- 06-Layer 2 - LAN Switching
- 01-BRIDGE-MIB
- 02-EtherLike-MIB
- 03-HH3C-LAG-MIB
- 04-HH3C-LLDP-EXT-MIB
- 05-HH3C-LPBKDT-MIB
- 06-HH3C-LswMAM-MIB
- 07-HH3C-LswMSTP-MIB
- 08-HH3C-LswVLAN-MIB
- 09-HH3C-MAC-INFORMATION-MIB
- 10-HH3C-MLAG-MIB
- 11-HH3C-PROTOCOL-VLAN-MIB
- 12-HH3C-QINQV2-MIB
- 13-HH3C-SUBNET-VLAN-MIB
- 14-HH3C-VMAP-MIB
- 15-HH3C-VOICE-VLAN-MIB
- 16-IEEE8021-CFM-MIB
- 17-IEEE8021-CFM-V2-MIB
- 18-IEEE8023-LAG-MIB
- 19-LLDP-EXT-DOT1-EVB-EXTENSIONS-MIB
- 20-LLDP-EXT-DOT1-MIB
- 21-LLDP-EXT-DOT1-V2-MIB
- 22-LLDP-EXT-DOT3-MIB
- 23-LLDP-EXT-DOT3-V2-MIB
- 24-LLDP-EXT-MED-MIB
- 25-LLDP-MIB
- 26-LLDP-V2-MIB
- 27-MAU-MIB
- 28-P-BRIDGE-MIB
- 29-Q-BRIDGE-MIB
- 30-RBRIDGE-MIB
08-HH3C-LswVLAN-MIB | 108.25 KB |
HH3C-LswVLAN-MIB
About this MIB
Use this MIB to configure basic VLAN settings and obtain basic VLAN information.
MIB file name
hh3c-splat-vlan.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cRhw(8).hh3clswCommon(35).hh3cLswVlan(2)
Scalar objects
hh3cVLANMibGarpLeaveAllTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibGarpLeaveAllTime (1.3.6.1.4.1.25506.8.35.2.2.14) |
read-write |
Time-Interval |
Standard MIB values. |
GARP timer, in centiseconds. |
Not supported |
hh3cVLANMibSwitchGMRPRXPkt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchGMRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.1) |
read-only |
COUNTER32 |
Traffic switch. |
Not supported |
hh3cVLANMibSwitchGVRPRXPkt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchGVRPRXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.2) |
read-only |
COUNTER32 |
Traffic switch. |
Not supported |
hh3cVLANMibSwitchGMRPTXPkt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchGMRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.3) |
read-only |
COUNTER32 |
Traffic switch. |
Not supported |
hh3cVLANMibSwitchGVRPTXPkt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchGVRPTXPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.4) |
read-only |
COUNTER32 |
Traffic switch. |
Not supported |
hh3cVLANMibSwitchDiscardedPkt
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchDiscardedPkt (1.3.6.1.4.1.25506.8.35.2.2.15.1.5) |
read-only |
COUNTER32 |
Traffic switch. |
Not supported |
hh3cVLANMibSwitchGarpStatClear
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibSwitchGarpStatClear (1.3.6.1.4.1.25506.8.35.2.2.15.1.6) |
read-write |
INTEGER |
Traffic switch. |
Not supported |
hh3cVLANMibHoldTime
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVLANMibHoldTime (1.3.6.1.4.1.25506.8.35.2.2.16.1.1) |
read-write |
INTEGER |
INTEGER (10..32765) |
Interface holdtime. |
Not supported |
Tabular objects
hh3cdot1qVlanMIBTable
About this table
Use this table to manage and monitor VLANs, create and delete VLANs, and configure and obtain the proprietary VLAN data.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cdot1qVlanIndex, which specifies a VLAN ID. Use this table to create and delete VLANs, configure VLAN attributes, and obtain VLAN data.
The leaf objects in the table include configuration objects and query objects. The configuration objects can be written and read, and the query objects can only be read.
The following objects are configuration objects, and the other objects are query objects:
· hh3cdot1qVlanName
· hh3cdot1qVlanPorts
· hh3cdot1qVlanType
· hh3cdot1qVlanPriority
· hh3cdot1qVlanRowStatus
· hh3cdot1qVlanBroadcastSuppression
· hh3cdot1qVlanBcastSuppressionPPS
· hh3cdot1qVlanMulticast (not supported)
· hh3cdot1qVlanStatisticStatus
· hh3cdot1qVlanStatisticClear
hh3cdot1qVlanMIBTable configuration guidelines:
This table supports creating a row, namely, creating a VLAN. When creating a row, as a best practice, first traverse through the table, and use a VLAN ID that does not exist in the table. Available values are active(1), createAndGo(4), and destroy(6). This table involves the following two types of operation:
· hh3cdot1qVlanRowStatus (createAndGo(4)): Create a VLAN and configure the following attribute objects:
¡ hh3cdot1qVlanName
¡ hh3cdot1qVlanPorts
¡ hh3cdot1qVlanType
¡ hh3cdot1qVlanPriority
¡ hh3cdot1qVlanBroadcastSuppression
¡ hh3cdot1qVlanBcastSuppressionPPS
¡ hh3cdot1qVlanMulticast (Not support)
First check the input string for hh3cdot1qVlanName. Continue to create the VLAN after the check passes. After the VLAN is successfully created, configure the leaf objects listed above. The operation will fail if the configuration of any leaf object has errors. For example:
¡ hh3cdot1qVlanPorts: This object can only add an access port to or remove an access port from a VLAN. If a configured port is not an access port, the configuration for this object fails.
¡ hh3cdot1qVlanType: The MIB does not support sub-vlan(3). When the hh3cdot1qVlanRowStatus(createAndGo(4)) and hh3cdot1qVlanType(sub-vlan(3)) are executed in pairs, the operation fails.
As a best practice to avoid such errors, use the hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN and configure the other attribute objects separately.
· When a VLAN already exists, configure the following attribute objects:
¡ hh3cdot1qVlanName Enter a string of up to 32 bytes.
¡ hh3cdot1qVlanPorts First obtain the local object data, and then modify the bit corresponding to the interface in the data. Use the modified value as the configured value.
¡ hh3cdot1qVlanType This MIB does not support the sub-vlan(3) or secondary-vlan(5) type.
¡ hh3cdot1qVlanMulticast (not supported)
Configuration examples
· Configuration success: Use a VLAN ID that does not exist as an index, input vlantest for the hh3cdot1qVlanName object, and operate the row state object hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN. This operation successfully creates a VLAN and specifies a name for the VLAN.
· Configuration failure: A trunk interface cannot be assigned to a VLAN. Use the hh3cdot1qVlanPorts object to specify the trunk ports, and operate the row state object hh3cdot1qVlanRowStatus(createAndGo(4)) to create a VLAN. This operation fails.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qVlanIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.1) |
read-only |
Hh3cVlanIndex |
Integer32 (0..2147483647) |
VLAN index. |
As per the MIB. |
hh3cdot1qVlanName (1.3.6.1.4.1.25506.8.35.2.1.1.1.2) |
read-write |
SnmpAdminString |
OCTET STRING (0..80) |
VLAN name. |
If the VLAN name input starts or ends with spaces, the spaces will be automatically trimmed. The string cannot contain only spaces. If you enter an empty string, the default VLAN description is used. |
hh3cdot1qVlanPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.3) |
read-write |
PortList |
OCTET STRING (0..65535) |
List of ports in a VLAN. |
This object can only assign access ports to and remove access ports from VLANs. |
hh3cdot1qVlanType (1.3.6.1.4.1.25506.8.35.2.1.1.1.4) |
read-write |
Integer |
superVlan(1) common-vlan(2) sub-vlan(3) isolate-user-vlan(4) secondary-vlan(5) primaryVlan(6) |
VLAN type. |
Not supported |
hh3cdot1qVlanMacFilter (1.3.6.1.4.1.25506.8.35.2.1.1.1.5) |
read-only |
TruthValue |
true(1), false(2) |
MAC VLAN filtering |
Not supported. The default false(2) is displayed. |
hh3cdot1qVlanMcastUnknownProtos (1.3.6.1.4.1.25506.8.35.2.1.1.1.6) |
read-only |
TruthValue |
true(1), false(2) |
Whether to broadcast packets. |
hh3cExistInterface (1.3.6.1.4.1.25506.8.35.2.1.1.1.7) |
read-only |
TruthValue |
true(1), false(2) |
Whether the VLAN has a VLAN interface. |
As per the MIB. |
hh3cVlanInterfaceIndex (1.3.6.1.4.1.25506.8.35.2.1.1.1.8) |
read-only |
Integer |
Integer (1..4094) |
Index of the VLAN interface. |
As per the MIB. |
hh3cdot1qVlanMacLearn (1.3.6.1.4.1.25506.8.35.2.1.1.1.9) |
read-only |
TruthValue |
true(1), false(2) |
Whether MAC address learning is supported. |
hh3cdot1qVlanStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.10) |
read-only |
Integer |
other(1), static(2), dynamic(3) |
VLAN state. |
As per the MIB. |
hh3cdot1qVlanCreationTime (1.3.6.1.4.1.25506.8.35.2.1.1.1.11) |
read-only |
TimeTicks |
TimeTicks (0..4294967295) |
Time when the VLAN was created. |
As per the MIB. |
hh3cdot1qVlanPriority (1.3.6.1.4.1.25506.8.35.2.1.1.1.12) |
read-write |
Integer |
Integer
VLAN priority. |
Implementation varies by product. |
hh3cdot1qVlanRowStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.13) |
read-create |
Row-Status |
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6) |
VLAN row state. |
Only the following operations are supported:
hh3cdot1qVlanBroadcastSuppression (1.3.6.1.4.1.25506.8.35.2.1.1.1.14) |
read-write |
Integer |
Integer
VLAN broadcast suppression. |
The object can only be read. |
hh3cdot1qVlanBcastSuppressionPPS (1.3.6.1.4.1.25506.8.35.2.1.1.1.15) |
read-write |
Integer |
Integer
VLAN broadcast suppression in pps. |
Not supported |
hh3cdot1qVlanMulticast (1.3.6.1.4.1.25506.8.35.2.1.1.1.16) |
read-write |
Integer |
disable(0),
Multicast VLAN. |
Not supported |
hh3cdot1qVlanTaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.17) |
read-only |
PortList |
Tagged ports of a VLAN. |
As per the MIB. |
hh3cdot1qVlanUntaggedPorts (1.3.6.1.4.1.25506.8.35.2.1.1.1.18) |
read-only |
PortList |
Untagged ports of a VLAN. |
As per the MIB. |
hh3cdot1qVlanPortIndexs (1.3.6.1.4.1.25506.8.35.2.1.1.1.19) |
read-write |
OCTET STRING |
Port index list. |
As per the MIB. |
hh3cdot1qVlanStatisticStatus (1.3.6.1.4.1.25506.8.35.2.1.1.1.20) |
read-write |
TruthValue |
true(1), false(2) |
VLAN traffic statistics switch. |
hh3cdot1qVlanStatisticClear (1.3.6.1.4.1.25506.8.35.2.1.1.1.21) |
read-write |
Integer |
clear(1) |
Clear VLAN traffic statistics. |
The object can only be written. Implementation varies by product. |
hh3cdot1qVlanStatisticInTotalPkts (1.3.6.1.4.1.25506.8.35.2.1.1.1.22) |
read-only |
Counter64 |
Counter64 (0..18446744073709551615) |
Total number of incoming packets. |
hh3cdot1qVlanStatisticInTotalBytes (1.3.6.1.4.1.25506.8.35.2.1.1.1.23) |
read-only |
Counter64 |
Total bytes of incoming packets. |
hh3cdot1qVlanStatisticInPPS (1.3.6.1.4.1.25506.8.35.2.1.1.1.24) |
read-only |
Counter64 |
Incoming packet rate in pps. |
hh3cdot1qVlanStatisticInBPS (1.3.6.1.4.1.25506.8.35.2.1.1.1.25) |
read-only |
Counter64 |
Incoming packet rate in Bps. |
hh3cdot1qVlanStatisticOutTotalPkts (1.3.6.1.4.1.25506.8.35.2.1.1.1.26) |
read-only |
Counter64 |
Total number of outgoing packets. |
hh3cdot1qVlanStatisticOutTotalBytes (1.3.6.1.4.1.25506.8.35.2.1.1.1.27) |
read-only |
Counter64 |
Total bytes of outgoing packets. |
hh3cdot1qVlanStatisticOutPPS (1.3.6.1.4.1.25506.8.35.2.1.1.1.28) |
read-only |
Counter64 |
Outgoing packet rate in pps. |
hh3cdot1qVlanStatisticOutBPS (1.3.6.1.4.1.25506.8.35.2.1.1.1.29) |
read-only |
Counter64 |
Outgoing packet rate in Bps. |
hh3cVlanInterfaceTable
About this table
Use this table to configure and obtain VLAN interface information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table index is hh3cdot1qVlanID.
You must specify the hh3cdot1qVlanIpAddress and hh3cdot1qVlanIpAddressMask objects in pairs.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVlanInterfaceID (1.3.6.1.4.1.25506.8.35.2.1.2.1.1) |
read-only |
Integer |
Index. |
As per the MIB. |
hh3cdot1qVlanID (1.3.6.1.4.1.25506.8.35.2.1.2.1.2) |
read-only |
Hh3cVlanIndex |
VLAN ID |
As per the MIB. |
hh3cdot1qVlanIpAddress (1.3.6.1.4.1.25506.8.35.2.1.2.1.3) |
read-write |
IpAddress |
IP address. |
As per the MIB. |
hh3cdot1qVlanIpAddressMask (1.3.6.1.4.1.25506.8.35.2.1.2.1.4) |
read-write |
IpAddress |
IP address and its mask. |
As per the MIB. |
hh3cVlanInterfaceAdminStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.5) |
read-write |
Integer |
up(1), down(2) |
VLAN interface state. |
As per the MIB. |
hh3cVlanInterfaceFrameType (1.3.6.1.4.1.25506.8.35.2.1.2.1.6) |
read-only |
Integer |
ethernet-ii(1), ethernet-snap(2), ethernet-8022(3), ethernet-8023(4) |
Frame type. |
As per the MIB. |
hh3cInterfaceRowStatus (1.3.6.1.4.1.25506.8.35.2.1.2.1.7) |
read-create |
RowStatus |
active(1),
Interface row state. |
Available values are active(1), createAndgo(4), and destroy(6).
If an object fails to be configured, this operation fails. As a best practice, use the hh3cInterfaceRowStatus (createAndGo(4)) to create a VLAN interface and configure other attribute objects separately.
hh3cVlanInterfaceIpMethod (1.3.6.1.4.1.25506.8.35.2.1.2.1.8) |
read-write |
Integer |
assigned-ip(1), dhcp-ip(2), bootp-ip(3) |
VLAN interface IP address assignment method. |
hh3cVlanInterfaceIfIndex (1.3.6.1.4.1.25506.8.35.2.1.2.1.9) |
read-only |
Integer |
As per the MIB. |
hh3cifIsolateMappingTable
About this table
Use this table to configure the isolate VLAN feature and configure and obtain the isolate VLAN-to-secondary VLAN mappings. Implementation varies by product.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cifIsolatePrimaryVlanID.
You must specify the hh3cifIsolateSecondaryVlanlistLow and hh3cifIsolateSecondaryVlanlistHigh objects in pairs.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifIsolatePrimaryVlanID (1.3.6.1.4.1.25506.8.35.2.1.4.1.1) |
read-only |
Hh3cVlanIndex |
Primary VLAN |
hh3cifIsolateSecondaryVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.4.1.2) |
read-write |
OCTET STRING |
OCTET STRING (0..256) |
Low bit in the secondary VLAN bitmap. |
hh3cifIsolateSecondaryVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.4.1.3) |
read-write |
OCTET STRING |
High bit in the secondary VLAN bitmap. |
hh3cVlanInterfaceAddrTable
About this table
Use this table to configure and obtain VLAN interface IP addresses.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cVlanInterfaceIpIfIndex and hh3cVlanInterfaceIpAddr.
When the hh3cVlanInterfaceIpRowStatus (createAndgo(4)) operation is executed, you must specify the hh3cVlanInterfaceIpAddr and hh3cVlanInterfaceIpMask objects in pairs. When the hh3cVlanInterfaceIpRowStatus (destroy(6)) operation is executed, you must specify the hh3cVlanInterfaceIpAddr and hh3cVlanInterfaceIpType objects in pairs.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cVlanInterfaceIpIfIndex (1.3.6.1.4.1.25506.8.35.2.1.5.1.1) |
read-only |
Integer |
As per the MIB. |
hh3cVlanInterfaceIpAddr (1.3.6.1.4.1.25506.8.35.2.1.5.1.2) |
read-only |
IpAddress |
OCTET STRING (4) |
VLAN interface IP address. |
As per the MIB. |
hh3cVlanInterfaceIpMask (1.3.6.1.4.1.25506.8.35.2.1.5.1.3) |
read-create |
IpAddress |
OCTET STRING (4) |
VLAN Interface IP address mask. |
As per the MIB. |
hh3cVlanInterfaceIpType (1.3.6.1.4.1.25506.8.35.2.1.5.1.4) |
read-create |
Integer |
primary(1), sub(2), cluster(3), vrrp(4) |
VLAN interface IP type. |
As per the MIB. Available values are primary(1) and sub(2). |
hh3cVlanInterfaceIpRowStatus (1.3.6.1.4.1.25506.8.35.2.1.5.1.5) |
read-create |
RowStatus |
Interface IP address row state. |
Available values are active(1), createAndGo(4), and destroy(6). |
hh3cDot1qVlanBatchMIBTable
About this table
Use this table to bulk configure VLANs.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are hh3cdot1qVlanBatchStartIndex, hh3cdot1qVlanBatchEndIndex, and hh3cdot1qVlanBatchSetOperate.
To bulk create VLANs, set the hh3cdot1qVlanBatchSetOperate object to 1.
For example, to create VLANs 2 through 4, enter the following values for objects:
hh3cdot1qVlanBatchStartIndex 2,
hh3cdot1qVlanBatchEndIndex 4,
hh3cdot1qVlanBatchSetOperate create(1),
hh3cdot1qVlanBatchRowStatus createAndGo(4).
To bulk delete VLANs, set the hh3cdot1qVlanBatchSetOperate object to 2.
For example, to delete VLANs 10 through 20, enter the following values for objects:
hh3cdot1qVlanBatchStartIndex 10,
hh3cdot1qVlanBatchEndIndex 20,
hh3cdot1qVlanBatchSetOperate delete(2),
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cdot1qVlanBatchOperIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.1) |
read-only |
Integer32 |
Operation index. |
Not supported |
hh3cdot1qVlanBatchStartIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.2) |
read-write |
Hh3cVlanIndex |
Start VLAN ID. |
Not supported |
hh3cdot1qVlanBatchEndIndex (1.3.6.1.4.1.25506.8.35.2.1.6.1.3) |
read-write |
Hh3cVlanIndex |
End VLAN ID. |
Not supported |
hh3cdot1qVlanBatchOperStatus (1.3.6.1.4.1.25506.8.35.2.1.6.1.4) |
read-only |
Integer |
Operation state. |
Not supported |
hh3cdot1qVlanBatchRowStatus (1.3.6.1.4.1.25506.8.35.2.1.6.1.5) |
read-create |
Row-Status |
Row status. |
Not supported |
hh3cdot1qVlanBatchSetOperate (1.3.6.1.4.1.25506.8.35.2.1.6.1.6) |
read-create |
Integer |
Set the operation type. |
Not supported |
hh3cifSuperVlanMappingTable
About this table
Use this table to configure the super VLAN feature and configure and obtain the super VLAN-to-sub VLAN mappings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cifSuperVlanID.
When setting super VLAN, you must specify the hh3cifSubVlanlistLow and hh3cifSubVlanlistHigh objects in pairs.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cifSuperVlanID (1.3.6.1.4.1.25506.8.35.2.1.7.1.1) |
read-only |
Hh3cVlanIndex |
Super VLAN index. |
Not supported |
hh3cifSubVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.7.1.2) |
read-write |
OCTET STRING |
Low bit in the sub VLAN bitmap. |
Not supported |
hh3cifSubVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.7.1.3) |
read-write |
OCTET STRING |
High bit in the sub VLAN bitmap. |
Not supported |
hh3cPrivateVlanMappingTable
About this table
Use this table to configure the private VLAN feature and configure and obtain the primary VLAN-to-secondary VLAN mappings.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Supported |
Not supported |
Supported |
Columns
The table index is hh3cPrimaryVlanID.
When setting private VLAN, you must specify the hh3cSecondaryVlanlistLow and hh3cSecondaryVlanlistHigh objects in pairs.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cPrimaryVlanID (1.3.6.1.4.1.25506.8.35.2.1.8.1.1) |
read-only |
Hh3cVlanIndex |
Primary VLAN index. |
As per the MIB. |
hh3cSecondaryVlanlistLow (1.3.6.1.4.1.25506.8.35.2.1.8.1.2) |
read-write |
OCTET STRING |
As per the MIB. |
hh3cSecondaryVlanlistHigh (1.3.6.1.4.1.25506.8.35.2.1.8.1.3) |
read-write |
OCTET STRING |
As per the MIB. |
