01 Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10001 Fundamentals Command Reference
09-Device management commands
09-Device management commands 301.83 KB
Device management commands 1
clock datetime· 1
clock protocol 2
clock summer-time· 2
clock timezone· 4
command· 5
copyright-info enable· 6
display clock· 7
display copyright 8
display cpu-usage· 8
display cpu-usage configuration· 9
display cpu-usage history· 10
display device· 12
display device manuinfo· 13
display device manuinfo fan· 14
display device manuinfo power 14
display diagnostic-information· 15
display environment 16
display fan· 17
display memory· 18
display memory-threshold· 19
display power 20
display scheduler job· 21
display scheduler logfile· 22
display scheduler reboot 22
display scheduler schedule· 23
display system-working-mode· 24
display switch-mode status 24
display transceiver alarm·· 25
display transceiver diagnosis 27
display transceiver interface· 28
display transceiver manuinfo· 29
display version· 30
display version-update-record· 30
fan prefer-direction· 31
header 32
job· 33
memory-threshold· 34
memory-threshold usage· 35
monitor cpu-usage enable· 36
monitor cpu-usage interval 37
monitor cpu-usage threshold· 37
password-recovery enable· 38
reboot 39
reset scheduler logfile· 40
reset version-update-record· 41
restore factory-default 41
scheduler job· 42
scheduler logfile size· 43
scheduler reboot at 43
scheduler reboot delay· 44
scheduler schedule· 45
shutdown-interval 46
switch-mode· 47
sysname· 48
system-working-mode· 48
temperature-limit 49
time at 50
time once· 51
time repeating· 52
usb disable· 54
user-role· 54
clock datetime
Use clock datetime to set the UTC time.
clock datetime time date
The UTC time is the factory-default time.
time: Specifies a time in the format hh:mm:ss. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
date: Specifies a date in the format MM/DD/YYYY or YYYY/MM/DD. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
When the system time source is the local system time, the system time varies by the following items:
·     Local time zone.
·     UTC time.
·     Daylight saving time.
To view the system time, use the display clock command.
The correct system time setting is essential to network management and communication. To run a device on a network, you must perform one of the following tasks on the device:
·     Set the system time correctly.
·     Use NTP to synchronize the device with a trusted time source.
# Set the UTC time to 08:08:08 01/01/2012.
<Sysname> clock datetime 8:8:8 1/1/2012
# Set the UTC time to 08:10:00 01/01/2012.
<Sysname> clock datetime 8:10 2012/1/1
·     clock protocol
·     clock summer-time
·     clock timezone
·     display clock
clock protocol
Use clock protocol to specify the system time source.
Use undo clock protocol to restore the default.
clock protocol { none | ntp | ptp }
undo clock protocol
The device uses the NTP time source.
none: Uses the local system time configured by using the clock datetime, clock timezone, and clock summer-time commands.
ptp: Uses the PTP time source. This keyword is not supported in the current release.
ntp: Uses the NTP time source. When the device uses the NTP time source, you cannot change the system time manually. For more information about NTP, see Network Management and Monitoring Configuration Guide.
If you configure this command multiple times, the most recent configuration takes effect.
# Configure the device to use the local system time.
[Sysname] clock protocol none
clock summer-time
Use clock summer-time to configure the device to use daylight saving time during a specific period of time.
Use undo clock summer-time to cancel the configuration.
Daylight saving time is disabled.
name: Specifies a name for the daylight saving time schedule, a case-sensitive string of 1 to 32 characters.
start-time: Specifies the start time in the format hh:mm:ss. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
start-date: Specifies the start date in one of the following formats:
·     MM/DD. The value range for MM is 1 to 12. The value range for DD varies by month.
·     month week date, where:
¡     month—Takes January, February, March, April, May, June, July, August, September, October, November or December.
¡     week—Represents week of the month. It takes first, second, third, fourth, fifth, or last.
¡     day—Takes Sunday, Monday, Tuesday, Wednesday, Thursday, Friday, or Saturday.
end-time: Specifies the end time in the format hh:mm:ss. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
end-date: Specifies the end date in one of the following formats:
add-time: Specifies the time to be added to the standard time, in the format hh:mm:ss. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
·     Local time zone.
·     UTC time.
The correct system time setting is essential to network management and communication. Set the system time correctly or use NTP or PTP to synchronize the device with a trusted time source before you run it on the network.
# Set the system time ahead 1 hour for the period between 06:00:00 on 08/01 and 06:00:00 on 09/01.
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
·     clock datetime
·     clock timezone
·     display clock
clock timezone
Use clock timezone to set the local time zone.
Use undo clock timezone to restore the default.
undo clock timezone
The local time zone is the UTC time zone.
zone-name: Specifies a time zone by its name, a case-sensitive string of 1 to 32 characters.
add: Adds an offset to the UTC time.
minus: Decreases the UTC time by an offset.
zone-offset: Specifies an offset to the UTC time, in the format hh:mm:ss. The value range for hh is 0 to 23. The value range for mm is 0 to 59. The value range for ss is 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
·     Local time zone.
·     UTC time.
# Set the name of the local time zone to Z5, and add 5 hours to the UTC time.
[Sysname] clock timezone Z5 add 5
·     clock datetime
·     clock summer-time
·     display clock
command
Use command to assign a command to a job.
Use undo command to revoke a command.
command id command
undo command id
No command is assigned to a job.
Job view
id: Specifies an ID for the command, in the range of 0 to 4294967295. A command ID uniquely identifies a command in a job. Commands in a job are executed in ascending order.
command: Specifies the command to be assigned to the job.
If a command uses the ID of an existing command, the existing command is replaced.
A job cannot contain any of these commands: telnet, ftp, ssh2, or monitor process.
The system does not check the validity of the command argument. You must make sure the command is supported by the device, is input in the correct format, and uses valid values. If these requirements are not met, the command cannot be executed automatically.
# Assign commands to job backupconfig to back up configuration file startup.cfg to the TFTP server at 192.168.100.11.
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
scheduler job
Use copyright-info enable to enable displaying the copyright statement.
Use undo copyright-info enable to disable displaying the copyright statement.
The copyright statement is displayed.
# Enable displaying the copyright statement.
[Sysname] copyright-info enable
·     When a Telnet user logs in, the following statement appears:
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                               *
* no decompiling or reverse-engineering shall be allowed.                  *
<Sysname>
·     When a console user quits user view, the device automatically restarts the console session and displays the following message:
User interface aux0 is available.
Press ENTER to get started.
# Disable displaying the copyright statement.
[Sysname] undo copyright-info enable
·     When a Telnet user logs in, the user view prompt appears:
<Sysname>
·     When a console user quits user view, the following message appears:
display clock
Use display clock to display the system time, date, local time zone, and daylight saving time.
display clock
# Display the system time and date when the local time zone is not specified.
<Sysname> display clock
10:09:00 UTC Fri 03/16/2012
# Display the system time and date when the local time zone Z5 is specified.
15:10:00 Z5 Fri 03/16/2012
Time Zone : Z5 add 05:00:00
# Display the system time and date when the local time zone Z5 and daylight saving time PDT are specified.
15:11:00 Z5 Fri 03/16/2012
·     clock datetime
·     clock timezone
·     clock summer-time
display copyright
Use display copyright to display the copyright statement, including software and hardware copyright statements, and third-party software license agreements.
display copyright
# Display the copyright statement.
<Sysname> display copyright
display cpu-usage
Use display cpu-usage to display CPU usage statistics.
display cpu-usage [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the CPU usage statistics for all IRF member devices.
cpu cpu-number: Displays the CPU usage statistics. The cpu-number argument must be 0.
After startup, the device tracks the average CPU usage at the following intervals:
·     5 seconds.
·     1 minute.
·     5 minutes.
This command displays the average CPU usage values during the last 5-second, 1-minute, and 5-minute intervals.
#  Display the current CPU usage statistics for all member devices.
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
       6% in last 5 seconds
      10% in last 1 minute
       5% in last 5 minutes
Average CPU usage during the last 5-second interval.
Average CPU usage during the last 1-minute interval.
Average CPU usage during the last 5-minute interval.
Slot x CPU y CPU usage
Usage statistics for CPU y of member device x.
Use display cpu-usage configuration to display CPU usage monitoring settings.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the CPU usage monitoring settings for the master device in the IRF fabric.
cpu cpu-number: Displays the CPU usage monitoring settings. The cpu-number argument must be 0.
# Display the CPU usage monitoring settings.
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current monitor threshold is 99%.
·     monitor cpu-usage enable
·     monitor cpu-usage interval
·     monitor cpu-usage threshold
Use display cpu-usage history to display the historical CPU usage statistics in charts.
job job-id: Specifies a process by its ID. If you do not specify this option, the command displays the historical CPU usage statistics for the entire system. To view the IDs and names of the running processes, use the display process command. For more information, see Network Management and Monitoring Configuration Guide.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the historical CPU usage statistics for the master device in the IRF fabric.
cpu cpu-number: Displays the historical CPU usage statistics. The cpu-number argument must be 0.
After CPU usage monitoring is enabled, the system regularly samples CPU usage and saves the samples to the history record buffer. This command displays the most recent 60 samples in a coordinate system as follows:
·     The vertical axis represents the CPU usage. If a statistic is not a multiple of the usage step, it is rounded up or down to the closest multiple of the usage step. For example, if the CPU usage step is 5%, the statistic 53% is rounded up to 55%, and the statistic 52% is rounded down to 50%.
·     The horizontal axis represents the time.
·     Consecutive pound signs (#) indicate the CPU usage at a specific time. The value on the vertical axis for the topmost pound sign at a specific time represents the CPU usage at that time.
# Display the historical CPU usage statistics for the entire system.
<Sysname> display cpu-usage history
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|             #
 10%|            ###  #
  5%|           ########
              10        20        30        40        50        60  (minutes)
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
The output shows the historical CPU usage statistics for the entire system (with the name SYSTEM) in the last 60 minutes.
·     12 minutes ago: Approximately 5%.
·     13 minutes ago: Approximately 10%.
·     14 minutes ago: Approximately 15%.
·     15 minutes ago: Approximately 10%.
·     16 and 17 minutes ago: Approximately 5%.
·     18 minutes ago: Approximately 10%.
·     19 minutes ago: Approximately 5%.
·     Other time: 2% or lower than 2%.
# Display the historical CPU usage statistics for process 1.
<Sysname> display cpu-usage history job 1
100%|
 95%|
 90%|
 85%|
 80%|
 75%|
 70%|
 65%|
 60%|
 55%|
 50%|
 45%|
 40%|
 35%|
 30%|
 25%|
 20%|
 15%|
 10%|
  5%|                   #
                      cpu-usage (Slot 1 CPU 0) last 60 minutes (scmd)
The output shows the historical CPU usage statistics of process 1 (with the process name scmd) in the last 60 minutes. A process name with square brackets ([ ]) means that the process is a kernel process.
·     20 minutes ago: Approximately 5%.
display device
Use display device to display device information.
display device [ flash | usb ] [ slot slot-number [ subslot subslot-number ] | verbose ]
flash: Specifies the flash memory.
usb: Specifies the device connected to the USB interface.
subslot subslot-number: Specifies a subcard by its subslot number.
verbose: Displays detailed hardware information. Without this keyword, the command displays brief information.
# Display device information for all IRF member devices in the IRF fabric.
<Sysname> display device
Slot Type             State    Subslot  Soft Ver             Patch Ver
1    S7502E-XS        Master   0        S7500E-XS-2418P05    None
Slot
ID of the IRF member device.
Type of the switch.
Status of the switch.
Subslot
Subslot number of the subcard.
Soft Ver
Software version.
Patch Ver
Patch version.
Use display device manuinfo to display the electronic label information for the device.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays electronic label information for all IRF member devices.
An electronic label is a profile of a device or card. It contains the permanent configuration, including the serial number, manufacturing date, MAC address, and vendor name. The data is written to the storage component during debugging or testing.
# Display the electronic label information for the device.
<Sysname>display device manuinfo
 Slot 1 CPU 0:
DEVICE_NAME          : S7500E-XS
DEVICE_SERIAL_NUMBER : 210235A1AE0000001234
MAC_ADDRESS          : 00E0-FC00-5800
MANUFACTURING_DATE   : 2008-05-08
VENDOR_NAME          : H3C
Fan 1
DEVICE_NAME          : LSQM1HFANSCB
DEVICE_SERIAL_NUMBER : 210231A0WFH115000073
MANUFACTURING_DATE   : 2011-11-12
VENDOR_NAME          : H3C
Fan 2
DEVICE_SERIAL_NUMBER : 210231A0WFH115000070
MANUFACTURING_DATE   : 2011-11-13
VENDOR_NAME          : H3C
Power 2
DEVICE_NAME          : LSVM1AC650
MANU SERIAL NUMBER   : 210231A0QMX129000007
MANUFACTURING_DATE   : 2011-11-14
VENDOR_NAME          : H3C
Slot x CPU y
Slot number of the card and number of the CPU.
Serial number.
MAC_ADDRESS
MAC address.
MANUFACTURING_DATE
Manufacturing date.
VENDOR_NAME
Vendor name.
Use display device manuinfo fan to display electronic label information for a fan.
display device manuinfo slot slot-number fan fan-id
fan-id: Specifies a fan by its ID.
# Display the electronic label information for fan 1.
<Sysname> display device manuinfo slot 1 fan 1
Fan 1:
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MANUFACTURING_DATE   : 2010-01-20
VENDOR_NAME          : H3C
Use display device manuinfo power to display the electronic label information for a power supply.
display device manuinfo slot slot-number power power-id
power-id: Specifies a power supply by its ID.
# Display the electronic label information for power supply 1.
<Sysname> display device manuinfo slot 1 power 1
Power 1:
VENDOR_NAME          : H3C
Use display diagnostic-information to display the operating statistics for multiple feature modules in the system.
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ filename ]
hardware: Displays hardware-related operating statistics.
infrastructure: Displays operating statistics for the fundamental modules.
l2: Displays operating statistics for the Layer 2 features.
l3: Displays operating statistics for the Layer 3 features.
service: Displays operating statistics for upper-layer features.
filename: Specifies a .tar.gz file to save the statistics to the file.
You can use one of the following methods to collect data for diagnostics and troubleshooting:
·     Use separate display commands to collect running status data module by module.
·     Use the display diagnostic-information command to bulk collect running data for multiple modules.
This display command does not support the | by-linenum option, the > filename option, or the >> filename option. However, this command asks you whether you want to save the output to a file or display the output on the screen. The file used to save the output is automatically compressed to save storage space.
# Display the operating statistics for multiple feature modules in the system.
14:03:55 UTC Thu 01/05/2012
display environment
Use display environment to display the temperature statistics for the temperature sensors, including the current temperature and temperature alarm thresholds.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the temperature statistics for all temperature sensors in the IRF fabric.
#  Display the temperature statistics for all temperature sensors on the device.
<Sysname>display environment
System temperature information (degree centigrade):
 Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1     hotspot 1 38           0      62       75     NA
 1     hotspot 2 36           0      62       75     NA
1     hotspot 3 36           0      52       55     NA
 1     hotspot 4 42           0      77       87     NA
Temperature information (°C).
sensor
Temperature sensor, hotspot for a hotspot sensor.
Slot x
Temperature
Current temperature.
Lower
Low-temperature threshold.
Warning
High-temperature warning threshold.
Alarm
High-temperature alarming threshold.
Shutdown
High-temperature shutdown threshold.
display fan
Use display fan to display the operating states of fans.
display fan [ slot slot-number [ fan-id ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the operating states of fans on all IRF member devices.
fan-id: Specifies a fan by its ID. If you do not specify this argument, the command displays the operating states of all fans on the specified member device.
# Display the operating states of all fans.
<Sysname> display fan
 Slot 1:
 Fan 1:
 State    : Normal
 Airflow Direction: Port-to-power
 Prefer Airflow Direction: Port-to-power
 Fan 2:
 State    : Normal
Table 5 Command output
Slot x
Fan 1
ID of the Fan.
Fan status:
·     Absent—No fan is installed in the position.
·     Normal—The fan is operating correctly.
·     Fault—The fan has a problem.
·     FanDirectionFault—The current air direction is different from the preferred airflow direction.
Airflow Direction
Current airflow direction:
·     Port-to-power—From the port side to the power supply side.
·     Power-to-port—From the power supply side to the port side.
Preferred airflow direction:
display memory
Use display memory to display memory usage.
display memory [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays memory usage for all member devices.
cpu cpu-number: Specifies a CPU by its number. The cpu-number argument must be 0.
# Display memory usage.
<Sysname>display memory
The statistics about memory is measured in KB:
Slot 1:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:       1784660    743988   1040672         0        92    282660       58.3%
-/+ Buffers/Cache:    461236   1323424
Swap:           0         0         0
Table 6 Command output
Slot
ID of an IRF member device.
Mem
Memory usage information.
Total
Total size of the physical memory space that can be allocated.
The memory space is virtually divided into two parts. Part 1 is solely used for kernel codes, kernel management, and ISSU functions. Part 2 can be allocated and used for such tasks as running service modules and storing files. The size of part 2 equals the total size minus the size of part 1.
Used
Used physical memory.
Free
Free physical memory.
Shared
Physical memory shared by processes.
Buffers
Physical memory used for buffers.
Cached
Physical memory used for caches.
FreeRatio
Free memory ratio.
-/+ Buffers/Cache
-/+ Buffers/Cache:Used = Mem:Used – Mem:Buffers – Mem:Cached, which indicates the physical memory used by applications.
-/+ Buffers/Cache:Free = Mem:Free + Mem:Buffers + Mem:Cached, which indicates the physical memory available for applications.
Swap
Swap memory.
Use display memory-threshold to display memory usage thresholds and memory usage notification statistics.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command displays the memory usage thresholds and memory usage notification statistics for the master device.
For more information about memory usage notifications, see log information containing MEM_EXCEED_THRESHOLD or MEM_BELOW_THRESHOLD.
# Display memory usage thresholds and memory usage notification statistics.
<Sysname>display memory-threshold
Memory usage threshold:  100%
Free memory threshold:
    Minor: 96M
    Severe: 64M
    Critical: 48M
    Normal: 128M
Current memory state: Normal
Event statistics:
 [Back to normal state]
    First notification: 0.0
    Latest notification: 0.0
    Total number of notifications sent: 0
 [Enter minor low-memory state]
    First notification at: 0.0
    Latest notification at: 0.0
 [Back to minor low-memory state]
 [Enter severe low-memory state]
 [Back to severe low-memory state]
 [Enter critical low-memory state]
·     memory-threshold
·     memory-threshold usage
display power
Use display power to display power supply information.
display power [ slot slot-number [ power-id ] ]
power-id: Specifies a power supply by its ID. If you do not specify this option, the command displays information about all power supplies on the specified member device.
# Display power supply information.
<Sysname> display power
Slot 1:
 Input Power: 244(W)
 PowerID State    Mode   Current(A)  Voltage(V)  Power(W)
 1       Absent   --        --          --          --
 2       Normal   AC        --          --          --
Use display scheduler job to display job configuration information.
job-name: Specifies a job by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays all jobs' configuration information.
# Display all jobs' configuration information.
<Sysname> display scheduler job
Job name: saveconfig
 copy startup.cfg backup.cfg
Job name: backupconfig
Job name: creat-VLAN100
 vlan 100
// The output shows that the device has three jobs: the first has one command, the second has no command, and the third has two commands. Jobs are separated by blank lines.
Use display scheduler logfile to display log information for executed jobs.
# Display job execution log information.
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name        : shutdown
Schedule name   : shutdown
Execution time  : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface range fortygige 1/1/1 to fortygige 1/1/2
[Sysname-if-range]shutdown
Table 7 Command output
Logfile Size
Size of the log file, in bytes.
Schedule name
Schedule to which the job belongs.
Execution time
Time when the job was started.
Completion time
Time when the job was completed. If the job has never been executed or the job has no commands, this field is blank.
Job output
Commands in the job and their output.
Use display scheduler reboot to display the automatic reboot schedule.
# Display the automatic reboot schedule.
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
·     scheduler reboot at
·     scheduler reboot delay
Use display scheduler schedule to display schedule information.
schedule-name: Specifies a schedule by its name, a case-sensitive string of 1 to 47 characters. If you do not specify this option, the command displays information about all schedules.
# Display information about all schedules.
<Sysname> display scheduler schedule
Schedule type        : Run once after 0 hours 2 minutes
Start time           : Tue Dec 27 10:44:42 2011
Last execution time  : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts     : 1
shutdown                                          Successful
Table 8 Command output
Schedule type
Execution time setting of the schedule. If no execution time is specified, this field is not displayed.
Start time
Time to execute the schedule for the first time. If no execution time is specified, this field is not displayed.
Last execution time
Last time when the schedule was executed. If no execution time is specified, this field is not displayed. If the schedule has never been executed, "Yet to be executed" is displayed for this field.
Last time when the schedule was completed. If no execution time is specified, this field is not displayed.
Execution counts
Number of times the schedule has been executed. If the schedule has never been executed, this field is not displayed.
Job name
Name of a job under the schedule.
Result of the most recent execution:
·     Successful.
·     Failed.
·     Waiting—The device is executing the schedule and the job is waiting to be executed.
·     In process—The job is being executed.
·     -NA-—The execution time has not arrived yet.
To view information about whether the commands in the job has been executed and the execution results, execute the display scheduler logfile command.
Use display system-working-mode to display system working mode information.
# Display system working mode information.
<Sysname> display system-working-mode
The current system working mode is standard.
The next system working mode is advance.
Use display switch-mode status to display table capacity mode information.
# Display table capacity mode information.
<Sysname> display switch-mode status
Switch-mode in use: 1--MAC table is 224K, L3 host table is 56K, LPM Table is 16K
Switch-mode at the next reboot: 0--MAC table is 288K, L3 host table is 16K, LPM
Table is 16K
Table 9 Command output
Switch-mode in use
Current table capacity mode.
Table capacity mode for the next reboot.
MAC table is 288K
Capacity of the MAC address table.
Capacity of the ARP or ND table.
LPM Table is 16K
Capacity of the routing table.
Use display transceiver alarm to display transceiver alarms.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the alarms present on every transceiver module.
Table 10 shows the common transceiver alarms. If no error occurs, "None" is displayed.
Table 10 Common transceiver alarms
SFP/SFP+:
RX loss of signal
Signal loss occurred in the inbound direction.
RX power high
The received optical power is high.
RX power low
The received optical power is low.
TX fault
Transmission error.
TX bias high
The transmitted bias current is high.
TX bias low
The transmitted bias current is low.
TX power high
The transmitted optical power is high.
TX power low
The transmitted optical power is low.
Temp high
The temperature is high.
Temp low
The temperature is low.
Voltage high
The voltage is high.
Voltage low
The voltage is low.
Transceiver info I/O error
Transceiver information read/write error.
Transceiver info checksum error
Transceiver information checksum error.
Transceiver type and port configuration mismatch
The type of the transceiver module does not match the port configuration.
Transceiver type not supported by port hardware
The port does not support this type of transceiver modules.
QSFP+:
RX signal loss in channel x
Signal loss occurred in the inbound direction of the specified channel.
TX fault in channel x
Transmission error occurred in the specified channel.
TX signal loss in channel x
Transmitted signals were lost in the specified channel.
RX power high in channel x
The received optical power is high in the specified channel.
RX power low in channel x
The received optical power is low in the specified channel.
TX bias high in channel x
The transmitted bias current is high in the specified channel.
TX bias low in channel x
The transmitted bias current is low in the specified channel.
Temp high
Temp low
Voltage high
Voltage low
The voltage is low.
The port does not support this type of transceiver module.
# Display the alarms present on the transceiver module in interface FortyGigE 1/1/1.
<Sysname> display transceiver alarm interface fortygige 1/1/1
FortyGigE1/1/1 transceiver current alarm information:
  Temp high
Table 11 Command output
Alarms present on the transceiver module.
RX loss of signal
Received signals are lost.
RX power low
Received power is low.
Temp high
Temperature is high.
Use display transceiver diagnosis to display the current values of the digital diagnosis parameters on transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays the current values of the digital diagnosis parameters on every transceiver module.
This command cannot display information about some transceiver modules.
# Display the current values of the digital diagnosis parameters on the transceiver module in interface FortyGigE 1/1/2.
<Sysname> display transceiver diagnosis interface fortygige 1/1/2
FortyGigE1/1/2 transceiver diagnostic information:
    Temp.(°C) Voltage(V)  Bias(mA)  RX power(dBm)  TX power(dBm)
    43         3.31        6.23      -6.50          -2.15
  Alarm thresholds:
          Temp(°C)  Voltage(V)  Bias(mA)  RX power(dBM)  TX power(dBM)
    High   75         -63        10.50       2.00           1.50
    Low    -5         2.97        2.00      -13.90         -11
Table 12 Command output
Digital diagnosis information of the transceiver module in the interface.
Temp.(°C)
Temperature in °C, accurate to 1°C.
Voltage(V)
Voltage in V, accurate to 0.01 V.
Bias(mA)
Bias current in mA, accurate to 0.01 mA.
RX power(dBm)
RX power in dBm, accurate to 0.01 dBm.
TX power(dBm)
TX power in dBm, accurate to 0.01 dBm.
Use display transceiver interface to display the key parameters of transceiver modules.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays the key parameters of every transceiver module.
# Display the key parameters of the transceiver module in interface FortyGigE 1/1/3.
<Sysname> display transceiver interface fortygige 1/1/3
FortyGigE1/1/3 transceiver information:
  Transceiver Type              : 40G_BASE_LR4_QSFP_PLUS
  Connector Type                : LC
  Wavelength(nm)                : 1301
  Transfer Distance(km)          : 10(SMF)
  Digital Diagnostic Monitoring : YES
  Vendor Name                   : H3C
  Ordering Name                 : QSFP-40G-LR4-WDM1300
Table 13 Command output
Transceiver information.
Transceiver Type
Transceiver type.
Connector Type
Connector type options:
·     MPO—Multi-fiber Push On.
·     LC—1.25 mm/RJ-45 fiber connector developed by Lucent.
·     RJ-45.
Wavelength(nm)
·     Fiber transceiver: Central wavelength (in nm) of the transmit laser. If the transceiver supports multiple wavelengths, every two wavelength values are separated by a comma.
·     Copper cable: Displayed as N/A.
Transfer Distance(xx)
Transfer distance, with "xx" representing the distance unit: km (kilometers) for single-mode transceiver modules and m (meters) for other transceiver modules.
If the transceiver module supports multiple transfer media, the transfer distances are separated by commas. The transfer medium is included in the bracket following the transfer distance value. The following are the transfer media:
·     9 um—9/125 um single-mode fiber.
·     50 um—50/125 um multi-mode fiber.
·     62.5 um—62.5/125 um multi-mode fiber.
·     TP—Twisted pair.
·     CX4—CX4 cable.
Support for the digital diagnosis function:
·     YES—Supported.
·     NO—Not supported.
Ordering Name
Product code.
Use display transceiver manuinfo to display electronic label information for transceiver modules.
interface [ interface-type interface-number ]: Specifies an interface by its type and number. If no interface is specified, this command displays electronic label information for the transceiver modules on all interfaces.
This command displays only part of the electronic label information.
# Display the electronic label information for the transceiver module in interface FortyGigE 1/1/4 .
<Sysname> display transceiver manuinfo interface fortygige 1/1/4
FortyGigE1/1/4 transceiver manufacture information:
  Manu. Serial Number  : 213410A0000054000251
  Manufacturing Date   : 2012-09-01
  Vendor Name          : H3C
Table 14 Command output
Manu. Serial Number
Serial number generated during production of the transceiver module.
Manufacturing Date
Date when the electronic label information was written to the transceiver module.
display version
Use display version to display system version information.
display version
# Display system version information.
<Sysname> display version
Use display version-update-record to display the startup software image upgrade history records of the master device.
The device records its current startup software version information and all subsequent version update information. Such information can survive reboots.
The maximum number of records is 10.
# Display the startup software image upgrade history records.
<Sysname>display version-update-record
Name                                   Version            Compile time
Record 1  (updated on Oct 25 2014 at 00:25:04):
* s7500e-xs-cmw710-boot-r2418P05.bin     7.1.045 ESS 2418P05 Oct 24 2014 17:45:29
* s7500e-xs-cmw710-system-r2418P05.bin   7.1.045 ESS 2418P05 Oct 24 2014 17:45:29
Table 15 Command output
Name
Software image file name.
The new software image is different from the old one.
Use fan prefer-direction to configure the preferred airflow direction.
Use undo fan prefer-direction to restore the default.
fan prefer-direction slot slot-number { power-to-port | port-to-power }
undo fan prefer-direction slot slot-number
The default preferred airflow direction is from the power supply side to the port side.
power-to-port: Specifies the airflow direction from the power supply side to the port side.
port-to-power: Specifies the airflow direction from the port side to the power supply side.
# Set the preferred airflow direction to port-to-power for member device 1.
[Sysname] fan prefer-direction slot 1 port-to-power
display fan
header
Use header to create a banner.
Use undo header to clear a banner.
header { incoming | legal | login | motd | shell } text
undo header { incoming | legal | login | motd | shell }
The device does not have any banner.
incoming: Configures the banner to be displayed before a modem dial-up user accesses user view. If authentication is required, the incoming banner appears after the authentication is passed.
legal: Configures the banner to be displayed before a user inputs the username and password to access the CLI.
login: Configures the banner displayed to be before password or scheme authentication is performed for a login user.
motd: Configures the greeting banner to be displayed before the legal banner appears.
shell: Configures the banner to be displayed before a non-modem dial-in user accesses user view.
text: Specifies the banner message, which can be entered in two formats. For more information, see Fundamentals Configuration Guide.
# Create the incoming banner, legal banner, login banner, MOTD banner, and shell banner.
[Sysname] header incoming
Welcome to incoming(header incoming)%
[Sysname] header legal
Welcome to legal (header legal)%
[Sysname] header login
Welcome to login(header login)%
[Sysname] header motd
Welcome to motd(header motd)%
[Sysname] header shell
Welcome to shell(header shell)%
In this example, the percentage sign (%) is the starting and ending character of the text argument. Entering the percentage sign after the text quits the header command. Because it is the starting and ending character, the percentage sign is not included in the banner.
# Test the configuration by using Telnet. The login banner appears only when password or scheme login authentication has been configured.
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
 Press Y or ENTER to continue, N to exit.
Password:
job
Use job to assign a job to a schedule.
Use undo job to revoke a job.
job job-name
undo job job-name
No job is assigned to a schedule.
Schedule view
job-name: Specifies the job name, a case-sensitive string of 1 to 47 characters.
You can assign multiple jobs to a schedule. The jobs in a schedule are executed concurrently.
The jobs to be assigned to a schedule must already exist. To create a job, use the scheduler job command.
# Assign job save-job to schedule saveconfig.
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
·     scheduler job
·     scheduler schedule
memory-threshold
Use memory-threshold to set free-memory thresholds.
Use undo memory-threshold to restore the defaults.
memory-threshold [ slot slot-number [ cpu cpu-number ] ] minor minor-value severe severe-value critical critical-value normal normal-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
·     Minor alarm threshold: 96 MB.
·     Severe alarm threshold: 64 MB.
·     Critical alarm threshold: 48 MB.
·     Normal state threshold: 128 MB.
minor minor-value: Specifies the minor alarm threshold in the range of 0 to 1742. This threshold must be equal to or less than the normal state threshold. Setting this threshold to 0 disables the minor alarm function.
severe severe-value: Specifies the severe alarm threshold in the range of 0 to 1742. This threshold must be equal to or less than the minor alarm threshold. Setting this threshold to 0 disables the severe alarm function.
critical critical-value: Specifies the critical alarm threshold in the range of 0 to 1742. This threshold must be equal to or less than the severe alarm threshold. Setting this threshold to 0 disables the critical alarm function.
normal normal-value: Specifies the normal state threshold in the range of 0 to 1742. This threshold must be equal to or less than the total memory size.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command sets free-memory thresholds for the master device.
To ensure correct operation and improve memory utilization, the system monitors the amount of free memory space in real time. When a threshold is exceeded, the system sends an alarm notification or an alarm-removed notification to affected feature modules or processes so they can take countermeasures. For more information about the thresholds, see Fundamentals Configuration Guide.
# Set the minor alarm, severe alarm, critical alarm, and normal state thresholds to 64 MB, 48 MB, 32 MB, and 96 MB, respectively.
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
·     display memory-threshold
Use memory-threshold usage to set the memory usage threshold.
Use undo memory-threshold usage to restore the default.
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
The memory usage threshold is 100%.
memory-threshold: Specifies the memory usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command sets the memory usage threshold for the master device.
The device samples memory usage at an interval of 1 minute, and compares the sample with the memory usage threshold. If the sample is greater, the device sends a trap.
# Set the memory usage threshold to 80%.
[Sysname] memory-threshold threshold 80
·     memory-threshold
Use monitor cpu-usage enable to enable CPU usage recording.
Use undo monitor cpu-usage enable to disable CPU usage recording.
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
CPU usage recording is enabled.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command enables CPU usage recording for the master device.
# Enable CPU usage recording.
[Sysname] monitor cpu-usage enable
·     display cpu-usage configuration
·     display cpu-usage history
Use monitor cpu-usage interval to set the CPU usage sampling interval.
monitor cpu-usage interval interval-value [ slot slot-number [ cpu cpu-number ] ]
The CPU usage sampling interval is 1 minute.
interval-value: Specifies the CPU usage sampling interval. Valid values include 5Sec for 5 seconds, 1Min for 1 minute, and 5Min for 5 minutes.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command sets the CPU usage sampling interval for the master device.
# Set the CPU usage sampling interval to 5 seconds.
[Sysname] monitor cpu-usage interval 5Sec
Use monitor cpu-usage threshold to set CPU usage thresholds.
Use undo monitor cpu-usage threshold to restore the defaults.
monitor cpu-usage threshold cpu-threshold [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ slot slot-number [ cpu cpu-number ] ]
The CPU usage threshold is 99%.
cpu-threshold: Specifies a CPU usage threshold in percentage. The value range is 0 to 100.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command sets the CPU usage threshold for the master device.
The device samples CPU usage at an interval of 1 minute, and compares the sample with the CPU usage threshold. If the sample is greater than the CPU usage threshold, the device sends a trap.
# Set the CPU usage threshold to 80%.
[Sysname] monitor cpu-usage threshold 80
·     display cpu-usage
Use password-recovery enable to enable password recovery capability.
Use undo password-recovery enable to disable password recovery capability.
Password recovery capability is enabled.
Password recovery capability controls console user access to the device configuration and SDRAM from Boot ROM menus.
If password recovery capability is enabled, a console user can access the device configuration without authentication to configure new passwords.
If password recovery capability is disabled, console users must restore the factory-default configuration before they can configure new passwords. Restoring the factory-default configuration deletes the next-startup configuration files.
To enhance system security, disable password recovery capability.
Availability of Boot ROM menu options varies by the password recovery capability setting. For more information, see the release notes.
# Disable password recovery capability.
[Sysname] undo password-recovery enable
reboot
Use reboot to reboot an IRF member device or all IRF member devices.
The default setting varies by device model.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify this option, the command reboots all member devices.
force: Reboots the device immediately without performing any software check. If this keyword is not specified, the system first checks whether the reboot might result in data loss or a system failure. For example, the system checks whether the main system software image file exists and whether a write operation is in progress on a storage medium. If the reboot might cause problems, the system does not reboot the device.
CAUTION
CAUTION:
·     A device reboot might interrupt network services.
·     If the main startup software images are corrupted or missing, you must re-specify a set of main startup software images before executing the reboot command.
For data security, the device does not reboot if you reboot the device while the device is performing file operations.
Use the force keyword only when you cannot reboot the device without using it.
# Reboot the device when no configuration change has occurred since the last time you saved the running configuration.
<Sysname> reboot
Now rebooting, please wait...
# If any configuration has changed, reboot the device and save the configuration.
<Sysname> reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to flash successfully.
# If any configuration has changed, reboot the device but do not save the configuration.
<Sysname> reboot
Current configuration may be lost after the reboot, save current configuration? [Y/N]:n
# Reboot the device immediately without performing any software check.
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
Use reset scheduler logfile to clear job execution log information.
None
# Clear job execution log information.
<Sysname> reset scheduler logfile
Use reset version-update-record to clear the startup software image upgrade history records of the master device.
# Clear the startup software image upgrade history records.
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
Use restore factory-default to restore the factory-default settings and states.
CAUTION
CAUTION:
This command is disruptive. Use this command only when you cannot troubleshoot the device by using other methods, or you want to use the device in a different scenario.
If a device fails or you want to use it in a different scenario, you can restore the factory-default settings and states for the device.
This command performs the following tasks:
·     Deletes all configuration files (.cfg files) in the root directories of the storage media.
·     Deletes all log files (.log files in the folder /logfile).
·     Clears all log information (in the log buffer), trap information, and debugging information.
·     Restores the parameters for the BootWare to the factory-default settings.
·     Deletes all license files (.ak files).
·     Deletes all files on an installed hot-swappable storage medium, such as a USB disk.
Before this operation, remove all hot-swappable storage media from the device.
# Restore the factory-default settings and states for the device.
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
reboot
scheduler job
Use scheduler job to create a job and enter job view. If the job already exists, you enter job view directly.
Use undo scheduler job to delete a job.
scheduler job job-name
undo scheduler job job-name
No job exists.
A job can be referenced by multiple schedules. In job view, you can assign commands to the job.
# Create a job named backupconfig and enter job view.
·     command
Use scheduler logfile size to set the size of the job execution log file.
scheduler logfile size value
The size of the job execution log file is 16 KB.
value: Sets the size of the job execution log file, in KB. The value range is 16 to 1024.
The job execution log file saves the execution information of jobs. If the file is full, old records are deleted to make room for new records. If the size of the log information is greater than the file size, the excessive information is not written to the file.
# Set the size of the job execution log file to 32 KB.
[Sysname] scheduler logfile size 32
scheduler reboot at
Use scheduler reboot at to specify the reboot date and time.
Use undo scheduler reboot to remove the reboot schedule configuration.
No reboot date or time is specified.
time: Specifies the reboot time in the format hh:mm. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the reboot date in the format MM/DD/YYYY or YYYY/MM/DD. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
CAUTION
CAUTION:
Device reboot interrupts network services.
When the date argument is not specified, the system uses the following rules to determine the reboot time:
·     If the reboot time is later than the current time, a reboot occurs at the reboot time of the current day.
·     If the reboot time is earlier than the current time, a reboot occurs at the reboot time the next day.
For data security, if you are performing file operations at the reboot time, the system does not reboot.
The device supports only one device reboot schedule. If you configure both the schedule reboot delay and schedule reboot delay commands or configure one of the commands multiple times, the most recent configuration takes effect.
# Configure the device to reboot at 12:00 p.m. This example assumes that the current time is 11:43 a.m. on June 6, 2011.
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
Use scheduler reboot delay to specify the reboot delay time.
scheduler reboot delay time
No reboot delay time is specified.
time: Specifies the reboot delay time in the format hh:mm or mm. This argument can consist up to 6 characters. When in the format hh:mm, mm must be in the range of 0 to 59.
CAUTION
CAUTION:
# Configure the device to reboot after 88 minutes. This example assumes that the current time is 11:48 a.m. on June 6, 2011.
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule
Use scheduler schedule to create a schedule and enter schedule view. If the schedule already exists, you enter schedule view directly.
Use undo scheduler schedule to delete a schedule.
undo scheduler schedule schedule-name
No schedule exists.
schedule-name: Specifies the schedule name, a case-sensitive string of 1 to 47 characters.
You can schedule a job to have the device automatically run a command or a set of commands without administrative interference.
To configure a schedule:
1.     Use the scheduler job command to create a job.
2.     In job view, use the command command to assign commands to the job.
3.     Use the scheduler schedule command to create a schedule.
4.     In schedule view, use the job command to assign the job to the schedule. You can assign multiple jobs to a schedule. The jobs must already exist.
5.     In schedule view, use the user-role command to assign user roles to the schedule. You can assign up to 64 user roles to a schedule.
6.     In schedule view, use the time at, time once, or time repeating command to specify an execution time for the schedule. You can specify only one execution time per schedule.
# Create a schedule named saveconfig.
·     job
·     time at
·     time once
shutdown-interval
Use shutdown-interval to set the detection timer.
Use undo shutdown-interval to restore the default.
shutdown-interval time
The detection interval is 30 seconds.
time: Specifies a detection timer in the range of 0 to 300 seconds. Setting it to 0 disables the detection function.
The device starts a detection timer when a port is shut down by a protocol. Once the timer expires, the device brings up the port so the port status reflects the port's physical status.
If you change the timer during port detection, the device compares the new setting (T1) with the time that elapsed since the port was shut down (T).
·     If T<T1, the port will be brought up after T1-T seconds.
·     If T>=T1, the port is brought up immediately.
For example, if you change the timer from 30 seconds to 10 seconds two seconds after the port is shut down, the port will come up 8 seconds later. If you change the timer from 30 seconds to 2 seconds ten seconds after the port is shut down, the port comes up immediately.
# Set the detection timer to 100 seconds.
[Sysname] shutdown-interval 100
switch-mode
Use switch-mode to set the table capacity mode.
switch-mode { 0 | 1 | 2 | 3 | 4 | 5 }
The table capacity mode is 0.
0: Sets the table capacity mode to 0.
1: Sets the table capacity mode to 1.
2: Sets the table capacity mode to 2.
3: Sets the table capacity mode to 3.
4: Sets the table capacity mode to 4.
5: Sets the table capacity mode to 5.
The switch supports multiple table capacity modes. The capacities of the MAC address table, ARP/ND table, and routing table vary by the following items:
·     Table capacity mode.
·     Whether the switch-routing-mode ipv6-128 command is configured. For more information about the switch-routing-mode ipv6-128 command, see Layer 3—IP Routing Command Reference.
For table capacities in different scenarios, see Fundamentals Configuration Guide.
Mode 4 and the switch-routing-mode ipv6-128 command are mutually exclusive.
Mode 5 and the switch-routing-mode ipv6-128 command are mutually exclusive.
This setting takes effect after a reboot. Before rebooting the switch, make sure you know the possible impact on the network.
# Set the table capacity mode to 2.
[Sysname] switch-mode 2
Reboot device to make the configuration take effect.
sysname
Use sysname to set the device name.
Use undo sysname to restore the default.
sysname sysname
undo sysname
The default device name is H3C.
sysname: Specifies a name for the device, a string of 1 to 64 characters.
A device name identifies a device in a network and is used as the user view prompt at the CLI. For example, if the device name is Sysname, the user view prompt is <Sysname>.
# Set the name of the device to R2000.
[Sysname] sysname R2000
[R2000]
system-working-mode
Use system-working-mode to set the system operating mode.
Use undo system-working-mode to restore the default.
system-working-mode { advance | standard | expert }
The device operates in standard mode.
advance: Sets the system operating mode to advanced.
standard: Sets the system operating mode to standard.
expert: Sets the system operating mode to expert.
After changing the operating mode, you must reboot the device to make the device operate in the new mode.
In different operating modes, the device supports different features, and might have different specifications for the supported features.
If the prompt "Not enough hardware resources available." appears after you set the system operating mode, perform the following tasks:
·     Use the display qos-acl resource command to display ACL resource usage.
·     Use the undo acl command to release ACL resources as required.
·     Set the system operating mode again.
For more information about the display qos-acl resource and undo acl commands, see ACL and QoS Command Reference.
# Set the system operating mode to advanced.
[Sysname] system-working-mode advance
Do you want to change the system working mode? [Y/N]:y
The system working mode is changed, please save the configuration and reboot the system to make it effective.
temperature-limit
Use temperature-limit to set the temperature alarm thresholds for the device.
Use undo temperature-limit to restore the default.
temperature-limit slot slot-number hotspot sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number hotspot sensor-number
To view the default settings, execute the undo temperature-limit and display environment commands in turn.
hotspot: Configures temperature alarm thresholds for hotspot sensors. A hotspot sensor is typically near the chip that generates a great amount of heat and used to monitor the chip.
sensor-number: Specifies a sensor by its number, an integer starting from 1. Each number represents a temperature sensor on the device.
lowlimit: Specifies the low-temperature threshold in Celsius degrees.
warninglimit: Specifies the high-temperature warning threshold in Celsius degrees. This threshold must be greater than the low-temperature threshold.
alarmlimit: Specifies the high-temperature alarming threshold in Celsius degrees. This threshold must be greater than the warning threshold.
The value ranges for the sensor number and thresholds vary by device model. To view the value ranges, use the CLI online help.
When the device temperature drops below the low-temperature threshold or reaches the high-temperature warning threshold, the device performs the following tasks:
·     Logs the event.
·     Sends a log message.
When the device temperature reaches the high-temperature alarming threshold, the device performs the following tasks:
·     Logs the event.
·     Sends log messages repeatedly.
·     Sets the LEDs on the device panel.
# Set temperature alarm thresholds for Hotspot 1 on member device 1.
[sysname] temperature-limit slot 1 hotspot 1 -10 70 100
time at
Use time at to specify an execution date and time for a one-time schedule.
Use undo time to remove the execution time configuration for a schedule.
time at time date
undo time
No execution time or date is specified for a schedule.
Schedule view
time: Specifies the schedule execution time in the format hh:mm. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
date: Specifies the schedule execution date in the format MM/DD/YYYY or YYYY/MM/DD. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month.
The specified time (date plus time) must be later than the current system time.
The time at command, the time once command, and the time repeating command overwrite one another. The most recently configured command takes effect.
# Configure the device to execute schedule saveconfig at 01:01 a.m. on May 11, 2011.
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
scheduler schedule
time once
Use time once to specify one or more execution days and the execution time for a one-time schedule.
time once delay time
undo time
No execution time or day is specified for a schedule.
Schedule view
at time: Specifies the execution time in the format hh:mm. The value range for hh is 0 to 23. The value range for mm is 0 to 59.
month-date month-day: Specifies a day in the current month, in the range of 1 to 31. If you specify a day that does not exist in the current month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days for the schedule. Valid values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
delay time: Specifies the delay time for executing the schedule, in the format hh:mm or mm. This argument can consist up to 6 characters. When in the format hh:mm, mm must be in the range of 0 to 59.
If the specified time has already occurred, the schedule will be executed at the specified time the following day.
If the day in the month has already occurred, the schedule will be executed at the specified day in the following month.
If the specified day in a week has already occurred, the schedule will be executed at the specified day in the following week.
# Configure the device to execute schedule saveconfig once at 15:00.
[Sysname-schedule-saveconfig] time once at 15:00
Schedule starts at 15:00 5/11/2011.
# Configure the device to execute schedule saveconfig once at 15:00 on the coming 15th day in a month.
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# Configure the device to execute schedule saveconfig at 12:00 p.m. on the coming Monday and Friday.
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# Configure the device to execute schedule saveconfig after 10 minutes.
[Sysname-schedule-saveconfig] time once delay 10
scheduler schedule
time repeating
Use time repeating to specify an execution time table for a periodic schedule.
time repeating [ at time [ date ] ] interval interval-time
undo time
No execution time table is specified for a schedule.
Schedule view
at time: Specifies the execution time in the format hh:mm. The value range for hh is 0 to 23. The value range for mm is 0 to 59. If you do not specify this option, the current system time is used as the execution time.
date: Specifies the start date for the periodic schedule, in the format MM/DD/YYYY or YYYY/MM/DD. The value range for YYYY is 2000 to 2035. The value range for MM is 1 to 12. The value range for DD varies by month. If you do not specify this argument, the execution start date is the first day when the specified time arrives.
interval interval-time: Specifies the execution time interval in the format hh:mm or mm. This argument can consist up to 6 characters. When in the format hh:mm, mm must be in the range of 0 to 59. When in the format mm, this argument must be equal to or greater than 1 minute.
month-date [ month-day | last ]: Specifies a day in a month, in the range 1 to 31. The last keyword indicates the last day of a month. If you specify a day that does not exist in a month, the configuration takes effect on that day in the next month.
week-day week-day&<1-7>: Specifies a space-separated list of up to seven week days. Valid values include Mon, Tue, Wed, Thu, Fri, Sat, and Sun.
The time repeating [ at time [ date ] ] interval interval-time command configures the device to execute the schedule regularly from the specified time on.
The time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ] command configures the device to execute the schedule at the specified time on every specified day in a month or week.
The time at command, the time once command, and the time repeating command overwrite one another, whichever is configured most recently takes effect.
# Configure the device to execute schedule saveconfig once an hour from 8:00 a.m. on.
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# Configure the device to execute schedule saveconfig at 12:00 p.m. every day.
[Sysname-schedule-saveconfig] time repeating at 12:00
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the 5th of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# Configure the device to execute schedule saveconfig at 8:00 a.m. on the last day of every month.
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# Configure the device to execute schedule saveconfig at 8:00 a.m. every Friday and Saturday.
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
scheduler schedule
usb disable
Use usb disable to disable all USB interfaces.
Use undo usb disable to enable all USB interfaces.
usb disable
undo usb disable
All USB interfaces are enabled.
You can use USB interfaces to upload or download files. By default, all USB interfaces are enabled.
Before executing this command, use the umount command to unmount all USB partitions.
# Unmount all USB partitions before disabling USB interfaces.
<Sysname> umount slot1#usba0:
[Sysname] usb disable
# Enable all USB interfaces.
[Sysname] undo usb disable
user-role
Use user-role to assign user roles to a schedule.
Use undo user-role to remove user roles from a schedule.
user-role role-name
undo user-role role-name
A schedule has the user roles of the schedule creator.
Schedule view
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined. Predefined user roles include network-admin, network-operator, level-0 to level-15, and security-audit.
By assigning user roles to and removing user roles from a schedule, you can control the commands to be executed in the schedule.
A schedule must have one or more user roles, and can have up to 64 user roles. A command in a schedule can be executed if it is permitted by one or more user roles of the schedule.
You must have the network-admin user role to assign user roles to or remove user roles from a schedule. You can assign only user roles lower than your own user role.
The security-audit user role is mutually exclusive with any other user roles. Assigning the security-audit user role to a schedule removes all the other user role assignments for the schedule. Assigning any other user roles to a schedule removes the security-audit user role assignment for the schedule.
For more information about user roles, see the RBAC configuration in Fundamentals Configuration Guide.
# Assign user role rolename to schedule test.
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
[Sysname-schedule-test] display this
 user-role network-admin
 user-role network-operator
 user-role rolename
return
·     command
