- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
05-HH3C-LPBKDT-MIB | 78.03 KB |
HH3C-LPBKDT-MIB
About this MIB
The loop detection mechanism performs periodic checking for Layer 2 loops and processes the interfaces with loops as configured.
Use this MIB to perform the following tasks:
· Generate traps when the loop state of an interface changes.
· Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs globally.
· Configure and view the loop detection state, loop protection action, and loop detection interval for VLANs on an interface.
MIB file name
hh3c-lpbkdt.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).h3cCommon(2).hh3cDldp2Lpbkdt(95)
Scalar objects
OID of this table is: 1.3.6.1.4.1.25506.2.95.2
hh3cLpbkdtVlanID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLpbkdtVlanID (1.3.6.1.4.1.25506.2.95.2.1) |
accessible-for-notify |
INTEGER |
1..4094 |
VLAN ID in reported trap messages when a loop is detected or eliminated on an interface. |
As per the MIB. |
hh3cLpbkdtVlanEnable
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLpbkdtVlanEnable (1.3.6.1.4.1.25506.2.95.2.2) |
read-write |
OCTETSTRING |
SIZE(1..512) |
Enable or disable loop detection for VLANs globally. |
As per the MIB. |
hh3cLpbkdtAction
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLpbkdtAction (1.3.6.1.4.1.25506.2.95.2.3) |
read-write |
INTEGER |
none (1), block(2), nolearning(3), shutdown(4) |
Configure the global loop protection action, which is to take on all ports where loops are detected. |
In the current software version, only the log and shutdown operations are supported, and the block and nolearning actions are not supported. |
hh3cLpbkdtAction
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLpbkdtIntervalTime (1.3.6.1.4.1.25506.2.95.2.4) |
read-write |
Integer32 |
1..300 |
Loop detection interval. |
As per the MIB. |
Tabular objects
hh3cLpbkdtPortTable
OID of this table is: 1.3.6.1.4.1.25506.2.95.2.5
About this table
Use this table to configure loop detection on a port.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cLpbkdtPortIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cLpbkdtPortIfIndex (1.3.6.1.4.1.25506.2.95.2.5.1.1) |
not-accessible |
INTEGER |
1..2147483647 |
Interface index. |
As per the MIB. |
hh3cLpbkdtPortVlanEnable (1.3.6.1.4.1.25506.2.95.2.5.1.2) |
read-write |
OCTET STRING |
SIZE(1..512) |
Enable or disable loop detection for VLANs on a port. |
As per the MIB. |
Not related. Please archive it. hh3cLpbkdtPortAction (1.3.6.1.4.1.25506.2.95.2.5.1.3) |
read-write |
INTEGER |
Configure the loop protection action for a port, which is to take on the port when a loop is detected. |
An aggregate interface supports only the log and shutdown actions. The other interfaces support all actions. |
hh3cLpbkdtPortLoopbacked (1.3.6.1.4.1.25506.2.95.2.5.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Check for a loop on a port. |
As per the MIB. |
Notifications
hh3cLpbkdtTrapLoopbacked
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.95.1.0.1 |
A loop occurs on a port |
Error |
Warning |
1.3.6.1.4.1.25506.2.95.1.0.2 (hh3cLpbkdtTrapRecovered) |
ON |
This notification is generated when a port detects the loopback detection packets that the device sends to notify that a loop is generated.
Status control
This notification cannot be turned off.
Objects
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.2.1.2.2.1.1 (ifIndex) |
Interface index |
No |
Integer32 |
Integer32 (1..2147483647) |
1.3.6.1.2.1.2.2.1.2 (ifDescr) |
Interface name |
No |
OCTET STRING |
OCTET STRING (0..255) |
Recommended action
Check for a loop on the network.
Basic information
OID |
Event |
Type |
Severity |
Default status |
A loop is removed from a port |
Informational |
ON |
This notification is generated when a port does not receive loopback packets that the device sends within a period of time to notify that a loop is removed.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
Interface name |
No |
OCTET STRING |
Recommended action
hh3cLpbkdtTrapPerVlanLoopbacked
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.95.1.0.3 |
Error |
Warning |
1.3.6.1.4.1.25506.2.95.1.0.4 (hh3cLpbkdtTrapPerVlanRecovered) |
ON |
This notification is generated when a port detects the loopback detection packets that the device sends in a VLAN to notify that a loop is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
Interface name |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.95.2.1 (hh3cLpbkdtVlanID) |
VLAN in which a loop occurs |
No |
Integer32 |
Integer32 (1..4094) |
Recommended action
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.95.1.0.4 |
Informational |
ON |
This notification is generated when a port does not receive loopback packets that the device sends in a VLAN within a period of time to notify that a loop is removed.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
Interface name |
Yes |
OCTET STRING |
VLAN in which a loop is removed |
No |
Integer32 |
Recommended action
No action is required.
hh3cLpbkdtTrapVsiLoopbacked
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.95.1.0.5 |
A loop occurred on an AC interface |
Error |
Warning |
1.3.6.1.4.1.25506.2.95.1.0.6 (hh3cLpbkdtTrapVsiRecovered) |
ON |
This notification is generated when an AC interface detects the loopback detection packets that the device sends to notify that a loop is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
1.3.6.1.4.1.25506.2.95.1.1.1 (hh3cLpbkdtVsiName) |
VSI name |
No |
OCTET STRING |
1.3.6.1.4.1.25506.2.95.1.1.2 (hh3cLpbkdtSVlanID) |
Outer VLAN ID |
No |
Integer32 |
1.3.6.1.4.1.25506.2.95.1.1.2 (hh3cLpbkdtCVlanID) |
Inner VLAN ID |
No |
Integer32 |
1.3.6.1.4.1.25506.2.95.1.1.4 (hh3cLpbkdtACName) |
AC name |
No |
OCTET STRING |
Recommended action
Check for a loop on a VSI on the network.
Basic information
OID |
Event |
Type |
Severity |
Default status |
1.3.6.1.4.1.25506.2.95.1.0.6 |
A loop is removed from an AC interface |
Informational |
ON |
This notification is generated when an AC interface does not receive the loopback detection packets that the device sends to notify that a loop is generated.
Status control
Objects
OID (object name) |
Index |
Type |
Value range |
Interface index |
No |
Integer32 |
VSI name |
No |
OCTET STRING |
AC name |
No |
OCTET STRING |
Recommended action
