H3C Data Center Switches DRNI Configuration Guide-6W103
HomeSupportConfigure & DeployConfiguration GuidesH3C Data Center Switches DRNI Configuration Guide-6W103
05-DRNI and VRRP Configuration Example
05-DRNI and VRRP Configuration Example 282.22 KB
Example: Configuring DRNI and VRRP
In the underlay network as shown in Figure 1, deploy DRNI at the access layer to provide high availability and load balancing services for access devices. Deploy VRRP to provide gateway redundancy and ensure user service continuity. You can achieve the following purposes on the server through the VRRP gateway:
·     To implement Layer 2 connectivity, the server can communicate with the service network at Layer 2 through the DR system.
·     Use the secondary IP addresses of the VLAN interfaces created on the DR member devices to set up Layer 3 links between the server and the core devices, and configure BGP or OSPF to achieve Layer 3 connectivity.
Figure 1 Network diagram
Device role
IP address
Remarks
DR 1
WGE1/0/1
N/A
Member port of a DR interface.
Connected to the server.
WGE1/0/2
100.100.100.5/30
Connected to WGE1/0/2 on DR 2 to establish the DRNI keepalive link.
HGE1/0/25
N/A
Member port the IPP.
Connected to HGE1/0/25 on DR 2.
HGE1/0/26
N/A
Connected to HGE1/0/26 on DR 2.
HGE1/0/27
10.39.245.13/31
Connected to HGE1/0/2 on Core 2.
HGE1/0/28
10.39.244.13/31
Connected to HGE1/0/1 on Core 1.
Vlan-interface100
10.40.196.61/26
Secondary IP address: 100.127.128.253/24
Virtual IP address of the VRRP group: 10.40.196.1
10.40.196.1
Vlan-interface4094
100.100.100.1/30
Connects two DR member devices over a Layer 3 link.
Bridge-Aggregation 1
N/A
DR interface.
Bridge-Aggregation 1024
N/A
IPP.
Connected to the IPL.
DR 2
WGE1/0/1
N/A
Member port of the DR interface.
WGE1/0/2
100.100.100.6/30
Connected to WGE1/0/2 on DR 1.
HGE1/0/25
N/A
Member port of the IPP interface.
Connected to HGE1/0/25 on DR 1.
HGE1/0/26
N/A
Connected to HGE1/0/26 on DR 1.
HGE1/0/27
10.39.244.45/31
Connected to HGE1/0/2 on Core 1.
HGE1/0/28
10.39.245.45/31
Connected to HGE1/0/1 on Core 2.
Vlan-interface100
10.40.196.62/26
Secondary IP address: 100.127.128.254/24
10.40.196.1
Vlan-interface4094
100.100.100.2/30
N/A
DR interface.
N/A
IPP.
Core 1
HGE1/0/1
10.39.244.12/31
Connected to HGE1/0/28 on DR 1.
HGE1/0/2
10.39.244.44/31
Connected to HGE1/0/27 on DR 2.
HGE1/0/3
22.22.1.1/24
Connected to the service network.
Core 2
HGE1/0/1
10.39.245.44/31
Connected to HGE1/0/28 on DR 2.
HGE1/0/2
10.39.245.12/31
Connected to HGE1/0/27 on DR 1.
HGE1/0/3
12.12.1.1/24
Analysis
·     Deploy link aggregation between DR 1 and the server and between DR 2 and the server.
·     Deploy DRNI for DR 1 and DR 2 at the access layer. Configure a VRRP group and specify its virtual IP address as the gateway address of the server.
·     Core 1 and Core 2 are Layer 3 devices connected to the service network.
·     Create VLAN interfaces on the DR interfaces of the DR member devices, and configure the primary and secondary IP addresses.
¡     Set up Layer 3 links between the DR member devices and the core devices, and configure BGP between them to achieve Layer 3 connectivity.
¡     Use the secondary IP address of the VLAN interfaces created on the DR interfaces to set up Layer 3 links to the server, and configure BGP or OSPF to achieve Layer 3 connectivity.
Applicable product matrix
IMPORTANT
IMPORTANT:
In addition to running an applicable software version, you must also install the most recent patch, if any.
Device
Software version
S6805, S6825, S6850, S9850, S9820-64H, and S9820-8C
R6616P01 and R6635
S6800, S6860
F2707 and higher F27xx versions
S12500X-AF, S6890
F2809 and higher F28xx versions
S12500G-AF
R7624P12
S6812, S6813
Under development. To obtain the latest images, contact Technical Support.
Configuration procedure
Procedure summary
·     Configuring DRNI
·     Deploying a VRRP gateway on the DR member devices
·     Configuring the links between the DR member devices and the Layer 3 virtualization server
·     Configuring the links between the DR member devices and core devices
·     Configuring BGP between the DR member devices and core devices
·     Configure BGP or OSPF between the DR member devices and the server (perform one of the following tasks):
¡     (Optional.) Configuring BGP between the DR member devices and the server
¡     (Optional.) Configuring OSPF between the DR member devices and the server
·     Configuring the links between the core devices and DR member devices
·     Configuring the links between the core devices and the service network
·     Configuring BGP on the core devices for communication with the DR member devices
·     Configuring OSPF on the core devices for communication with the service network
Configuring DRNI
DR 1
DR 2
Remarks
interface Bridge-Aggregation 1024
Create Layer 2 aggregate interface Bridge-Aggregation 1024.
N/A
link-aggregation mode dynamic
Configure Bridge-Aggregation 1024 to operate in dynamic mode, and enable LACP.
N/A
N/A
N/A
interface range HundredGigE1/0/25 HundredGigE1/0/26
Enter IPL physical port view.
N/A
port link-aggregation group 1024
Assign the physical ports to Layer 2 aggregation group 1024.
N/A
N/A
N/A
interface Bridge-Aggregation1024
Enter the view of Bridge-Aggregation 1024 to be used as IPP.
N/A
port drni intra-portal-port 1
port drni intra-portal-port1
Configure Bridge-Aggregation 1024 as the IPP.
N/A
port link-type trunk
Set the link type of the physical port to trunk.
N/A
port trunk permit vlan all
Assign the port to all VLANs.
N/A
N/A
N/A
vlan 4094
vlan 4094
Create VLAN 4094.
N/A
N/A
N/A
interface Vlan-interface 4094
Create VLAN-interface 4094.
N/A
ip address 100.100.100.1 255.255.255.252
ip address 100.100.100.2 255.255.255.252
Assign an IP address to the interface for establishing IBGP peer connection on the IPL link.
N/A
N/A
N/A
Enter the view of Bridge-Aggregation 1.
N/A
Configure Bridge-Aggregation 1 to operate in dynamic mode, and enable LACP.
N/A
lacp edge-port
lacp edge-port
Configure the aggregate interface as an edge aggregate interface.
N/A
port drni group 1
port drni group 1
Assign the aggregate interface to a DR group.
N/A
N/A
N/A
ip vpn-instance drni-keepalive
Create VPN instance drni-keepalive.
N/A
route-distinguisher 100:1
Configure the RD of the VPN instance.
N/A
vpn-target 1:1
vpn-target 1:1
Configure the RT of the VPN instance.
N/A
N/A
N/A
interface Twenty-FiveGigE1/0/2
Enter the view of interface Twenty-FiveGigE 1/0/2.
N/A
port link-mode route
Configure the Ethernet interface to work in Layer 3 mode.
N/A
ip binding vpn-instance drni-keepalive
Associate the interface with VPN instance drni-keepalive.
N/A
ip address 100.100.100.5 255.255.255.252
ip address 100.100.100.6 255.255.255.252
Configure the IP address for the keepalive link.
N/A
N/A
N/A
drni role priority 10000
drni role priority 40000
Set the DR role priority of the device.
N/A
drni system-mac 8465-6958-e2c4
Configure the DR system MAC address.
N/A
drni system-number 1
drni system-number 2
Set the DR system number.
N/A
drni system-priority 10000
Set the DR system priority.
N/A
drni standalone enable
Enable DRNI standalone mode.
N/A
drni keepalive ip destination 100.100.100.6 source 100.100.100.5 vpn-instance drni-keepalive
drni keepalive ip destination 100.100.100.5 source 100.100.100.6 vpn-instance drni-keepalive
Configure DR keepalive packet parameters.
N/A
drni mad exclude interface Twenty-FiveGigE1/0/2
Configure DRNI MAD to not shut down the interface attached to the keepalive link.
N/A
drni mad exclude interface Vlan-interface 4094
Configure DRNI MAD to not shut down the Layer 3 interconnection interface for fast entry synchronization upon recovery of the DR interface from a failure.
N/A
drni restore-delay 300
Set the data restoration interval for more data synchronization time and faster convergence.
N/A
stp instance 0 root primary
Configure the DR member device as the root bridge.
N/A
stp global enable
stp global enable
Enable the spanning tree feature globally.
N/A
stp tc-protection
stp tc-protection
Enable TC-BPDU attack guard for the device to avoid frequent deletion of MAC address entries and ARP entries.
N/A
stp bpdu-protection
stp bpdu-protection
Enable BPDU guard globally.
N/A
DR 1
DR 2
Remarks
vlan 100
vlan 100
Configure the VLAN used to communicate with a virtualization server.
N/A
N/A
N/A
interface Vlan-interface 100
Create VLAN-interface 100.
N/A
ip address 10.40.196.61 255.255.255.192
ip address
100.127.128.253
255.255.255.0 sub
ip address 10.40.196.62 255.255.255.192
ip address
100.127.128.254
255.255.255.0 sub
Assign the primary and secondary IP addresses to VLAN-interface 100.
N/A
vrrp vrid 1 virtual-ip 10.40.196.1
Configure the virtual IP address of a VRRP group.
N/A
vrrp vrid 1 priority 200
vrrp vrid 1 priority 100
Configure the priority of the device in the VRRP group.
VRRP determines the role (master or backup) of each router in a VRRP group by priority. A router with higher priority is more likely to become the master.
N/A
N/A
drni mad exclude interface Vlan-interface 100
Configure DRNI MAD to not shut down the interface connected to the server for fast entry synchronization upon recovery of the DR interface from a failure.
As a best practice, do not configure this command for an S12500G-AF device. If you configure this command for the device, the fault recovery time might exceed 500 milliseconds.
DR 1
DR 2
Remarks
vlan 2 to 1000
vlan 2 to 1000
Create VLANs.
N/A
N/A
N/A
interface Twenty-FiveGigE1/0/1
Configuring the interface used to connect to the Layer 3 virtualization server.
N/A
Assign the physical port to Layer 2 aggregation group 1.
N/A
N/A
N/A
N/A
N/A
port trunk permit vlan 2 to 1000
Assign the port to VLAN 2 through VLAN 1000.
N/A
port trunk pvid vlan 100
Set the PVID for the trunk port to 100.
N/A
N/A
N/A
DR 1
DR 2
Remarks
interface HundredGigE1/0/27
interface HundredGigE1/0/28
Enter view of the interface connected to Core 2.
N/A
N/A
ip address 10.39.245.13 255.255.255.254
ip address 10.39.245.45 255.255.255.254
Assign an IP address to the interface.
N/A
N/A
N/A
Enter view of the interface connected to Core 1.
N/A
N/A
ip address 10.39.244.13 255.255.255.254
ip address 10.39.244.45 255.255.255.254
N/A
N/A
N/A
DR 1
DR 2
Remarks
bgp 65115
bgp 65115
Enable the specified BGP instance and enter its view.
N/A
bgp update-delay on-startup 120
Configure BGP to delay sending route updates on reboot, and set the delay timer to 120 seconds.
The DR member devices learn route entries after synchronizing MAC address entries and ARP entries.
non-stop-routing
non-stop-routing
Enable BGP nonstop routing (NSR).
Avoid forwarding interruption on the DR member devices.
router-id 10.41.254.140
router-id 10.41.254.141
Specify the router ID for the BGP instance.
N/A
group DR internal
group DR internal
Create an IBGP peer group named DR.
N/A
peer DR route-update-interval 0
Specify the interval for sending the same update to the peer group as 0.
Enable the device to fast send update to the peer group upon route changes to speed up route convergence after a DR primary/secondary switchover occurs.
peer DR timer keepalive 10 hold 30
Set the keepalive interval and hold time for the peer group to 10 seconds and 30 seconds, respectively.
N/A
group core external
group core external
Create an EBGP peer group to connect to the core device.
N/A
peer core as-number 65105
Configure the AS number of the EBGP peer group.
N/A
peer core route-update-interval 0
peer core timer keepalive 10 hold 30
N/A
peer 10.39.244.12 group core
peer 10.39.244.44 group core
Add Core 1 as a peer to peer group core.
N/A
peer 10.39.245.12 group core
peer 10.39.245.44 group core
Add Core 2 as a peer to peer group core.
N/A
peer 100.100.100.2 group DR
peer 100.100.100.1 group DR
Add the other DR as a peer to peer group DR.
N/A
address-family ipv4 unicast
Enter BGP IPv4 unicast address family view.
N/A
balance 8
balance 8
Enable load balancing and set the maximum number of BGP ECMP routes as 8 for load balancing.
N/A
preference 180 200 130
Set preferences for EBGP, IBGP, and local routes to 180, 200, and 130, respectively.
Adjust the possibility of selecting BGP routes as optimal routes.
import-route direct
import-route direct
Redistribute direct routes.
N/A
import-route ospf
import-route ospf
Redistribute OSPF routes between the DR member device and server.
N/A
peer core enable
peer core enable
Enable BGP to exchange routing information with peer group core.
N/A
peer core advertise-community
Advertise the COMMUNITY attribute to peer group core.
N/A
peer DR enable
peer DR enable
Enable BGP to exchange routing information with peer group DR.
N/A
peer DR next-hop-local
Set the local router as the next hop for routes sent to peer group DR.
N/A
Perform this task or the task in "Configuring OSPF between the DR member devices and the server."
DR 1
DR 2
Remarks
bgp 65115
bgp 65115
Use BGP to implement Layer 3 connectivity between the DR member devices and the server.
group docker_host external
Create an EBGP peer group to connect to the server.
N/A
peer docker_host as-number 60000
N/A
peer 100.127.128.3 group docker_host
Add the server (with IP address 100.127.128.3) to peer group docker_host.
N/A
N/A
peer docker_host enable
Enable BGP to exchange routing information with peer group docker_host.
Establish EBGP peer with the Layer 3 virtualization server.
peer docker_host route-limit 5000
Set the maximum number of routes that can be received from a peer group.
N/A
Perform this task or the task in "Configuring BGP between the DR member devices and the server."
DR 1
DR 2
Remarks
ospf 1
ospf 1
Enable OSPF and enter OSPF view.
Use OSPF to implement Layer 3 connectivity between the DR member devices and the server.
stub-router include-stub on-startup 900
Specify the cost of the stub links (link type 3) in Router LSAs to the maximum value 65535, in order to speed up convergence.
N/A
import-route direct
import-route direct
Redistribute direct routes into the OSPF routing table.
N/A
import-route bgp
import-route bgp
Redistribute BGP routes into the OSPF routing table.
N/A
area 0.0.0.0
area 0.0.0.0
Enter OSPF area view.
N/A
network 100.127.128.0 0.0.0.255
Configure OSPF to advertise the local network route.
N/A
Exit OSPF area view.
N/A
Core 1
Core 2
Remarks
interface HundredGigE1/0/1
Enter the view of the interface connected to DR 1.
N/A
Configure the interface to work in Layer 3 mode.
N/A
ip address 10.39.244.12 255.255.255.254
ip address 10.39.245.12 255.255.255.254
N/A
N/A
N/A
Enter the view of the interface connected to DR 2.
N/A
N/A
ip address 10.39.244.44 255.255.255.254
ip address 10.39.245.44 255.255.255.254
N/A
N/A
N/A
Core 1
Core 2
Remarks
interface HundredGigE1/0/3
Enter the view of the interface connected to the service network.
N/A
N/A
ip address 22.22.1.1 255.255.255.0
ip address 12.12.1.1 255.255.255.0
N/A
Exit interface view.
N/A
Core 1
Core 2
Remarks
bgp 65105
bgp 65105
N/A
group DR external
group DR external
Create an EBGP peer group named DR.
N/A
peer DR as-number 65115
Specify an AS number for EBGP peer group DR.
N/A
peer 10.39.244.45 group DR
peer 10.39.245.45 group DR
Add DR2 as a peer to peer group DR.
N/A
peer 10.39.244.13 group DR
peer 10.39.245.13 group DR
Add DR1 as a peer to peer group DR.
N/A
N/A
balance 8
balance 8
Enable load balancing and set the maximum number of BGP ECMP routes for load balancing.
N/A
N/A
import-route direct
import-route direct
Redistribute direct routes into the BGP routing table.
N/A
import-route ospf
import-route ospf
Redistribute OSPF routes into the BGP routing table.
N/A
peer DR enable
peer DR enable
N/A
peer DR preferred-value 60000
Set preferred value 60000 for routes received from peer group DR.
Enable the routes received from the peer group to become the optimal routes.
Exit BGP view.
N/A
Core 1
Core 2
Remarks
ospf 1
ospf 1
N/A
N/A
import-route direct
import-route direct
N/A
import-route bgp
import-route bgp
N/A
area 0.0.0.0
area 0.0.0.0
N/A
network 22.22.1.0 0.0.0.255
network 12.12.1.0 0.0.0.255
Configure OSPF to advertise the service network route.
N/A
N/A
Traffic forwarding models
Underlay traffic forwarding models
Traffic type: Known IPv4 unicast, Layer 2 unicast, and unknown unicast.
Direction: South to north, north to south, east to west across the DR system, and west to east across the DR system.
Forwarding path: Server > DR system > core devices > service network, service network > core devices > DR system > server, DR 2 > DR 1, and DR 1 > DR 2.
Traffic simulation: Send packets by using the tester.
Load: Light load (less than 1000 flows).
Traffic direction to firewalls/LB: N/A
Traffic type
Direction
Forwarding path
Traffic simulation
Load
Remarks
Known IPv4 unicast
South to north
Tester
Light
N/A
N/A
Known IPv4 unicast
North to south
Service network > core devices > DR system > server
Tester
Light
N/A
N/A
Known IPv4 unicast
East to west across the DR system
DR 2 > DR 1
Tester
Light
N/A
N/A
Known IPv4 unicast
West to east across the DR system
DR 1 > DR 2
Tester
Light
N/A
N/A
Layer 2 unicast
South to north
Server > DR system
Tester
Light
N/A
N/A
Layer 2 unicast
North to south
DR system > server
Tester
Light
N/A
N/A
Layer 2 unicast
DR 2 > DR 1
Tester
Light
N/A
N/A
Layer 2 unicast
DR 1 > DR 2
Tester
Light
N/A
N/A
Unknown unicast
South to north
Server > DR system
Tester
Light
N/A
N/A
Unknown unicast
North to south
DR system > server
Tester
Light
N/A
N/A
Unknown unicast
DR 2 > DR 1
Tester
Light
N/A
N/A
Unknown unicast
DR 1 > DR 2
Tester
Light
N/A
N/A
Verification commands
DR 1
DR 2
display drni summary
Displays summary information about DR interfaces.
display drni system
display drni system
Displays the DR system settings.
display drni keepalive
Displays DR keepalive packet statistics.
display drni role
display drni role
Displays DR role information.
display drni consistency { type1 | type2 }
Displays information about the configuration consistency check done by DRNI.
display drni consistency-check status
Displays the configuration consistency check status.
display interface Bridge-Aggregation [ brief ]
Displays information about aggregate interfaces.
# Display the DR system settings on DR 1 to verify that DR 1 and DR 2 has established a DR system.
[DR1] display drni system
                    System information
Local system number: 1                      Peer system number: 2
Local system MAC: 8465-6958-e2c4            Peer system MAC: 8465-6958-e2c4
Local system priority: 10000                Peer system priority: 10000
Local bridge MAC: 0068-5116-5101            Peer bridge MAC: 90e7-1062-5371
Local effective role: Primary               Peer effective role: Secondary
Health level: 0
Standalone mode on split: Enabled
In standalone mode: No
                    System timer information
Timer                      State       Value (s)    Remaining time (s)
Auto recovery              Disabled    -            -
Restore delay              Disabled    300          -
Consistency-check delay    Disabled    150          -
Standalone delay           Disabled    -            -
Role to None delay         Disabled    60           -
# View summary information about DR interfaces on DR 1.
[DR1] display drni summary
Flags: A -- Aggregate interface down, B -- No peer DR interface configured
       C -- Configuration consistency check failed
IPP: BAGG1024
IPP state (cause): UP
Keepalive link state (cause): UP
                    DR interface information
DR interface  DR group  Local state (cause)  Peer state  Remaining down time(s)
BAGG1         1         UP                   UP          -
# View DR role information on DR 1.
[DR1] display drni role
                   Effective role information
Factors                  Local                    Peer
Effective role           Primary                  Secondary
Initial role             Primary                  Secondary
MAD DOWN state           No                       Yes
Health level             0                        0
Role priority            10000                    40000
Bridge MAC               0068-5116-5101           90e7-1062-5371
Effective role trigger: IPL calculation
Effective role reason: MAD status
                   Configured role information
Factors                  Local                    Peer
Configured role          Primary                  Secondary
# View information about the aggregate interfaces on DR 1.
[DR1] display interface Bridge-Aggregation brief
Speed: (a) - auto
Interface            Link Speed     Duplex Type PVID Description
BAGG1                UP   25G(a)    F(a)   T    100
BAGG1024             UP   200G(a)   F(a)   T    1
Testing network convergence
Testing network convergence upon single points of failure
Table 1 Network convergence upon single points of failure
Device
Failure type
Traffic interruption time
DR member device
Link failure.
≤ 500 ms
Node failure.
Fixed-port device: < 500 ms
Modular device:
·     Device replacement: < 1000 ms
·     Switching fabric module replacement: 0 ms
·     Service module replacement: < 500 ms
Upgrading the devices
Upgrading the DR member devices
Checking the environment
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an upgrade.
DR 1
DR 2
display device
display device
Displays device information.
display boot-loader
display boot-loader
Displays current software images and startup software images.
display version
display version
Displays system version information.
See H3C Switches DR System Upgrade & Replacement & Expansion Guide.
Verifying the traffic interruption time during the upgrade
Verify that the traffic interruption time is shorter than 500 ms during a switchover and shorter than 150 ms during fallback. For more information, see "Testing network convergence."
Verifying the upgrade result
Execute the commands in "Verification commands" and the following commands to verify that the device is upgraded successfully.
DR 1
DR 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Expanding the network
An expansion operation adds two leaf devices.
Expanding the DR system
Execute the commands in "Verification commands" and the following commands to verify that the device is available for an expansion.
DR 1
DR 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Adding the device to the DR system
1.     Disconnect the device from network management systems.
2.     Upgrade the software of the device as needed.
3.     Preconfigure the device.
4.     Connect the device to network management systems.
5.     Incorporate the device on the controller.
Verifying the expansion result
Execute the following commands to verify that the device is added successfully.
DR 1
DR 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Replacing hardware
Replacing a service module
Execute the commands in "Verification commands" and the following commands to verify that the target device is available for a replacement.
DR 1
DR 2
display device
display device
display boot-loader
display boot-loader
display version
display version
1.     Switch service and management traffic on the target service module to other service modules.
2.     Power off the device and replace the service module, or replace the service module when the device is running. For more information, see the installation guides for the service module.
For details, see H3C Switches DR System Upgrade & Replacement & Expansion Guide.
Verifying the replacement result
Execute the commands in "Checking the environment."
Replacing a switching fabric module
DR 1
DR 2
display device
display device
display boot-loader
display boot-loader
display version
display version
Power off the device and replace the switching fabric module, or replace the switching fabric module when the device is running. For more information, see the installation guides for the switching fabric module.
