214.1.3.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Set this object to true(1) to disable learning of MAC addresses in this VLAN. |
rbridgeVlanSnooping (1.3.6.1.2.1.214.1.3.1.1.4) |
read-only |
INTEGER |
notSupported(1), ipv4(2), ipv6(3), ipv4v6(4) |
IP multicast snooping on this VLAN. |
As per the MIB. |
rbridgeVlanPortTable
About this table
Use this table to obtain VLAN information of RBridge ports.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are rbridgeBasePort and rbridgeVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeVlanPortInhibited (1.3.6.1.2.1.214.1.3.2.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Setting this object to true(1) means this VLAN has been inhibited by the RBridge due to conflicting forwarder information received from another RBridge. |
As per the MIB. |
rbridgeVlanPortForwarder (1.3.6.1.2.1.214.1.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Setting this object to true(1) means this RBridge is an appointed forwarder for this VLAN on this port. |
As per the MIB. |
rbridgeVlanPortAnnouncing (1.3.6.1.2.1.214.1.3.2.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Setting this object to true(1) means TRILL Hellos tagged with this VLAN can be sent by this RBridge on this port. |
As per the MIB. |
rbridgeVlanPortDetectedVlanMapping (1.3.6.1.2.1.214.1.3.2.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Setting this object to true(1) means VLAN mapping has been detected on the link attached to this port. |
rbridgeSnoopingPortTable
About this table
Use this table to obtain information about ports on which the presence of IPv4 or IPv6 multicast routers has been detected for RBridges implementing IP multicast snooping.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeSnoopingPortAddrType (1.3.6.1.2.1.214.1.6.1.1.1) |
read-only |
INTEGER |
ipv4(1), ipv6(2), ipv4v6(3) |
IP address type of an IP multicast router detected on this port and VLAN. |
As per the MIB. |
rbridgeDtreeTable
About this table
Use this to obtain information about distribution trees being computed by this RBridge.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is rbridgeDtreeNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
rbridgeDtreeNumber (1.3.6.1.2.1.214.1.7.5.1.1) |
not-accessible |
Unsigned32 |
Number of trees in a distribution tree computed by this RBridge. |
As per the MIB. |
rbridgeDtreeNickname (1.3.6.1.2.1.214.1.7.5.1.2) |
read-only |
RbridgeNickname |
Nickname of the distribution tree. |
As per the MIB. |
rbridgeDtreeIngress(1.3.6.1.2.1.214.1.7.5.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether this RBridge might choose this distribution tree to receive a multi-destination frame. |
The value is fixed at true(1). |
