01 Fundamentals Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10001 Fundamentals Command Reference
06-Configuration file management commands
06-Configuration file management commands 147.32 KB
archive configuration
Use archive configuration to manually archive the running configuration to the configuration archive directory.
Before manually archiving the running configuration, you must use the archive configuration location command to specify a directory and a name prefix for the configuration archives.
Configuration archive facilitates configuration rollback. It provides manual and automatic methods for saving the running configuration. For more information about the archiving mechanism, see the section about configuration rollback in Fundamentals Configuration Guide.
# Archive the running configuration.
<Sysname> archive configuration
Save the running configuration to an archive file. Continue? [Y/N]: Y
The archive configuration file myarchive_1.cfg is saved.
·     archive configuration interval
·     archive configuration location
·     archive configuration max
·     display archive configuration
Use archive configuration interval to enable automatic running-configuration archiving and set the archiving interval.
Use undo archive configuration interval to restore the default.
archive configuration interval minutes
The system does not automatically archive the running configuration.
minutes: Specifies the interval (in minutes) for automatically saving the running configuration. The value range is 10 to 525600 (365 days).
Before enabling automatic configuration archiving, use the archive configuration location command to specify the configuration archive directory and archive file name prefix.
Configuration archive is a function that facilitates configuration rollback. It provides manual and automatic methods for saving the running configuration.
Automatic configuration archiving enables the system to save the running configuration to the archive directory at the specified interval. For more information about the archiving mechanism, see the section about configuration rollback in Fundamentals Configuration Guide.
Change the archiving interval depending on the amount of available storage space. The shorter the interval, the more free storage space is required.
# Configure the system to archive the running configuration every 60 minutes.
[Sysname] archive configuration interval 60
Archive files will be saved every 60 minutes.
Use archive configuration location to configure the directory and file name prefix for archiving the running configuration.
Use undo archive configuration location to restore the default.
archive configuration location directory filename-prefix filename-prefix
No configuration archive directory or configuration archive file name prefix has been set.
directory: Specifies the name of a configuration archive directory, a case-insensitive string of 1 to 63 characters. The directory name must take the format storage-medium-name:/folder-name. This directory must already exist on the master.
filename-prefix: Specifies a file name prefix for configuration archives, a case-insensitive string of 1 to 30 characters. Valid characters are letters, digits, underscores (_), and hyphens (-).
Before archiving the running configuration, either manually or automatically, you must configure a directory and file name prefix for configuration archives.
In an IRF fabric, the configuration archive function saves the running configuration only on the master device. To ensure that the system can archive the running configuration after a master/subordinate switchover, create the directory on all IRF members.
Configuration archives take the file name format prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
After you change the file directory or file name prefix, or reboot the device, all of the following events occur:
·     The old configuration archives are regarded as common configuration files.
·     The configuration archive counter is reset.
·     The display archive configuration command no longer displays the old configuration archives.
·     The serial number for new configuration archives starts at 1.
The undo archive configuration location command removes the configuration archive directory and file name prefix settings. The command also performs the following tasks:
·     Disables the configuration archive function (both manual and automatic methods).
·     Restores the default settings of the archive configuration interval and archive configuration max commands.
·     Clears all configuration archives.
# Configure the configuration archive directory as flash:/archive and the archive file name prefix as my_archive.
<Sysname> mkdir flash:/archive
Creating directory flash:/archive... Done.
[Sysname] archive configuration location flash:/archive filename-prefix my_archive
Use archive configuration max to set the maximum number of configuration archives.
Use undo archive configuration max to restore the default.
archive configuration max file-number
Up to five configuration archives can be saved.
file-number: Sets the maximum number of configuration archives that can be saved. The value range is 1 to 10. Adjust the setting depending on the amount of storage space available.
Before you can set a limit on configuration archives, use the archive configuration location command to specify a configuration archive directory and archive file name prefix.
After the maximum number of configuration archives is reached, the system deletes the oldest archive for the new archive.
Changing the limit setting to a lower value does not cause immediate deletion of excess archives. Instead, the configuration archive function deletes the oldest n files when a new archive is manually or automatically saved, where n = current archive count – new archive limit + 1.
Suppose seven configuration archives have been saved before the archive limit is set to four. When saving a new configuration archive, the system first deletes the oldest four (7 – 4 + 1) archives.
If you execute the undo archive configuration location command, the default archive limit is restored.
# Set the maximum number of configuration archives to 10.
[Sysname] archive configuration max 10
backup startup-configuration
Use backup startup-configuration to back up the main next-startup configuration file to a TFTP server.
backup startup-configuration to tftp-server [ dest-filename ]
tftp-server: Specifies a TFTP server by its IPv4 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
dest-filename: Specifies the target file name used for saving the file on the server. The file name must use the .cfg extension. If you do not specify a target file name, the source file name is used.
This command is not supported in FIPS mode.
# Back up the main next-startup configuration file to the TFTP server at 2.2.2.2, and set the target file name to 192-168-1-26.cfg.
<Sysname> backup startup-configuration to 2.2.2.2 192-168-1-26.cfg
Backup next startup-configuration file to 2.2.2.2, please wait…finished
restore startup-configuration
configuration encrypt
Use configuration encrypt to enable configuration encryption.
Use undo configuration encrypt to restore the default.
configuration encrypt { private-key | public-key }
Configuration encryption is disabled. The running configuration is saved to a configuration file without encryption.
private-key: Encrypts configuration with a private key. All H3C devices running Comware V7 software use the same private key.
public-key: Encrypts configuration with a public key. All H3C devices running Comware V7 software use the same public key.
Configuration encryption enables the device to automatically encrypt a configuration file when saving the running configuration to the file.
Only H3C devices running Comware V7 software can decrypt the encrypted configuration file.
# Enable the public-key method for configuration encryption.
[Sysname] configuration encrypt public-key
configuration replace file
Use configuration replace file to perform configuration rollback.
filename: Specifies the name of the replacement configuration file suffixed with the .cfg extension. Excluding the .cfg extension, the file name is a case-insensitive string of 1 to 191 characters and can include path information. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.). If the file path includes a folder name, the folder must already exist.
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback function. This function helps you revert to a previous configuration state or adapt the running configuration to different network environments.
To ensure a successful rollback:
·     Make sure the replacement configuration file is created by using the configuration archive function or the save command on the device.
·     If the configuration file is not created on the device, make sure the command lines in the configuration file are fully compatible with the device.
·     Make sure the replacement configuration file is not encrypted.
# Replace the running configuration with the configuration in the my_archive_1.cfg configuration file.
[Sysname] configuration replace file my_archive_1.cfg
Current configuration will be lost, save current configuration? [Y/N]:n
Now replacing the current configuration. Please wait...
Succeeded in replacing current configuration with the file my_archive_1.cfg.
Use display archive configuration to display configuration archive information, including the archive directory, archive prefix, archive interval, maximum number of archives, and saved archives.
# Display configuration archive information.
<Sysname> display archive configuration
Filename prefix: my_archive
Archive interval in minutes: 120
Maximum number of archive files: 10
Saved archive files:
  No. TimeStamp                  FileName
  1   Wed Jan 15 14:20:18 2012   my_archive_1.cfg
  2   Wed Jan 15 14:33:10 2012   my_archive_2.cfg
# 3   Wed Jan 15 14:49:37 2012   my_archive_3.cfg
'#' indicates the most recent archive file.
Next archive file to be saved: my_archive_4.cfg
Location
Absolute path of the directory for saving running-configuration archives.
Filename prefix
File name prefix for configuration archives.
Interval (in minutes) for the system to automatically archive the running configuration.
If automatic configuration saving is disabled, this field is not available.
Maximum number of configuration archives that can be saved.
Saved archive files
Configuration archives that have been saved.
TimeStamp
Time when the configuration archive was created.
display current-configuration
Use display current-configuration to display the running configuration.
display current-configuration [ configuration [ module-name ] | interface [ interface-type [ interface-number ] ] ]
configuration [ module-name ]: Displays feature configuration. The module-name argument specifies a feature module. If no feature module is specified, this command displays all feature settings you have made. Available feature modules depend on the device configuration.
interface [ interface-type [ interface-number ] ]: Displays interface configuration, where the interface-type argument represents the interface type and the interface-number argument represents the interface number.
Use this command to verify the configuration you have made.
If the system has automatically changed the setting you have made for a parameter, this command displays the effective setting instead of the configured one. An automatic change typically occurs because of system restrictions.
Typically, this command does not display parameters that are using the default settings.
# Display local user configuration.
<Sysname> display current-configuration configuration local-user
local-user ftp
 password hash $h$6$4UDOXMkpPwLyMwIX$ohXVbEb+YPMceuyB1A9k+MBoylujMQSAedf+fskEIkYFqcIBXvAqvdbzgqFK2azda3BAtLeHakQe9hepn8ejsA==
 service-type ftp
local-user root
 password hash $h$6$zSWYxJ3Oj01iR7x1$a5BIEHfcqTUKrVkd6HB9vVLh8abWLm9sy/FW8J0ypdnqtH/Du6IU+9UlM8W5OM+ihHJAWXUkTEAoMuJKBwcogw==
return
# Display Ethernet interface configuration.
<Sysname> display current-configuration interface fortygige 1/1/1
interface FortyGigE1/1/1
port link-mode route
return
display current-configuration diff
Use display current-configuration diff to display the configuration differences between the current startup configuration file and the next-startup configuration file.
This command compares the current startup configuration file with the next-startup configuration file in the following steps:
1.     Compares the current startup configuration file with the main next-startup configuration file.
2.     If the main next-startup configuration file is unavailable or corrupt, this command compares the current startup configuration file with the backup next-startup configuration file.
If both the main and backup next-startup configuration files are unavailable or corrupt, the system prompts that the next-startup configuration file does not exist.
# Display the configuration differences between the current startup configuration file and the next-startup configuration file.
<TEST1> display current-configuration diff
--- Startup configuration
+++ Current configuration
@@ -6,7 +6,7 @@
  stp global enable
- sysname TEST
+ sysname TEST1
  telnet server enable
- - - Startup configuration
The next-startup configuration file.
The current startup configuration file.
@@ -linenumber1,number1 +linenumber2,number2 @@
Location summary for a command line difference:
·     -linenumber1 represents the line number of the different command line in the next-startup configuration file.
·     +linenumber2 represents the line number of the different command line in the current startup configuration file.
·     number1 represents the total number of lines excerpted from the next-startup configuration file for comparison. The lines help you further locate the difference.
·     number2 represents the total number of lines excerpted from the current startup configuration file for comparison. The lines help you further locate the difference.
- cmd
+ cmd
Different command lines in the compared configuration files:
·     The command line in the next-startup configuration file is prefixed with a minus sign (-).
·     The command line in the current startup configuration file is prefixed with a plus sign (+).
cmd
The command line without a minus sign (-) or a plus sign (+) provides a context for locating the different command lines.
·     display current-configuration
·     display diff
·     display saved-configuration
display default-configuration
Use display default-configuration to display the factory defaults.
Factory defaults are product-specific default settings that are different from initial settings. These default settings ensure that the device can start up and run correctly when it does not have a startup configuration file or the configuration file is corrupt.
# Display the factory defaults.
<Sysname> display default-configuration
display diff
Use display diff to display the configuration differences between two configuration files.
display diff configfile file-name-s { configfile file-name-d | current-configuration | startup-configuration }
display diff current-configuration { configfile file-name-d | startup-configuration }
display diff startup-configuration { configfile file-name-d | current-configuration }
configfile file-name-s: Specifies the source configuration file for comparison.
configfile file-name-d: Specifies the target configuration file for comparison.
current-configuration: Specifies the current startup configuration file. In the display diff current-configuration command, this keyword specifies the source configuration file for comparison. In the display diff configfile file-name-s and display diff startup-configuration commands, this keyword specifies the target configuration file.
startup-configuration: Specifies the next-startup configuration file. In the display diff startup-configuration command, this keyword specifies the source configuration file for comparison. In the display diff configfile file-name-s and display diff current-configuration commands, this keyword specifies the target configuration file.
If you specify the startup-configuration keyword, the system searches the next-startup configuration file for comparison in the following order:
1.     The main next-startup configuration file.
2.     The backup next-startup configuration file if the main next-startup configuration file is unavailable or corrupt.
# Display the configuration differences between test.cfg and testsys.cfg.
<Sysname> display diff configfile test.cfg configfile testsys.cfg
--- flash:/test.cfg
+++ flash:/testsys.cfg
@@ -6,7 +6,7 @@
  stp global enable
- sysname test
+ sysname test1
# Display the configuration differences between test.cfg and testsys.cfg on the master and subordinate devices.
<Sysname>display diff configfile slot1#flash:/test.cfg configfile slot2#flash:/testsys.cfg
--- flash:/test.cfg
+++ slot2#flash:/testsys.cfg
@@ -6,7 +6,7 @@
  stp global enable
- sysname TEST
+ sysname TEST1
<TEST> display diff current-configuration startup-configuration
--- Current configuration
+++ Startup configuration
@@ -6,7 +6,7 @@
  stp global enable
- sysname TEST
+ sysname TEST1
- - - file1.cfg
Name and directory of the source configuration file.
+++ file2.cfg
Name and directory of the target configuration file.
·     -linenumber1 represents the line number of the different command line in the source configuration file.
·     +linenumber2 represents the line number of the different command line in the target configuration file.
·     number1 represents the total number of lines excerpted from the source configuration file for comparison. The lines help you further locate the difference.
·     number2 represents the total number of lines excerpted from the target configuration file for comparison. The lines help you further locate the difference.
- cmd
+ cmd
·     The command line in the source configuration file is prefixed with a minus sign (-).
·     The command line in the target configuration file is prefixed with a plus sign (+).
cmd
·     display current-configuration diff
Use display saved-configuration to display the contents of the configuration file for the next system startup.
Use this command to verify that important settings have been saved to the configuration file for the next system startup.
This command selects the configuration file to display in the following order:
1.     If the main startup configuration file is available, this command displays the contents of the main startup configuration file.
2.     If only the backup startup configuration file is available, this command displays the contents of the backup file.
3.     If both the main and backup startup configuration files are not available, this command displays nothing.
# Display the contents of the configuration file for the next system startup.
<Sysname> display saved-configuration
 version 7.1.045, ESS 2415
 sysname Sysname
 ftp server enable
 domain default enable system
vlan 1
domain system
  ---- More ----
·     reset saved-configuration
·     save
display startup
Use display startup to display the names of the current startup configuration file and the next-startup configuration files.
display startup
Current startup configuration file is the configuration file that has been loaded. Next-startup configuration file is the configuration file used at the next startup.
All IRF members use the same current startup configuration file as the master. After a master/subordinate switchover, it is normal that the current startup configuration files on them are displayed as NULL. This is because the new master continues to run with the running configuration rather than rebooting with a startup configuration file.
# Display names of the startup configuration files.
<Sysname> display startup
MainBoard:
 Current startup saved-configuration file: flash:/startup.cfg
 Next main startup saved-configuration file: flash:/startup.cfg
 Next backup startup saved-configuration file: NULL
Slot 1:
MainBoard
Displays the startup configuration files on the master device.
Configuration file that the device has started up with.
Main configuration file to be used at the next startup.
Backup configuration file to be used at the next startup.
Slot n
Displays the startup configuration files on member device n.
display this
Use display this to display the running configuration in the current view.
display this
Use this command to verify the configuration you have made in a certain view.
Typically, this command does not display parameters that are set to their default settings.
Some parameters can be successfully configured even if their dependent features are not enabled. For these parameters, this command displays their settings after the dependent features are enabled.
This command can be executed in any user line view to display the running configuration of all user lines.
# Display the running configuration on interface FortyGigE 1/1/1.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] display this
return
# Display the running configuration on user lines.
[Sysname]line vty 0
[Sysname-line-vty0] display this
line aux 0
line vty 0 63
 authentication-mode none
return
Use reset saved-configuration to delete next-startup configuration files.
backup: Deletes the backup next-startup configuration file.
main: Deletes the main next-startup configuration file.
CAUTION:
Use this command with caution. This command permanently deletes the next-startup configuration files from all IRF member devices.
Delete a next-startup configuration file if it does not match the software version or is corrupt.
You can delete the main, the backup, or both.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file setting is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
If no configuration file attribute is specified, the reset saved-configuration command deletes the main next-startup configuration file.
# Delete the backup next-startup configuration file.
<Sysname> reset saved-configuration backup
The saved configuration file will be erased. Are you sure? [Y/N]:y
Configuration file in flash: is being cleared.
Please wait ...
MainBoard:
Configuration file is cleared.
Slot 2:
Erase next configuration file successfully
Use restore startup-configuration to download a configuration file from a TFTP server and specify it as the main next-startup configuration file.
restore startup-configuration from tftp-server src-filename
tftp-server: Specifies a TFTP server's IPv4 address or host name. The host name is a case-insensitive string of 1 to 253 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
src-filename: Specifies the file name of the configuration file to be downloaded. The name is suffixed with the .cfg extension. Excluding the .cfg extension, the file name is a case-insensitive string of 1 to 191 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.).
Before restoring the configuration file for the next startup, make sure the following requirements are met:
·     The server is reachable.
·     The server is enabled with TFTP service.
·     You have read and write permissions to the server.
This command provides an easy method for configuration file restoration by automatically performing all operations required for restoring the main next-startup configuration file.
The command downloads the configuration file to the root directory of each member device's default storage medium and specifies the file as the main next-startup configuration file.
If the USB disk is used and partitioned, the configuration file is saved on the first partition.
This command assumes that all IRF members use the same type of storage medium. If a subordinate device uses a different type of storage medium than the master, the command cannot propagate the configuration file to the subordinate device. For example, the subordinate device uses a USB disk, but the master uses a flash memory. In this situation, you must manually restore the main next-startup configuration file on the subordinate device.
# Download the configuration file config.cfg from the TFTP server at 2.2.2.2 and specify the file as the main next-startup configuration file.
<Sysname> restore startup-configuration from 2.2.2.2 config.cfg
Restoring the next startup-configuration file from 2.2.2.2. Please wait...finished.
Now restoring the next startup-configuration file from main board to backup board. Please wait...finished.
save
Use save file-url [ all | slot slot-number ] to save the running configuration to a configuration file, without specifying the file as a next-startup configuration file.
Use save [ safely ] [ backup | main ] [ force ] to save the running configuration to a file in the root directory of the default storage medium. This command applies to each member device. It automatically specifies the file as a next-startup configuration file.
file-url: Saves the running configuration to the specified file suffixed with the .cfg extension, without specifying the file as a next-startup configuration file. Excluding the .cfg extension, the file name is a case-insensitive string of 1 to 191 characters and can include path information. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.). If you specify the all keyword or a member ID, the file path cannot include a member ID. If the file path includes a folder name, the folder must already exist.
all: Saves the running configuration to all member devices. If you do not specify this keyword or the slot slot-number option, the command saves the running configuration only to the master.
slot slot-number: Saves the running configuration to a subordinate device. The slot-number argument represents the IRF member ID of the device. If you do not specify this option or the all keyword, the command saves the running configuration only to the master.
safely: Saves the configuration file in safe mode. If this keyword is not specified, the device saves the configuration file in fast mode. Safe mode is slower than fast mode, but more secure.
backup: Saves the running configuration to a configuration file, and specifies the file as the backup next-startup configuration file. If you do not specify this keyword or the main keyword, the command specifies the saved file as the main next-startup configuration file.
main: Saves the running configuration to a configuration file, and specifies the file as the main next-startup configuration file. If you do not specify this keyword or the backup keyword, the command specifies the saved file as the main next-startup configuration file.
force: Saves the running configuration without prompting for confirmation. Without this keyword, the system asks you to confirm the operation. If you do not confirm the operation within 30 seconds, the system automatically aborts the operation. If you enter Y within the time limit, you can continue the save process and change the target file name during the process.
If the file specified for the command does not exist, the system creates the file before saving the configuration. If the file already exists, the system prompts you to confirm whether to overwrite the file. If you choose to not overwrite the file, the system cancels the save operation.
If you do not specify the file-url option for the command, the command saves the running configuration to an .mdb binary file as well as a .cfg text file. The two files use the same file name. An .mdb file takes less time to load than a .cfg file.
If you specify the file-url option for the command, the command only saves the running configuration to the specified .cfg file.
In safe mode, the system saves configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot, power failure, or out of memory event occurs during the save operation, the next-startup configuration file is retained.
In fast mode, the device directly overwrites the target next-startup configuration file. If a reboot, power failure, or out of memory event occurs during this process, the next-startup configuration file is lost.
H3C recommends that you specify the safely keyword for the command.
# Save the running configuration to the configuration file backup.cfg, without specifying the file as the next-startup configuration file.
<Sysname> save backup.cfg
The current configuration will be saved to flash:/backup.cfg. Continue? [Y/N]:y
Now saving current configuration to the device.
Saving configuration
flash:/backup.cfg. Please wait...
Configuration is saved to flash successfully.
# Save the running configuration to the main next-startup configuration file without any confirmation required.
<Sysname> save force
Validating file. Please wait....
Configuration is saved to device successfully.
# Save the running configuration to a file in the root directory of the default storage medium, and specify the file as the main next-startup configuration file.
<Sysname> save
Slot 1:
Save next configuration file successfully.
Use startup saved-configuration to specify a file as a next-startup configuration file for all IRF member devices.
Use undo startup saved-configuration to configure all IRF member devices to start up with the factory defaults at the next startup.
No next-startup configuration file is specified.
cfgfile: Specifies the name of a configuration file suffixed with the .cfg extension. Excluding the .cfg extension, the file name is a case-insensitive string of 1 to 191 characters. Valid characters include letters, digits, hyphens (-), underscores (_), and dots (.). This .cfg file must already exist in the root directory of the default storage medium.
backup: Specifies the configuration file as the backup next-startup configuration file.
main: Specifies the configuration file as the main next-startup configuration file. This is the primary configuration file that the device attempts to load at startup. If the loading attempt fails, the device tries the backup next-startup configuration file.
CAUTION:
In an IRF fabric, use the undo startup saved-configuration command with caution. This command can cause an IRF split after the IRF fabric or an IRF member reboots.
In an IRF fabric, the startup saved-configuration command applies to all IRF members. To successfully configure the command, verify that the specified file already exists in the root directory of each member's default storage medium.
Make sure all member devices use the same type of storage medium as the default storage medium.
If the USB disk is used to store the next-startup configuration files, do not remove the USB disk during the startup process. If you remove the USB disk on a device, one of the following consequences occurs:
·     In a single-chassis IRF fabric, the device starts up with the factory defaults.
·     In a multichassis IRF fabric, the device leaves the IRF fabric at startup and runs the factory defaults.
If neither backup nor main is specified, the startup saved-configuration command specifies the main next-startup configuration file.
Even though the main and backup next-startup configuration files can be the same one, specify them as separate files for high availability.
The undo startup saved-configuration command changes the file attribute of the main and backup next-startup configuration files to NULL. The command does not delete the two configuration files.
You can also specify a configuration file as a next-startup file when you use the save command to save the running configuration to it.
# Specify the main next-startup configuration file.
<Sysname> startup saved-configuration testcfg.cfg
Please wait ....
... Done.
display startup
