01 Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10001 Fundamentals Command Reference
02-Login management commands
02-Login management commands 201.19 KB
Some login management commands are available in both user line view and user line class view. For these commands, the device uses the following rules to determine the settings to be activated:
·     A setting in user line view is applied only to the user line. A setting in user line class view is applied to all user lines of the class.
·     A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
·     A setting in user line view takes effect immediately and affects the online user. A setting in user line class view does not affect online users. It takes effect only for new login users.
activation-key
Use activation-key to define a shortcut key for starting a terminal session.
Use undo activation-key to restore the default.
activation-key key-string
undo activation-key
Pressing Enter starts a terminal session.
User line view, user line class view
key-string: Specifies the shortcut key. It can be a character (case sensitive), or an ASCII code value in the range of 0 to 127. For example, activation-key 65 defines the shortcut key A. If you configure activation-key a, the shortcut key is a.
This command is not supported in VTY line view or VTY line class view.
This command is available in both user line view and user line class view. A non-default setting in either view takes precedence over a default setting in the other view. A non-default setting in user line view takes precedence over a non-default setting in user line class view.
To display the shortcut key you have defined, use the display current-configuration | include activation-key command.
# Configure character s as the shortcut key for starting a terminal session on the AUX line.
[Sysname] line aux 0
[Sysname-line-aux0] activation-key s
To verify the configuration:
1.     Exit the console session.
[Sysname-line-aux0] return
<Sysname> quit
2.     Log in again through the AUX line.
The following message appears:
Press ENTER to get started.
3.     Press Enter.
Pressing Enter does not start a session.
4.     Enter s.
A terminal session is started.
<Sysname>
authentication-mode
Use authentication-mode to set the authentication mode for a user line.
Use undo authentication-mode to restore the default.
In non-FIPS mode:
authentication-mode { none | password | scheme }
In FIPS mode:
authentication-mode scheme
In non-FIPS mode, the authentication mode is password for VTY lines, and none for the AUX lines.
In FIPS mode, the authentication mode is scheme.
none: Disables authentication.
password: Performs local password authentication.
scheme: Performs AAA authentication. For more information about AAA, see Security Configuration Guide.
When the authentication mode is none, a user can log in without authentication. To improve device security, use the password or scheme authentication mode.
In VTY line view, this command is associated with the protocol inbound command. If you specify a non-default value for only one of the two commands in VTY line view, the other command uses the default setting, regardless of the setting in VTY line class view.
# Enable the none authentication mode for user line VTY 0.
[Sysname] line vty 0
[Sysname-line-vty0] authentication-mode none
# Enable password authentication for user line VTY 0 and set the password to 321.
[Sysname-line-vty0] authentication-mode password
[Sysname-line-vty0] set authentication password simple 321
# Enable scheme authentication for user line VTY 0. Configure local user 123 and set the password to 321. Assign the Telnet service and the user role network-admin to the user.
[Sysname-line-vty0] authentication-mode scheme
[Sysname-line-vty0] quit
[Sysname] local-user 123
[Sysname-luser-manage-123] password simple 321
[Sysname-luser-manage-123] service-type telnet
[Sysname-luser-manage-123] authorization-attribute user-role network-admin
auto-execute command
CAUTION
CAUTION:
After configuring this command for a user line, you might be unable to access the CLI through the user line. Make sure you can access the CLI through a different user line before you configure this command and save the configuration.
Use auto-execute command to specify a command that is automatically executed when a user logs in through the current user line.
Use undo auto-execute command to remove the configuration.
auto-execute command command
Command auto-execution is disabled.
command: Specifies the command to be automatically executed.
This command is not supported in AUX line view or AUX line class view.
The device automatically executes the specified command when a user logs in through the user line, and closes the user connection after the command is executed. If the command triggers another task, the device does not close the user connection until the task is completed.
Typically, you configure the auto-execute command telnet X.X.X.X command on the device so the device redirects a Telnet user to the host at X.X.X.X. In this case, the connection to the current device is closed when the user terminates the Telnet connection to X.X.X.X.
# Configure the device to automatically Telnet to 192.168.1.41 after a user logs in through user line VTY 0.
[Sysname-line-vty0] auto-execute command telnet 192.168.1.41
% This action will lead to configuration failure through line-vty0. Are you sure?
[Y/N]:y
[Sysname-line-vty0]
# To verify the configuration, Telnet to 192.168.1.40.
The device automatically Telnets to 192.168.1.41, and the following output is displayed:
C:\> telnet 192.168.1.40
* Copyright (c) 2004-2014 Hangzhou H3C Tech. Co., Ltd. All rights reserved.  *
Trying 192.168.1.41 ...
Press CTRL+K to abort
Connected to 192.168.1.41 ...
<Sysname.41>
This operation is the same as directly logging in to the device at 192.168.1.41 through Telnet. When you break the Telnet connection to 192.168.1.41, the Telnet connection to 192.168.1.40 is broken at the same time.
command accounting
Use command accounting to enable command accounting.
Use undo command accounting to restore the default.
command accounting
Command accounting is disabled, and the accounting server does not record executed commands.
When command accounting is enabled but command authorization is not, every executed command is recorded on the HWTACACS server.
When both command accounting and command authorization are enabled, only authorized commands that are executed are recorded on the HWTACACS server.
Invalid commands issued by users are not recorded.
If the command accounting command is configured in user line class view, command accounting is enabled on all user lines in the class. You cannot configure the undo command accounting command in the view of a user line in the class.
# Enable command accounting for user line VTY 0.
[Sysname-line-vty0] command accounting
·     accounting command (Security Command Reference)
·     command authorization
Use command authorization to enable command authorization.
Use undo command authorization to restore the default.
Command authorization is disabled. Logged-in users can execute commands without authorization.
When command authorization is enabled, a command is available only if the following requirements are met:
·     The user has the commensurate user role.
·     The user is authorized to use the command by the AAA scheme.
If the command authorization command is configured in user line class view, command authorization is enabled on all user lines in the class. You cannot configure the undo command authorization command in the view of a user line in the class.
# Enable command accounting for VTY 0 so the VTY 0 user can execute only authorized commands that are permitted by the user role.
[Sysname-line-vty0] command authorization
·     authorization command (Security Command Reference)
·     command accounting
databits
Use databits to specify the number of data bits for each character.
Use undo databits to restore the default.
databits { 5 | 6 | 7 | 8 }
undo databits
Eight data bits are used for each character.
User line view
5: Uses five data bits for each character.
6: Uses six data bits for each character.
7: Uses seven data bits for each character.
8: Uses eight data bits for each character.
This command is not supported in VTY line class view.
This setting must be the same as that on the configuration terminal.
# Configure AUX 0 to use five data bits for each character.
[Sysname-line-aux0] databits 5
display line
Use display line to display user line information.
display line [ number1 | { aux | vty } number2 ] [ summary ]
number1: Specifies the absolute number of a user line, in the range of 0 to 192.
aux: Specifies the AUX line.
vty: Specifies the VTY line.
number2: Specifies the relative number of a user line. The value range is 0 to 128 for the AUX line and 0 to 63 for the VTY line.
summary: Displays summary information about user lines. If you do not specify this keyword, the detailed information is displayed.
# Display user line information.
<Sysname> display line 0
  Idx  Type     Tx/Rx      Modem Auth  Int
  0    AUX 0    9600       -     N     -
  +    : Line is active.
  F    : Line is active and in async mode.
  Idx  : Absolute index of line.
  Type : Type and relative index of line.
  Auth : Login authentication mode.
  Int  : Physical port of the line.
  A    : Authentication use AAA.
  N    : No authentication is required.
  P    : Password authentication.
Modem
Whether the modem allows calling in or out. By default, this attribute is not configured and a hyphen (-) is displayed.
# Display summary information about all user lines.
<Sysname> display line summary
  Line type : [AUX]
           0:UXXX XXXX XXXX XXXX
         112:XXXX XXXX XXXX XXXX
  Line type : [VTY]
         129:UUXX XXXX XXXX XXXX
         176:XXXX XXXX XXXX XXXX
   3 lines used.      (U)
   190 lines not used.  (X)
Fields
number:status
The number indicates the absolute number of the first user line of the user line class, starting from 0. The status indicates whether the user lines of the user line class are being used (X for unused and U for used).
For example, if "0:UXXX XXXX XXXX XXXX" is displayed, there are ten user lines of the user line class, which use the absolute numbers 0 through 15. User line 0 is being used. The other user lines are not.
display telnet client
Use display telnet client to display the source address or interface for outgoing Telnet packets when the device acts as a Telnet client.
# Display the Telnet client configuration of the device when it acts as a Telnet client.
<Sysname> display telnet client
 The source IP address is 1.1.1.1.
The output shows that the device uses the source IPv4 address 1.1.1.1 for outgoing Telnet packets when it acts as a Telnet client.
telnet client source
display user-interface
Use display user-interface to display user line information.
display user-interface [ number1 | { aux | vty } number2 ] [ summary ]
This command is an older version reserved for backward compatibility purposes. H3C recommends that you use the display line command.
<Sysname> display user-interface 0
  0    AUX 0    9600       -     N     -
  +    : Line is active.
Modem
<Sysname> display user-interface summary
  Line type : [AUX]
  Line type : [VTY]
   3 lines used.      (U)
Fields
number:status
display users
Use display users to display online CLI user information.
display users [ all ]
all: Displays all user lines supported by the device.
# Display online user information.
<Sysname> display users
  Idx  Line    Idle       Time              Pid     Type
  129   VTY 0   00:10:49   Jun 11 11:27:32   320     TEL
+ 130   VTY 1   00:00:00   Jun 11 11:39:40   334     TEL
Following are more details.
VTY 0   :
VTY 1   :
 +    : Current operation user.
 F    : Current operation user works in async mode.
The output shows that two users have logged in to the device: one is using user line VTY 0 and the other (yourself) is using VTY 1. Your IP address is 192.168.1.26.
Table 5 Command output
Idx
Absolute number of the user line.
Line
Type and relative number of the user line.
Idle
Time elapsed after the user's most recent input, in the format hh:mm:ss.
Time
Login time of the user.
Pid
Process ID of the user session.
User type, such as Telnet, SSH.
Indicates the user line you are using.
Location
IP address of the user.
escape-key
Use escape-key to define a shortcut key for terminating a task.
Use undo escape-key to disable the shortcut key for terminating a task.
escape-key { key-string| default }
undo escape-key
Pressing Ctrl+C terminates a task.
key-string: Specifies the shortcut key. It can be a character, or an ASCII code value in the range of 0 to 127. For example, escape-key 65 defines the shortcut key A. If you configure escape-key a, the shortcut key is a.
default: Restores the default escape key sequence Ctrl+C.
Some commands might take a long time to complete in certain situations. Examples include:
·     A ping command that has 1000 packets to send.
·     A tracert command that is used for an unreachable destination.
To stop a command, press the shortcut key for terminating tasks.
Whether a command can be terminated by Ctrl+C by default depends on the software implementation of the command. For more information, see the description of the command.
H3C recommends that you use a key sequence as the shortcut key. If you define a single character as the shortcut key, pressing the key while a command is being executed stops the command. If no command is being executed, the result depends on the following situations:
·     If you are managing the local device, pressing the key enters the character as a common character.
·     If you Telnet to another device and manage the remote device, pressing the key does nothing.
You can execute this command multiple times, but only the most recent configuration takes effect. To view the current shortcut key definition, use the display current-configuration command.
# Define character a as the shortcut key for terminating a task.
[Sysname-line-aux0] escape-key a
1.     Ping IP address 192.168.1.49, specifying the -c keyword to set the number of ICMP echo request packets to 20.
<Sysname> ping -c 20 192.168.1.49
  PING 192.168.1.49: 56  data bytes, press a to break
    Reply from 192.168.1.49: bytes=56 Sequence=1 ttl=255 time=3 ms
    Reply from 192.168.1.49: bytes=56 Sequence=2 ttl=255 time=3 ms
2.     Press a.
The task is terminated, and the system returns to user view.
  --- 192.168.1.49 ping statistics ---
    2 packet(s) transmitted
    2 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 3/3/3 ms
<Sysname>
flow-control
Use flow-control to configure the flow control mode.
Use undo flow-control to restore the default.
undo flow-control
The flow control mode is none.
User line view
hardware: Performs hardware flow control.
none: Disables flow control.
software: Performs software flow control.
This command is not supported in VTY line view.
The device supports flow control in both the inbound and outbound directions.
·     For flow control in the inbound direction, the local device listens to flow control information from the remote device.
·     For flow control in the outbound direction, the local device sends flow control information to the remote device.
The flow control setting takes effect in both directions.
To communicate, two devices must be configured with the same flow control mode.
# Configure software flow control in the inbound and outbound directions for user line AUX 0.
[Sysname-line-aux0] flow-control software
free line
Use free line to release a user line.
free line { number1 | { aux | vty } number2 }
This command does not release the line you are using.
# Release user line VTY 1:
1.     Display online users.
VTY 0   :
VTY 1   :
2.     If the operations of the user on VTY 1 impact your operations, log out the user.
<Sysname> free line vty 1
Are you sure to free line vty1? [Y/N]:y
 [OK]
free user-interface
Use free user-interface to release a user line.
free user-interface { number1 | { aux | vty } number2 }
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the free line command.
  Idx  LINE    Idle       Time              Pid     Type
VTY 0   :
VTY 1   :
<Sysname> free user-interface vty 1
 [OK]
history-command max-size
Use history-command max-size to set the size of the command history buffer for a user line.
Use undo history-command max-size to restore the default.
history-command max-size size-value
The buffer of a user line saves up to 10 history commands.
size-value: Specifies the maximum number of history commands the buffer can store, in the range of 0 to 256.
Each user line uses a separate command history buffer to save commands successfully executed by its user. The size of the buffer determines how many history commands the buffer can store.
To view stored history commands on your user line, press the up or down arrow key, or execute the display history-command command.
Terminating a CLI session clears the commands in the history buffer.
# Set the size of the command history buffer to 20 for user line AUX 0.
[Sysname-line-aux0] history-command max-size 20
idle-timeout
Use idle-timeout to set the session idle timeout.
Use undo idle-timeout to restore the default.
undo idle-timeout
The idle-timeout interval is 10 minutes.
minutes: Specifies the number of minutes for the idle timeout, in the range of 0 to 35791. The default is 10 minutes.
seconds: Specifies the number of seconds for the idle timeout, in the range of 0 to 59. The default is 0 seconds.
The system automatically terminates a user connection if no information interaction occurs on the connection within the idle-timeout interval.
Setting the idle timeout to 0 disables the idle timeout function.
# Set the idle timeout to 1 minute and 30 seconds for user line AUX 0.
[Sysname-line-aux0] idle-timeout 1 30
line
Use line to enter one or multiple user line views.
line { first-number1 [ last-number1 ] | { aux | vty } first-number2 [ last-number2 ] }
first-number1: Specifies the absolute number of the first user line, in the range of 0 to 192.
last-number1: Specifies the absolute number of the last user line. This number cannot be smaller than first-number1.
first-number2: Specifies the relative number of the first user line. The value range is 0 to 128 for the AUX line and 0 to 63 for the VTY line.
last-number2: Specifies the relative number of the last user line. This number cannot be smaller than first-number2.
To configure settings for a single user line, use this command to enter the user line view.
To configure the same settings for multiple user lines, use this command to enter multiple user line views.
# Enter the view of user line AUX 0.
[Sysname-line-aux0]
# Enter the views of user lines VTY 0 to VTY 4.
[Sysname] line vty 0 4
[Sysname-line-vty0-4]
line class
line class
Use line class to enter user line class view.
line class { aux | vty }
aux: Specifies the AUX line class view.
vty: Specifies the VTY line class view.
To configure the same settings for all user lines of a line class, use this command to enter the user line class view.
·     A setting in user line view takes effect immediately and affects the online user. A setting in user line class view takes effect only for new login users. It does not affect online users.
# Set the user connection timeout to 15 minutes in VTY line class view.
[Sysname] line class vty
[Sysname-line-class-vty] idle-timeout 15
# In AUX line class view, configure character s as the shortcut key for starting a terminal session.
[Sysname] line class aux
[Sysname-line-class-aux] activation-key s
[Sysname-line-class-aux] quit
# In AUX line view, restore the default shortcut key for starting a terminal session.
[Sysname-line-aux0] undo activation-key
Alternatively:
[Sysname-line-aux0] activation-key 13
<Sysname> quit
3.     Press Enter.
4.     Enter s.
<Sysname>
line
lock
Use lock to lock the current user line. This method prevents unauthorized users from using the user line.
lock
By default, the system does not lock any user lines.
This command is not supported in FIPS mode.
After executing the lock command, enter the password for unlocking the user line and confirm the password by entering it again.
To unlock the user line, press Enter and enter the correct password.
# Lock the current user line and then unlock it.
<Sysname> lock
Please input password<1 to 16> to lock current line:
Password:
Again:
                   locked !
// The user line is locked. To unlock it, press Enter and enter the password:
Password:
<Sysname>
parity
Use parity to specify a parity check mode.
Use undo parity to restore the default.
undo parity
The setting is none, and no parity check is performed.
User line view
even: Performs even parity check.
mark: Performs mark parity check.
none: Disables parity check.
odd: Performs odd parity check.
space: Performs space parity check.
The configuration terminal and the device must be configured with the same parity check mode to communicate.
# Configure user line AUX 0 to perform odd parity check.
[Sysname-line-aux0] parity odd
protocol inbound
Use protocol inbound to enable a user line to support Telnet, SSH, or both protocols.
Use undo protocol inbound to restore the default.
In non-FIPS mode:
protocol inbound { all |ssh | telnet }
In FIPS mode:
protocol inbound ssh
In non-FIPS mode, both protocols are supported.
In FIPS mode, SSH is supported.
VTY line view, VTY line class view
all: Supports both protocols.
ssh: Supports SSH only.
telnet: Supports Telnet only.
A protocol change does not take effect for current online users. It takes effect only for new login users.
Before configuring a user line to support SSH, set the authentication mode to scheme for the user line. For more information, see authentication-mode.
This command is available in both VTY line view and VTY line class view. In VTY line view, this command is associated with the authentication-mode command. If you specify a non-default value for only one of the two commands in VTY line view, the other command uses the default setting, regardless of the setting in VTY line class view.
# Enable user lines VTY 0 through VTY 4 to support only SSH.
[Sysname-line-vty0-4] authentication-mode scheme
[Sysname-line-vty0-4] protocol inbound ssh
# Enable SSH support and set the authentication mode to scheme in VTY line class view. Enable user lines VTY 0 through VTY 4 to support all protocols and disable authentication for the user lines.
[Sysname-line-class-vty] authentication-mode scheme
[Sysname-line-class-vty] protocol inbound ssh
[Sysname-line-class-vty] line vty 0 4
[Sysname-line-vty0-4] authentication-mode none
1.     Telnet to the device.
<Client> telnet 192.168.1.241
Trying 192.168.1.241 ...
Connected to 192.168.1.241 ...
<Server>
You are logged in without authentication.
2.     Display online CLI user information.
<Server> display users
+ 50   VTY 0   00:00:00   Jan 17 15:29:27   189     TEL
VTY 0   :
The output shows that you are using VTY 0. The configuration in user line view is effective.
screen-length
Use screen-length to set the maximum number of lines to be displayed on a screen.
Use undo screen-length to restore the default.
screen-length screen-length
undo screen-length
Up to 24 lines are displayed on a screen.
screen-length: Specifies the maximum number of lines to be displayed on a screen, in the range of 0 to 512. Setting this argument to 0 disables pausing between screens of output.
This command sets the maximum number of lines that can be displayed on one screen when the screen pause function is enabled. If the screen pause function is disabled, the system displays command output without a pause.
The actual number of lines that can be displayed on a screen is restricted by the display specification of the configuration terminal. For example, if you set the maximum number of lines for a screen to 40, the device sends 40 lines to the screen at a time. If the display specification is 24 lines, only the last 24 lines are displayed on the screen. To view the previous 16 lines, you must press PgUp.
The screen pause function is enabled by default. To disable this function, execute the screen-length 0 command or the screen-length disable command. The screen-length disable command is available in user view.
# Set the maximum number of lines to be displayed on a screen to 30 for user line AUX 0.
[Sysname-line-aux0] screen-length 30
send
Use send to send messages to user lines.
send { all | number1 | { aux | vty } number2 }
all: Specifies all user lines.
To end a message, press Enter. To cancel a message and return to user view, press Ctrl+C.
# Before you restart the device, send a notification to VTY 1 to inform the user.
<Sysname> send vty 1
Input message, end with Enter; abort with CTRL+C:
Your attention, please. I will reboot the system in 3 minutes.
Send message? [Y/N]:y
The message should appear on the screen of the user's configuration terminal, as shown in the following example:
[Sysname]
***Message from vty0 to vty1
Use set authentication password to set a password for password authentication.
Use undo set authentication password to remove the password.
set authentication password { hash | simple } password
No password is set for password authentication.
hash: Sets a hashed password.
simple: Sets a plaintext password.
password: Specifies the password string. This argument is case sensitive. If simple is specified, it must be a string of 1 to 16 characters. If hash is specified, it must be a string of 1 to 110 characters.
For security purposes, the password is hashed before being saved, whether you specify the hash or simple keyword.
# Set the password for password authentication on user line AUX 0 to hello.
[Sysname-line-aux0] authentication-mode password
[Sysname-line-aux0] set authentication password simple hello
When you log in again through user line AUX 0, you must enter the password hello to pass authentication.
authentication-mode
shell
Use shell to enable the terminal service for a user line.
Use undo shell to disable the terminal service for a user line.
shell
undo shell
The terminal service is enabled on all user lines.
The undo shell command is not supported in AUX line view or AUX line class view.
You cannot disable the terminal service on the user line you are using.
When the device operates as a Telnet or SSH server, you cannot configure the undo shell command.
If the undo shell command is configured in user line class view, you cannot configure the shell command in the view of a user line in the class.
# Disable the terminal service for user line VTY 0 through VTY 4 so no user can log in to the device through the user lines.
[Sysname-line-vty0-4] undo shell
Disable ui-vty0-4 , are you sure? [Y/N]:y
speed
Use speed to set the transmission rate (also called the "baud rate") on a user line.
Use undo speed to restore the default.
speed speed-value
undo speed
The transmission rate is 9600 bps.
User line view
speed-value: Specifies the transmission rate in bps. Supported transmission rates vary by configuration environment. The transmission rates for asynchronous serial interfaces might include:
·     300 bps.
·     600 bps.
·     1200 bps.
·     2400 bps.
·     4800 bps.
·     9600 bps.
·     19200 bps.
·     38400 bps.
·     57600 bps.
·     115200 bps.
The configuration terminal and the device must be configured with the same transmission rate to communicate.
# Set the transmission rate to 19200 bps for user line AUX 0.
[Sysname-line-aux0] speed 19200
stopbits
Use stopbits to specify the number of stop bits for a character.
Use undo stopbits to restore the default.
stopbits { 1 | 1.5 | 2 }
undo stopbits
One stop bit is used.
User line view
1: Uses one stop bit.
1.5: Uses one and a half stop bits. The device does not support using one and a half stop bits. If you specify this keyword, two stop bits are used.
2: Uses two stop bits.
The configuration terminal and the device must be configured to use the same number of stop bits to communicate.
# Set the number of stop bits to 1 for user line AUX 0.
[Sysname-line-aux0] stopbits 1
telnet
Use telnet to Telnet to a host in an IPv4 network.
telnet remote-host [ service-port ] [ vpn-instance vpn-instance-name ] [ source { interface interface-type interface-number | ip ip-address } ] [ dscp dscp-value ]
remote-host: Specifies the IPv4 address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
service-port: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
vpn-instance vpn-instance-name: Specifies the VPN instance to which the remote host belongs, where vpn-instance-name is a case-sensitive string of 1 to 31 characters. If the remote host belongs to the public network, do not specify this option.
source: Specifies a source IPv4 address or source interface for outgoing Telnet packets.
interface interface-type interface-number: Specifies the source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies the source IPv4 address for outgoing Telnet packets.
dscp dscp-value: Specifies the DSCP value for IP to use in outgoing Telnet packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 48.
To terminate the current Telnet connection, press Ctrl+K or execute the quit command.
The source address or interface specified by this command is applied only to the current Telnet connection.
# Telnet to host 1.1.1.2, using 1.1.1.1 as the source IP address for outgoing Telnet packets.
<Sysname> telnet 1.1.1.2 source ip 1.1.1.1
Use telnet client source to specify a source IPv4 address or source interface for outgoing Telnet packets when the device acts as a Telnet client.
Use undo telnet client source to remove the configuration.
No source IPv4 address or source interface is specified for outgoing Telnet packets. The source IPv4 address is the primary IPv4 address of the outbound interface.
interface interface-type interface-number: Specifies a source interface. The primary IPv4 address of the interface will be used as the source IPv4 address for outgoing Telnet packets.
ip ip-address: Specifies a source IPv4 address.
The source IPv4 address or source interface that is specified by this command applies to all Telnet connections. However, if a user specifies a source IPv4 address or source interface when executing the telnet command, the setting specified by the user takes effect.
# Set the source IPv4 address for outgoing Telnet packets to 1.1.1.1 when the device acts as a Telnet client.
[Sysname] telnet client source ip 1.1.1.1
display telnet client configuration
telnet ipv6
Use telnet ipv6 to Telnet to a host in an IPv6 network.
telnet ipv6 remote-host [ -i interface-type interface-number ] [ port-number ] [ vpn-instance vpn-instance-name ] [ dscp dscp-value ]
remote-host: Specifies the IP address or host name of a remote host. A host name can be a case-insensitive string of 1 to 253 characters. Valid characters for a host name include letters, digits, hyphens (-), underscores (_), and dots (.).
-i interface-type interface-number: Specifies the outbound interface for sending Telnet packets. This option is required when the destination address is a link-local address. When the destination address is a global unicast address, you cannot specify this option.
port-number: Specifies the TCP port number for the Telnet service on the remote host. The value range is 0 to 65535 and the default is 23.
dscp dscp-value: Specifies the DSCP value for IPv6 to use in outgoing Telnet packets to indicate the packet transmission priority. The value range is 0 to 63. The default is 48.
# Telnet to the host at 5000::1.
<Sysname> telnet ipv6 5000::1
telnet server acl
Use telnet server acl to apply an ACL to filter Telnet logins.
Use undo telnet server acl to restore the default.
telnet server acl acl-number
No ACL is used to filter Telnet logins.
acl-number: Specifies an ACL by its number. The following are the value ranges:
·     Basic ACL—2000 to 2999.
·     Advanced ACL—3000 to 3999.
·     Ethernet frame header ACL—4000 to 4999.
Only one ACL can be used to filter Telnet logins, and only users permitted by the ACL can Telnet to the device.
This command does not take effect on existing Telnet connections.
You can specify an ACL that has not been created yet in this command. The command takes effect after the ACL is created.
For more information about ACL, see ACL and QoS Configuration Guide.
# Permit only the user at 1.1.1.1 to Telnet to the device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0
[Sysname-acl-basic-2001] quit
[Sysname] telnet server acl 2001
telnet server dscp
Use telnet server dscp to set the DSCP value for IPv4 to use for outgoing Telnet packets on a Telnet server.
Use undo telnet server dscp to restore the default.
telnet server dscp dscp-value
IPv4 uses the DSCP value 48 for outgoing Telnet packets on a Telnet server.
dscp-value: Specifies a DSCP value in the range of 0 to 63.
The DSCP value is carried in the ToS field of an IP packet, and it indicates the transmission priority of the packet.
# Set the DSCP value for IPv4 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server dscp 30
telnet server enable
Use telnet server enable to enable the Telnet server function.
Use undo telnet server enable to disable the Telnet server function.
The Telnet server function is disabled.
Administrators can Telnet to the device only when the Telnet server function is enabled.
# Enable the Telnet server function.
telnet server ipv6 acl
Use telnet server ipv6 acl to apply an IPv6 ACL to filter IPv6 Telnet logins.
Use undo telnet server ipv6 acl to restore the default.
telnet server ipv6 acl [ ipv6 ] acl-number
No ACL is used to filter IPv6 Telnet logins.
acl-number: Specifies an IPv6 ACL by its number. The following are the value ranges:
·     Basic ACL—2000 to 2999. The ipv6 option is required.
·     Advanced ACL—3000 to 3999. The ipv6 option is required.
·     Ethernet frame header ACL—4000 to 4999. Do not specify the ipv6 option.
If the ACL does not exist or does not have a rule, all users are permitted to Telnet to the device.
When the ACL exists and has rules, only users permitted by the ACL can Telnet to the device.
This command is not effective for existing Telnet connections.
# Permit only the user at 2000::1 to Telnet to the device.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2000::1 128
[Sysname-acl6-basic-2001] quit
[Sysname] telnet server ipv6 acl ipv6 2001
telnet server ipv6 dscp
Use telnet server ipv6 dscp to set the DSCP value for IPv6 to use for outgoing Telnet packets on a Telnet server.
Use undo telnet server ipv6 dscp to restore the default.
IPv6 uses the DSCP value 48 for outgoing Telnet packets on a Telnet server.
The DSCP value is carried in the Traffic class field of an IPv6 packet, and it indicates the transmission priority of the packet.
# Set the DSCP value for IPv6 to use for outgoing Telnet packets to 30 on a Telnet server.
[Sysname] telnet server ipv6 dscp 30
terminal type
Use terminal type to specify the terminal display type.
Use undo terminal type to restore the default.
undo terminal type
The terminal display type is ANSI.
ansi: Specifies the terminal display type ANSI.
vt100: Specifies the terminal display type VT100.
The device supports two terminal display types: ANSI and VT100. H3C recommends that you set the display type to VT100 on both the device and the configuration terminal. If either side uses the ANSI type, a display problem such as cursor positioning error might occur when a command line has more than 80 characters.
# Set the terminal display type to VT100.
[Sysname-line-vty0] terminal type vt100
user-interface
Use user-interface to enter one or multiple user line views.
user-interface { first-number1 [ last-number1 ] | { aux | vty } first-number2 [ last-number2 ] }
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the line command.
[Sysname] user-interface aux 0
[Sysname-line-aux0]
[Sysname] user-interface vty 0 4
user-interface class
Use user-interface class to enter user line class view.
user-interface class { aux | vty }
This command is an older version reserved for backward compatibility purposes. H3C recommends you use the line class command.
To configure the same settings for all user lines of a line class, you can use this command to enter the user line class view.
[Sysname] user-interface class vty
[Sysname] user-interface class aux
Alternatively:
<Sysname> quit
3.     Press Enter.
4.     Enter s.
<Sysname>
user-interface
user-role
Use user-role to assign a user role to a user line so users logged in through the user line get the user role at login.
Use undo user-role to remove a user role or restore the default.
user-role role-name
undo user-role [ role-name ]
An AUX line user is assigned the user role network-admin. Users of other user lines are assigned the user role network-operator.
role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters. The user role can be user-defined or predefined (network-admin, network-operator, or level-0 to level-15). If you do not specify this argument, the undo user-role command restores the default user role.
You can assign up to 64 user roles to a user line. A user logged in through the user line gets all the user roles.
For more information about user roles, see "Configuring RBAC."
# Assign user role network-admin through the user line VTY 0.
[Sysname-line-vty0] user-role network-admin
