- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
29-Q-BRIDGE-MIB | 144.57 KB |
Q-BRIDGE-MIB
About this MIB
Use this MIB to manage Virtual Bridged Local Area Networks, as defined by IEEE 802.1Q-2003.
MIB file name
rfc4363-qbridge.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).dot1dBridge(17).qBridgeMIB(7)
Scalar objects
dot1qVlanNumDeletes
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanNumDeletes (1.3.6.1.2.1.17.7.1.4.1) |
read-only |
Counter32 |
Standard MIB values. |
The number of times a VLAN entry has been deleted from the dot1qVlanCurrentTable (for any reason).
Not supported |
dot1qNextFreeLocalVlanIndex
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qNextFreeLocalVlanIndex (1.3.6.1.2.1.17.7.1.4.4) |
read-only |
Integer32 |
Integer32 (0|4096..2147483647) |
The next available value for dot1qVlanIndex of a local VLAN entry in dot1qVlanStaticTable. |
Not supported |
dot1qConstraintSetDefault
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qConstraintSetDefault (1.3.6.1.2.1.17.7.1.4.9) |
read-write |
Integer32 |
Integer32 (0..65535) |
The identity of the constraint set to which a VLAN belongs, if there is not an explicit entry for that VLAN in dot1qLearningConstraintsTable. |
Not supported |
dot1qConstraintTypeDefault
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qConstraintTypeDefault (1.3.6.1.2.1.17.7.1.4.10) |
read-write |
INTEGER |
independent(1) shared(2) |
The type of constraint set to which a VLAN belongs. |
Supports only the read operation. |
dot1qVlanVersionNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanVersionNumber (1.3.6.1.2.1.17.7.1.1.1) |
read-only |
INTEGER |
version1(1) |
The version number of IEEE 802.1Q that this device supports. |
As per the MIB. |
dot1qMaxVlanId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qMaxVlanId (1.3.6.1.2.1.17.7.1.1.2) |
read-only |
VlanId |
The maximum IEEE 802.1Q VLAN ID that this device supports. |
As per the MIB. |
dot1qMaxSupportedVlans
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qMaxSupportedVlans (1.3.6.1.2.1.17.7.1.1.3) |
read-only |
Unsigned32 |
The maximum number of IEEE 802.1Q VLANs that this device supports. |
As per the MIB. |
dot1qNumVlans
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qNumVlans (1.3.6.1.2.1.17.7.1.1.4) |
read-only |
Unsigned32 |
The current number of IEEE 802.1Q VLANs that are configured in this device. |
As per the MIB. |
dot1qGvrpStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qGvrpStatus (1.3.6.1.2.1.17.7.1.1.5) |
read-write |
EnabledStatus |
enabled(1) disabled(2) |
The administrative status requested by management for GVRP: · enable(1)—GVRP should be enabled on this device, on all ports for which it has not been specifically disabled. · disable(2)—GVRP is disabled on all ports. |
Not supported |
Tabular objects
dot1qFdbTable
About this table
Use this table to display configuration and control information for each filtering database currently operating on this device.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is dot1qFdbId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qFdbId (1.3.6.1.2.1.17.7.1.2.1.1.1) |
not-accessible |
Unsigned32 |
The identity of this filtering database. |
As per the MIB. |
dot1qFdbDynamicCount (1.3.6.1.2.1.17.7.1.2.1.1.2) |
read-only |
Counter32 |
The current number of dynamic entries in this filtering database. |
As per the MIB. |
dot1qTpFdbTable
About this table
Use this table to display information about unicast entries for which the device has forwarding and/or filtering information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qFdbId and dot1qTpFdbAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpFdbAddress (1.3.6.1.2.1.17.7.1.2.2.1.1) |
not-accessible |
MacAddress |
A unicast MAC address for which the device has forwarding and/or filtering information. |
As per the MIB. |
dot1qTpFdbPort (1.3.6.1.2.1.17.7.1.2.2.1.2) |
read-only |
Integer32 |
The port number of the port on which a frame having a source address equal to the value of the corresponding instance of dot1qTpFdbAddress has been seen. A value of 0 indicates that the port number has not been learned but that the device does have some forwarding/filtering information about this address. |
As per the MIB. |
dot1qTpFdbStatus (1.3.6.1.2.1.17.7.1.2.2.1.3) |
read-only |
INTEGER |
other(1) invalid(2) learned(3) self(4) mgmt(5) |
The status of this entry. |
Manually added dynamic MAC address entries are counted as learned MAC address entries. |
dot1qTpGroupTable
About this table
Use this table to obtain filtering information for VLANs configured into the bridge by (local or network) management, or learned dynamically.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qVlanIndex and dot1qTpGroupAddress.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpGroupAddress (1.3.6.1.2.1.17.7.1.2.3.1.1) |
not-accessible |
MacAddress |
The destination group MAC address in a frame to which this entry's filtering information applies. |
As per the MIB. |
dot1qTpGroupEgressPorts (1.3.6.1.2.1.17.7.1.2.3.1.2) |
read-only |
PortList |
The complete set of ports, in this VLAN, to which frames destined for this Group MAC address are currently being explicitly forwarded. |
As per the MIB. |
dot1qTpGroupLearnt (1.3.6.1.2.1.17.7.1.2.3.1.3) |
read-only |
PortList |
The subset of ports in dot1qTpGroupEgressPorts that were learned by GMRP or some other dynamic mechanism, in this filtering database. |
As per the MIB. |
dot1qForwardAllTable
About this table
Use this table to obtain forwarding information for each VLAN, specifying the set of ports to which forwarding of all multicasts applies.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table index is dot1qVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qForwardAllPorts (1.3.6.1.2.1.17.7.1.2.4.1.1) |
read-only |
PortList |
The complete set of ports in this VLAN to which all multicast group-addressed frames are to be forwarded. This includes ports for which this need has been determined dynamically by GMRP, or configured statically by management. |
Not supported |
dot1qForwardAllStaticPorts (1.3.6.1.2.1.17.7.1.2.4.1.2) |
read-write |
PortList |
The set of ports configured by management in this VLAN to which all multicast group-addressed frames are to be forwarded. |
Not supported |
dot1qForwardAllForbiddenPorts (1.3.6.1.2.1.17.7.1.2.4.1.3) |
read-write |
PortList |
The set of ports configured by management in this VLAN for which the Service Requirement attribute Forward All Multicast Groups may not be dynamically registered by GMRP. |
Not supported |
dot1qForwardUnregisteredTable
About this table
Use this table to obtain forwarding information for each VLAN, specifying the set of ports to which forwarding of multicast group-addressed frames for which no more specific forwarding information applies.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qForwardUnregisteredPorts (1.3.6.1.2.1.17.7.1.2.5.1.1) |
read-only |
PortList |
The complete set of ports in this VLAN to which multicast group-addressed frames for which there is no more specific forwarding information will be forwarded. This includes ports for which this need has been determined dynamically by GMRP, or configured statically by management. |
Not supported |
dot1qForwardUnregisteredStaticPorts (1.3.6.1.2.1.17.7.1.2.5.1.2) |
read-write |
PortList |
The set of ports configured by management, in this VLAN, to which multicast group-addressed frames for which there is no more specific forwarding information. |
Not supported |
dot1qForwardUnregisteredForbiddenPorts (1.3.6.1.2.1.17.7.1.2.5.1.3) |
read-write |
PortList |
The set of ports configured by management in this VLAN for which the Service Requirement attribute Forward Unregistered Multicast Groups may not be dynamically registered by GMRP. |
Not supported |
dot1qStaticUnicastTable
About this table
Use this table to obtain filtering information for unicast MAC addresses for each filtering database.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1qFdbId, dot1qStaticUnicastAddress, and dot1qStaticUnicastReceivePort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qStaticUnicastAddress (1.3.6.1.2.1.17.7.1.3.1.1.1) |
not-accessible |
MacAddress |
The destination MAC address in a frame to which this entry's filtering information applies. |
Not supported |
dot1qStaticUnicastReceivePort (1.3.6.1.2.1.17.7.1.3.1.1.2) |
not-accessible |
Integer32 |
The port number of the port from which a frame must be received in order for this entry's filtering information to apply. A value of 0 indicates that this entry applies on all ports of the device for which there is no other applicable entry. |
Not supported |
dot1qStaticUnicastAllowedToGoTo (1.3.6.1.2.1.17.7.1.3.1.1.3) |
read-write |
PortList |
The set of ports for which a frame with a specific unicast address will be flooded in the event that it has not been learned. |
Not supported |
dot1qStaticUnicastStatus (1.3.6.1.2.1.17.7.1.3.1.1.4) |
read-write |
INTEGER |
other(1) invalid(2) permanent(3) deleteOnReset(4) deleteOnTimeout(5) |
Status of this entry. |
Not supported |
dot1qStaticMulticastTable
About this table
Use this table to obtain filtering information for multicast and broadcast MAC addresses for each VLAN.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1qVlanIndex, dot1qStaticMulticastAddress, and dot1qStaticMulticastReceivePort.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qStaticMulticastAddress (1.3.6.1.2.1.17.7.1.3.2.1.1) |
not-accessible |
MacAddress |
Not supported |
dot1qStaticMulticastReceivePort (1.3.6.1.2.1.17.7.1.3.2.1.2) |
not-accessible |
Integer32 |
Not supported |
dot1qStaticMulticastStaticEgressPorts (1.3.6.1.2.1.17.7.1.3.2.1.3) |
read-write |
PortList |
The set of ports to which frames received from a specific port and destined for a specific multicast or broadcast MAC address must be forwarded. |
Not supported |
dot1qStaticMulticastForbiddenEgressPorts (1.3.6.1.2.1.17.7.1.3.2.1.4) |
read-write |
PortList |
The set of ports to which frames received from a specific port and destined for a specific multicast or broadcast MAC address must not be forwarded. |
Not supported |
dot1qStaticMulticastStatus (1.3.6.1.2.1.17.7.1.3.2.1.5) |
read-write |
INTEGER |
Not supported |
About this table
Use this table to obtain current configuration information for each VLAN currently configured into the device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are dot1qVlanTimeMark and dot1qVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanTimeMark (1.3.6.1.2.1.17.7.1.4.2.1.1) |
not-accessible |
TimeFilter |
A time filter for this entry. |
As per the MIB. |
dot1qVlanIndex (1.3.6.1.2.1.17.7.1.4.2.1.2) |
not-accessible |
VlanIndex |
The VLAN-ID or other identifier referring to this VLAN. |
As per the MIB. |
dot1qVlanFdbId (1.3.6.1.2.1.17.7.1.4.2.1.3) |
read-only |
Unsigned32 |
The filtering database used by this VLAN. |
As per the MIB. |
dot1qVlanCurrentEgressPorts (1.3.6.1.2.1.17.7.1.4.2.1.4) |
read-only |
PortList |
The set of ports that are transmitting traffic for this VLAN as either tagged or untagged frames. |
As per the MIB. |
dot1qVlanCurrentUntaggedPorts (1.3.6.1.2.1.17.7.1.4.2.1.5) |
read-only |
PortList |
The set of ports that are transmitting traffic for this VLAN as untagged frames. |
As per the MIB. |
dot1qVlanStatus (1.3.6.1.2.1.17.7.1.4.2.1.6) |
read-only |
INTEGER |
other(1) permanent(2) dynamicGvrp(3) |
Status of this VLAN. |
As per the MIB. |
dot1qVlanCreationTime (1.3.6.1.2.1.17.7.1.4.2.1.7) |
read-only |
TimeTicks |
Time when this VLAN was created. |
As per the MIB. |
About this table
Use this table to obtain static configuration information for each VLAN configured into the device.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Not supported |
Not supported |
Supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qVlanStaticName (1.3.6.1.2.1.17.7.1.4.3.1.1) |
read-create |
SnmpAdminString |
OCTET STRING (0..32) |
VLAN name. |
If the name string is too long or empty, a default name in the vlan VLAN ID format applies. |
dot1qVlanStaticEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.2) |
read-create |
PortList |
The set of ports that are permanently assigned to the egress list for this VLAN by management. |
As per the MIB. |
dot1qVlanForbiddenEgressPorts (1.3.6.1.2.1.17.7.1.4.3.1.3) |
read-create |
PortList |
The set of ports that are prohibited by management from being included in the egress list for this VLAN. |
Not supported |
dot1qVlanStaticUntaggedPorts (1.3.6.1.2.1.17.7.1.4.3.1.4) |
read-create |
PortList |
The set of ports that should transmit egress packets for this VLAN as untagged. |
As per the MIB. |
dot1qVlanStaticRowStatus (1.3.6.1.2.1.17.7.1.4.3.1.5) |
read-create |
RowStatus |
Supports only active(1), createAndgo(4) and destroy(6). You cannot delete the default VLAN. |
dot1qPortVlanTable
About this table
Use this table to obtain per-port control and status information for VLAN configuration in the device.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is ifIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qPvid (1.3.6.1.2.1.17.7.1.4.5.1.1) |
read-write |
VlanIndex |
The PVID, the VLAN ID assigned to untagged frames received on this port. |
Does not support the write operation on an access port. |
dot1qPortAcceptableFrameTypes (1.3.6.1.2.1.17.7.1.4.5.1.2) |
read-write |
INTEGER |
admitAll(1) admitOnlyVlanTagged(2) |
Packet types that this port can receive: · admitOnlyVlanTagged(2)—Drop untagged packets. · admitAll(1)—Accept untagged packets and assign them the PVID. |
dot1qPortIngressFiltering (1.3.6.1.2.1.17.7.1.4.5.1.3) |
read-write |
TruthValue |
true(1), false(2) |
When this is true(1), the device will discard incoming frames for VLANs that do not include this port in its member set. When false(2), the port will accept all incoming frames. |
dot1qPortGvrpStatus (1.3.6.1.2.1.17.7.1.4.5.1.4) |
read-write |
EnabledStatus |
enabled(1), disabled(2) |
The state of GVRP operation on this port: · enabled(1)—GVRP is enabled. · disabled(2)—GVRP is disabled. This port drops any incoming GVRP frames. |
Not supported |
dot1qPortGvrpFailedRegistrations (1.3.6.1.2.1.17.7.1.4.5.1.5) |
read-only |
Counter32 |
The total number of failed GVRP registrations, for any reason, on this port. |
Not supported |
dot1qPortGvrpLastPduOrigin (1.3.6.1.2.1.17.7.1.4.5.1.6) |
read-only |
MacAddress |
The source MAC address of the last GVRP message received on this port. |
Not supported |
dot1qPortRestrictedVlanRegistration (1.3.6.1.2.1.17.7.1.4.5.1.7) |
read-write |
TruthValue |
true(1), false(2) |
The state of restricted vlan registration on this port. If the value of this object is true(1), then creation of a new dynamic VLAN entry is permitted only if there is a static vlan registration entry for the VLAN concerned, in which the registrar administrative control value for this port is normal registration. |
Not supported |
dot1qPortVlanStatisticsTable
About this table
Use this table to obtain per-port, per-VLAN statistics for traffic received. Separate objects are provided for both the most-significant and least-significant bits of statistics counters for ports that are associated with this transparent bridge. The most-significant bit objects are only required on high-capacity interfaces, as defined in the conformance clauses for these objects. This mechanism is provided as a way to read 64-bit counters for agents that support only SNMPv1.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1dBasePort and dot1qVlanIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpVlanPortInFrames (1.3.6.1.2.1.17.7.1.4.6.1.1) |
read-only |
Counter32 |
The number of valid frames received by this port from its segment that were classified as belonging to this VLAN. |
Not supported |
dot1qTpVlanPortOutFrames (1.3.6.1.2.1.17.7.1.4.6.1.2) |
read-only |
Counter32 |
The number of valid frames transmitted by this port to its segment from the local forwarding process for this VLAN. |
Not supported |
dot1qTpVlanPortInDiscards (1.3.6.1.2.1.17.7.1.4.6.1.3) |
read-only |
Counter32 |
The number of valid frames received by this port from its segment that were classified as belonging to this VLAN and that were discarded due to VLAN-related reasons. |
Not supported |
dot1qTpVlanPortInOverflowFrames (1.3.6.1.2.1.17.7.1.4.6.1.4) |
read-only |
Counter32 |
The number of times the associated dot1qTpVlanPortInFrames counter has overflowed. |
Not supported |
dot1qTpVlanPortOutOverflowFrames (1.3.6.1.2.1.17.7.1.4.6.1.5) |
read-only |
Counter32 |
The number of times the associated dot1qTpVlanPortOutFrames counter has overflowed. |
Not supported |
dot1qTpVlanPortInOverflowDiscards (1.3.6.1.2.1.17.7.1.4.6.1.6) |
read-only |
Counter32 |
The number of times the associated dot1qTpVlanPortInDiscards counter has overflowed. |
Not supported |
dot1qPortVlanHCStatisticsTable
About this table
Use this table to obtain per-port, per-VLAN statistics for traffic on high-capacity interfaces.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qTpVlanPortHCInFrames (1.3.6.1.2.1.17.7.1.4.7.1.1) |
read-only |
Counter64 |
Not supported |
dot1qTpVlanPortHCOutFrames (1.3.6.1.2.1.17.7.1.4.7.1.2) |
read-only |
Counter64 |
Not supported |
dot1qTpVlanPortHCInDiscards (1.3.6.1.2.1.17.7.1.4.7.1.3) |
read-only |
Counter64 |
Not supported |
About this table
Use this table to obtain learning constraints for sets of shared and independent VLANs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1qConstraintVlan and dot1qConstraintSet.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1qConstraintVlan (1.3.6.1.2.1.17.7.1.4.8.1.1) |
not-accessible |
VlanIndex |
The index of the row in this table for the VLAN constrained by this entry. |
Not supported |
dot1qConstraintSet (1.3.6.1.2.1.17.7.1.4.8.1.2) |
not-accessible |
Integer32 |
The identity of the constraint set to which dot1qConstraintVlan belongs. |
Not supported |
dot1qConstraintType (1.3.6.1.2.1.17.7.1.4.8.1.3) |
read-create |
INTEGER |
independent(1), shared(2) |
The type of constraint this entry defines: · independent(1)—The VLAN uses a filtering database independent from all other VLANs in the same set. · shared(2)—The VLAN shares the same filtering database as all other VLANs in the same set. |
Not supported |
dot1qConstraintStatus (1.3.6.1.2.1.17.7.1.4.8.1.4) |
read-create |
RowStatus |
Status of this row. |
Not supported |
dot1vProtocolGroupTable
About this table
Use this table to obtain mappings from protocol templates to protocol group identifiers used for port-and-protocol-based VLAN classification.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1vProtocolTemplateFrameType and dot1vProtocolTemplateProtocolValue.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1vProtocolTemplateFrameType (1.3.6.1.2.1.17.7.1.5.1.1.1) |
not-accessible |
INTEGER |
ethernet(1) rfc1042(2) snap8021H(3) snapOther(4) llcOther(5) |
Data-link encapsulation format. |
Not supported |
dot1vProtocolTemplateProtocolValue (1.3.6.1.2.1.17.7.1.5.1.1.2) |
not-accessible |
OCTET STRING |
OCTET STRING SIZE (2 | 5) |
The identification of the protocol above the data-link layer in a protocol template. |
Not supported |
dot1vProtocolGroupId (1.3.6.1.2.1.17.7.1.5.1.1.3) |
read-create |
Integer32 |
Integer32 (0..2147483647) |
A group of protocols that are associated together when assigning a VID to a frame. |
Not supported |
dot1vProtocolGroupRowStatus (1.3.6.1.2.1.17.7.1.5.1.1.4) |
read-create |
RowStatus |
Not supported |
dot1vProtocolPortTable
About this table
Use this table to obtain VID sets used for port-and-protocol-based VLAN classification.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Not supported |
Columns
The table indexes are dot1dBasePort and dot1vProtocolPortGroupId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
dot1vProtocolPortGroupId (1.3.6.1.2.1.17.7.1.5.2.1.1) |
not-accessible |
Integer32 |
Integer32 (1..2147483647) |
A group of protocols in the protocol group database. |
Not supported |
dot1vProtocolPortGroupVid (1.3.6.1.2.1.17.7.1.5.2.1.2) |
read-create |
Integer32 |
Integer32 (1..4094) |
The VID associated with a group of protocols for each port. |
Not supported |
dot1vProtocolPortRowStatus (1.3.6.1.2.1.17.7.1.5.2.1.3) |
read-create |
RowStatus |
Not supported |
