H3C Data Center Switches DRNI Configuration Guide-6W103
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches DRNI Configuration Guide-6W103
12-DRNI+EVPN+Monitor Link Configuration Examples
12-DRNI+EVPN+Monitor Link Configuration Examples 203.00 KB
Example: Configuring DRNI, EVPN, and Monitor Link· 1
Network configuration· 1
Applicable product matrix· 3
Analysis· 4
Restrictions and guidelines· 4
Configuring the DR member devices· 4
Procedure summary· 4
Configuring interfaces· 4
Configuring the links towards the downstream server 8
Configuring the links towards Device C· 11
Configuring DRNI MAD·· 11
Configuring monitoring· 11
Configuring Device C· 12
Procedure summary· 12
Configuring the interfaces· 12
Configuring the links towards the DR system·· 14
Configuring the links towards the servers and Network· 14
Configuring Device D·· 15
Procedure summary· 15
Configuring the links towards the DR system·· 15
Configuring the link towards Server 1· 15
Configuring routing· 16
Procedure summary· 16
Configuring routing on the DR member devices· 16
Configuring routing on Device C· 18
Traffic forwarding models· 20
Traffic characteristics· 20
Underlay forwarding models· 20
Testing network convergence upon single points of failure· 20
Verifying the configuration· 21
Verifying functionality of the DR system·· 21
Verifying routing information· 22
Verifying connectivity between Server 1 and Server 2· 24
Verifying connectivity between Server 1 and Server 3· 24
Verifying connectivity between Server 1 and Network· 24
Verifying traffic failover upon uplink failure· 24
Verifying spanning tree configuration· 24
Upgrading the DR member devices· 24
Checking the environment 24
Upgrading the device· 25
Verifying the traffic interruption time during the upgrade· 25
Verifying the upgrade result 25
As shown in Figure 1, configure the network as follows:
·     Set up a DR system with Device A and Device B.
·     Connect Server 1 to the DR system via Device D.
·     Connect Device C to Server 2, Server 3, and Network (public network).
·     Configure ECMP routes between the DR system and Device C.
Perform the following tasks to ensure network connectivity:
·     Configure Device A and Device B as distributed gateways.
·     Configure Device C as a distributed gateway and border gateway.
·     Assign Server 1 to Server 2 to one VXLAN, and assign Server 3 to another VXLAN.
·     Configure Monitor Link to enable one DR member device to shut down its downlink interface upon uplink interface failure for traffic to fail over to the other DR member device.
Configure spanning tree to eliminate loops:
·     Enable spanning tree on the DR member devices.
·     Enable BPDU guard on the DR member devices to protect them from forged BPDU attacks.
Figure 1 Network diagram
Device
IP address
Remarks
Device A
HGE 1/0/27
10.130.0.161/31
Connected to HGE 1/0/26 on Device C.
HGE 1/0/29
N/A
Connected to HGE 2/0/6 on Device D.
MGE 0/0/0
10.130.8.105/24
Connected to MGE 0/0/0 on Device A.
Vlan-int 100
192.168.1.1/30
Connected to VLAN-interface 100 on Device B.
Used for Layer 3 communication between the DR member devices, BGP peer relationship setup, and traffic failover.
Vsi-int 5000
120.241.147.49/26
Distributed EVPN gateway interface.
Vsi-int 1
N/A
L3VNI-associated VSI interface.
LoopBack 0
10.130.11.1/32
VTEP IP address used for setting up BGP EVPN peer relationships.
LoopBack 1
10.130.12.1/32
Virtual VTEP IP address.
Device B
HGE 1/0/25
N/A
Connected to HGE 1/0/26 on Device A.
HGE 1/0/29
N/A
Connected to HGE 4/0/4 on Device D.
HGE 1/0/30
10.130.1.161/31
Connected to HGE 1/0/25 on Device C.
MGE 0/0/0
10.130.8.106/24
Connected to MGE 0/0/0 on Device B.
Vlan-int 100
192.168.1.2/30
Connected to VLAN-interface 100 on Device A.
Vsi-int 5000
120.241.147.49/26
Vsi-int 1
N/A
LoopBack 0
10.130.11.2/32
LoopBack 1
10.130.12.1/32
Device C
HGE 1/0/25
10.130.1.160/31
Connected to HGE 1/0/30 on Device B.
HGE 1/0/26
10.130.0.160/31
Connected to HGE 1/0/27 on Device A
HGE 1/0/27
N/A
Connected to Network, Server 2, and Server 3.
Vlan-int 5
192.168.255.1
Connected to Network.
Vsi-int 5000
120.241.147.49/26
Vsi-int 1000
11.0.0.1/26
Gateway interface for Server 3.
Vsi-int 1
N/A
LoopBack 1
10.130.12.253/32
Device D
HGE 2/0/6
N/A
Connected to HGE 1/0/29 on Device A.
HGE 4/0/4
N/A
Connected to HGE 1/0/29 on Device B.
HGE 6/0/5
N/A
Connected to Server 1.
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S12500X-AF, S6890
R2820
S6805, S6825, S6850, S9850
R6635
S12500G-AF
R7624P12
S6800, S6860
F2715 and higher F27xx versions
Do not use F28xx versions.
S9820-64H, S9820-8C
Not supported
S6812, S6813
Contact H3C Support to obtain compatible versions.
Analysis
To enable successful traffic failover upon failure of one DR member device, configure Device A and Device B to set up BGP peer relationships by using VLAN-interface 100.
In this example, all devices use factory defaults. When you configure DRNI on a live network, make sure the following requirements are met:
·     Device A and Device B use the same DR system MAC address.
·     Each device has a unique router ID.
Procedure summary
·     Configuring interfaces
·     Configuring the links towards the downstream server
·     Configuring the links towards Device C
·     Configuring DRNI MAD
·     Configuring monitoring
Device A
Device B
Remarks
interface LoopBack 0
Create loopback 0.
N/A
description evpn_ip
description evpn_ip
Configure a description for the interface to indicate its purpose.
N/A
ip address 10.130.11.1 32
ip address 10.130.11.2 32
Assign an IP address to the interface.
Unique VTEP IP address.
interface LoopBack 1
Create loopback 1.
N/A
description VTEP
description VTEP
Configure a description for the interface.
N/A
ip address 10.130.12.1 32
Assign an IP address to the interface to indicate its purpose.
Return to system view.
N/A
ip vpn-instance Mgt
ip vpn-instance Mgt
Create a VPN instance.
Bound to the management Ethernet interface.
ip vpn-instance WAN
ip vpn-instance WAN
Create another VPN instance and enter its view.
Bound to the VSI interface acting as a gateway for service traffic.
route-distinguisher 10.130.11.1:400
route-distinguisher 10.130.11.2:400
Configure an RD for the VPN instance.
An RD uniquely identifies a VPN instance. Configure unique RDs on different devices.
address-family ipv4
address-family ipv4
Enter IPv4 address family view of the VPN instance.
N/A
vpn-target 65000:10000 import-extcommunity
Configure import targets.
Route targets are used to control advertisement of VPN routes.
·     Export target attribute—A PE sets the export target attribute for VPN routes before advertising them to other PEs.
·     Import target attribute—A PE checks the export target attribute of VPN routes received from other PEs. If the export target attribute matches the import target attribute of a VPN instance, the PE adds the routes to the routing table of the VPN instance.
vpn-target 65000:10000 export-extcommunity
Configure export targets.
address-family evpn
address-family evpn
Enter EVPN view of the VPN instance.
N/A
Exit the current view.
N/A
N/A
interface M-GigabitEthernet0/0/0
Enter management Ethernet interface view.
N/A
ip binding vpn-instance Mgt
Bind the interface to a VPN instance.
N/A
ip address 10.130.8.105 24
ip address 10.130.8.106 24
Assign an IP address to the management Ethernet interface.
N/A
N/A
vlan 50 100
vlan 50 100
Create VLAN 50 and VLAN 100.
N/A
interface Vlan-interface100
Create a VLAN interface.
Layer 3 interface used for interconnecting the DR member devices.
ip address 192.168.1.1 30
ip address 192.168.1.2 30
Assign an IP address to the VLAN interface.
N/A
N/A
interface Vsi-interface 5000
Create a VSI interface and enter its view.
 ip binding vpn-instance WAN
Bind the VSI interface to VPN instance WAN.
N/A
 ip address 120.241.147.49 26
Assign an IP address to the VSI interface.
N/A
 mac-address 0000-5e00-aa01
Assign a MAC address to the VSI interface.
N/A
 distributed-gateway local
Specify the VSI interface as a distributed gateway interface.
N/A
N/A
vsi 5000
vsi 5000
Create a VSI and enter its view.
N/A
gateway vsi-interface 5000
Specify a gateway interface for the VSI.
N/A
arp suppression enable
Enable ARP flood suppression.
N/A
vxlan 5000
vxlan 5000
Create a VXLAN and enter its view.
N/A
evpn encapsulation vxlan
Enter VSI EVPN instance view.
N/A
route-distinguisher 10.130.11.1:5000
route-distinguisher 10.130.11.2:5000
Configure an RD for the EVPN instance.
vpn-target 65000:5000 export-extcommunity
vpn-target 65000:5000 import-extcommunity
Return to VSI view.
N/A
N/A
interface Vsi-interface 1
Create a VSI interface.
N/A
l3-vni 10000
l3-vni 10000
Assign an L3VNI to the VSI interface.
N/A
Device A
Device B
Remarks
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
vxlan tunnel arp-learning disable
Disable remote ARP learning.
N/A
Disable remote MAC learning.
N/A
evpn drni group 10.130.12.1
Configure a virtual VTEP IP address.
Used by the DR member devices to establish tunnels with peer devices.
evpn global-mac 0000-5e01-0e01
Configure an EVPN global MAC address for L3VNI-associated VSI interfaces.
N/A
drni system-mac 0000-5e01-0ffe
Configure a DR system MAC address.
Configure the same DR system MAC address on the DR member devices.
drni system-number 1
drni system-number 2
Configure a DR system number.
Configure different DR system numbers on the DR member devices.
drni role priority 100
drni role priority 150
Set the DR role priority.
The lower the value, the higher the priority.
drni system-priority 32768
Set the DR system priority.
Configure the same DR system priority on the DR member devices.
drni auto-recovery reload-delay 240
Enable DR system auto-recovery and set the reload delay timer.
To avoid incorrect role preemption, make sure the reload delay timer is longer than the amount of time required for the device to restart.
drni keepalive ip destination 10.130.8.106 source 10.130.8.105 vpn-instance Mgt
drni keepalive ip destination 10.130.8.105 source 10.130.8.106 vpn-instance Mgt
Configure DR keepalive packet parameters.
N/A
drni standalone enable
Enable DRNI standalone mode.
N/A
stp global enable
stp global enable
Enable spanning tree globally.
N/A
stp bpdu-protection
stp bpdu-protection
Enable BPDU guard globally.
N/A
interface bridge-aggregation 100
Create Bridge-Aggregation 100, which will be configured as the IPP.
N/A
N/A
interface HundredGigE 1/0/26
interface HundredGigE 1/0/25
Enter Ethernet interface view.
N/A
port link-mode bridge
Configure the Ethernet interface to work in Layer 2 mode.
N/A
port link-aggregation group 100
Assign HundredGigE 1/0/25 to Layer 2 aggregation group 100.
N/A
N/A
Enter the view of Bridge-Aggregation 100.
N/A
link-aggregation mode dynamic
Configure Bridge-Aggregation 100 to work in dynamic aggregation mode.
N/A
port drni intra-portal-port 1
Configure Bridge-Aggregation 100 as an IPP.
N/A
port link-type trunk
Configure the Layer 2 aggregate interface as a trunk port.
N/A
port trunk permit vlan all
Configure the trunk port to permit all VLANs.
N/A
N/A
Create Bridge-Aggregation 1, which is connected to Device D.
N/A
N/A
Interface HundredGigE 1/0/29
interface HundredGigE 1/0/29
N/A
N/A
Assign the Ethernet interface to aggregation group 1.
N/A
N/A
Enter the view of Bridge-Aggregation 1.
N/A
undo mac-address static source-check enable
Disable static source check.
The S12500X-AF, S12500G-AF, and S6890 switches do not support this command.
Configure the aggregate interface to work in dynamic aggregation mode.
N/A
port drni group 1
port drni group 1
Assign the aggregate interface to a DR group.
N/A
N/A
undo port trunk permit vlan 1
Forbid traffic of VLAN 1.
N/A
port trunk permit vlan 50
Permit traffic of VLAN 50.
N/A
service-instance 50
service-instance 50
Create Ethernet service instance 50.
N/A
encapsulation s-vid 50
Configure the Ethernet service instance to match packets with outer VLAN tag 50.
N/A
xconnect vsi 5000
xconnect vsi 5000
Map the Ethernet service instance to VSI 5000.
N/A
Return to VSI view.
N/A
N/A
Device A
Device B
interface HundredGigE 1/0/27
interface HundredGigE 1/0/30
port link-mode route
Configure the interface to work in Layer 3 mode.
description TO_Device-C
Configure a description.
ip address 10.130.0.161 31
ip address 10.130.1.161 31
Device A
Device B
drni mad default-action none
Set the default DRNI MAD action to NONE.
drni mad include interface HundredGigE 1/0/27
drni mad include interface HundredGigE 1/0/30
Specify an interface to be shut down by DRNI MAD when the DR system splits.
drni mad include interface HundredGigE 1/0/29
Device A
Device B
undo monitor-link disable
Enable Monitor Link globally.
monitor-link group 1
Create a monitor link group and enter its view.
port HundredGigE 1/0/27 uplink
port HundredGigE 1/0/30 uplink
Assign uplink interfaces to the monitor link group.
port HundredGigE 1/0/29 downlink
Assign downlink interfaces to the monitor link group.
Procedure summary
·     Configuring the interfaces
·     Configuring the links towards the DR system
·     Configuring the links towards the servers and Network
Device C
Create a loopback interface and enter its view.
description VTEP
ip address 10.130.12.253 32
ip vpn-instance Mgt
Create VPN instance Mgt.
ip vpn-instance WAN
Create L3VPN instance WAN.
route-distinguisher 10.130.12.253:400
address-family ipv4
address-family evpn
Bind the management Ethernet interface to VPN instance Mgt.
ip address 10.130.8.104 24
vlan 5 10 50
Create VLAN 5, VLAN 10, and VLAN 100.
interface Vlan-interface 5
Bind the VLAN interface to VPN instance WAN.
ip address 192.168.255.1 30
vsi 5000
Create a VSI.
vxlan 5000
Create a VXLAN.
route-distinguisher 10.130.12.253:5000
Return to VSI view.
interface Vsi-interface1
l3-vni 10000
interface Vsi-interface1000
ip address 11.0.0.1 26
mac-address 0000-5e00-aa02
vsi 1000
Create a VSI.
gateway vsi-interface 1000
vxlan 1000
Enter VXLAN view.
route-distinguisher 10.130.12.253:1000
vpn-target 65000:1000 export-extcommunity
vpn-target 65000:1000 import-extcommunity
Return to VSI view.
Device C
l2vpn enable
Enable L2VPN.
Enter the view of the interface connected to Device A.
Configure the interface to work at Layer 3 mode.
description TO_Device-A
ip address 10.130.0.160 31
Enter the view of the interface connected to Device B.
description TO_Device-B
ip address 10.130.1.160 31
Device C
Enter the view of the physical interface facing the servers and Network.
Configure the interface to work at Layer 2 mode.
Set the link type to trunk.
port trunk permit vlan 5 10 50
Permit traffic of VLAN 5, VLAN 10, and VLAN 50.
service-instance 50
Create an Ethernet service instance.
Configure a frame match criterion for the Ethernet service instance.
xconnect vsi 5000
Map the Ethernet service instance to a VSI.
service-instance 10
encapsulation s-vid 10
xconnect vsi 1000
Procedure summary
·     Configuring the link towards Server 1
Device D
vlan 50
Create VLAN 50.
Create an aggregate interface.
interface HundredGigE 2/0/6
interface HundredGigE 4/0/4
Set the link type of the aggregate interface to trunk.
Device D
stp global enable
interface HundredGigE 6/0/5
Enter the view of the interface connected to Server 1.
port link-type access
Set the link type to access.
port access vlan 50
Configure the interface to permit traffic of VLAN 50 as an access port.
stp edged-port
Configure the interface as a spanning tree edge port.
Configuring routing
Procedure summary
·     Configuring routing on the DR member devices
·     Configuring routing on Device C
Device A
Device B
Purpose/Remarks
bgp 1
bgp 1
Enable BGP instance default, specify 1 as the local AS number, and enter BGP instance view.
Used for creating underlay routes.
bgp update-delay on-startup 240
Configure BGP to delay sending route updates on reboot.
The delay timer must be longer than the time spent on BGP relationship establishment after the BGP process restarts.
non-stop-routing
non-stop-routing
Enable BGP NSR.
N/A
router-id 10.130.11.1
router-id 10.130.11.2
Configure a router ID.
Configure unique router IDs for the devices in the same AS.
group ibgp internal
group ibgp internal
Create IBGP peer group ibgp.
N/A
group spine external
Create EBGP peer group spine.
N/A
peer spine as-number 2
Specify AS number 2 for the EBGP peer group.
N/A
peer spine route-update-interval 0
Set the interval to 0 for sending the same update to peer group spine.
N/A
peer 10.130.0.160 group spine
peer 10.130.1.160 group spine
Assign peers with a 10.130.x.160 IP address to EBGP peer group spine.
Set up peer relationships between the DR member devices and Device C.
peer 192.168.1.2 group ibgp
peer 192.168.1.1 group ibgp
Assign peers with a 192.168.1.x address to IBGP peer group ibgp.
address-family ipv4 unicast
Create the BGP-VPN IPv4 unicast address family and enter its view.
N/A
balance ebgp 8
balance ebgp 8
Enable load balancing and set the maximum number of EBGP ECMP routes for load balancing to 8.
N/A
network 10.130.11.1 255.255.255.255
network 10.130.11.2 255.255.255.255
Configure BGP to advertise a local network.
N/A
network 10.130.12.1 255.255.255.255
Configure BGP to inject local network 10.130.12.1/32 into the BGP routing table.
N/A
peer ibgp enable
peer ibgp enable
Enable BGP to exchange IPv4 unicast routing information with peer group ibgp.
N/A
peer ibgp next-hop-local
Set the local router as the next hop for BGP routes sent to the IBGP peer group.
N/A
peer spine enable
peer spine enable
Enable BGP to exchange IPv4 unicast routing information with peer group spine.
N/A
Return to BGP view.
N/A
N/A
bgp 65000 instance evpn
Enable BGP instance evpn, specify 65000 as the local AS number, and enter BGP instance view.
Used for creating overlay routes.
non-stop-routing
non-stop-routing
Enable BGP NSR.
N/A
group spine internal
Create IBGP peer group spine.
N/A
peer spine connect-interface LoopBack0
Specify source interface Loopback 0 for establishing TCP links towards peer group spine.
N/A
peer 10.130.12.253 group spine
Assign the peer at 10.130.12.253 to IBGP peer group spine.
N/A
address-family l2vpn evpn
Create the BGP EVPN address family and enter its view.
N/A
nexthop evpn-drni group-address
Set the next hop of advertised EVPN routes to the virtual VTEP address of the DR system.
N/A
peer spine enable
peer spine enable
Enable the device to exchange BGP EVPN routes with peer group spine.
N/A
Return to BGP view.
N/A
N/A
Device C
Remarks
bgp 2
Enable BGP instance default, specify 2 as the local AS number, and enter BGP instance view.
N/A
non-stop-routing
Enable BGP NSR.
N/A
N/A
peer spine as-number 1
Specify AS number 1 for the EBGP peer group.
N/A
N/A
peer 10.130.0.161 group spine
Assign the peer at 10.130.0.161 to EBGP peer group spine.
N/A
peer 10.130.1.161 group spine
Assign the peer at 10.130.1.161 to EBGP peer group spine.
N/A
Enter BGP IPv4 unicast address family view.
N/A
balance ebgp 8
N/A
network 10.130.12.253 255.255.255.255
Configure BGP to inject local network 10.130.12.253/32 into the BGP routing table.
N/A
peer spine enable
N/A
Return to BGP view.
N/A
N/A
N/A
non-stop-routing
Enable BGP NSR.
N/A
router-id 10.130.12.253
N/A
N/A
peer spine connect-interface LoopBack1
Specify source interface Loopback 1 for establishing TCP links towards peer group spine.
N/A
peer 10.130.11.1 group spine
Assign the peer at 10.130.11.1 to IBGP peer group spine.
N/A
peer 10.130.11.2 group spine
Assign the peer at 10.130.11.2 to IBGP peer group spine.
N/A
N/A
peer spine enable
Enable BGP to exchange BGP EVPN routing information with peer group spine.
N/A
ip vpn-instance WAN
Enter the view of BGP-VPN instance WAN.
N/A
Enter BGP-VPN IPv4 unicast address family view.
N/A
default-route imported
Import default routes to the BGP routing table.
N/A
balance 16
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing to 16.
N/A
Return to BGP view.
N/A
N/A
ip route-static vpn-instance WAN 0.0.0.0 0 Vlan-interface5 192.168.255.2 description to-evpn-wan
Configure a static route for Network.
N/A
ip route-static vpn-instance Mgt 10.0.0.0 8 10.130.8.1
Configure a static route for the management Ethernet interface.
N/A
The forwarding model matrix provides the following characteristics of traffic:
·     No.—Traffic number, which can be U-S2, U-S3, or U-N.
¡     U—Underlay traffic.
¡     S—Server.
¡     N—Network.
·     Traffic type—Type of traffic, which can only be known IPv4 unicast.
·     Direction—Direction of traffic, which can only be south to north.
·     Forwarding path—Nodes that traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically a tester is used to simulate traffic.
·     Load—Traffic size, which can be light (less than 1000 flows).
·     Traffic direction to firewalls/LB—Not applicable.
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
U-S2
Known unicast
South to north
Server 1 > Device A/B > Device C > Server 2
Tester
Light
N/A
U-S3
Known unicast
South to north
Server 1 > Device A/B > Device C > Server 3
Tester
Light
N/A
U-N1
Known unicast
South to north
Server 1 > Device A/B > Device C > Network
Tester
Light
N/A
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
DR member device
Link failure
≤ 500 ms
Link failure recovery
≤ 500 ms
Uplink failure
≤ 500 ms
IPL failure
≤ 500 ms
IPL failure recovery
≤ 500 ms
Keepalive link failure
0 ms
Keepalive link failure recovery
0 ms
Concurrent failure of the keepalive link and IPL
≤ 5000 ms
Recovery of the keepalive link and IPL from failure
≤ 1000 ms
Upgrade
≤ 500 ms (device-by-device upgrade)
The following steps use Device A as an example.
# Verify that Device A and Device B have established a DR system.
[DeviceA] display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
       C -- Configuration consistency check failed
IPP: BAGG100
IPP state (cause): UP
Keepalive link state (cause): UP
                     DR interface information
DR interface  DR group  Local state (cause)  Peer state  Remaining down time (s)
BAGG1         1         UP                   UP          -
# Verify the keepalive packet statistics.
[DeviceA] display drni keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 69 s 921 ms
Keepalive packet transmission status:
Sent: Successful
Received: Successful
Last received keepalive packet information:
Source IP address: 10.130.8.106
Time: 2022/01/03 15:30:44
Action: Accept
Distributed relay keepalive parameters:
Destination IP address: 10.130.8.106
Source IP address: 10.130.8.105
Keepalive UDP port : 6400
Keepalive VPN name : Mgt
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Verify the DR system settings.
[DeviceA] display drni system
                                       System information
Local system number: 1                      Peer system number: 2
Local system MAC: 0000-5e01-0ffe            Peer system MAC: 0000-5e01-0ffe
Local system priority: 32768                  Peer system priority: 32768
Local bridge MAC: f474-8882-ee00            Peer bridge MAC: 0000-fc00-6504
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Disabled
In standalone mode: No
                       System timer information
Timer                                         State       Value (s)    Remaining time (s)
Auto recovery   Disabled    240                   -
Restore delay   Disabled    30                     -
Consistency-check delay Disabled    15                     -
Standalone delay    Disabled     -                       -
Role to None delay  Disabled    60                     -
# Verify information about the interfaces on the DR system.
[DeviceA] display drni verbose
Flags: A -- Home_Gateway, B -- Neighbor_Gateway, C -- Other_Gateway,
       D -- IPP_Activity, E -- DRCP_Timeout, F -- Gateway_Sync,
       G -- Port_Sync, H -- Expired
IPP/IPP ID: BAGG100/1
State: UP
Cause: -
Local DRCP flags/Peer DRCP flags: ABDFG/ABDFG
Local Selected ports (index): HGE 1/0/26 (26)
Peer Selected ports indexes: 25
DR interface/DR group ID: BAGG1/1
Local DR interface state: UP
Peer DR interface state: UP
DR group state: UP
Local DR interface down cause: -
Remaining DRNI DOWN time: -
Local DR interface LACP MAC: Config=N/A, Effective=0000-5e01-0ffe
Peer DR interface LACP MAC: Config=N/A, Effective=0000-5e01-0ffe
Local DR interface LACP priority: Config=32768, Effective=32768
Peer DR interface LACP priority: Config=32768, Effective=32768
Local Selected ports (index): HGE 1/0/29(45)
Peer Selected ports indexes: 29
# Verify that Device A has underlay BGP peers.
[DeviceA] display bgp peer ipv4
BGP local router ID: 10.130.11.1
Local AS number: 1
Total number of peers: 2        peers in established state: 2
* - Dynamically created peer
Peer          AS    MsgRcvd   MsgSent    OutQ    PrefRcv    Up/Down      State
10.130.0.160  2     3743      3744       0       1          01:02:17     Established
192.168.1.2   1     600024    600043     0       3          0166h40m     Established
# Verify that Device A has overlay BGP peers.
[DeviceA] display bgp instance evpn peer l2vpn evpn
Local AS number: 65000
Total number of peers: 1        peers in established state: 1
10.130.12.253 65000 10232     11134      0       4          0166h52m     Established
# Verify that Device B has underlay BGP peers.
[DeviceB] display bgp peer ipv4
BGP local router ID: 10.130.11.2
Local AS number: 1
10.130.1.160  2    3925       3926       0       1          01:21:55     Established
192.168.1.1   1    601092     602000     0       3          0166h52m     Established
# Verify that Device B has overlay BGP peers.
[DeviceB] display bgp instance evpn peer l2vpn evpn
10.130.12.253 65000 12539     11149      0       4          0166h59m     Established
# Verify that Device C has underlay BGP peers.
[DeviceC] display bgp peer ipv4
BGP local router ID: 10.130.12.253
Local AS number: 2
10.130.0.161  1    5211       5209       0       3          01:26:42     Established
10.130.1.161  1    502        501        0       3          01:08:16     Established
# Verify that Device C has overlay BGP peers.
BGP local router ID: 10.130.12:253
10.130.11.1   65000  11156     10252      0       3          0167h12m     Established
10.130.11.2   65000  11157     12549      0       3          0167h07m     Established
Verify that Server 1 and Server 2, which are in the same VXLAN, have Layer 2 connectivity.
Verify that Server 1 and Server 2, which are in different VXLANs, have Layer 3 connectivity.
Verify that Server 1 on a private network and Network on the public network have Layer 3 connectivity.
Configure Monitor Link.
port HGE 1/0/30 uplink           Uplink interface
port ethernet 1/0/29 downlink    Associated member port of a DR group
monitor-link group 2
port HGE 1/0/27 uplink           Uplink interface
Disconnect the interface connected to Device C on Device A or Device B.
Verify that Server 1, Server 2, Server 3, and Network can communicate with one another.
# Verify that spanning tree is operating correctly.
<DeviceA> display stp brief
MST ID              Port                         Role            STP State            Protection
0                  HundredGigE1/0/27         DESI          FORWARDING         NONE
0                  Bridge-Aggregation1 (DR)  DESI          FORWARDING         NONE
<DeviceB> display stp brief
0                  HundredGigE1/0/30         DESI          FORWARDING         NONE
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is available for an upgrade.
Leaf 1
Leaf 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches DR System Upgrade & Replacement & Expansion Guide.
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback. For more information, see "Testing network convergence upon single points of failure."
Execute the commands in "Verifying the configuration" and the following commands to verify that the device is upgraded successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
