- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
21-LLDP-EXT-DOT1-V2-MIB | 248.66 KB |
lldpV2Xdot1ConfigPortVlanTable
lldpV2Xdot1ConfigVlanNameTable
lldpV2Xdot1ConfigProtoVlanTable
lldpV2Xdot1ConfigProtocolTable
lldpV2Xdot1ConfigVidUsageDigestTable
lldpV2Xdot1RemVidUsageDigestTable
lldpXdot1dcbxConfigETSConfigurationTable
lldpXdot1dcbxConfigETSRecommendationTable
lldpXdot1dcbxConfigApplicationPriorityTable
lldpXdot1dcbxLocETSBasicConfigurationTable
lldpXdot1dcbxLocETSConPriorityAssignmentTable
lldpXdot1dcbxLocETSConTrafficClassBandwidthTable
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxLocETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxLocPFCEnableTable
lldpXdot1dcbxLocApplicationPriorityAppTable
lldpXdot1dcbxRemETSBasicConfigurationTable
lldpXdot1dcbxRemETSConPriorityAssignmentTable
lldpXdot1dcbxRemETSConTrafficClassBandwidthTable
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxRemETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxRemPFCEnableTable
lldpXdot1dcbxRemApplicationPriorityAppTable
lldpXdot1dcbxAdminETSBasicConfigurationTable
lldpXdot1dcbxAdminETSConPriorityAssignmentTable
lldpXdot1dcbxAdminETSConTrafficClassBandwidthTable
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithmTable
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidthTable
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithmTable
lldpXdot1dcbxAdminPFCBasicTable
About this MIB
LLDP facilitates network management to discover and use network physical topology in a standard way, and enables network management to discover configuration inconsistencies or errors that affect the upper-layer applications. Although H3C products already support the LLDP 2009 version, they still use the MIBs of the LLDP 2005 version.
The MIB of the LLDP 2009 version is also referred to as LLDP-V2-MIB. This MIB is a standard public MIB, which contains LLDP configuration, LLDP statistics, local LLDP information, neighboring LLDP information, and IEEE 802.1 extended configuration, DCBX extended configuration, IEEE 802.3 extended configuration. The CNP extended configuration is not supported in Comware V700R001.
MIB file name
lldp-ext-dot1-v2.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962)
This MIB is the LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information.
Tabular objects
About this table
This table controls selection of LLDP port VLAN TLVs to be transmitted on individual ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigPortVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the port VLAN TLV transmission is enabled on a given LLDP transmission capable port. |
The default is true for the following agents: Nearest bridge agents and nearest customer bridge agents on the Layer 2 Ethernet interfaces. Nearest customer bridge agents on Layer 2 aggregate interfaces. |
About this table
This table controls selection of LLDP VLAN name TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigVlanNameTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the agents on the ports of the device can send VLAN name TLVs. |
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one VLAN name TLV is supported in an LLDP packet. As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to walk through all ports and VLANs. |
About this table
This table controls selection of LLDP port and protocol VLAN ID TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocProtoVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigProtoVlanTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the transmission of port and protocol VLAN ID TLVs is enabled on a given LLDP transmission capable port. |
By default, the value is 0 and the status is FALSE. If this object is set to TRUE, the VLAN with the minimum VLAN ID is enabled. To delete an enabled VLAN, set the VLAN status to FALSE. Only one protocol VLAN TLV is supported in an LLDP packet. As a best practice, do not perform the walk operation from the MIB browser, because it takes a long time to scan all ports and VLANs. |
About this table
This table controls selection of LLDP protocol identity TLV instances to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpV2Xdot1LocProtocolIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigProtocolTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.4.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the agents on the ports of the device can send protocol identity TLVs. |
Not supported. |
About this table
This table controls selection of LLDP VID usage digest TLVs to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.5.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigVidUsageDigestTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.5.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the agents on the ports of the device can send VID usage digest TLVs. |
Not supported. |
lldpV2Xdot1ConfigManVidTable
About this table
This table controls selection of management VID TLVs to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.1.6.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1ConfigManVidTxEnable (1.3.111.2.802.1.1.13.1.5.32962.1.1.6.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the management VID TLV transmission is enabled on a given LLDP transmission capable port. |
As per the MIB. |
lldpV2Xdot1LocTable
About this table
This table contains local VLAN ID information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.1.1.1) |
read-only |
Unsigned32 |
Unsigned32(0|1..4094) |
Local VLAN ID. |
As per the MIB. |
lldpV2Xdot1LocProtoVlanTable
About this table
This table contains information about local port and protocol VLANs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.1) |
not-accessible |
Unsigned32 |
Unsigned320|1..4094 |
Port and protocol VLAN ID. |
As per the MIB. |
lldpV2Xdot1LocProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given local port supports port and protocol VLANs. |
As per the MIB. |
lldpV2Xdot1LocProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.2.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the port and protocol VLANs are enabled on the given local port. |
As per the MIB. |
lldpV2Xdot1LocVlanNameTable
About this table
This table contains information about VLAN names on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.1) |
not-accessible |
VlanId |
Standard MIB values. |
ID of the VLAN to which the port belongs. |
As per the MIB. |
lldpV2Xdot1LocVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.2.3.1.2) |
read-only |
SnmpAdminString |
OCTET STRING (1..32) |
VLAN name identified by the VLAN ID associated with the given local port. |
As per the MIB. |
lldpV2Xdot1LocProtocolTable
About this table
This table contains protocol identity information on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.2.4.1.1) |
not-accessible |
Unsigned32 |
Unsigned32(1..2147483647) |
Protocol index. |
Not supported. |
lldpV2Xdot1LocProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.2.4.1.2) |
read-only |
OCTET STRING |
OCTET STRING (1..255) |
IDs of the protocols associated with the given port. |
Not supported. |
lldpV2Xdot1LocManVidTable
About this table
This table contains management TLV information on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.6.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocManVid (1.3.111.2.802.1.1.13.1.5.32962.1.2.6.1.1) |
read-only |
Unsigned32 |
Local management TLV information. |
As per the MIB. |
lldpV2Xdot1LocLinkAggTable
About this table
This table contains link aggregation information on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.2.7.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.1) |
read-only |
LldpV2LinkAggStatusMap |
The link aggregation capabilities and the current aggregation status of the system. |
As per the MIB. |
lldpV2Xdot1LocLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.2.7.1.2) |
read-only |
Unsigned32 |
Unsigned32(0|1..2147483647) |
Aggregate interface ID. |
As per the MIB. |
lldpV2Xdot1RemTable
About this table
This table contains information about physical network connections.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemPortVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.1.1.1) |
read-only |
Unsigned32 |
PVID of the given port on a neighboring device. |
As per the MIB. |
lldpV2Xdot1RemProtoVlanTable
About this table
This table contains port and protocol VLAN information about the neighboring devices, received on the given port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpV2Xdot1RemProtoVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemProtoVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.1) |
not-accessible |
Unsigned32 |
Port and protocol VLAN ID of a neighboring device. |
As per the MIB. |
lldpV2Xdot1RemProtoVlanSupported (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether the given port of the neighboring device supports port and protocol VLANs. |
As per the MIB. |
lldpV2Xdot1RemProtoVlanEnabled (1.3.111.2.802.1.1.13.1.5.32962.1.3.2.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates whether port and protocol VLANs are enabled on the given port of the neighboring device. |
As per the MIB. |
lldpV2Xdot1RemVlanNameTable
About this table
This table contains information about VLAN names on the ports of the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex,a nd lldpV2Xdot1RemVlanId.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemVlanId (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.1) |
not-accessible |
VlanId |
ID of the VLAN to which a port on a neighboring device belongs. |
As per the MIB. |
lldpV2Xdot1RemVlanName (1.3.111.2.802.1.1.13.1.5.32962.1.3.3.1.2) |
read-only |
SnmpAdminString |
VLAN name identified by the VLAN ID associated with the neighboring device. |
As per the MIB. |
lldpV2Xdot1RemProtocolTable
About this table
This table contains neighboring protocol information received on the given port.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddres, lldpV2RemIndex, and lldpV2Xdot1RemProtocolIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemProtocolIndex (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.1) |
not-accessible |
Unsigned32 |
Protocol index. |
As per the MIB. |
lldpV2Xdot1RemProtocolId (1.3.111.2.802.1.1.13.1.5.32962.1.3.4.1.2) |
read-only |
OCTET STRING |
IDs of the protocols associated with the ports of the neighboring devices. |
As per the MIB. |
About this table
This table contains VID usage information of the agents on the ports of the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, and lldpV2RemLocalDestMACAddress.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.5.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemVidUsageDigest (1.3.111.2.802.1.1.13.1.5.32962.1.3.5.1.1) |
read-only |
Unsigned32 |
VID usage information on the given port of a neighboring device. |
As per the MIB. |
lldpV2Xdot1RemManVidTable
About this table
This table contains management VLAN information received from the neighbors.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.6.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemManVid (1.3.111.2.802.1.1.13.1.5.32962.1.3.6.1.1) |
read-only |
Unsigned32 |
Management VLAN information on the given port of a neighboring device. |
As per the MIB. |
lldpV2Xdot1RemLinkAggTable
About this table
This table contains port link aggregation information of the agents on the ports of the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex. lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.1.3.7.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemLinkAggStatus (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.1) |
read-only |
Link aggregation capabilities and current aggregation status of a neighboring device. |
As per the MIB. |
lldpV2Xdot1RemLinkAggPortId (1.3.111.2.802.1.1.13.1.5.32962.1.3.7.1.2) |
read-only |
Unsigned32 |
As per the MIB. |
About this table
The table controls selection of ETS configuration TLVs to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex .
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxConfigETSConfigurationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the ETS Configuration TLV transmission is enabled on the agents of a given LLDP transmission capable port. |
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSRecommendationTxEnable, lldpXdot1dcbxConfigPFCTxEnable, and lldpXdot1dcbxConfigApplicationPriorityTxEnable. |
About this table
The table controls selection of ETS recommendation TLVs to be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxConfigETSRecommendationTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the ETS recommendation TLV transmission is enabled on the agents of a given LLDP transmission capable port. |
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigPFCTxEnable, and lldpXdot1dcbxConfigApplicationPriorityTxEnable. |
lldpXdot1dcbxConfigPFCTable
About this table
The table controls selection of priority-based Flow Control TLVs o be transmitted on individual ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxConfigPFCTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.3.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the Flow Control TLV transmission is enabled on the agents of a given LLDP transmission capable port. |
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigETSRecommendationTxEnable, lldpXdot1dcbxConfigApplicationPriorityTxEnable, and lldpXdot1dcbxConfigApplicationPriorityTxEnable. |
About this table
The table configures the transmission of the Application Priority TLV on a set of ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxConfigApplicationPriorityTxEnable (1.3.111.2.802.1.1.13.1.5.32962.5.1.1.4.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Indicates whether the Application Priority TLV transmission is enabled on the agents of a given LLDP transmission capable port. |
The configuration for this object also applies to the following objects: lldpXdot1dcbxConfigETSConfigurationTxEnable, lldpXdot1dcbxConfigETSRecommendationTxEnable, and lldpXdot1dcbxConfigPFCTxEnable. |
About this table
This table contains information about ETS configuration TLVs on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the credit-based shaper traffic selection algorithm is supported on the local system. |
As per the MIB. |
lldpXdot1dcbxLocETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.2) |
read-only |
LldpXdot1dcbxSupportedCapacity |
Indicates the supported capacity of a given feature. |
As per the MIB. |
lldpXdot1dcbxLocETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.1.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the local system is willing to accept the ETS configuration recommended by a neighboring device. |
As per the MIB. |
About this table
This table contains one row per priority. The entry in each row indicates the traffic class to which the priority is assigned.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.1) |
not-accessible |
IEEE8021PriorityValue |
Indicates the priority that is assigned to a traffic class. |
As per the MIB. |
lldpXdot1dcbxLocETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.2.1.2) |
read-only |
LldpXdot1dcbxTrafficClassValue |
Indicates the traffic class to which this priority is to be assigned. |
As per the MIB. |
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic class to which the bandwidth is assigned.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.1) |
not-accessible |
Indicates the traffic class to which this bandwidth applies. |
As per the MIB. |
lldpXdot1dcbxLocETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.3.1.2) |
read-only |
LldpXdot1dcbxTrafficClassBandwidthValue |
Indicates the bandwidth assigned to this traffic class. |
As per the MIB. |
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selction algorithm to be used by the traffic class.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxLocETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.1.4.1.2) |
read-only |
LldpXdot1dcbxTrafficSelectionAlgorithm |
Indicates the traffic selection algorithm to which this traffic class is to be assigned. |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxLocETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.1.1.2) |
read-only |
As per the MIB. |
About this table
This table contains one row per priority. The entry in each row indicates the traffic selction algorithm to be used by the traffic class.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxLocETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.2.2.1.2) |
read-only |
As per the MIB. |
lldpXdot1dcbxLocPFCBasicTable
About this table
This table contains information about local PFC TLVs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index islldpV2LocPortIfIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the local system is willing to accept the PFC configuration of a neighboring device. |
As per the MIB. |
lldpXdot1dcbxLocPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the local system is capable of bypassing MACsec processing when MACsec is disabled. |
As per the MIB. |
lldpXdot1dcbxLocPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.1.1.3) |
read-only |
Indicates the number of traffic classes on the local device that might simultaneously have PFC enabled. |
As per the MIB. |
About this table
This table indicates if PFC is enabled on the corresponding priority on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxLocPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.1) |
not-accessible |
Priority for which PFC is enabled or disabled. |
As per the MIB. |
lldpXdot1dcbxLocPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if PFC is enabled on the corresponding priority. |
As per the MIB. |
About this table
This table contains entries that indicate the priority to be used for a given application.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex, lldpXdot1dcbxLocApplicationPriorityAESelector, and lldpXdot1dcbxLocApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxLocApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.1) |
not-accessible |
LldpXdot1dcbxAppSelector |
Protocol object index. |
As per the MIB. |
lldpXdot1dcbxLocApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.2) |
not-accessible |
LldpXdot1dcbxAppProtocol |
Protocol ID index. |
If the DCBX protocol version is the pre-standard version 1.0, the value of this object is fixed at 35078. |
lldpXdot1dcbxLocApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.2.4.1.3) |
read-only |
The priority code point that should be used in frames transporting the specified protocol. |
As per the MIB. |
About this table
This table contains information about ETS configuration TLVs on the neighbors.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the credit-based shaper traffic selection algorithm is supported on a neighboring device. |
As per the MIB. |
lldpXdot1dcbxRemETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.2) |
read-only |
Indicates the number of traffic classes supported. |
As per the MIB. |
lldpXdot1dcbxRemETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.1.1.3) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the remote system is willing to accept the ETS configuration recommended by the neighboring device. |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.2.1.2) |
read-only |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.3.1.2) |
read-only |
As per the MIB. |
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selection algorithm to be used by the traffic class.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.1) |
not-accessible |
Indicates the traffic class that is assigned to a traffic selection algorithm. |
As per the MIB. |
lldpXdot1dcbxRemETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.1.4.1.2) |
read-only |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.1.1.2) |
read-only |
As per the MIB. |
About this table
This table contains one row per traffic class. The entry in each row indicates the traffic selction algorithm to be used by the priority.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.2.2.1.2) |
read-only |
As per the MIB. |
lldpXdot1dcbxRemPFCBasicTable
About this table
This table contains information about PFC TLVs on the neighbors.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, ldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if a neighboring device is willing to accept the PFC configuration of the local system. |
As per the MIB. |
lldpXdot1dcbxRemPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if a neighboring device is capable of bypassing MACsec processing when MACsec is disabled. |
As per the MIB. |
lldpXdot1dcbxRemPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.1.1.3) |
read-only |
Indicates the number of traffic classes on the neighboring device that might simultaneously have PFC enabled. |
As per the MIB. |
About this table
This table indicates if PFC is enabled on the corresponding priority on the neighbors.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex. lldpV2RemLocalDestMACAddress, lldpV2RemIndex, and lldpXdot1dcbxRemPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.3.2.1.2) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, lldpV2RemIndex, lldpXdot1dcbxRemApplicationPriorityAESelector, and lldpXdot1dcbxRemApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxRemApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.2) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxRemApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.3.4.1.3) |
read-only |
As per the MIB. |
About this table
This table contains information about ETS configuration TLV configuration.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSConCreditBasedShaperSupport (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.1) |
read-only |
TruthValue |
true(1), false(2) |
Indicates if the credit-based shaper traffic selection algorithm is supported. |
As per the MIB. |
lldpXdot1dcbxAdminETSConTrafficClassesSupported (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.2) |
read-only |
As per the MIB. |
lldpXdot1dcbxAdminETSConWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.1.1.3) |
read-write |
TruthValue |
true(1), false(2) |
Indicates if the local system is willing to accept the ETS configuration recommended by the remote system. |
Supports only the read operation. |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConPriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSConPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminETSConPriTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.2.1.2) |
read-write |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSConTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminETSConTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.3.1.2) |
read-write |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSConTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSConTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminETSConTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.1.4.1.2) |
read-write |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSRecoTrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSRecoTrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminETSRecoTrafficClassBandwidth (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.1.1.2) |
read-write |
About this table
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminETSRecoTSATrafficClass.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminETSRecoTSATrafficClass (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminETSRecoTrafficSelectionAlgorithm (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.2.2.1.2) |
read-write |
About this table
This table contains information about local PFC TLV configuration.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminPFCWilling (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
lldpXdot1dcbxAdminPFCMBC (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.2) |
read-only |
TruthValue |
true(1), false(2) |
As per the MIB. |
lldpXdot1dcbxAdminPFCCap (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.1.1.3) |
read-only |
As per the MIB. |
lldpXdot1dcbxAdminPFCEnableTable
About this table
This table lists the configuration about whether PFC is enabled on the corresponding priority on the local system.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex and lldpXdot1dcbxAdminPFCEnablePriority.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminPFCEnablePriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminPFCEnableEnabled (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.3.2.1.2) |
read-write |
TruthValue |
true(1), false(2) |
lldpXdot1dcbxAdminApplicationPriorityAppTable
About this table
This table contains entries indicating the priority to be used for a given application.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2LocPortIfIndex, lldpXdot1dcbxAdminApplicationPriorityAESelector, and lldpXdot1dcbxAdminApplicationPriorityAEProtocol.
The table OID is 1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1dcbxAdminApplicationPriorityAESelector (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.1) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminApplicationPriorityAEProtocol (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.2) |
not-accessible |
As per the MIB. |
lldpXdot1dcbxAdminApplicationPriorityAEPriority (1.3.111.2.802.1.1.13.1.5.32962.5.1.4.4.1.3) |
read-create |
