H3C WX5540E Access Controller Switching Engine Web-Based Configuration Guide(R2607P26)-6W101
HomeSupportWirelessWX5500E Series Access ControllersConfigure & DeployUser ManualsH3C WX5540E Access Controller Switching Engine Web-Based Configuration Guide(R2607P26)-6W101
03-Web overview
03-Web overview 201.40 KB
Web overview
This chapter describes the Web interface, functions available on the Web interface, Web user levels you must have to perform a function, and common icons and buttons on the Web pages.
Web interface
The Web interface consists of the navigation tree, title area, and body area.
Figure 1 Web-based configuration interface
(1) Navigation area
(2) Body area
(3) Title area
·           Navigation areaOrganizes the Web-based NM function menus in the form of a navigation tree, where you can select function menus as needed. The result is displayed in the body area. The Web network management functions not supported by the device are not displayed in the navigation area.
·           Body areaThe area where you can configure and display a function.
·           Title areaOn the left, displays the path of the current configuration interface in the navigation area; on the right, provides the Save button to quickly save the current configuration, the Help button to display the Web related help information, and the Logout button to log out of the Web interface.
Web user level
Web user levels, ranging from low to high, are visitor, monitor, configure, and management. A user with a higher level has all the operating rights of a user with a lower level.
·           VisitorUsers can use the network diagnostic tools ping and Trace Route, but they can neither access the device data nor configure the device.
·           MonitorUsers can only access the device data, but they cannot configure the device.
·           ConfigureUsers can access device data and configure the device, but they cannot upgrade the host software, add/delete/modify users, or backup/restore configuration files.
·           ManagementUsers of this level can perform any operations to the device.
Web-based NM functions
A user level in Table 1 indicates that users of this level or users of a higher level can perform the corresponding operations.
Table 1 Web-based NM function description
Function menu
User level
Wizard
IP Setup
Perform quick configuration of the device.
Management
Summary
System Information
Display the system information, system resource status, and the recent system operation logs.
Monitor
Device Information
Display the port, power supply, and fan information of the device.
Monitor
Device
Basic
System Name
Display and configure the system name.
Configure
Web Idle Timeout
Display and configure the idle timeout period for logged-in users.
Configure
System Time
System Time
Display the system date and time.
Monitor
Configure the system date and time
Configure
Time Zone
Display configurations about system time zone and daylight saving time.
Monitor
Configure system time zone and daylight saving time.
Configure
Network Time Protocol
Display the synchronization status of system clock and network time configuration information.
Monitor
Configure the network time.
Configure
Device Maintenance
Software Upgrade
Configure to upload upgrade file from local host, and upgrade the system software.
Management
Reboot
Configure to reboot the device.
Management
Diagnostic Information
Generate diagnostic information file, and view or save the file to local host.
Management
Syslog
Loglist
Display and refreshes system logs.
Monitor
Clear system logs.
Configure
Loghost
Display and configure the loghost.
Configure
Log Setup
Display and configure the buffer capacity, and interval for refreshes system logs.
Configure
Configuration
Backup
Back up the configuration file to be used at the next startup from the device to the host of the current user.
Management
Restore
Upload the configuration file to be used at the next startup from the host of the current user to the device.
Management
Save
Save the current configuration to the configuration file to be used at the next startup.
Configure
Initialize
Restore the factory default settings.
Configure
File Manage
File Manage
Manage files on the device, such as displaying the file list, downloading a file, uploading a file, removing a file, and setting the main boot file.
Management
Port Management
Summary
Display port information by features.
Monitor
Detail
Display feature information by ports.
Monitor
Setup
Create, modify, delete, or enable/disable a port, and clear port statistics.
Configure
Port Mirroring
Summary
Display the configuration information of a port mirroring group.
Monitor
Create
Create a port mirroring group.
Configure
Remove
Remove a port mirroring group.
Configure
Modify Port
Configure ports for a mirroring group.
Configure
Users
Summary
Display the brief information about FTP and Telnet users.
Monitor
Super Password
Configure a password for a lower-level user to switch from the current access level to the management level.
Management
Create
Create an FTP or Telnet user.
Management
Modify
Modify FTP or Telnet user information.
Management
Remove
Remove an FTP or a Telnet user.
Management
Switch To Management
Switch the current user level to the management level.
Visitor
Loopback
Loopback
Perform loopback tests on Ethernet interfaces.
Configure
VCT
VCT
Check the status of the cables connected to Ethernet ports.
Configure
Flow Interval
Port Traffic Statistics
Display the number of packets and bytes received and sent by the interface, and the bandwidth usage within a specified time interval.
Monitor
Interval Configuration
Set an interval for collecting traffic statistics on interfaces.
Configure
Storm Constrain
Storm Constrain
Display and set the interval for collecting storm constrain statistics.
Display, create, modify, and remove the port traffic threshold.
Configure
RMON
Statistics
Display, create, modify, and clear RMON statistics.
Configure
History
Display, create, modify, and clear RMON history sampling information.
Configure
Alarm
View, create, modify, and clear alarm entries.
Configure
Event
View, create, modify, and clear event entries.
Configure
Log
Display log information about RMON events.
Configure
Energy Saving
Energy Saving
Display and configure the energy saving settings of an interface.
Configure
SNMP
Setup
Display and refresh SNMP configuration and statistics information.
Monitor
Configure SNMP.
Configure
Community
Display SNMP community information.
Monitor
Create, modify, and delete an SNMP community.
Configure
Group
Display SNMP group information.
Monitor
Create, modify, and delete an SNMP group.
Configure
User
Display SNMP user information.
Monitor
Create, modify, and delete an SNMP user.
Configure
Trap
Display the status of the SNMP trap function and information about target hosts.
Monitor
Enable or disable the SNMP trap function, or create, modify, and delete a target host.
Configure
View
Display SNMP view information.
Monitor
Create, modify, and delete an SNMP view.
Configure
Interface Statistics
Display and clear the statistics information of an interface.
Configure
Network
VLAN
Select VLAN
Select a VLAN range.
Monitor
Create
Create VLANs.
Configure
Port Detail
Display the VLAN-related details of a port.
Monitor
Detail
Display the member port information of a VLAN.
Monitor
Modify VLAN
Modify the description and member ports of a VLAN.
Configure
Modify Port
Change the VLAN to which a port belongs, the connection type and PVID of the port.
Configure
Remove
Remove VLANs.
Configure
VLAN Interface
Summary
Display information about VLAN interfaces by address type.
Monitor
Create
Create VLAN interfaces and configure IP addresses for them.
Configure
Modify
Modify the IP addresses and status of VLAN interfaces.
Configure
Remove
Remove VLAN interfaces.
Configure
Voice VLAN
Summary
Display voice VLAN information globally or on a port.
Monitor
Setup
Configure the global voice VLAN.
Configure
Port Setup
Configure a voice VLAN on a port.
Configure
OUI Summary
Display the addresses of the OUIs that can be identified by voice VLAN.
Monitor
OUI Add
Add the address of an OUI that can be identified by voice VLAN.
Configure
OUI Remove
Remove the address of an OUI that can be identified by voice VLAN.
Configure
MAC
MAC
Display MAC address information.
Monitor
Create and remove MAC addresses.
Configure
Setup
Display and configure MAC address aging time.
Configure
MSTP
Region
Display information about MST regions.
Monitor
Modify MST regions.
Configure
Global
Set global MSTP parameters.
Configure
Port Summary
Display the MSTP information of ports.
Monitor
Port Setup
Set MSTP parameters on ports.
Configure
Link Aggregation
Summary
Display information about aggregated interface, and information about member ports.
Monitor
Create
Create link aggregation groups.
Configure
Modify
Modify link aggregation groups.
Configure
Remove
Remove link aggregation groups.
Configure
LACP
Summary
Display information about LACP-enabled ports and their partner ports.
Monitor
Setup
Set LACP priorities.
Configure
LLDP
Port Setup
Display the LLDP configuration information, local information, neighbor information, statistics information, and status information of a port.
Monitor
Modify LLDP configuration on a port.
Configure
Global Setup
Display global LLDP configuration information.
Monitor
Configure global LLDP parameters.
Configure
Global Summary
Display global LLDP local information and statistics.
Monitor
Neighbor Summary
Display global LLDP neighbor information.
Monitor
Service
Service
Display the states of services: enabled or disabled.
Configure
Enable/disable services, and set related parameters.
Management
Diagnostic Tools
Ping
Ping an IP address and display the operation result.
Visitor
Trace Route
Perform trace route operation and display the operation result.
Visitor
Common items on the Web pages
Buttons and icons
Table 2 Commonly used buttons and icons
Button and icon
Applies the configuration on the current page.
Cancels the configuration on the current page, and returns to the corresponding list page or the Device Info page.
Refreshes the current page.
Clears all entries in a list or all statistics.
Adds an item.
Removes the selected items.
Selects all the entries in a list, or selects all ports on the device panel.
Clears all the entries in a list, or clears all ports on the device panel.
Buffers settings you made and proceeds to the next step without applying the settings.
This button is typically present on the configuration wizard.
Buffers settings you made and returns to the previous step without applying the settings.
Applies all settings you made at each step and finishes the configuration task.
icon_mdf
Accesses a configuration page to modify settings.
This icon is typically present in the Operation column in a list,
icon_del
Deletes an entry.
Page display
The Web interface can display contents by pages, as shown in Figure 2. You can set the number of entries displayed per page, and view the contents on the first, previous, next, and last pages, or go to any page that you want to check.
A list can contain a maximum of 20000 entries if displayed in pages.
Figure 2 Content display by pages
Search function
The Web interface provides you with the basic and advanced search functions to display only the entries that match specific searching criteria.
·           Basic searchAs shown in Figure 2, input the keyword in the text box above the list, select a search item from the list and click Search to display the entries that match the criteria. Figure 3 shows an example of searching for entries with VLAN ID 2.
Figure 3 Basic search function example
·           Advanced searchAdvanced search function: As shown in Figure 2, you can click the Advanced Search link to open the advanced search page, as shown in Figure 4. Specify the search criteria, and click Apply to display the entries that match the criteria.
Figure 4 Advanced search
Take the ARP table shown in Figure 2 as an example. If you want to search for the ARP entries with interface being GigabitEthernet1/0/19, and IP address range being 192.168.1.50 to 192.168.1.59, follow these steps:
1.      Click the Advanced Search link, specify the search criteria on the advanced search page as shown in Figure 5, and click Apply. The ARP entries with interface being GigabitEthernet1/0/19 are displayed.
Figure 5 Advanced search function example (1)
2.      Click the Advanced Search link, specify the search criteria on the advanced search page as shown in Figure 6, and click Apply. The ARP entries with interface being GigabitEthernet1/0/19 and IP address range being 192.168.1.50 to 192.168.1.59 are displayed as shown in Figure 7.
Figure 6 Advanced search function example (2)
Figure 7 Advanced search function example (3)
Sort function
The Web interface provides you with the basic functions to display entries in certain orders.
On a list page, you can click the blue heading item of each column to sort the entries based on the heading item you selected. After your clicking, the heading item is displayed with an arrow beside it as shown in Figure 8. The upward arrow indicates the ascending order, and the downward arrow indicates the descending order.
Figure 8 Basic sorting function example (based on IP address in the descending order)
