H3C Data Center Switches DRNI Configuration Guide-6W103
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches DRNI Configuration Guide-6W103
09-DRNI+EVPN Distributed Gateway (OSPF on Underlay Network)+DHCP Relay+Microsegmentation+Service Chain Configuration Example
Configuring DRNI, EVPN distributed gateway (OSPF on the underlay network), DHCP relay, microsegmentation, and service chain
As shown in Figure 1:
·           Deploy DR systems at the leaf tier on a leaf-spine network to provide node redundancy.
·           Place EVPN gateways at the leaf tier. Configure the members in each DR system to provide distributed EVPN gateway services.
·           Use DHCP for dynamic assignment of IP addresses. This example deploys DHCP clients in a different VXLAN than the DHCP server.
·           For the DHCP clients to obtain IP services from the DHCP server, configure DHCP relay between them.
The following information describes the deployment in detail:
·           At the leaf tier, set up DR systems A, B, and C.
¡  DR system A—Contains nodes Leaf 1 and Leaf 2.
¡  DR system B—Contains nodes Leaf 3 and Leaf 4.
¡  DR system C—Contains nodes Leaf 5 and Leaf 6.
·           Leaf 1 and Leaf 2 act as service leaf nodes and connect to the firewall devices.
¡  Configure two DR interfaces on each of the two nodes. On each node, connect one DR interface to firewall EW for east-west protection and connect the other to firewall NS for north-south protection.
¡  All east-west flows (traffic between servers on the internal network) except for DHCP messages must be forwarded to firewall EW before they can reach their destination.
¡  All north-south flows (traffic from the internal network to the external network) must be forwarded to firewall NS before they can reach their destination.
¡  Use VXLANs 10999 and 11000 to accommodate traffic sent towards and received from firewall EW, respectively. Use VXLANs 10997 and 10998 to accommodate traffic sent towards and received from firewall NS, respectively.
·           DR system B (Leaf 3 and Leaf 4) and DR system C (Leaf 5 and Leaf 6) connect to the servers. The physical server that hosts the DHCP clients (VMs) is singled homed to node Leaf 3. The physical device that hosts the DHCP server (a VM) is single homed to node Leaf 5.
·           The DHCP clients belong to VXLAN 13313 and the DHCP server belongs to VXLAN 13342. Place EVPN distributed gateways at the leaf tier to provide Layer 3 connectivity between the DHCP clients and server. Configure the DR systems at the leaf tier to provide DHCP relay services between the DHCP clients and server.
·           At the border tier, set up a DR system with Border 1 and Border 2, and use DR interfaces to connect the DR system to external devices and downstream Spine A and Spine B.
·           Deploy nodes Spine A and Spine B as route reflectors (RRs) to reflect routes between the leaf nodes and forward underlay traffic.
·           Run OSPF on the underlay network to establish L3 connectivity between the devices.
·           Deploy service chains to direct service traffic to the firewalls for filtering and protection.
·           Configure the following VPN instances:
¡  Assign VPN ZHTESTCTVRF to accommodate all business services.
¡  Assign VPN ZHTESTCTFWEW01VRF to accommodate EW firewall services.
¡  Assign VPN ZHTESTCTFWNS01VRF to accommodate NS firewall services.
·           Deploy both IPv4 and IPv6 services. IPv6 traffic is forwarded through IPv6 over IPv4 tunnels.
Configure ACs for the servers to access the leaf devices, and configure the leaf devices to assign VMs to microsegments based on the IP address. Configure microsegmentation as follows:
·           Assign the business subnets to microsegment EPG 10001.
·           Assign the subnet accomodating common servers, such as the FTP server, to microsegment EPG 10002.
·           Assign the subnet accomodating the default route to the external network to microsegment EPG 10001.
·           Assign the subnet accomodating the DHCP server to microsegment EPG 10001.
·           Permit communication between microsegments EPG 10001 and EPG 10001.
·           Direct the traffic sent between microsegments EPG 10001 and EPG 10002 to firewall EW.
·           Direct the traffic sent between microsegments EPG 10001 and EPG 10003 to firewall NS.
·           Direct the traffic sent between microsegments EPG 10001 and EPG 10004 to firewall EW, except for DHCP messages.
·           Permit communication between microsegments EPG 10002 and EPG 10002.
·           Direct the traffic sent between microsegments EPG 10002 and EPG 10003 to firewall NS.
·           Permit communication between microsegments EPG 10002 and EPG 10004.
·           Permit communication within microsegment EPG 10004.
Figure 1 Network diagram
Device
IP address
Spine A
Loopback0
197.32.241.37
None.
HGE1/0/1
Borrowed from Loopback 0
Connected to Leaf 1.
HGE1/0/2
Connected to Leaf 2.
HGE1/0/3
Connected to Leaf 3.
HGE1/0/4
Connected to Leaf 4.
HGE1/0/5
Connected to Leaf 5.
HGE1/0/6
Connected to Leaf 6.
HGE1/0/7
Connected to Border 1.
HGE1/0/8
Connected to Border 2.
Spine B
Loopback0
197.32.241.38
None.
HGE1/0/1
HGE1/0/2
HGE1/0/3
HGE1/0/4
HGE1/0/5
HGE1/0/6
HGE1/0/7
HGE1/0/8
Leaf 1
Loopback0
197.32.241.41
None.
Loopback2
197.32.241.55
None.
VSI-interface10997
197.32.224.21
Gateway of VXLAN 10997.
VSI-interface10998
197.32.224.25
Gateway of VXLAN 10998.
VSI-interface10999
197.32.224.29
Gateway of VXLAN 10999.
VSI-interface11000
197.32.224.33
Gateway of VXLAN 11000.
VSI-interface13313
197.32.13.254
Gateway of VXLAN 13313.
HGE1/0/25
Connected to Spine A.
HGE1/0/26
Connected to Spine B.
HGE1/0/31
N/A
Connected to Leaf 2, member port of the IPL.
Twenty-FiveGigE1/0/54
197.32.241.57
Connected to Leaf 2, member port of the keepalive link.
HGE1/0/51
N/A
Connected to the EW firewall, member port of DR group member interface Bridge-Aggregation 257.
HGE1/0/52
N/A
Connected to firewall NS, member port of DR group member interface Bridge-Aggregation 258.
Leaf 2
Loopback0
197.32.241.42
None.
Loopback2
197.32.241.55
None.
VSI-interface10997
197.32.224.21
VSI-interface10998
197.32.224.25
VSI-interface10999
197.32.224.29
VSI-interface11000
197.32.224.33
VSI-interface13313
197.32.13.254
HGE1/0/25
HGE1/0/26
HGE1/0/31
N/A
Connected to Leaf 1, member port of the IPL.
197.32.241.58
Connected to Leaf 1, member port of the keepalive link.
HGE1/0/51
N/A
Connected to firewall EW, member port of DR group member interface Bridge-Aggregation 257.
HGE1/0/52
N/A
Leaf 3
Loopback0
197.32.241.43
None.
Loopback2
197.32.241.64
None.
VSI-interface13313
197.32.13.254
HGE1/0/25
HGE1/0/26
HGE1/0/31
N/A
Connected to Leaf 4, member port of the IPL.
197.32.241.61
Connected to Leaf 4, member port of the keepalive link.
Twenty-FiveGigE1/0/2
N/A
Connected to DHCP clients.
Leaf 4
Loopback0
197.32.241.44
None.
Loopback2
197.32.241.64
None.
VSI-interface13313
197.32.13.254
HGE1/0/25
HGE1/0/26
HGE1/0/31
N/A
Connected to Leaf 3, member port of the IPL.
197.32.241.62
Connected to Leaf 3, member port of the keepalive link.
Leaf 5
Loopback0
197.32.241.45
None.
Loopback2
197.32.241.67
None.
VSI-interface13342
197.32.42.254
Gateway of VXLAN 13342.
VSI-interface13316
197.32.162.54
Gateway of VXLAN 13316.
HGE1/0/25
HGE1/0/26
HGE1/0/31
N/A
Connected to Leaf 6, member port of the IPL.
197.32.241.77
Connected to Leaf 6, member port of the keepalive link.
N/A
Connected to the DHCP server.
Leaf 6
Loopback0
197.32.241.46
None.
Loopback2
197.32.241.67
None.
VSI-interface13342
197.32.42.254
VSI-interface13316
197.32.162.54
HGE1/0/25
HGE1/0/26
HGE1/0/31
N/A
Connected to Leaf 5, member port of the IPL.
197.32.241.78
Connected to Leaf 5, member port of the keepalive link.
Border 1
Loopback0
197.32.241.47
None.
Loopback2
197.32.241.86
None.
HGE1/0/25
HGE1/0/26
HGE1/0/31
Connected to Border 2, member port of the IPL.
HGE1/0/51
Connected to L3switch.
197.32.241.93
Connected to Border 2, member port of the keepalive link.
Border 2
Loopback0
197.32.241.48
None.
Loopback2
197.32.241.86
None.
HGE1/0/25
HGE1/0/26
HGE1/0/31
Connected to Border 1, member port of the IPL.
HGE1/0/51
197.32.241.94
Connected to Border 1, member port of the keepalive link.
EW firewall
Vlan-interface999
197.32.224.30
None.
Vlan-interface1000
197.32.224.34
None.
HGE2/0/29
N/A
Connected to Leaf 1, member port of DR group member interface Bridge-Aggregation 257.
HGE2/0/30
N/A
Connected to Leaf 2, member port of DR group member interface Bridge-Aggregation 257.
NS firewall
Vlan-interface997
197.32.224.22
None.
Vlan-interface998
197.32.224.26
None.
HGE3/0/29
N/A
Connected to Leaf 1, member port of DR group member interface Bridge-Aggregation 258.
HGE3/0/30
N/A
Connected to Leaf 2, member port of DR group member interface Bridge-Aggregation 258.
DHCP server
N/A
197.32.42.9
None.
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Microsegmentation and service chain are supported only by S6805, S6825, S6850, and S9850 switches. For configuration of other device models, see DRNI+EVPN Distributed Gateway+DHCP Relay Configuration Example.
Role
Device
Software version
Spine
S12500X-AF
F2809 and higher F28xx or R28xx versions
S12500G-AF
R7624P12
Border/Leaf
S6800, S6860
F2717 and higher F27xx or R27xx versions
Do not use F28xx or R28xx versions.
S6805, S6825, S6850, S9850
S6850 switches are used in this configuration example.
F6632 and higher F66xx or R66xx versions
S6890
S6812, S6813
Under development. To obtain the latest images, contact Technical Support.
S9820-64H (EVPN gateway not supported)
S9820-8C (EVPN not supported)
Not supported
SDN controller
N/A
E3610P12H02, or contact Technical Support to obtain a higher version
·           The member devices in a DR system must use the same DR system MAC address. Different DR systems must each have a unique DR system MAC address on the network.
·           As a best practice, run a dynamic routing protocol between the spine devices and the external network.
·           If leaf devices provide both distributed EVPN gateway and DHCP relay services, you must perform the following steps:
¡  Execute the dhcp relay mac-forward enable command to enable MAC address table lookup for DHCP replies that do not have request forwarding information.
¡  Execute the dhcp relay request-from-tunnel discard command on the VSI interfaces that act as DHCP relay agents to discard the DHCP requests received from VXLAN tunnels. This feature prevents the DHCP server from receiving the same DHCP request from the relay agents on different leaf devices.
Configuring the service leaf nodes (Leaf 1 and Leaf 2)
Procedure summary
·           Configuring the device modes
·           Configuring the underlay routing protocol
·           Configuring L3VPN
·           Setting up the DR system and the IPL link
·           Configuring the firewall-attached DR interfaces on the leaf devices
·           Configuring the links towards the spine tier
·           Configuring distributed EVPN gateways
·           Configuring ACs
For how to configure the device modes, see ADDC solution deployment guides. The mode-related configurations might include the following types:
·           Hardware resource mode configuration (for example, the hardware-resource switch-mode command on S6850 switches).
·           Support for IPv6 routes with the prefix longer than 64 bits (for example, the hardware-resource routing-mode ipv6-128 command on S6850 switches).
·           VXLAN hardware resource mode configuration (for example, the hardware-resource vxlan command on S6850 switches).
Leaf 1 (S6850)
Leaf 2 (S6850)
Configuration method
router id 197.32.241.41
router id 197.32.241.42
Manual or controller-based
Configure a router ID.
ospf 65530
ospf 65530
Run OSPF process 65530.
non-stop-routing
non-stop-routing
Enable OSPF NSR.
stub-router include-stub on-startup 900
Specify the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535 to accelerate network convergence.
area 0.0.0.0
area 0.0.0.0
Create OSPF area 0.0.0.0.
interface LoopBack0
interface LoopBack0
Enter the view of Loopback 0.
ospf 65530 area 0.0.0.0
Enable OSPF on Loopback 0.
Return to system view.
interface LoopBack2
interface LoopBack2
Enter the view of Loopback 2.
Enable OSPF on Loopback 2.
Configuring L3VPN
Leaf 1 (S6850)
Leaf 2 (S6850)
interface LoopBack0
interface LoopBack0
Configure Loopback 0.
ip address 197.32.241.41 255.255.255.255
ip address 197.32.241.42 255.255.255.255
Assign an IP address to Loopback 0.
interface LoopBack2
interface LoopBack2
Configure Loopback 2.
ip address 197.32.241.55 255.255.255.255
Assign an IP address to Loopback 2.
ip vpn-instance auto-online-mlag
Configure the VPN instance where the keepalive link belongs.
ip vpn-instance mgmt
Configure the VPN instance where the management interface belongs.
ip vpn-instance ZHTESTCTVRF
Configure the service VPN instance where the servers belong.
To ensure correct route learning, configure consistent route targets for the service VPN instance on different devices.
route-distinguisher 1:10000
route-distinguisher 2:10000
Configure an RD for the VPN instance.
address-family ipv4
address-family ipv4
Enter VPN instance IPv4 address family view.
vpn-target 0:10000 1:10000 0.39.18.0:10000 0.39.17.0:10000 import-extcommunity
Configure import targets in VPN instance IPv4 address family view.
vpn-target 0:10000 1:10000 0.39.18.0:10000  0.39.17.0:10000 export-extcommunity
Configure export targets in VPN instance IPv4 address family view.
Return to VPN instance view.
address-family ipv6
address-family ipv6
Enter VPN instance IPv6 address family view.
Configure import targets in VPN instance IPv6 address family view.
Configure export targets in VPN instance IPv6 address family view.
address-family evpn
address-family evpn
Enter VPN instance EVPN address family view.
Configure import targets in VPN instance EVPN address family view.
Configure export targets in VPN instance EVPN address family view.
ip vpn-instance ZHTESTCTFWNS01VRF
Configure the VPN instance where firewall NS belongs.
To ensure correct route learning, configure consistent route targets for the NS firewall VPN instance on different devices.
route-distinguisher 1:10001
route-distinguisher 2:10001
address-family ipv4
address-family ipv4
vpn-target 0:10001 1:10001 0.39.17.0:10000 import-extcommunity
vpn-target 0:10001 1:10001 0.39.17.0:10000 export-extcommunity
address-family ipv6
address-family ipv6
route-replicate from vpn-instance ZHTESTCTVRF protocol vlink-direct
Redistribute the IPv6 VLINK direct routes of VPN instance ZHTESTCTVRF to the current VPN instance.
address-family evpn
address-family evpn
vpn-target0:10001 1:10001 0.39.17.0:10000 export-extcommunity
ip vpn-instance ZHTESTCTFWEW01VRF
Configure the VPN instance where firewall EW belongs.
To ensure correct route learning, configure consistent route targets for firewall EW VPN instance on different devices.
route-distinguisher 1:10002
route-distinguisher 2:10002
address-family ipv4
address-family ipv4
vpn-target 0:10002 1:10002 0.39.18.0:10000 import-extcommunity
vpn-target 0:10002 1:10002 0.39.18.0:10000 export-extcommunity
address-family ipv6
address-family ipv6
export-extcommunity
address-family evpn
address-family evpn
ip route-static vpn-instance ZHTESTCTFWNS01VRF 0.0.0.0 0 vpn-instance ZHTESTCTVRF 197.32.224.18 description SDN_ROUTE
Direct the traffic matching the IPv4 default route of the NS firewall VPN instance to the external network address configured on the border devices in the user VPN instance. This configuration ensures correct forwarding of south-to-north traffic returned from firewall NS.
ipv6 route-static vpn-instance ZHTESTCTFWNS01VRF :: 0 vpn-instance ZHTESTCTVRF FD00:0:97B0:2::F description SDN_ROUTE
Direct the traffic matching the IPv6 default route of the NS firewall VPN instance to the external network address configured on the border devices in the user VPN instance. This configuration ensures correct forwarding of south-to-north traffic returned from firewall NS.
Leaf 1 (S6850)
Leaf 2 (S6850)
drni system-mac 0c3a-fa36-ef49
Set the MAC address of the DR system.
You must assign the same DR system MAC address to the member devices in a DR system.
drni system-number 1
drni system-number 2
Set the DR system number.
You must assign different DR system numbers to the member devices in a DR system.
drni system-priority 10
Set the DR system priority.
You must set the same DR system priority on the member devices in a DR system.
drni keepalive ip destination 197.32.241.58 source 197.32.241.57 vpn-instance auto-online-mlag
drni keepalive ip destination 197.32.241.57 source 197.32.241.58 vpn-instance auto-online-mlag
Configure the source and destination IP addresses of keepalive packets.
The source and destination IP addresses specified on one member device must be the destination and source IP addresses specified on the other, respectively.
drni restore-delay 300
Set the data restoration interval.
To avoid packet loss and forwarding failure, increase the data restoration interval if the amount of data is large, for example, when the device has a large number of routes and interfaces.
drni mad default-action none
Set the DRNI MAD action to none. When the DR system splits, DRNI MAD will not shut down any network interfaces, except the interfaces configured manually or by the system to be shut down by DRNI MAD.
drni mad include interface HundredGigE1/0/25
drni mad include interface HundredGigE1/0/26
drni mad include interface HundredGigE1/0/51
drni mad include interface HundredGigE1/0/52
Configure DRNI MAD to shut down the uplink interfaces and firewall-attached physical interfaces.
interface
Twenty-FiveGigE 1/0/54
interface  Twenty-FiveGigE 1/0/54
Enter the interface view for the keepalive link.
port link-mode route
Configure the interface for keepalive detection to operate in route mode as a Layer 3 interface.
ip binding vpn-instance auto-online-mlag
Associate the interface with VPN instance auto-online-mlag, the VPN instance for DRNI keepalive detection.
ip address 197.32.241.57 255.255.255.252
ip address 197.32.241.58 255.255.255.252
Assign an IP address to the interface as planned.
interface bridge-aggregation 256
Create the Layer 2 aggregate interface to be used as IPP, and enter interface view.
link-aggregation mode dynamic
Configure the aggregate interface to operate in dynamic mode.
interface HundredGigE1/0/31
Enter the view of the physical port for the IPL.
port link-aggregation group 256
Assign the physical port to the aggregation group for the IPL (aggregation group 256).
Enter aggregate interface view.
port drni intra-portal-port 1
Specify Bridge-Aggregation 256 as the IPP.
port trunk pvid vlan 4094
Set the PVID of the physical port to 4094.
undo mac-address static source-check enable
Disable the static source check feature on Bridge-Aggregation 256.
interface Vlan-interface 4094
Create a VLAN interface on each of the DR member devices to establish Layer 3 connectivity for forwarding packets from devices single-homed to only one DR interface. This example uses VLAN-interface 4094.
ip address 197.32.241.141 255.255.255.0
ip address 197.32.241.142 255.255.255.0
Assign an IP address to VLAN-interface 4094.
Configure OSPF on VLAN-interface 4094.
Leaf 1 (S6850)
Leaf 2 (S6850)
interface bridge-aggregation 257
Create the Layer 2 aggregate interface to be used as the DR interface connected to firewall EW.
port drni group 1
port drni group 1
Assign the aggregate interface (Bridge-Aggregation 257) to DR group 1.
port link-type trunk
Set the link type of DR interface Bridge-Aggregation 257 to trunk.
port trunk permit vlan 1 997 to 1000
Assign DR interface Bridge-Aggregation 257 to VLANs 997 through 1000.
Enter the view of the physical port connected to firewall EW.
Set the link type of the physical port to trunk.
Assign the physical port to VLANs 997 through 1000.
port link-aggregation group 257
Assign the physical port to aggregation group 257. This is the aggregation group for the aggregate interface connected to firewall EW.
interface bridge-aggregation 258
Create the Layer 2 aggregate interface to be used as the DR interface connected to firewall NS.
port drni group 2
port drni group 2
Assign the aggregate interface (Bridge-Aggregation 258) to DR group 2.
Set the link type of DR interface Bridge-Aggregation 258 to trunk.
Assign DR interface Bridge-Aggregation 258 to VLANs 997 through 1000.
Enter the view of the physical port connected to firewall NS.
port link-aggregation group 258
Assign the physical port to aggregation group 258. This is the aggregation group for the aggregate interface connected to firewall NS.
Leaf 1 (S6850)
Leaf 2 (S6850)
Enter the view of the physical interface connected to Spine A.
Configure the interface to operate in route mode as a Layer 3 interface.
ip address unnumbered interface LoopBack0
Configure the interface to borrow the IP address of Loopback 0.
ospf network-type p2p
Set the OSPF network type of the interface to P2P.
Enable OSPF on the interface.
Disable the static source check feature on the interface.
lldp compliance admin-status cdp txrx
Configure CDP-compatible LLDP to operate in TxRx mode. In this mode, LLDP both sends and receives CDP packets.
lldp management-address arp-learning
Enable the device to generate an ARP entry after it receives an LLDP frame that contains a management address TLV on the interface.
lldp tlv-enable basic-tlv management-address-tlv interface LoopBack0
Specify advertisable TLVs on the interface.
Enter the view of the physical interface connected to Spine B.
Leaf 1 (S6850)
Leaf 2 (S6850)
l2vpn enable
l2vpn enable
Enable L2VPN.
l2vpn drni peer-link ac-match-rule vxlan-mapping
Enable the device to create frame match criteria based on VXLAN IDs for the dynamic ACs on the Ethernet aggregate link IPL.
vxlan tunnel arp-learning disable
vxlan tunnel nd-learning disable
Disable remote ARP learning. This setting avoids the conflict between automatically learned ARP entries and ARP entries advertised through BGP EVPN.
Disable remote MAC address learning. This setting avoids the conflict between automatically learned MAC address entries and MAC address entries advertised through BGP EVPN.
vxlan default-decapsulation source interface LoopBack0
Enable the device to always decapsulate the VXLAN packets destined for the IP address of Loopback 0, whether or not it has a VXLAN tunnel for them.
vlan all
vlan all
Create VLANs 1 through 4094.
evpn drni group 197.32.241.55
Enable EVPN DRNI and set the virtual VTEP address.
evpn drni local 197.32.241.41 remote 197.32.241.42
evpn drni local 197.32.241.42 remote 197.32.241.41
Specify the IP addresses of the local and peer VTEPs in the DR system.
This step is required if the DR system uses an Ethernet aggregate link as the IPL and has ACs attached to only one of the member devices.
evpn global-mac 0c3a-fa38-4695
Configure an EVPN global MAC address.
interface Vsi-interface10997
Create the VSI interface to be used as a distributed EVPN gateway member for routing traffic to firewall NS.
ip binding vpn-instance ZHTESTCTFWNS01VRF
Associate the VSI interface with the VPN instance for firewall NS.
ip address 197.32.224.21 255.255.255.252 sub
ipv6 nd ra prefix FD00:0:97B0:100::/64 no-advertise
 ipv6 address FD00:0:97B0:100::1/64
Assign an IP address to the VSI interface.
You must assign the same IP address to all members of the distributed EVPN gateway for a VXLAN on different devices.
mac-address 6805-ca21-d6e5
Assign a MAC address to the distributed EVPN gateway.
You must assign the same MAC address to all members of the distributed EVPN gateway for a VXLAN on different devices.
arp route-direct advertise
Enable ARP direct route advertisement.
distributed-gateway local
Enable distributed gateway service on the VSI interface.
interface Vsi-interface10998
Create the VSI interface to be used as a distributed EVPN gateway member for receiving traffic returned from firewall NS.
ip address 197.32.224.25 255.255.255.252 sub
ipv6 nd ra prefix FD00:0:97B0:101::/64 no-advertise
 ipv6 address FD00:0:97B0:101::1/64
interface Vsi-interface10999
Create the VSI interface to be used as a distributed EVPN gateway member for routing traffic to firewall EW.
ip binding vpn-instance ZHTESTCTFWEW01VRF
Associate the VSI interface with the VPN instance for firewall EW.
ip address 197.32.224.29 255.255.255.252 sub
ipv6 nd ra prefix FD00:0:97B0:102::/64 no-advertise
 ipv6 address FD00:0:97B0:102::1/64
interface Vsi-interface11000
Create the VSI interface to be used as a distributed EVPN gateway member for receiving  traffic returned from firewall EW.
ip address 197.32.224.33 255.255.255.252 sub
ipv6 nd ra prefix FD00:0:97B0:103::/64 no-advertise
 ipv6 address FD00:0:97B0:103::1/64
vsi SDN_VSI_10997
vsi SDN_VSI_10997
Create the VSI for sending traffic to firewall NS.
gateway vsi-interface 10997
Specify a gateway interface for the VSI.
arp suppression enable
ipv6 nd suppression enable
Enable ARP flood suppression and ND flood suppression.
vxlan 10997
vxlan 10997
Create VXLAN 10997.
Return to VSI view.
evpn encapsulation vxlan
Create a VXLAN EVPN instance on the VSI.
route-distinguisher auto
Configure the device to automatically generate an RD for the EVPN instance.
vpn-target auto export-extcommunity
Configure the device to automatically generate an export RT for the EVPN instance.
vpn-target auto import-extcommunity
Configure the device to automatically generate an import RT for the EVPN instance.
vsi SDN_VSI_10998
vsi SDN_VSI_10998
Create the VSI for receiving traffic from firewall NS.
gateway vsi-interface 10998
vxlan 10998
vxlan 10998
Create VXLAN 10998.
Return to VSI view.
vsi SDN_VSI_10999
vsi SDN_VSI_10999
Create the VSI for sending traffic to firewall EW.
gateway vsi-interface 10999
vxlan 10999
vxlan 10999
Create VXLAN 10999.
Return to VSI view.
vsi SDN_VSI_11000
vsi SDN_VSI_11000
Create the VSI for receiving traffic from firewall EW.
gateway vsi-interface 11000
vxlan 11000
vxlan 11000
Create VXLAN 11000.
Return to VSI view.
interface Vsi-interface10001
Create the VSI interface for L3 connectivity to firewall NS.
ipv6 address auto link-local
Automatically generate a link-local address for the VSI interface.
l3-vni 10001
l3-vni 10001
Assign an L3VNI to the interface.
interface Vsi-interface10002
Create the VSI interface for L3 connectivity to firewall EW.
l3-vni 10002
l3-vni 10002
interface Vsi-interface10000
Create the VSI interface for L3 connectivity to servers.
ip binding vpn-instance ZHTESTCTVRF
Associate the VSI interface with the VPN instance for servers.
l3-vni 10000
l3-vni 10000
bgp 65530
bgp 65530
Enable the specified BGP instance and enter its view.
non-stop-routing
non-stop-routing
Enable BGP nonstop routing (NSR).
router-id 197.32.241.41
router-id 197.32.241.42
Specify a unique router ID for the BGP instance on each BGP device.
group evpn internal
group evpn internal
Create an IBGP peer group named evpn.
peer evpn connect-interface LoopBack0
Specify a source interface for establishing TCP connections to a peer or peer group.
peer 197.32.241.37 group evpn
Add node Spine A to IBGP group evpn.
peer 197.32.241.38 group evpn
Add node Spine B to IBGP group evpn.
address-family l2vpn evpn
Create the BGP EVPN address family and enter its view.
peer evpn enable
peer evpn enable
Enable BGP to exchange BGP EVPN routes with IBGP peer group evpn.
Return to BGP instance view.
Create a BGP-VPN instance for the VPN instance that contains firewall EW, and enter BGP-VPN instance view.
address-family ipv4 unicast
Create the BGP-VPN IPv4 unicast address family and enter its view.
balance 4
balance 4
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing.
network 197.32.224.28 255.255.255.252
network 197.32.224.29 255.255.255.255
network 197.32.224.30 255.255.255.255
network 197.32.224.32 255.255.255.252
network 197.32.224.33 255.255.255.255
network 197.32.224.34 255.255.255.255
Specify the local networks to be advertised by BGP.
address-family ipv6 unicast
Create the BGP-VPN IPv6 unicast address family and enter its view.
balance 4
balance 4
network FD00:0:97B0:102:: 64
network FD00:0:97B0:102::1 128
network FD00:0:97B0:102::F 128
network FD00:0:97B0:103:: 64
network FD00:0:97B0:103::1 128
network FD00:0:97B0:103::F 128
Create a BGP-VPN instance for the VPN instance that contains firewall NS, and enter BGP-VPN instance view.
balance 4
balance 4
network 197.32.224.20 255.255.255.252
network 197.32.224.21 255.255.255.255
network 197.32.224.22 255.255.255.255
network 197.32.224.24 255.255.255.252
network 197.32.224.25 255.255.255.255
network 197.32.224.26 255.255.255.255
balance 4
balance 4
Create a BGP-VPN instance for the VPN instance that contains servers, and enter BGP-VPN instance view.
balance 4
balance 4
network 197.32.13.0 255.255.255.0
network 197.32.13.254 255.255.255.255
network 197.32.42.0 255.255.255.0
network 197.32.42.254 255.255.255.255
balance 4
balance 4
network FD00:0:97B0:1013:: 64
network FD00:0:97B0:1013::FFFF 128
network FD00:0:97B0:1042:: 64
network FD00:0:97B0:1042::FFFF 128
Configuring ACs
Leaf 1 (S6850)
Leaf 2 (S6850)
interface Bridge-Aggregation257
Enter the view of the aggregate interface connected to firewall EW.
service-instance 997
Create an Ethernet service instance.
encapsulation s-vid 997
Specify the outer VLAN IDs to match.
xconnect vsi SDN_VSI_10997
Map the AC to a VSI.
service-instance 998
encapsulation s-vid 998
xconnect vsi SDN_VSI_10998
Return to interface view.
service-instance 999
encapsulation s-vid 999
xconnect vsi SDN_VSI_10999
service-instance 1000
encapsulation s-vid1000
encapsulation s-vid 1000
xconnect vsi SDN_VSI_11000
interface Bridge-Aggregation258
Enter the view of the aggregate interface connected to firewall NS.
Configuring leaf nodes (Leaf 3 and Leaf 4)
Procedure summary
·           Configuring L3VPN
·           Configuring the distributed EVPN gateway
·           Configuring ACs
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
router id 197.32.241.43
router id 197.32.241.44
Specify a unique global router ID for each device.
N/A
ospf 65530
ospf 65530
Create OSPF process 65530.
N/A
non-stop-routing
non-stop-routing
Enable non-stop routing (NSR) for OSPF.
N/A
To accelerate network convergence, specify the router as a stub router during reboot for the specified period of time.
This command sets the cost of stub links to the maximum value (65535). Neighbors on such links will not send packets to the stub router as long as they have a route with a smaller cost.
area 0.0.0.0
area 0.0.0.0
N/A
interface loopback 0
Enter the interface view of Loopback 0.
N/A
Enable OSPF on interface Loopback 0.
N/A
N/A
interface loopback 2
Enter the interface view of Loopback 2.
N/A
Enable OSPF on interface Loopback 2.
N/A
Configuring L3VPN
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
Configure interface Loopback 0.
N/A
ip address 197.32.241.43 255.255.255.255
ip address 197.32.241.44 255.255.255.255
Assign an IP address to interface Loopback 0.
N/A
N/A
Configure interface Loopback 2.
N/A
ip address 197.32.241.64 255.255.255.255
Assign an IP address to interface Loopback 2.
N/A
Create a VPN instance for the DRNI keepalive link. In this example, the VPN instance name is auto-online-mlag.
N/A
N/A
Create a VPN instance for the management port. In this example, the VPN instance name is mgmt.
N/A
N/A
 route-distinguisher3:10000
 address-family ipv4
address-family ipv6
 address-family evpn
  vpn-target0:10000 1:10000 0.39.18.0:10000 0.39.17.0:10000 export-extcommunity
 route-distinguisher 4:10000
 address-family ipv4
address-family ipv6
export-extcommunity
 address-family evpn
Configure the VPN instance for user services. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4/IPv6 address family and EVPN address family.
For two devices to learn routes from each other in the VPN instance, make sure the import RTs on one device match the export RTs on the other.
N/A
 route-distinguisher 3:10001
 address-family ipv4
address-family ipv6
export-extcommunity
 address-family evpn
 route-distinguisher 4:10001
 address-family ipv4
  address-family ipv6
export-extcommunity
address-family evpn
Configure the VPN instance for the north-south firewall service. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4/IPv6 address family and EVPN address family.
N/A
 route-distinguisher 3:10002
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 4:10002
 address-family ipv4
address-family ipv6
export-extcommunity
 address-family evpn
Configure the VPN instance for the east-west firewall service. Set a route distinguisher (RD) for the VPN instance, and set the import and export route targets (RTs) for the VPN instance IPv4/IPv6 address family and EVPN address family.
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
drni system-mac   0c3a-fa36-acef
drni keepalive ip destination 197.32.241.62 source 197.32.241.61 vpn-instance auto-online-mlag
drni keepalive ip destination 197.32.241.61 source 197.32.241.62 vpn-instance auto-online-mlag
Set the data restoration interval. This parameter specifies the maximum amount of time for the secondary DR member device to synchronize data with the primary DR member device during DR system setup.
N/A
Configure DRNI MAD to shut down the uplink interfaces.
N/A
interface
N/A
N/A
N/A
ip address 197.32.241.61 255.255.255.252
ip address 197.32.241.62 255.255.255.252
N/A
N/A
Create the Layer 2 aggregate interface to be used as the IPP, and enter interface view.
N/A
N/A
N/A
N/A
N/A
N/A
Specify the aggregate interface (Bridge-Aggregation 256) as the IPP.
N/A
N/A
N/A
N/A
N/A
ip address 197.32.241.143 255.255.255.0
ip address 197.32.241.144 255.255.255.0
N/A
N/A
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
N/A
N/A
ip address unnumbered interface loopback 0
N/A
N/A
N/A
N/A
N/A
N/A
lldp tlv-enable basic-tlv management-address-tlv interface loopback 0
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
N/A
Disable remote ARP/ND learning. This setting avoids the conflict between automatically learned ARP/ND entries and ARP/ND entries advertised through BGP EVPN.
N/A
N/A
vxlan default-decapsulation source interface loopback 0
N/A
vlan all
vlan all
N/A
evpn drni group 197.32.241.64
Enable EVPN distributed relay and set the virtual VTEP address.
N/A
evpn drni local 197.32.241.43 remote 197.32.241.44
evpn drni local 197.32.241.44 remote 197.32.241.43
evpn global-mac 0c3a-fa38-3d3b
N/A
interface Vsi-interface13313
Create the VSI interface to be used as a distributed EVPN gateway member for compute servers.
N/A
Associate the VSI interface with the VPN instance for compute servers.
N/A
ip address 197.32.13.254 255.255.255.0 sub
ipv6 nd ra prefix FD00:0:97B0:1013::/64 no-advertise
 ipv6 address FD00:0:97B0:1013::FFFF/64
Assign an IPv4 address and an IPv6 address to the VSI interface.
N/A
N/A
ipv6 nd route-direct advertise
Enable ARP/ND direct route advertisement.
Enabled with this feature, ARP/ND advertises ARP/ND entries to the route management module to generate direct routes.
N/A
N/A
N/A
vsi SDN_VSI_13313
vsi SDN_VSI_13313
Create a VSI to provide access services for the attached compute servers.
N/A
gateway vsi-interface 13313
Specify the gateway interface for the VSI.
N/A
Enable ARP/ND flood suppression.
N/A
vxlan 13313
vxlan 13313
Create VXLAN 13313.
N/A
Return to VSI view.
N/A
N/A
N/A
N/A
N/A
N/A
interface Vsi-interface 13314
N/A
N/A
ip address 197.32.14.254 255.255.255.0 sub
ipv6 nd ra prefix FD00:0:97B0:1014::/64 no-advertise
 ipv6 address FD00:0:97B0:1014::FFFF/64
N/A
N/A
N/A
N/A
N/A
vsi SDN_VSI_13314
vsi SDN_VSI_13314
N/A
gateway vsi-interface 13314
N/A
N/A
vxlan 13314
vxlan 13314
Create VXLAN 13314.
N/A
Return to VSI view.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
l3-vni 10001
l3-vni 10001
Assign an L3VNI (also called an L3 VXLAN ID) to the VSI interface.
N/A
N/A
N/A
l3-vni 10002
l3-vni 10002
N/A
N/A
Create the VSI interface for L3 connectivity to compute servers.
N/A
N/A
N/A
l3-vni 10000
l3-vni 10000
N/A
bgp 65530
bgp 65530
N/A
non-stop-routing
non-stop-routing
Enable BGP non-stop routing (NSR).
N/A
router-id 197.32.241.43
router-id 197.32.241.44
N/A
group evpn internal
group evpn internal
N/A
peer evpn connect-interface loopback 0
N/A
N/A
N/A
N/A
peer evpn enable
peer evpn enable
N/A
N/A
N/A
N/A
balance 4
balance 4
N/A
N/A
N/A
N/A
balance 4
balance 4
N/A
N/A
Create a BGP-VPN instance for the VPN instance that contains compute servers, and enter BGP-VPN instance view.
N/A
N/A
balance 4
balance 4
N/A
N/A
N/A
balance 4
balance 4
N/A
N/A
Configuring ACs
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
interface Twenty-FiveGigE 1/0/2
interface Twenty-FiveGigE 1/0/4
Enter the view of the physical port connected to compute servers.
N/A
N/A
undo port trunk permit vlan 1
Remove the port from VLAN 1.
N/A
port trunk permit vlan 3313
port trunk permit vlan 3314
Assign the port to a VLAN.
N/A
port trunk pvid vlan 3313
port trunk pvid vlan 3314
Set the PVID of the port.
N/A
service-instance 3313
service-instance 3314
N/A
encapsulation untagged
Configure the Ethernet service instance to match any frames that do not have an 802.1Q VLAN tag.
N/A
xconnect vsi SDN_VSI_13313 access-mode ethernet
xconnect vsi SDN_VSI_13314 access-mode ethernet
Map the Ethernet service instance to the specified VSI.
N/A
Configuring leaf nodes (Leaf 5 and Leaf 6)
Procedure summary
·           Configuring L3VPN
·           Configuring ACs
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
router id 197.32.241.45
router id 197.32.241.46
N/A
ospf 65530
ospf 65530
N/A
non-stop-routing
non-stop-routing
N/A
area 0.0.0.0
area 0.0.0.0
N/A
interface loopback0
interface loopback0
N/A
N/A
N/A
N/A
N/A
Configuring L3VPN
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
N/A
ip address 197.32.241.45 255.255.255.255
ip address 197.32.241.46 255.255.255.255
N/A
N/A
N/A
ip address 197.32.241.67 255.255.255.255
N/A
N/A
N/A
N/A
N/A
 route-distinguisher 5:10000
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 6:10000
 address-family ipv4
address-family ipv6
 address-family evpn
N/A
 route-distinguisher 5:10001
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 6:10001
 address-family ipv4
address-family ipv6
 address-family evpn
N/A
 route-distinguisher 5:10002
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 6:10002
 address-family ipv4
address-family ipv6
 address-family evpn
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
drni system-mac 0c3a-fa36-b811
drni keepalive ip destination 197.32.241.78 source 197.32.241.77 vpn-instance auto-online-mlag
drni keepalive ip destination 197.32.241.77 source 197.32.241.78 vpn-instance auto-online-mlag
N/A
N/A
interface
N/A
N/A
N/A
ip address 197.32.241.77 255.255.255.252
ip address 197.32.241.78 255.255.255.252
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
ip address 197.32.241.145 255.255.255.0
ip address 197.32.241.146 255.255.255.0
N/A
N/A
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
N/A
N/A
N/A
N/A
vlan all
vlan all
N/A
evpn drni group 197.32.241.67
N/A
evpn drni local 197.32.241.45 remote 197.32.241.46
evpn drni local 197.32.241.46 remote 197.32.241.45
evpn global-mac 0c3a-fa36-b035
N/A
interface Vsi-interface13342
N/A
N/A
ip address 197.32.42.254 255.255.255.0 sub
ipv6 nd ra prefix FD00:0:97B0:1042::/64 no-advertise
 ipv6 address FD00:0:97B0:1042::FFFF/64
N/A
N/A
N/A
N/A
N/A
vsi SDN_VSI_13342
vsi SDN_VSI_13342
N/A
gateway vsi-interface 13342
N/A
N/A
vxlan 13342
vxlan 13342
Create VXLAN 13342.
N/A
Return to VSI view.
N/A
N/A
N/A
N/A
N/A
N/A
interface Vsi-interface13316
N/A
N/A
ip address 197.32.162 54 255.255.255.0 sub
ipv6 nd ra prefix FD00:0:97B0:1016::/64 no-advertise
 ipv6 address FD00:0:97B0:1016::FFFF/64
ip address 197.32.16.254 255.255.255.0 sub
N/A
N/A
N/A
N/A
N/A
vsi SDN_VSI_13316
vsi SDN_VSI_13316
N/A
gateway vsi-interface 13316
N/A
N/A
vxlan 13316
vxlan 13316
Create VXLAN 13313.
N/A
Return to VSI view.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
l3-vni 10001
l3-vni 10001
N/A
N/A
N/A
N/A
l3-vni 10002
l3-vni 10002
N/A
N/A
N/A
N/A
l3-vni 10000
l3-vni 10000
N/A
N/A
bgp 65530
bgp 65530
N/A
non-stop-routing
non-stop-routing
N/A
router-id 197.32.241.45
router-id 197.32.241.46
N/A
group evpn internal
group evpn internal
N/A
N/A
N/A
N/A
N/A
peer evpn enable
peer evpn enable
N/A
N/A
N/A
N/A
balance 4
balance 4
N/A
N/A
N/A
N/A
balance 4
balance 4
N/A
N/A
N/A
N/A
balance 4
balance 4
N/A
network 197.32.42.9 255.255.255.255
N/A
N/A
balance 4
balance 4
N/A
N/A
Configuring ACs
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
interface Twenty-FiveGigE 1/0/6
N/A
N/A
N/A
port trunk permit vlan 3342
port trunk permit vlan 3316
N/A
port trunk pvid vlan 3342
port trunk pvid vlan 3316
N/A
service-instance 3342
service-instance 3316
N/A
N/A
xconnect vsi SDN_VSI_13342 access-mode ethernet
xconnect vsi SDN_VSI_13316 access-mode ethernet
N/A
Configuring border devices (Border1 and Border2)
Procedure summary
·           Configuring the routing protocols on the underlay network
·           Configuring L3VPNs
·           Configuring the DR aggregate links connecting border devices to the Layer 3 device on the external network
·           Configuring the links connecting border devices to spine devices
·           Configuring the EVPN distributed gateways
Border1 (S6850)
Border2 (S6850)
Remarks
router id 197.32.241.47
router id 197.32.241.48
N/A
ospf 65530
ospf 65530
Enable OSPF process 65530.
N/A
non-stop-routing
non-stop-routing
Enable OSPF NSR.
N/A
Configure the router as a stub router during reboot and specify the timeout time. Specify the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535.
Execute this command to accelerate network convergence.
area 0.0.0.0
area 0.0.0.0
N/A
interface LoopBack0
interface LoopBack0
Create interface Loopback 0 and enter its view.
N/A
N/A
N/A
interface LoopBack2
interface LoopBack2
Create interface Loopback 2 and enter its view.
N/A
N/A
Configuring L3VPNs
Border1 (S6850)
Border2 (S6850)
Remarks
interface LoopBack0
interface LoopBack0
N/A
ip address 197.32.241.47 255,255,255,255
ip address 197.32.241.48 255.255.255.255
N/A
N/A
interface LoopBack2
interface LoopBack2
N/A
ip address 197.32.241.86 255,255,255,255
ip address 197.32.241.86 255.255.255.255
N/A
N/A
N/A
N/A
N/A
 route-distinguisher 7:10000
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 8:10000
 address-family ipv4
address-family ipv6
 vpn-target 0:10000 1:10000 0.39.18.0:10000 0.39.17.0:10000 export-extcommunity address-family evpn
Configure the VPN instance for user services. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4 address family and EVPN address family.
N/A
 route-distinguisher 7:10001
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 8:10001
 address-family ipv4
address-family ipv6
 address-family evpn
Configure the VPN instance for the north-south firewall service. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4 address family and EVPN address family.
N/A
 route-distinguisher 7:10002
 address-family ipv4
address-family ipv6
 address-family evpn
 route-distinguisher 8:10002
 address-family ipv4
address-family ipv6
 address-family evpn
Configure the VPN instance for the east-west firewall service. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4 address family and EVPN address family.
ip vpn-instance external_vpn_1001
 route-distinguisher 1:1001
 address-family ipv4
  vpn-target 0:1001 1:1001 1:10000 import-extcommunity
  vpn-target 1:1001 export-extcommunity
 address-family ipv6
 address-family evpn
 route-distinguisher 2:1001
 address-family ipv4
 address-family ipv6
 address-family evpn
Configure the VPN instance for the external network users. Set an RD for the VPN instance, and set the import and export RTs for the VPN instance IPv4 address family and EVPN address family.
N/A
ip route-static vpn-instance ZHTESTCTVRF 0.0.0.0 0 vpn-instance external_vpn_1001 197.32.224.18
Configure the default IPv4 route from the VPN instance of the user services to the Layer 3 devices in the VPN instance of the external network.
N/A
ipv6 route-static vpn-instance ZHTESTCTVRF :: 0 vpn-instance external_vpn_1001 FD00:0:97B0:2::F description SDN_ROUTE
Configure the default IPv6 route from the VPN instance of the user services to the Layer 3 devices in the VPN instance of the external network.
N/A
Border1 (S6850)
Border2 (S6850)
Remarks
 drni system-mac 0c3a-fa38-9c5f
drni keepalive ip destination 197.32.241.94 source 197.32.241.93 vpn-instance auto-online-mlag
drni keepalive ip destination 197.32.241.93 source 197.32.241.94 vpn-instance auto-online-mlag
Configure the destination and source IP addresses of keepalive packets.
Configure DRNI MAD to shut down the uplink interfaces when the DR system splits.
N/A
interface
N/A
Configure the interface for the keepalive link to operate in route mode as a Layer 3 interface.
N/A
Associate the interface for the keepalive link with a VPN instance.
N/A
ip address 197.32.241.93 255,255,255,252
ip address 197.32.241.94 255.255.255.252
Assign an IP address to the interface for the keepalive link.
N/A
N/A
N/A
Configure the aggregate interface to operate in dynamic aggregation mode.
N/A
N/A
N/A
Assign the physical port for the IPL to the aggregation group (aggregation group 256).
N/A
N/A
N/A
N/A
Set the PVID of the trunk port to 4094.
N/A
N/A
N/A
N/A
ip address 197.32.241.147 255.255.255.0
ip address 197.32.241.148 255.255.255.0
N/A
N/A
Border1 (S6850)
Border2 (S6850)
Remarks
Create a DR aggregate interface connecting to the Layer 3 device on the external network.
N/A
Configure the aggregate interface connecting to the Layer 3 device on the external network to operate in dynamic aggregation mode.
N/A
port drni group 1
port drni group 1
N/A
Set the link type of DR aggregate interface 257 to trunk.
N/A
port trunk permit vlan 1 1001
Assign DR aggregate interface 257 to VLAN 1001.
N/A
N/A
Enter the view of the physical interface connecting to the Layer 3 device on the external network.
N/A
Set the link type to trunk for the physical interface connecting to the Layer 3 device on the external network.
N/A
Assign the physical interface connecting to the Layer 3 device on the external network to VLAN 1001.
N/A
Assign the physical interface connecting to the Layer 3 device on the external network to aggregation group 257.
N/A
N/A
interface Vlan-interface1001
N/A
Configure the VLAN interface connecting to the Layer 3 device on the external network.
N/A
ip binding vpn-instance external_vpn_1001
N/A
Associate the VLAN interface connecting to the Layer 3 device on the external network with a VPN instance, which is different from the VPN instance of user services.
N/A
ip address 197.32.224.17 255.255.255.252 sub
N/A
Configure the IP address for connecting to the Layer 3 device on the external network to implement a dual-active gateway.
N/A
mac-address 3c8c-404e-dd46
N/A
Assign a MAC address to the interface connecting to the Layer 3 device on the external network.
N/A
ipv6 address FD00:0:97B0:2::1/64
N/A
Assign an IPv6 address to the interface connecting to the Layer 3 device on the external network.
N/A
Border1 (S6850)
Border2 (S6850)
Remarks
Enter the view of the uplink interface, the physical interface connecting to Spine A.
N/A
Configure the uplink interface to operate in route mode as a Layer 3 interface.
N/A
Configure the uplink interface to borrow the IP address of interface Loopback 0.
N/A
N/A
Enable OSPF on the uplink interface.
N/A
Disable source MAC check on the uplink interface.
N/A
N/A
Configure advertisable TLVs on the interface.
N/A
N/A
Enter the view of the uplink interface, the physical interface connecting to Spine B.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
N/A
Border1 (S6850)
Border2 (S6850)
Remarks
l2vpn enable
l2vpn enable
Enable L2VPN.
N/A
N/A
This setting avoids the conflict between automatically learned ARP/ND entries and ARP/ND entries advertised through EVPN.
This setting avoids the conflict between automatically learned MAC address entries and MAC address entries advertised through EVPN.
N/A
vlan all
vlan all
Bulk create VLANs 1 through 4094.
N/A
evpn drni group 197.32.241.86
Enable EVPN distributed relay and specify the virtual VTEP address.
N/A
evpn global-mac 0c3a-fa38-2211
N/A
interface Vsi-interface1001
Create the VSI interface to be associated with the L3VNI of the external network device.
N/A
Bind the interface to the VPN instance of the external network device.
N/A
l3-vni 1001
l3-vni 1001
Associate the interface with an L3VNI.
N/A
interface Vsi-interface 10001
Create the VSI interface to be associated with the L3VNI of the north-south firewall.
N/A
Bind the interface to the VPN instance of the north-south firewall.
N/A
l3-vni 10001
l3-vni 10001
N/A
N/A
interface Vsi-interface 10002
Create the VSI interface to be associated with the L3VNI of the east-west firewall.
N/A
Bind the interface to the VPN instance of the east-west firewall.
N/A
l3-vni 10002
l3-vni 10002
N/A
N/A
Create the VSI interface to be associated with the L3VNI of the server.
N/A
Bind the interface to the VPN instance of the server.
N/A
l3-vni 10000
l3-vni 10000
N/A
N/A
bgp 65530
bgp 65530
Enable the BGP instance and enter BGP instance view.
N/A
non-stop-routing
non-stop-routing
Enable BGP NSR.
N/A
router-id 197.32.241.47
router-id 197.32.241.48
Specify a router ID for the BGP instance.
N/A
group evpn internal
group evpn internal
N/A
Specify a source interface for establishing TCP connections to the peer group.
N/A
N/A
N/A
N/A
peer evpn enable
peer evpn enable
Enable BGP to exchange BGP EVPN routes with peer group evpn.
N/A
nexthop evpn-drni group-address
Enable the device to replace the next hop in advertised BGP EVPN routes with the virtual VTEP address.
Execute this command on the border DR system to advertise its virtual address tunnel.
Enter the view of the BGP-VPN instance of the east-west firewall.
N/A
Enter BGP-VPN IPv4 unicast address family view.
N/A
balance 4
balance 4
N/A
Enter BGP-VPN IPv6 unicast address family view.
N/A
balance 4
balance 4
N/A
Enter the view of the BGP-VPN instance of the north-south firewall.
N/A
N/A
balance 4
balance 4
N/A
N/A
balance 4
balance 4
N/A
Enter the view of the BGP-VPN instance of the server.
N/A
   default-route imported
   balance 4
   import-route static
   balance 4
   import-route static
Enter BGP-VPN IPv4 unicast address family view and configure routes to be redistributed into BGP.
N/A
   balance 4
   import-route static
   balance 4
   import-route static
Enter BGP-VPN IPv6 unicast address family view and configure routes to be redistributed into BGP.
N/A
   balance 4
   network 197.32.224.16 255.255.255.252
   network 197.32.224.18 255.255.255.255
   balance 4
   network FD00:0:97B0:2:: 64
   network FD00:0:97B0:2::F 128
   balance 4
   balance 4
Enter the view of the BGP-VPN instance connecting to the Layer 3 device on the external network. Enter BGP-VPN IPv4/IPv6 unicast address family view.  Inject networks to the BGP routing table and configure BGP to advertise the networks.
N/A
Configuring the spine devices
Procedure summary
·           Configuring the links connecting spine devices to leaf/border devices
·           Configuring the spine devices as route reflectors
Spine A (S12500X)
Spine B (S12500X)
Remarks
interface LoopBack0
interface LoopBack0
N/A
ip address 197.32.241.37 255.255.255.255
ip address 197.32.241.38 255.255.255.255
N/A
N/A
router id 197.32.241.37
router id 197.32.241.38
N/A
ospf 65530
ospf 65530
N/A
non-stop-routing
non-stop-routing
Enable OSPF NSR.
N/A
area 0.0.0.0
area 0.0.0.0
N/A
N/A
interface LoopBack0
interface LoopBack0
N/A
N/A
Spine A (S12500X)
Spine B (S12500X)
Remarks
interface HundredGigE1/0/1
Enter the view of the downlink interface, the physical interface connecting to Leaf 1.
N/A
Configure the downlink interface to operate in route mode as a Layer 3 interface.
N/A
Configure the downlink interface to borrow the IP address of interface Loopback 0.
N/A
N/A
Enable OSPF on the downlink interface.
N/A
N/A
Enter the view of the downlink interface, the physical interface connecting to Leaf 2.
N/A
N/A
N/A
N/A
N/A
N/A
Enter the view of the downlink interface, the physical interface connecting to Leaf 3.
N/A
N/A
N/A
N/A
N/A
N/A
interface HundredGigE1/0/4
Enter the view of the downlink interface, the physical interface connecting to Leaf 4.
N/A
N/A
N/A
N/A
N/A
N/A
Enter the view of the downlink interface, the physical interface connecting to Leaf 5.
N/A
N/A
N/A
N/A
N/A
N/A
interface HundredGigE1/0/6
Enter the view of the downlink interface, the physical interface connecting to Leaf 6.
N/A
N/A
N/A
N/A
N/A
N/A
interface HundredGigE1/0/7
Enter the view of the uplink interface, the physical interface connecting to Border1.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface HundredGigE1/0/8
Enter the view of the uplink interface, the physical interface connecting to Border2.
N/A
N/A
N/A
N/A
N/A
N/A
N/A
interface range HundredGigE1/0/1 to HundredGigE1/0/8
Enter the view of the interfaces connecting to leaf devices.
N/A
N/A
N/A
Spine A (S12500X)
Spine B (S12500X)
Remarks
bgp 65530
bgp 65530
N/A
non-stop-routing
non-stop-routing
Enable BGP NSR.
N/A
router-id 197.32.241.37
router-id 197.32.241.38
N/A
group evpn internal
group evpn internal
N/A
N/A
peer 197.32.241.41 group evpn
Added Leaf 1 to peer group evpn.
N/A
peer 197.32.241.42 group evpn
Added Leaf 2 to peer group evpn.
N/A
peer 197.32.241.43 group evpn
Added Leaf 3 to peer group evpn.
N/A
peer 197.32.241.44 group evpn
Added Leaf 4 to peer group evpn.
N/A
peer 197.32.241.45 group evpn
Added Leaf 5 to peer group evpn.
N/A
peer 197.32.241.46 group evpn
Added Leaf 6 to peer group evpn.
N/A
peer 197.32.241.47 group evpn
Added Border 1 to peer group evpn.
N/A
peer 197.32.241.48 group evpn
Added Border 2 to peer group evpn.
N/A
N/A
undo policy vpn-target
Disable route target-based filtering of incoming BGP EVPN routes.
N/A
peer evpn enable
peer evpn enable
N/A
peer evpn reflect-client
Configure the spine node as a route reflector and specify peer group evpn as a client.
N/A
Configuring the links connecting the east-west/north-south firewalls to leaf devices
East-west firewall
North-south firewall
Remarks
vlan 999 1000
vlan 997 998
N/A
interface Vlan-interface 999
 ip address 197.32.224.30 255.255.255.252
ipv6 address FD00:0:97B0:102::F/64
interface Vlan-interface 997
 ip address 197.32.224.22 255.255.255.252
ipv6 address FD00:0:97B0:100::F/64
Configure a VLAN interface for forwarding packets at Layer 3.
N/A
interface Vlan-interface1000
 ip address 197.32.224.34 255.255.255.252
ipv6 address FD00:0:97B0:103::F/64
interface Vlan-interface 998
 ip address 197.32.224.26 255.255.255.252
ipv6 address FD00:0:97B0:101::F/64
N/A
 port trunk permit vlan all
Configure the firewall to access the DR system formed by leaf devices through an aggregate interface.
N/A
interface HundredGigE2/0/29
 port link-mode bridge
 flow-interval 5
interface HundredGigE3/0/29
 flow-interval 5
Assign the physical interface connecting to Leaf 1 to an aggregation group.
N/A
interface HundredGigE2/0/30
 flow-interval 5
interface HundredGigE3/0/30
 flow-interval 5
Assign the physical interface connecting to Leaf 2 to an aggregation group.
N/A
ip route-static 197.32.0.0 16 197.32.224.33
ipv6 route-static FD00:0:97B0::/24 FD00:0:97B0:103::1
ip route-static 197.32.0.0 16 197.32.224.25
ipv6 route-static FD00:0:97B0::/24 FD00:0:97B0:101::1
Create static routes for routing traffic back to the connected DR system at the leaf tier.
This setting is for illustration only. In a real deployment, you can configure a firewall by using any method as long as the firewall can return the traffic to the VXLAN network back to the leaf device connected to it.
Configuring the links connecting L3 devices and border devices
L3 device
Remarks
vlan all
N/A
Configure VLAN-interface 1001 for forwarding packets at Layer 3 to the external network.
N/A
ip address 197.32.225.18 255.255.255.252
Assign an IPv4 address to an interface.
N/A
ipv6 address FD00:1:97B0:2::F/64
Assign an IPv6 address to an interface.
N/A
 port trunk permit vlan 1001
Configure the aggregate interface to access the DR system formed by border devices.
N/A
interface HundredGigE4/0/29
 flow-interval 5
Assign the physical interface connecting to Border1 to an aggregation group.
N/A
interface HundredGigE4/0/30
 port trunk permit vlan1001
 flow-interval 5
Assign the physical interface connecting to Border2 to an aggregation group.
N/A
ip route-static 197.32.0.0 16 197.32.224.17
ipv6 route-static FD00:: 16 FD00:0:97B0:2::1
Create static routes for routing traffic back to the connected leaf devices.
N/A
Configuring the DHCP server (single-homed to Leaf 5)
Attach a virtual DHCP server to Twenty-FiveGigE 1/0/2 of Leaf 5. The DHCP server runs Windows Server 2012 and is assigned IP address 197.32.42.9.
To add the DHCP role on Windows Server 2012:
1.      As shown in Figure 2, click Add Role and Features.
Figure 2 Server management page
2.      On the Add Role and Features Wizard page, select options as shown in Figure 3, Figure 4, and Figure 5. Click Next until the DHCP service is installed.
Figure 3 Add Role and Features Wizard (I)
Figure 4 Add Role and Features Wizard (II)
Figure 5 Add Role and Features Wizard (III)
3.      Enable the DHCP service, and configure the DHCP address pool to allocate IP addresses in the range of 197.32.13.50 and 197.32.13.100.
Figure 6 Configuring the DHCP address pool
Configuring DHCP relay (with DHCP clients single-homed to Leaf 3)
Configuring service leaf nodes (Leaf 1 and Leaf 2)
Leaf 1 (S6850)
Leaf 2 (S6850)
dhcp enable
dhcp enable
Enable DHCP.
Enable MAC address table lookup for DHCP replies that do not have request forwarding information.
Configuring DHCP client-attached leaf nodes (Leaf 3 and Leaf 4)
Leaf 3 (S6850)
Leaf 4 (S6850)
Remarks
dhcp enable
dhcp enable
Enable DHCP.
N/A
This setting is required on devices that provide both distributed EVPN gateway and DHCP relay services.
Enter the view of the VSI interface that provides distributed gateway service for attached servers.
N/A
dhcp select relay
dhcp select relay
Enable the VSI interface to operate as a DHCP relay agent.
N/A
dhcp relay server-address 197.32.42.9
Specify the IP address of the DHCP server for the DHCP relay agent.
N/A
Configure the DHCP relay agent to discard the DHCP requests received from VXLAN tunnels.
N/A
Configuring DHCP server-attached leaf nodes (Leaf 5 and Leaf 6)
Leaf 5 (S6850)
Leaf 6 (S6850)
Remarks
dhcp enable
dhcp enable
Enable DHCP.
N/A
Configuring IPv4/IPv6 microsegments and service chains
Leaf 1 (S6850)
Leaf 2 (S6850)
microsegment enable
microsegment enable
Enable microsegmentation.
microsegment 10001 name SDN_EPG_10001
Create microsegment 10001 and enter its view.
member ipv4 197.32.14.0 255.255.255.0 vpn-instance ZHTESTCTVRF
Add an IPv4 member to microsegment 10001.
member ipv4 197.32.16.0 255.255.255.0 vpn-instance ZHTESTCTVRF
member ipv6 FD00:0:97B0:1014:: 64 vpn-instance ZHTESTCTVRF
Add an IPv6 member to microsegment 10001.
member ipv6 FD00:0:97B0:1016:: 64 vpn-instance ZHTESTCTVRF
microsegment 10002 name SDN_EPG_10002
Create microsegment 10002 and enter its view.
member ipv4 197.32.42.0 255.255.255.0 vpn-instance ZHTESTCTVRF
Add an IPv4 member to microsegment 10002.
member ipv6 FD00:0:97B0:1042:: 64 vpn-instance ZHTESTCTVRF
Add an IPv6 member to microsegment 10002.
microsegment 10003 name SDN_EPG_10003
Create microsegment 10003 and enter its view.
member ipv4 0.0.0.0 0.0.0.0 vpn-instance ZHTESTCTVRF
Add an IPv4 member to microsegment 10003.
member ipv6 :: 0 vpn-instance ZHTESTCTVRF
Add an IPv6 member to microsegment 10003.
microsegment 10004 name SDN_EPG_10004
Create microsegment 10004 and enter its view.
member ipv4 197.32.42.9 255.255.255.255 vpn-instance ZHTESTCTVRF
Add an IPv4 member to microsegment 10004.
policy-based-route SDN_SC_L3_10001 permit node 0
Configure an IPv4 PBR policy on VSI-interface 10001. This policy directs north-south traffic to firewall NS.
if-match service-chain path-id 1 path-index 1
Set a service chain match criterion to match the south-to-north traffic from microsegment 10001.
apply next-hop vpn-instance ZHTESTCTFWNS01VRF 197.32.224.22
Redirect traffic to firewall NS.
policy-based-route SDN_SC_L3_10001 permit node 1
if-match service-chain path-id 8388609 path-index 1
Set a service chain match criterion to match the north-to-south traffic from microsegment 10003.
apply next-hop vpn-instance ZHTESTCTFWNS01VRF 197.32.224.26
policy-based-route SDN_SC_L3_10002 permit node 0
Configure an IPv4 PBR policy on VSI-interface 10002. This policy directs east-west traffic to firewall EW.
if-match service-chain path-id 2 path-index 1
Set a service chain match criterion to match the east-west traffic from microsegment 10001.
apply next-hop vpn-instance ZHTESTCTFWEW01VRF 197.32.224.30
Redirect traffic to firewall EW.
policy-based-route SDN_SC_L3_10002 permit node 1
if-match service-chain path-id 8388610 path-index 1
Set a service chain match criterion to match the east-west traffic from microsegment 10002 and microsegment 10004.
apply next-hop vpn-instance ZHTESTCTFWEW01VRF 197.32.224.34
ipv6 policy-based-route SDN_SC_L3_10001 permit node 0
Configure an IPv6 PBR policy on VSI-interface 10001. This policy directs north-south traffic to firewall NS.
apply next-hop vpn-instance ZHTESTCTFWNS01VRF FD00:0:97B0:100::F
ipv6 policy-based-route SDN_SC_L3_10001 permit node 1
apply next-hop vpn-instance ZHTESTCTFWNS01VRF FD00:0:97B0:101::F
ipv6 policy-based-route SDN_SC_L3_10002 permit node 0
Configure an IPv6 PBR policy on VSI-interface 10002. This policy directs east-west traffic to firewall EW.
apply next-hop vpn-instance ZHTESTCTFWEW01VRF FD00:0:97B0:102::F
ipv6 policy-based-route SDN_SC_L3_10002 permit node 1
apply next-hop vpn-instance ZHTESTCTFWEW01VRF FD00:0:97B0:103::F
Create the VSI interface for L3 connectivity to firewall NS and enter its view.
ip policy-based-route SDN_SC_L3_10001
Deploy the IPv4 PBR policy on VSI interface 10001.
Deploy the IPv6 PBR policy on VSI interface 10001.
Create the VSI interface for L3 connectivity to firewall EW and enter its view.
ip policy-based-route SDN_SC_L3_10002
Deploy the IPv4 PBR policy on VSI interface 10002.
Deploy the IPv6 PBR policy on VSI interface 10002.
Configuring Leaf 3 and Leaf 4
Leaf 3 (S6850)
Leaf 4 (S6850)
microsegment enable
microsegment enable
acl advanced name 13314_1
Create IPv4 ACL 13314_1 and enter its view.
This ACL will be applied to IPv4 PBR policy node 0 in VSI 13314.
rule 0 permit udp vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10004
Create a rule for the ACL.
This rule matches UDP traffic transmitted from microsegment 10001 to microsegment 10004.
acl advanced name 13314_2
Create IPv4 ACL 13314_2 and enter its view.
This ACL will be applied to IPv4 PBR policy node 1 in VSI 13314.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10004
This rule matches IPv4 traffic transmitted from microsegment 10001 to microsegment 10004.
acl advanced name 13314_3
Create IPv4 ACL 13314_3 and enter its view.
This ACL will be applied to IPv4 PBR policy node 2 in VSI 13314.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10002
This rule matches IPv4 traffic transmitted from microsegment 10001 to microsegment 10002.
acl advanced name 13314_4
Create IPv4 ACL 13314_4 and enter its view.
This ACL will be applied to IPv4 PBR policy node 3 in VSI 13314.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10003
This rule matches IPv4 traffic transmitted from microsegment 10001 to microsegment 10003.
acl advanced name 13314_5
Create IPv4 ACL 13314_5 and enter its view.
This ACL will be applied to IPv4 PBR policy node 4 in VSI 13314.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10001
This rule matches IPv4 traffic transmitted from microsegment 10001 to microsegment 10001.
acl advanced name 13314_6
Create IPv4 ACL 13314_6 and enter its view.
This ACL will be applied to IPv4 PBR policy node 5 in VSI 13314.
rule 0 permit ip
rule 0 permit ip
This rule permits all IPv4 traffic.
acl ipv6 advanced name 13314_1
Create IPv6 ACL 13314_1 and enter its view.
This ACL will be applied to IPv6 PBR policy node 0 in VSI 13314.
acl ipv6 advanced name 13314_2
Create IPv6 ACL 13314_2 and enter its view.
This ACL will be applied to IPv6 PBR policy node 1 in VSI 13314.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10004
This rule matches IPv6 traffic transmitted from microsegment 10001 to microsegment 10004.
acl ipv6 advanced name 13314_3
Create IPv6 ACL 13314_3 and enter its view.
This ACL will be applied to IPv6 PBR policy node 2 in VSI 13314.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10002
This rule matches IPv6 traffic transmitted from microsegment 10001 to microsegment 10002.
acl ipv6 advanced name 13314_4
Create IPv6 ACL 13314_4 and enter its view.
This ACL will be applied to IPv6 PBR policy node 3 in VSI 13314.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10003
This rule matches IPv6 traffic transmitted from microsegment 10001 to microsegment 10003.
acl ipv6 advanced name 13314_5
Create IPv6 ACL 13314_5 and enter its view.
This ACL will be applied to IPv6 PBR policy node 4 in VSI 13314.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10001 destination microsegment 10001
This rule matches IPv6 traffic transmitted from microsegment 10001 to microsegment 10001.
acl ipv6 advanced name 13314_6
Create IPv6 ACL 13314_6 and enter its view.
This ACL will be applied to IPv6 PBR policy node 5 in VSI 13314.
rule 0 permit ipv6
rule 0 permit ipv6
This rule permits all IPv6 traffic.
policy-based-route SDN_SC_13314 permit node 0
Create node 0 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_1
Configure IPv4 ACL 13314_1 as an ACL match criterion for IPv4 PBR policy node 0.
policy-based-route SDN_SC_13314 permit node 1
Create node 1 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_2
Configure IPv4 ACL 13314_2 as an ACL match criterion for IPv4 PBR policy node 1.
Set a next hop for packets that match IPv4 PBR policy node 1.
apply service-chain path-id 2 path-index 1
Set service chain information for packets that match IPv4 PBR policy node 1.
policy-based-route SDN_SC_13314 permit node 2
Create node 2 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_3
Configure IPv4 ACL 13314_3 as an ACL match criterion for IPv4 PBR policy node 2.
Set a next hop for packets that match IPv4 PBR policy node 2.
Set service chain information for packets that match IPv4 PBR policy node 2.
policy-based-route SDN_SC_13314 permit node 3
Create node 3 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_4
Configure IPv4 ACL 13314_4 as an ACL match criterion for IPv4 PBR policy node 3.
Set a next hop for packets that match IPv4 PBR policy node 3.
apply service-chain path-id 1 path-index 1
Set service chain information for packets that match IPv4 PBR policy node 3.
policy-based-route SDN_SC_13314 permit node 4
policy-based-route SDN_SC_13314 permit node4
Create node 4 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_5
Configure IPv4 ACL 13314_5 as an ACL match criterion for IPv4 PBR policy node 4.
policy-based-route SDN_SC_13314 permit node 5
Create node 5 for IPv4 PBR policy SDN_SC_13314 and enter its view.
if-match acl name 13314_6
Configure IPv4 ACL 13314_6 as an ACL match criterion for IPv4 PBR policy node 5.
apply output-interface NULL0
Set NULL0 as the output interface for packets that match IPv4 PBR policy node 5. These packets will be discarded.
interface Vsi-interface13314
Create VSI interface 13314 and enter its view.
ip policy-based-route SDN_SC_13314
Deploy IPv4 PBR policy SDN_SC_13314 on VSI interface 13314.
ipv6 policy-based-route SDN_SC_13314 permit node 0
Create node 0 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_1 as an ACL match criterion for IPv6 PBR policy node 0.
ipv6 policy-based-route SDN_SC_13314 permit node 1
Create node 1 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_2 as an ACL match criterion for IPv6 PBR policy node 1.
Set a next hop for packets that match IPv6 PBR policy node 1.
Set service chain information for packets that match IPv6 PBR policy node 1.
ipv6 policy-based-route SDN_SC_13314 permit node 2
Create node 2 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_3 as an ACL match criterion for IPv6 PBR policy node 2.
Set a next hop for packets that match IPv6 PBR policy node 2.
Set service chain information for packets that match IPv6 PBR policy node 2.
ipv6 policy-based-route SDN_SC_13314 permit node 3
Create node 3 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_4 as an ACL match criterion for IPv6 PBR policy node 3.
Set a next hop for packets that match IPv6 PBR policy node 3.
Set service chain information for packets that match IPv6 PBR policy node 3.
ipv6 policy-based-route SDN_SC_13314 permit node 4
Create node 4 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_5 as an ACL match criterion for IPv6 PBR policy node 4.
ipv6 policy-based-route SDN_SC_13314 permit node 5
Create node 5 for IPv6 PBR policy SDN_SC_13314 and enter its view.
Configure IPv6 ACL 13314_6 as an ACL match criterion for IPv6 PBR policy node 5.
Set NULL0 as the output interface for packets that match IPv6 PBR policy node 5. These packets will be discarded.
Deploy IPv6 PBR policy SDN_SC_13314 on VSI interface 13314.
Configuring Leaf 5 and Leaf 6
Leaf 5 (S6850)
Leaf 6 (S6850)
microsegment enable
microsegment enable
acl advanced name 13316_1
Create IPv4 ACL 13316_1 and enter its view.
This ACL will be applied to IPv4 PBR policy node 0 in VSI 13316.
acl advanced name 13316_2
Create IPv4 ACL 13316_2 and enter its view.
This ACL will be applied to IPv4 PBR policy node 1 in VSI 13316.
acl advanced name 13316_3
Create IPv4 ACL 13316_3 and enter its view.
This ACL will be applied to IPv4 PBR policy node 2 in VSI 13316.
acl advanced name 13316_4
Create IPv4 ACL 13316_4 and enter its view.
This ACL will be applied to IPv4 PBR policy node 3 in VSI 13316.
acl advanced name 13316_5
Create IPv4 ACL 13316_5 and enter its view.
This ACL will be applied to IPv4 PBR policy node 4 in VSI 13316.
acl advanced name 13316_6
Create IPv4 ACL 13316_6 and enter its view.
This ACL will be applied to IPv4 PBR policy node 5 in VSI 13316.
rule 0 permit ip
rule 0 permit ip
acl ipv6 advanced name 13316_1
Create IPv6 ACL 13316_1 and enter its view.
This ACL will be applied to IPv6 PBR policy node 0 in VSI 13316.
acl ipv6 advanced name 13316_2
Create IPv6 ACL 13316_2 and enter its view.
This ACL will be applied to IPv6 PBR policy node 1 in VSI 13316.
acl ipv6 advanced name 13316_3
Create IPv6 ACL 13316_3 and enter its view.
This ACL will be applied to IPv6 PBR policy node 2 in VSI 13316.
Manual or controller-based
acl ipv6 advanced name 13316_4
Create IPv6 ACL 13316_4 and enter its view.
This ACL will be applied to IPv6 PBR policy node 3 in VSI 13316.
acl ipv6 advanced name 13316_5
Create IPv6 ACL 13316_5 and enter its view.
This ACL will be applied to IPv6 PBR policy node 4 in VSI 13316.
acl ipv6 advanced name 13316_6
Create IPv6 ACL 13316_6 and enter its view.
This ACL will be applied to IPv6 PBR policy node 5 in VSI 13316.
rule 0 permit ipv6
rule 0 permit ipv6
policy-based-route SDN_SC_13316 permit node 0
Create node 0 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_1
Configure IPv4 ACL 13316_1 as an ACL match criterion for IPv4 PBR policy node 0.
policy-based-route SDN_SC_13316 permit node 1
Create node 1 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_2
Configure IPv4 ACL 13316_2 as an ACL match criterion for IPv4 PBR policy node 1.
policy-based-route SDN_SC_13316 permit node 2
Create node 2 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_3
Configure IPv4 ACL 13316_3 as an ACL match criterion for IPv4 PBR policy node 2.
policy-based-route SDN_SC_13316 permit node 3
Create node 3 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_4
Configure IPv4 ACL 13316_4 as an ACL match criterion for IPv4 PBR policy node 3.
policy-based-route SDN_SC_13316 permit node 4
policy-based-route SDN_SC_13316 permit node4
Create node 4 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_5
Configure IPv4 ACL 13316_5 as an ACL match criterion for IPv4 PBR policy node 4.
policy-based-route SDN_SC_13316 permit node 5
Create node 5 for IPv4 PBR policy SDN_SC_13316 and enter its view.
if-match acl name 13316_6
Configure IPv4 ACL 13316_6 as an ACL match criterion for IPv4 PBR policy node 5.
Create VSI interface 13316 and enter its view.
ip policy-based-route SDN_SC_13316
Deploy IPv4 PBR policy SDN_SC_13316 on VSI interface 13316.
ipv6 policy-based-route SDN_SC_13316 permit node 0
Create node 0 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_1 as an ACL match criterion for IPv6 PBR policy node 0.
ipv6 policy-based-route SDN_SC_13316 permit node 1
Create node 1 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_2 as an ACL match criterion for IPv6 PBR policy node 1.
ipv6 policy-based-route SDN_SC_13316 permit node 2
Create node 2 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_3 as an ACL match criterion for IPv6 PBR policy node 2.
ipv6 policy-based-route SDN_SC_13316 permit node 3
Create node 3 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_4 as an ACL match criterion for IPv6 PBR policy node 3.
ipv6 policy-based-route SDN_SC_13316 permit node 4
Create node 4 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_5 as an ACL match criterion for IPv6 PBR policy node 4.
ipv6 policy-based-route SDN_SC_13316 permit node 5
Create node 5 for IPv6 PBR policy SDN_SC_13316 and enter its view.
Configure IPv6 ACL 13316_6 as an ACL match criterion for IPv6 PBR policy node 5.
Deploy IPv6 PBR policy SDN_SC_13316 on VSI interface 13316.
acl advanced name 13342_1
Create IPv4 ACL 13342_1 and enter its view.
This ACL will be applied to IPv4 PBR policy node 0 in VSI 13342.
rule 0 permit udp vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10001
rule 1 permit ip vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10004
Create rules for the ACL:
·          Rule 0 matches UDP traffic transmitted from microsegment 10004 to microsegment 10001.
·          Rule 1 matches IPv4 traffic transmitted from microsegment 10002 to microsegment 10004.
acl advanced name 13342_2
Create IPv4 ACL 13342_2 and enter its view.
This ACL will be applied to IPv4 PBR policy node 1 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10002
This rule matches IPv4 traffic transmitted from microsegment 10004 to microsegment 10002.
acl advanced name 13342_3
Create IPv4 ACL 13342_3 and enter its view.
This ACL will be applied to IPv4 PBR policy node 2 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10001
This rule matches IPv4 traffic transmitted from microsegment 10004 to microsegment 10001.
acl advanced name 13342_4
Create IPv4 ACL 13342_4 and enter its view.
This ACL will be applied to IPv4 PBR policy node 3 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10001
This rule matches IPv4 traffic transmitted from microsegment 10002 to microsegment 10001.
acl advanced name 13342_5
Create IPv4 ACL 13342_5 and enter its view.
This ACL will be applied to IPv4 PBR policy node 4 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10003
This rule matches IPv4 traffic transmitted from microsegment 10002 to microsegment 10003.
acl advanced name 13342_6
Create IPv4 ACL 13342_6 and enter its view.
This ACL will be applied to IPv4 PBR policy node 5 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10003
This rule matches IPv4 traffic transmitted from microsegment 10004 to microsegment 10003.
acl advanced name 13342_7
Create IPv4 ACL 13342_7 and enter its view.
This ACL will be applied to IPv4 PBR policy node 6 in VSI 13342.
rule 0 permit ip vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10002
rule 1 permit ip vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10004
·          Rule 0 matches IPv4 traffic transmitted from microsegment 10002 to microsegment 10002.
·          Rule 1 matches IPv4 traffic transmitted from microsegment 10004 to microsegment 10004.
acl advanced name 13342_8
Create IPv4 ACL 13342_8 and enter its view.
This ACL will be applied to IPv4 PBR policy node 7 in VSI 13342.
rule 0 permit ip
rule 0 permit ip
acl ipv6 advanced name 13342_1
Create IPv6 ACL 13342_1 and enter its view.
This ACL will be applied to IPv6 PBR policy node 0 in VSI 13342.
rule 1 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10004
·          Rule 1 matches IPv6 traffic transmitted from microsegment 10002 to microsegment 10004.
acl ipv6 advanced name 13342_2
Create IPv6 ACL 13342_2 and enter its view.
This ACL will be applied to IPv6 PBR policy node 1 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10002
This rule matches IPv6 traffic transmitted from microsegment 10004 to microsegment 10002.
acl ipv6 advanced name 13342_3
Create IPv6 ACL 13342_3 and enter its view.
This ACL will be applied to IPv6 PBR policy node 2 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10001
This rule matches IPv6 traffic transmitted from microsegment 10004 to microsegment 10001.
acl ipv6 advanced name 13342_4
Create IPv6 ACL 13342_4 and enter its view.
This ACL will be applied to IPv6 PBR policy node 3 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10001
This rule matches IPv6 traffic transmitted from microsegment 10002 to microsegment 10001.
acl ipv6 advanced name 13342_5
Create IPv6 ACL 13342_5 and enter its view.
This ACL will be applied to IPv6 PBR policy node 4 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10003
This rule matches IPv6 traffic transmitted from microsegment 10002 to microsegment 10003.
acl ipv6 advanced name 13342_6
Create IPv6 ACL 13342_6 and enter its view.
This ACL will be applied to IPv6 PBR policy node 5 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10003
This rule matches IPv6 traffic transmitted from microsegment 10004 to microsegment 10003.
acl ipv6 advanced name 13342_7
Create IPv6 ACL 13342_7 and enter its view.
This ACL will be applied to IPv6 PBR policy node 6 in VSI 13342.
rule 0 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10002 destination microsegment 10002
rule 1 permit ipv6 vpn-instance ZHTESTCTVRF source microsegment 10004 destination microsegment 10004
·          Rule 0 matches IPv6 traffic transmitted from microsegment 10002 to microsegment 10002.
·          Rule 1 matches IPv6 traffic transmitted from microsegment 10004 to microsegment 10004.
acl ipv6 advanced name 13342_8
Create IPv6 ACL 13342_8 and enter its view.
This ACL will be applied to IPv6 PBR policy node 7 in VSI 13342.
rule 0 permit ipv6
rule 0 permit ipv6
policy-based-route SDN_SC_13342 permit node 0
Create node 0 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_1
Configure IPv4 ACL 13342_1 as an ACL match criterion for IPv4 PBR policy node 0.
policy-based-route SDN_SC_13342 permit node 1
Create node 1 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_2
Configure IPv4 ACL 13342_2 as an ACL match criterion for IPv4 PBR policy node 1.
policy-based-route SDN_SC_13342 permit node 2
Create node 2 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_3
Configure IPv4 ACL 13342_3 as an ACL match criterion for IPv4 PBR policy node 2.
apply service-chain path-id 8388610 path-index 1
policy-based-route SDN_SC_13342 permit node 3
Create node 3 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_4
Configure IPv4 ACL 13342_4 as an ACL match criterion for IPv4 PBR policy node 3.
policy-based-route SDN_SC_13342 permit node 4
Create node 4 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_5
Configure IPv4 ACL 13342_5 as an ACL match criterion for IPv4 PBR policy node 4.
Set a next hop for packets that match IPv4 PBR policy node 4.
Set service chain information for packets that match IPv4 PBR policy node 4.
policy-based-route SDN_SC_13342 permit node 5
Create node 5 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_6
Configure IPv4 ACL 13342_6 as an ACL match criterion for IPv4 PBR policy node 5.
Set a next hop for packets that match IPv4 PBR policy node 5.
Set service chain information for packets that match IPv4 PBR policy node 5.
policy-based-route SDN_SC_13342 permit node 6
Create node 6 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_7
Configure IPv4 ACL 13342_7 as an ACL match criterion for IPv4 PBR policy node 6.
policy-based-route SDN_SC_13342 permit node 7
Create node 7 for IPv4 PBR policy SDN_SC_13342 and enter its view.
if-match acl name 13342_8
Configure IPv4 ACL 13342_8 as an ACL match criterion for IPv4 PBR policy node 7.
Set NULL0 as the output interface for packets that match IPv4 PBR policy node 7. These packets will be discarded.
Create VSI interface 13342 and enter its view.
ip policy-based-route SDN_SC_13342
Deploy IPv4 PBR policy SDN_SC_13342 on VSI interface 13342.
ipv6 policy-based-route SDN_SC_13342 permit node 0
Create node 0 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_1 as an ACL match criterion for IPv6 PBR policy node 0.
ipv6 policy-based-route SDN_SC_13342 permit node 1
Create node 1 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_2 as an ACL match criterion for IPv6 PBR policy node 1.
ipv6 policy-based-route SDN_SC_13342 permit node 2
Create node 2 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_3 as an ACL match criterion for IPv6 PBR policy node 2.
apply next-hop vpn-instance ZHTESTCTFWEW01VRF FD00:0:97B0:103::F 128
ipv6 policy-based-route SDN_SC_13342 permit node 3
Create node 3 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_4 as an ACL match criterion for IPv6 PBR policy node 3.
ipv6 policy-based-route SDN_SC_13342 permit node 4
Create node 4 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_5 as an ACL match criterion for IPv6 PBR policy node 4.
Set a next hop for packets that match IPv6 PBR policy node 4.
Set service chain information for packets that match IPv6 PBR policy node 4.
ipv6 policy-based-route SDN_SC_13342 permit node 5
Create node 5 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_6 as an ACL match criterion for IPv6 PBR policy node 5.
Set a next hop for packets that match IPv6 PBR policy node 5.
Set service chain information for packets that match IPv6 PBR policy node 5.
ipv6 policy-based-route SDN_SC_13342 permit node 6
Create node 6 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_7 as an ACL match criterion for IPv6 PBR policy node 6.
ipv6 policy-based-route SDN_SC_13342 permit node 7
Create node 7 for IPv6 PBR policy SDN_SC_13342 and enter its view.
Configure IPv6 ACL 13342_8 as an ACL match criterion for IPv6 PBR policy node 7.
Set NULL0 as the output interface for packets that match IPv6 PBR policy node 7. These packets will be discarded.
Deploy IPv6 PBR policy SDN_SC_13342 on VSI interface 13342.
Configuring border nodes (Border 1 and Border 2)
Border 1 (S6850)
Border 2 (S6850)
Configuration method
microsegment enable
microsegment enable
member ipv4 197.32.14.0 255.255.255.0 vpn-instance external_vpn_1001
member ipv4 197.32.16.0 255.255.255.0 vpn-instance external_vpn_1001
member ipv6 FD00:0:97B0:1014:: 64 vpn-instance external_vpn_1001
member ipv6 FD00:0:97B0:1016:: 64 vpn-instance external_vpn_1001
member ipv4 197.32.42.0 255.255.255.0 vpn-instance external_vpn_1001
member ipv6 FD00:0:97B0:1042:: 64 vpn-instance external_vpn_1001
member ipv4 0.0.0.0 0.0.0.0 vpn-instance external_vpn_1001
member ipv6 :: 0 vpn-instance external_vpn_1001
member ipv4 197.32.42.9 255.255.255.255 vpn-instance external_vpn_1001
acl advanced name 1001_1
Create IPv4 ACL 1001_1 and enter its view.
This ACL will be applied to IPv4 PBR policy node 0 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ip vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10001
This rule matches IPv4 traffic transmitted from microsegment 10003 to microsegment 10001.
acl advanced name 1001_2
Create IPv4 ACL 1001_2 and enter its view.
This ACL will be applied to IPv4 PBR policy node 1 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ip vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10002
This rule matches IPv4 traffic transmitted from microsegment 10003 to microsegment 10002.
acl advanced name 1001_3
Create IPv4 ACL 1001_3 and enter its view.
This ACL will be applied to IPv4 PBR policy node 2 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ip vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10004
This rule matches IPv4 traffic transmitted from microsegment 10003 to microsegment 10004.
acl advanced name 1001_4
Create IPv4 ACL 1001_4 and enter its view.
This ACL will be applied to IPv4 PBR policy node 3 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ip
rule 0 permit ip
acl ipv6 advanced name 1001_1
ipv6 acl advanced name 1001_1
Create IPv6 ACL 1001_1 and enter its view.
This ACL will be applied to IPv6 PBR policy node 0 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ipv6 vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10001
This rule matches IPv6 traffic transmitted from microsegment 10003 to microsegment 10001.
ipv6 acl advanced name 1001_2
Create IPv6 ACL 1001_2 and enter its view.
This ACL will be applied to IPv6 PBR policy node 1 in VPN external_vpn_1001 VLAN 1001.
 rule 0 permit ipv6 vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10002
This rule matches IPv6 traffic transmitted from microsegment 10003 to microsegment 10002.
ipv6 acl advanced name 1001_3
Create IPv6 ACL 1001_3 and enter its view.
This ACL will be applied to IPv6 PBR policy node 2 in VPN external_vpn_1001 VLAN 1001.
 rule 0 permit ipv6 vpn-instance external_vpn_1001 source microsegment 10003 destination microsegment 10004
This rule matches IPv6 traffic transmitted from microsegment 10003 to microsegment 10004.
ipv6 acl advanced name 1001_4
Create IPv6 ACL 1001_4 and enter its view.
This ACL will be applied to IPv6 PBR policy node 3 in VPN external_vpn_1001 VLAN 1001.
rule 0 permit ipv6
rule 0 permit ipv6
policy-based-route SDN_SC_VLAN_1001 permit node 0
Create node 0 for IPv4 PBR policy SDN_SC_VLAN_1001 and enter its view.
if-match acl name 1001_1
Configure IPv4 ACL 1001_1 as an ACL match criterion for IPv4 PBR policy node 0.
Set a next hop for packets that match IPv4 PBR policy node 0.
apply service-chain path-id 8388609 path-index 1
Set service chain information for packets that match IPv4 PBR policy node 0.
policy-based-route SDN_SC_VLAN_1001 permit node 1
Create node 1 for IPv4 PBR policy SDN_SC_VLAN_1001 and enter its view.
if-match acl name 1001_2
Configure IPv4 ACL 1001_2 as an ACL match criterion for IPv4 PBR policy node 1.
policy-based-route SDN_SC_VLAN_1001 permit node 2
Create node 2 for IPv4 PBR policy SDN_SC_VLAN_1001 and enter its view.
if-match acl name 1001_3
Configure IPv4 ACL 1001_3 as an ACL match criterion for IPv4 PBR policy node 2.
policy-based-route SDN_SC_VLAN_1001 permit node 3
Create node 3 for IPv4 PBR policy SDN_SC_VLAN_1001 and enter its view.
if-match acl name 1001_4
Configure IPv4 ACL 1001_4 as an ACL match criterion for IPv4 PBR policy node 3.
Set NULL0 as the output interface for packets that match IPv4 PBR policy node 3. These packets will be discarded.
Create VLAN-interface 1001 for VPN external_vpn_1001 VLAN 1001 and enter its view.
ip policy-based-route SDN_SC_VLAN_1001
Deploy IPv4 PBR policy SDN_SC_VLAN_1001 on VLAN-interface 1001.
ipv6 policy-based-route SDN_SC_VLAN_1001 permit node 0
Create node 0 for IPv6 PBR policy SDN_SC_VLAN_1001 and enter its view.
Configure IPv6 ACL 1001_1 as an ACL match criterion for IPv6 PBR policy node 0.
Set a next hop for packets that match IPv6 PBR policy node 0.
Set service chain information for packets that match IPv6 PBR policy node 0.
ipv6 policy-based-route SDN_SC_VLAN_1001 permit node 1
Create node 1 for IPv6 PBR policy SDN_SC_VLAN_1001 and enter its view.
Configure IPv6 ACL 1001_2 as an ACL match criterion for IPv6 PBR policy node 1.
ipv6 policy-based-route SDN_SC_VLAN_1001 permit node 2
Create node 2 for IPv6 PBR policy SDN_SC_VLAN_1001 and enter its view.
Configure IPv6 ACL 1001_3 as an ACL match criterion for IPv6 PBR policy node 2.
ipv6 policy-based-route SDN_SC_VLAN_1001 permit node 3
Create node 3 for IPv6 PBR policy SDN_SC_VLAN_1001 and enter its view.
Configure IPv6 ACL 1001_4 as an ACL match criterion for IPv6 PBR policy node 3.
Set NULL0 as the output interface for packets that match IPv6 PBR policy node 3. These packets will be discarded.
Deploy IPv6 PBR policy SDN_SC_VLAN_1001 on VLAN-interface 1001.
Verification commands
display drni role
Displays DR role information.
display drni summary
Displays summary information about the IPP and DR interfaces in the DR system.
display ospf peer
Displays information about OSPF neighbors.
display bgp peer l2vpn evpn
Displays BGP EVPN peer or peer group information.
display bgp l2vpn evpn
Displays BGP EVPN routes.
display l2vpn vsi
Displays information about VSIs.
display microsegment
Displays the configuration and status of microsegments.
1.      Verify that the DR systems at the leaf tier are operating correctly.
The following information uses node Leaf 1 for example to show the procedure.
# Verify that nodes Leaf 1 and Leaf 2 has established a DR system.
<Leaf1> display drni role
            Effective role information
Factors                  Local                    Peer
Effective role           Secondary                Primary
Initial role             None                     None
MAD DOWN state           Yes                      Yes
Health level             0                        0
Role priority            32768                    32768
Bridge MAC               703a-a6e9-a00a           0440-a9df-98d0
Effective role trigger: IPL calculation
Effective role reason: Bridge MAC
                    Configured role information
Factors                  Local                    Peer
Configured role          Secondary                Primary
<Leaf1> display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
       C -- Configuration consistency check failed
IPP: BAGG256
IPP state (cause): UP
Keepalive link state (cause): UP
                     DR interface information
DR interface  DR group  Local state (cause)  Peer state  Remaining down time(s)
BAGG256      1         UP                   UP          -
# Verify that node Leaf 1 has established OSPF neighbor relationships and BGP EVPN peer relationships with the spine nodes.
<Leaf1> display ospf peer
         OSPF Process 65530 with Router ID 197.32.241.41
               Neighbor Brief Information
 Area: 0.0.0.0
 Router ID       Address         Pri Dead-Time  State             Interface
 197.32.241.37  197.32.241.37   1   38         Full/ -           HGE1/0/25
 197.32.241.38  197.32.241.38   1   34         Full/ -           HGE1/0/26
 197.32.241.42     197.32.241.142   1   31         Full/DR           Vlan4094
<Leaf1> display bgp peer l2vpn evpn
 BGP local router ID: 197.32.241.41
 Local AS number: 65530
 Total number of peers: 2                 Peers in established state: 2
  * - Dynamically created peer
  ^ - Peer created through link-local address
  197.32.241.37        65530     6273     5374    0     340 0080h32m Established
  197.32.241.38        65530     5175     5041    0     340 0080h34m Established
2.      On node Leaf 1, verify that the configuration and status of microsegments are all correct.
<Leaf1>display microsegment
Microsegment status   : Enabled
Total microsegments   : 4
Microsegment list
  Microsegment ID  Members  Microsegment name
  10001              87        SDN_EPG_10001
  10002              8         SDN_EPG_10002
  10003              2         SDN_EPG_10003
  10004              2         SDN_EPG_10004
3.      On the DHCP client side, verify that the Windows 7 and Linux DHCP clients attached to node Leaf 3 can obtain IP addresses from the DHCP server. (Details not shown.)
4.      On the DHCP server, verify that the IP addresses have been assigned to the DHCP clients. (Details not shown.)
