01 Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10001 Fundamentals Command Reference
01-CLI commands
01-CLI commands 94.65 KB
Basic CLI commands
command-alias enable
Use command-alias enable to enable the command keyword alias function.
Use undo command-alias enable to disable the command keyword alias function.
The command keyword alias function is disabled.
Configured command keyword aliases take effect only when the command keyword alias function is enabled.
Disabling the command keyword alias function does not delete configured aliases.
# Enable the command keyword alias function.
[Sysname] command-alias enable
·     command-alias mapping
·     display command-alias
Use command-alias mapping to configure a command keyword alias.
Use undo command-alias mapping to delete a command keyword alias.
command-alias mapping cmdkey alias
undo command-alias mapping cmdkey
A command keyword has no alias.
cmdkey: Specifies the first keyword of a non-undo command or the second keyword of an undo command. You must enter the keyword in its complete form.
alias: Specifies an alias for the keyword, a string of 1 to 20 characters. It must be different from the first keyword of any non-undo command and the second keyword of any undo command.
You can configure an alias for the first keyword of a non-undo command or the second keyword of an undo command. Then, when you execute a command that starts with the keyword or the undo keyword plus the keyword, you can use the alias. For example, if you configure show as the alias for the display keyword, you can enter show clock to execute the display clock command.
To use configured command keyword aliases, make sure the command-alias enable command is configured.
# Define show as the alias of the display keyword.
[Sysname] command-alias mapping display show
·     command-alias enable
display | { begin | exclude | include }
Use display | { begin | exclude | include } to filter the output from a display command with a regular expression.
display command | { begin | exclude | include } regular-expression
command: Specifies the keywords and arguments of a display command. To display available keywords and arguments, enter display ?.
begin: Displays the first line matching the specified regular expression and all subsequent lines.
exclude: Displays all lines not matching the specified regular expression.
include: Displays all lines matching the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the | { begin | exclude | include } regular-expression option with a display command to filter the command output. For more information about regular expressions, see Fundamentals Configuration Guide.
# Display the lines that contain vlan in the running configuration.
<Sysname> display current-configuration | include vlan
vlan 1
vlan 999
 port access vlan 999
display | by-linenum
Use display | by-linenum to number each output line for a display command.
display command | by-linenum
By numbering each output line from a display command, you can easily identify the lines of interest.
Each line number is displayed as a 5-character string and might be followed by a colon (:) or hyphen (-). If you specify both | by-linenum and | begin regular-expression for a display command, a hyphen is displayed for all lines that do not match the regular expression.
# Display CPU usage information, with each output line identified by a number.
<Sysname> display cpu-usage | by-linenum
    1:  Slot 1 CPU 0 CPU usage:
    2:        14% in last 5 seconds
    3:        14% in last 1 minute
    4:        13% in last 5 minutes
# Display the first line that begins with user-group in the running configuration and all of the following lines.
<Sysname> display current-configuration | by-linenum begin user-group
  114:  user-group system
  115-  #
  116-  return
display >
Use display > to save the output from a display command to a separate file.
display command > filename
filename: Specifies the name of the file that is used to save the output, a string of 1 to 63 characters.
The display commands show the configuration, statistics, and states of the device. You can use the display > command to save the output to a file.
If the specified file does not exist, the system creates the file and saves the output to the file. If the file already exists, the system overwrites the file.
# Save CPU usage information to a separate file named cpu.txt.
<Sysname> display cpu-usage > cpu.txt
# Verify the content of the cpu.txt file.
<Sysname> more cpu.txt
      13% in last 5 seconds
      13% in last 1 minute
display >>
Use display >> to append the output from a display command to the end of a file.
display command >> filename
The display commands show the configuration, statistics, and states of the device. You can use display >> to save the output to a file.
If the specified file does not exist, the system creates the file and saves the output to the file. If the file already exists, the system appends the output to the end of the file.
# Append system time information to the end of the cpu.txt file.
<Sysname> display clock >> cpu.txt
# Check the content of the cpu.txt file.
02:03:27 UTC Tue 01/01/2013
Use display command-alias to display the status of the command keyword alias function and the configured command keyword alias.
# Display command keyword alias information.
<Sysname> display command-alias
Command alias is enabled
Index Alias                Command key
1     ping1                ping
2     ssh1                 ssh
display history-command
Use display history-command to display all commands that are saved in the command history buffer for the current CLI session.
The system automatically saves commands you have successfully executed to the command history buffer for the current CLI session. You can view them and execute them again.
By default, the system can save up to 10 commands in the buffer. You can use the history-command max-size command to change the buffer size.
# Display all commands saved in the command history buffer for the current CLI session.
<Sysname> display history-command
  vlan 2
display history-command all
Use display history-command all to display all commands saved in the command history buffer for all CLI sessions.
The system automatically saves commands successfully executed by users to the command history buffer for all CLI sessions. Users can view them and execute them again.
Up to 1024 commands can be saved in the command history buffer. When this number is reached, the system deletes the earliest commands to make room for newly executed commands.
# Display all commands saved in the command history buffer for all CLI sessions.
<Sysname> display history-command all
  Date       Time     Terminal   Ip              User
  03/16/2012 20:03:33 vty0       192.168.1.26    **
  Cmd:dis his all
  03/16/2012 20:03:29 vty0       192.168.1.26    **
  Cmd:sys
display hotkey
Use display hotkey to display hotkey information.
display hotkey
# Display hotkey information.
<Sysname> display hotkey
----------------- Hotkeys -----------------
           -Defined command hotkeys-
CTRL_G display current-configuration
CTRL_L display ip routing-table
CTRL_O undo debugging all
           -Undefined command hotkeys-
CTRL_T NULL
CTRL_U NULL
           -System-reserved hotkeys-
CTRL_A  Move the cursor to the beginning of the line.
CTRL_B  Move the cursor one character to the left.
CTRL_C  Stop the current command.
CTRL_D  Erase the character at the cursor.
CTRL_E  Move the cursor to the end of the line.
CTRL_F  Move the cursor one character to the right.
CTRL_H  Erase the character to the left of the cursor.
CTRL_K  Abort the connection request.
CTRL_N  Display the next command in the history buffer.
CTRL_P  Display the previous command in the history buffer.
CTRL_R  Redisplay the current line.
CTRL_V  Paste text from the clipboard.
CTRL_W  Delete the word to the left of the cursor.
CTRL_X  Delete all characters from the beginning of the line to the cursor.
CTRL_Y  Delete all characters from the cursor to the end of the line.
CTRL_Z  Return to the User View.
CTRL_]  Kill incoming connection or redirect connection.
ESC_B   Move the cursor back one word.
ESC_D   Delete all characters from the cursor to the end of the word.
ESC_F   Move the cursor forward one word.
hotkey
hotkey
Use hotkey to assign a command to a configurable hotkey.
Use undo hotkey to restore the default.
hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U } command
undo hotkey { CTRL_G | CTRL_L | CTRL_O | CTRL_T | CTRL_U }
·     Ctrl_G: display current-configuration (display the running configuration).
·     Ctrl_L: display ip routing-table (display the IPv4 routing table information).
·     Ctrl_O: undo debugging all (disable all debugging functions).
·     Ctrl_T: No command is assigned to this hotkey.
·     Ctrl_U: No command is assigned to this hotkey.
CTRL_G: Assigns a command to Ctrl+G.
CTRL_L: Assigns a command to Ctrl+L.
CTRL_O: Assigns a command to Ctrl+O.
CTRL_T: Assigns a command to Ctrl+T.
CTRL_U: Assigns a command to Ctrl+U.
command: Specifies the command to be assigned to the hotkey.
The system defines some hotkeys and provides five configurable command hotkeys. Pressing a hotkey executes the command assigned to the hotkey.
To display system-defined and configurable hotkeys, use the display hotkey command.
# Assign the display tcp status command to the hotkey Ctrl+T.
[Sysname] hotkey ctrl_t display tcp status
display hotkey
Use quit to return to the upper-level view.
Executing this command in user view disconnects you from the device.
# Return from the view of VLAN-interface 1 to system view and then to user view.
[Sysname-vlan1] quit
[Sysname] quit
<Sysname>
return
Use return to return to user view from any other view.
return
Any view except user view
Pressing Ctrl+Z has the same effect as the return command.
# Return to user view from the view of VLAN-interface 1.
[Sysname-vlan1] return
<Sysname>
screen-length disable
Use screen-length disable to disable pausing between screens of output for the current session.
Use undo screen-length disable to enable pausing between screens of output for the current session.
The default varies by settings of the screen-length command in user line view.
The following are the default settings for the screen-length command:
·     Pausing between screens of output.
·     Displaying up to 24 lines on a screen.
If you disable pausing between screens of output, all output is displayed. The screen is refreshed continuously until the final screen is displayed.
This command takes effect only for the current session. When you are logged out, the default is restored.
# Disable pausing between screens of output for the current session.
<Sysname> screen-length disable
screen-length
Use system-view to enter system view from user view.
# Enter system view from user view.
[Sysname]
