H3C Data Center Switches DRNI Configuration Guide-6W103
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches DRNI Configuration Guide-6W103
07-DRNI and EVPN Distributed Gateway (IS-IS for underlay routing) Configuration Example
Example: Configuring DRNI and EVPN distributed gateways (IS-IS for underlay routing) 1
Network configuration· 1
Traffic forwarding models· 5
Applicable product matrix· 6
Configuring S6800 or S6812 switches as leaf devices· 7
Procedure summary· 7
Configuring the resource mode (only on S6800 switches) 7
Creating VRRP groups· 8
Configuring IS-IS· 9
Configuring the links towards the spine tier 13
Configuring L2VPN· 15
Configuring DRNI 16
Configuring the links towards the virtualization servers· 21
Configuring the links towards the bare metal servers· 21
Configuring spanning tree· 22
Configuring a BGP instance· 23
Configuring the overlay network· 24
Configuring S6850 switches as leaf devices· 28
Procedure summary· 28
Configuring the resource mode· 29
Creating VRRP groups· 29
Configuring IS-IS· 30
Configuring the links towards the spine tier 34
Configuring L2VPN· 36
Configuring DRNI 38
Configuring the links towards the virtualization servers· 42
Configuring the links towards the bare metal servers· 42
Configuring spanning tree· 43
Configuring a BGP instance· 44
Configuring the overlay network· 44
Configuring S12508X-AF or S12500G-AF switches as border devices· 49
Procedure summary· 49
Configuring basic settings· 49
Configuring IS-IS· 50
Configuring STP· 54
Configuring the links towards the spine tier 54
Configuring L2VPN· 56
Configuring DRNI 58
Configuring the DR interfaces connected to the external network· 62
Configuring the DR interfaces connected to the external network firewalls· 63
Configuring a BGP instance· 64
Configuring the overlay network· 68
Configuring S12508X-AF or S12500G-AF switches as spine devices· 78
Procedure summary· 78
Configuring IS-IS· 79
Configuring the links between the spine and leaf tiers· 81
Configuring the links between the spine and border tiers· 82
Configuring BGP· 83
Overlay traffic forwarding models· 85
Overlay traffic characteristics· 85
Forwarding models· 86
Testing network convergence upon single points of failure· 94
Verifying the configuration· 94
Verification commands· 94
Procedure· 95
Upgrading the devices· 97
Upgrading the leaf devices· 97
Upgrading the spine devices· 97
Upgrading the border devices· 98
Expanding the network· 99
Adding a leaf device· 99
Replacing hardware· 100
Replacing a service module· 100
Replacing a switching fabric module· 100
As shown in Figure 1:
·     Deploy a DR system at the border tier, and deploy two DR systems at the leaf tier. Configure the DR systems as follows:
¡     Configure Ethernet aggregate links as IPLs.
¡     Set up one border DR system with two S12500X-AF or S12500G-AF switches. Configure SDN gateways on the border DR system to forward traffic between the data center and external network, and between PODs.
¡     Set up one leaf DR system with two S6800 or S6812 switches. Configure them as SDN ToR switches and distributed EVPN gateways for network overlay.
¡     Set up another leaf DR system with two S6850 switches. Configure them as SDN ToR switches and distributed EVPN gateways for network overlay.
·     Configure two S12500X-AF or S12500G-AF switches as spine devices. Configure them as route reflectors to reflect BGP EVPN routes among border and leaf devices.
·     Configure the firewalls as follows:
¡     Configure them to operate in primary/secondary mode.
¡     Attach the firewalls to the border DR system by using four aggregation links of DR groups.
¡     Assign the firewalls to the same VLAN as the border DR system.
·     Configure static routes on the border DR system to direct the following traffic to the firewall for security policy-based filtering or NAT:
¡     South-to-north traffic sent from the bare metal servers and VMs to the external network.
¡     Inter-VPC east-west traffic sent between the bare metal servers and VMs.
·     Configure the C-spine device to provide access to other data centers and forward Layer 3 traffic on the underlay network.
·     Configure the public device to provide access to the external network.
This example uses IS-IS as the underlay routing protocol. Alternatively, you can use OSPF or other protocols for routing on the underlay network.
Figure 1 Network diagram
Device
IP address
Remarks
Leaf 1
XGE1/0/21
N/A
Member port of an underlay DR interface.
Connected to a virtualization server.
XGE1/0/47
N/A
Member port of a DR interface, interface with ACs configured.
Connected to a bare metal server.
FGE1/0/53
N/A
Member port of the IPP.
Connected to FGE1/0/53 on Leaf 2.
FGE1/0/54
N/A
Connected to FGE1/0/54 on Leaf 2.
FGE1/0/51
6.1.1.1/30
Connected to FGE3/0/16 on Spine 1.
FGE1/0/49
6.1.1.5/30
Connected to FGE3/0/4 on Spine 2.
Loopback0
5.1.1.1/32
VTEP IP address.
Loopback1
5.1.1.101/32
Virtual VTEP IP address.
Vlan-interface2
10.10.10.3/24
VRRP virtual IP: 10.10.10.254
The VRRP virtual IP address is the gateway address for virtualization servers.
Vlan-interface10
10.1.1.1/24
Peer link.
Leaf 2
XGE1/0/21
N/A
XGE1/0/47
N/A
FGE1/0/53
N/A
Connected to FGE1/0/53 on Leaf 1.
FGE1/0/54
N/A
Connected to FGE1/0/54 on Leaf 1.
FGE1/0/51
6.1.1.9/30
Connected to FGE3/0/13 on Spine 1.
FGE1/0/49
6.1.1.13/30
Connected to FGE3/0/1 on Spine 2.
LoopBack0
5.1.1.2/32
VTEP IP address.
LoopBack1
5.1.1.101/32
Vlan-interface2
10.10.10.4/24
Vlan-interface10
10.1.1.2/24
Peer link.
Leaf 3
WGE1/0/21
N/A
WGE1/0/55
N/A
HGE1/0/31
N/A
Connected to HGE1/0/31 on Leaf 4.
HGE1/0/32
N/A
Connected to HGE1/0/32 on Leaf 4.
HGE1/0/29
6.1.1.17/30
Connected to HGE2/0/3 on Spine 1.
HGE1/0/25
6.1.1.29/30
Connected to HGE2/0/12 on Spine 2.
LoopBack0
5.1.1.3/32
VTEP IP address.
LoopBack1
5.1.1.102/32
Vlan-interface2
50.50.50.2/24
VRRP virtual IP: 50.50.50.254
Vlan-interface10
10.2.1.1/24
Peer link.
Leaf 4
WGE1/0/21
N/A
WGE1/0/55
N/A
HGE1/0/31
N/A
Connected to HGE1/0/31 on Leaf 3.
HGE1/0/32
N/A
Connected to HGE1/0/32 on Leaf 3.
HGE1/0/29
6.1.1.25/30
Connected to HGE2/0/1 on Spine 1.
HGE1/0/25
6.1.1.21/30
Connected to HGE2/0/11 on Spine 2.
LoopBack0
5.1.1.4/32
VTEP IP address.
LoopBack1
5.1.1.102/32
Vlan-interface2
50.50.50.3/24
Vlan-interface10
10.2.1.2/24
Peer link.
Spine 1
FGE3/0/16
6.1.1.2/30
Connected to FGE1/0/51 on Leaf 1.
FGE3/0/13
6.1.1.10/30
Connected to FGE1/0/51 on Leaf 2.
HGE2/0/3
6.1.1.18/30
Connected to HGE1/0/29 on Leaf 3.
HGE2/0/1
6.1.1.26/30
Connected to HGE1/0/29 on Leaf 4.
HGE2/0/5
6.1.1.33/30
Connected to HGE3/0/16 on Border 1.
HGE2/0/7
6.1.1.37/30
Connected to HGE2/0/13 on Border 2.
LoopBack0
5.1.1.6/32
N/A
Spine 2
FGE3/0/4
6.1.1.6/30
Connected to FGE1/0/49 on Leaf 1.
FGE3/0/1
6.1.1.14/30
Connected to FGE1/0/49 on Leaf 2.
HGE2/0/12
6.1.1.30/30
Connected to HGE1/0/25 on Leaf 3.
HGE2/0/11
6.1.1.22/30
Connected to HGE1/0/25 on Leaf 4.
HGE2/0/9
6.1.1.41/30
Connected to HGE2/0/12 on Border 1.
HGE2/0/10
6.1.1.45/30
Connected to HGE2/0/1 on Border 2.
LoopBack0
5.1.1.8/32
N/A
Border 1
HGE1/0/16
6.1.1.34/30
Connected to HGE2/0/5 on Spine 1.
HGE1/0/12
6.1.1.42/30
Connected to HGE2/0/9 on Spine 2.
HGE2/0/21
N/A
Connected to HGE2/0/7 on Border 2.
HGE3/0/36
N/A
Connected to HGE3/0/36 on Border 2.
HGE2/0/5
5.58.1.1/30
Connected to the C-spine device.
FGE3/0/24
N/A
Member port of a DR interface.
Connected to the public device.
HGE2/0/27
N/A
Upstream traffic forwarding to the firewalls.
HGE2/0/11
N/A
Downstream traffic forwarding to the firewalls.
LoopBack0
5.1.1.7/32
ED IP address.
LoopBack100
100.100.100.100/32
Virtual ED IP address.
Vlan-interface1000
100.1.1.1/24
Peer link.
Border 2
HGE1/0/13
6.1.1.38/30
Connected to HGE2/0/7 on Spine 1.
HGE1/0/1
6.1.1.46/30
Connected to HGE2/0/10 on Spine 2.
HGE2/0/7
N/A
Connected to HGE2/0/21 on Border 1.
HGE3/0/36
N/A
HGE2/0/5
5.58.1.5/30
FGE3/0/24
N/A
HGE2/0/27
N/A
HGE2/0/29
N/A
LoopBack0
5.1.1.9/32
ED IP address.
LoopBack100
100.100.100.100/32
Vlan-interface1000
100.1.1.2/24
Peer link.
A VM is in a host overlay network, and a bare metal host is called a BM in network overlay. The following traffic forwarding models are available:
·     Intra-VPC forwarding in the same POD (leaf > spine > leaf):
¡     VM-to-VM and VM-to-BM Layer 2 and Layer 3 communication through the same DR system at the leaf tier.
¡     BM-to-VM and BM-to-BM Layer 2 and Layer 3 communication through the same DR system at the leaf tier.
¡     VM-to-VM and VM-to-BM Layer 2 and Layer 3 communication across DR systems at the leaf tier.
¡     BM-to-VM and BM-to-BM Layer 2 and Layer 3 communication across DR systems at the leaf tier.
·     Inter-VPC forwarding in the same POD (leaf > spine > border > firewall > border > spine > leaf):
¡     VM-to-VM and VM-to-BM Layer 3 communication through the same DR system at the leaf tier.
¡     BM-to-VM and BM-to-BM Layer 3 communication through the same DR system at the leaf tier.
¡     VM-to-VM and VM-to-BM Layer 3 communication across DR systems at the leaf tier.
¡     BM-to-VM and BM-to-BM Layer 3 communication across DR systems at the leaf tier.
·     Inter-POD forwarding (leaf > spine > border > C-spine > border > spine > leaf):
¡     VM-remote host and BM-remote host Layer 2 communication across PODs.
¡     VM-remote host and BM-remote host Layer 3 communication across PODs.
·     Forwarding between the data center and the external network (leaf > spine > border > firewall > border > public device):
¡     Layer 3 communication between BMs and the external network.
¡     Layer 3 communication between VMs and the external network.
¡     SSH, FTP, and fping operations from the external network to the data center (leaf > spine > border > LB > border > public device).
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Role
Device
Software version
Border or spine
S12500X-AF
S12500X-AF switches are used in this example.
F2809 and higher F28xx versions
S12500G-AF
R7624P12
Leaf
S6800, S6860
S6800 switches are used in this configuration example.
F2715 and higher F27xx versions
Do not use F28xx versions.
S6812, S6813
S6812 switches are used in this configuration example.
Under development. To obtain the latest images, contact Technical Support.
S6805, S6825, S6850, and S9850
S6850 switches are used in this configuration example.
F6632 and higher F66xx versions
S6890
S9820-64H (EVPN gateway not supported)
S9820-8C
Not supported
SDN controller
N/A
SeerEngine-DC E3610 or higher versions
Before you use a higher version than E3610, contact H3C support to verify version compatibility.
Procedure summary
·     Configuring the resource mode (only on S6800 switches)
·     Creating VRRP groups
·     Configuring IS-IS
·     Configuring the links towards the spine tier
·     Configuring L2VPN
·     Configuring DRNI
·     Configuring the links towards the virtualization servers
·     Configuring the links towards the bare metal servers
·     Configuring spanning tree
·     Configuring a BGP instance
·     Configuring the overlay network
Leaf 1
Leaf 2
Configuration method
Purpose
Remarks
hardware-resource switch-mode 4
Manual
Set the hardware resource mode for the MAC address table, ARP/ND table, and routing tables.
Adjust the capacities of the MAC address table, ARP/ND table, and routing tables.
Reboot the device for this setting to take effect.
hardware-resource routing-mode ipv6-128
Manual
Enable support for IPv6 routes with prefixes longer than 64 bits.
N/A
hardware-resource vxlan l3gw40k
Manual
Set the VXLAN hardware resource mode to Layer 3 gateway mode that supports 40 K of overlay adjacency table
N/A
openflow flow-table ipv6-enhanced
Manual
Enable support for bidirectional security groups.
N/A
N/A
openflow permit-flag ignore
Manual
Ignore the permit flag added by OpenFlow.
Enable support for bidirectional security groups and port rate limiting.
N/A
Leaf 1
Leaf 2
Purpose
Remarks
vlan 2
vlan 2
Manual
Configure the VLAN used to communicate with a virtualization server.
The switch is an underlay device to a virtualization server.
N/A
interface Vlan-interface 2
Manual
Create a VLAN interface.
N/A
N/A
ip address 10.10.10.3 255.255.255.0
ip address 10.10.10.4 255.255.255.0
Manual
Assign an IP address to the interface.
N/A
N/A
vrrp vrid 1 virtual-ip 10.10.10.254
Manual
Configure the virtual IP address of a VRRP group.
N/A
N/A
vrrp vrid 1 priority 100
vrrp vrid 1 priority 101
Manual
Configure the priority of the device in the VRRP group.
VRRP determines the role (master or backup) of each router in a VRRP group by priority. A router with higher priority is more likely to become the master.
The larger the priority value, the higher the priority.
undo vrrp vrid 1 preempt-mode
Manual
Configure the device to work in non-preemptive mode in the VRRP group.
Ensure consistency between the VRRP role and DR role.
This command is optional. Inconsistency between the VRRP role and DR role does not affect traffic forwarding.
Manual
N/A
N/A
N/A
ip prefix-list 1 index 10 permit 10.10.10.0 24
Manual
Configure an IPv4 prefix list or an item for the list.
Create an IPv4 prefix list for the virtual IP address of the VRRP group.
N/A
route-policy 1 permit node 0
Manual
Configure a routing policy.
Create the routing policy used in IS-IS IPv4 unicast address family view.
N/A
if-match ip address prefix-list 1
Manual
Match IPv4 routes with an IPv4 prefix list.
N/A
N/A
Manual
Exit routing policy view.
N/A
N/A
Configuring IS-IS
Leaf 1
Leaf 2
Purpose
Remarks
router id 5.1.1.1
router id 5.1.1.2
Manual
Configure the IP address of Loopback 0 as the router ID.
Configure the global router ID.
N/A
isis 1
isis 1
Manual
Enter IS-IS view.
N/A
N/A
is-level level-2
is-level level-2
Manual
Specify the IS level.
If the only area is an IP network, configure all the routers as Level-2 for scalability.
N/A
cost-style wide
cost-style wide
Manual
Set the cost style to wide.
Enable the device to receive wide cost style packets.
N/A
timer spf 1 10 10
timer spf 1 10 10
Manual
Set the maximum SPF calculation interval to 1 second, minimum SPF calculation interval to 10 milliseconds, and incremental SPF calculation interval to 10 milliseconds.
Reduce the interval between two SPF calculations and speed up convergence.
N/A
timer lsp-max-age 65535
Manual
Set the LSP maximum age in the LSDB to 65535 seconds.
A large LSP maximum age reduces LSP floods. Any LSP with an age of 0 is deleted from the LSDB.
N/A
timer lsp-refresh 65000
Manual
Set the LSP refresh interval to 65000 seconds.
A large refresh interval reduces LSP refreshes and saves bandwidth.
N/A
timer lsp-generation 1 10 10
Manual
Set the maximum interval to 1 second, minimum interval to 10 milliseconds, and incremental interval to 10 milliseconds for LSP generation.
Speed up LSP generation and routing convergence upon network topology changes.
N/A
set-overload on-startup 360
Manual
Set the overload bit for 360 seconds upon system startup.
Delay VRRP address advertisement after system startup to reduce traffic loss during fallback.
N/A
network-entity 51.0000.0005.0001.00
network-entity 51.0000.0005.0002.00
Manual
Configure the NET for an IS-IS process.
N/A
N/A
address-family ipv4 unicast
Manual
Enter IS-IS IPv4 address family view.
N/A
N/A
fast-reroute lfa
fast-reroute lfa
Manual
Configure IS-IS FRR.
Enable IS-IS to calculate backup next hops for all Level-2 routes to reduce traffic interruption upon link or device failure.
N/A
import-route direct route-policy 1
Manual
Redistribute direct VRRP routes.
Use this command together with the set-overload command to delay VRRP route advertisement after system startup to optimize route convergence upon fallback.
N/A
Manual
Exit address family view.
N/A
N/A
Manual
Exit IS-IS view.
N/A
N/A
interface LoopBack0
interface LoopBack0
Manual
Create Loopback 0 and enter its view.
N/A
N/A
ip address 5.1.1.1 255.255.255.255
ip address 5.1.1.2 255.255.255.255
Manual
Configure the VTEP IP address.
N/A
isis enable 1
isis enable 1
Manual
Enable IS-IS on the interface.
N/A
N/A
isis circuit-level level-2
Manual
Set the circuit level for the interface to Level-2.
N/A
For the Level-2 device, the circuit level can only be Level-2.
Manual
Exit the view of Loopback 0.
N/A
N/A
interface LoopBack1
interface LoopBack1
Manual
Create Loopback 1 and enter its view.
N/A
N/A
ip address 5.1.1.101 255.255.255.255
Manual
Configure the virtual VTEP IP address.
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
Exit the view of Loopback 1.
N/A
N/A
vlan 10
vlan 10
Manual
Create a VLAN.
Create the VLAN for communicating with the DR peer.
N/A
interface Vlan-interface10
Manual
Create VLAN-interface 10.
Create the VLAN interface for the VLAN used for communicating with the DR peer. When the uplink interface fails, the device forwards the packets received on the DR interfaces to the DR peer for Layer 3 forwarding.
N/A
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
isis circuit-type p2p
Manual
Set the network type of the interface to P2P.
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P to avoid DIS election and CSNP flooding. This saves network bandwidth and speeds up network convergence.
N/A
isis peer hold-max-cost duration 20000
Manual
Enable IS-IS to advertise the maximum link cost to neighbors within 20000 milliseconds.
N/A
Execute this command at both ends of a link.
Manual
Exit the view of VLAN-interface 10.
N/A
N/A
On an IS-IS network, when a link recovers from failures or the state of an interface changes, IS-IS will re-establish neighbor relationships and perform route convergence. During the route convergence process, routing loops and traffic loss might occur because the convergence speeds of the nodes are different. To address this issue, enable IS-IS to advertise the maximum link cost to neighbors within the specified period, so the traffic forwarding path remains unchanged. After the specified period, IS-IS advertises the original link cost to neighbors and performs optimal route selection again.
Leaf 1
Leaf 2
Purpose
Remarks
interface FortyGigE1/0/49
interface FortyGigE 1/0/49
Manual
Configure the interface connected to Spine 2.
N/A
N/A
port link-mode route
Manual
Configure the Ethernet interface to work in Layer 3 mode.
N/A
N/A
ip address 6.1.1.5 255.255.255.252
ip address 6.1.1.13 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
undo mac-address static source-check enable
Manual
Disable static source check.
To correctly forward traffic sourced from the MAC address of a VLAN interface, you must disable the static source check feature on the Layer 2 interfaces in the VLAN.
N/A
interface FortyGigE1/0/51
interface FortyGigE 1/0/51
Manual
Configure the interface connected to Spine 1.
N/A
N/A
Manual
N/A
N/A
ip address 6.1.1.1 255.255.255.252
ip address 6.1.1.9 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Manual
N/A
Configuring L2VPN
Leaf 1
Leaf 2
Purpose
Remarks
l2vpn enable
l2vpn enable
Manual
Enable L2VPN.
N/A
N/A
l2vpn statistics interval 30
Manual
Set the interval for collecting L2VPN statistics to 30 seconds.
Configure this setting according to the gRPC report interval.
N/A
vxlan default-decapsulation source interface LoopBack0
Manual
Enable default VXLAN decapsulation on the packets destined for the VTEP IP address.
N/A
This command takes effect only when the specified interface has an IP address.
Manual
Disable remote-MAC address learning.
Execute this command if a controller issues forwarding entries to the device.
N/A
vxlan tunnel arp-learning disable
Manual
Disable remote ARP learning.
N/A
vxlan tunnel nd-learning disable
Manual
Disable remote ND learning.
N/A
mac-address timer aging 3600
Manual
Set the aging time to 3600 seconds for dynamic MAC address entries.
Increase this timer to ensure forwarding entry synchronization is finished in time after the DR peer restarts.
This setting must be consistent on the DR member devices in the same DR system.
mac-address mac-move fast-update
Manual
Enable ARP fast update for MAC address moves.
Use this command together with gRPC.
N/A
arp timer aging 1440
Manual
Set the aging timer for dynamic ARP entries to 1440 minutes.
ipv6 neighbor stale-aging 1440
Manual
Set the aging timer for ND entries in stale state to 1440 minutes.
If you use two border devices to set up a DR system and BMs in bond1 mode need to communicate with the external network, unidirectional tunnels exist between the ToR switches and SDN gateway.  Typically, unidirectional tunnels are set up when a ToR switch is disconnected from the controller or new BMs come online. In this scenario, an online ToR switch advertises routes that contain its real IP address. The SDN will set up a tunnel to that real IP address, while the ToR switch uses the virtual VTEP IP address for tunnel setup. For the ToR switches to decapsulate the packets sent by the SDN gateway, enable default VXLAN decapsulation on the ToR switches.
Configuring DRNI
Leaf 1
Leaf 2
Purpose
Remarks
ip vpn-instance management
Manual
Create a VPN for the management Ethernet interface.
N/A
interface M-GigabitEthernet0/0/0
Manual
Enter the view of the management Ethernet interface.
N/A
N/A
ip binding vpn-instance management
Manual
Assign the management Ethernet interface to the VPN.
N/A
Assign the management Ethernet interface to a VPN as needed.
ip address 192.1.2.66 255.255.255.0
ip address 192.1.2.67 255.255.255.0
Manual
Configure a management IP address.
N/A
N/A
Manual
Exit the view of the management Ethernet interface.
N/A
N/A
l2vpn drni peer-link ac-match-rule vxlan-mapping
Manual
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link IPL.
N/A
N/A
evpn drni group 5.1.1.101
Manual
Enable EVPN distributed relay and specify the virtual VTEP address.
N/A
You must specify the same virtual VTEP address on both VTEPs in the same DR system.
evpn drni local 5.1.1.1 remote 5.1.1.2
evpn drni local 5.1.1.2 remote 5.1.1.1
Manual
Specify the IP addresses of the VTEPs in a DR system.
After you configure this command, each VTEP in a DR system changes the next hop of the routes for single-armed ACs to its local VTEP IP address when advertising the routes. This ensures that the traffic of a single-armed AC is forwarded to its attached VTEP.
When you execute this command, make sure the IP address of the local VTEP belongs to a local interface. Make sure the local VTEP IP address and peer VTEP IP address are reversed on the VTEPs in a DR system.
evpn global-mac 00e0-fc00-580a
Manual
Configure the EVPN global MAC address.
N/A
You must specify the same EVPN global MAC address on the devices in the same DR system.
Do not use a reserved MAC address as the EVPN global MAC address.
drni system-mac 00e0-fc00-5800
Manual
Configure the DR system MAC address.
Configure the settings required for establishing the DR system.
The DR system MAC address uniquely identifies the DR system on the network. For the DR member devices to be identified as one DR system, you must configure the same DR system MAC address on them.
drni system-number 1
drni system-number 2
Manual
Set the DR system number.
You must assign different DR system numbers to the DR member devices in a DR system.
drni system-priority 123
Manual
Set the DR system priority.
N/A
You must configure the same DR system priority for the DR member devices in a DR system.
The default DR system priority is 32768. The smaller the priority value, the higher the priority.
drni keepalive ip destination 192.1.2.67 source 192.1.2.66 vpn-instance management
drni keepalive ip destination 192.1.2.66 source 192.1.2.67 vpn-instance management
Manual
Configure DR keepalive packet parameters.
Use the management Ethernet interface to set up the keepalive link. This interface is excluded from the DRNI MAD DOWN action.
You do not need to specify a VPN instance if the interface does not belong to any VPN instance.
If the interface that owns the source IP address is not excluded from the DRNI MAD DOWN action, exclude it from that action.
drni mad default-action none
Manual
Set the default DRNI MAD action to NONE.
N/A
N/A
drni mad include interface FortyGigE1/0/49
drni mad include interface FortyGigE 1/0/49
Manual
Enable DRNI to shut down an interface when the DR system splits.
Shut down the interface upon a DR system split to reduce the fallback duration after a device restart.
Execute this command on the uplink interface attached to a spine device.
drni mad include interface FortyGigE1/0/51
drni mad include interface FortyGigE 1/0/51
Manual
drni restore-delay 300
Manual
Set the data restoration interval.
Ensure that entry synchronization is finished before interfaces are brought up.
N/A
interface Bridge-Aggregation1
Manual
Create Bridge-Aggregation 1 which will be the IPP.
N/A
N/A
port link-type trunk
Manual
Set the link type of the interface to trunk.
N/A
N/A
port trunk permit vlan all
Manual
Configure the trunk interface to permit all VLANs.
N/A
N/A
link-aggregation mode dynamic
Manual
Configure the aggregate interface to operate in dynamic mode and enable LACP.
N/A
N/A
port drni intra-portal-port 1
Manual
Configure the interface as the IPP.
N/A
N/A
Manual
You do not need to execute this command on S12500X-AF switches.
Disable static source check on the IPP and the uplink interfaces attached to spine devices.
interface FortyGigE1/0/53
Manual
Configure the interface as a member port of the IPP.
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
port link-aggregation group 1
Manual
Assign the interface to link aggregation group 1.
N/A
N/A
interface FortyGigE1/0/54
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
N/A
By default, if a DR system uses an Ethernet aggregate link as the IPL, each DR member device creates a dynamic AC on the IPL when an AC is configured on a site-facing interface. The dynamic AC and the site-facing AC have the same frame match criteria and VSI mapping. If two site-facing ACs on different interfaces have the same frame match criteria but different VSI mappings, the dynamic ACs created for the site-facing ACs will conflict with each other. To prevent this issue, enable the DR member devices to create frame match criteria based on VXLAN IDs for the dynamic ACs on the IPL.
If you use a VXLAN tunnel as the IPL in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. To reduce configuration steps, set the default DRNI MAD action to NONE and execute the drni mad include interface command to specify interfaces that must be shut down by DRNI MAD in addition to those already automatically specified by the system.
Leaf 1
Leaf 2
Purpose
Remarks
interface Bridge-Aggregation101
Manual
Create an aggregate interface to be configured as a DR interface.
Create the interface to connect to the host overlay servers.
N/A
port access vlan 2
port access vlan 2
Manual
Configure the interface as an access interface and assign it to VLAN 2.
Assign the interface to the VLAN of the VRRP group.
N/A
Manual
N/A
N/A
port drni group 101
port drni group 101
Manual
Assign the interface to a DR group.
N/A
N/A
interface Ten-GigabitEthernet1/0/21
interface Ten-GigabitEthernet 1/0/21
Manual
Enter the view of a member port to be assigned to the DR interface.
N/A
N/A
port access vlan 2
port access vlan 2
Manual
N/A
port link-aggregation group 101
Manual
Assign the interface to the aggregation group of the DR interface.
N/A
N/A
Manual
Exit the current view.
N/A
N/A
Leaf 1
Leaf 2
Purpose
Remarks
interface Bridge-Aggregation1024
Manual
Create the aggregate interface to connect to the bare metal servers.
N/A
Manual
N/A
N/A
Manual
N/A
port drni group 1024
Manual
Assign the aggregate interface to a DR group.
N/A
N/A
interface Ten-GigabitEthernet1/0/47
interface Ten-GigabitEthernet 1/0/47
Manual
N/A
N/A
Manual
N/A
N/A
port link-aggregation group 1024
Manual
N/A
N/A
Manual
N/A
N/A
Leaf 1
Leaf 2
Purpose
stp global enable
stp global enable
Manual
Enable spanning tree globally.
N/A
Manual
Enter the view of the DR interface connected to the virtualization servers.
N/A
stp edged-port
stp edged-port
Manual
Configure the interface as an edge port.
Exclude the interface from spanning tree calculation.
interface Bridge-Aggregation 1024
Manual
Enter the view of the DR interface connected to the bare metal servers.
N/A
stp edged-port
stp edged-port
Manual
Make sure the DR member devices have the same spanning tree configuration, including:
·     Global spanning tree configuration.
·     Spanning tree configuration on the IPP.
·     Spanning tree configuration on DR interfaces.
Violation of this rule might cause network flapping. IPPs in the DR system do not participate in spanning tree calculation.
The DR member devices still use the DR system MAC address after the DR system splits, which will cause spanning tree calculation issues. To avoid the issues, enable DRNI standalone mode on the DR member devices before the DR system splits.
Leaf 1
Leaf 2
Purpose
Remarks
bgp 400
bgp 400
Manual
Enable a BGP instance.
N/A
N/A
bgp update-delay on-startup 40
Manual
Configure BGP to delay sending route updates on reboot.
Avoid forwarding issues during fallback after a ToR switch restarts.
N/A
router-id 5.1.1.1
router-id 5.1.1.2
Manual
Configure a router ID for the BGP instance.
To run BGP in a BGP instance, you must configure a router ID for the BGP instance.
If you do not configure a router ID for the BGP instance, it uses the global router ID.
N/A
group evpn internal
group evpn internal
Manual
Create an IBGP peer group.
N/A
N/A
peer evpn connect-interface LoopBack0
Manual
Specify a source interface for establishing TCP links towards the peer group.
N/A
N/A
peer evpn route-update-interval 0
Manual
Specify an interval for sending the same update to the peer group.
Enable the device to fast send update to the peer group upon route changes to speed up route convergence after a DR primary/secondary switchover occurs.
Execute this command only for IBGP peers.
peer 5.1.1.6 group evpn
Manual
Add a spine device to the peer group.
N/A
N/A
peer 5.1.1.8 group evpn
Manual
N/A
N/A
address-family l2vpn evpn
Manual
Enter L2VPN EVPN address family view.
N/A
N/A
peer evpn enable
peer evpn enable
Manual
Enable the device to exchange routes with the peer group.
N/A
N/A
Manual
Exit L2VPN EVPN address family view.
N/A
N/A
Leaf 1
Leaf 2
Remarks
ip vpn-instance admin_route1_50034
Controller-based
Create a VPN instance on the private network.
N/A
route-distinguisher 1:50034
Controller-based
Configure the RD of the VPN instance.
N/A
address-family ipv4
address-family ipv4
Controller-based
Enter IPv4 address family view of the VPN instance.
N/A
vpn-target 0:50034 1:50034 import-extcommunity
Controller-based
Configure import targets for the VPN instance.
N/A
vpn-target 1:50034 export-extcommunity
Controller-based
Configure export targets for the VPN instance.
N/A
address-family ipv6
address-family ipv6
Controller-based
Enter IPv6 address family view of the VPN instance.
N/A
Controller-based
N/A
Controller-based
N/A
address-family evpn
address-family evpn
Controller-based
Enter EVPN view of the VPN instance.
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
interface Vsi-interface22000
Controller-based
Create a VSI interface and enter its view.
N/A
mtu 1450
mtu 1450
Controller-based
Configure the MTU of the VSI interface.
N/A
ip binding vpn-instance admin_route1_50034
Controller-based
Associate the VSI interface with the VPN instance.
N/A
ip address 121.1.0.1 255.255.0.0 sub
Controller-based
Assign an IPv4 address as a gateway address to the VSI interface.
Make sure the VSI interface has the same setting for this command on all distributed gateways.
mac-address 542b-de0c-02c9
Controller-based
Assign a MAC address to the VSI interface.
ipv6 nd ra prefix 121:1::/64 no-advertise
Controller-based
Disable the device from advertising the prefix of the IPv6 gateway through RA messages.
ipv6 address 121:1::1/64
Controller-based
Assign an IPv6 address as a gateway address to the VSI interface.
distributed-gateway local
Controller-based
Specify the VSI interface as a distributed gateway to provide services for the local site.
N/A
Controller-based
N/A
interface Vsi-interface 22001
Controller-based
N/A
mtu 1450
mtu 1450
Controller-based
N/A
Controller-based
Associate the VSI interface with a VPN instance.
N/A
ip address 121.2.0.1 255.255.0.0 sub
Controller-based
Controller-based
ipv6 nd ra prefix 121:2::/64 no-advertise
Controller-based
ipv6 address 121:2::1/64
Controller-based
Controller-based
N/A
Controller-based
N/A
interface Vsi-interface50034
Controller-based
N/A
Controller-based
N/A
ipv6 address auto link-local
Controller-based
Automatically generate a link-local address for the VSI interface.
N/A
l3-vni 50034
l3-vni 50034
Controller-based
Assign an L3VNI to the VSI interface.
The L3VNI is shared among the VSI interfaces associated with the same VPN instance.
Controller-based
N/A
vsi SDN_VSI_22000
vsi SDN_VSI_22000
Controller-based
Create a VSI and enter its view.
N/A
gateway vsi-interface 22000
Controller-based
Specify a gateway interface for the VSI.
N/A
arp suppression enable
Controller-based
Enable ARP flood suppression.
N/A
ipv6 nd suppression enable
Controller-based
Enable ND flood suppression.
N/A
flooding disable all
Controller-based
Disable flooding of local broadcast, unknown unicast, and unknown multicast traffic.
N/A
vxlan 22000
vxlan 22000
Controller-based
Create a VXLAN and enter its view.
N/A
evpn encapsulation vxlan
Controller-based
Create an EVPN instance and enter its view.
N/A
route-distinguisher auto
Controller-based
Configure the RD of the EVPN instance.
N/A
vpn-target auto
vpn-target auto
Controller-based
Configure import and export targets for EVPN.
N/A
Controller-based
N/A
vsi SDN_VSI_22001
vsi SDN_VSI_22001
Controller-based
N/A
gateway vsi-interface 22001
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vxlan 22001
vxlan 22001
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vpn-target auto
vpn-target auto
Controller-based
Configure export targets for EVPN.
N/A
Controller-based
N/A
vlan 21 to 22
vlan 21 to 22
Controller-based
Create VLANs.
N/A
Controller-based
Enter the view of the interface to be configured with ACs.
N/A
Controller-based
N/A
undo port trunk permit vlan 1
Controller-based
Remove the trunk interface from VLAN 1.
N/A
port trunk permit vlan 21 to 22
Controller-based
Assign the trunk interface to VLAN 21 and VLAN 22.
N/A
Controller-based
N/A
Controller-based
N/A
service-instance 21
service-instance 21
Controller-based
Create an Ethernet service instance and enter its view.
N/A
encapsulation s-vid 21
Controller-based
Configure the Ethernet service instance to match traffic by the outer VLAN ID.
N/A
xconnect vsi SDN_VSI_22000
Controller-based
Map the Ethernet service instance to the VSI created previously.
N/A
service-instance 22
service-instance 22
Controller-based
N/A
encapsulation s-vid 22
Controller-based
N/A
xconnect vsi SDN_VSI_22001
Controller-based
N/A
Controller-based
N/A
Procedure summary
·     Configuring IS-IS
·     Configuring L2VPN
·     Configuring DRNI
Leaf 3
Leaf 4
Purpose
Remarks
hardware-resource switch-mode DUAL-STACK
Manual
Set the hardware resource mode to DUAL-STACK for the MAC address table, ARP/ND table, and routing tables
Manual
N/A
Manual
N/A
Manual
N/A
Leaf 3
Leaf 4
Purpose
vlan 2
vlan 2
Manual
Manual
N/A
ip address 50.50.50.2 255.255.255.0
ip address 50.50.50.3 255.255.255.0
Manual
N/A
vrrp vrid 2 virtual-ip 50.50.50.254
Manual
N/A
vrrp vrid 2 priority 100
vrrp vrid 2 priority 101
Manual
undo vrrp vrid 2 preempt-mode
Manual
Ensure consistency between the VRRP role and DR role. This command is optional. Inconsistency between the VRRP role and DR role does not affect traffic forwarding.
Manual
N/A
ip prefix-list 1 index 10 permit 50.50.50.0 24
Manual
Manual
Manual
N/A
Manual
N/A
Configuring IS-IS
Leaf 3
Leaf 4
Purpose
Remarks
router id 5.1.1.3
router id 5.1.1.4
Manual
N/A
isis 1
isis 1
Manual
Enter IS-IS view.
N/A
is-level level-2
is-level level-2
Manual
N/A
cost-style wide
cost-style wide
Manual
N/A
timer spf 1 10 10
timer spf 1 10 10
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
network-entity 51.0000.0005.0003.00
network-entity 51.0000.0005.0004.00
Manual
N/A
N/A
Manual
N/A
N/A
fast-reroute lfa
fast-reroute lfa
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Manual
Exit IS-IS view.
N/A
N/A
interface LoopBack0
interface LoopBack0
Manual
N/A
N/A
ip address 5.1.1.3 255.255.255.255
ip address 5.1.1.4 255.255.255.255
Manual
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
N/A
interface LoopBack1
interface LoopBack1
Manual
N/A
N/A
ip address 5.1.1.102 255.255.255.255
Manual
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
N/A
vlan 10
vlan 10
Manual
Create a VLAN.
N/A
Manual
N/A
ip address 10.2.1.1 255.255.255.0
ip address 10.2.1.2 255.255.255.0
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Leaf 3
Leaf 4
Purpose
Remarks
interface HundredGigE1/0/25
Manual
N/A
N/A
Manual
N/A
N/A
ip address 6.1.1.29 255.255.255.252
ip address 6.1.1.21 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
interface HundredGigE1/0/29
Manual
N/A
N/A
Manual
N/A
N/A
ip address 6.1.1.17 255.255.255.252
ip address 6.1.1.25 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Manual
Disable static source check on the interface connected to Spine 2.
N/A
Configuring L2VPN
Leaf 3
Leaf 4
Purpose
Remarks
l2vpn enable
l2vpn enable
Manual
Enable L2VPN.
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
Manual
N/A
Manual
Manual
Configuring DRNI
Leaf 3
Leaf 4
Purpose
Remarks
Manual
N/A
Manual
N/A
N/A
Manual
N/A
ip address 192.1.2.68 255.255.255.0
ip address 192.1.2.69 255.255.255.0
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
evpn drni group 5.1.1.102
Manual
N/A
evpn drni local 5.1.1.3 remote 5.1.1.4
evpn drni local 5.1.1.4 remote 5.1.1.3
Manual
evpn global-mac 90e7-1060-2fe0
Manual
N/A
drni system-mac 90e7-1060-2faf
Manual
Manual
Manual
N/A
drni keepalive ip destination 192.1.2.69 source 192.1.2.68 vpn-instance management
drni keepalive ip destination 192.1.2.68 source 192.1.2.69 vpn-instance management
Manual
Manual
N/A
N/A
drni mad include interface  HundredGigE1/0/25
Manual
drni mad include interface HundredGigE1/0/29
Manual
Manual
N/A
Manual
N/A
N/A
Manual
Exit interface view.
N/A
N/A
interface HundredGigE1/0/31
Manual
Enter interface view.
N/A
N/A
Manual
Assign the interface to the aggregation group for the IPP.
N/A
N/A
interface HundredGigE1/0/32
Manual
N/A
N/A
Manual
N/A
N/A
Manual
Enter aggregate interface view.
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
Manual
N/A
N/A
If you use a VXLAN tunnel as the IPL in an EVPN environment, you must retain a large number of logical interfaces (for example, tunnel and loopback interfaces) in up state. You can set the default DRNI MAD action to NONE and execute the drni mad include interface command to specify interfaces that must be shut down by DRNI MAD in addition to those already automatically specified by the system.
Leaf 3
Leaf 4
Purpose
Manual
port access vlan 2
port access vlan 2
Manual
Manual
N/A
port drni group 101
port drni group 101
Manual
N/A
interface  Twenty-FiveGigE 1/0/21
interface Twenty-FiveGigE1/0/21
Manual
N/A
port access vlan 2
port access vlan 2
Manual
Manual
N/A
Manual
N/A
Leaf 3
Leaf 4
Purpose
Remarks
Manual
Connect to the bare metal servers.
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
interface Twenty-FiveGigE1/0/55
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Leaf 3
Leaf 4
Purpose
stp global enable
stp global enable
Manual
N/A
Manual
N/A
stp edged-port
stp edged-port
Manual
Manual
N/A
stp edged-port
stp edged-port
Manual
Leaf 3
Leaf 4
Purpose
bgp 400
bgp 400
Manual
N/A
Manual
router-id 5.1.1.3
router-id 5.1.1.4
Manual
To run BGP in a BGP instance, you must configure a router ID for the BGP instance. If you do not configure a router ID for the BGP instance, it uses the global router ID.
group evpn internal
group evpn internal
Manual
N/A
Manual
N/A
Manual
Manual
N/A
Manual
N/A
Manual
N/A
peer evpn enable
peer evpn enable
Manual
N/A
Manual
N/A
Manual
Exit BGP instance view.
N/A
Leaf 3
Leaf 4
Remarks
Controller-based
N/A
Controller-based
N/A
address-family ipv4
address-family ipv4
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
address-family ipv6
address-family ipv6
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
address-family evpn
address-family evpn
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
mtu 1450
mtu 1450
Controller-based
N/A
Controller-based
N/A
Controller-based
Controller-based
Controller-based
Controller-based
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
mtu 1450
mtu 1450
Controller-based
N/A
Controller-based
N/A
Controller-based
Controller-based
Controller-based
Controller-based
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
l3-vni 50034
l3-vni 50034
Controller-based
Controller-based
N/A
vsi SDN_VSI_22000
vsi SDN_VSI_22000
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vxlan 22000
vxlan 22000
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vpn-target auto
vpn-target auto
Controller-based
N/A
Controller-based
N/A
vsi SDN_VSI_22001
vsi SDN_VSI_22001
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vxlan 22001
vxlan 22001
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
vpn-target auto
vpn-target auto
Controller-based
N/A
Controller-based
N/A
vlan 21 to 22
vlan 21 to 22
Controller-based
Create VLANs.
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
service-instance 21
service-instance 21
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
service-instance 22
service-instance 22
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Procedure summary
·     Configuring basic settings
·     Configuring IS-IS
·     Configuring STP
·     Configuring L2VPN
·     Configuring DRNI
·     Configuring the DR interfaces connected to the external network
·     Configuring the DR interfaces connected to the external network firewalls
Configuring basic settings on S12500X-AF switches
Border 1
Border 2
Purpose
Remarks
vxlan ip-forwarding tagged
Manual
Enable Layer 3 forwarding for all VXLANs.
Enable VXLAN tunnels to forward VLAN tagged packets.
You must delete all VSIs, VSI interfaces, and VXLAN tunnel interfaces before you can change the forwarding mode.
routing-interface base-mac 542b-de0c-0264
routing-interface base-mac 542b-de0c-0200
Manual
Configure the base MAC address.
Configure the start MAC address of the consecutive MAC addresses that are reserved for system use.
You must configure the base MAC address prior to the subsequent settings.
Configuring basic settings on S12500G-AF switches
Border 1
Border 2
Purpose
Remarks
hardware-resource vxlan L3GW
Manual
Set the VXLAN hardware resource mode to Layer 3 gateway.
Enable the device to perform VXLAN Layer 2 and Layer 3 forwarding.
Save the configuration and reboot the device for this command to take effect.
Manual
N/A
Configuring IS-IS
Border 1
Border 2
Purpose
Remarks
vlan all
vlan all
Manual
Create a VLAN.
N/A
N/A
router id 5.1.1.7
router id 5.1.1.9
Manual
N/A
N/A
isis 1
isis 1
Manual
Enter IS-IS view.
N/A
N/A
non-stop-routing
non-stop-routing
Manual
Enable IS-IS NSR.
Avoid forwarding interruption on the DR system.
N/A
is-level level-2
is-level level-2
Manual
N/A
cost-style wide
cost-style wide
Manual
N/A
timer spf 1 500 10
timer spf 1 500 10
Manual
Set the maximum SPF calculation interval to 1 second, minimum SPF calculation interval to 500 milliseconds, and incremental SPF calculation interval to 10 milliseconds.
N/A
Manual
N/A
Manual
N/A
Manual
N/A
set-overload on-startup 770
Manual
Set the overload bit for 770 seconds upon system startup.
N/A
network-entity 51.0000.0005.0007.00
network-entity 51.0000.0005.0009.00
Manual
N/A
N/A
Manual
N/A
N/A
fast-reroute lfa
fast-reroute lfa
Manual
N/A
import-route direct
import-route direct
Manual
N/A
Manual
N/A
N/A
interface LoopBack0
interface LoopBack0
Manual
N/A
N/A
ip address 5.1.1.7 255.255.255.255
ip address 5.1.1.9 255.255.255.255
Manual
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
N/A
interface LoopBack100
Manual
Create Loopback 100 and enter its view.
N/A
N/A
ip address 100.100.100.100 255.255.255.255
Manual
Disable IS-IS on the interface for IS-IS to redistribute direct routes to speed up fallback and convergence after a border device reboots.
Manual
N/A
N/A
interface Vlan-interface 1000
Manual
Create VLAN-interface 1000.
N/A
ip address 100.1.1.1 255.255.255.0
ip address 100.1.1.2 255.255.255.0
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Configuring STP
Border 1
Border 2
stp global enable
stp global enable
Manual
Border 1
Border 2
Purpose
Remarks
interface HundredGigE1/0/16
interface HundredGigE1/0/13
Manual
N/A
N/A
Manual
N/A
N/A
ip address 6.1.1.34 255.255.255.252
ip address 6.1.1.38 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Manual
N/A
N/A
interface HundredGigE1/0/12
Manual
N/A
N/A
Manual
N/A
N/A
ip address 6.1.1.42 255.255.255.252
ip address 6.1.1.46 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Configuring L2VPN
Border 1
Border 2
Purpose
Remarks
l2vpn enable
l2vpn enable
Manual
Enable L2VPN.
N/A
N/A
Manual
N/A
l2vpn drni peer-link tunnel source 5.1.1.9 destination 5.1.1.7
l2vpn drni peer-link tunnel source 5.1.1.7 destination 5.1.1.9
Manual
Enable the device to automatically set up a VXLAN tunnel with the peer DR member device.
N/A
Execute this command only on S12500X-AF switches.
Manual
Execute this command if a controller issues forwarding entries to the device to save resources.
N/A
Manual
N/A
Manual
N/A
vxlan default-decapsulation source interface LoopBack100
Manual
N/A
N/A
mac-address timer aging 900
Manual
Set the aging time to 900 seconds for dynamic MAC address entries.
mac-address mac-learning ingress
Manual
Configure the device to learn MAC addresses at ingress.
N/A
Manual
Manual
arp forwarding-conversational-learning
Manual
Enable conversational learning for remote ARP entries.
Save forwarding entry resources.
Execute this command only when EVPN is configured.
ip forwarding-conversational-learning
Manual
Enable conversational learning for IPv4 host route FIB entries.
Execute this command only on S12500G-AF switches.
ipv6 forwarding-conversational-learning
Manual
Enable conversational learning for IPv6 host route FIB entries.
An S12500X-AF or S12500G-AF switch learns MAC addresses at egress by default. If you enable the switch to learn MAC addresses at ingress, the DR peer will send the MAC addresses entries for the firewalls to that switch once the local DR interface of the switch comes up. if the member ports of the local DR interface exit DRNI MAD DOWN state, MAC address entry changes will trigger ARP migration, and ARP entries will be moved from the IPP to the DR interface.
Configuring DRNI
Border 1
Border 2
Purpose
Remarks
Manual
N/A
interface M-GigabitEthernet0/0/1
Manual
N/A
Manual
N/A
ip address 192.1.2.74 255.255.255.0
ip address 192.1.2.100 255.255.255.0
Manual
N/A
N/A
Manual
N/A
N/A
drni restore-delay 450
Manual
N/A
drni role priority 100
drni role priority 101
Manual
Set the DR role priority of the device.
N/A
A DR member device is assigned the primary or secondary role based on its DR role priority. The lower the priority value, the higher the priority.
drni system-mac 542b-de0c-0200
Manual
N/A
Manual
N/A
drni system-priority 10000
Manual
N/A
Manual
N/A
N/A
drni keepalive ip destination 192.1.2.100 source 192.1.2.74 vpn-instance management
 drni keepalive ip destination 192.1.2.74 source 192.1.2.100 vpn-instance management
Manual
drni mad include interface HundredGigE2/0/5
Manual
Enable DRNI to shut down the interface connected to the C-spine device when the DR system splits.
N/A
N/A
drni mad include interface HundredGigE1/0/12
Manual
Enable DRNI to shut down the interface connected to a spine device when the DR system splits.
N/A
N/A
drni mad include interface HundredGigE1/0/16
drni mad include interface HundredGigE1/0/13
Manual
N/A
N/A
evpn drni group 100.100.100.100
Manual
N/A
N/A
evpn global-mac 542b-de0c-0201
Manual
N/A
Manual
N/A
N/A
Manual
N/A
N/A
interface HundredGigE2/0/21
interface HundredGigE2/0/7
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
interface HundredGigE3/0/36
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
port trunk pvid vlan 4094
Manual
Assign the interface as a trunk port to VLAN 4094.
Prevent the IPL from forwarding the VLAN traffic that erroneously matches dynamic ACs.
N/A
Manual
N/A
Border 1
Border 2
interface Bridge-Aggregation4
Manual
Create Bridge-Aggregation 4.
Manual
Configure link type as trunk.
Manual
port trunk permit vlan 4089
Manual
Configure the trunk interface to permit the VLAN of the external network.
Manual
Set the aggregation mode to dynamic.
port drni group 4
port drni group 4
Manual
Assign the interface to DR group 4.
interface HundredGigE3/0/24
Manual
Enter the view of an aggregation member port.
Manual
Manual
Manual
port link-aggregation group 4
Manual
Assign the interface to aggregation group 4.
Manual
Border 1
Border 2
Remarks
Manual
Create the aggregate interface to be assigned to DR group 10.
N/A
Manual
Configure the interface as a trunk interface.
N/A
Manual
Remove the interface from VLAN 1.
N/A
Manual
N/A
Manual
Configure the aggregate interface to operate in dynamic mode.
N/A
port drni group 10
port drni group 10
Manual
Assign the aggregate interface to DR group 10.
N/A
interface Bridge-Aggregation20
Manual
Create the aggregate interface to be assigned to DR group 20.
N/A
Manual
N/A
Manual
N/A
port trunk permit vlan 2000 to 2100
Manual
Configure the trunk interface to permit the VLANs of the tenant network.
Configure VLAN settings according to the planned configuration on the controller.
Manual
N/A
port drni group 20
port drni group 20
Manual
Assign the aggregate interface to DR group 20.
N/A
interface HundredGigE2/0/27
Manual
Enter the view of the member port in the DR group 10.
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
interface HundredGigE2/0/11
interface HundredGigE2/0/29
Manual
Enter the view of the member port in the DR group 20.
N/A
Manual
N/A
Manual
N/A
port link-aggregation group 20
Manual
N/A
Manual
N/A
Border 1
Border 2
Purpose
Remarks
route-policy 1 permit node 1
Manual
Create a routing policy.
N/A
These settings are used for direct communication with the external network upon border device failure. You can execute these commands as needed.
apply ip-address next-hop 5.1.1.7
apply ip-address next-hop 5.1.1.9
Manual
Set the next hop to the real IP address of the device.
Set up a tunnel used for communication upon border device failure.
apply local-preference 50
Manual
Set the local preference of advertised BGP routes to 50.
Optimize the route pointing to the DR peer upon border device failure.
Manual
N/A
N/A
bgp 400
bgp 400
Manual
Enable a BGP instance and enter its view.
N/A
N/A
non-stop-routing
non-stop-routing
Manual
non-stop-routing
non-stop-routing
N/A
router-id 5.1.1.7
router-id 5.1.1.9
Manual
Configure a route ID.
N/A
N/A
group evpn internal
group evpn internal
Manual
N/A
Use evpn as the name of the IBGP peer group.
Manual
N/A
N/A
Manual
group pod1 external
group pod1 external
Manual
Create an EBGP peer group.
N/A
Perform this task on EDs.
peer pod1 as-number 100
Manual
Configure the AS number of the peer group.
N/A
peer pod1 connect-interface LoopBack0
Manual
N/A
peer pod1 ebgp-max-hop 64
Manual
Enable BGP to establish an EBGP session to the indirectly connected peer group and specify the maximum hop count.
N/A
group taosheng internal
Manual
Configure a peer group used for permitting traffic to the DR peer upon border device failure.
N/A
N/A
peer taosheng connect-interface LoopBack0
Manual
Specify a source interface for establishing TCP connections to the fail-permit peer group.
N/A
N/A
peer 2.1.1.7 group pod1
Manual
Assign a peer to the peer group.
N/A
Manual
N/A
N/A
peer 5.1.1.7 group taosheng
peer 5.1.1.9 group taosheng
Manual
Assign the peer border device to the fail-permit peer group.
N/A
N/A
Manual
N/A
N/A
peer 16.16.16.16 group pod1
Manual
N/A
Manual
Create BGP EVPN address family and enter its view.
N/A
N/A
nexthop evpn-drni group-address
Manual
Set the next hop of advertised EVPN routes to the virtual VTEP address of the DR system.
Enable the device to advertise EVPN routes whose next hop is the virtual VTEP address of the DR system.
N/A
peer evpn enable
peer evpn enable
Manual
Enable the device to exchange routes with the IBGP peer group.
N/A
N/A
peer evpn next-hop-local
Manual
Set the local router as the next hop for routes sent to the IBGP peer group.
Enable the peer group to reach the local router.
N/A
peer evpn re-originated replace-rt
Manual
Replace the  route targets of IP prefix advertisement routes received from the IBGP peer group.
N/A
N/A
peer evpn re-originated mac-ip replace-rt
Manual
Replace the  route targets of MAC/IP advertisement routes received from the IBGP peer group.
N/A
N/A
peer evpn re-originated imet replace-rt
Manual
Replace the  route targets of IMET routes received from the IBGP peer group.
N/A
N/A
peer pod1 enable
peer pod1 enable
Manual
Enable the device to exchange routes with the EBGP peer group.
N/A
peer pod1 router-mac-local dci
Manual
Enable route router MAC replacement for the peer group and set up VXLAN-DCI tunnels with the EBGP peer group..
Set up VXLAN-DCI tunnels with the peer group to speed up route convergence upon public-side link flapping.
You do not need to execute the dci enable command to set up VXLAN-DCI tunnels.
peer pod1 re-originated replace-rt
Manual
Replace the  route targets of BGP EVPN routes received from the EBGP peer group.
Enable inter-data center route exchange.
peer pod1 re-originated mac-ip replace-rt
Manual
Replace the  route targets of MAC/IP advertisement routes received from the EBGP peer group.
N/A
peer pod1 re-originated imet replace-rt
Manual
Replace the  route targets of IMET routes received from the EBGP peer group.
N/A
peer taosheng enable
Manual
Enable the device to exchange routes with the fail-permit peer group.
N/A
peer taosheng route-policy 1 export
Manual
Apply the routing policy created previously to the outbound direction.
N/A
peer taosheng advertise evpn-route suppress mac-ip
Manual
Disable advertising MAC/IP advertisement routes to the fail-permit peer group.
Prevent inter-data center Layer 2 traffic from being forwarded over the fail-permit tunnel.
peer taosheng advertise vpn-reoriginate ibgp
Manual
Enable advertising the EVPN routes reoriginated in VPN instances to IBGP peer.
N/A
Border 1
Border 2
Purpose
Remarks
ip vpn-instance external_vpn_123
Controller-based
N/A
route-distinguisher 5:50035
Controller-based
Configure an RD for the VPN instance.
N/A
bgp 400
bgp 400
Controller-based
Start a BGP instance.
N/A
Controller-based
Enter the view of the VPN instance on the private network.
N/A
Controller-based
Enter BGP-VPN IPv4 unicast address family view.
N/A
balance 4
balance 4
Controller-based
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing.
N/A
advertise route-reoriginate replace-rt
Controller-based
Reoriginate the BGP unicast routes from other VPN instances and change the route target attribute of reoriginated routes to that of the current VPN instance.
N/A
network 123.0.0.0 255.255.255.0
Controller-based
Configure BGP to advertise a local network.
N/A
network 123.0.0.1 255.255.255.255
Controller-based
N/A
Controller-based
N/A
address-family ipv6 unicast
Controller-based
Enter BGP-VPN IPv6 unicast address family view.
N/A
balance 4
balance 4
Controller-based
N/A
Controller-based
N/A
network 2123:: 64
network 2123:: 64
Controller-based
N/A
network 2123::1 128
network 2123::1 128
Controller-based
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
route-distinguisher 5:50034
Controller-based
N/A
N/A
address-family ipv4
address-family ipv4
Controller-based
N/A
N/A
Controller-based
Configure import route targets for the VPN instance.
N/A
N/A
Controller-based
Configure export route targets for the VPN instance.
N/A
N/A
address-family ipv6
address-family ipv6
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
address-family evpn
address-family evpn
Controller-based
Enter EVPN address family view of the VPN instance.
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
interface Vsi-interface 22000
Controller-based
N/A
N/A
mtu 1450
mtu 1450
Controller-based
Configure the MTU.
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
mtu 1450
mtu 1450
Controller-based
Configure the MTU.
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
interface Vsi-interface 50034
Controller-based
N/A
N/A
Controller-based
Bind the VSI interface to the VPN instance.
N/A
N/A
Controller-based
N/A
N/A
l3-vni 50034
l3-vni 50034
Controller-based
N/A
Controller-based
N/A
N/A
vsi SDN_VSI_22000
vsi SDN_VSI_22000
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
vxlan 22000
vxlan 22000
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
vpn-target auto
vpn-target auto
Controller-based
Configure import and export route targets for EVPN.
N/A
N/A
Controller-based
N/A
N/A
vsi SDN_VSI_22005
vsi SDN_VSI_22005
Controller-based
N/A
N/A
gateway vsi-interface 22005
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
vxlan 22005
vxlan 22005
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
vpn-target auto
vpn-target auto
Controller-based
N/A
N/A
mapping vni 123123
mapping vni 123123
Controller-based
Map the local VXLAN to a remote VXLAN.
Enable Layer 2 communication between data centers.
Controller-based
N/A
N/A
vsi SDN_VSI_123123
vsi SDN_VSI_123123
Controller-based
Create a VSI.
vxlan 123123
vxlan 123123
Controller-based
N/A
Controller-based
N/A
Controller-based
Configure the RD.
N/A
vpn-target 123123:1 export-extcommunity
Controller-based
Configure export route targets for EVPN.
N/A
vpn-target 123123:1 import-extcommunity
Controller-based
Configure import route targets for EVPN.
N/A
Controller-based
N/A
ip vpn-instance 5ndrrejtf68up8h4lbkloqqh59dto8
Controller-based
Create a VPN instance for inter-data center communication.
Enable Layer 3 communication between data centers.
route-distinguisher 5:456456
Controller-based
Configure the RD.
N/A
address-family ipv4
address-family ipv4
Controller-based
N/A
route-replicate from vpn-instance admin_route4_50025 protocol direct advertise
Controller-based
Redistribute routes from the private VPN instance to the VPN instance for inter-data center communication.
N/A
vpn-target 456456:1 1:50025 import-extcommunity
Controller-based
Configure import route targets for the private VPN instance.
Edit the private routes to reoriginate routes.
vpn-target 456456:1 export-extcommunity
Controller-based
Configure export route targets for the public device.
Configure the export route targets same as those of the VPN instance for inter-data center communication.
address-family ipv6
address-family ipv6
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
address-family evpn
address-family evpn
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
N/A
ip route-static vpn-instance admin_route1_50034 0.0.0.0 0 200.3.1.3 description SDN_ROUTE
Controller-based
Configure a static route.
Direct traffic to the firewalls.
The controller issues static routes on demand.
ip route-static vpn-instance admin_route1_50034 121.5.0.0 16 200.3.1.3 description SDN_ROUTE
Controller-based
ipv6 route-static vpn-instance admin_route1_50034 :: 0 200:3:1::2 description SDN_ROUTE
Controller-based
ipv6 route-static vpn-instance admin_route1_50034 121:5:: 64 200:3:1::2 description SDN_ROUTE
Controller-based
bgp 400
bgp 400
Controller-based
Enter BGP instance view.
N/A
N/A
Controller-based
Create a BGP-VPN instance and enter its view.
Create a BGP-VPN instance on the private network.
N/A
Controller-based
N/A
N/A
default-route imported
Controller-based
Import default routes.
Advertise the default routes issued by the controller.
N/A
balance 4
balance 4
Controller-based
N/A
N/A
import-route static
import-route static
Controller-based
Import static routes.
Advertise the static routes issued by the controller.
N/A
Controller-based
N/A
Controller-based
N/A
balance 4
balance 4
Controller-based
N/A
import-route static
import-route static
Controller-based
N/A
Controller-based
N/A
N/A
Controller-based
N/A
N/A
Controller-based
Create a BGP-VPN instance for the VPN instance for inter-data center communication.
Controller-based
N/A
balance 4
balance 4
Controller-based
N/A
import-route direct
import-route direct
Controller-based
Import direct routes.
N/A
Controller-based
N/A
balance 4
balance 4
Controller-based
N/A
import-route direct
import-route direct
Controller-based
N/A
Controller-based
N/A
Controller-based
N/A
Configuring S12508X-AF or S12500G-AF switches as spine devices
Procedure summary
·     Configuring IS-IS
·     Configuring the links between the spine and leaf tiers
·     Configuring the links between the spine and border tiers
·     Configuring BGP
Configuring IS-IS
Spine 1
Spine 2
Purpose
Remarks
router id 5.1.1.6
router id 5.1.1.8
Manual
N/A
N/A
isis 1
isis 1
Manual
Enable IS-IS and enter IS-IS view.
N/A
N/A
non-stop-routing
non-stop-routing
Manual
Enable IS-IS NSR.
N/A
is-level level-2
is-level level-2
Manual
N/A
cost-style wide
cost-style wide
Manual
N/A
flash-flood
flash-flood
Manual
Enable IS-IS LSP flash flooding.
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding.
N/A
timer spf 1 500 10
timer spf 1 500 10
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
network-entity 51.0000.0005.0006.00
network-entity 51.0000.0005.0008.00
Manual
N/A
N/A
Manual
N/A
N/A
interface LoopBack0
interface LoopBack0
Manual
N/A
N/A
ip address 5.1.1.6 255.255.255.255
ip address 5.1.1.8 255.255.255.255
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
N/A
The following matrix uses an interface as an example. You can configure other interface in the same way.
Spine 1
Spine 2
Purpose
Remarks
interface FortyGigE3/0/16
interface FortyGigE3/0/4
Manual
Configure a connection to Leaf 1.
N/A
Manual
N/A
N/A
ip address 6.1.1.2 255.255.255.252
ip address 6.1.1.6 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Spine 1
Spine 2
Purpose
Remarks
interface HundredGigE2/0/9
Manual
Configure a connection to Border 1.
N/A
Manual
N/A
N/A
ip address 6.1.1.33 255.255.255.252
ip address 6.1.1.41 255.255.255.252
Manual
N/A
N/A
isis enable 1
isis enable 1
Manual
N/A
N/A
Manual
N/A
Manual
N/A
Manual
N/A
Manual
N/A
N/A
Configuring BGP
Spine 1
Spine 2
Purpose
Remarks
bgp 400
bgp 400
Manual
N/A
N/A
non-stop-routing
non-stop-routing
Manual
Enable BGP NSR.
If the device has two MPUs, BGP NSR ensures continuous routing by synchronizing BGP state and data information from the active BGP process to the standby BGP process. The standby BGP process can seamlessly take over all services when the active process fails.
router-id 5.1.1.6
router-id 5.1.1.8
Manual
N/A
N/A
group evpn internal
group evpn internal
Manual
N/A
N/A
Manual
N/A
N/A
Manual
group vbgp internal
group vbgp internal
Manual
Create an IBGP peer group for communicating with the controller.
N/A
N/A
peer vbgp route-update-interval 0
Manual
peer 5.1.1.1 group evpn
Manual
N/A
N/A
peer 5.1.1.2 group evpn
Manual
N/A
N/A
peer 5.1.1.3 group evpn
Manual
N/A
N/A
peer 5.1.1.4 group evpn
Manual
N/A
N/A
peer 5.1.1.7 group evpn
Manual
N/A
N/A
peer 5.1.1.9 group evpn
Manual
N/A
N/A
peer 52.1.2.2 group vbgp
Manual
N/A
N/A
Manual
Enter BGP EVPN view.
N/A
N/A
undo policy vpn-target
Manual
Disable route target filtering for BGP EVPN routes.
N/A
N/A
peer evpn enable
peer evpn enable
Manual
N/A
N/A
peer evpn reflect-client
Manual
Configure the device as a route reflector and specify the  evpn peer group as a client.
N/A
N/A
peer vbgp enable
peer vbgp enable
Manual
N/A
N/A
peer vbgp reflect-client
Manual
Configure the device as a route reflector and specify the  vbgp peer group as a client.
N/A
N/A
Manual
N/A
N/A
Manual
N/A
N/A
When the TCP connection goes down, the hold timer expires, or the support for a new address family is added, BGP tears down and then re-establishes the peer sessions, which will cause traffic interruption. To avoid traffic interruption in these cases, enable BGP to reset peer sessions gracefully.
Overlay traffic forwarding models
Overlay traffic characteristics
The forwarding model matrix provides the following characteristics of overlay traffic:
·     No.—Traffic number in the O-X-XXX format:
¡     O—Overlay traffic.
¡     X—Protocol number, which can be 4 (IPv4) or 6 (IPv6).
¡     XXX—Traffic sequence number starting from 001.
·     Traffic type—Type of overlay traffic, which can be known unicast/IPV4 and unicast/Layer 2.
·     Direction—Direction of overlay traffic.
·     Forwarding path—Nodes that overlay traffic traverses.
·     Traffic simulation—Traffic simulation method. Typically a tester is used to simulate server traffic.
·     Load—Traffic size, which can be light (less than 1000 flows) and heavy (more than 1000 flows).
·     Traffic direction to firewalls/LB—Configuration used to direct traffic to firewalls and load balancers, other than PBR, DRNI, VRRP, static routes.
Forwarding models
No.
Traffic type
Direction
Forwarding path
Traffic simulation
Load
Remarks
O-4-001
Known unicast/IPv4
East to west, across leaf devices
Server 3 > Leaf 3 > Spine 2 > Leaf 2 > Server 2
Bound4+ tester
Light
N/A
BM-to-BM communication.
O-4-002
Known unicast/IPv4
Bound4+ tester
Light
N/A
BM-to-VM communication.
O-4-003
Known unicast/IPv4
South to north
Server 3 > Leaf 3 > Spine 2 > Border 2 > public device
Bound4+ tester
Light
Static routes.
Firewall: Through a VLAN on a DR interface.
LB: Through an AC on a DR interface.
BM-to-external network communication.
O-4-004
Known unicast/IPv4
South to north
Server 3 > Leaf 1 > Spine 2 > Border 2 > public device
Bound4+ tester
Light
Static routes.
O-4-005
Unicast/Layer 2
Server 2 > Leaf 1 > Server 1
Bound4+ tester
Light
N/A
O-4-006
Known unicast/IPv4
Server 2 > Leaf 1 > Leaf 4 > Server 4
Bound4+ tester
Light
N/A
O-4-007
Known unicast/IPv4
Server 2 > Leaf 2 > Spine 1 > Leaf 3 > Server 4
Bound4+ tester
Light
N/A
VM-to-BM communication.
O-4-008
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-4-009
Known unicast/IPv4
Server 1 > Leaf 2 > Spine 1 > Border > Spine 2 > Leaf 3 > Server 4
Bound4+ tester
Light
Static routes.
O-4-010
Known unicast/IPv4
South to north
Server 1 > Leaf 1 > Spine 2 > Border 2 > public device
Bound4+ tester
Light
Static routes.
VM-to-external network communication.
O-4-011
Unicast/Layer 2
Between data centers
Bound4+ tester
Light
Static routes.
Inter-data center Layer 2 communication.
O-4-012
Known unicast/IPv4
Server 4 > Leaf 3 > Spine 1 > Border > Spine > Leaf 2 > Server 1
Bound4+ tester
Light
Static routes.
O-4-013
Known unicast/IPv4
Server 4 > Leaf 3 > Spine 2 > Border > Spine > Leaf 2 > Server 2
Bound4+ tester
Light
Static routes.
O-4-014
Known unicast/IPv4
East to west, same leaf device
Server 4 > Leaf 3 > Spine > Border > Spine > Leaf > Server 4
Bound4+ tester
Light
N/A
O-4-015
Known unicast/IPv4
Server 4 > Leaf 3 > Spine 1 > Leaf 2 > Server 1
Bound4+ tester
Light
N/A
O-4-016
Known unicast/IPv4
Server 4 > Leaf 3 > Spine 1 > Leaf 2 > Server 2
Bound4+ tester
Light
Static routes.
O-4-017
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-4-018
Known unicast/IPv4
South to north
Server 3 > Leaf 3 > Server 1
Bound4+ tester
Light
N/A
O-4-019
Unicast/Layer 2
Server 2 > Leaf 3 > Spine 1 > Leaf 2 > Server 1
Bound4+ tester
Light
N/A
O-4-020
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-4-021
Known unicast/IPv4
Server 2 > Leaf 1 > Spine > Border > Spine > Leaf > Server 4
Bound4+ tester
Light
Static routes.
O-4-022
Known unicast/IPv4
South to north
Server 2 > Leaf 1 > Spine 2 > Border 2 > public device
Bound4+ tester
Light
N/A
O-4-023
Known unicast/IPv4
Server 4 > Leaf 4 > Spine 2 > Border 2
Bound4+ tester
Light
N/A
Inter-data center Layer 3 communication.
O-4-024
Unicast/Layer 2
Server 3 > Leaf 4 > Spine 2 > Leaf 2 > Server 2
Bound4+ tester
Light
N/A
O-4-025
Known unicast/IPv4
Server 3 > Leaf 4 > Server 4
Bound4+ tester
Light
N/A
O-4-026
Known unicast/IPv4
South to north
Bound4+ tester
Light
Static routes.
O-4-027
Known unicast/IPv4
North to south
Public device > Border 2 > Spine 2 > Leaf 1 > Server 1
Bound4+ tester
Light
Static routes.
External network-to-VM communication.
O-4-028
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
External network-to-BM communication.
O-4-029
Known unicast/IPv4
North to south
Public device > Border 2 > Spine 2 > Leaf 3 > Server 4
Bound4+ tester
Light
Static routes.
O-4-030
Known unicast/IPv4
North to south
Public device > Border 2 > Spine 2 > Leaf 3 > Server 3
Bound4+ tester
Light
Static routes.
O-4-031
Known unicast/IPv4
North to south
Public device > Border 2 > Spine 2 > Leaf 1 > Server 2
Bound4+ tester
Light
Static routes.
O-4-032
Known unicast/IPv4
North to south
Public device > Border 2 > Spine 2 > Leaf 1 > Server 4
Bound4+ tester
Light
Static routes.
O-4-033
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-4-034
Known unicast/IPv4
Border 1 > Spine 1 > Leaf 4 > Server 4
Bound4+ tester
Light
N/A
O-6-035
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-036
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-037
Known unicast/IPv4
South to north
Server 3 > Leaf 3 > Spine 2 > Border 2 > Public device
Bound4+ tester
Light
Static routes.
O-6-038
Known unicast/IPv4
South to north
Server 3 > Leaf 1 > Spine 2 > Border 2 > Public device
Bound4+ tester
Light
Static routes.
O-6-039
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-6-040
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-041
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-042
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-6-043
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-044
Known unicast/IPv4
South to north
Server 1 > Leaf 1 > Spine 2 > Border 2 > Public device
Bound4+ tester
Light
Static routes.
O-6-045
Unicast/Layer 2
Bound4+ tester
Light
Static routes.
O-6-046
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-047
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-048
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-049
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-050
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-051
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-052
Known unicast/IPv4
South to north
Bound4+ tester
Light
N/A
O-6-053
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-6-054
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-055
Known unicast/IPv4
Bound4+ tester
Light
Static routes.
O-6-056
Known unicast/IPv4
South to north
Server 2 > Leaf 1 > Spine 2 > Border 2 > Public device
Bound4+ tester
Light
N/A
O-6-057
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-058
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-6-059
Known unicast/IPv4
Bound4+ tester
Light
N/A
O-6-060
Known unicast/IPv4
South to north
Bound4+ tester
Light
Static routes.
O-6-061
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-062
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-063
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-064
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-065
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-066
Known unicast/IPv4
North to south
Bound4+ tester
Light
Static routes.
O-6-067
Unicast/Layer 2
Bound4+ tester
Light
N/A
O-6-068
Known unicast/IPv4
Bound4+ tester
Light
N/A
Testing network convergence upon single points of failure
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
Leaf
Link failure when the traffic load is light.
≤ 500 ms
Node failure when the traffic load is light.
≤ 2000 ms
Border
≤ 500 ms
≤ 2000 ms
Spine
≤ 500 ms
≤ 2000 ms
Verification commands
Leaf 1
Leaf 2
display drni summary
Displays summary information about the IPP and DR interfaces.
display drni system
display drni system
Displays the DR system settings.
display drni keepalive
Displays DR keepalive packet statistics.
display drni role
display drni role
Displays DR role information.
display drni consistency { type1 | type2 }
Displays information about the configuration consistency check done by DRNI.
display drni consistency-check status
Displays the configuration consistency check status.
display interface Bridge-Aggregation [ brief ]
Displays information about aggregate interfaces.
display stp brief
display stp brief
Displays the brief spanning tree status and statistics.
# Verify that nodes Border 1 and Border 2 has established a DR system.
<POD2-Border1>display drni summary
Global consistency check           : SUCCESS
Inconsistent type 1 global settings: -
IPP             IPP ID        State
BAGG1           1             UP
DR interface    DR group ID   State    Check result   Type 1 inconsistency
BAGG4            4               UP        SUCCESS         -
BAGG10           10             UP        SUCCESS          -
BAGG20           20             UP        SUCCESS          -
# Verify the DR system settings on Border 1.
<POD2-Border1>display drni system
IPP: Bridge-Aggregation1
State: UP
DR          System number System MAC         System priority
Local       2             542b-de0c-0200     10000
Peer        1             542b-de0c-0200     10000
# Verify the keepalive packet statistics on Border 1.
<POD2-Border1>dis drni keepalive
Neighbor keepalive link status: Up
Neighbor is alive for: 192203 s 276 ms
Last keepalive packet sending status: Successful
Last keepalive packet sending time: 2021/03/12 07:22:20 278 ms
Last keepalive packet receiving status: Successful
Last keepalive packet receiving time: 2021/03/12 07:22:20 287 ms
Distributed relay keepalive parameters:
Destination IP address: 192.1.2.100
Source IP address: 192.1.2.74
Keepalive UDP port : 6400
Keepalive VPN name : management
Keepalive interval : 1000 ms
Keepalive timeout  : 5 sec
Keepalive hold time: 3 sec
# Verify the DR roles on Border 1.
<POD2-Border1>display drni role
DR      Role priority    Bridge Mac          Configured role    Effective role
Local   100              7057-bff9-aa00      Primary            Primary
Peer    101              542b-de0c-0200      Secondary          Secondary
# View information about the configuration consistency check done by DRNI on Border 1.
<POD2-Border1>display drni consistency type2 global
VLAN consistency check: Success
Local VLAN interfaces:
  123, 1000, 2000-2005
Peer VLAN interfaces:
Passing PVID and VLANs (tagged) on local IPP:
  1-22, 24-4094
Passing PVID and VLANs (tagged) on peer IPP:
  1-22, 24-4094
Invalid VLANs on local IPP:
  None
# View information about the aggregate interfaces on Border 1.
<POD2-Border1>display interface Bridge-Aggregation brief
Speed: (a) - auto
BAGG1                 UP   80G(a)  F(a)    T    1
BAGG4                 UP   80G(a)  F(a)    T    1
BAGG10                UP   200G(a) F(a)    T    1
BAGG20                UP   200G(a) F(a)    T    1
# View the brief spanning tree status and statistics.
<POD2-Border1> display stp brief
 MST ID   Port                                Role  STP State   Protection
 0         Bridge-Aggregation4              DESI  FORWARDING  NONE
 0         Bridge-Aggregation10             DESI  FORWARDING  NONE
 0         Bridge-Aggregation20             DESI  FORWARDING  NONE
Upgrading the devices
Upgrading the leaf devices
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an upgrade.
Leaf 1
Leaf 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches DR System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback when the traffic load is light. For more information, see "Testing network convergence upon single points of failure."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Upgrading the spine devices
Spine 1
Spine 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Use the display version command to verify the current BootWare image version and startup software version.
2.     Use the release notes for the upgrade software version to evaluate the upgrade impact on your network and verify the following items:
¡     Software and hardware compatibility.
¡     Version and size of the upgrade software.
¡     Compatibility of the upgrade software with the current BootWare image and startup software image.
3.     Use the release notes to verify whether the software images require a license. If licenses are required, register and activate licenses for each license-based software image.
4.     Use the dir command to verify that the device has sufficient storage space for the upgrade images. If the storage space is not sufficient, delete unused files by using the delete command.
5.     Use FTP or TFTP to transfer the upgrade image file to the root directory of a file system.
6.     Upgrade the device according to the configuration guides for the device.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Upgrading the border devices
Border 1
Border 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Expanding the network
An expansion operation adds two leaf devices.
Adding a leaf device
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an expansion.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Adding the device to the leaf tier
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replacing a service module
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Switch service and management traffic on the target service module to other service modules.
2.     Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches DR System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
Leaf 1
Leaf 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
