- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB | 54.59 KB |
About this MIB
Use this MIB to obtain information about EVB TLV configuration.
MIB file name
lldp-ext-dot1-evb-extensions.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbers-series-standards(2).lan-man-stds(802).ieee802dot1mibs(1).lldpV2MIB(13).lldpV2Objects(1).lldpV2Extensions(5).lldpV2Xdot1MIB(32962).lldpXdot1StandAloneExtensions(7).lldpXDot1EvbExtensions(1)
This MIB is LLDP Management Information Base extension module for IEEE 802.1 organizationally defined discovery information for the EVB extension objects.
Tabular objects
lldpXdot1EvbConfigEvbTable
About this table
This table configures the transmission of EVB TLVs on a set of ports.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2PortConfigIfIndex and lldpV2PortConfigDestAddressIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1EvbConfigEvbTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.1.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable EVB TLV transmission. |
As per the MIB. |
lldpXdot1EvbConfigCdcpTable
About this table
This table configures the transmission of CDCP TLVs on a set of ports.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpXdot1EvbConfigCdcpTxEnable(1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.1.2.1.1) |
read-write |
TruthValue |
true(1), false(2) |
Selects whether to enable CDCP TLV transmission. |
As per the MIB. |
lldpV2Xdot1LocEvbTlvTable
About this table
This table contains information about local EVB TLVs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is lldpV2LocPortIfIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.1.1.1) |
read-only |
OCTET STRING |
OCTET STRING (0..514) |
Local EVB TLV information. |
As per the MIB. |
lldpV2Xdot1LocCdcpTlvTable
About this table
This table contains information about local CDCP TLVs.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index islldpV2LocPortIfIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1LocCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.2.2.1.1) |
read-only |
OCTET STRING |
Local CDCP TLV information. |
As per the MIB. |
lldpV2Xdot1RemEvbTlvTable
About this table
This table contains information about EVB TLVs received from the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are lldpV2RemTimeMark, lldpV2RemLocalIfIndex, lldpV2RemLocalDestMACAddress, and lldpV2RemIndex.
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemEvbTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.1.1.1) |
read-only |
OCTET STRING |
Information about EVB TLVs from neighboring devices. |
As per the MIB. |
lldpV2Xdot1RemCdcpTlvTable
About this table
This table contains information about CDCP TLVs received from the neighboring devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The OID of the table is 1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
lldpV2Xdot1RemCdcpTlvString (1.3.111.2.802.1.1.13.1.5.32962.7.1.1.1.3.2.1.1) |
read-only |
OCTET STRING |
Information about CDCP TLVs from neighboring devices. |
As per the MIB. |
