- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
03-HH3C-LAG-MIB | 124.51 KB |
hh3cAggResourceAllocationValue
hh3cAggPortInactiveNotification
hh3cAggPortInactiveNotification2
hh3cAggMemberCoutExceedThreshold
hh3cAggMemberCoutExceedRecovery
HH3C-LAG-MIB
About this MIB
This MIB contains information in ieee8023-lag.mib and hh3c-lag.mib.
MIB file name
hh3c-lag.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3cLAG(25)
Scalar objects
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAggResourceAllocationValue (1.3.6.1.4.1.25506.8.25.1.3) |
read-only |
OCTET STRING (1) |
Whether link aggregation is implemented by Huawei or H3C. |
As per the MIB. |
Tabular objects
hh3cAggLinkTable
About this table
This table contains aggregation group information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cAggLinkNumber.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAggLinkNumber (1.3.6.1.4.1.25506.8.25.1.1.1.1) |
not-accessible |
Integer32 |
Standard MIB values. |
Aggregation group ID. |
As per the MIB. |
hh3cAggLinkName (1.3.6.1.4.1.25506.8.25.1.1.1.2) |
read-create |
DisplayString |
SIZE (0..32) |
Aggregation group name. |
Not supported |
hh3cAggLinkMode (1.3.6.1.4.1.25506.8.25.1.1.1.3) |
read-create |
INTEGER |
manual(1) static(2) dynamic(3) |
Aggregation mode. |
Supports only 2 and 3. |
hh3cAggLinkPortList (1.3.6.1.4.1.25506.8.25.1.1.1.4) |
read-create |
PortList |
OCTET STRING (0..255) |
Aggregation member ports. |
As per the MIB. |
hh3cAggLinkState (1.3.6.1.4.1.25506.8.25.1.1.1.5) |
read-create |
RowStatus |
Row status. |
Supports only active(1), createAndGo(4), and destroy(6). |
hh3cAggPortListSelectedPorts (1.3.6.1.4.1.25506.8.25.1.1.1.6) |
read-only |
PortList |
Selected member ports. |
As per the MIB. |
hh3cAggPortListSamePartnerPorts (1.3.6.1.4.1.25506.8.25.1.1.1.7) |
read-only |
PortList |
Member ports attached to the same peer. |
As per the MIB. |
Example:
hh3cAggLinkPortList.1 (PortList) 00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.34 (hex)
Hexadecimal string 00 indicates that no ports are included in an octet. The last octet is 34 in hexadecimal format and 00110100 in binary format. Therefore, the following ports are included in the list:
Port 307 (38 × 8 + 3 = 307, where 38 is the number of times that hexadecimal string 00 appears.)
Port 308 (38 × 8 + 4 = 308)
Port 310 (38 × 8 + 6 = 310)
To view the member ports of an aggregate interface:
1. Check the hh3cAggLinkPortList object in the hh3cAggLinkTable table to obtain the member port list.
¡ For a Layer 2 aggregate interface, this object is suffixed with the aggregate interface ID. For example, hh3cAggLinkPortList.3 lists the member ports of Bridge-Aggregation 3.
¡ For a Layer 3 aggregate interface, this object is suffixed with the sum of the aggregate interface ID and 16384. For example, hh3cAggLinkPortList.16387 lists the member ports of Route-Aggregation 3.
2. Calculate the logical ID of each member port based on the value of the hh3cAggLinkPortList object.
3. Check the dot1dBasePortIfIndex object in the dot1dBasePortTable table for the ifindex value mapped to the logical ID of each member port.
4. Check the ifXTable table for the interface name mapped to each ifindex value.
Example:
The value of the hh3cAggLinkTable object is as follows:
11:hh3cAggLinkPortList.16387(PortList)00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.80.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.00.40 (hex)
The following member ports are included in the list:
Port 409 (51 × 8 + 1= 409, where 51 is the number of times that hexadecimal string 00 appears.)
Port 2690 (336 × 8 + 2= 2690)
The value of the dot1dBasePortIfIndex object is as follows:
127:dot1dBasePortIfIndex.409(INTEGER) 385
234:dot1dBasePortIfIndex.2690 (INTEGER) 2690
The ifindex value of port 409 is 385, and the ifindex value of port 2690 is 2690.
The value of the ifXTable table is as follows:
177:ifName.9173 (DisplayString) Route-Aggregation3[52.6F.75.74.65.2D.41.67.67.72.65.67.61.74.69.6F.6E.33 (hex)]
5:ifName.385(DisplayString) GigabitEthernet1/4/2/1[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.34.2F.32.2F.31 (hex)]
112:ifName.2690(DisplayString) GigabitEthernet2/5/1/2[47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.32.2F.35.2F.31.2F.32 (hex)]
Therefore, the interface name is GigabitEthernet 1/4/2/1 for port 409 and GigabitEthernet 2/5/1/2 for port 2690.
On the device, the ports are as follows:
[H3C]dislink-aggregation verbose Route-Aggregation 3
AggregateInterface: Route-Aggregation3
AggregationMode: Static
LoadsharingType: Shar
Port Status Priority Oper-Key
GE1/4/2/1 S 32768 2
GE2/5/1/2 S 32768 2
[H3C]
hh3cAggPortTable
About this table
This table contains aggregation member port information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cAggPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cAggPortIndex (1.3.6.1.4.1.25506.8.25.1.2.1.1) |
not-accessible |
Gauge32 |
Member port index. |
As per the MIB. |
hh3cAggPortNotAttachedReason (1.3.6.1.4.1.25506.8.25.1.2.1.2) |
read-write |
Integer32 |
0..10 |
Why the port is unselected. |
Read-only. |
hh3cAggPortLacpState (1.3.6.1.4.1.25506.8.25.1.2.1.3) |
read-write |
TruthValue |
true(1) false(2) |
Status of LACP. |
Read-only. |
hh3cAggPortNotAttachedString (1.3.6.1.4.1.25506.8.25.1.2.1.4) |
read-write |
DisplayString |
SIZE (0..255) |
Detailed cause for the unselected state of the member port. |
Read-only. |
Notifications
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.8.25.2.2 |
An aggregation member port becomes unselected. |
Informational |
Warning |
ON |
This notification is generated when an aggregation member port becomes unselected.
Status control
This notification cannot be disabled.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.25.1.1.1.1 (hh3cAggLinkNumber) |
Yes |
Integer32 |
1..40960 |
Recommended action
1. Verify that the aggregation member port is physically up.
2. Verify that the attribute configuration of the aggregation member port is the same as that of the aggregate interface.
3. Repeat step 1 and step 2 on the peer port if the aggregate interface operates in dynamic mode.
4. If the issue persists, contact H3C Support.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.2.2.3 |
Informational |
Warning |
ON |
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..40960 |
1.3.6.1.4.1.25506.8.25.1.2.1.1 (hh3cAggPortIndex) |
Aggregation member port index. |
No |
Integer32 |
As per the MIB. |
Recommended action
hh3cAggPortActiveNotification
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.2.2.4 |
An aggregation member port becomes selected. |
Informational |
ON |
This notification is generated when an aggregation member port becomes selected.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Yes |
Integer32 |
1..40960 |
No |
Integer32 |
As per the MIB. |
Recommended action
No action is required.
hh3cAggAllMemberDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.7 |
All member ports in an aggregation group go down. |
Informational |
Alarm |
1.3.6.1.4.1.25506.8.25.0.8 (hh3cAggAllMemberDownRecovery) |
ON |
This notification is generated when all member ports in an aggregation group go down.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.8.25.4.1 (hh3cAggPortName) |
Aggregate interface name. |
No |
OCTET_STRING |
OCTET_STRING (0..255) |
Recommended action
Check the link status of aggregation member ports.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.8 |
An aggregation group has the first up member port. |
Informational |
Alarm |
ON |
This notification is generated when an aggregation group has the first up member port.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
Recommended action
hh3cAggAllMemberUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.9 |
All member ports in an aggregation group come up. |
Informational |
Alarm |
ON |
This notification is generated when all member ports in an aggregation group come up.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
Recommended action
hh3cAggMemberLinkDown
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.10 |
A member port goes down in an aggregation group. |
Informational |
Alarm |
1.3.6.1.4.1.25506.8.25.0.11 (hh3cAggMemberLinkUp) |
ON |
This notification is generated when a member port goes down in an aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
1.3.6.1.4.1.25506.8.25.4.2 (hh3cAggMemberPortName) |
Aggregation member port name. |
No |
OCTET_STRING |
Recommended action
hh3cAggMemberLinkUp
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.11 |
A member port comes up in an aggregation group. |
Informational |
Alarm |
ON |
This notification is generated when a member port comes up in an aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.12 |
The maximum number of selected ports is exceeded in an aggregation group. |
Informational |
Alarm |
1.3.6.1.4.1.25506.8.25.0.13 (hh3cAggMemberCoutExceedRecovery) |
ON |
This notification is generated when the maximum number of selected ports is exceeded in an aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
1.3.6.1.4.1.25506.8.25.4.7 (hh3cAggUpThreshold) |
Maximum number of selected ports. |
No |
Integer32 |
Integer32 (1..2147483647) |
Recommended action
Check the configured maximum number of selected ports.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.13 |
The number of selected ports in an aggregation group drops below the maximum number of selected ports. |
Informational |
ON |
This notification is generated when the number of selected ports in an aggregation group drops below the maximum number of selected ports.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
Integer32 |
Recommended action
hh3cAggMemberNumberChanged
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.14 |
The number of selected ports changes in an aggregation group. |
Informational |
Alarm |
ON |
This notification is generated when the number of selected ports changes in an aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
1.3.6.1.4.1.25506.8.25.4.6 (hh3cAggTotalActiveNum) |
Number of selected ports. |
No |
Integer32 |
1.3.6.1.4.1.25506.8.25.4.8 (hh3cAggReasonCode) |
Cause of change. |
No |
OCTET_STRING |
Recommended action
hh3cAggLacpPartnerExpired
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.15 |
The LACP timeout timer expires for the peer of an aggregation member port. |
Informational |
Alarm |
ON |
This notification is generated when the LACP timeout timer expires for the peer of an aggregation member port.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
No |
Integer32 |
1..40960 |
Recommended action
hh3cAggPortLacpInactive
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.16 |
An aggregation member port cannot be selected after receiving an LACPDU. |
Informational |
Alarm |
ON |
This notification is generated when an aggregation member port receives a PDU that prevents it from being selected.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
No |
Integer32 |
Interger32 (1..40960) |
1.3.6.1.4.1.25506.8.25.4.3 (hh3cAggOldPduInfo) |
Old PDU information. |
No |
OCTET_STRING |
OCTET_STRING (0..512) |
1.3.6.1.4.1.25506.8.25.4.4 (hh3cAggNewPduInfo) |
New PDU information. |
No |
OCTET_STRING |
1.3.6.1.4.1.25506.8.25.4.5 (hh3cAggPduChangeCode) |
Changed PDU information. |
No |
OCTET_STRING |
Recommended action
hh3cAggPortLacpNegotiateFailed
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.17 |
Negotiation fails on a member port in a dynamic aggregation group. |
Informational |
Alarm |
1.3.6.1.4.1.25506.8.25.0.17 (hh3cAggPortLacpNegotiateRecovery) |
ON |
This notification is generated when negotiation fails on a member port in a dynamic aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
No |
Integer32 |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.8.25.0.18 |
Negotiation succeeds on a member port in a dynamic aggregation group. |
Informational |
Alarm |
ON |
This notification is generated when negotiation succeeds on a member port in a dynamic aggregation group.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
No |
OCTET_STRING |
No |
OCTET_STRING |
No |
Integer32 |
Recommended action
